path: root/lib/flex_array.c
2010-08-09flex_array: add helpers to get and put to make pointers easy to useEric Paris
Getting and putting arrays of pointers with flex arrays is a PITA. You have to remember to pass &ptr to the _put and you have to do weird and wacky casting to get the ptr back from the _get. Add two functions flex_array_get_ptr() and flex_array_put_ptr() to handle all of the magic. [akpm@linux-foundation.org: simplification suggested by Joe] Signed-off-by: Eric Paris <eparis@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Joe Perches <joe@perches.com> Cc: James Morris <jmorris@namei.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-24flex_array: fix the panic when calling flex_array_alloc() without __GFP_ZEROChangli Gao
memset() is called with the wrong address and the kernel panics. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: add missing kerneldoc annotationsDavid Rientjes
Add kerneldoc annotations for function formals of type struct flex_array and gfp_t which are currently lacking. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: introduce DEFINE_FLEX_ARRAYDavid Rientjes
FLEX_ARRAY_INIT(element_size, total_nr_elements) cannot determine if either parameter is valid, so flex arrays which are statically allocated with this interface can easily become corrupted or reference beyond its allocated memory. This removes FLEX_ARRAY_INIT() as a struct flex_array initializer since no initializer may perform the required checking. Instead, the array is now defined with a new interface: DEFINE_FLEX_ARRAY(name, element_size, total_nr_elements) This may be prefixed with `static' for file scope. This interface includes compile-time checking of the parameters to ensure they are valid. Since the validity of both element_size and total_nr_elements depend on FLEX_ARRAY_BASE_SIZE and FLEX_ARRAY_PART_SIZE, the kernel build will fail if either of these predefined values changes such that the array parameters are no longer valid. Since BUILD_BUG_ON() requires compile time constants, several of the static inline functions that were once local to lib/flex_array.c had to be moved to include/linux/flex_array.h. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: add flex_array_shrink functionDavid Rientjes
Add a new function to the flex_array API: int flex_array_shrink(struct flex_array *fa) This function will free all unused second-level pages. Since elements are now poisoned if they are not allocated with __GFP_ZERO, it's possible to identify parts that consist solely of unused elements. flex_array_shrink() returns the number of pages freed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: poison free elementsDavid Rientjes
Newly initialized flex_array's and/or flex_array_part's are now poisoned with a new poison value, FLEX_ARRAY_FREE. It's value is similar to POISON_FREE used in the various slab allocators, but is different to distinguish between flex array's poisoned kmem and slab allocator poisoned kmem. This will allow us to identify flex_array_part's that only contain free elements (and free them with an addition to the flex_array API). This could also be extended in the future to identify `get' uses on elements that have not been `put'. If __GFP_ZERO is passed for a part's gfp mask, the poisoning is avoided. These elements are considered to be in-use since they have been initialized. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: add flex_array_clear functionDavid Rientjes
Add a new function to the flex_array API: int flex_array_clear(struct flex_array *fa, unsigned int element_nr) This function will zero the element at element_nr in the flex_array. Although this is equivalent to using flex_array_put() and passing a pointer to zero'd memory, flex_array_clear() does not require such a pointer to memory that would most likely need to be allocated on the caller's stack which could be significantly large depending on element_size. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: convert element_nr formals to unsignedDavid Rientjes
It's problematic to allow signed element_nr's or total's to be passed as part of the flex array API. flex_array_alloc() allows total_nr_elements to be set to a negative quantity, which is obviously erroneous. flex_array_get() and flex_array_put() allows negative array indices in dereferencing an array part, which could address memory mapped before struct flex_array. The fix is to convert all existing element_nr formals to be qualified as unsigned. Existing checks to compare it to total_nr_elements or the max array size based on element_size need not be changed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix flex_array_free_parts commentDavid Rientjes
flex_array_free_parts() does not take `src' or `element_nr' formals, so remove their respective comments. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix get function for elements in base starting at non-zeroDavid Rientjes
If all array elements fit into the base structure and data is copied using flex_array_put() starting at a non-zero index, flex_array_get() will fail to return the data. This fixes the bug by only checking for NULL parts when all elements do not fit in the base structure when flex_array_get() is used. Otherwise, fa_element_to_part_nr() will always be 0 since there are no parts structures needed and such element may never have been put. Thus, it will remain NULL due to the kzalloc() of the base. Additionally, flex_array_put() now only checks for a NULL part when all elements do not fit in the base structure. This is otherwise unnecessary since the base structure is guaranteed to exist (or we would have already hit a NULL pointer). Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04flex_array: remove unneeded index calculationJonathan Corbet
flex_array_get() calculates an index value, then drops it on the floor; simply remove it. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29lib: flexible array implementationDave Hansen
Once a structure goes over PAGE_SIZE*2, we see occasional allocation failures. Some people have chosen to switch over to things like vmalloc() that will let them keep array-like access to such a large structures. But, vmalloc() has plenty of downsides. Here's an alternative. I think it's what Andrew was suggesting here: http://lkml.org/lkml/2009/7/2/518 I call it a flexible array. It does all of its work in PAGE_SIZE bits, so never does an order>0 allocation. The base level has PAGE_SIZE-2*sizeof(int) bytes of storage for pointers to the second level. So, with a 32-bit arch, you get about 4MB (4183112 bytes) of total storage when the objects pack nicely into a page. It is half that on 64-bit because the pointers are twice the size. There's a table detailing this in the code. There are kerneldocs for the functions, but here's an overview: flex_array_alloc() - dynamically allocate a base structure flex_array_free() - free the array and all of the second-level pages flex_array_free_parts() - free the second-level pages, but not the base (for static bases) flex_array_put() - copy into the array at the given index flex_array_get() - copy out of the array at the given index flex_array_prealloc() - preallocate the second-level pages between the given indexes to guarantee no allocs will occur at put() time. We could also potentially just pass the "element_size" into each of the API functions instead of storing it internally. That would get us one more base pointer on 32-bit. I've been testing this by running it in userspace. The header and patch that I've been using are here, as well as the little script I'm using to generate the size table which goes in the kerneldocs. http://sr71.net/~dave/linux/flexarray/ [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
