2020-11-10 | Fonts: Replace discarded const qualifier | Lee Jones | |
commit 9522750c66c689b739e151fcdf895420dc81efc0 upstream. Commit 6735b4632def ("Fonts: Support FONT_EXTRA_WORDS macros for built-in fonts") introduced the following error when building rpc_defconfig (only this build appears to be affected): `acorndata_8x8' referenced in section `.text' of arch/arm/boot/compressed/ll_char_wr.o: defined in discarded section `.data' of arch/arm/boot/compressed/font.o `acorndata_8x8' referenced in section `.data.rel.ro' of arch/arm/boot/compressed/font.o: defined in discarded section `.data' of arch/arm/boot/compressed/font.o make[3]: *** [/scratch/linux/arch/arm/boot/compressed/Makefile:191: arch/arm/boot/compressed/vmlinux] Error 1 make[2]: *** [/scratch/linux/arch/arm/boot/Makefile:61: arch/arm/boot/compressed/vmlinux] Error 2 make[1]: *** [/scratch/linux/arch/arm/Makefile:317: zImage] Error 2 The .data section is discarded at link time. Reinstating acorndata_8x8 as const ensures it is still available after linking. Do the same for the other 12 built-in fonts as well, for consistency purposes. Cc: <stable@vger.kernel.org> Cc: Russell King <linux@armlinux.org.uk> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Fixes: 6735b4632def ("Fonts: Support FONT_EXTRA_WORDS macros for built-in fonts") Signed-off-by: Lee Jones <lee.jones@linaro.org> Co-developed-by: Peilin Ye <yepeilin.cs@gmail.com> Signed-off-by: Peilin Ye <yepeilin.cs@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: https://patchwork.freedesktop.org/patch/msgid/20201102183242.2031659-1-yepeilin.cs@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2020-10-14 | Fonts: Support FONT_EXTRA_WORDS macros for built-in fonts | Peilin Ye | |
commit 6735b4632def0640dbdf4eb9f99816aca18c4f16 upstream. syzbot has reported an issue in the framebuffer layer, where a malicious user may overflow our built-in font data buffers. In order to perform a reliable range check, subsystems need to know `FONTDATAMAX` for each built-in font. Unfortunately, our font descriptor, `struct console_font` does not contain `FONTDATAMAX`, and is part of the UAPI, making it infeasible to modify it. For user-provided fonts, the framebuffer layer resolves this issue by reserving four extra words at the beginning of data buffers. Later, whenever a function needs to access them, it simply uses the following macros: Recently we have gathered all the above macros to <linux/font.h>. Let us do the same thing for built-in fonts, prepend four extra words (including `FONTDATAMAX`) to their data buffers, so that subsystems can use these macros for all fonts, no matter built-in or user-provided. This patch depends on patch "fbdev, newport_con: Move FONT_EXTRA_WORDS macros into linux/font.h". Cc: stable@vger.kernel.org Link: https://syzkaller.appspot.com/bug?id=08b8be45afea11888776f897895aef9ad1c3ecfd Signed-off-by: Peilin Ye <yepeilin.cs@gmail.com> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: https://patchwork.freedesktop.org/patch/msgid/ef18af00c35fb3cc826048a5f70924ed6ddce95b.1600953813.git.yepeilin.cs@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2013-06-28 | lib: Move fonts from drivers/video/console/ to lib/fonts/ | Geert Uytterhoeven | |
Several drivers need font support independent of CONFIG_VT, cfr. commit 9cbce8d7e1dae0744ca4f68d62aa7de18196b6f4, "console/font: Refactor font support code selection logic"). Hence move the fonts and their support logic from drivers/video/console/ to its own library directory lib/fonts/. This also allows to limit processing of drivers/video/console/Makefile to CONFIG_VT=y again. [Kevin Hilman <khilman@linaro.org>: Update arch/arm/boot/compressed/Makefile] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> |
