path: root/lib/interval_tree.c
2019-05-21treewide: Add SPDX license identifier for missed filesThomas Gleixner
Add SPDX license identifiers to all files which: - Have no license information of any form - Have EXPORT_.*_SYMBOL_GPL inside which was used in the initial scan/conversion to ignore the file These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-12lib/interval_tree.c: simplify includesRasmus Villemoes
The file uses nothing from init.h, and also doesn't need the full module.h machinery; export.h is sufficient. The latter requires the user to ensure compiler.h is included, so do that explicitly instead of relying on some other header pulling it in. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-05lib: Export interval_treeChris Wilson
lib/interval_tree.c provides a simple interface for an interval-tree (an augmented red-black tree) but is only built when testing the generic macros for building interval-trees. For drivers with modest needs, export the simple interval-tree library as is. v2: Lots of help from Michel Lespinasse to only compile the code as required: - make INTERVAL_TREE a config option - make INTERVAL_TREE_TEST select the library functions and sanitize the filenames & Makefile - prepare interval_tree for being built as a module if required Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> [Acked for inclusion via drm/i915 by Andrew Morton.] [danvet: switch to _GPL as per the mailing list discussion.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-09mm: interval tree updatesMichel Lespinasse
Update the generic interval tree code that was introduced in "mm: replace vma prio_tree with an interval tree". Changes: - fixed 'endpoing' typo noticed by Andrew Morton - replaced include/linux/interval_tree_tmpl.h, which was used as a template (including it automatically defined the interval tree functions) with include/linux/interval_tree_generic.h, which only defines a preprocessor macro INTERVAL_TREE_DEFINE(), which itself defines the interval tree functions when invoked. Now that is a very long macro which is unfortunate, but it does make the usage sites (lib/interval_tree.c and mm/interval_tree.c) a bit nicer than previously. - make use of RB_DECLARE_CALLBACKS() in the INTERVAL_TREE_DEFINE() macro, instead of duplicating that code in the interval tree template. - replaced vma_interval_tree_add(), which was actually handling the nonlinear and interval tree cases, with vma_interval_tree_insert_after() which handles only the interval tree case and has an API that is more consistent with the other interval tree handling functions. The nonlinear case is now handled explicitly in kernel/fork.c dup_mmap(). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09rbtree: add prio tree and interval tree testsMichel Lespinasse
Patch 1 implements support for interval trees, on top of the augmented rbtree API. It also adds synthetic tests to compare the performance of interval trees vs prio trees. Short answers is that interval trees are slightly faster (~25%) on insert/erase, and much faster (~2.4 - 3x) on search. It is debatable how realistic the synthetic test is, and I have not made such measurements yet, but my impression is that interval trees would still come out faster. Patch 2 uses a preprocessor template to make the interval tree generic, and uses it as a replacement for the vma prio_tree. Patch 3 takes the other prio_tree user, kmemleak, and converts it to use a basic rbtree. We don't actually need the augmented rbtree support here because the intervals are always non-overlapping. Patch 4 removes the now-unused prio tree library. Patch 5 proposes an additional optimization to rb_erase_augmented, now providing it as an inline function so that the augmented callbacks can be inlined in. This provides an additional 5-10% performance improvement for the interval tree insert/erase benchmark. There is a maintainance cost as it exposes augmented rbtree users to some of the rbtree library internals; however I think this cost shouldn't be too high as I expect the augmented rbtree will always have much less users than the base rbtree. I should probably add a quick summary of why I think it makes sense to replace prio trees with augmented rbtree based interval trees now. One of the drivers is that we need augmented rbtrees for Rik's vma gap finding code, and once you have them, it just makes sense to use them for interval trees as well, as this is the simpler and more well known algorithm. prio trees, in comparison, seem *too* clever: they impose an additional 'heap' constraint on the tree, which they use to guarantee a faster worst-case complexity of O(k+log N) for stabbing queries in a well-balanced prio tree, vs O(k*log N) for interval trees (where k=number of matches, N=number of intervals). Now this sounds great, but in practice prio trees don't realize this theorical benefit. First, the additional constraint makes them harder to update, so that the kernel implementation has to simplify things by balancing them like a radix tree, which is not always ideal. Second, the fact that there are both index and heap properties makes both tree manipulation and search more complex, which results in a higher multiplicative time constant. As it turns out, the simple interval tree algorithm ends up running faster than the more clever prio tree. This patch: Add two test modules: - prio_tree_test measures the performance of lib/prio_tree.c, both for insertion/removal and for stabbing searches - interval_tree_test measures the performance of a library of equivalent functionality, built using the augmented rbtree support. In order to support the second test module, lib/interval_tree.c is introduced. It is kept separate from the interval_tree_test main file for two reasons: first we don't want to provide an unfair advantage over prio_tree_test by having everything in a single compilation unit, and second there is the possibility that the interval tree functionality could get some non-test users in kernel over time. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
