path: root/lib/iov_iter.c
2017-04-21new privimitive: iov_iter_revert()Al Viro
commit 27c0e3748e41ca79171ffa3e97415a20af6facd0 upstream. opposite to iov_iter_advance(); the caller is responsible for never using it to move back past the initial position. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19fix a fencepost error in pipe_advance()Al Viro
commit b9dc6f65bc5e232d1c05fe34b5daadc7e8bbf1fb upstream. The logics in pipe_advance() used to release all buffers past the new position failed in cases when the number of buffers to release was equal to pipe->buffers. If that happened, none of them had been released, leaving pipe full. Worse, it was trivial to trigger and we end up with pipe full of uninitialized pages. IOW, it's an infoleak. Reported-by: "Alan J. Wylie" <alan@wylie.me.uk> Tested-by: "Alan J. Wylie" <alan@wylie.me.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-17fix iov_iter_advance() for ITER_PIPEAbhi Das
iov_iter_advance() needs to decrement iter->count by the number of bytes we'd moved beyond. Normal flavours do that, but ITER_PIPE doesn't and ITER_PIPE generic_file_read_iter() for O_DIRECT files ends up with a bogus fallback to page cache read, resulting in incorrect values for file offset and bytes read. Signed-off-by: Abhi Das <adas@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector()Vegard Nossum
Both import_iovec() and rw_copy_check_uvector() take an array (typically small and on-stack) which is used to hold an iovec array copy from userspace. This is to avoid an expensive memory allocation in the fast path (i.e. few iovec elements). The caller may have to check whether these functions actually used the provided buffer or allocated a new one -- but this differs between the too. Let's just add a kernel doc to clarify what the semantics are for each function. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-11Fix off-by-one in __pipe_get_pages()Al Viro
it actually worked only when requested area ended on the page boundary... Reported-by: Marco Grassi <marco.gra@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted misc bits and pieces. There are several single-topic branches left after this (rename2 series from Miklos, current_time series from Deepa Dinamani, xattr series from Andreas, uaccess stuff from from me) and I'd prefer to send those separately" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits) proc: switch auxv to use of __mem_open() hpfs: support FIEMAP cifs: get rid of unused arguments of CIFSSMBWrite() posix_acl: uapi header split posix_acl: xattr representation cleanups fs/aio.c: eliminate redundant loads in put_aio_ring_file fs/internal.h: add const to ns_dentry_operations declaration compat: remove compat_printk() fs/buffer.c: make __getblk_slow() static proc: unsigned file descriptors fs/file: more unsigned file descriptors fs: compat: remove redundant check of nr_segs cachefiles: Fix attempt to read i_blocks after deleting file [ver #2] cifs: don't use memcpy() to copy struct iov_iter get rid of separate multipage fault-in primitives fs: Avoid premature clearing of capabilities fs: Give dentry to inode_change_ok() instead of inode fuse: Propagate dentry down to inode_change_ok() ceph: Propagate dentry down to inode_change_ok() xfs: Propagate dentry down to inode_change_ok() ...
2016-10-05pipe: add pipe_buf_release() helperMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-05new iov_iter flavour: pipe-backedAl Viro
iov_iter variant for passing data into pipe. copy_to_iter() copies data into page(s) it has allocated and stuffs them into the pipe; copy_page_to_iter() stuffs there a reference to the page given to it. Both will try to coalesce if possible. iov_iter_zero() is similar to copy_to_iter(); iov_iter_get_pages() and friends will do as copy_to_iter() would have and return the pages where the data would've been copied. iov_iter_advance() will truncate everything past the spot it has advanced to. New primitive: iov_iter_pipe(), used for initializing those. pipe should be locked all along. Running out of space acts as fault would for iovec-backed ones; in other words, giving it to ->read_iter() may result in short read if the pipe overflows, or -EFAULT if it happens with nothing copied there. In other words, ->read_iter() on those acts pretty much like ->splice_read(). Moreover, all generic_file_splice_read() users, as well as many other ->splice_read() instances can be switched to that scheme - that'll happen in the next commit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27get rid of separate multipage fault-in primitivesAl Viro
* the only remaining callers of "short" fault-ins are just as happy with generic variants (both in lib/iov_iter.c); switch them to multipage variants, kill the "short" ones * rename the multipage variants to now available plain ones. * get rid of compat macro defining iov_iter_fault_in_multipage_readable by expanding it in its only user. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-17fix iov_iter_fault_in_readable()Al Viro
... by turning it into what used to be multipages counterpart Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: optimize copy_page_to/from_iter_iovecMikulas Patocka
copy_page_to_iter_iovec() and copy_page_from_iter_iovec() copy some data to userspace or from userspace. These functions have a fast path where they map a page using kmap_atomic and a slow path where they use kmap. kmap is slower than kmap_atomic, so the fast path is preferred. However, on kernels without highmem support, kmap just calls page_address, so there is no need to avoid kmap. On kernels without highmem support, the fast path just increases code size (and cache footprint) and it doesn't improve copy performance in any way. This patch enables the fast path only if CONFIG_HIGHMEM is defined. Code size reduced by this patch: x86 (without highmem) 928 x86-64 960 sparc64 848 alpha 1136 pa-risc 1200 [akpm@linux-foundation.org: use IS_ENABLED(), per Andi] Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1607221711410.4818@file01.intranet.prod.int.rdu2.redhat.com Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-09iov_iter: use bvec iterator to implement iterate_bvec()Ming Lei
bvec has one native/mature iterator for long time, so not necessary to use the reinvented wheel for iterating bvecs in lib/iov_iter.c. Two ITER_BVEC test cases are run: - xfstest(-g auto) on loop dio/aio, no regression found - swap file works well under extreme stress(stress-ng --all 64 -t 800 -v), and lots of OOMs are triggerd, and the whole system still survives Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@canonical.com> Tested-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-25Merge branch 'work.iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs iov_iter regression fix from Al Viro: "Fix for braino in 'fold checks into iterate_and_advance()'" * 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: do "fold checks into iterate_and_advance()" right
2016-05-25do "fold checks into iterate_and_advance()" rightAl Viro
the only case when we should skip the iterate_and_advance() guts is when nothing's left in the iterator, _not_ just when requested amount is 0. Said guts will do nothing in the latter case anyway; the problem we tried to deal with in the aforementioned commit is that when there's nothing left *and* the amount requested is 0, we might end up deferencing one iovec too many; the value we fetch from there is discarded in that case, but theoretically it might oops if the iovec array ends exactly at the end of page with the next page not mapped. Bailing out on zero size requested had an unexpected side effect - zero-length segment in the beginning of iovec array ended up throwing do_loop_readv_writev() into infinite spin; we do not advance past the empty segment at all. Reproducer is trivial: echo '#include <sys/uio.h>' >a.c echo 'main() {char c; struct iovec v[] = {{&c,0},{&c,1}}; readv(0,v,2);}' >>a.c cc a.c && ./a.out </proc/uptime which should end up with the process not hanging. Probably ought to go into LTP or xfstests... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-18Merge branch 'work.iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull iov_iter cleanups from Al Viro. * 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fold checks into iterate_and_advance() rw_verify_area(): saner calling conventions aio: remove a pointless assignment
2016-05-09fold checks into iterate_and_advance()Al Viro
they are open-coded in all users except iov_iter_advance(), and there they wouldn't be a bad idea either - as it is, iov_iter_advance(i, 0) ends up dereferencing potentially past the end of iovec array. It doesn't do anything with the value it reads, and very unlikely to trigger an oops on dereference, but it is not impossible. Reported-by: Jiri Slaby <jslaby@suse.cz> Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-08fix the copy vs. map logics in blk_rq_map_user_iov()Al Viro
2015-12-06iov_iter: export import_single_range()Al Viro
2015-12-06iov_iter: constify {csum_and_,}copy_to_iter()Al Viro
2015-04-11Merge branch 'iov_iter' into for-nextAl Viro
2015-04-11VFS: Add iov_iter_fault_in_multipages_readable()Anton Altaparmakov
simillar to iov_iter_fault_in_readable() but differs in that it is not limited to faulting in the first iovec and instead faults in "bytes" bytes iterating over the iovecs as necessary. Also, instead of only faulting in the first and last page of the range, all pages are faulted in. This function is needed by NTFS when it does multi page file writes. Signed-off-by: Anton Altaparmakov <anton@tuxera.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-30saner iov_iter initialization primitivesAl Viro
iovec-backed iov_iter instances are assumed to satisfy several properties: * no more than UIO_MAXIOV elements in iovec array * total size of all ranges is no more than MAX_RW_COUNT * all ranges pass access_ok(). The problem is, invariants of data structures should be established in the primitives creating those data structures, not in the code using those primitives. And iov_iter_init() violates that principle. For a while we managed to get away with that, but once the use of iov_iter started to spread, it didn't take long for shit to hit the fan - missed check in sys_sendto() had introduced a roothole. We _do_ have primitives for importing and validating iovecs (both native and compat ones) and those primitives are almost always followed by shoving the resulting iovec into iov_iter. Life would be considerably simpler (and safer) if we combined those primitives with initializing iov_iter. That gives us two new primitives - import_iovec() and compat_import_iovec(). Calling conventions: iovec = iov_array; err = import_iovec(direction, uvec, nr_segs, ARRAY_SIZE(iov_array), &iovec, &iter); imports user vector into kernel space (into iov_array if it fits, allocated if it doesn't fit or if iovec was NULL), validates it and sets iter up to refer to it. On success 0 is returned and allocated kernel copy (or NULL if the array had fit into caller-supplied one) is returned via iovec. On failure all allocations are undone and -E... is returned. If the total size of ranges exceeds MAX_RW_COUNT, the excess is silently truncated. compat_import_iovec() expects uvec to be a pointer to user array of compat_iovec; otherwise it's identical to import_iovec(). Finally, import_single_range() sets iov_iter backed by single-element iovec covering a user-supplied range - err = import_single_range(direction, address, size, iovec, &iter); does validation and sets iter up. Again, size in excess of MAX_RW_COUNT gets silently truncated. Next commits will be switching the things up to use of those and reducing the amount of iov_iter_init() instances. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17move iov_iter.c from mm/ to lib/Al Viro
