path: root/lib/kobject_uevent.c
2008-04-03Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
2008-04-03[NETNS]: Declare init_net even without CONFIG_NET defined.Denis V. Lunev
This does not look good, but there is no other choice. The compilation without CONFIG_NET is broken and can not be fixed with ease. After that there is no need for the following commits: 1567ca7eec7664b8be3b07755ac59dc1b1ec76cb 3edf8fa5ccf10688a9280b5cbca8ed3947c42866 2d38f9a4f8d2ebdc799f03eecf82345825495711 Revert them. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-30fix uevent action-string regressionMark Lord
Mark Lord wrote: > > On boot, syslog is flooded with "uevent: unsupported action-string;" messages. .. > Mar 28 14:43:29 shrimp kernel: tty ptyqd: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyqe: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyqf: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyr0: uevent: unsupported > action-string; this will be ignored in a future kernel version .. These messages are a regression compared with 2.6.24, which did not flood the syslog with them. The actual underlying problem was introduced in 2.6.23, when somebody made the string parsing no longer accept nul-terminated strings as a valid input to store_uevent(). Eg. "add\0" was valid prior to 2.6.23, where the code regressed to require "add" without the '\0'. This patch fixes the 2.6.23 / 2.6.24 regressions, by having the code once again tolerate the trailing '\0', if present. According to GregKH, this mainly affects older Ubuntu systems, such as the one I have here that requires this fix. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-27[NETNS]: Do no include NET related headers if CONFIG_NET is not set.Denis V. Lunev
This fix broken compilation for 'allnoconfig'. This was introduced by Introduced by commit 1218854afa6f659be90b748cf1bc7badee954a35 ("[NET] NETNS: Omit seq_net_private->net without CONFIG_NET_NS.") Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-24Kobject: fix coding style issues in kobject c filesGreg Kroah-Hartman
Clean up the kobject.c and kobject_uevent.c files to follow the proper coding style rules. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: auto-cleanup on final unrefKay Sievers
We save the current state in the object itself, so we can do proper cleanup when the last reference is dropped. If the initial reference is dropped, the object will be removed from sysfs if needed, if an "add" event was sent, "remove" will be send, and the allocated resources are released. This allows us to clean up some driver core usage as well as allowing us to do other such changes to the rest of the kernel. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: clean up debugging messagesGreg Kroah-Hartman
The kobject debugging messages are a mess. This provides a unified message that makes them actually useful. The format for new kobject debug messages should be: kobject: 'KOBJECT_NAME' (ADDRESS): FUNCTION_NAME: message.\n Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12Driver core: kerneldoc - kobject_uevent_env is not "usually KOBJ_MOVE"Kay Sievers
2007-10-12Driver core: exclude kobject_uevent.c for !CONFIG_HOTPLUGKay Sievers
Move uevent specific logic from the core into kobject_uevent.c, which does no longer require to link the unused string array if hotplug is not compiled in. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: add CONFIG_UEVENT_HELPER_PATHKay Sievers
The kernel creates a process for every event that is send, even when there is no binary it could execute. We are needlessly creating around 200-300 failing processes during early bootup, until we have the chance to disable it from userspace. This change allows us to disable /sbin/hotplug entirely, if you want to, by setting UEVENT_HELPER_PATH="" in the kernel config. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-10[NET]: Support multiple network namespaces with netlinkEric W. Biederman
Each netlink socket will live in exactly one network namespace, this includes the controlling kernel sockets. This patch updates all of the existing netlink protocols to only support the initial network namespace. Request by clients in other namespaces will get -ECONREFUSED. As they would if the kernel did not have the support for that netlink protocol compiled in. As each netlink protocol is updated to be multiple network namespace safe it can register multiple kernel sockets to acquire a presence in the rest of the network namespaces. The implementation in af_netlink is a simple filter implementation at hash table insertion and hash table look up time. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30kobject: fix link error when CONFIG_HOTPLUG is disabledCornelia Huck
Leaving kobject_actions[] in kobject_uevent.c, but putting it outside the #ifdef looks indeed like the best solution to me. This way, we avoid adding #ifdef CONFIG_HOTPLUG into core.c, when all other functions called do not need such a thing. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-18Driver core: accept all valid action-strings in uevent-triggerKay Sievers
This allows the uevent file to handle any type of uevent action to be triggered by userspace instead of just the "add" uevent. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-18usermodehelper: Tidy up waitingJeremy Fitzhardinge
Rather than using a tri-state integer for the wait flag in call_usermodehelper_exec, define a proper enum, and use that. I've preserved the integer values so that any callers I've missed should still work OK. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com>
2007-04-27the overdue removal of the mount/umount ueventsAdrian Bunk
This patch contains the overdue removal of the mount/umount uevents. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27Kobject: kobject_uevent.c: Collapse unnecessary loop nesting (top_kobj)John Anthony Kazos Jr
Collapses a do..while() loop within an if() to a simple while() loop for simplicity and readability. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27driver core: fix namespace issue with devices assigned to classesKay Sievers
- uses a kset in "struct class" to keep track of all directories belonging to this class - merges with the /sys/devices/virtual logic. - removes the namespace-dir if the last member of that class leaves the directory. There may be locking or refcounting fixes left, I stopped when it seemed to work with network and sound modules. :) From: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-20kobject: kobject_uevent() returns manageable valueAneesh Kumar K.V
Since kobject_uevent() function does not return an integer value to indicate if its operation was completed with success or not, it is worth changing it in order to report a proper status (success or error) instead of returning void. [randy.dunlap@oracle.com: Fix inline kobject functions] Cc: Mauricio Lin <mauriciolin@gmail.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01driver core: Introduce device_move(): move a device to a new parent.Cornelia Huck
Provide a function device_move() to move a device to a new parent device. Add auxilliary functions kobject_move() and sysfs_move_dir(). kobject_move() generates a new uevent of type KOBJ_MOVE, containing the previous path (DEVPATH_OLD) in addition to the usual values. For this, a new interface kobject_uevent_env() is created that allows to add further environmental data to the uevent at the kobject layer. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-03PCI: docking station: remove dock ueventsKristen Carlson Accardi
Remove uevent dock notifications. There are no consumers of these events at present, and uevents are likely not the correct way to send this type of event anyway. Until I get some kind of idea if anyone in userspace cares about dock events, I will just not send any. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27KEVENT: add new uevent for dockKristen Accardi
so that userspace can be notified of dock and undock events. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-27[PATCH] Kobject: fix build errorKay Sievers
This fixes a build error for various odd combinations of CONFIG_HOTPLUG and CONFIG_NET. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Nigel Cunningham <ncunningham@cyclades.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] kobject: fix build error if CONFIG_SYSFS=nJun'ichi Nomura
Moving uevent_seqnum and uevent_helper to kobject_uevent.c because they are used even if CONFIG_SYSFS=n while kernel/ksysfs.c is built only if CONFIG_SYSFS=y, Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-22Revert mount/umount uevent removalGreg Kroah-Hartman
This change reverts the 033b96fd30db52a710d97b06f87d16fc59fee0f1 commit from Kay Sievers that removed the mount/umount uevents from the kernel. Some older versions of HAL still depend on these events to detect when a new device has been mounted. These events are not correctly emitted, and are broken by design, and so, should not be relied upon by any future program. Instead, the /proc/mounts file should be polled to properly detect this kind of event. A feature-removal-schedule.txt entry has been added, noting when this interface will be removed from the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] Fix uevent buffer overflow in input layerBenjamin Herrenschmidt
The buffer used for kobject uevent is too small for some of the events generated by the input layer. Bump it to 2k. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] kobject_uevent CONFIG_NET=n fixakpm@osdl.org
lib/lib.a(kobject_uevent.o)(.text+0x25f): In function `kobject_uevent': : undefined reference to `__alloc_skb' lib/lib.a(kobject_uevent.o)(.text+0x2a1): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x31d): In function `kobject_uevent': : undefined reference to `skb_over_panic' lib/lib.a(kobject_uevent.o)(.text+0x356): In function `kobject_uevent': : undefined reference to `netlink_broadcast' lib/lib.a(kobject_uevent.o)(.init.text+0x9): In function `kobject_uevent_init': : undefined reference to `netlink_kernel_create' make: *** [.tmp_vmlinux1] Error 1 Netlink is unconditionally enabled if CONFIG_NET, so that's OK. kobject_uevent.o is compiled even if !CONFIG_HOTPLUG, which is lazy. Let's compound the sin. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] merge kobject_uevent and kobject_hotplugKay Sievers
The distinction between hotplug and uevent does not make sense these days, netlink events are the default. udev depends entirely on netlink uevents. Only during early boot and in initramfs, /sbin/hotplug is needed. So merge the two functions and provide only one interface without all the options. The netlink layer got a nice generic interface with named slots recently, which is probably a better facility to plug events for subsystem specific events. Also the new poll() interface to /proc/mounts is a nicer way to notify about changes than sending events through the core. The uevents should only be used for driver core related requests to userspace now. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] remove mount/umount uevents from superblock handlingKay Sievers
The names of these events have been confusing from the beginning on, as they have been more like claim/release events. We needed these events for noticing HAL if storage devices have been mounted. Thanks to Al, we have the proper solution now and can poll() /proc/mounts instead to get notfied about mount tree changes. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] remove CONFIG_KOBJECT_UEVENT optionKay Sievers
It makes zero sense to have hotplug, but not the netlink events enabled today. Remove this option and merge the kobject_uevent.h header into the kobject.h header file. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] kobject_uevent.c has a typo in a commentErik Hovland
This patch changes trough to through in a comment in kobject_uevent.c. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: lib/*Al Viro
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-08-29[NETLINK]: Fix missing dst_groups initializations in netlink_broadcast usersPatrick McHardy
netlink_broadcast users must initialize NETLINK_CB(skb).dst_groups to the destination group mask for netlink_recvmsg. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[PATCH] Make kobject's name be const char *Dmitry Torokhov
kobject: make kobject's name const char * since users should not attempt to change it (except by calling kobject_rename). Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] kobject_hotplug() should use kobject_name()Dmitry Torokhov
kobject: kobject_hotplug should use kobject_name() instead of accessing kobj->name directly since for objects with long names it can contain garbage. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
