path: root/lib/kstrtox.c
2011-07-25lib: make _tolower() publicAndy Shevchenko
This function is required by *printf and kstrto* functions that are located in the different modules. This patch makes _tolower() public. However, it's good idea to not use the helper outside of mentioned functions. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: add kstrto*_from_user()Alexey Dobriyan
There is quite a lot of code which does copy_from_user() + strict_strto*() or simple_strto*() combo in slightly different ways. Before doing conversions all over tree, let's get final API correct. Enter kstrtoull_from_user() and friends. Typical code which uses them looks very simple: TYPE val; int rv; rv = kstrtoTYPE_from_user(buf, count, 0, &val); if (rv < 0) return rv; [use val] return count; There is a tiny semantic difference from the plain kstrto*() API -- the latter allows any amount of leading zeroes, while the former copies data into buffer on stack and thus allows leading zeroes as long as it fits into buffer. This shouldn't be a problem for typical usecase "echo 42 > /proc/x". The point is to make reading one integer from userspace _very_ simple and very bug free. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14kstrtox: simpler code in _kstrtoull()Alexey Dobriyan
2011-03-22kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
