path: root/lib/md5.c
2015-02-12lib/md5.c: simplify includeRasmus Villemoes
md5.c doesn't use anything from kernel.h, except that that pulls in compiler.h, which is needed for the export.h to work. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-06crypto: Move md5_transform to lib/md5.cDavid S. Miller
We are going to use this for TCP/IP sequence number and fragment ID generation. Signed-off-by: David S. Miller <davem@davemloft.net>
