path: root/lib/mpi/mpi-bit.c
2012-10-08MPILIB: Provide count_leading/trailing_zeros() based on arch functionsDavid Howells
Provide count_leading/trailing_zeros() macros based on extant arch bit scanning functions rather than reimplementing from scratch in MPILIB. Whilst we're at it, turn count_foo_zeros(n, x) into n = count_foo_zeros(x). Also move the definition to asm-generic as other people may be interested in using it. Signed-off-by: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: Arnd Bergmann <arnd@arndb.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-26Remove unused code from MPI libraryDmitry Kasatkin
MPI library is used by RSA verification implementation. Few files contains functions which are never called. James Morris has asked to remove all of them. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Requested-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-18mpi: Avoid using freed pointer in mpi_lshift_limbs()Jesper Juhl
At the start of the function we assign 'a->d' to 'ap'. Then we use the RESIZE_IF_NEEDED macro on 'a' - this may free 'a->d' and replace it with newly allocaetd storage. In that case, we'll be operating on freed memory further down in the function when we index into 'ap[]'. Since we don't actually need 'ap' until after the use of the RESIZE_IF_NEEDED macro we can just delay the assignment to it until after we've potentially resized, thus avoiding the issue. While I was there anyway I also changed the integer variable 'n' to be const. It might as well be since we only assign to it once and use it as a constant, and then the compiler will tell us if we ever assign to it in the future. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-02-02lib: Fix multiple definitions of clz_tabDavid Miller
Both sparc 32-bit's software divide assembler and MPILIB provide clz_tab[] with identical contents. Break it out into a seperate object file and select it when SPARC32 or MPILIB is set. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-11-09crypto: GnuPG based MPI lib - source files (part 1)Dmitry Kasatkin
Adds the multi-precision-integer maths library which was originally taken from GnuPG and ported to the kernel by (among others) David Howells. This version is taken from Fedora kernel 2.6.32-71.14.1.el6. The difference is that checkpatch reported errors and warnings have been fixed. This library is used to implemenet RSA digital signature verification used in IMA/EVM integrity protection subsystem. Due to patch size limitation, the patch is divided into 4 parts. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
