path: root/lib/mpi
2013-02-01mpilib: use DIV_ROUND_UP and remove unused macrosAndy Shevchenko
Remove MIN, MAX and ABS macros that are duplicates kernel's native implementation. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-11-23MPI: Fix compilation on MIPS with GCC 4.4 and newerManuel Lauss
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint, leading to this build failure: CC lib/mpi/generic_mpih-mul1.o lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm' This patch updates MPI with the latest umul_ppm implementations for MIPS. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: James Morris <jmorris@namei.org> Patchwork: https://patchwork.linux-mips.org/patch/4612/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-08MPILIB: Provide a function to read raw data into an MPIDavid Howells
Provide a function to read raw data of a predetermined size into an MPI rather than expecting the size to be encoded within the data. The data is assumed to represent an unsigned integer, and the resulting MPI will be positive. The function looks like this: MPI mpi_read_raw_data(const void *, size_t); This is useful for reading ASN.1 integer primitives where the length is encoded in the ASN.1 metadata. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08MPILIB: Reinstate mpi_cmp[_ui]() and export for RSA signature verificationDavid Howells
Reinstate and export mpi_cmp() and mpi_cmp_ui() from the MPI library for use by RSA signature verification as per RFC3447 section 5.2.2 step 1. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08MPILIB: Provide count_leading/trailing_zeros() based on arch functionsDavid Howells
Provide count_leading/trailing_zeros() macros based on extant arch bit scanning functions rather than reimplementing from scratch in MPILIB. Whilst we're at it, turn count_foo_zeros(n, x) into n = count_foo_zeros(x). Also move the definition to asm-generic as other people may be interested in using it. Signed-off-by: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: Arnd Bergmann <arnd@arndb.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-26Remove unused code from MPI libraryDmitry Kasatkin
MPI library is used by RSA verification implementation. Few files contains functions which are never called. James Morris has asked to remove all of them. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Requested-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-26Revert "crypto: GnuPG based MPI lib - additional sources (part 4)"Dmitry Kasatkin
This reverts commit 7e8dec918ef8e0f68b4937c3c50fa57002077a4d. RSA verification implementation does not use this code. James Morris has asked to remove that. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Requested-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-18mpi: Avoid using freed pointer in mpi_lshift_limbs()Jesper Juhl
At the start of the function we assign 'a->d' to 'ap'. Then we use the RESIZE_IF_NEEDED macro on 'a' - this may free 'a->d' and replace it with newly allocaetd storage. In that case, we'll be operating on freed memory further down in the function when we index into 'ap[]'. Since we don't actually need 'ap' until after the use of the RESIZE_IF_NEEDED macro we can just delay the assignment to it until after we've potentially resized, thus avoiding the issue. While I was there anyway I also changed the integer variable 'n' to be const. It might as well be since we only assign to it once and use it as a constant, and then the compiler will tell us if we ever assign to it in the future. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-02-02lib: Fix 32-bit sparc udiv_qrnnd() definition in mpilib's longlong.hDavid Miller
This copy of longlong.h is extremely dated and results in compile errors on sparc32 when MPILIB is enabled, copy over the more uptodate implementation from arch/sparc/math/sfp-util_32.h Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib: Fix multiple definitions of clz_tabDavid Miller
Both sparc 32-bit's software divide assembler and MPILIB provide clz_tab[] with identical contents. Break it out into a seperate object file and select it when SPARC32 or MPILIB is set. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: added missing NULL checkDmitry Kasatkin
Added missing NULL check after mpi_alloc_limb_space(). Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: added comment on divide by 0 caseDmitry Kasatkin
Comment explains that existing clients do not call this function with dsize == 0, which means that 1/0 should not happen. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: check for possible zero lengthDmitry Kasatkin
Buggy client might pass zero nlimbs which is meaningless. Added check for zero length. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: removed unused functionsDmitry Kasatkin
do_encode_md() and mpi_get_keyid() are not parts of mpi library. They were used early versions of gnupg and in digsig project, but they are not used neither here nor there anymore. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: checks for zero divisor lengthDmitry Kasatkin
Divisor length should not be 0. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: return error code on dividing by zeroDmitry Kasatkin
Definitely better to return error code than to divide by zero. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/mpi: replaced MPI_NULL with normal NULLDmitry Kasatkin
MPI_NULL is replaced with normal NULL. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
Added missing NULL check after mpi_alloc(). Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-19MPILIB: Add a missing ENOMEM checkDavid Howells
Add a missing ENOMEM check. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-12-08mpi/mpi-mpow: NULL dereference on allocation failureDan Carpenter
We can't call mpi_free() on the elements if the first kzalloc() fails. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-11-09crypto: GnuPG based MPI lib - additional sources (part 4)Dmitry Kasatkin
Adds the multi-precision-integer maths library which was originally taken from GnuPG and ported to the kernel by (among others) David Howells. This version is taken from Fedora kernel 2.6.32-71.14.1.el6. The difference is that checkpatch reported errors and warnings have been fixed. This library is used to implemenet RSA digital signature verification used in IMA/EVM integrity protection subsystem. Due to patch size limitation, the patch is divided into 4 parts. This code is unnecessary for RSA digital signature verification, but for completeness it is included here and can be compiled, if CONFIG_MPILIB_EXTRA is enabled. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2011-11-09crypto: GnuPG based MPI lib - make files (part 3)Dmitry Kasatkin
Adds the multi-precision-integer maths library which was originally taken from GnuPG and ported to the kernel by (among others) David Howells. This version is taken from Fedora kernel 2.6.32-71.14.1.el6. The difference is that checkpatch reported errors and warnings have been fixed. This library is used to implemenet RSA digital signature verification used in IMA/EVM integrity protection subsystem. Due to patch size limitation, the patch is divided into 4 parts. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2011-11-09crypto: GnuPG based MPI lib - header files (part 2)Dmitry Kasatkin
2011-11-09crypto: GnuPG based MPI lib - source files (part 1)Dmitry Kasatkin
