path: root/lib/oid_registry.c
2018-02-25509: fix printing uninitialized stack memory when OID is emptyEric Biggers
[ Upstream commit 8dfd2f22d3bf3ab7714f7495ad5d897b8845e8c1 ] Callers of sprint_oid() do not check its return value before printing the result. In the case where the OID is zero-length, -EBADMSG was being returned without anything being written to the buffer, resulting in uninitialized stack memory being printed. Fix this by writing "(bad)" to the buffer in the cases where -EBADMSG is returned. Fixes: 4f73175d0375 ("X.509: Add utility functions to render OIDs as strings") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-05Give the OID registry file module info to avoid kernel taintingDavid Howells
Give the OID registry file module information so that it doesn't taint the kernel when compiled as a module and loaded. Reported-by: Dros Adamson <Weston.Adamson@netapp.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Trond Myklebust <Trond.Myklebust@netapp.com> cc: stable@vger.kernel.org cc: linux-nfs@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-08X.509: Add utility functions to render OIDs as stringsDavid Howells
Add a pair of utility functions to render OIDs as strings. The first takes an encoded OID and turns it into a "a.b.c.d" form string: int sprint_oid(const void *data, size_t datasize, char *buffer, size_t bufsize); The second takes an OID enum index and calls the first on the data held therein: int sprint_OID(enum OID oid, char *buffer, size_t bufsize); Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08X.509: Implement simple static OID registryDavid Howells
Implement a simple static OID registry that allows the mapping of an encoded OID to an enum value for ease of use. The OID registry index enum appears in the: linux/oid_registry.h header file. A script generates the registry from lines in the header file that look like: <sp*>OID_foo,<sp*>/*<sp*>1.2.3.4<sp*>*/ The actual OID is taken to be represented by the numbers with interpolated dots in the comment. All other lines in the header are ignored. The registry is queries by calling: OID look_up_oid(const void *data, size_t datasize); This returns a number from the registry enum representing the OID if found or OID__NR if not. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
