commit 27d20fddc8af539464fc3ba499d6a830054c3bd6 upstream.
Salman Qazi describes the following radix-tree bug:
In the following case, we get can get a deadlock:
0. The radix tree contains two items, one has the index 0.
1. The reader (in this case find_get_pages) takes the rcu_read_lock.
2. The reader acquires slot(s) for item(s) including the index 0 item.
3. The non-zero index item is deleted, and as a consequence the other item is
moved to the root of the tree. The place where it used to be is queued for
deletion after the readers finish.
3b. The zero item is deleted, removing it from the direct slot, it remains in
the rcu-delayed indirect node.
4. The reader looks at the index 0 slot, and finds that the page has 0 ref
count
5. The reader looks at it again, hoping that the item will either be freed or
the ref count will increase. This never happens, as the slot it is looking
at will never be updated. Also, this slot can never be reclaimed because
the reader is holding rcu_read_lock and is in an infinite loop.
The fix is to re-use the same "indirect" pointer case that requires a slot
lookup retry into a general "retry the lookup" bit.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reported-by: Salman Qazi <sqazi@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev
* 'radix-tree' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev:
radix-tree: radix_tree_range_tag_if_tagged() can set incorrect tags
radix-tree: clear all tags in radix_tree_node_rcu_free
Commit ebf8aa44beed48cd17893a83d92a4403e5f9d9e2 ("radix-tree:
omplement function radix_tree_range_tag_if_tagged") does not safely
set tags on on intermediate tree nodes. The code walks down the tree
setting tags before it has fully resolved the path to the leaf under
the assumption there will be a leaf slot with the tag set in the
range it is searching.
Unfortunately, this is not a valid assumption - we can abort after
setting a tag on an intermediate node if we overrun the number of
tags we are allowed to set in a batch, or stop scanning because we
we have passed the last scan index before we reach a leaf slot with
the tag we are searching for set.
As a result, we can leave the function with tags set on intemediate
nodes which can be tripped over later by tag-based lookups. The
result of these stale tags is that lookup may end prematurely or
livelock because the lookup cannot make progress.
The fix for the problem involves reocrding the traversal path we
take to the leaf nodes, and only propagating the tags back up the
tree once the tag is set in the leaf node slot. We are already
recording the path for efficient traversal, so there is no
additional overhead to do the intermediately node tag setting in
this manner.
This fixes a radix tree lookup livelock triggered by the new
writeback sync livelock avoidance code introduced in commit
f446daaea9d4a420d16c606f755f3689dcb2d0ce ("mm: implement writeback
livelock avoidance using page tagging").
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
Commit f446daaea9d4a420d16c606f755f3689dcb2d0ce ("mm: implement
writeback livelock avoidance using page tagging") introduced a new
radix tree tag, increasing the number of tags in each node from 2 to
3. It did not, however, fix up the code in
radix_tree_node_rcu_free() that cleans up after radix_tree_shrink()
and hence could leave stray tags set in the new tag array.
The result is that the livelock avoidance code added in the the
above commit would hit stale tags when doing tag based lookups,
resulting in livelocks when trying to traverse the tree.
Fix this problem in radix_tree_node_rcu_free() so it doesn't happen
again in the future by using a loop to walk all the tags up to
RADIX_TREE_MAX_TAGS to clear the stray tags radix_tree_shrink()
leaves behind.
Acked-by: Nick Piggin <npiggin@kernel.dk>
When radix_tree_maxindex() is ~0UL, it can happen that scanning overflows
index and tree traversal code goes astray reading memory until it hits
unreadable memory. Check for overflow and exit in that case.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Implement function for setting one tag if another tag is set for each item
in given range.
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Theodore Ts'o <tytso@mit.edu>
radix_tree_prev_hole() used LONG_MAX to detect underflow; however,
ULONG_MAX is clearly what was intended, both here and by its only user
(count_history_pages at mm/readahead.c).
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
radix_tree_tag_get() is not safe to use concurrently with radix_tree_tag_set()
or radix_tree_tag_clear(). The problem is that the double tag_get() in
radix_tree_tag_get():
if (!tag_get(node, tag, offset))
saw_unset_tag = 1;
if (height == 1) {
int ret = tag_get(node, tag, offset);
may see the value change due to the action of set/clear. RCU is no protection
against this as no pointers are being changed, no nodes are being replaced
according to a COW protocol - set/clear alter the node directly.
The documentation in linux/radix-tree.h, however, says that
radix_tree_tag_get() is an exception to the rule that "any function modifying
the tree or tags (...) must exclude other modifications, and exclude any
functions reading the tree".
The problem is that the next statement in radix_tree_tag_get() checks that the
tag doesn't vary over time:
BUG_ON(ret && saw_unset_tag);
This has been seen happening in FS-Cache:
https://www.redhat.com/archives/linux-cachefs/2010-April/msg00013.html
To this end, remove the BUG_ON() from radix_tree_tag_get() and note in various
comments that the value of the tag may change whilst the RCU read lock is held,
and thus that the return value of radix_tree_tag_get() may not be relied upon
unless radix_tree_tag_set/clear() and radix_tree_delete() are excluded from
running concurrently with it.
Reported-by: Romain DEGEZ <romain.degez@smartjog.com>
Acked-by: Nick Piggin <npiggin@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Because the radix tree is used with many different locking
designs, we cannot do any effective checking without changing
the radix-tree APIs. It might make sense to do this later, but
only if the RCU lockdep checking proves itself sufficiently
valuable.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-10-git-send-email-paulmck@linux.vnet.ibm.com>
Don't delete pending pages from the page-store tracking tree, but rather send
them for another write as they've presumably been updated.
__fscache_write_page() attempts to load the radix tree preallocation pool for
the CPU it is on before calling radix_tree_insert(), as the insertion must be
done inside a pair of spinlocks.
Use of the preallocation pool, however, is contingent on the radix tree being
initialised without __GFP_WAIT specified. __fscache_acquire_cookie() was
passing GFP_NOFS to INIT_RADIX_TREE() - but that includes __GFP_WAIT.
The solution is to AND out __GFP_WAIT.
Additionally, the banner comment to radix_tree_preload() is altered to make
note of this prerequisite. Possibly there should be a WARN_ON() too.
Without this fix, I have seen the following recursive deadlock caused by
radix_tree_insert() attempting to allocate memory inside the spinlocked
region, which resulted in FS-Cache being called back into to release memory -
which required the spinlock already held.
[ INFO: possible recursive locking detected ]
2.6.32-rc6-cachefs #24
nfsiod/7916 is trying to acquire lock:
(&cookie->lock){+.+.-.}, at: [<ffffffffa0076872>] __fscache_uncache_page+0xdb/0x160 [fscache]
but task is already holding lock:
(&cookie->lock){+.+.-.}, at: [<ffffffffa0076acc>] __fscache_write_page+0x15c/0x3f3 [fscache]
5 locks held by nfsiod/7916:
#0: (nfsiod){+.+.+.}, at: [<ffffffff81048290>] worker_thread+0x19a/0x2e2
#1: (&task->u.tk_work#2){+.+.+.}, at: [<ffffffff81048290>] worker_thread+0x19a/0x2e2
#2: (&cookie->lock){+.+.-.}, at: [<ffffffffa0076acc>] __fscache_write_page+0x15c/0x3f3 [fscache]
#3: (&object->lock#2){+.+.-.}, at: [<ffffffffa0076b07>] __fscache_write_page+0x197/0x3f3 [fscache]
#4: (&cookie->stores_lock){+.+...}, at: [<ffffffffa0076b0f>] __fscache_write_page+0x19f/0x3f3 [fscache]
stack backtrace:
Pid: 7916, comm: nfsiod Not tainted 2.6.32-rc6-cachefs #24
Call Trace:
[<ffffffff8105ac7f>] __lock_acquire+0x1649/0x16e3
[<ffffffff81059ded>] ? __lock_acquire+0x7b7/0x16e3
[<ffffffff8100e27d>] ? dump_trace+0x248/0x257
[<ffffffff8105ad70>] lock_acquire+0x57/0x6d
[<ffffffffa0076872>] ? __fscache_uncache_page+0xdb/0x160 [fscache]
[<ffffffff8135467c>] _spin_lock+0x2c/0x3b
[<ffffffffa0077eb7>] ? __fscache_check_page_write+0x0/0x71 [fscache]
[<ffffffffa00b4755>] nfs_fscache_release_page+0x86/0xc4 [nfs]
[<ffffffffa00907f0>] nfs_release_page+0x3c/0x41 [nfs]
[<ffffffff81087ffb>] try_to_release_page+0x32/0x3b
[<ffffffff81092c2b>] shrink_page_list+0x316/0x4ac
[<ffffffff81058a9b>] ? mark_held_locks+0x52/0x70
[<ffffffff8135451b>] ? _spin_unlock_irq+0x2b/0x31
[<ffffffff81093153>] shrink_inactive_list+0x392/0x67c
[<ffffffff810934ca>] shrink_list+0x8d/0x8f
[<ffffffff81093744>] shrink_zone+0x278/0x33c
[<ffffffff81052c70>] ? ktime_get_ts+0xad/0xba
[<ffffffff8109453b>] try_to_free_pages+0x22e/0x392
[<ffffffff8109184c>] ? isolate_pages_global+0x0/0x212
[<ffffffff8108e16b>] __alloc_pages_nodemask+0x3dc/0x5cf
[<ffffffff810ae24a>] cache_alloc_refill+0x34d/0x6c1
[<ffffffff811bcf74>] ? radix_tree_node_alloc+0x52/0x5c
[<ffffffff810ae929>] kmem_cache_alloc+0xb2/0x118
[<ffffffff811bcf74>] radix_tree_node_alloc+0x52/0x5c
[<ffffffff811bcfd5>] radix_tree_insert+0x57/0x19c
[<ffffffffa0076b53>] __fscache_write_page+0x1e3/0x3f3 [fscache]
[<ffffffffa00b4248>] __nfs_readpage_to_fscache+0x58/0x11e [nfs]
[<ffffffffa009bb77>] nfs_readpage_release+0x34/0x9b [nfs]
[<ffffffffa009c0d9>] nfs_readpage_release_full+0x32/0x4b [nfs]
[<ffffffffa0006cff>] rpc_release_calldata+0x12/0x14 [sunrpc]
[<ffffffffa0006e2d>] rpc_free_task+0x59/0x61 [sunrpc]
[<ffffffffa0006f03>] rpc_async_release+0x10/0x12 [sunrpc]
[<ffffffff810482e5>] worker_thread+0x1ef/0x2e2
[<ffffffff81048290>] ? worker_thread+0x19a/0x2e2
[<ffffffff81352433>] ? thread_return+0x3e/0x101
[<ffffffffa0006ef3>] ? rpc_async_release+0x0/0x12 [sunrpc]
[<ffffffff8104bff5>] ? autoremove_wake_function+0x0/0x34
[<ffffffff81058d25>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff810480f6>] ? worker_thread+0x0/0x2e2
[<ffffffff8104bd21>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8104c2b9>] ? add_wait_queue+0x15/0x44
[<ffffffff8104bca7>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
radix_tree_lookup() and radix_tree_lookup_slot() have much the
same code except for the return value.
Introduce radix_tree_lookup_element() to do the real work.
* is_slot == 1 : search for the slot.
* is_slot == 0 : search for the node.
static void * radix_tree_lookup_element(struct radix_tree_root *root,
unsigned long index, int is_slot);
Signed-off-by: Huang Shijie <shijie8@gmail.com>
The counterpart of radix_tree_next_hole(). To be used by context readahead.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Vladislav Bolkhovitin <vst@vlnb.net>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Ying Han <yinghan@google.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
trivial: chack -> check typo fix in main Makefile
trivial: Add a space (and a comma) to a printk in 8250 driver
trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx
trivial: Fix misspelling of "firmware" in powerpc Makefile
trivial: Fix misspelling of "firmware" in usb.c
trivial: Fix misspelling of "firmware" in qla1280.c
trivial: Fix misspelling of "firmware" in a100u2w.c
trivial: Fix misspelling of "firmware" in megaraid.c
trivial: Fix misspelling of "firmware" in ql4_mbx.c
trivial: Fix misspelling of "firmware" in acpi_memhotplug.c
trivial: Fix misspelling of "firmware" in ipw2100.c
trivial: Fix misspelling of "firmware" in atmel.c
trivial: Fix misspelled firmware in Kconfig
trivial: fix an -> a typos in documentation and comments
trivial: fix then -> than typos in comments and documentation
trivial: update Jesper Juhl CREDITS entry with new email
trivial: fix singal -> signal typo
trivial: Fix incorrect use of "loose" in event.c
trivial: printk: fix indentation of new_text_line declaration
trivial: rtc-stk17ta8: fix sparse warning
radix_tree_preloads is unused outside of this file, make it static.
Noticed by sparse:
lib/radix-tree.c:84:1: warning: symbol 'per_cpu__radix_tree_preloads' was not declared. Should it be static?
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
And some 80-line cleanups.
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Introduce gang_lookup_slot() and gang_lookup_slot_tag() functions, which
are used by lockless pagecache.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Remove all clameter@sgi.com addresses from the kernel tree since they will
become invalid on June 27th. Change my maintainer email address for the
slab allocators to cl@linux-foundation.org (which will be the new email
address for the future).
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
We shrink a radix tree when its root node has only one child, in the left
most slot. The child becomes the new root node. To perform this
operation in a manner compatible with concurrent lockless lookups, we
atomically switch the root pointer from the parent to its child.
However a concurrent lockless lookup may now have loaded a pointer to the
parent (and is presently deciding what to do next). For this reason, we
also have to keep the parent node in a valid state after shrinking the
tree, until the next RCU grace period -- otherwise this lookup with the
parent pointer may not do the right thing. Notably, we need to keep the
child in the left most slot there in case that is requested by the lookup.
This is all pretty standard RCU stuff. It is worth repeating because in
my eagerness to obey the radix tree node constructor scheme, I had broken
it by zeroing the radix tree node before the grace period.
What could happen is that a lookup can load the parent pointer, then
decide it wants to follow the left most child slot, only to find the slot
contained NULL due to the concurrent shrinker having zeroed the parent
node before waiting for a grace period. The lookup would return a false
negative as a result.
Fix it by doing that clearing in the RCU callback. I would normally want
to rip out the constructor entirely, but radix tree nodes are one of those
places where they make sense (only few cachelines will be touched soon
after allocation).
This was never actually found in any lockless pagecache testing or by the
test harness, but by seeing the odd problem with my scalable vmap rewrite.
I have not tickled the test harness into reproducing it yet, but I'll
keep working at it.
Fortunately, it is not a problem anywhere lockless pagecache is used in
mainline kernels (pagecache probe is not a guarantee, and brd does not
have concurrent lookups and deletes).
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Migrate flags must be set on slab creation as agreed upon when the antifrag
logic was reviewed. Otherwise some slabs of a slabcache will end up in the
unmovable and others in the reclaimable section depending on which flag was
active when a new slab page was allocated.
This likely slid in somehow when antifrag was merged. Remove it.
The buffer_heads are always allocated with __GFP_RECLAIMABLE because the
SLAB_RECLAIM_ACCOUNT option is set. The set_migrateflags() never had any
effect there.
Radix tree allocations are not directly reclaimable but they are allocated
with __GFP_RECLAIMABLE set on each allocation. We now set
SLAB_RECLAIM_ACCOUNT on radix tree slab creation making sure that radix
tree slabs are consistently placed in the reclaimable section. Radix tree
slabs will also be accounted as such.
There is then no user left of set_migratepages. So remove it.
Most pagecache (and some other) radix tree insertions have the great
opportunity to preallocate a few nodes with relaxed gfp flags. But the
preallocation is squandered when it comes time to allocate a node, we
default to first attempting a GFP_ATOMIC allocation -- that doesn't
normally fail, but it can eat into atomic memory reserves that we don't
need to be using.
Another upshot of this is that it removes the sometimes highly contended
zone->lock from underneath tree_lock. Pagecache insertions are always
performed with a radix tree preload, and after this change, such a
situation will never fall back to kmem_cache_alloc within
radix_tree_node_alloc.
David Miller reports seeing this allocation fail on a highly threaded
sparc64 system:
[527319.459981] dd: page allocation failure. order:0, mode:0x20
[527319.460403] Call Trace:
[527319.460568] [00000000004b71e0] __slab_alloc+0x1b0/0x6a8
[527319.460636] [00000000004b7bbc] kmem_cache_alloc+0x4c/0xa8
[527319.460698] [000000000055309c] radix_tree_node_alloc+0x20/0x90
[527319.460763] [0000000000553238] radix_tree_insert+0x12c/0x260
[527319.460830] [0000000000495cd0] add_to_page_cache+0x38/0xb0
[527319.460893] [00000000004e4794] mpage_readpages+0x6c/0x134
[527319.460955] [000000000049c7fc] __do_page_cache_readahead+0x170/0x280
[527319.461028] [000000000049cc88] ondemand_readahead+0x208/0x214
[527319.461094] [0000000000496018] do_generic_mapping_read+0xe8/0x428
[527319.461152] [0000000000497948] generic_file_aio_read+0x108/0x170
[527319.461217] [00000000004badac] do_sync_read+0x88/0xd0
[527319.461292] [00000000004bb5cc] vfs_read+0x78/0x10c
[527319.461361] [00000000004bb920] sys_read+0x34/0x60
[527319.461424] [0000000000406294] linux_sparc_syscall32+0x3c/0x40
The calltrace is significant: __do_page_cache_readahead allocates a number
of pages with GFP_KERNEL, and hence it should have reclaimed sufficient
memory to satisfy GFP_ATOMIC allocations. However after the list of pages
goes to mpage_readpages, there can be significant intervals (including disk
IO) before all the pages are inserted into the radix-tree. So the reserves
can easily be depleted at that point. The patch is confirmed to fix the
problem.
Negative shifts are not allowed in C (the result is undefined). Same thing
with full-width shifts.
It works on most platforms but not on the VAX with gcc 4.0.1 (it results in an
"operand reserved" fault).
Shifting by more than the width of the value on the left is also not
allowed. I think the extra '>> 1' tacked on at the end in the original
code was an attempt to work around that. Getting rid of that is an extra
feature of this patch.
Here's the chapter and verse, taken from the final draft of the C99
standard ("6.5.7 Bitwise shift operators", paragraph 3):
"The integer promotions are performed on each of the operands. The
type of the result is that of the promoted left operand. If the
value of the right operand is negative or is greater than or equal
to the width of the promoted left operand, the behavior is
undefined."
Thank you to Jan-Benedict Glaw, Christoph Hellwig, Maciej Rozycki, Pekka
Enberg, Andreas Schwab, and Christoph Lameter for review. Special thanks
to Andreas for spotting that my fix only removed half the undefined
behaviour.
Signed-off-by: Peter Lund <firefly@vax64.dk>
Cc: "Maciej W. Rozycki" <macro@linux-mips.org>
Cc: Andreas Schwab <schwab@suse.de>
Cc: WU Fengguang <wfg@mail.ustc.edu.cn>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
This patch marks a number of allocations that are either short-lived such as
network buffers or are reclaimable such as inode allocations. When something
like updatedb is called, long-lived and unmovable kernel allocations tend to
be spread throughout the address space which increases fragmentation.
This patch groups these allocations together as much as possible by adding a
new MIGRATE_TYPE. The MIGRATE_RECLAIMABLE type is for allocations that can be
reclaimed on demand, but not moved. i.e. they can be migrated by deleting
them and re-reading the information from elsewhere.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Christoph Lameter <clameter@sgi.com>
A while back, Nick Piggin introduced a patch to reduce the node memory
usage for small files (commit cfd9b7df4abd3257c9e381b0e445817b26a51c0c):
-#define RADIX_TREE_MAP_SHIFT 6
+#define RADIX_TREE_MAP_SHIFT (CONFIG_BASE_SMALL ? 4 : 6)
Unfortunately, he didn't take into account the fact that the
calculation of the maximum path was based on an assumption of having
to round up:
#define RADIX_TREE_MAX_PATH (RADIX_TREE_INDEX_BITS/RADIX_TREE_MAP_SHIFT + 2)
So, if CONFIG_BASE_SMALL is set, you will end up with a
RADIX_TREE_MAX_PATH that is one greater than necessary. The practical
upshot of this is just a bit of wasted memory (one long in the
height_to_maxindex array, an extra pre-allocated radix tree node per
cpu, and extra stack usage in a couple of functions), but it seems
worth getting right.
It's also worth noting that I never build with CONFIG_BASE_SMALL.
What I did to test this was duplicate the code in a small user-space
program and check the results of the calculations for max path and the
contents of the height_to_maxindex array.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
Rather than sign direct radix-tree pointers with a special bit, sign the
indirect one that hangs off the root. This means that, given a lookup_slot
operation, the invalid result will be differentiated from the valid
(previously, valid results could have the bit either set or clear).
This does not affect slot lookups which occur under lock -- they can never
return an invalid result. Is needed in future for lockless pagecache.
Introduce radix_tree_next_hole(root, index, max_scan) to scan radix tree for
the first hole. It will be used in interleaved readahead.
The implementation is dumb and obviously correct. It can help debug(and
document) the possible smart one in future.
Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
XFS filestreams functionality uses radix trees and the preload
functions. XFS can be built as a module and hence we need
radix_tree_preload() exported. radix_tree_preload_end() is a
static inline, so it doesn't need exporting.
Signed-Off-By: Dave Chinner <dgc@sgi.com>
Signed-Off-By: Tim Shimmin <tes@sgi.com>
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
Make radix tree lookups safe to be performed without locks. Readers are
protected against nodes being deleted by using RCU based freeing. Readers
are protected against new node insertion by using memory barriers to ensure
the node itself will be properly written before it is visible in the radix
tree.
Each radix tree node keeps a record of their height (above leaf nodes).
This height does not change after insertion -- when the radix tree is
extended, higher nodes are only inserted in the top. So a lookup can take
the pointer to what is *now* the root node, and traverse down it even if
the tree is concurrently extended and this node becomes a subtree of a new
root.
"Direct" pointers (tree height of 0, where root->rnode points directly to
the data item) are handled by using the low bit of the pointer to signal
whether rnode is a direct pointer or a pointer to a radix tree node.
When a reader wants to traverse the next branch, they will take a copy of
the pointer. This pointer will be either NULL (and the branch is empty) or
non-NULL (and will point to a valid node).
[akpm@osdl.org: cleanups]
[Lee.Schermerhorn@hp.com: bugfixes, comments, simplifications]
[clameter@sgi.com: build fix]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Christoph Lameter <clameter@engr.sgi.com>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
struct radix_tree_root has unused upper bits of ->gfp_mask reused for
tags bitmap. Annotated.
In radix_tree_tag_get(), return normalized value of 0/1, as indicated
by its comment.
Signed-off-by: Wu Fengguang <wfg@mail.ustc.edu.cn>
The comment states: 'Setting a tag on a not-present item is a BUG.' Hence
if 'index' is larger than the maxindex; the item _cannot_ be presen; it
should also be a BUG.
Also, this allows the following statement (assume a fresh tree):
radix_tree_tag_set(root, 16, 1);
to fail silently, but when preceded by:
radix_tree_insert(root, 32, item);
it would BUG, because the height has been extended by the insert.
In neither case was 16 present.
Reduce radix tree node memory usage by about a factor of 4 for small files
(< 64K). There are pointer traversal and memory usage costs for large
files with dense pagecache.
The ability to have height 0 radix trees (a direct pointer to the data item
rather than going through a full node->slot) quietly disappeared with
old-2.6-bkcvs commit ffee171812d51652f9ba284302d9e5c5cc14bdfd. On 64-bit
machines this causes nearly 600 bytes to be used for every <= 4K file in
pagecache.
Re-introduce this feature, root tags stored in spare ->gfp_mask bits.
Simplify radix_tree_delete's complex tag clearing arrangement (which would
become even more complex) by just falling back to tag clearing functions
(the pagecache radix-tree never uses this path anyway, so the icache
savings will mean it's actually a speedup).
On my 4GB G5, this saves 8MB RAM per kernel kernel source+object tree in
pagecache.
Pagecache lookup, insertion, and removal speed for small files will also be
improved.
This makes RCU radix tree harder, but it's worth it.
Documentation changes to help radix tree users avoid overrunning the tags
array. RADIX_TREE_TAGS moves to linux/radix-tree.h and is now known as
RADIX_TREE_MAX_TAGS (Nick Piggin's idea). Tag parameters are changed to
unsigned, and some comments are updated.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
If a tag is set for a node being deleted from a radix_tree, then that
tag gets cleared from the parent of the node, even if it is set for some
siblings of the node begin deleted.
This patch changes the logic to include a test for any_tag_set similar
to the logic a little futher down. Care is taken to ensure that
'nr_cleared_tags' remains equals to the number of entries in the 'tags'
array which are set to '0' (which means that this tag is not set in the
tree below pathp->node, and should be cleared at pathp->node and
possibly above.
[ Nick says: "Linus FYI, I was able to modify the radix tree test
harness to catch the bug and can no longer trigger it after the fix.
Resulting code passes all other harness tests as well of course." ]
Signed-off-by: Neil Brown <neilb@suse.de>
Shrink the height of a radix tree when it is partially truncated - we only do
shrinkage of full truncation at present.
Correctly determine the tags to be cleared in radix_tree_delete() so we
don't keep moving up the tree clearing tags that we don't need to. For
example, if a tag is simply not set in the deleted item, nor anywhere up
the tree, radix_tree_delete() would attempt to clear it up the entire
height of the tree.
Also, tag_set() was made conditional so as not to dirty too many cachelines
high up in the radix tree. Instead, put this logic into
radix_tree_tag_set().
Introduce helper any_tag_set() rather than repeat the same code sequence 4
times.
Reiser4 uses radix trees to solve a trouble reiser4_readdir has serving nfs
requests.
Unfortunately, radix tree api lacks an operation suitable for modifying
existing entry. This patch adds radix_tree_lookup_slot which returns pointer
to found item within the tree. That location can be then updated.
Both Nick and Christoph Lameter have patches which need this as well.
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Fix the sparse warning "implicit cast to nocast type"
Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br>
Signed-off-by: Domen Puncer <domen@coderock.org>
cases
Simple patch to radix_tree_tag_get() to return different values for non
present node and tag unset.
The function is not used by any in-kernel callers (yet), but this
information is definitely useful.
- There is frequent use of indirections in the radix code. This patch
removes those indirections, makes the code more readable and allows
the compilers to generate better code.
- Removing indirections allows the removal of several casts.
- Removing indirections allows the reduction of the radix_tree_path
size from 3 to 2 words.
- Use pathp-> consistently.
- Remove unnecessary tmp variable in radix_tree_insert
- Separate the upper layer processing from the lowest layer in __lookup()
in order to make it easier to understand what is going on and allow
compilers to generate better code for the loop.
Cc: James Bottomley <James.Bottomley@steeleye.com>
