path: root/lib/raid6/neon.c
2013-07-08lib/raid6: add ARM-NEON accelerated syndrome calculationArd Biesheuvel
Rebased/reworked a patch contributed by Rob Herring that uses NEON intrinsics to perform the RAID-6 syndrome calculations. It uses the existing unroll.awk code to generate several unrolled versions of which the best performing one is selected at boot time. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: hpa@linux.intel.com
