path: root/lib/rbtree.c
2009-01-10rbtree: add const qualifier to some functionsArtem Bityutskiy
The 'rb_first()', 'rb_last()', 'rb_next()' and 'rb_prev()' calls take a pointer to an RB node or RB root. They do not change the pointed objects, so add a 'const' qualifier in order to make life of the users of these functions easier. Indeed, if I have my own constant pointer &const struct my_type *p, and I call 'rb_next(&p->rb)', I get a GCC warning: warning: passing argument 1 of ‘rb_next’ discards qualifiers from pointer target type Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-30[PATCH] rbtree: fixed reversed RB_EMPTY_NODE and rb_next/prevJens Axboe
The conditions got reserved. Also make rb_next() and rb_prev() check for the empty condition. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-05[RBTREE] Switch rb_colour() et al to en_US spelling of 'color' for consistencyDavid Woodhouse
Since rb_insert_color() is part of the _public_ API, while the others are purely internal, switch to be consistent with that. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-21[RBTREE] Merge colour and parent fields of struct rb_node.David Woodhouse
We only used a single bit for colour information, so having a whole machine word of space allocated for it was a bit wasteful. Instead, store it in the lowest bit of the 'parent' pointer, since that was always going to be aligned anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-21[RBTREE] Remove dead code in rb_erase()David Woodhouse
Observe rb_erase(), when the victim node 'old' has two children so neither of the simple cases at the beginning are taken. Observe that it effectively does an 'rb_next()' operation to find the next (by value) node in the tree. That is; we go to the victim's right-hand child and then follow left-hand pointers all the way down the tree as far as we can until we find the next node 'node'. We end up with 'node' being either the same immediate right-hand child of 'old', or one of its descendants on the far left-hand side. For a start, we _know_ that 'node' has a parent. We can drop that check. We also know that if 'node's parent is 'old', then 'node' is the right-hand child of its parent. And that if 'node's parent is _not_ 'old', then 'node' is the left-hand child of its parent. So instead of checking for 'node->rb_parent == old' in one place and also checking 'node's heritage separately when we're trying to change its link from its parent, we can shuffle things around a bit and do it like this... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
