When trying to allocate future tables via bucket_table_alloc(), it seems
overkill on large table shifts that we probe for kzalloc() unconditionally
first, as it's likely to fail.
Only probe with kzalloc() for more reasonable table sizes and use vzalloc()
either as a fallback on failure or directly in case of large table sizes.
Fixes: 7e1e77636e36 ("lib: Resizable, Scalable, Concurrent Hash Table")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Thomas Graf <tgraf@suug.ch>
Restore pre 54c5b7d311c8 behaviour and only probe for expansions on inserts
and shrinks on deletes. Currently, it will happen that on initial inserts
into a sparse hash table, we may i.e. shrink it first simply because it's
not fully populated yet, only to later realize that we need to grow again.
This however is counter intuitive, e.g. an initial default size of 64
elements is already small enough, and in case an elements size hint is given
to the hash table by a user, we should avoid unnecessary expansion steps,
so a shrink is clearly unintended here.
Fixes: 54c5b7d311c8 ("rhashtable: introduce rhashtable_wakeup_worker helper function")
Cc: Ying Xue <ying.xue@windriver.com>
The remove logic properly searched the remaining chain for a matching
entry with an identical hash but it did this while searching from both
the old and new table. Instead in order to not leave stale references
behind we need to:
1. When growing and searching from the new table:
Search remaining chain for entry with same hash to avoid having
the new table directly point to a entry with a different hash.
2. When shrinking and searching from the old table:
Check if the element after the removed would create a cross
reference and avoid it if so.
These bugs were present from the beginning in nft_hash.
Also, both insert functions calculated the hash based on the mask of
the new table. This worked while growing. Wwhile shrinking, the mask
of the inew table is smaller than the mask of the old table. This lead
to a bit not being taken into account when selecting the bucket lock
and thus caused the wrong bucket to be locked eventually.
Fixes: 97defe1ecf86 ("rhashtable: Per bucket locks & deferred expansion/shrinking")
Reported-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
During a resize, when two buckets in the larger table map to
a single bucket in the smaller table and the new table has already
been (partially) linked to the old table. Removal of an element
may result the bucket in the larger table to point to entries
which all hash to a different value than the bucket index. Thus
causing two buckets to point to the same sub chain after unzipping.
This is not illegal *during* the resize phase but after it has
completed.
Keep the old table around until all of the unzipping is done to
allow the removal code to only search for matching hashed entries
during this special period.
Catch hash miscalculations which result in hard to track down race
conditions.
This simplifies debugging of locking violations if compiled with
CONFIG_PROVE_LOCKING.
We need to wait for all RCU readers to complete after the last bit of
unzipping has been completed. Otherwise the old table is freed up
prematurely.
rhashtable currently allows to use a bucket lock per bucket. This
requires multiple levels of complicated nested locking because when
resizing, a single bucket of the smaller table will map to two
buckets in the larger table. So far rhashtable has explicitly locked
both buckets in the larger table.
By excluding the highest bit of the hash from the bucket lock map and
thus only allowing locks to buckets in a ratio of 1:2, the locking
can be simplified a lot without losing the benefits of multiple locks.
Larger tables which benefit from multiple locks will not have a single
lock per bucket anyway.
The value computed by key_hashfn() is used by rhashtable_lookup_compare()
to traverse both tables during a resize. key_hashfn() must therefore
return the hash value without the buckets mask applied so it can be
masked to the size of each individual table.
Some existing rhashtable users get too intimate with it by walking
the buckets directly. This prevents us from easily changing the
internals of rhashtable.
This patch adds the helpers rhashtable_walk_init/exit/start/next/stop
which will replace these custom walkers.
They are meant to be usable for both procfs seq_file walks as well
as walking by a netlink dump. The iterator structure should fit
inside a netlink dump cb structure, with at least one element to
spare.
The current being_destroyed check in rhashtable_expand is not
enough since if we start a shrinking process after freeing all
elements in the table that's also going to crash.
This patch adds a being_destroyed check to the deferred worker
thread so that we bail out as soon as we take the lock.
Allow the selftest on the resizable hash table to be built modular, just
like all other tests that do not depend on DEBUG_KERNEL.
As removals can occur during resizes, entries may be referred to from
both tbl and future_tbl when the removal is requested. Therefore
rhashtable_remove() must unlink the entry in both tables if this is
the case. The existing code did search both tables but stopped when it
hit the first match.
Failing to unlink in both tables resulted in use after free.
When we put our declared work task in the global workqueue with
schedule_delayed_work(), its delay parameter is always zero.
Therefore, we should define a regular work in rhashtable structure
instead of a delayed work.
By the way, we add a condition to check whether resizing functions
are NULL before cancelling the work, avoiding to cancel an
uninitialized work.
Lastly, while we wait for all work items we submitted before to run
to completion with cancel_delayed_work(), ht->mutex has been taken in
rhashtable_destroy(). Moreover, cancel_delayed_work() doesn't return
until all work items are accomplished, and when work items are
scheduled, the work's function - rht_deferred_worker() will be called.
However, as rht_deferred_worker() also needs to acquire the lock,
deadlock might happen at the moment as the lock is already held before.
So if the cancel work function is moved out of the lock covered scope,
this will avoid the deadlock.
Fixes: 97defe1 ("rhashtable: Per bucket locks & deferred expansion/shrinking")
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Thomas Graf <tgraf@suug.ch>
Each per bucket lock covers a configurable number of buckets. While
shrinking, two buckets in the old table contain entries for a single
bucket in the new table. We need to lock down both while linking.
Check if they are protected by different locks to avoid a recursive
lock.
Fixes: 97defe1e ("rhashtable: Per bucket locks & deferred expansion/shrinking")
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Introduce a new function called rhashtable_lookup_compare_insert()
which is very similar to rhashtable_lookup_insert(). But the former
makes use of users' given compare function to look for an object,
and then inserts it into hash table if found. As the entire process
of search and insertion is under protection of per bucket lock, this
can help users to avoid the involvement of extra lock.
Move condition statements of verifying whether hash table size exceeds
its maximum threshold or reaches its minimum threshold from resizing
functions to resizing decision functions, avoiding unnecessary wakeup
for worker queue thread.
When remove an object from hash table, we currently only traverse old
bucket table to check whether the object exists. If the object is not
found in it, we will try again. But in the second search loop, we still
search the object from the old table instead of future table. As a
result, the object may be not removed from hash table especially when
resizing is currently in progress and the object is just saved in the
future table.
Involve a new function called rhashtable_lookup_insert() which makes
lookup and insertion atomic under bucket lock protection, helping us
avoid to introduce an extra lock when we search and insert an object
into hash table.
Introduce rhashtable_wakeup_worker() helper function to reduce
duplicated code where to wake up worker.
By the way, as long as the both "future_tbl" and "tbl" bucket table
pointers point to the same bucket array, we should try to wake up
the resizing worker thread, otherwise, it indicates the work of
resizing hash table is not finished yet. However, currently we will
wake up the worker thread only when the two pointers point to
different bucket array. Obviously this is wrong. So, the issue is
also fixed as well in the patch.
Define an internal compare function and relevant compare argument,
and then make use of rhashtable_lookup_compare() to lookup key in
hash table, reducing duplicated code between rhashtable_lookup()
and rhashtable_lookup_compare().
In order to allow for wider usage of rhashtable, use a special nulls
marker to terminate each chain. The reason for not using the existing
nulls_list is that the prev pointer usage would not be valid as entries
can be linked in two different buckets at the same time.
The 4 nulls base bits can be set through the rhashtable_params structure
like this:
struct rhashtable_params params = {
.nulls_base = (1U << RHT_BASE_SHIFT),
This reduces the hash length from 32 bits to 27 bits.
Introduces an array of spinlocks to protect bucket mutations. The number
of spinlocks per CPU is configurable and selected based on the hash of
the bucket. This allows for parallel insertions and removals of entries
which do not share a lock.
The patch also defers expansion and shrinking to a worker queue which
allows insertion and removal from atomic context. Insertions and
deletions may occur in parallel to it and are only held up briefly
while the particular bucket is linked or unzipped.
Mutations of the bucket table pointer is protected by a new mutex, read
access is RCU protected.
In the event of an expansion or shrinking, the new bucket table allocated
is exposed as a so called future table as soon as the resize process
starts. Lookups, deletions, and insertions will briefly use both tables.
The future table becomes the main table after an RCU grace period and
initial linking of the old to the new table was performed. Optimization
of the chains to make use of the new number of buckets follows only the
new table is in use.
The side effect of this is that during that RCU grace period, a bucket
traversal using any rht_for_each() variant on the main table will not see
any insertions performed during the RCU grace period which would at that
point land in the future table. The lookup will see them as it searches
both tables if needed.
Having multiple insertions and removals occur in parallel requires nelems
to become an atomic counter.
The removal function of nft_hash currently stores a reference to the
previous element during lookup which is used to optimize removal later
on. This was possible because a lock is held throughout calling
rhashtable_lookup() and rhashtable_remove().
With the introdution of deferred table resizing in parallel to lookups
and insertions, the nftables lock will no longer synchronize all
table mutations and the stored pprev may become invalid.
Removing this optimization makes removal slightly more expensive on
average but allows taking the resize cost out of the insert and
remove path.
Cc: netfilter-devel@vger.kernel.org
Subsequent patches will require access to the bucket tail. Access
to the tail is relatively cheap as the automatic resizing of the
table should keep the number of entries per bucket to no more
than 0.75 on average.
This patch is in preparation to introduce per bucket spinlocks. It
extends all iterator macros to take the bucket table and bucket
index. It also introduces a new rht_dereference_bucket() to
handle protected accesses to buckets.
It introduces a barrier() to the RCU iterators to the prevent
the compiler from caching the first element.
The lockdep verifier is introduced as stub which always succeeds
and properly implement in the next patch when the locks are
introduced.
Hash the key inside of rhashtable_lookup_compare() like
rhashtable_lookup() does. This allows to simplify the hashing
functions and keep them private.
This patch effectively reverts commit 500f80872645 ("net: ovs: use CRC32
accelerated flow hash if available"), and other remaining arch_fast_hash()
users such as from nfsd via commit 6282cd565553 ("NFSD: Don't hand out
delegations for 30 seconds after recalling them.") where it has been used
as a hash function for bloom filtering.
While we think that these users are actually not much of concern, it has
been requested to remove the arch_fast_hash() library bits that arose
from [1] entirely as per recent discussion [2]. The main argument is that
using it as a hash may introduce bias due to its linearity (see avalanche
criterion) and thus makes it less clear (though we tried to document that)
when this security/performance trade-off is actually acceptable for a
general purpose library function.
Lets therefore avoid any further confusion on this matter and remove it to
prevent any future accidental misuse of it. For the time being, this is
going to make hashing of flow keys a bit more expensive in the ovs case,
but future work could reevaluate a different hashing discipline.
[1] https://patchwork.ozlabs.org/patch/299369/
[2] https://patchwork.ozlabs.org/patch/418756/
Cc: Neil Brown <neilb@suse.de>
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Jesse Gross <jesse@nicira.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Verify whether both the lock and RCU protected iterators see all
test entries before and after expanding and shrinking has been
performed. Also verify whether the number of entries in the hashtable
remains stable during expansion and shrinking.
drivers/net/ethernet/chelsio/cxgb4vf/sge.c
drivers/net/ethernet/intel/ixgbe/ixgbe_phy.c
sge.c was overlapping two changes, one to use the new
__dev_alloc_page() in net-next, and one to use s->fl_pg_order in net.
ixgbe_phy.c was a set of overlapping whitespace changes.
Reallocation is only required for shrinking and expanding and both rely
on a mutex for synchronization and callers of rhashtable_init() are in
non atomic context. Therefore, no reason to continue passing allocation
hints through the API.
Instead, use GFP_KERNEL and add __GFP_NOWARN | __GFP_NORETRY to allow
for silent fall back to vzalloc() without the OOM killer jumping in as
pointed out by Eric Dumazet and Eric W. Biederman.
Currently mutex_is_held can only test locks in the that are global
since it takes no arguments. This prevents rhashtable from being
used in places where locks are lock, e.g., per-namespace locks.
This patch adds a parent field to mutex_is_held and rhashtable_params
so that local locks can be used (and tested).
The rhashtable function mutex_is_held is only used when PROVE_LOCKING
is enabled. This patch makes the mutex_is_held field in rhashtable
optional depending on PROVE_LOCKING.
My editor spewed garbage that looked like memory corruption on
my screen. It turns out that a number of occurences of "fi" got
turned into a ligature.
This patch replaces these ligatures with the ASCII letters "fi".
Cheers,
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
drivers/net/usb/r8152.c
net/netfilter/nfnetlink.c
Both r8152 and nfnetlink conflicts were simple overlapping changes.
Pablo Neira Ayuso says:
nf pull request for net
This series contains netfilter fixes for net, they are:
1) Fix lockdep splat in nft_hash when releasing sets from the
rcu_callback context. We don't the mutex there anymore.
2) Remove unnecessary spinlock_bh in the destroy path of the nf_tables
rbtree set type from rcu_callback context.
3) Fix another lockdep splat in rhashtable. None of the callers hold
a mutex when calling rhashtable_destroy.
4) Fix duplicated error reporting from nfnetlink when aborting and
replaying a batch.
5) Fix a Kconfig issue reported by kbuild robot.
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
linux/log2.h was included twice.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Although rhashtable library allows user to specify a quiet big size
for user's created hash table, the table may be shrunk to a
very small size - HASH_MIN_SIZE(4) after object is removed from
the table at the first time. Subsequently, even if the total amount
of objects saved in the table is quite lower than user's initial
setting in a long time, the hash table size is still dynamically
adjusted by rhashtable_shrink() or rhashtable_expand() each time
object is inserted or removed from the table. However, as
synchronize_rcu() has to be called when table is shrunk or
expanded by the two functions, we should permit user to set the
minimum table size through configuring the minimum number of shifts
according to user specific requirement, avoiding these expensive
actions of shrinking or expanding because of calling synchronize_rcu().
No need for rht_dereference() from rhashtable_destroy() since the
existing callers don't hold the mutex when invoking this function
1) Netlink, this is called in case of memory allocation errors in the
initialization path, no nl_sk_hash_lock is held.
2) Netfilter, this is called from the rcu callback, no nfnl_lock is
held either.
I think it's reasonable to assume that the caller has to make sure
that no hash resizing may happen before releasing the bucket array.
Therefore, the caller should be responsible for releasing this in a
safe way, document this to make people aware of it.
This resolves a rcu lockdep splat in nft_hash:
[ INFO: suspicious RCU usage. ]
3.16.0+ #178 Not tainted
lib/rhashtable.c:596 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 1, debug_locks = 1
1 lock held by ksoftirqd/2/18:
#0: (rcu_callback){......}, at: [<ffffffff810918fd>] rcu_process_callbacks+0x27e/0x4c7
stack backtrace:
CPU: 2 PID: 18 Comm: ksoftirqd/2 Not tainted 3.16.0+ #178
Hardware name: LENOVO 23259H1/23259H1, BIOS G2ET32WW (1.12 ) 05/30/2012
0000000000000001 ffff88011706bb68 ffffffff8143debc 0000000000000000
ffff880117062610 ffff88011706bb98 ffffffff81077515 ffff8800ca041a50
0000000000000004 ffff8800ca386480 ffff8800ca041a00 ffff88011706bbb8
Call Trace:
[<ffffffff8143debc>] dump_stack+0x4e/0x68
[<ffffffff81077515>] lockdep_rcu_suspicious+0xfa/0x103
[<ffffffff81228b1b>] rhashtable_destroy+0x46/0x52
[<ffffffffa06f21a7>] nft_hash_destroy+0x73/0x82 [nft_hash]
No need to export rht_obj(), all inner to outer object translations
occur internally. It was intended to be used with rht_for_each() which
now primarily serves as the iterator for rhashtable_remove_pprev() to
effectively flush and free the full table.
Properly annotate next pointers as access is RCU protected in
the lookup path.
Generic implementation of a resizable, scalable, concurrent hash table
based on [0]. The implementation supports both, fixed size keys specified
via an offset and length, or arbitrary keys via own hash and compare
functions.
Lookups are lockless and protected as RCU read side critical sections.
Automatic growing/shrinking based on user configurable watermarks is
available while allowing concurrent lookups to take place.
Objects to be hashed must include a struct rhash_head. The reason for not
using the existing struct hlist_head is that the expansion and shrinking
will have two buckets point to a single entry which would lead in obscure
reverse chaining behaviour.
Code includes a boot selftest if CONFIG_TEST_RHASHTABLE is defined.
[0] https://www.usenix.org/legacy/event/atc11/tech/final_files/Triplett.pdf
Reviewed-by: Nikolay Aleksandrov <nikolay@redhat.com>
