path: root/lib/rwsem.c
2008-01-30x86: fix UML and -regparm=3Ingo Molnar
introduce the "asmregparm" calling convention: for functions implemented in assembly with a fixed regparm input parameters calling convention. mark the semaphore and rwsem slowpath functions with that. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18sched: mark rwsem functions as __sched for wchan/profilingLivio Soares
This following commit http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=fdf8cb0909b531f9ae8f9b9d7e4eb35ba3505f07 un-inlined a low-level rwsem function, but did not mark it as __sched. The result is that it now shows up as thread wchan (which also affects /proc/profile stats). The following simple patch fixes this by properly marking rwsem_down_failed_common() as a __sched function. Also in this patch, which is up for discussion, marks down_read() and down_write() proper as __sched. For profiling, it is pretty much useless to know that a semaphore is beig help - it is necessary to know _which_ one. By going up another frame on the stack, the information becomes much more useful. In summary, the below change to lib/rwsem.c should be applied; the changes to kernel/rwsem.c could be applied if other kernel hackers agree with my proposal that down_read()/down_write() in the profile is not enough. [ akpm@linux-foundation.org: build fix ] Signed-off-by: Livio Soares <livio@eecg.toronto.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-10-11Lockdep: add lockdep_set_class_and_subclass() and lockdep_set_subclass()Peter Zijlstra
This annotation makes it possible to assign a subclass on lock init. This annotation is meant to reduce the _nested() annotations by assigning a default subclass. One could do without this annotation and rely on lockdep_set_class() exclusively, but that would require a manual stack of struct lock_class_key objects. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-29[PATCH] lib/rwsem.c: un-inline rwsem_down_failed_common()Andreas Mohr
Un-inlining rwsem_down_failed_common() (two callsites) reduced lib/rwsem.o on my Athlon, gcc 4.1.2 from 5935 to 5480 Bytes (455 Bytes saved). I thus guess that reduced icache footprint (and better function caching) is worth more than any function call overhead. Signed-off-by: Andreas Mohr <andi@lisas.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove rwsem locking correctnessIngo Molnar
Use the lock validator framework to prove rwsem locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: clean up rwsemsIngo Molnar
Clean up rwsems. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
