path: root/lib/sort.c
2007-10-17lib/sort.c optimizationSubbaiah Venkata
Hello, I fixed and tested a small bug in lib/sort.c file, heap sort function. The fix avoids unnecessary swap of contents when i is 0 (saves few loads and stores), which happens every time sort function is called. I felt the fix is worth bringing it to your attention given the importance and frequent use of the sort function. Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] low performance of lib/sort.ckeios
It is a non-standard heap-sort algorithm implementation because the index of child node is wrong . The sort function still outputs right result, but the performance is O( n * ( log(n) + 1 ) ) , about 10% ~ 20% worse than standard algorithm. Signed-off-by: keios <keios.cn@gmail.com> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Zou Nan hai <nanhai.zou@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] lib/sort.c: small cleanupsAdrian Bunk
This patch contains the following small cleanups: - make two needlessly global functions static - every file should #include the header files containing the prototypes of it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] fix lib/sort regression testDomen Puncer
The regression test in lib/sort.c is currently worthless because the array that is generated for sorting will be all zeros. This patch fixes things so that the array that is generated will contain unsorted integers (that are not all identical) as was probably intended. Signed-off-by Daniel Dickman <didickman@yahoo.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
