path: root/lib/string.c
2011-05-19Add a strtobool function matching semantics of existing in kernel equivalentsJonathan Cameron
This is a rename of the usr_strtobool proposal, which was a renamed, relocated and fixed version of previous kstrtobool RFC Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-03-06lib/string.c: simplify strnstr()André Goddard Rosa
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Joe Perches <joe@perches.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06lib/string.c: simplify stricmp()André Goddard Rosa
Removes 32 bytes on core2 with gcc 4.4.1: text data bss dec hex filename 3196 0 0 3196 c7c lib/string-BEFORE.o 3164 0 0 3164 c5c lib/string-AFTER.o Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-14lib: Introduce strnstr()Li Zefan
It differs strstr() in that it limits the length to be searched in the first string. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4B4E8743.6030805@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-22lib/string.c: fix kernel-doc warningsRandy Dunlap
Fix kernel-doc warnings (@arg name) in string.c::skip_spaces(). Warning(lib/string.c:347): No description found for parameter 'str' Warning(lib/string.c:347): Excess function parameter 's' description in 'skip_spaces' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Subject: Re: [PATCH] strstrip incorrectly marked __must_checkKOSAKI Motohiro
Recently, We marked strstrip() as must_check. because it was frequently misused and it should be checked. However, we found one exception. scsi/ipr.c intentionally ignore return value of strstrip. Because it wishes to keep the whitespace at the beginning. Thus we need to keep with and without checked whitespace trim function. This patch adds a new strim() and changes ipr.c to use it. [akpm@linux-foundation.org: coding-style fixes] Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15string: on strstrip(), first remove leading spaces before running over strAndré Goddard Rosa
... so that strlen() iterates over a smaller string comprising of the remaining characters only. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15string: factorize skip_spaces and export it to be generally availableAndré Goddard Rosa
On the following sentence: while (*s && isspace(*s)) s++; If *s == 0, isspace() evaluates to ((_ctype[*s] & 0x20) != 0), which evaluates to ((0x08 & 0x20) != 0) which equals to 0 as well. If *s == 1, we depend on isspace() result anyway. In other words, "a char equals zero is never a space", so remove this check. Also, *s != 0 is most common case (non-null string). Fixed const return as noticed by Jan Engelhardt and James Bottomley. Fixed unnecessary extra cast on strstrip() as noticed by Jan Engelhardt. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-18strcmp: fix overflow and possibly signedness errorLinus Torvalds
Doing the strcmp return value as signed char __res = *cs - *ct; is wrong for two reasons. The subtraction can overflow because __res doesn't use a type big enough. Moreover the compared bytes should be interpreted as unsigned char as specified by POSIX. The same problem is fixed in strncmp. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Michael Buesch <mb@bu3sch.de> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01Add a new sysfs_streq() string comparison functionDavid Brownell
Add a new sysfs_streq() string comparison function, which ignores the trailing newlines found in sysfs inputs. By example: sysfs_streq("a", "b") ==> false sysfs_streq("a", "a") ==> true sysfs_streq("a", "a\n") ==> true sysfs_streq("a\n", "a") ==> true This is intended to simplify parsing of sysfs inputs, letting them avoid the need to manually strip off newlines from inputs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-28[PATCH] strstrip remove last blank fixMichael Holzheu
strstrip() does not remove the last blank from strings which only consist of blanks. Example: char string[] = " "; strstrip(string); results in " ", but should produce an empty string! The following patch solves this problem: Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by Joern Engel <joern@wh.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] strstrip() APIPekka Enberg
Add a new strstrip() function to lib/string.c for removing leading and trailing whitespace from a string. Cc: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Ingo Oeser <ioe-lkml@rameria.de> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Silence a const vs non-const warningJan-Benedict Glaw
lib/string.c: In function 'memcpy': lib/string.c:470: warning: initialization discards qualifiers from pointer = target type Signed-off-by: Jan-Benedict Glaw <jbglaw@lug-owl.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Clean up arch-overrides in linux/string.hKyle McMartin
Some string functions were safely overrideable in lib/string.c, but their corresponding declarations in linux/string.h were not. Correct this, and make strcspn overrideable. Odds of someone wanting to do optimized assembly of these are small, but for the sake of cleanliness, might as well bring them into line with the rest of the file. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] No arch-specific strpbrk implementationsKyle McMartin
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't being exported from lib/string.c. Investigating further, I noticed a changeset that removed its export and added it to _ksyms.c on a few more architectures. The justification was that "other arches do it." I think this is wrong, since no architecture currently defines __HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it themselves. Therefore, consolidate the export to lib/string.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] multiple exports of strpbrkAndrew Morton
Sam's tree includes a new check, which found that we're exporting strpbrk() multiple times. It seems that the convention is that this is exported from the arch files, so reove the lib/string.c export. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: restore useful memmove constPaul Jackson
A couple of (char *) casts removed in a previous cleanup patch in lib/string.c:memmove() were actually useful, as they suppressed a couple of warnings: assignment discards qualifiers from pointer target type Fix by declaring the local variable const in the first place, so casts aren't needed to strip the const qualifier. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: remove pointless explicit castsJesper Juhl
The first two hunks of the patch really belongs in patch 1, but I missed them on the first pass and instead of redoing all 3 patches I stuck them in this one. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: remove pointless register keywordJesper Juhl
Removes a few pointless register keywords. register is merely a compiler hint that access to the variable should be optimized, but gcc (3.3.6 in my case) generates the exact same code with and without the keyword, and even if gcc did something different with register present I think it is doubtful we would want to optimize access to these variables - especially since this is generic library code and there are supposed to be optimized versions in asm/ for anything that really matters speed wise. (akpm: iirc, keyword register is a gcc no-op unless using -O0) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: whitespace and CodingStyle cleanupsJesper Juhl
Removes some blank lines, removes some trailing whitespace, adds spaces after commas and a few similar changes. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] documentation for strncpy()walter harms
this clarifies the documentation on the behavier of strncpy(). Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] x86_64: make string func definition work as intendedPaolo 'Blaisorblade' Giarrusso
In include/asm-x86_64/string.h there are such comments: /* Use C out of line version for memcmp */ #define memcmp __builtin_memcmp int memcmp(const void * cs,const void * ct,size_t count); This would mean that if the compiler does not decide to use __builtin_memcmp, it emits a call to memcmp to be satisfied by the C out-of-line version in lib/string.c. What happens is that after preprocessing, in lib/string.i you may find the definition of "__builtin_strcmp". Actually, by accident, in the object you will find the definition of strcmp and such (maybe a trick intended to redirect calls to __builtin_memcmp to the default memcmp when the definition is not expanded); however, this particular case is not a documented feature as far as I can see. Also, the EXPORT_SYMBOL does not work, so it's duplicated in the arch. I simply added some #undef to lib/string.c and removed the (now duplicated) exports in x86-64 and UML/x86_64 subarchs (the second ones are introduced by another patch I just posted for -mm). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
