path: root/lib/swiotlb.c
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-20lib: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-12-06swiotlb: Expose swiotlb_nr_tlb function to modulesKonrad Rzeszutek Wilk
As a mechanism to detect whether SWIOTLB is enabled or not. We also fix the spelling - it was swioltb instead of swiotlb. CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> [v1: Ripped out swiotlb_enabled] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-06swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.FUJITA Tomonori
By default the io_tlb_nslabs is set to zero, and gets set to whatever value is passed in via swiotlb_init_with_tbl function. The default value passed in is 64MB. However, if the user provides the 'swiotlb=<nslabs>' the default value is ignored and the value provided by the user is used... Except when the SWIOTLB is used under Xen - there the default value of 64MB is used and the Xen-SWIOTLB has no mechanism to get the 'io_tlb_nslabs' filled out by setup_io_tlb_npages functions. This patch provides a function for the Xen-SWIOTLB to call to see if the io_tlb_nslabs is set and if so use that value. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-25swiotlb: fix wrong panicFUJITA Tomonori
swiotlb's map_page wrongly calls panic() when it can't find a buffer fit for device's dma mask. It should return an error instead. Devices with an odd dma mask (i.e. under 4G) like b44 network card hit this bug (the system crashes): http://marc.info/?l=linux-kernel&m=129648943830106&w=2 If swiotlb returns an error, b44 driver can use the own bouncing mechanism. Reported-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11swiotlb: Use page alignment for early buffer allocationYinghai Lu
We could call free_bootmem_late() if swiotlb is not used, and it will shrink to page alignment. So alloc them with page alignment at first, to avoid lose two pages before patch: [ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer [ 0.000000] memblock_x86_reserve_range: [00d7e7ef40, 00d7e9ef40] swiotlb list [ 0.000000] memblock_x86_reserve_range: [00d7e3ef40, 00d7e7ef40] swiotlb orig_ad [ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo after patch will get [ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer [ 0.000000] memblock_x86_reserve_range: [00d7e7e000, 00d7e9e000] swiotlb list [ 0.000000] memblock_x86_reserve_range: [00d7e3e000, 00d7e7e000] swiotlb orig_ad [ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-11swiotlb: make io_tlb_overflow staticFUJITA Tomonori
We don't need to export io_tlb_overflow_buffer. I'll remove io_tlb_overflow_buffer completely in the long term though. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-06-07swiotlb: Make swiotlb bookkeeping functions visible in the header file.Konrad Rzeszutek Wilk
We put the functions dealing with the operations on the SWIOTLB buffer in the header and make those functions non-static. And also make the functions exported via EXPORT_SYMBOL_GPL. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: swiotlb_sync_single_range_for_* no more. Remove usage.] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: search and replace "int dir" with "enum dma_data_direction dir"Konrad Rzeszutek Wilk
.. to catch anybody doing something funky. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: swiotlb_sync_single_range_* no more - removed usage] [v3: enum dma_data_direction direction -> enum dma_data_direction dir] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: Make internal bookkeeping functions have 'swiotlb_tbl' prefix.Konrad Rzeszutek Wilk
The functions that operate on io_tlb_list/io_tlb_start/io_tlb_orig_addr have the prefix 'swiotlb_tbl' now. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: add the swiotlb initialization function with iotlb memoryFUJITA Tomonori
This enables the caller to initialize swiotlb with its own iotlb memory. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: changed ..with_tlb to ..with_tbl] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: add swiotlb_tbl_map_single library functionFUJITA Tomonori
swiotlb_tbl_map_single() takes the dma address of iotlb instead of using swiotlb_virt_to_bus(). [v2: changed swiotlb_tlb to swiotlb_tbl] [v3: changed u64 to dma_addr_t] This patch: This is a set of patches that separate the address translation (virt_to_phys, virt_to_bus, etc) and allocation of the SWIOTLB buffer from the SWIOTLB library. The idea behind this set of patches is to make it possible to have separate mechanisms for translating virtual to physical or virtual to DMA addresses on platforms which need an SWIOTLB, and where physical != PCI bus address and also to allocate the core IOTLB memory outside SWIOTLB. One customers of this is the pv-ops project, which can switch between different modes of operation depending on the environment it is running in: bare-metal or virtualized (Xen for now). Another is the Wii DMA - used to implement the MEM2 DMA facility needed by its EHCI controller (for details: http://lkml.org/lkml/2010/5/18/303) On bare-metal SWIOTLB is used when there are no hardware IOMMU. In virtualized environment it used when PCI pass-through is enabled for the guest. The problems with PCI pass-through is that the guest's idea of PFN's is not the real thing. To fix that, there is translation layer for PFN->machine frame number and vice-versa. To bubble that up to the SWIOTLB layer there are two possible solutions. One solution has been to wholesale copy the SWIOTLB, stick it in arch/x86/xen/swiotlb.c and modify the virt_to_phys, phys_to_virt and others to use the Xen address translation functions. Unfortunately, since the kernel can run on bare-metal, there would be big code overlap with the real SWIOTLB. (git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git xen/dom0/swiotlb-new) Another approach, which this set of patches explores, is to abstract the address translation and address determination functions away from the SWIOTLB book-keeping functions. This way the core SWIOTLB library functions are present in one place, while the address related functions are in a separate library that can be loaded when running under non-bare-metal platform. Changelog: Since the last posting [v8.2] Konrad has done: - Added this changelog in the patch and referenced in the other patches this description. - 'enum dma_data_direction direction' to 'enum dma.. dir' so to be unified. [v8-v8.2 changes:] - Rolled-up the last two patches in one. - Rebased against linus latest. That meant dealing with swiotlb_sync_single_range_* changes. - added Acked-by: Fujita Tomonori and Tested-by: Albert Herranz [v7-v8 changes:] - Minimized the list of exported functions. - Integrated Fujita's patches and changed "swiotlb_tlb" to "swiotlb_tbl" in them. [v6-v7 changes:] - Minimized the amount of exported functions/variable with a prefix of: "swiotbl_tbl". - Made the usage of 'int dir' to be 'enum dma_data_direction'. [v5-v6 changes:] - Made the exported functions/variables have the 'swiotlb_bk' prefix. - dropped the checkpatches/other reworks Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-05-27swiotlb: remove unnecessary swiotlb_sync_single_range_*FUJITA Tomonori
swiotlb_sync_single_range_for_cpu and swiotlb_sync_single_range_for_device are unnecessary because swiotlb_sync_single_for_cpu and swiotlb_sync_single_for_device can be used instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16dma-mapping: fix off-by-one error in dma_capable()Jan Beulich
dma_mask is, when interpreted as address, the last valid byte, and hence comparison msut also be done using the last valid of the buffer in question. Also fix the open-coded instances in lib/swiotlb.c. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-11swiotlb: Remove the swiotlb variable usageFUJITA Tomonori
POWERPC doesn't expect it to be used. This fixes the linux-next build failure reported by Stephen Rothwell: lib/swiotlb.c: In function 'setup_io_tlb_npages': lib/swiotlb.c:114: error: 'swiotlb' undeclared (first use in this function) Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: peterz@infradead.org LKML-Reference: <20091112000258F.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: Handle HW IOMMU initialization failure gracefullyFUJITA Tomonori
If HW IOMMU initialization fails (Intel VT-d often does this, typically due to BIOS bugs), we fall back to nommu. It doesn't work for the majority since nowadays we have more than 4GB memory so we must use swiotlb instead of nommu. The problem is that it's too late to initialize swiotlb when HW IOMMU initialization fails. We need to allocate swiotlb memory earlier from bootmem allocator. Chris explained the issue in detail: http://marc.info/?l=linux-kernel&m=125657444317079&w=2 The current x86 IOMMU initialization sequence is too complicated and handling the above issue makes it more hacky. This patch changes x86 IOMMU initialization sequence to handle the above issue cleanly. The new x86 IOMMU initialization sequence are: 1. we initialize the swiotlb (and setting swiotlb to 1) in the case of (max_pfn > MAX_DMA32_PFN && !no_iommu). dma_ops is set to swiotlb_dma_ops or nommu_dma_ops. if swiotlb usage is forced by the boot option, we finish here. 2. we call the detection functions of all the IOMMUs 3. the detection function sets x86_init.iommu.iommu_init to the IOMMU initialization function (so we can avoid calling the initialization functions of all the IOMMUs needlessly). 4. if the IOMMU initialization function doesn't need to swiotlb then sets swiotlb to zero (e.g. the initialization is sucessful). 5. if we find that swiotlb is set to zero, we free swiotlb resource. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-10-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10swiotlb: Defer swiotlb init printing, export swiotlb_print_info()FUJITA Tomonori
This enables us to avoid printing swiotlb memory info when we initialize swiotlb. After swiotlb initialization, we could find that we don't need swiotlb. This patch removes the code to print swiotlb memory info in swiotlb_init() and exports the function to do that. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com Cc: tony.luck@intel.com Cc: benh@kernel.crashing.org LKML-Reference: <1257849980-22640-9-git-send-email-fujita.tomonori@lab.ntt.co.jp> [ -v2: merge up conflict ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10swiotlb: Add swiotlb_free() functionFUJITA Tomonori
swiotlb_free() function frees all allocated memory for swiotlb. We need to initialize swiotlb before IOMMU initialization (x86 and powerpc needs to allocate memory from bootmem allocator). If IOMMU initialization is successful, we need to free swiotlb resource (don't want to waste 64MB). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-8-git-send-email-fujita.tomonori@lab.ntt.co.jp> [ -v2: build fix for the !CONFIG_SWIOTLB case ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21lib/swiotlb.c: Fix strange panic message selection logic when swiotlb fills upCasey Dahlin
swiotlb_full() in lib/swiotlb.c throws one of two panic messages based on whether the direction of transfer is from the device or to the device. The logic around this is somewhat weird in the case of bidirectional transfers. It appears to want to throw both in succession, but since its a panic only the first makes it. This patch adds a third, separate error for DMA_BIDIRECTIONAL to make things a bit clearer. Signed-off-by: Casey Dahlin <cdahlin@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> [ further fixed the error message ] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200908202327.n7KNRuqK001504@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-28swiotlb: use phys_to_dma and dma_to_physFUJITA Tomonori
This converts swiotlb to use phys_to_dma and dma_to_phys instead of swiotlb_phys_to_bus() and swiotlb_bus_to_phys(). swiotlb_phys_to_bus() and swiotlb_bus_to_phys() are not necessary so this patch also removes them. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-28swiotlb: use dma_capable()FUJITA Tomonori
This converts swiotlb to use dma_capable() instead of swiotlb_arch_address_needs_mapping() and is_buffer_dma_capable(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-28swiotlb: remove unnecessary swiotlb_bus_to_virtFUJITA Tomonori
swiotlb_bus_to_virt is unncessary; we can use swiotlb_bus_to_phys and phys_to_virt instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-28swiotlb: remove swiotlb_arch_range_needs_mappingFUJITA Tomonori
Nobody uses swiotlb_arch_range_needs_mapping(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-28swiotlb: remove unused swiotlb_alloc()FUJITA Tomonori
Nobody uses swiotlb_alloc(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-28swiotlb: remove unused swiotlb_alloc_boot()FUJITA Tomonori
Nobody uses swiotlb_alloc_boot(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-04-08swiotlb: change swiotlb_bus_to[phys,virt] prototypesBecky Bruce
Add a hwdev argument that is needed on some architectures in order to access a per-device offset that is taken into account when producing a physical address (also needed to get from bus address to virtual address because the physical address is an intermediate step). Also make swiotlb_bus_to_virt weak so architectures can override it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-8-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: use swiotlb_sync_single instead of duplicating codeBecky Bruce
Right now both swiotlb_sync_single_range and swiotlb_sync_sg were duplicating the code in swiotlb_sync_single. Just call it instead. Also rearrange the sync_single code for readability. Note that the swiotlb_sync_sg code was previously doing a complicated comparison to determine if an addresses needed to be unmapped where a simple is_swiotlb_buffer() call would have sufficed. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-7-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: rename unmap_single to do_unmap_singleBecky Bruce
Previously, swiotlb_unmap_page and swiotlb_unmap_sg were duplicating very similar code. Refactor that code into a new unmap_single and unmap_single use do_unmap_single. Note that the swiotlb_unmap_sg code was previously doing a complicated comparison to determine if an addresses needed to be unmapped where a simple is_swiotlb_buffer() call would have sufficed. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-6-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: allow arch override of address_needs_mappingBecky Bruce
Some architectures require additional checking to determine if a device can dma to an address and need to provide their own address_needs_mapping.. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-5-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: map_page fix for highmem systemsBecky Bruce
The current code calls virt_to_phys() on address that might be in highmem, which is bad. This wasn't needed, anyway, because we already have the physical address we need. Get rid of the now-unused virtual address as well. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-4-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: fix compile warningBecky Bruce
Squash a build warning seen on 32-bit powerpc caused by calling min() with 2 different types. Use min_t() instead. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-3-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08swiotlb: comment correctionsBecky Bruce
Impact: cleanup swiotlb_map/unmap_single are now swiotlb_map/unmap_page; trivially change all the comments to reference new names. Also, there were some comments that should have been referring to just plain old map_single, not swiotlb_map_single; fix those as well. Also change a use of the word "pointer", when what is referred to is actually a dma/physical address. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: jeremy@goop.org Cc: ian.campbell@citrix.com LKML-Reference: <1239199761-22886-2-git-send-email-galak@kernel.crashing.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-11swiotlb: do not use sg_virt()Ian Campbell
Scatterlists containing HighMem pages do not have a useful virtual address. Use the physical address instead. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11swiotlb: range_needs_mapping should take a physical address.Ian Campbell
The swiotlb_arch_range_needs_mapping() hook should take a physical address rather than a virtual address in order to support highmem pages. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11Merge branch 'linus' into core/iommuIngo Molnar
2009-01-06Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: fix rcutorture bug rcu: eliminate synchronize_rcu_xxx macro rcu: make treercu safe for suspend and resume rcu: fix rcutree grace-period-latency bug on small systems futex: catch certain assymetric (get|put)_futex_key calls futex: make futex_(get|put)_key() calls symmetric locking, percpu counters: introduce separate lock classes swiotlb: clean up EXPORT_SYMBOL usage swiotlb: remove unnecessary declaration swiotlb: replace architecture-specific swiotlb.h with linux/swiotlb.h swiotlb: add support for systems with highmem swiotlb: store phys address in io_tlb_orig_addr array swiotlb: add hwdev to swiotlb_phys_to_bus() / swiotlb_sg_to_bus()
2009-01-06swiotlb: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06x86, ia64: remove duplicated swiotlb codeFUJITA Tomonori
This adds swiotlb_map_page and swiotlb_unmap_page to lib/swiotlb.c and remove IA64 and X86's swiotlb_map_page and swiotlb_unmap_page. This also removes unnecessary swiotlb_map_single, swiotlb_map_single_attrs, swiotlb_unmap_single and swiotlb_unmap_single_attrs. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, ia64: convert to use generic dma_map_ops structFUJITA Tomonori
This converts X86 and IA64 to use include/linux/dma-mapping.h. It's a bit large but pretty boring. The major change for X86 is converting 'int dir' to 'enum dma_data_direction dir' in DMA mapping operations. The major changes for IA64 is using map_page and unmap_page instead of map_single and unmap_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-05Merge branch 'core/iommu' into core/urgentIngo Molnar
Conflicts: lib/swiotlb.c
2009-01-04swiotlb: Don't include linux/swiotlb.h twice in lib/swiotlb.cJesper Juhl
There's no point in including the linux/swiotlb.h header twice in lib/swiotlb.c - this patch gets rid of the unneeded include. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-02swiotlb: add missing __init annotationsRoland Dreier
Impact: cleanup, reduce kernel size a bit The current kernel build warns: WARNING: vmlinux.o(.text+0x11458): Section mismatch in reference from the function swiotlb_alloc_boot() to the function .init.text:__alloc_bootmem_low() The function swiotlb_alloc_boot() references the function __init __alloc_bootmem_low(). This is often because swiotlb_alloc_boot lacks a __init annotation or the annotation of __alloc_bootmem_low is wrong. WARNING: vmlinux.o(.text+0x1011f2): Section mismatch in reference from the function swiotlb_late_init_with_default_size() to the function .init.text:__alloc_bootmem_low() The function swiotlb_late_init_with_default_size() references the function __init __alloc_bootmem_low(). This is often because swiotlb_late_init_with_default_size lacks a __init annotation or the annotation of __alloc_bootmem_low is wrong. and indeed the functions calling __alloc_bootmem_low() can be marked __init as well. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-28swiotlb: clean up EXPORT_SYMBOL usageFUJITA Tomonori
Impact: cleanup swiotlb uses EXPORT_SYMBOL in an inconsistent way. Some functions use EXPORT_SYMBOL at the end of functions. Some use it at the end of swiotlb.c. This cleans up swiotlb to use EXPORT_SYMBOL in a consistent way (at the end of functions). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-28swiotlb: remove unnecessary declarationFUJITA Tomonori
Impact: cleanup Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
