2019-09-04 | test_firmware: add support for request_firmware_into_buf | Scott Branden | |
Add test config into_buf to allow request_firmware_into_buf to be called instead of request_firmware/request_firmware_direct. The number of parameters differ calling request_firmware_into_buf and support has not been added to test such api in test_firmware until now. Signed-off-by: Scott Branden <scott.branden@broadcom.com> Acked-by: Luis Chamberlain <mcgrof@kernel.org> Acked-by: Shuah Khan <skhan@linuxfoundation.org> Link: https://lore.kernel.org/r/20190822184005.901-2-scott.branden@broadcom.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2019-07-25 | test_firmware: fix a memory leak bug | Wenwen Wang | |
In test_firmware_init(), the buffer pointed to by the global pointer 'test_fw_config' is allocated through kzalloc(). Then, the buffer is initialized in __test_firmware_config_init(). In the case that the initialization fails, the following execution in test_firmware_init() needs to be terminated with an error code returned to indicate this failure. However, the allocated buffer is not freed on this execution path, leading to a memory leak bug. To fix the above issue, free the allocated buffer before returning from test_firmware_init(). Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu> Link: https://lore.kernel.org/r/1563084696-6865-1-git-send-email-wang6495@umn.edu Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2019-06-08 | Merge tag 'char-misc-5.2-rc4' of ↵ | Linus Torvalds | |
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are some small char and misc driver fixes for 5.2-rc4 to resolve a number of reported issues. The most "notable" one here is the kernel headers in proc^Wsysfs fixes. Those changes move the header file info into sysfs and fixes the build issues that you reported. Other than that, a bunch of small habanalabs driver fixes, some fpga driver fixes, and a few other tiny driver fixes. All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-5.2-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: habanalabs: Read upper bits of trace buffer from RWPHI habanalabs: Fix virtual address access via debugfs for 2MB pages fpga: zynqmp-fpga: Correctly handle error pointer habanalabs: fix bug in checking huge page optimization habanalabs: Avoid using a non-initialized MMU cache mutex habanalabs: fix debugfs code uapi/habanalabs: add opcode for enable/disable device debug mode habanalabs: halt debug engines on user process close test_firmware: Use correct snprintf() limit genwqe: Prevent an integer overflow in the ioctl parport: Fix mem leak in parport_register_dev_model fpga: dfl: expand minor range when registering chrdev region fpga: dfl: Add lockdep classes for pdata->lock fpga: dfl: afu: Pass the correct device to dma_mapping_error() fpga: stratix10-soc: fix use-after-free on s10_init() w1: ds2408: Fix typo after 49695ac46861 (reset on output_write retry with readback) kheaders: Do not regenerate archive if config is not changed kheaders: Move from proc to sysfs lkdtm/bugs: Adjust recursion test to avoid elision lkdtm/usercopy: Moves the KERNEL_DS test to non-canonical | |||
2019-05-24 | test_firmware: Use correct snprintf() limit | Dan Carpenter | |
The limit here is supposed to be how much of the page is left, but it's just using PAGE_SIZE as the limit. The other thing to remember is that snprintf() returns the number of bytes which would have been copied if we had had enough room. So that means that if we run out of space then this code would end up passing a negative value as the limit and the kernel would print an error message. I have change the code to use scnprintf() which returns the number of bytes that were successfully printed (not counting the NUL terminator). Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2019-05-21 | treewide: Add SPDX license identifier for more missed files | Thomas Gleixner | |
Add SPDX license identifiers to all files which: - Have no license information of any form - Have MODULE_LICENCE("GPL*") inside which was used in the initial scan/conversion to ignore the file These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2019-03-07 | lib/test_firmware.c: remove some dead code | Dan Carpenter | |
The test_fw_config->reqs allocation succeeded so these addresses can't be NULL. Also on the second error path, we forgot to set "rc = -ENOMEM;". Link: http://lkml.kernel.org/r/20190221183700.GA1737@kadam Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> | |||
2018-11-11 | test_firmware: fix error return getting clobbered | Colin Ian King | |
In the case where eq->fw->size > PAGE_SIZE the error return rc is being set to EINVAL however this is being overwritten to rc = req->fw->size because the error exit path via label 'out' is not being taken. Fix this by adding the jump to the error exit path 'out'. Detected by CoverityScan, CID#1453465 ("Unused value") Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests") Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2018-06-12 | treewide: Use array_size() in vzalloc() | Kees Cook | |
The vzalloc() function has no 2-factor argument form, so multiplication factors need to be wrapped in array_size(). This patch replaces cases of: vzalloc(a * b) with: vzalloc(array_size(a, b)) as well as handling cases of: vzalloc(a * b * c) with: vzalloc(array3_size(a, b, c)) This does, however, attempt to ignore constant size factors like: vzalloc(4 * 1024) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ type TYPE; expression THING, E; @@ ( vzalloc( - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | vzalloc( - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression COUNT; typedef u8; typedef __u8; @@ ( vzalloc( - sizeof(u8) * (COUNT) + COUNT , ...) | vzalloc( - sizeof(__u8) * (COUNT) + COUNT , ...) | vzalloc( - sizeof(char) * (COUNT) + COUNT , ...) | vzalloc( - sizeof(unsigned char) * (COUNT) + COUNT , ...) | vzalloc( - sizeof(u8) * COUNT + COUNT , ...) | vzalloc( - sizeof(__u8) * COUNT + COUNT , ...) | vzalloc( - sizeof(char) * COUNT + COUNT , ...) | vzalloc( - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( vzalloc( - sizeof(TYPE) * (COUNT_ID) + array_size(COUNT_ID, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * COUNT_ID + array_size(COUNT_ID, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * (COUNT_CONST) + array_size(COUNT_CONST, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * COUNT_CONST + array_size(COUNT_CONST, sizeof(TYPE)) , ...) | vzalloc( - sizeof(THING) * (COUNT_ID) + array_size(COUNT_ID, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * COUNT_ID + array_size(COUNT_ID, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * (COUNT_CONST) + array_size(COUNT_CONST, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * COUNT_CONST + array_size(COUNT_CONST, sizeof(THING)) , ...) ) // 2-factor product, only identifiers. @@ identifier SIZE, COUNT; @@ vzalloc( - SIZE * COUNT + array_size(COUNT, SIZE) , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( vzalloc( - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vzalloc( - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | vzalloc( - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | vzalloc( - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( vzalloc( - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | vzalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | vzalloc( - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | vzalloc( - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | vzalloc( - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | vzalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ identifier STRIDE, SIZE, COUNT; @@ ( vzalloc( - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | vzalloc( - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products // when they're not all constants... @@ expression E1, E2, E3; constant C1, C2, C3; @@ ( vzalloc(C1 * C2 * C3, ...) | vzalloc( - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants. @@ expression E1, E2; constant C1, C2; @@ ( vzalloc(C1 * C2, ...) | vzalloc( - E1 * E2 + array_size(E1, E2) , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org> | |||
2018-04-05 | headers: untangle kmemleak.h from mm.h | Randy Dunlap | |
Currently <linux/slab.h> #includes <linux/kmemleak.h> for no obvious reason. It looks like it's only a convenience, so remove kmemleak.h from slab.h and add <linux/kmemleak.h> to any users of kmemleak_* that don't already #include it. Also remove <linux/kmemleak.h> from source files that do not use it. This is tested on i386 allmodconfig and x86_64 allmodconfig. It would be good to run it through the 0day bot for other $ARCHes. I have neither the horsepower nor the storage space for the other $ARCHes. Update: This patch has been extensively build-tested by both the 0day bot & kisskb/ozlabs build farms. Both of them reported 2 build failures for which patches are included here (in v2). [ slab.h is the second most used header file after module.h; kernel.h is right there with slab.h. There could be some minor error in the counting due to some #includes having comments after them and I didn't combine all of those. ] [akpm@linux-foundation.org: security/keys/big_key.c needs vmalloc.h, per sfr] Link: http://lkml.kernel.org/r/e4309f98-3749-93e1-4bb7-d9501a39d015@infradead.org Link: http://kisskb.ellerman.id.au/kisskb/head/13396/ Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Reviewed-by: Ingo Molnar <mingo@kernel.org> Reported-by: Michael Ellerman <mpe@ellerman.id.au> [2 build failures] Reported-by: Fengguang Wu <fengguang.wu@intel.com> [2 build failures] Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Wei Yongjun <weiyongjun1@huawei.com> Cc: Luis R. Rodriguez <mcgrof@kernel.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: John Johansen <john.johansen@canonical.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> | |||
2018-01-22 | test_firmware: fix missing unlock on error in config_num_requests_store() | Wei Yongjun | |
Add the missing unlock before return from function config_num_requests_store() in the error handling case. Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests") Cc: stable <stable@vger.kernel.org> Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2018-01-22 | test_firmware: make local symbol test_fw_config static | Wei Yongjun | |
Fixes the following sparse warnings: lib/test_firmware.c:99:20: warning: symbol 'test_fw_config' was not declared. Should it be static? Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2018-01-09 | treewide: Use DEVICE_ATTR_RW | Joe Perches | |
Convert DEVICE_ATTR uses to DEVICE_ATTR_RW where possible. Done with perl script: $ git grep -w --name-only DEVICE_ATTR | \ xargs perl -i -e 'local $/; while (<>) { s/\bDEVICE_ATTR\s*\(\s*(\w+)\s*,\s*\(?(\s*S_IRUGO\s*\|\s*S_IWUSR|\s*S_IWUSR\s*\|\s*S_IRUGO\s*|\s*0644\s*)\)?\s*,\s*\1_show\s*,\s*\1_store\s*\)/DEVICE_ATTR_RW(\1)/g; print;}' Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2017-08-10 | test_firmware: add batched firmware tests | Luis R. Rodriguez | |
The firmware API has a feature to enable batching requests for the same fil e under one worker, so only one lookup is done. This only triggers if we so happen to schedule two lookups for same file around the same time, or if release_firmware() has not been called for a successful firmware call. This can happen for instance if you happen to have multiple devices and one device driver for certain drivers where the stars line up scheduling wise. This adds a new sync and async test trigger. Instead of adding a new trigger for each new test type we make the tests a bit configurable so that we could configure the tests in userspace and just kick a test through a few basic triggers. With this, for instance the two types of sync requests: o request_firmware() and o request_firmware_direct() can be modified with a knob. Likewise the two type of async requests: o request_firmware_nowait(uevent=true) and o request_firmware_nowait(uevent=false) can be configured with another knob. The call request_firmware_into_buf() has no users... yet. The old tests are left in place as-is given they serve a few other purposes which we are currently not interested in also testing yet. This will change later as we will be able to just consolidate all tests under a few basic triggers with just one general configuration setup. We perform two types of tests, one for where the file is present and one for where the file is not present. All test tests go tested and they now pass for the following 3 kernel builds possible for the firmware API: 0. Most distro setup: CONFIG_FW_LOADER_USER_HELPER_FALLBACK=n CONFIG_FW_LOADER_USER_HELPER=y 1. Android: CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y CONFIG_FW_LOADER_USER_HELPER=y 2. Rare build: CONFIG_FW_LOADER_USER_HELPER_FALLBACK=n CONFIG_FW_LOADER_USER_HELPER=n Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2017-01-25 | test_firmware: add test custom fallback trigger | Luis R. Rodriguez | |
We have no custom fallback mechanism test interface. Provide one. This tests both the custom fallback mechanism and cancelling the it. Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2017-01-25 | test_firmware: use device attribute groups | Luis R. Rodriguez | |
This simplifies init and exit. Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2017-01-25 | test_firmware: move misc_device down | Luis R. Rodriguez | |
This will make further changes easier to review. Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2016-01-07 | test: firmware_class: add asynchronous request trigger | Brian Norris | |
We might want to test for bugs like that found in commit f9692b2699bd ("firmware: fix possible use after free on name on asynchronous request"), where the asynchronous request API had race conditions. Let's add a simple file that will launch the async request, then wait until it's complete and report the status. It's not a true async test (we're using a mutex + wait_for_completion(), so we can't get more than one going at the same time), but it does help make sure the basic API is sane, and it can catch some class of bugs. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Cc: Luis R. Rodriguez <mcgrof@suse.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> | |||
2016-01-07 | test: firmware_class: use kstrndup() where appropriate | Brian Norris | |
We're essentially just doing an open-coded kstrndup(). The only differences are with what happens after the first '\0' character, but request_firmware() doesn't care about that. Suggested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> | |||
2016-01-07 | test: firmware_class: report errors properly on failure | Brian Norris | |
request_firmware() failures currently won't get reported at all (the error code is discarded). What's more, we get confusing messages, like: # echo -n notafile > /sys/devices/virtual/misc/test_firmware/trigger_request [ 8280.311856] test_firmware: loading 'notafile' [ 8280.317042] test_firmware: load of 'notafile' failed: -2 [ 8280.322445] test_firmware: loaded: 0 # echo $? 0 Report the failures via write() errors, and don't say we "loaded" anything. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> | |||
2014-07-17 | test: add firmware_class loader test | Kees Cook | |
This provides a simple interface to trigger the firmware_class loader to test built-in, filesystem, and user helper modes. Additionally adds tests via the new interface to the selftests tree. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> |
