path: root/lib/vsprintf.c
2010-03-06vsprintf: move %pR resource printf_specs off the stackBjorn Helgaas
This adds separate I/O and memory specs, so we don't have to change the field width in a shared spec, which then lets us make all the specs const and static, since they never change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vsprintf: clarify comments for printf_spec flagsBjorn Helgaas
Add clues about what the SMALL and SPECIAL flags do. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vsprintf.c: Reduce sizeof struct printf_spec from 24 to 8 bytesJoe Perches
Reducing the size of struct printf_spec is a good thing because multiple instances are commonly passed on stack. It's possible for type to be u8 and field_width to be s8, but this is likely small enough for now. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-13lib/vsprintf.c: Add IPV4 options %pI4[hnbl] for host, network, big and ↵Joe Perches
little endian This should allow the removal of the #defines and uses of NIPQUAD and NIPQUAD_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11vsnprintf: fix reference for compressed ipv6 addressesUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reported-by: Josip Rodin <joy@entuzijast.net> Cc: Joe Perches <joe@perches.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11lib: Kill bit-reversed FDDI MAC output case, it's bogus.Joe Perches
2010-01-07lib/vsprintf.c: Add %pMF to format FDDI bit reversed MAC addressesJoe Perches
On Mon, 2010-01-04 at 23:43 +0000, Maciej W. Rozycki wrote: > The example below shows an address, and the sequence of bits or symbols > that would be transmitted when the address is used in the Source Address > or Destination Address fields on the MAC header. The transmission line > shows the address bits in the order transmitted, from left to right. For > IEEE 802 LANs these correspond to actual bits on the medium. The FDDI > symbols line shows how the FDDI PHY sends the address bits as encoded > symbols. > > MSB: 35:7B:12:00:00:01 > Canonical: AC-DE-48-00-00-80 > Transmission: 00110101 01111011 00010010 00000000 00000000 00000001 > FDDI Symbols: 35 7B 12 00 00 01" > > Please note that this address has its group bit clear. > > This notation is also defined in the "FDDI MEDIA ACCESS CONTROL-2 > (MAC-2)" (X3T9/92-120) document although that book does not have a need > to use the MSB form and it's skipped. Adds 6 bytes to object size for x86 New: $ size lib/vsprintf.o text data bss dec hex filename 8664 0 2 8666 21da lib/vsprintf.o $ size lib/vsprintf.o text data bss dec hex filename 8658 0 2 8660 21d4 lib/vsprintf.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-17lib/vsprintf.c: document more vsnprintf extensionsUwe Kleine-König
These were added in 9ac6e44 (lib/vsprintf.c: add %pU to print UUID/GUIDs) c7dabef (vsprintf: use %pR, %pr instead of %pRt, %pRf) 8a27f7c (lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 address) 4aa9960 (printk: add %I4, %I6, %i4, %i6 format specifiers) dd45c9c (printk: add %pM format specifier for MAC addresses) but only added comments to pointer() not vsnprintf() that is refered to by printk's comments. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Joe Perches <joe@perches.com> Cc: Jens Rosenboom <jens@mcbone.net> Cc: David S. Miller <davem@davemloft.net> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15lib/vsprintf.c: add %pU to print UUID/GUIDsJoe Perches
UUID/GUIDs are somewhat common in kernel source. Standardize the printed style of UUID/GUIDs by using another extension to %p. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 (upper case) %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 %pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 (upper case) %pU defaults to %pUb Signed-off-by: Joe Perches <joe@perches.com> Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: reuse almost identical simple_strtoulX() functionsAndré Goddard Rosa
The difference between simple_strtoul() and simple_strtoull() is just the size of the variable used to keep track of the sum of characters converted to numbers: unsigned long simple_strtoul() {...} unsigned long long simple_strtoull(){...} Both are same size on my Core 2/gcc 4.4.1. Overflow condition is not checked on both functions, so an extremely large string can break these functions so that they don't even notice it. As we do not care for overflowing on these functions, always keep the sum using the larger variable around (unsigned long long) on simple_strtoull() and cast it to (unsigned long) on simple_strtoul(), which then becomes just a wrapper around simple_strtoull(). Code size decreases by 304 bytes: text data bss dec hex filename 15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-BEFORE) 15230 0 8 15238 3b86 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: factor out skip_space code in a separate functionAndré Goddard Rosa
When converting more caller sites, the inline decision will be left up to gcc. It decreases code size: text data bss dec hex filename 15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-BEFORE) 15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: move local vars to block local vars and remove unneeded onesAndré Goddard Rosa
Cleanup by moving variables closer to the scope where they're used in fact. Also, remove unneeded ones. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: reduce code size by avoiding extra checkAndré Goddard Rosa
No functional change, just refactor the code so that it avoid checking "if (hi)" two times in a sequence, taking advantage of previous check made. It also reduces code size: text data bss dec hex filename 15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-BEFORE) 15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: use TOLOWER whenever possibleAndré Goddard Rosa
It decreases code size as well: text data bss dec hex filename 15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-BEFORE) 15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-TOLOWER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: give it some care to please checkpatch.plAndré Goddard Rosa
Most relevant complaints were addressed. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: pre-calculate final string length for later useAndré Goddard Rosa
2009-12-15vsprintf: factorize "(null)" stringAndré Goddard Rosa
This patchset reduces lib/lib.a code size by 482 bytes on my Core 2 with gcc 4.4.1 even considering that it exports a newly defined function skip_spaces() to drivers: text data bss dec hex filename 64867 840 592 66299 102fb (TOTALS-lib.a-BEFORE) 64641 584 592 65817 10119 (TOTALS-lib.a-AFTER) and implements some code tidy up. Besides reducing lib.a size, it converts many in-tree drivers to use the newly defined function, which makes another small reduction on kernel size overall when those drivers are used. This patch: Change "<NULL>" to "(null)", unifying 3 equal strings. glibc also uses "(null)" for the same purpose. It decreases code size by 7 bytes: text data bss dec hex filename 15765 0 8 15773 3d9d vsprintf.o (ex lib/lib.a-BEFORE) 15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: add %pRt, %pRf to print struct resource detailsBjorn Helgaas
This adds support for printing struct resource type and flag information. For example, "%pRt" looks like "[mem 0x80080000000-0x8008001ffff 64bit pref]", and "%pRf" looks like "[mem 0xff5e2000-0xff5e2007 pref flags 0x1]". Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: add %pR support for IRQ and DMA resourcesBjorn Helgaas
Print addresses (IO port numbers and memory addresses) in hex, but print others (IRQs and DMA channels) in decimal. Only print the end if it's different from the start. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: fix io/mem resource widthBjorn Helgaas
The leading "0x" consumes field width, so leave space for it in addition to the 4 or 8 hex digits. This means we'll print "0x0000-0x01df" rather than "0x00-0x1df", for example. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-10-01sscanf(): fix %*s%nAndy Spencer
When using %*s, sscanf should honor conversion specifiers immediately following the %*s. For example, the following code should find the position of the end of the string "hello". int end; char buf[] = "hello world"; sscanf(buf, "%*s%n", &end); printf("%d\n", end); Ideally, sscanf would advance the fmt and str pointers the same as it would without the *, but the code for that is rather complicated and is not included in the patch. Signed-off-by: Andy Spencer <andy753421@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/cpc-usb/TODO drivers/staging/cpc-usb/cpc-usb_drv.c drivers/staging/cpc-usb/cpc.h drivers/staging/cpc-usb/cpc_int.h drivers/staging/cpc-usb/cpcusb.h
2009-09-22lib/vsprintf.c: Avoid possible unaligned accesses in %pI6cJoe Perches
Jens Rosenboom noticed that a possibly unaligned const char* is cast to a const struct in6_addr *. Avoid this at the cost of a struct in6_addr copy on the stack. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22vsprintf: use WARN_ON_ONCEMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17vsnprintf: remove duplicate comment of vsnprintfSteven Rostedt
Remove the duplicate comment of bstr_printf that is the same as the vsnprintf. Add the 's' option to the comment for the pointer function. This is more of an internal function so the little duplication of the comment here is OK. Reported-by: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-17vsprintf: add %ps that is the same as %pS but is like %pfSteven Rostedt
On PowerPC64 function pointers do not point directly at the functions, but instead point to pointers to the functions. The output of %pF expects to point to a pointer to the function, whereas %pS will show the function itself. mcount returns the direct pointer to the function and not the pointer to the pointer. Thus %pS must be used to show this. The function tracer requires printing of the functions without offsets and uses the %pf instead. %pF produces run_local_timers+0x4/0x1f %pf produces just run_local_timers For PowerPC64, we need to use the direct pointer, and we only have %pS which will produce .run_local_timers+0x4/0x1f This patch creates a %ps that matches the %pf as %pS matches %pF. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-29lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 addressJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Jens Rosenboom <jens@mcbone.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29vsprintf: introduce %pf format specifierFrederic Weisbecker
A printf format specifier which would allow us to print a pure function name has been suggested by Andrew Morton a couple of months ago. The current %pF is very convenient to print a function symbol, but often we only want to print the name of the function, without its asm offset. That's what %pf does in this patch. The lowecase f has been chosen for its intuitive meaning of a 'weak kind of %pF'. The support for this new format would be welcome by the tracing code where the need to print pure function names is often needed. This is also true for other parts of the kernel: $ git-grep -E "kallsyms_lookup\(.+?\)" arch/blackfin/kernel/traps.c: symname = kallsyms_lookup(address, &symsize, &offset, &modname, namebuf); arch/powerpc/xmon/xmon.c: name = kallsyms_lookup(pc, &size, &offset, NULL, tmpstr); arch/sh/kernel/cpu/sh5/unwind.c: sym = kallsyms_lookup(pc, NULL, &offset, NULL, namebuf); arch/x86/kernel/ftrace.c: kallsyms_lookup((unsigned long) syscall, NULL, NULL, NULL, str); kernel/kprobes.c: sym = kallsyms_lookup((unsigned long)p->addr, NULL, kernel/lockdep.c: return kallsyms_lookup((unsigned long)key, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup((unsigned long)rec->ops->func, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str); kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, &modname, str); kernel/trace/ftrace.c: kallsyms_lookup(*ptr, NULL, NULL, NULL, str); kernel/trace/trace_functions.c: kallsyms_lookup(ip, NULL, NULL, NULL, str); kernel/trace/trace_output.c: kallsyms_lookup(address, NULL, NULL, NULL, str); Changes in v2: - Add the explanation of the %pf role for vsnprintf() and bstr_printf() - Change the comments by dropping the "asm offset" notion and only define the %pf against the actual function offset notion. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20090415154817.GC5989@nowhere> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08printk: add support of hh length modifier for printkZhaolei
Impact: new feature, extend vsprintf format strings hh is used as length modifier for signed char or unsigned char. It is supported by glibc, we add kernel support now. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: torvalds@linux-foundation.org Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49CC9739.30107@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08printk: fix wrong format string iter for printkZhaolei
printk("%Q"); Output before patch: %QQ Output after patch: %Q Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: torvalds@linux-foundation.org Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49CC97B6.7040809@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14vsprintf: unify the format decoding layer for its 3 users, cleanupVegard Nossum
Impact: cleanup Rename FORMAT_TYPE_WITDH to => FORMAT_TYPE_WIDTH Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14fix regression from "vsprintf: unify the format decoding layer for its 3 users"Vegard Nossum
Jeremy Fitzhardinge reported: > Change fef20d9c1380f04ba9492d6463148db07b413708, "vsprintf: > unify the format decoding layer for its 3 users", causes a > regression in xenbus which results in no devices getting > attached to a new domain. %.*s is broken - fix it. Reported-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10vsprintf: fix bug in negative value printingFrederic Weisbecker
Sitsofe Wheeler found and bisected that while unifying the vsprintf format decoding in: fef20d9: vsprintf: unify the format decoding layer for its 3 users The sign flag has been dropped out in favour of precise types (ie: LONG/ULONG). But the format helper number() still needs this flag to keep track of the signedness unless it will consider all numbers as unsigned. Also add an explicit cast to int (for %d) while parsing with va_arg() to ensure the highest bit is well extended on the 64 bits number that hosts the value in case of negative values. Reported-Bisected-Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20090309201503.GA5010@nowhere> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06vsprintf: unify the format decoding layer for its 3 usersFrederic Weisbecker
An new optimization is making its way to ftrace. Its purpose is to make trace_printk() consuming less memory and be faster. Written by Lai Jiangshan, the approach is to delay the formatting job from tracing time to output time. Currently, a call to trace_printk() will format the whole string and insert it into the ring buffer. Then you can read it on /debug/tracing/trace file. The new implementation stores the address of the format string and the binary parameters into the ring buffer, making the packet more compact and faster to insert. Later, when the user exports the traces, the format string is retrieved with the binary parameters and the formatting job is eventually done. The new implementation rewrites a lot of format decoding bits from vsnprintf() function, making now 3 differents functions to maintain in their duplicated parts of printf format decoding bits. Suggested by Ingo Molnar, this patch tries to factorize the most possible common bits from these functions. The real common part between them is the format decoding. Although they do somewhat similar jobs, their way to export or import the parameters is very different. Thus, only the decoding layer is extracted, unless you see other parts that could be worth factorized. Changes in V2: - Address a suggestion from Linus to group the format_decode() parameters inside a structure. Changes in v3: - Address other cleanups suggested by Ingo and Linus such as passing the printf_spec struct to the format helpers: pointer()/number()/string() Note that this struct is passed by copy and not by address. This is to avoid side effects because these functions often change these values and the changes shoudn't be persistant when a callee helper returns. It would be too risky. - Various cleanups (code alignement, switch/case instead of if/else fountains). - Fix a bug that printed the first format specifier following a %p Changes in v4: - drop unapropriate const qualifier loss while casting fmt to a char * (thanks to Vegard Nossum for having pointed this out). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-6-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06vsprintf: add binary printfLai Jiangshan
Impact: add new APIs for binary trace printk infrastructure vbin_printf(): write args to binary buffer, string is copied when "%s" is occurred. bstr_printf(): read from binary buffer for args and format a string [fweisbec@gmail.com: rebase] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1236356510-8381-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06strict_strto* is not strict enoughPavel Machek
It decodes "\n" as 0, which is bad, because stray echo into backlight will turn your backlight off, etc... Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Yi Yang <yi.y.yang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-03Make %p print '(null)' for NULL pointersLinus Torvalds
Before, when we only ever printed out the pointer value itself, a NULL pointer would never cause issues and might as well be printed out as just its numeric value. However, with the extended %p formats, especially %pR, we might validly want to print out resources for debugging. And sometimes they don't even exist, and the resource pointer is just NULL. Print it out as such, rather than oopsing. This is a more generic version of a patch done by Trent Piepho (catching all %p cases rather than just %pR, and using "(null)" instead of "[NULL]" to match glibc). Requested-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-25aoe: remove private mac address format functionHarvey Harrison
Add %pm to omit the colons when printing a mac address. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03printk: ipv4 address digits printed in reverse orderHarvey Harrison
put_dec_trunc prints the digits in reverse order and is reversed inside number(). Continue using put_dec_trunc, but reverse each quad in ip4_addr_string. [Noticed by Julius Volz] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29printk: remove %p6 format specifier, fix up commentsHarvey Harrison
2008-10-29printk: add %I4, %I6, %i4, %i6 format specifiersHarvey Harrison
For use in printing IPv4, or IPv6 addresses in the usual way: %i4 and %I4 are currently equivalent and print the address in dot-separated decimal x.x.x.x %I6 prints 16-bit network order hex with colon separators: xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx %i6 omits the colons. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28printk: add %p6 format specifier for IPv6 addressesHarvey Harrison
Takes a pointer to a IPv6 address and formats it in the usual colon-separated hex format: xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx Each 16 bit word is printed in network-endian byteorder. %#p6 is also supported and will omit the colons. %p6 is a replacement for NIP6_FMT and NIP6() %#p6 is a replacement for NIP6_SEQFMT and NIP6() Note that NIP6() took a struct in6_addr whereas this takes a pointer to a struct in6_addr. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27printk: add %pM format specifier for MAC addressesHarvey Harrison
Add format specifiers for printing out six colon-separated bytes: MAC addresses (%pM): xx:xx:xx:xx:xx:xx %#pM is also supported and omits the colon separators. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-20Implement %pR to print struct resource contentLinus Torvalds
Add a %pR option to the kernel vsnprintf that prints the range of addresses inside a struct resource passed by pointer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16lib: remove defining macros for strict_strto??Harvey Harrison
Open-code them rather than using defining macros. The function bodies are now next to their kerneldoc comments as a bonus. Add casts to the signed cases as they call into the unsigned versions. Avoids the sparse warnings: lib/vsprintf.c:249:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:249:1: expected unsigned long *res lib/vsprintf.c:249:1: got long *res lib/vsprintf.c:249:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:249:1: expected unsigned long *res lib/vsprintf.c:249:1: got long *res lib/vsprintf.c:251:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:251:1: expected unsigned long long *res lib/vsprintf.c:251:1: got long long *res lib/vsprintf.c:251:1: warning: incorrect type in argument 3 (different signedness) lib/vsprintf.c:251:1: expected unsigned long long *res lib/vsprintf.c:251:1: got long long *res Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16lib: trivial whitespace tidyHarvey Harrison
Remove extra lines before the EXPORT_SYMBOL()s Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16lib: pull base-guessing logic to helper functionHarvey Harrison
The default base is 10 unless there is a leading zero, in which case the base will be guessed as 8. The base will only be guesed as 16 when the string starts with '0x' the third character is a valid hex digit. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
