path: root/lib/vsprintf.c
2018-07-03lib/vsprintf: Remove atomic-unsafe support for %pCrGeert Uytterhoeven
commit 666902e42fd8344b923c02dc5b0f37948ff4f225 upstream. "%pCr" formats the current rate of a clock, and calls clk_get_rate(). The latter obtains a mutex, hence it must not be called from atomic context. Remove support for this rarely-used format, as vsprintf() (and e.g. printk()) must be callable from any context. Any remaining out-of-tree users will start seeing the clock's name printed instead of its rate. Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com> Fixes: 900cca2944254edd ("lib/vsprintf: add %pC{,n,r} format specifiers for clocks") Link: http://lkml.kernel.org/r/1527845302-12159-5-git-send-email-geert+renesas@glider.be To: Jia-Ju Bai <baijiaju1990@gmail.com> To: Jonathan Corbet <corbet@lwn.net> To: Michael Turquette <mturquette@baylibre.com> To: Stephen Boyd <sboyd@kernel.org> To: Zhang Rui <rui.zhang@intel.com> To: Eduardo Valentin <edubezval@gmail.com> To: Eric Anholt <eric@anholt.net> To: Stefan Wahren <stefan.wahren@i2se.com> To: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-doc@vger.kernel.org Cc: linux-clk@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: linux-serial@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-20lib/uuid.c: introduce a few more generic helpersAndy Shevchenko
There are new helpers in this patch: uuid_is_valid checks if a UUID is valid uuid_be_to_bin converts from string to binary (big endian) uuid_le_to_bin converts from string to binary (little endian) They will be used in future, i.e. in the following patches in the series. This also moves the indices arrays to lib/uuid.c to be shared accross modules. [andriy.shevchenko@linux.intel.com: fix typo] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20lib/vsprintf: simplify UUID printingAndy Shevchenko
There are few functions here and there along with type definitions that provide UUID API. This series consolidates everything under one hood and converts current users. This has been tested for a while internally, however it doesn't mean we covered all possible cases (especially accuracy of UUID constants after conversion). So, please test this as much as you can and provide your tag. We appreciate the effort. The ACPI conversion is postponed for now to sort more generic things out first. This patch (of 9): Since we have hex_byte_pack_upper() we may use it directly and avoid second loop. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17sscanf: implement basic character setsJessica Yu
Implement basic character sets for the '%[' conversion specifier. The '%[' conversion specifier matches a nonempty sequence of characters from the specified set of accepted (or with '^', rejected) characters between the brackets. The substring matched is to be made up of characters in (or not in) the set. This is useful for matching substrings that are delimited by something other than spaces. This implementation differs from its glibc counterpart in the following ways: (1) No support for character ranges (e.g., 'a-z' or '0-9') (2) The hyphen '-' is not a special character (3) The closing bracket ']' cannot be matched (4) No support (yet) for discarding matching input ('%*[') The bitmap code is largely based upon sample code which was provided by Rasmus. The motivation for adding character set support to sscanf originally stemmed from the kernel livepatching project. An ongoing patchset utilizes new livepatch Elf symbol and section names to store important metadata livepatch needs to properly apply its patches. Such metadata is stored in these section and symbol names as substrings delimited by periods '.' and commas ','. For example, a livepatch symbol name might look like this: .klp.sym.vmlinux.printk,0 However, sscanf currently can only extract "substrings" delimited by whitespace using the "%s" specifier. Thus for the above symbol name, one cannot not use sscanf() to extract substrings "vmlinux" or "printk", for example. A number of discussions on the livepatch mailing list dealing with string parsing code for extracting these '.' and ',' delimited substrings eventually led to the conclusion that such code would be completely unnecessary if the kernel sscanf() supported character sets. Thus only a single sscanf() call would be necessary to extract these substrings. In addition, such an addition to sscanf() could benefit other areas of the kernel that might have a similar need in the future. [akpm@linux-foundation.org: 80-col tweaks] Signed-off-by: Jessica Yu <jeyu@redhat.com> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm, printk: introduce new format string for flagsVlastimil Babka
In mm we use several kinds of flags bitfields that are sometimes printed for debugging purposes, or exported to userspace via sysfs. To make them easier to interpret independently on kernel version and config, we want to dump also the symbolic flag names. So far this has been done with repeated calls to pr_cont(), which is unreliable on SMP, and not usable for e.g. sysfs export. To get a more reliable and universal solution, this patch extends printk() format string for pointers to handle the page flags (%pGp), gfp_flags (%pGg) and vma flags (%pGv). Existing users of dump_flag_names() are converted and simplified. It would be possible to pass flags by value instead of pointer, but the %p format string for pointers already has extensions for various kernel structures, so it's a good fit, and the extra indirection in a non-critical path is negligible. [linux@rasmusvillemoes.dk: lots of good implementation suggestions] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-11vsprintf: kptr_restrict is okay in IRQ when 2Jason A. Donenfeld
The kptr_restrict flag, when set to 1, only prints the kernel address when the user has CAP_SYSLOG. When it is set to 2, the kernel address is always printed as zero. When set to 1, this needs to check whether or not we're in IRQ. However, when set to 2, this check is unneccessary, and produces confusing results in dmesg. Thus, only make sure we're not in IRQ when mode 1 is used, but not mode 2. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf: factor out %pN[F] handler as netdev_bits()Andy Shevchenko
Move switch case to the netdev_features_string() and rename it to netdev_bits(). In the future we can extend it as needed. Here we replace the fallback of %pN from '%p' with possible flags to sticter '0x%p' without any flags variation. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf: refactor duplicate code to special_hex_number()Andy Shevchenko
special_hex_number() is a helper to print a fixed size type in a hex format with '0x' prefix, zero padding, and small letters. In the module we have already several copies of such code. Consolidate them under special_hex_number() helper. There are couple of differences though. It seems nobody cared about the output in case of CONFIG_KALLSYMS=n, when printing symbol address, because the asked field width is not enough to care last 2 characters in the string represantation of the pointer. Fixed here. The %pNF specifier used to be allowed with a specific field width, though there is neither any user of it nor mention the possibility in the documentation. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: warn about too large precisions and field widthsRasmus Villemoes
The field width is overloaded to pass some extra information for some %p extensions (e.g. #bits for %pb). But we might silently truncate the passed value when we stash it in struct printf_spec (see e.g. "lib/vsprintf.c: expand field_width to 24 bits"). Hopefully 23 value bits should now be enough for everybody, but if not, let's make some noise. Do the same for the precision. In both cases, clamping seems more sensible than truncating. While, according to POSIX, "A negative precision is taken as if the precision were omitted.", the kernel's printf has always treated that case as if the precision was 0, so we use that as lower bound. For the field width, the smallest representable value is actually -(1<<23), but a negative field width means 'set the LEFT flag and use the absolute value', so we want the absolute value to fit. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: help gcc make number() smallerRasmus Villemoes
One consequence of the reorganization of struct printf_spec to make field_width 24 bits was that number() gained about 180 bytes. Since spec is never passed to other functions, we can help gcc make number() lose most of that extra weight by using local variables for the field width and precision. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: expand field_width to 24 bitsRasmus Villemoes
Maurizio Lombardi reported a problem [1] with the %pb extension: It doesn't work for sufficiently large bitmaps, since the size is stashed in the field_width field of the struct printf_spec, which is currently an s16. Concretely, this manifested itself in /sys/bus/pseudo/drivers/scsi_debug/map being empty, since the bitmap printer got a size of 0, which is the 16 bit truncation of the actual bitmap size. We do want to keep struct printf_spec at 8 bytes so that it can cheaply be passed by value. The qualifier field is only used for internal bookkeeping in format_decode, so we might as well use a local variable for that. This gives us an additional 8 bits, which we can then use for the field width. To stay in 8 bytes, we need to do a little rearranging and make the type member a bitfield as well. For consistency, change all the members to bit fields. gcc doesn't generate much worse code with these changes (in fact, bloat-o-meter says we save 300 bytes - which I think is a little surprising). I didn't find a BUILD_BUG/compiletime_assertion/... which would work outside function context, so for now I just open-coded it. [1] http://thread.gmane.org/gmane.linux.kernel/2034835 [akpm@linux-foundation.org: avoid open-coded BUILD_BUG_ON] Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reported-by: Maurizio Lombardi <mlombard@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: eliminate potential race in string()Rasmus Villemoes
If the string corresponding to a %s specifier can change under us, we might end up copying a \0 byte to the output buffer. There might be callers who expect the output buffer to contain a genuine C string whose length is exactly the snprintf return value (assuming truncation hasn't happened or has been checked for). We can avoid this by only passing over the source string once, stopping the first time we meet a nul byte (or when we reach the given precision), and then letting widen_string() handle left/right space padding. As a small bonus, this code reuse also makes the generated code slightly smaller. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: move string() below widen_string()Rasmus Villemoes
This is pure code movement, making sure the widen_string() helper is defined before the string() function. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: pull out padding code from dentry_name()Rasmus Villemoes
Pull out the logic in dentry_name() which handles field width space padding, in preparation for reusing it from string(). Rename the widen() helper to move_right(), since it is used for handling the !(flags & LEFT) case. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-06lib/vsprintf: add %*pg format specifierDmitry Monakhov
This allow to directly print block_device name. Currently one should use bdevname() with temporal char buffer. This is very ineffective because bloat stack usage for deep IO call-traces Example: %pg -> sda, sda1 or loop0p1 [AV: fixed a minor braino - position updates should not be dependent upon having reached the of buffer] Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-06lib/vsprintf.c: update documentationRasmus Villemoes
%n is no longer just ignored; it results in early return from vsnprintf. Also add a request to add test cases for future %p extensions. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Martin Kletzander <mkletzan@redhat.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06lib/vsprintf.c: remove SPECIAL handling in pointer()Rasmus Villemoes
As a quick git grep -E '%[ +0#-]*#[ +0#-]*(\*|[0-9]+)?(\.(\*|[0-9]+)?)?p' shows, nobody uses the # flag with %p. Should one try to do so, one will be met with warning: `#' flag used with `%p' gnu_printf format [-Wformat] (POSIX and C99 both say "... For other conversion specifiers, the behavior is undefined.". Obviously, the kernel can choose to define the behaviour however it wants, but as long as gcc issues that warning, users are unlikely to show up.) Since default_width is effectively always 2*sizeof(void*), we can simplify the prologue of pointer() and save a few instructions. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Martin Kletzander <mkletzan@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06lib/vsprintf.c: also improve sanity check in bstr_printf()Rasmus Villemoes
Quoting from 2aa2f9e21e4e ("lib/vsprintf.c: improve sanity check in vsnprintf()"): On 64 bit, size may very well be huge even if bit 31 happens to be 0. Somehow it doesn't feel right that one can pass a 5 GiB buffer but not a 3 GiB one. So cap at INT_MAX as was probably the intention all along. This is also the made-up value passed by sprintf and vsprintf. I should have seen this copy-pasted instance back then, but let's just do it now. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Martin Kletzander <mkletzan@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06lib/vsprintf.c: handle invalid format specifiers more robustlyRasmus Villemoes
If we meet any invalid or unsupported format specifier, 'handling' it by just printing it as a literal string is not safe: Presumably the format string and the arguments passed gcc's type checking, but that means something like sprintf(buf, "%n %pd", &intvar, dentry) would end up interpreting &intvar as a struct dentry*. When the offending specifier was %n it used to be at the end of the format string, but we can't rely on that always being the case. Also, gcc doesn't complain about some more or less exotic qualifiers (or 'length modifiers' in posix-speak) such as 'j' or 'q', but being unrecognized by the kernel's printf implementation, they'd be interpreted as unknown specifiers, and the rest of arguments would be interpreted wrongly. So let's complain about anything we don't understand, not just %n, and stop pretending that we'd be able to make sense of the rest of the format/arguments. If the offending specifier is in a printk() call we unfortunately only get a "BUG: recent printk recursion!", but at least direct users of the sprintf family will be caught. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Martin Kletzander <mkletzan@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06printk: synchronize %p formatting documentationMartin Kletzander
Move all pointer-formatting documentation to one place in the code and one place in the documentation instead of keeping it in three places with different level of completeness. Documentation/printk-formats.txt has detailed information about each modifier, docstring above pointer() has short descriptions of them (as that is the function dealing with %p) and docstring above vsprintf() is removed as redundant. Both docstrings in the code that were modified are updated with a reminder of updating the documentation upon any further change. [akpm@linux-foundation.org: fix comment] Signed-off-by: Martin Kletzander <mkletzan@redhat.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-20lib/vsprintf.c: Include clk.hStephen Boyd
This file uses the clk API so it should include clk.h directly instead of indirectly including it through clk-provider.h. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-04-17lib/vsprintf.c: improve put_dec_trunc8 slightlyRasmus Villemoes
I hadn't had enough coffee when I wrote this. Currently, the final increment of buf depends on the value loaded from the table, and causes gcc to emit a cmov immediately before the return. It is smarter to let it depend on r, since the increment can then be computed in parallel with the final load/store pair. It also shaves 16 bytes of .text. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17lib/vsprintf.c: even faster binary to decimal conversionRasmus Villemoes
The most expensive part of decimal conversion is the divisions by 10 (albeit done using reciprocal multiplication with appropriately chosen constants). I decided to see if one could eliminate around half of these multiplications by emitting two digits at a time, at the cost of a 200 byte lookup table, and it does indeed seem like there is something to be gained, especially on 64 bits. Microbenchmarking shows improvements ranging from -50% (for numbers uniformly distributed in [0, 2^64-1]) to -25% (for numbers heavily biased toward the smaller end, a more realistic distribution). On a larger scale, perf shows that top, one of the big consumers of /proc data, uses 0.5-1.0% fewer cpu cycles. I had to jump through some hoops to get the 32 bit code to compile and run on my 64 bit machine, so I'm not sure how relevant these numbers are, but just for comparison the microbenchmark showed improvements between -30% and -10%. The bloat-o-meter costs are around 150 bytes (the generated code is a little smaller, so it's not the full 200 bytes) on both 32 and 64 bit. I'm aware that extra cache misses won't show up in a microbenchmark as used above, but on the other hand decimal conversions often happen in bulk (for example in the case of top). I have of course tested that the new code generates the same output as the old, for both the first and last 1e10 numbers in [0,2^64-1] and 4e9 'random' numbers in-between. Test and verification code on github: https://github.com/Villemoes/dec. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Tested-by: Jeff Epler <jepler@unpythonic.net> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/string_helpers.c: change semantics of string_escape_memRasmus Villemoes
The current semantics of string_escape_mem are inadequate for one of its current users, vsnprintf(). If that is to honour its contract, it must know how much space would be needed for the entire escaped buffer, and string_escape_mem provides no way of obtaining that (short of allocating a large enough buffer (~4 times input string) to let it play with, and that's definitely a big no-no inside vsnprintf). So change the semantics for string_escape_mem to be more snprintf-like: Return the size of the output that would be generated if the destination buffer was big enough, but of course still only write to the part of dst it is allowed to, and (contrary to snprintf) don't do '\0'-termination. It is then up to the caller to detect whether output was truncated and to append a '\0' if desired. Also, we must output partial escape sequences, otherwise a call such as snprintf(buf, 3, "%1pE", "\123") would cause printf to write a \0 to buf[2] but leaving buf[0] and buf[1] with whatever they previously contained. This also fixes a bug in the escaped_string() helper function, which used to unconditionally pass a length of "end-buf" to string_escape_mem(); since the latter doesn't check osz for being insanely large, it would happily write to dst. For example, kasprintf(GFP_KERNEL, "something and then %pE", ...); is an easy way to trigger an oops. In test-string_helpers.c, the -ENOMEM test is replaced with testing for getting the expected return value even if the buffer is too small. We also ensure that nothing is written (by relying on a NULL pointer deref) if the output size is 0 by passing NULL - this has to work for kasprintf("%pE") to work. In net/sunrpc/cache.c, I think qword_add still has the same semantics. Someone should definitely double-check this. In fs/proc/array.c, I made the minimum possible change, but longer-term it should stop poking around in seq_file internals. [andriy.shevchenko@linux.intel.com: simplify qword_add] [andriy.shevchenko@linux.intel.com: add missed curly braces] Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf.c: fix potential NULL deref in hex_stringRasmus Villemoes
The helper hex_string() is broken in two ways. First, it doesn't increment buf regardless of whether there is room to print, so callers such as kasprintf() that try to probe the correct storage to allocate will get a too small return value. But even worse, kasprintf() (and likely anyone else trying to find the size of the result) pass NULL for buf and 0 for size, so we also have end == NULL. But this means that the end-1 in hex_string() is (char*)-1, so buf < end-1 is true and we get a NULL pointer deref. I double-checked this with a trivial kernel module that just did a kasprintf(GFP_KERNEL, "%14ph", "CrashBoomBang"). Nobody seems to be using %ph with kasprintf, but we might as well fix it before it hits someone. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf: add %pC{,n,r} format specifiers for clocksGeert Uytterhoeven
Add format specifiers for printing struct clk: - '%pC' or '%pCn': name (Common Clock Framework) or address (legacy clock framework) of the clock, - '%pCr': rate of the clock. [akpm@linux-foundation.org: omit code if !CONFIG_HAVE_CLK] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Mike Turquette <mturquette@linaro.org> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf.c: another small hackRasmus Villemoes
Making ZEROPAD == '0'-' ', we can eliminate a few more instructions. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf.c: eliminate duplicate hex string arrayRasmus Villemoes
gcc doesn't merge or overlap const char[] objects with identical contents (probably language lawyers would also insist that these things have different addresses), but there's no reason to have the string "0123456789ABCDEF" occur in multiple places. hex_asc_upper is declared in kernel.h and defined in lib/hexdump.c, which is unconditionally compiled in. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf.c: reduce stack use in number()Rasmus Villemoes
At least since the initial git commit, when base was passed as a separate parameter, number() has only been called with bases 8, 10 and 16. I'm guessing that 66 was to accommodate 64 0/1, a sign and a '\0', but the buffer is only used for the actual digits. Octal digits carry 3 bits of information, so 24 is enough. Spell that 3*sizeof(num) so one less place needs to be changed should long long ever be 128 bits. Also remove the commented-out code that would handle an arbitrary base. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15lib/vsprintf.c: eliminate some branchesRasmus Villemoes
Since FORMAT_TYPE_INT is simply 1 more than FORMAT_TYPE_UINT, and similarly for BYTE/UBYTE, SHORT/USHORT, LONG/ULONG, we can eliminate a few instructions by making SIGN have the value 1 instead of 2, and then use arithmetic instead of branches for computing the right spec->type. It's a little hacky, but certainly in the same spirit as SMALL needing to have the value 0x20. For example for the spec->qualifier == 'l' case, gcc now generates 75e: 0f b6 53 01 movzbl 0x1(%rbx),%edx 762: 83 e2 01 and $0x1,%edx 765: 83 c2 09 add $0x9,%edx 768: 88 13 mov %dl,(%rbx) instead of 763: 0f b6 53 01 movzbl 0x1(%rbx),%edx 767: 83 e2 02 and $0x2,%edx 76a: 80 fa 01 cmp $0x1,%dl 76d: 19 d2 sbb %edx,%edx 76f: 83 c2 0a add $0xa,%edx 772: 88 13 mov %dl,(%rbx) Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/vsprintf: implement bitmap printing through '%*pb[l]'Tejun Heo
bitmap and its derivatives such as cpumask and nodemask currently only provide formatting functions which put the output string into the provided buffer; however, how long this buffer should be isn't defined anywhere and given that some of these bitmaps can be too large to be formatted into an on-stack buffer it users sometimes are unnecessarily forced to come up with creative solutions and compromises for the buffer just to printk these bitmaps. There have been a couple different attempts at making this easier. 1. Way back, PeterZ tried printk '%pb' extension with the precision for bit width - '%.*pb'. This was intuitive and made sense but unfortunately triggered a compile warning about using precision for a pointer. http://lkml.kernel.org/g/1336577562.2527.58.camel@twins 2. I implemented bitmap_pr_cont[_list]() and its wrappers for cpumask and nodemask. This works but PeterZ pointed out that pr_cont's tendency to produce broken lines when multiple CPUs are printing is bothering considering the usages. http://lkml.kernel.org/g/1418226774-30215-3-git-send-email-tj@kernel.org So, this patch is another attempt at teaching printk and friends how to print bitmaps. It's almost identical to what PeterZ tried with precision but it uses the field width for the number of bits instead of precision. The format used is '%*pb[l]', with the optional trailing 'l' specifying list format instead of hex masks. This is a valid format string and doesn't trigger compiler warnings; however, it does make it impossible to specify output field width when printing bitmaps. I think this is an acceptable trade-off given how much easier it makes printing bitmaps and that we don't have any in-kernel user which is using the field width specification. If any future user wants to use field width with a bitmap, it'd have to format the bitmap into a string buffer and then print that buffer with width spec, which isn't different from how it should be done now. This patch implements bitmap[_list]_string() which are called from the vsprintf pointer() formatting function. The implementation is mostly identical to bitmap_scn[list]printf() except that the output is performed in the vsprintf way. These functions handle formatting into too small buffers and sprintf() family of functions report the correct overrun output length. bitmap_scn[list]printf() are now thin wrappers around scnprintf(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Cc: Christoph Lameter <cl@linux.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Mike Travis <travis@sgi.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12lib/vsprintf.c: replace while with do-while in skip_atoiRasmus Villemoes
All callers of skip_atoi have already checked for the first character being a digit. In this case, gcc generates simpler code for a do while-loop. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12lib/vsprintf.c: improve sanity check in vsnprintf()Rasmus Villemoes
On 64 bit, size may very well be huge even if bit 31 happens to be 0. Somehow it doesn't feel right that one can pass a 5 GiB buffer but not a 3 GiB one. So cap at INT_MAX as was probably the intention all along. This is also the made-up value passed by sprintf and vsprintf. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12lib/vsprintf.c: consume 'p' in format_decodeRasmus Villemoes
It seems a little simpler to consume the p from a %p specifier in format_decode, just as it is done for the surrounding %c, %s and %% cases. While there, delete a redundant and misplaced comment. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib/vsprintf: add %*pE[achnops] format specifierAndy Shevchenko
This allows user to print a given buffer as an escaped string. The rules are applied according to an optional mix of flags provided by additional format letters. For example, if the given buffer is: 1b 62 20 5c 43 07 22 90 0d 5d The result strings would be: %*pE "\eb \C\a"\220\r]" %*pEhp "\x1bb \C\x07"\x90\x0d]" %*pEa "\e\142\040\\\103\a\042\220\r\135" Please, read Documentation/printk-formats.txt and lib/string_helpers.c kernel documentation to get further information. [akpm@linux-foundation.org: tidy up comment layout, per Joe] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Joe Perches <joe@perches.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-09Documentation: Docbook: Fix generated DocBook/kernel-api.xmlMasanari Iida
This patch fix spelling typo found in DocBook/kernel-api.xml. It is because the file is generated from the source comments, I have to fix the comments in source codes. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-06-04lib/vsprintf.c: fix comparison to boolFabian Frederick
Fixing 2 coccinelle warnings: lib/vsprintf.c:2350:2-9: WARNING: Assignment of bool to 0/1 lib/vsprintf.c:2389:3-10: WARNING: Assignment of bool to 0/1 Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03vsprintf: remove %n handlingRyan Mallon
All in-kernel users of %n in format strings have now been removed and the %n directive is ignored. Remove the handling of %n so that it is treated the same as any other invalid format string directive. Keep a warning in place to deter new instances of %n in format strings. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-26vsprintf: Add support for IORESOURCE_UNSET in %pRBjorn Helgaas
Sometimes we have a struct resource where we know the type (MEM/IO/etc.) and the size, but we haven't assigned address space for it. The IORESOURCE_UNSET flag is a way to indicate this situation. For these "unset" resources, the start address is meaningless, so print only the size, e.g., - pci 0000:0c:00.0: reg 184: [mem 0x00000000-0x00001fff 64bit] + pci 0000:0c:00.0: reg 184: [mem size 0x2000 64bit] For %pr (printing with raw flags), we still print the address range, because %pr is mostly used for debugging anyway. Thanks to Fengguang Wu <fengguang.wu@intel.com> for suggesting resource_size(). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-01-23vsprintf: add %pad extension for dma_addr_t useJoe Perches
dma_addr_t's can be either u32 or u64 depending on a CONFIG option. There are a few hundred dma_addr_t's printed via either cast to unsigned long long, unsigned long or no cast at all. Add %pad to be able to emit them without the cast. Update Documentation/printk-formats.txt too. Signed-off-by: Joe Perches <joe@perches.com> Cc: "Shevchenko, Andriy" <andriy.shevchenko@intel.com> Cc: Rob Landley <rob@landley.net> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15vsprintf: ignore %n againKees Cook
This ignores %n in printf again, as was originally documented. Implementing %n poses a greater security risk than utility, so it should stay ignored. To help anyone attempting to use %n, a warning will be emitted if it is encountered. Based on an earlier patch by Joe Perches. Because %n was designed to write to pointers on the stack, it has been frequently used as an attack vector when bugs are found that leak user-controlled strings into functions that ultimately process format strings. While this class of bug can still be turned into an information leak, removing %n eliminates the common method of elevating such a bug into an arbitrary kernel memory writing primitive, significantly reducing the danger of this class of bug. For seq_file users that need to know the length of a written string for padding, please see seq_setwidth() and seq_pad() instead. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Joe Perches <joe@perches.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13lib/vsprintf.c: document formats for dentry and struct fileOlof Johansson
Looks like these were added to Documentation/printk-formats.txt but not the in-file table. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13vsprintf: check real user/group id for %pKRyan Mallon
Some setuid binaries will allow reading of files which have read permission by the real user id. This is problematic with files which use %pK because the file access permission is checked at open() time, but the kptr_restrict setting is checked at read() time. If a setuid binary opens a %pK file as an unprivileged user, and then elevates permissions before reading the file, then kernel pointer values may be leaked. This happens for example with the setuid pppd application on Ubuntu 12.04: $ head -1 /proc/kallsyms 00000000 T startup_32 $ pppd file /proc/kallsyms pppd: In file /proc/kallsyms: unrecognized option 'c1000000' This will only leak the pointer value from the first line, but other setuid binaries may leak more information. Fix this by adding a check that in addition to the current process having CAP_SYSLOG, that effective user and group ids are equal to the real ids. If a setuid binary reads the contents of a file which uses %pK then the pointer values will be printed as NULL if the real user is unprivileged. Update the sysctl documentation to reflect the changes, and also correct the documentation to state the kptr_restrict=0 is the default. This is a only temporary solution to the issue. The correct solution is to do the permission check at open() time on files, and to replace %pK with a function which checks the open() time permission. %pK uses in printk should be removed since no sane permission check can be done, and instead protected by using dmesg_restrict. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Joe Perches <joe@perches.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-04add formats for dentry/file pathnamesAl Viro
New formats: %p[dD][234]?. The next pointer is interpreted as struct dentry * or struct file * resp. ('d' => dentry, 'D' => file) and the last component(s) of pathname are printed (%pd => just the last one, %pd2 => the last two, etc.) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-01lib: vsprintf: add IPv4/v6 generic %p[Ii]S[pfs] format specifierDaniel Borkmann
In order to avoid making code that deals with printing both, IPv4 and IPv6 addresses, unnecessary complicated as for example ... if (sa.sa_family == AF_INET6) printk("... %pI6 ...", ..sin6_addr); else printk("... %pI4 ...", ..sin_addr.s_addr); ... it would be better to introduce a format specifier that can deal with those kind of situations internally; just as we have a "struct sockaddr" for generic mapping into "struct sockaddr_in" or "struct sockaddr_in6" as e.g. done in "union sctp_addr". Then, we could reduce the above statement into something like: printk("... %pIS ..", &sockaddr); In case our pointer is NULL, pointer() then deals with that already at an earlier point in time internally. While we're at it, support for both %piS/%pIS, where 'S' stands for sockaddr, comes (almost) for free. Additionally to that, postfix specifiers 'p', 'f' and 's' are supported as suggested and initially implemented in 2009 by Joe Perches [1]. Handling of those additional specifiers orientate on the initial RFC that was proposed. Also we support IPv6 compressed format specified by 'c' and various other IPv4 extensions as stated in the documentation part. Likely, there are many other areas than just SCTP in the kernel to make use of this extension as well. [1] http://patchwork.ozlabs.org/patch/31480/ Signed-off-by: Daniel Borkmann <dborkman@redhat.com> CC: Joe Perches <joe@perches.com> CC: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-29sprintf: hex_string(): fix commentSteven Rostedt
hex_string() had a typo in a comment. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-30vsprintf: Add extension %pSR - print_symbol replacementJoe Perches
print_symbol takes a long and converts it to a function name and offset. %pS does something similar, but doesn't translate the address via __builtin_extract_return_addr. %pSR does the translation. This will enable replacing multiple calls like printk(...); printk_symbol(addr); printk("\n"); with a single non-interleavable in dmesg printk("... %pSR\n", (void *)addr); Update documentation too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-21lib/vsprintf.c: add %pa format specifier for phys_addr_t typesStepan Moskovchenko
Add the %pa format specifier for printing a phys_addr_t type and its derivative types (such as resource_size_t), since the physical address size on some platforms can vary based on build options, regardless of the native integer type. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Cc: Rob Landley <rob@landley.net> Cc: George Spelvin <linux@horizon.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17simple_strto*: annotate function as obsoleteEldad Zack
Update the documentation for simple_strto* to reflect that it has been obsoleted and advise the usage of kstrto*. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Joe Perches <joe@perches.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
