Bug 1348440
Change-Id: If25c49f027dc2a69642f7ed4733e965962b2a5a2
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit ac5a2962b02f57dea76d314ef2521a2170b28ab6 upstream.
There is a race between klist_remove and klist_release. klist_remove
uses a local var waiter saved on stack. When klist_release calls
wake_up_process(waiter->process) to wake up the waiter, waiter might run
immediately and reuse the stack. Then, klist_release calls
list_del(&waiter->list) to change previous
wait data and cause prior waiter thread corrupt.
The patch fixes it against kernel 3.9.
Signed-off-by: wang, biao <biao.wang@intel.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit a49b7e82cab0f9b41f483359be83f44fbb6b4979 upstream.
Anatol Pomozov identified a race condition that hits module unloading
and re-loading. To quote Anatol:
"This is a race codition that exists between kset_find_obj() and
kobject_put(). kset_find_obj() might return kobject that has refcount
equal to 0 if this kobject is freeing by kobject_put() in other
thread.
Here is timeline for the crash in case if kset_find_obj() searches for
an object tht nobody holds and other thread is doing kobject_put() on
the same kobject:
THREAD A (calls kset_find_obj()) THREAD B (calls kobject_put())
splin_lock()
atomic_dec_return(kobj->kref), counter gets zero here
... starts kobject cleanup ....
spin_lock() // WAIT thread A in kobj_kset_leave()
iterate over kset->list
atomic_inc(kobj->kref) (counter becomes 1)
spin_unlock()
spin_lock() // taken
// it does not know that thread A increased counter so it
remove obj from list
spin_unlock()
vfree(module) // frees module object with containing kobj
// kobj points to freed memory area!!
kobject_put(kobj) // OOPS!!!!
The race above happens because module.c tries to use kset_find_obj()
when somebody unloads module. The module.c code was introduced in
commit 6494a93d55fa"
Anatol supplied a patch specific for module.c that worked around the
problem by simply not using kset_find_obj() at all, but rather than make
a local band-aid, this just fixes kset_find_obj() to be thread-safe
using the proper model of refusing the get a new reference if the
refcount has already dropped to zero.
See examples of this proper refcount handling not only in the kref
documentation, but in various other equivalent uses of this pattern by
grepping for atomic_inc_not_zero().
[ Side note: the module race does indicate that module loading and
unloading is not properly serialized wrt sysfs information using the
module mutex. That may require further thought, but this is the
correct fix at the kobject layer regardless. ]
Reported-analyzed-and-tested-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Bug 1243631
Change-Id: I915826047b2e20f0ad0a7d75df295c6cbf6e5b0a
commit 6cdae7416a1c45c2ce105a78187d9b7e8feb9e24 upstream.
The iteration logic of idr_get_next() is borrowed mostly verbatim from
idr_for_each(). It walks down the tree looking for the slot matching
the current ID. If the matching slot is not found, the ID is
incremented by the distance of single slot at the given level and
repeats.
The implementation assumes that during the whole iteration id is aligned
to the layer boundaries of the level closest to the leaf, which is true
for all iterations starting from zero or an existing element and thus is
fine for idr_for_each().
However, idr_get_next() may be given any point and if the starting id
hits in the middle of a non-existent layer, increment to the next layer
will end up skipping the same offset into it. For example, an IDR with
IDs filled between [64, 127] would look like the following.
[ 0 64 ... ]
NULL [ 64 ... 127 ]
If idr_get_next() is called with 63 as the starting point, it will try
to follow down the pointer from 0. As it is NULL, it will then try to
proceed to the next slot in the same level by adding the slot distance
at that level which is 64 - making the next try 127. It goes around the
loop and finds and returns 127 skipping [64, 126].
Note that this bug also triggers in idr_for_each_entry() loop which
deletes during iteration as deletions can make layers go away leaving
the iteration with unaligned ID into missing layers.
Fix it by ensuring proceeding to the next slot doesn't carry over the
unaligned offset - ie. use round_up(id + 1, slot_distance) instead of
id += slot_distance.
Reported-by: David Teigland <teigland@redhat.com>
commit 7810cc1e7721220f1ed2a23ca95113d6434f6dcd upstream.
digsig_verify_rsa() does not free kmalloc'ed buffer returned by
mpi_get_buffer().
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit fcc16882ac4532aaa644bff444f0c5d6228ba71e upstream.
The atomic64 library uses a handful of static spin locks to implement
atomic 64-bit operations on architectures without support for atomic
64-bit instructions.
Unfortunately, the spinlocks are initialized in a pure initcall and that
is too late for the vfs namespace code which wants to use atomic64
operations before the initcall is run.
This became a problem as of commit 8823c079ba71: "vfs: Add setns support
for the mount namespace".
This leads to BUG messages such as:
BUG: spinlock bad magic on CPU#0, swapper/0/0
lock: atomic64_lock+0x240/0x400, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
do_raw_spin_lock+0x158/0x198
_raw_spin_lock_irqsave+0x4c/0x58
atomic64_add_return+0x30/0x5c
alloc_mnt_ns.clone.14+0x44/0xac
create_mnt_ns+0xc/0x54
mnt_init+0x120/0x1d4
vfs_caches_init+0xe0/0x10c
start_kernel+0x29c/0x300
coming out early on during boot when spinlock debugging is enabled.
Fix this by initializing the spinlocks statically at compile time.
Reported-and-tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit a3cea9894157c20a5b1ec08b7e0b5f2019740c10 upstream.
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint,
leading to this build failure:
CC lib/mpi/generic_mpih-mul1.o
lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1':
lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm'
This patch updates MPI with the latest umul_ppm implementations for MIPS.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/4612/
Cc: Shuah Khan <shuah.khan@hp.com>
Change-Id: Ic8bbc5bbf9ef9cff65d93b14a655df1bdc7cd691
Signed-off-by: Jeff Smith <jsmith@nvidia.com>
Reviewed-on: http://git-master/r/141352
GVS: Gerrit_Virtual_Submit
commit eedce141cd2dad8d0cefc5468ef41898949a7031 upstream.
The genalloc code uses the bitmap API from include/linux/bitmap.h and
lib/bitmap.c, which is based on long values. Both bitmap_set from
lib/bitmap.c and bitmap_set_ll, which is the lockless version from
genalloc.c, use BITMAP_LAST_WORD_MASK to set the first bits in a long in
the bitmap.
That one uses (1 << bits) - 1, 0b111, if you are setting the first three
bits. This means that the API counts from the least significant bits
(LSB from now on) to the MSB. The LSB in the first long is bit 0, then.
The same works for the lookup functions.
The genalloc code uses longs for the bitmap, as it should. In
include/linux/genalloc.h, struct gen_pool_chunk has unsigned long
bits[0] as its last member. When allocating the struct, genalloc should
reserve enough space for the bitmap. This should be a proper number of
longs that can fit the amount of bits in the bitmap.
However, genalloc allocates an integer number of bytes that fit the
amount of bits, but may not be an integer amount of longs. 9 bytes, for
example, could be allocated for 70 bits.
This is a problem in itself if the Least Significat Bit in a long is in
the byte with the largest address, which happens in Big Endian machines.
This means genalloc is not allocating the byte in which it will try to
set or check for a bit.
This may end up in memory corruption, where genalloc will try to set the
bits it has not allocated. In fact, genalloc may not set these bits
because it may find them already set, because they were not zeroed since
they were not allocated. And that's what causes a BUG when
gen_pool_destroy is called and check for any set bits.
What really happens is that genalloc uses kmalloc_node with __GFP_ZERO
on gen_pool_add_virt. With SLAB and SLUB, this means the whole slab
will be cleared, not only the requested bytes. Since struct
gen_pool_chunk has a size that is a multiple of 8, and slab sizes are
multiples of 8, we get lucky and allocate and clear the right amount of
bytes.
Hower, this is not the case with SLOB or with older code that did memset
after allocating instead of using __GFP_ZERO.
So, a simple module as this (running 3.6.0), will cause a crash when
rmmod'ed.
[root@phantom-lp2 foo]# cat foo.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/genalloc.h>
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
static struct gen_pool *foo_pool;
static __init int foo_init(void)
int ret;
foo_pool = gen_pool_create(10, -1);
if (!foo_pool)
return -ENOMEM;
ret = gen_pool_add(foo_pool, 0xa0000000, 32 << 10, -1);
if (ret) {
gen_pool_destroy(foo_pool);
return ret;
return 0;
static __exit void foo_exit(void)
module_init(foo_init);
module_exit(foo_exit);
[root@phantom-lp2 foo]# zcat /proc/config.gz | grep SLOB
CONFIG_SLOB=y
[root@phantom-lp2 foo]# insmod ./foo.ko
[root@phantom-lp2 foo]# rmmod foo
kernel BUG at lib/genalloc.c:243!
cpu 0x4: Vector: 700 (Program Check) at [c0000000bb0e7960]
pc: c0000000003cb50c: .gen_pool_destroy+0xac/0x110
lr: c0000000003cb4fc: .gen_pool_destroy+0x9c/0x110
sp: c0000000bb0e7be0
msr: 8000000000029032
current = 0xc0000000bb0e0000
paca = 0xc000000006d30e00 softe: 0 irq_happened: 0x01
pid = 13044, comm = rmmod
[c0000000bb0e7ca0] d000000004b00020 .foo_exit+0x20/0x38 [foo]
[c0000000bb0e7d20] c0000000000dff98 .SyS_delete_module+0x1a8/0x290
[c0000000bb0e7e30] c0000000000097d4 syscall_exit+0x0/0x94
--- Exception: c00 (System Call) at 000000800753d1a0
SP (fffd0b0e640) is in userspace
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Benjamin Gaignard <benjamin.gaignard@stericsson.com>
commit e96875677fb2b7cb739c5d7769824dff7260d31d upstream.
Account for all properties when a and/or b are 0:
gcd(0, 0) = 0
gcd(a, 0) = a
gcd(0, b) = b
Fixes no known problems in current kernels.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
commit bc01637a80f5b670bd70a0279d3f93fa8de1c96d upstream.
When pkcs_1_v1_5_decode_emsa() returns without error and hash sizes do
not match, hash comparision is not done and digsig_verify_rsa() returns
no error. This is a bug and this patch fixes it.
The bug was introduced in v3.3 by commit b35e286a640f ("lib/digsig:
pkcs_1_v1_5_decode_emsa cleanup").
Add closing quote for LESS_GCC_OPT.
Change-Id: I6b48b19625ac3ab2cc9f4d651cc216fb890063fa
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/131257
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
We are seeing a lot of sg_alloc_table allocation failures using the new
drm prime infrastructure. We isolated the cause to code in
__sg_alloc_table that was re-writing the gfp_flags.
There is a comment in the code that suggest that there is an assumption
about the allocation coming from a memory pool. This was likely true
when sg lists were primarily used for disk I/O.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Cong Wang <amwang@redhat.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Rob Clark <rob.clark@linaro.org>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Sonny Rao <sonnyrao@chromium.org>
Cc: Olof Johansson <olofj@chromium.org>
This patch adds a new constructor for an sg table. The table is constructed
from an array of struct pages. All contiguous chunks of the pages are merged
into a single sg nodes. A user may provide an offset and a size of a buffer if
the buffer is not page-aligned.
The function is dedicated for DMABUF exporters which often perform conversion
from an page array to a scatterlist. Moreover the scatterlist should be
squashed in order to save memory and to speed-up the process of DMA mapping
using dma_map_sg.
The code is based on the patch 'v4l: vb2-dma-contig: add support for
scatterlist in userptr mode' and hints from Laurent Pinchart.
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
CC: Andrew Morton <akpm@linux-foundation.org>
Adds a kernel config option to lower the kernel compile optimization
level from O2 to O1 for clearer GDB debugging. Default on for simulation
builds, default off for others.
Change-Id: I17fd63b5b391984d28b275e516df89d6a223021c
Reviewed-on: http://git-master/r/121822
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Tested-by: Richard Wiley <rwiley@nvidia.com>
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Linux v3.4.5
drivers/base/power/main.c
Change-Id: I782e650a89665caea8aed9e5598234888dc11088
[ Upstream commit 914bec1011a25f65cdc94988a6f974bfb9a3c10d ]
dql->num_queued could change while processing dql_completed().
To provide consistent calculation, added an on stack variable.
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Denys Fedoryshchenko <denys@visp.net.lb>
[ Upstream commit 25426b794efdc70dde7fd3134dc56fac3e7d562d ]
When below pattern is observed,
TIME
dql_queued() dql_completed() |
a) initial state |
b) X bytes queued V
c) Y bytes queued
d) X bytes completed
e) Z bytes queued
f) Y bytes completed
a) dql->limit has already some value and there is no in-flight packet.
b) X bytes queued.
c) Y bytes queued and excess limit.
d) X bytes completed and dql->prev_ovlimit is set and also
dql->prev_num_queued is set Y.
e) Z bytes queued.
f) Y bytes completed. inprogress and prev_inprogress are true.
At f), according to the comment, all_prev_completed becomes
true and limit should be increased. But POSDIFF() ignores
(completed == dql->prev_num_queued) case, so limit is decreased.
[ Upstream commit 0cfd32b736ae0c36b42697584811042726c07cba ]
POSDIFF() fails to take into account integer overflow case.
commit cbf8ae32f66a9ceb8907ad9e16663c2a29e48990 upstream.
The memory the parameter __key points to is used as an iterator in
btree_get_prev(), so if we save off a bkey() pointer in retry_key and
then assign that to __key, we'll end up corrupting the btree internals
when we do eg
longcpy(__key, bkey(geo, node, i), geo->keylen);
to return the key value. What we should do instead is use longcpy() to
copy the key value that retry_key points to __key.
This can cause a btree to get corrupted by seemingly read-only
operations such as btree_for_each_safe.
[akpm@linux-foundation.org: avoid the double longcpy()]
Signed-off-by: Roland Dreier <roland@purestorage.com>
Acked-by: Joern Engel <joern@logfs.org>
drivers/i2c/busses/i2c-tegra.c
drivers/usb/gadget/fsl_udc_core.c
Change-Id: Ibfc3a8edc3665b832ddc94f89fc17b556629d104
commit fffaee365fded09f9ebf2db19066065fa54323c3 upstream.
This patch fixes bug in macro radix_tree_for_each_contig().
If radix_tree_next_slot() sees NULL in next slot it returns NULL, but following
radix_tree_next_chunk() switches iterating into next chunk. As result iterating
becomes non-contiguous and breaks vfs "splice" and all its users.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Reported-and-bisected-by: Hans de Bruin <jmdebruin@xmsnet.nl>
Reported-and-bisected-by: Ondrej Zary <linux@rainbow-software.org>
Reported-bisected-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
Link: https://lkml.org/lkml/2012/6/5/64
At the start of the function we assign 'a->d' to 'ap'. Then we use the
RESIZE_IF_NEEDED macro on 'a' - this may free 'a->d' and replace it
with newly allocaetd storage. In that case, we'll be operating on
freed memory further down in the function when we index into 'ap[]'.
Since we don't actually need 'ap' until after the use of the
RESIZE_IF_NEEDED macro we can just delay the assignment to it until
after we've potentially resized, thus avoiding the issue.
While I was there anyway I also changed the integer variable 'n' to be
const. It might as well be since we only assign to it once and use it
as a constant, and then the compiler will tell us if we ever assign to
it in the future.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
1/ convert open-coded KERN_ERR+dump_stack() to WARN(), so that automated
tools pick up this warning.
2/ include the 'child' and 'parent' kobject names. This information was
useful for tracking down the case where scsi invoked device_del() on a
parent object and subsequently invoked device_add() on a child. Now the
warning looks like:
kobject_add_internal failed for target8:0:16 (error: -2 parent: end_device-8:0:24)
Pid: 2942, comm: scsi_scan_8 Not tainted 3.3.0-rc7-isci+ #2
Call Trace:
[<ffffffff8125e551>] kobject_add_internal+0x1c1/0x1f3
[<ffffffff81075149>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff8125e659>] kobject_add_varg+0x41/0x50
[<ffffffff8125e723>] kobject_add+0x64/0x66
[<ffffffff8131124b>] device_add+0x12d/0x63a
[<ffffffff8125e0ef>] ? kobject_put+0x4c/0x50
[<ffffffff8132f370>] scsi_sysfs_add_sdev+0x4e/0x28a
[<ffffffff8132dce3>] do_scan_async+0x9c/0x145
Cc: James Bottomley <JBottomley@parallels.com>
it in the future.
warning looks like:
Call Trace:
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Pull x86 updates from Ingo Molnar.
This touches some non-x86 files due to the sanitized INLINE_SPIN_UNLOCK
config usage.
Fixed up trivial conflicts due to just header include changes (removing
headers due to cpu_idle() merge clashing with the <asm/system.h> split).
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic/amd: Be more verbose about LVT offset assignments
x86, tls: Off by one limit check
x86/ioapic: Add io_apic_ops driver layer to allow interception
x86/olpc: Add debugfs interface for EC commands
x86: Merge the x86_32 and x86_64 cpu_idle() functions
x86/kconfig: Remove CONFIG_TR=y from the defconfigs
x86: Stop recursive fault in print_context_stack after stack overflow
x86/io_apic: Move and reenable irq only when CONFIG_GENERIC_PENDING_IRQ=y
x86/apic: Add separate apic_id_valid() functions for selected apic drivers
locking/kconfig: Simplify INLINE_SPIN_UNLOCK usage
x86/kconfig: Update defconfigs
x86: Fix excessive MSR print out when show_msr is not specified
Merge third batch of patches from Andrew Morton:
- Some MM stragglers
- core SMP library cleanups (on_each_cpu_mask)
- Some IPI optimisations
- kexec
- kdump
- IPMI
- the radix-tree iterator work
- various other misc bits.
"That'll do for -rc1. I still have ~10 patches for 3.4, will send
those along when they've baked a little more."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
backlight: fix typo in tosa_lcd.c
crc32: add help text for the algorithm select option
mm: move hugepage test examples to tools/testing/selftests/vm
mm: move slabinfo.c to tools/vm
mm: move page-types.c from Documentation to tools/vm
selftests/Makefile: make `run_tests' depend on `all'
selftests: launch individual selftests from the main Makefile
radix-tree: use iterators in find_get_pages* functions
radix-tree: rewrite gang lookup using iterator
radix-tree: introduce bit-optimized iterator
fs/proc/namespaces.c: prevent crash when ns_entries[] is empty
nbd: rename the nbd_device variable from lo to nbd
pidns: add reboot_pid_ns() to handle the reboot syscall
sysctl: use bitmap library functions
ipmi: use locks on watchdog timeout set on reboot
ipmi: simplify locking
ipmi: fix message handling during panics
ipmi: use a tasklet for handling received messages
ipmi: increase KCS timeouts
ipmi: decrease the IPMI message transaction time in interrupt mode
Add help text to the crc32 algorithm selection option in Kconfig.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Rewrite radix_tree_gang_lookup_* functions using the new radix-tree
iterator.
Tested-by: Hugh Dickins <hughd@google.com>
A series of radix tree cleanups, and usage of them in the core pagecache
code.
Micro-benchmark:
lookup 14 slots (typical page-vector size)
in radix-tree there earch <step> slot filled and tagged
before/after - nsec per full scan through tree
* Intel Sandy Bridge i7-2620M 4Mb L3
New code always faster
* AMD Athlon 6000+ 2x1Mb L2, without L3
New code generally faster,
Minor degradation (marked with "*") for huge sparse trees
* i386 on Sandy Bridge
New code faster for common cases: tagged and dense trees.
Some degradations for non-tagged lookup on sparse trees.
Ideally, there might help __ffs() analog for searching first non-zero
long element in array, gcc sometimes cannot optimize this loop corretly.
Numbers:
CPU: Intel Sandy Bridge i7-2620M 4Mb L3
radix-tree with 1024 slots:
tagged lookup
step 1 before 7156 after 3613
step 2 before 5399 after 2696
step 3 before 4779 after 1928
step 4 before 4456 after 1429
step 5 before 4292 after 1213
step 6 before 4183 after 1052
step 7 before 4157 after 951
step 8 before 4016 after 812
step 9 before 3952 after 851
step 10 before 3937 after 732
step 11 before 4023 after 709
step 12 before 3872 after 657
step 13 before 3892 after 633
step 14 before 3720 after 591
step 15 before 3879 after 578
step 16 before 3561 after 513
normal lookup
step 1 before 4266 after 3301
step 2 before 2695 after 2129
step 3 before 2083 after 1712
step 4 before 1801 after 1534
step 5 before 1628 after 1313
step 6 before 1551 after 1263
step 7 before 1475 after 1185
step 8 before 1432 after 1167
step 9 before 1373 after 1092
step 10 before 1339 after 1134
step 11 before 1292 after 1056
step 12 before 1319 after 1030
step 13 before 1276 after 1004
step 14 before 1256 after 987
step 15 before 1228 after 992
step 16 before 1247 after 999
radix-tree with 1024*1024*128 slots:
tagged lookup
step 1 before 1086102841 after 674196409
step 2 before 816839155 after 498138306
step 7 before 599728907 after 240676762
step 15 before 555729253 after 185219677
step 63 before 606637748 after 128585664
step 64 before 608384432 after 102945089
step 65 before 596987114 after 123996019
step 128 before 304459225 after 56783056
step 256 before 158846855 after 31232481
step 512 before 86085652 after 18950595
step 12345 before 6517189 after 1674057
normal lookup
step 1 before 626064869 after 544418266
step 2 before 418809975 after 336321473
step 7 before 242303598 after 207755560
step 15 before 208380563 after 176496355
step 63 before 186854206 after 167283638
step 64 before 176188060 after 170143976
step 65 before 185139608 after 167487116
step 128 before 88181865 after 86913490
step 256 before 45733628 after 45143534
step 512 before 24506038 after 23859036
step 12345 before 2177425 after 2018662
tag-lookup
step 1 before 8164 after 5379
step 2 before 5818 after 5581
step 3 before 4959 after 4213
step 4 before 4371 after 3386
step 5 before 4204 after 2997
step 6 before 4950 after 2744
step 7 before 4598 after 2480
step 8 before 4251 after 2288
step 9 before 4262 after 2243
step 10 before 4175 after 2131
step 11 before 3999 after 2024
step 12 before 3979 after 1994
step 13 before 3842 after 1929
step 14 before 3750 after 1810
step 15 before 3735 after 1810
step 16 before 3532 after 1660
normal-lookup
step 1 before 7875 after 5847
step 2 before 4808 after 4071
step 3 before 4073 after 3462
step 4 before 3677 after 3074
step 5 before 4308 after 2978
step 6 before 3911 after 3807
step 7 before 3635 after 3522
step 8 before 3313 after 3202
step 9 before 3280 after 3257
step 10 before 3166 after 3083
step 11 before 3066 after 3026
step 12 before 2985 after 2982
step 13 before 2925 after 2924
step 14 before 2834 after 2808
step 15 before 2805 after 2803
step 16 before 2647 after 2622
tag-lookup
step 1 before 1288059720 after 951736580
step 2 before 961292300 after 884212140
step 7 before 768905140 after 547267580
step 15 before 771319480 after 456550640
step 63 before 504847640 after 242704304
step 64 before 392484800 after 177920786
step 65 before 491162160 after 246895264
step 128 before 208084064 after 97348392
step 256 before 112401035 after 51408126
step 512 before 75825834 after 29145070
step 12345 before 5603166 after 2847330
normal-lookup
step 1 before 1025677120 after 861375100
step 2 before 647220080 after 572258540
step 7 before 505518960 after 484041813
step 15 before 430483053 after 444815320 *
step 63 before 388113453 after 404250546 *
step 64 before 374154666 after 396027440 *
step 65 before 381423973 after 396704853 *
step 128 before 190078700 after 202619384 *
step 256 before 100886756 after 102829108 *
step 512 before 64074505 after 56158720
step 12345 before 4237289 after 4422299 *
* i686 on Sandy bridge
tagged lookup
step 1 before 7990 after 4019
step 2 before 5698 after 2897
step 3 before 5013 after 2475
step 4 before 4630 after 1721
step 5 before 4346 after 1759
step 6 before 4299 after 1556
step 7 before 4098 after 1513
step 8 before 4115 after 1222
step 9 before 3983 after 1390
step 10 before 4077 after 1207
step 11 before 3921 after 1231
step 12 before 3894 after 1116
step 13 before 3840 after 1147
step 14 before 3799 after 1090
step 15 before 3797 after 1059
step 16 before 3783 after 745
normal lookup
step 1 before 5103 after 3499
step 2 before 3299 after 2550
step 3 before 2489 after 2370
step 4 before 2034 after 2302 *
step 5 before 1846 after 2268 *
step 6 before 1752 after 2249 *
step 7 before 1679 after 2164 *
step 8 before 1627 after 2153 *
step 9 before 1542 after 2095 *
step 10 before 1479 after 2109 *
step 11 before 1469 after 2009 *
step 12 before 1445 after 2039 *
step 13 before 1411 after 2013 *
step 14 before 1374 after 2046 *
step 15 before 1340 after 1975 *
step 16 before 1331 after 2000 *
tagged lookup
step 1 before 1225865377 after 667153553
step 2 before 842427423 after 471533007
step 7 before 609296153 after 276260116
step 15 before 544232060 after 226859105
step 63 before 519209199 after 141343043
step 64 before 588980279 after 141951339
step 65 before 521099710 after 138282060
step 128 before 298476778 after 83390628
step 256 before 149358342 after 43602609
step 512 before 76994713 after 22911077
step 12345 before 5328666 after 1472111
normal lookup
step 1 before 819284564 after 533635310
step 2 before 512421605 after 364956155
step 7 before 271443305 after 305721345 *
step 15 before 223591630 after 273960216 *
step 63 before 190320247 after 217770207 *
step 64 before 178538168 after 267411372 *
step 65 before 186400423 after 215347937 *
step 128 before 88106045 after 140540612 *
step 256 before 44812420 after 70660377 *
step 512 before 24435438 after 36328275 *
step 12345 before 2123924 after 2148062 *
bloat-o-meter delta for this patchset + patchset with related shmem cleanups
bloat-o-meter: x86_64
add/remove: 4/3 grow/shrink: 5/6 up/down: 928/-939 (-11)
function old new delta
radix_tree_next_chunk - 499 +499
shmem_unuse 428 554 +126
shmem_radix_tree_replace 131 227 +96
find_get_pages_tag 354 419 +65
find_get_pages_contig 345 407 +62
find_get_pages 362 396 +34
__kstrtab_radix_tree_next_chunk - 22 +22
__ksymtab_radix_tree_next_chunk - 16 +16
__kcrctab_radix_tree_next_chunk - 8 +8
radix_tree_gang_lookup_slot 204 203 -1
static.shmem_xattr_set 384 381 -3
radix_tree_gang_lookup_tag_slot 208 191 -17
radix_tree_gang_lookup 231 187 -44
radix_tree_gang_lookup_tag 247 199 -48
shmem_unlock_mapping 278 190 -88
__lookup 217 - -217
__lookup_tag 242 - -242
radix_tree_locate_item 279 - -279
bloat-o-meter: i386
add/remove: 3/3 grow/shrink: 8/9 up/down: 1075/-1275 (-200)
radix_tree_next_chunk - 757 +757
shmem_unuse 352 449 +97
find_get_pages_contig 269 322 +53
shmem_radix_tree_replace 113 154 +41
find_get_pages_tag 277 318 +41
dcache_dir_lseek 426 458 +32
vc_do_resize 968 977 +9
snd_pcm_lib_read1 725 733 +8
__ksymtab_radix_tree_next_chunk - 8 +8
netlbl_cipsov4_list 1120 1127 +7
find_get_pages 293 291 -2
new_slab 467 459 -8
bitfill_unaligned_rev 425 417 -8
radix_tree_gang_lookup_tag_slot 177 146 -31
blk_dump_cmd 267 229 -38
radix_tree_gang_lookup_slot 212 134 -78
shmem_unlock_mapping 221 128 -93
radix_tree_gang_lookup_tag 275 162 -113
radix_tree_gang_lookup 255 126 -129
__lookup 227 - -227
__lookup_tag 271 - -271
radix_tree_locate_item 277 - -277
This patch:
Implement a clean, simple and effective radix-tree iteration routine.
Iterating divided into two phases:
* lookup next chunk in radix-tree leaf node
* iterating through slots in this chunk
Main iterator function radix_tree_next_chunk() returns pointer to first
slot, and stores in the struct radix_tree_iter index of next-to-last slot.
For tagged-iterating it also constuct bitmask of tags for retunted chunk.
All additional logic implemented as static-inline functions and macroses.
Also adds radix_tree_find_next_bit() static-inline variant of
find_next_bit() optimized for small constant size arrays, because
find_next_bit() too heavy for searching in an array with one/two long
elements.
[akpm@linux-foundation.org: rework comments a bit]
__any_online_cpu() is not optimal and also unnecessary. So, replace its
use by faster cpumask_* operations.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Venkatesh Pallipadi <venki@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML changes from Richard Weinberger:
"Mostly bug fixes and cleanups"
* 'for-linus-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: (35 commits)
um: Update defconfig
um: Switch to large mcmodel on x86_64
MTD: Relax dependencies
um: Wire CONFIG_GENERIC_IO up
um: Serve io_remap_pfn_range()
Introduce CONFIG_GENERIC_IO
um: allow SUBARCH=x86
um: most of the SUBARCH uses can be killed
um: deadlock in line_write_interrupt()
um: don't bother trying to rebuild CHECKFLAGS for USER_OBJS
um: use the right ifdef around exports in user_syms.c
um: a bunch of headers can be killed by using generic-y
um: ptrace-generic.h doesn't need user.h
um: kill HOST_TASK_PID
um: remove pointless include of asm/fixmap.h from asm/pgtable.h
um: asm-offsets.h might as well come from underlying arch...
um: merge processor_{32,64}.h a bit...
um: switch close_chan() to struct line
um: race fix: initialize delayed_work *before* registering IRQ
um: line->have_irq is never checked...
There are situations where CONFIG_HAS_IOMEM is too restrictive.
For example CONFIG_MTD_NAND_NANDSIM depends on CONFIG_HAS_IOMEM
but it works perfectly fine if an architecture without io memory
just includes asm-generic/io.h or implements everything defined in it.
UML is such a corner case.
Signed-off-by: Richard Weinberger <richard@nod.at>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
arch/arm/common/Kconfig
arch/arm/mm/Makefile
arch/arm/mm/cache-l2x0.c
drivers/misc/Kconfig
drivers/misc/Makefile
drivers/mmc/core/core.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Add API to allocate at specified alloc address.
Change-Id: I188e5430220c050026c6a3e17a586012d9a9fa04
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/74468
Rebase-Id: R93cbd801fbaea15cd4b0b579826b659d220618d7
Pull sysctl updates from Eric Biederman:
- Rewrite of sysctl for speed and clarity.
Insert/remove/Lookup in sysctl are all now O(NlogN) operations, and
are no longer bottlenecks in the process of adding and removing
network devices.
sysctl is now focused on being a filesystem instead of system call
and the code can all be found in fs/proc/proc_sysctl.c. Hopefully
this means the code is now approachable.
Much thanks is owed to Lucian Grinjincu for keeping at this until
something was found that was usable.
- The recent proc_sys_poll oops found by the fuzzer during hibernation
is fixed.
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl: (36 commits)
sysctl: protect poll() in entries that may go away
sysctl: Don't call sysctl_follow_link unless we are a link.
sysctl: Comments to make the code clearer.
sysctl: Correct error return from get_subdir
sysctl: An easier to read version of find_subdir
sysctl: fix memset parameters in setup_sysctl_set()
sysctl: remove an unused variable
sysctl: Add register_sysctl for normal sysctl users
sysctl: Index sysctl directories with rbtrees.
sysctl: Make the header lists per directory.
sysctl: Move sysctl_check_dups into insert_header
sysctl: Modify __register_sysctl_paths to take a set instead of a root and an nsproxy
sysctl: Replace root_list with links between sysctl_table_sets.
sysctl: Add sysctl_print_dir and use it in get_subdir
sysctl: Stop requiring explicit management of sysctl directories
sysctl: Add a root pointer to ctl_table_set
sysctl: Rewrite proc_sys_readdir in terms of first_entry and next_entry
sysctl: Rewrite proc_sys_lookup introducing find_entry and lookup_entry.
sysctl: Normalize the root_table data structure.
sysctl: Factor out insert_header and erase_header
== stat_check.py
num = 0
with open("/proc/stat") as f:
while num < 1000 :
data = f.read()
f.seek(0, 0)
num = num + 1
perf shows
20.39% stat_check.py [kernel.kallsyms] [k] format_decode
13.41% stat_check.py [kernel.kallsyms] [k] number
12.61% stat_check.py [kernel.kallsyms] [k] vsnprintf
10.85% stat_check.py [kernel.kallsyms] [k] memcpy
4.85% stat_check.py [kernel.kallsyms] [k] radix_tree_lookup
4.43% stat_check.py [kernel.kallsyms] [k] seq_printf
This patch removes most of calls to vsnprintf() by adding num_to_str()
and seq_print_decimal_ull(), which prints decimal numbers without rich
functions provided by printf().
On my 8cpu box.
== Before patch ==
[root@bluextal test]# time ./stat_check.py
real 0m0.150s
user 0m0.026s
sys 0m0.121s
== After patch ==
real 0m0.055s
user 0m0.022s
sys 0m0.030s
[akpm@linux-foundation.org: remove incorrect comment, use less statck in num_to_str(), move comment from .h to .c, simplify seq_put_decimal_ull()]
[andrea@betterlinux.com: avoid breaking the ABI in /proc/stat]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Andrea Righi <andrea@betterlinux.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Paul Turner <pjt@google.com>
Allow the kernel builder to choose a crc32* algorithm for the kernel.
Cc: Bob Pearson <rpearson@systemfabricworks.com>
Add self-test code for crc32c.
Reuse the existing crc32 code to stamp out a crc32c implementation.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Add a comment at the top of crc32.c
[djwong@us.ibm.com: Minor changelog tweaks]
Signed-off-by: Bob Pearson <rpearson@systemfabricworks.com>
