Fix the following warnings:
CC [M] lib/test-kstrtox.o
lib/test-kstrtox.c: In function 'test_kstrtou64_ok':
lib/test-kstrtox.c:318: warning: this decimal constant is unsigned only in ISO C90
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cite Documentation/kernel-parameters.txt for an alternative to
building with PRINTK_TIME compiled in.
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
When driver leak dma mapping, print additional information about one of
leaked entries, to to help investigate problem. Patch should be useful
for debugging drivers, which maps many different class of buffers.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
"You probably want ... instead." sounds like a recommendation better
not to use the v... functions.
mm/kmemleak-test.c is used to provide an example of how kmemleak
tool works.
Memory is leaked at module unload-time, so building the test
in kernel (Y) makes the leaks impossible and the test useless.
Qualify DEBUG_KMEMLEAK_TEST config symbol with "depends on m",
to restrict module-only building.
Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
* 'for-linus-1' of git://git.infradead.org/mtd-2.6: (49 commits)
mtd: mtdswap: fix compilation warning
mtdswap: kill strict error handling option
mtd: nand: enable software BCH ECC in nand simulator
mtd: nand: add software BCH ECC support
mtd: fix printf format warnings, mostly lack of %zd for size_t, in mtdswap
mtd: sm_rtl: check kmalloc return value
mtd: cfi: add support for AMIC flashes (e.g. A29L160AT)
lib: add shared BCH ECC library
mtd: mxc_nand: fix OOB corruption when page size > 2KiB
mtd: DaVinci: Removed header file that is not required
mtd: pxa3xx_nand: clean the keep configure code
mtd: pxa3xx_nand: mtd scan id process could be defined by driver itself
mtd: pxa3xx_nand: unify prepare command
mtd: pxa3xx_nand: discard wait_for_event,write_cmd,__readid function
mtd: pxa3xx_nand: rework irq logic
mtd: pxa3xx_nand: make scan procedure more clear
mtd: speedtest: fix integer overflow
mtd: mxc_nand: fix read past buffer end
mtd: omap3: nand: report corrected ecc errors
jffs2: remove a trailing white space in commentaries
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix WARN_ON() test for UP
WARN_ON_SMP(): Allow use in if() statements on UP
x86, dumpstack: Use %pB format specifier for stack trace
vsprintf: Introduce %pB format specifier
lockdep: Remove unused 'factor' variable from lockdep_stats_show()
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits)
[media] rc: update for bitop name changes
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
lib, arch: add filter argument to show_mem and fix private implementations
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
NOTE!
This merge commit was created to fix compilation error. The block
tree was merged upstream and removed the 'elv_queue_empty()'
function which the new 'mtdswap' driver is using. So a simple
merge of the mtd tree with upstream does not compile. And the
mtd tree has already be published, so re-basing it is not an option.
To fix this unfortunate situation, I had to merge upstream into the
mtd-2.6.git tree without committing, put the fixup patch on top of
this, and then commit this. The result is that we do not have commits
which do not compile.
In other words, this merge commit "merges" 3 things: the MTD tree, the
upstream tree, and the fixup patch.
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Rientjes <rientjes@google.com>
The %pB format specifier is for stack backtrace. Its handler
sprint_backtrace() does symbol lookup using (address-1) to
ensure the address will not point outside of the function.
If there is a tail-call to the function marked "noreturn",
gcc optimized out the code after the call then causes saved
return address points outside of the function (i.e. the start
of the next function), so pollutes call trace somewhat.
This patch adds the %pB printk mechanism that allows architecture
call-trace printout functions to improve backtrace printouts.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com>
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic
implementation of find_*_bit_le() in lib/find_next_bit.c or not.
For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which
enable CONFIG_GENERIC_FIND_NEXT_BIT.
But m68knommu wants to define own faster find_next_zero_bit_le() and
continues using generic find_next_{,zero_}bit().
(CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE)
Cc: Greg Ungerer <gerg@uclinux.org>
This makes the little-endian bitops take any pointer types by changing the
prototypes and adding casts in the preprocessor macros.
That would seem to at least make all the filesystem code happier, and they
can continue to do just something like
#define ext2_set_bit __test_and_set_bit_le
(or whatever the exact sequence ends up being).
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Zankel <chris@zankel.net>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
As a preparation for providing little-endian bitops for all architectures,
This renames generic implementation of little-endian bitops. (remove
"generic_" prefix and postfix "_le")
s/generic_find_next_le_bit/find_next_bit_le/
s/generic_find_next_zero_le_bit/find_next_zero_bit_le/
s/generic_find_first_zero_le_bit/find_first_zero_bit_le/
s/generic___test_and_set_le_bit/__test_and_set_bit_le/
s/generic___test_and_clear_le_bit/__test_and_clear_bit_le/
s/generic_test_le_bit/test_bit_le/
s/generic___set_le_bit/__set_bit_le/
s/generic___clear_le_bit/__clear_bit_le/
s/generic_test_and_set_le_bit/test_and_set_bit_le/
s/generic_test_and_clear_le_bit/test_and_clear_bit_le/
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Instead of always creating a huge (268K) deflate_workspace with the
maximum compression parameters (windowBits=15, memLevel=8), allow the
caller to obtain a smaller workspace by specifying smaller parameter
values.
For example, when capturing oops and panic reports to a medium with
limited capacity, such as NVRAM, compression may be the only way to
capture the whole report. In this case, a small workspace (24K works
fine) is a win, whether you allocate the workspace when you need it (i.e.,
during an oops or panic) or at boot time.
I've verified that this patch works with all accepted values of windowBits
(positive and negative), memLevel, and compression level.
Signed-off-by: Jim Keniston <jkenisto@us.ibm.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Chris Mason <chris.mason@oracle.com>
1. simple_strto*() do not contain overflow checks and crufty,
libc way to indicate failure.
2. strict_strto*() also do not have overflow checks but the name and
comments pretend they do.
3. Both families have only "long long" and "long" variants,
but users want strtou8()
4. Both "simple" and "strict" prefixes are wrong:
Simple doesn't exactly say what's so simple, strict should not exist
because conversion should be strict by default.
The solution is to use "k" prefix and add convertors for more types.
Enter
kstrtoull()
kstrtoll()
kstrtoul()
kstrtol()
kstrtouint()
kstrtoint()
kstrtou64()
kstrtos64()
kstrtou32()
kstrtos32()
kstrtou16()
kstrtos16()
kstrtou8()
kstrtos8()
Include runtime testsuite (somewhat incomplete) as well.
strict_strto*() become deprecated, stubbed to kstrto*() and
eventually will be removed altogether.
Use kstrto*() in code today!
Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if
they'll be unused at runtime. This is temporarily solution,
because I don't want to hardcode list of archs where these
functions aren't needed. Current solution with sizeof() and
__alignof__ at least always works.
We've been burned by regressions/bugs which we later realized could have
been triaged quicker if only we'd paid closer attention to dmesg. To make
it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL
Kconfig-settable. That way we can set it to KERN_NOTICE and audit any
messages <= KERN_WARNING.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Joe Perches <joe@perches.com>
Cc: Olof Johansson <olofj@chromium.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
In an effort to reduce kernel address leaks that might be used to help
target kernel privilege escalation exploits, this patch uses %pK when
displaying addresses in /proc/kallsyms, /proc/modules, and
/sys/module/*/sections/*.
Note that this changes %x to %p, so some legitimately 0 values in
/proc/kallsyms would have changed from 00000000 to "(null)". To avoid
this, "(null)" is not used when using the "K" format. Anything that was
already successfully parsing "(null)" in addition to full hex digits
should have no problem with this change. (Thanks to Joe Perches for the
suggestion.) Due to the %x to %p, "void *" casts are needed since these
addresses are already "unsigned long" everywhere internally, due to their
starting life as ELF section offsets.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: Eugene Teo <eugene@redhat.com>
Cc: Dan Rosenberg <drosenberg@vsecurity.com>
If kptr restrictions are on, just set the passed pointer to NULL.
$ size lib/vsprintf.o.*
8247 4 2 8253 203d lib/vsprintf.o.new
8282 4 2 8288 2060 lib/vsprintf.o.old
When a cpu is considered stuck, instead of limping along and just printing
a warning, it is sometimes preferred to just panic, let kdump capture the
vmcore and reboot. This gets the machine back into a stable state quickly
while saving the info that got it into a stuck state to begin with.
Add a Kconfig option to allow users to set the hardlockup to panic
by default. Also add in a 'nmi_watchdog=nopanic' to override this.
[akpm@linux-foundation.org: fix strncmp length]
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
The oom killer is extremely verbose for machines with a large number of
cpus and/or nodes. This verbosity can often be harmful if it causes other
important messages to be scrolled from the kernel log and incurs a
signicant time delay, specifically for kernels with CONFIG_NODES_SHIFT >
8.
This patch causes only memory information to be displayed for nodes that
are allowed by current's cpuset when dumping the VM state. Information
for all other nodes is irrelevant to the oom condition; we don't care if
there's an abundance of memory elsewhere if we can't access it.
This only affects the behavior of dumping memory information when an oom
is triggered. Other dumps, such as for sysrq+m, still display the
unfiltered form when using the existing show_mem() interface.
Additionally, the per-cpu pageset statistics are extremely verbose in oom
killer output, so it is now suppressed. This removes
nodes_weight(current->mems_allowed) * (1 + nr_cpus)
lines from the oom killer output.
Callers may use __show_mem(SHOW_MEM_FILTER_NODES) to filter disallowed
nodes.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by default
genksyms: Regenerate lexer and parser
genksyms: Track changes to enum constants
genksyms: simplify usage of find_symbol()
genksyms: Add helpers for building string lists
genksyms: Simplify printing of symbol types
genksyms: Simplify lexer
genksyms: Do not paste the bison header file to lex.c
modpost: fix trailing comma
KBuild: silence "'scripts/unifdef' is up to date."
kbuild: Add extra gcc checks
kbuild: reenable section mismatch analysis
unifdef: update to upstream version 2.5
CONFIG_DEBUG_SECTION_MISMATCH has also runtime effects due to the
-fno-inline-functions-called-once compiler flag, so forcing it on
everyone is not a good idea.
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: That's all, folks
fs/locks.c: Remove stale FIXME left over from BKL conversion
ipx: remove the BKL
appletalk: remove the BKL
x25: remove the BKL
ufs: remove the BKL
hpfs: remove the BKL
drivers: remove extraneous includes of smp_lock.h
tracing: don't trace the BKL
adfs: remove the big kernel lock
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits)
bonding: enable netpoll without checking link status
xfrm: Refcount destination entry on xfrm_lookup
net: introduce rx_handler results and logic around that
bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag
bonding: wrap slave state work
net: get rid of multiple bond-related netdevice->priv_flags
bonding: register slave pointer for rx_handler
be2net: Bump up the version number
be2net: Copyright notice change. Update to Emulex instead of ServerEngines
e1000e: fix kconfig for crc32 dependency
netfilter ebtables: fix xt_AUDIT to work with ebtables
xen network backend driver
bonding: Improve syslog message at device creation time
bonding: Call netif_carrier_off after register_netdevice
bonding: Incorrect TX queue offset
net_sched: fix ip_tos2prio
xfrm: fix __xfrm_route_forward()
be2net: Fix UDP packet detected status in RX compl
Phonet: fix aligned-mode pipe socket buffer header reserve
netxen: support for GbE port settings
Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c
with the staging updates.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits)
printk: do not mangle valid userspace syslog prefixes
efivars: Add Documentation
efivars: Expose efivars functionality to external drivers.
efivars: Parameterize operations.
efivars: Split out variable registration
efivars: parameterize efivars
efivars: Make efivars bin_attributes dynamic
efivars: move efivars globals into struct efivars
drivers:misc: ti-st: fix debugging code
kref: Fix typo in kref documentation
UIO: add PRUSS UIO driver support
Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches
firmware: Fix unaligned memory accesses in dmi-sysfs
firmware: Add documentation for /sys/firmware/dmi
firmware: Expose DMI type 15 System Event Log
firmware: Break out system_event_log in dmi-sysfs
firmware: Basic dmi-sysfs support
firmware: Add DMI entry types to the headers
Driver core: convert platform_{get,set}_drvdata to static inline functions
Translate linux-2.6/Documentation/magic-number.txt into Chinese
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtmutex: tester: Remove the remaining BKL leftovers
lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause
rtmutex: Simplify PI algorithm and make highest prio task get lock
rwsem: Remove redundant asmregparm annotation
rwsem: Move duplicate function prototypes to linux/rwsem.h
rwsem: Unify the duplicate rwsem_is_locked() inlines
rwsem: Move duplicate init macros and functions to linux/rwsem.h
rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h
x86: Cleanup rwsem_count_t typedef
rwsem: Cleanup includes
locking: Remove deprecated lock initializers
cred: Replace deprecated spinlock initialization
kthread: Replace deprecated spinlock initialization
xtensa: Replace deprecated spinlock initialization
um: Replace deprecated spinlock initialization
sparc: Replace deprecated spinlock initialization
mips: Replace deprecated spinlock initialization
cris: Replace deprecated spinlock initialization
alpha: Replace deprecated spinlock initialization
rtmutex-tester: Remove BKL tests
* 'core-futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
arm: Remove bogus comment in futex_atomic_cmpxchg_inatomic()
futex: Deobfuscate handle_futex_death()
plist: Add priority list test
plist: Shrink struct plist_head
futex,plist: Remove debug lock assignment from plist_node
futex,plist: Pass the real head of the priority list to plist_del()
futex: Sanitize futex ops argument types
futex: Sanitize cmpxchg_futex_value_locked API
futex: Remove redundant pagefault_disable in futex_atomic_cmpxchg_inatomic()
futex: Avoid redudant evaluation of task_pid_vnr()
futex: Update futex_wait_setup comments about locking
Add test code for checking plist when the kernel is booting.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4D107986.1010302@cn.fujitsu.com>
struct plist_head is used in struct task_struct as well as struct
rtmutex. If we can make it smaller, it will also make these structures
smaller as well.
The field prio_list in struct plist_head is seldom used and we can get
its information from the plist_nodes. Removing this field will decrease
the size of plist_head by half.
LKML-Reference: <4D107982.9090700@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
This is a new software BCH encoding/decoding library, similar to the shared
Reed-Solomon library.
Binary BCH (Bose-Chaudhuri-Hocquenghem) codes are widely used to correct
errors in NAND flash devices requiring more than 1-bit ecc correction; they
are generally better suited for NAND flash than RS codes because NAND bit
errors do not occur in bursts. Latest SLC NAND devices typically require at
least 4-bit ecc protection per 512 bytes block.
This library provides software encoding/decoding, but may also be used with
ASIC/SoC hardware BCH engines to perform error correction. It is being
currently used for this purpose on an OMAP3630 board (4bit/8bit HW BCH). It
has also been used to decode raw dumps of NAND devices with on-die BCH ecc
engines (e.g. Micron 4bit ecc SLC devices).
Latest NAND devices (including SLC) can exhibit high error rates (typically
a dozen or more bitflips per hour during stress tests); in order to
minimize the performance impact of error correction, this library
implements recently developed algorithms for fast polynomial root finding
(see bch.c header for details) instead of the traditional exhaustive Chien
root search; a few performance figures are provided below:
Platform: arm926ejs @ 468 MHz, 32 KiB icache, 16 KiB dcache
BCH ecc : 4-bit per 512 bytes
Encoding average throughput: 250 Mbits/s
Error correction time (compared with Chien search):
average worst average (Chien) worst (Chien)
1 bit 8.5 µs 11 µs 200 µs 383 µs
2 bit 9.7 µs 12.5 µs 477 µs 728 µs
3 bit 18.1 µs 20.6 µs 758 µs 1010 µs
4 bit 19.5 µs 23 µs 1028 µs 1280 µs
In the above figures, "worst" is meant in terms of error pattern, not in
terms of cache miss / page faults effects (not taken into account here).
The library has been extensively tested on the following platforms: x86,
x86_64, arm926ejs, omap3630, qemu-ppc64, qemu-mips.
Signed-off-by: Ivan Djelic <ivan.djelic@parrot.com>
In complex subsystems like mac80211 structures can contain several
timers and work structs, so identifying a specific instance from the
call trace and object type output of debugobjects can be hard.
Allow the subsystems which support debugobjects to provide a hint
function. This function returns a pointer to a kernel address
(preferrably the objects callback function) which is printed along
with the debugobjects type.
Add hint methods for timer_list, work_struct and hrtimer.
[ tglx: Massaged changelog, made it compile ]
LKML-Reference: <20110307085809.GA9334@redhat.com>
This removes the implementation of the big kernel lock,
at last. A lot of people have worked on this in the
past, I so the credit for this patch should be with
everyone who participated in the hunt.
The names on the Cc list are the people that were the
most active in this, according to the recorded git
history, in alphabetical order.
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Alessio Igor Bogani <abogani@texware.it>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Jan Blunck <jblunck@infradead.org>
Cc: John Kacur <jkacur@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Paul Menage <menage@google.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Make CONFIG_AVERAGE selectable for out-of-tree users
such as compat-wireless.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
drivers/net/bnx2x/bnx2x.h
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
MAINTAINERS: Add Andy Gospodarek as co-maintainer.
r8169: disable ASPM
RxRPC: Fix v1 keys
AF_RXRPC: Handle receiving ACKALL packets
cnic: Fix lost interrupt on bnx2x
cnic: Prevent status block race conditions with hardware
net: dcbnl: check correct ops in dcbnl_ieee_set()
e1000e: disable broken PHY wakeup for ICH10 LOMs, use MAC wakeup instead
igb: fix sparse warning
e1000: fix sparse warning
netfilter: nf_log: avoid oops in (un)bind with invalid nfproto values
dccp: fix oops on Reset after close
ipvs: fix dst_lock locking on dest update
davinci_emac: Add Carrier Link OK check in Davinci RX Handler
bnx2x: update driver version to 1.62.00-6
bnx2x: properly calculate lro_mss
bnx2x: perform statistics "action" before state transition.
bnx2x: properly configure coefficients for MinBW algorithm (NPAR mode).
bnx2x: Fix ethtool -t link test for MF (non-pmf) devices.
bnx2x: Fix nvram test for single port devices.
No reason to trace it when the last user is gone.
Currently nla_policy_len always returns n * NLA_HDRLEN:
It loops, but does not advance it's iterator.
NLA_UNSPEC == 0 does not contain a .len in any policy.
Trivially fixed by adding p++.
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
swiotlb's map_page wrongly calls panic() when it can't find a buffer fit
for device's dma mask. It should return an error instead.
Devices with an odd dma mask (i.e. under 4G) like b44 network card hit
this bug (the system crashes):
http://marc.info/?l=linux-kernel&m=129648943830106&w=2
If swiotlb returns an error, b44 driver can use the own bouncing
mechanism.
Reported-by: Chuck Ebbert <cebbert@redhat.com>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Cc: <stable@kernel.org>
This was disabled in commit
e5f95c8 (kbuild: print only total number of section mismatces found)
because there were too many warnings. Now we're down to a reasonable
number again, so we start scaring people with the details.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Documentation/feature-removal-schedule.txt
drivers/net/e1000e/netdev.c
net/xfrm/xfrm_policy.c
When list debugging is enabled, we aim to readably show list corruption
errors, and the basic list_add/list_del operations end up having extra
debugging code in them to do some basic validation of the list entries.
However, "list_del_init()" and "list_move[_tail]()" ended up avoiding
the debug code due to how they were written. This fixes that.
So the _next_ time we have list_move() problems with stale list entries,
we'll hopefully have an easier time finding them..
Merge reason: pick up upstream fixes.
M68KNOMMU is set nowhere.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
This fixes a build breakage caused by
8ba6ebf583f12da32036fc0f003ab4043e54692e "Dynamic debug: Add more flags"
Cc: Bart Van Assche <bvanassche@acm.org>
Add flags that allow the user to specify via debugfs whether or not the
module name, function name, line number and/or thread ID have to be
included in the printed message.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Greg Banks <gnb@fmeh.org>
Cc: Konrad Rzeszutek Wilk <konrad@darnok.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into core/locking
*git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace tip/rtmutex:
