commit d2e7276b6b5e4bc2148891a056d5862c5314342d upstream.
This is retry of reverted 859ddf09743a8cc680af33f7259ccd0fd36bfe9d
("idr: fix a critical misallocation bug") which contained two bugs.
* pa[idp->layers] should be cleared even if it's not used by
sub_alloc() because it's used by mark idr_mark_full().
* The original condition check also assigned pa[l] to p which the new
code didn't do thus leaving p pointing at the wrong layer.
Both problems have been fixed and the idr code has received good amount
testing using userland testing setup where simple bitmap allocator is
run parallel to verify the result of idr allocation.
The bug this patch fixes is caused by sub_alloc() optimization path
bypassing out-of-room condition check and restarting allocation loop
with starting value higher than maximum allowed value. For detailed
description, please read commit message of 859ddf09.
Based-on-patch-from: Eric Paris <eparis@redhat.com>
Reported-by: Eric Paris <eparis@redhat.com>
Tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Tested-by: Serge Hallyn <serue@us.ibm.com>
DMA_FROM_DEVICE and
commit 42d53b4ff7d61487d18274ebdf1f70c1aef6f122 upstream.
There is no need to perform full BIDIR sync (copying the buffers in case
of swiotlb and similar schemes) if we know that the owner (CPU or device)
hasn't altered the data.
Addresses the false-positive reported at
http://bugzilla.kernel.org/show_bug.cgi?id=14169
Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Joerg Roedel <joerg.roedel@amd.com>
commit 7ee3aebe31d2cb22c84e1c8f48182947b13a3607 upstream.
lib/rational.c:62: warning: data definition has no type or storage class
lib/rational.c:62: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
lib/rational.c:62: warning: parameter names (without types) in function declaration
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Oskar Schirmer <os@emlix.com>
commit a8fe9ea200ea21421ea750423d1d4d4f7ce037cf upstream.
Stephen Rothwell reported the following build warning:
lib/dma-debug.c: In function 'dma_debug_device_change':
lib/dma-debug.c:680: warning: 'return' with no value, in function returning non-void
Introduced by commit f797d9881b62c2ddb1d2e7bd80d87141949c84aa
("dma-debug: Do not add notifier when dma debugging is disabled").
Return 0 [notify-done] when disabled. (this is standard bus notifier behavior.)
Signed-off-by: Shaun Ruffell <sruffell@digium.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
LKML-Reference: <20091231125624.GA14666@liondog.tnic>
commit f797d9881b62c2ddb1d2e7bd80d87141949c84aa upstream.
If CONFIG_HAVE_DMA_API_DEBUG is defined and "dma_debug=off" is
specified on the kernel command line, when you detach a driver from a
device you can cause the following NULL pointer dereference:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c0580d35>] dma_debug_device_change+0x5d/0x117
The problem is that the dma_debug_device_change notifier function is
added to the bus notifier chain even though the dma_entry_hash array
was never initialized. If dma debugging is disabled, this patch both
prevents dma_debug_device_change notifiers from being added to the
chain, and additionally ensures that the dma_debug_device_change
notifier function is a no-op.
Don't delete pending pages from the page-store tracking tree, but rather send
them for another write as they've presumably been updated.
__fscache_write_page() attempts to load the radix tree preallocation pool for
the CPU it is on before calling radix_tree_insert(), as the insertion must be
done inside a pair of spinlocks.
Use of the preallocation pool, however, is contingent on the radix tree being
initialised without __GFP_WAIT specified. __fscache_acquire_cookie() was
passing GFP_NOFS to INIT_RADIX_TREE() - but that includes __GFP_WAIT.
The solution is to AND out __GFP_WAIT.
Additionally, the banner comment to radix_tree_preload() is altered to make
note of this prerequisite. Possibly there should be a WARN_ON() too.
Without this fix, I have seen the following recursive deadlock caused by
radix_tree_insert() attempting to allocate memory inside the spinlocked
region, which resulted in FS-Cache being called back into to release memory -
which required the spinlock already held.
[ INFO: possible recursive locking detected ]
2.6.32-rc6-cachefs #24
nfsiod/7916 is trying to acquire lock:
(&cookie->lock){+.+.-.}, at: [<ffffffffa0076872>] __fscache_uncache_page+0xdb/0x160 [fscache]
but task is already holding lock:
(&cookie->lock){+.+.-.}, at: [<ffffffffa0076acc>] __fscache_write_page+0x15c/0x3f3 [fscache]
5 locks held by nfsiod/7916:
#0: (nfsiod){+.+.+.}, at: [<ffffffff81048290>] worker_thread+0x19a/0x2e2
#1: (&task->u.tk_work#2){+.+.+.}, at: [<ffffffff81048290>] worker_thread+0x19a/0x2e2
#2: (&cookie->lock){+.+.-.}, at: [<ffffffffa0076acc>] __fscache_write_page+0x15c/0x3f3 [fscache]
#3: (&object->lock#2){+.+.-.}, at: [<ffffffffa0076b07>] __fscache_write_page+0x197/0x3f3 [fscache]
#4: (&cookie->stores_lock){+.+...}, at: [<ffffffffa0076b0f>] __fscache_write_page+0x19f/0x3f3 [fscache]
stack backtrace:
Pid: 7916, comm: nfsiod Not tainted 2.6.32-rc6-cachefs #24
Call Trace:
[<ffffffff8105ac7f>] __lock_acquire+0x1649/0x16e3
[<ffffffff81059ded>] ? __lock_acquire+0x7b7/0x16e3
[<ffffffff8100e27d>] ? dump_trace+0x248/0x257
[<ffffffff8105ad70>] lock_acquire+0x57/0x6d
[<ffffffffa0076872>] ? __fscache_uncache_page+0xdb/0x160 [fscache]
[<ffffffff8135467c>] _spin_lock+0x2c/0x3b
[<ffffffffa0077eb7>] ? __fscache_check_page_write+0x0/0x71 [fscache]
[<ffffffffa00b4755>] nfs_fscache_release_page+0x86/0xc4 [nfs]
[<ffffffffa00907f0>] nfs_release_page+0x3c/0x41 [nfs]
[<ffffffff81087ffb>] try_to_release_page+0x32/0x3b
[<ffffffff81092c2b>] shrink_page_list+0x316/0x4ac
[<ffffffff81058a9b>] ? mark_held_locks+0x52/0x70
[<ffffffff8135451b>] ? _spin_unlock_irq+0x2b/0x31
[<ffffffff81093153>] shrink_inactive_list+0x392/0x67c
[<ffffffff810934ca>] shrink_list+0x8d/0x8f
[<ffffffff81093744>] shrink_zone+0x278/0x33c
[<ffffffff81052c70>] ? ktime_get_ts+0xad/0xba
[<ffffffff8109453b>] try_to_free_pages+0x22e/0x392
[<ffffffff8109184c>] ? isolate_pages_global+0x0/0x212
[<ffffffff8108e16b>] __alloc_pages_nodemask+0x3dc/0x5cf
[<ffffffff810ae24a>] cache_alloc_refill+0x34d/0x6c1
[<ffffffff811bcf74>] ? radix_tree_node_alloc+0x52/0x5c
[<ffffffff810ae929>] kmem_cache_alloc+0xb2/0x118
[<ffffffff811bcf74>] radix_tree_node_alloc+0x52/0x5c
[<ffffffff811bcfd5>] radix_tree_insert+0x57/0x19c
[<ffffffffa0076b53>] __fscache_write_page+0x1e3/0x3f3 [fscache]
[<ffffffffa00b4248>] __nfs_readpage_to_fscache+0x58/0x11e [nfs]
[<ffffffffa009bb77>] nfs_readpage_release+0x34/0x9b [nfs]
[<ffffffffa009c0d9>] nfs_readpage_release_full+0x32/0x4b [nfs]
[<ffffffffa0006cff>] rpc_release_calldata+0x12/0x14 [sunrpc]
[<ffffffffa0006e2d>] rpc_free_task+0x59/0x61 [sunrpc]
[<ffffffffa0006f03>] rpc_async_release+0x10/0x12 [sunrpc]
[<ffffffff810482e5>] worker_thread+0x1ef/0x2e2
[<ffffffff81048290>] ? worker_thread+0x19a/0x2e2
[<ffffffff81352433>] ? thread_return+0x3e/0x101
[<ffffffffa0006ef3>] ? rpc_async_release+0x0/0x12 [sunrpc]
[<ffffffff8104bff5>] ? autoremove_wake_function+0x0/0x34
[<ffffffff81058d25>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff810480f6>] ? worker_thread+0x0/0x2e2
[<ffffffff8104bd21>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8104c2b9>] ? add_wait_queue+0x15/0x44
[<ffffffff8104bca7>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
Doing the strcmp return value as
signed char __res = *cs - *ct;
is wrong for two reasons. The subtraction can overflow because __res
doesn't use a type big enough. Moreover the compared bytes should be
interpreted as unsigned char as specified by POSIX.
The same problem is fixed in strncmp.
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Andreas Schwab <schwab@linux-m68k.org>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, fs: Fix x86 procfs stack information for threads on 64-bit
x86: Add reboot quirk for 3 series Mac mini
x86: Fix printk message typo in mtrr cleanup code
dma-debug: Fix compile warning with PAE enabled
x86/amd-iommu: Un__init function required on shutdown
x86/amd-iommu: Workaround for erratum 63
When PAE is enabled in the kernel configuration the size of
phys_addr_t differs from the size of a void pointer. The gcc
prints a warning about that in dma-debug code.
This patch fixes the warning by converting the output to
unsigned long long instead of a pointer.
We don't need an explicit PPC64 in the DEBUG_PREEMPT dependancies as all
PPC platforms now support TRACE_IRQFLAGS_SUPPORT.
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (21 commits)
[S390] dasd: fix race condition in resume code
[S390] Add EX_TABLE for addressing exception in usercopy functions.
[S390] 64-bit register support for 31-bit processes
[S390] hibernate: Use correct place for CPU address in lowcore
[S390] pm: ignore time spend in suspended state
[S390] zcrypt: Improve some comments
[S390] zcrypt: Fix sparse warning.
[S390] perf_counter: fix vdso detection
[S390] ftrace: drop nmi protection
[S390] compat: fix truncate system call wrapper
[S390] Provide arch specific mdelay implementation.
[S390] Fix enabled udelay for short delays.
[S390] cio: allow setting boxed devices offline
[S390] cio: make not operational handling consistent
[S390] cio: make disconnected handling consistent
[S390] Fix memory leak in /proc/cio_ignore
[S390] cio: channel path memory leak
[S390] module: fix memory leak in s390 module loader
[S390] Enable kmemleak on s390.
[S390] 3270 console build fix
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
Also increase the maximum possible kmemleak early log entries since
2000 are not sufficient on s390.
When using %*s, sscanf should honor conversion specifiers immediately
following the %*s. For example, the following code should find the
position of the end of the string "hello".
int end;
char buf[] = "hello world";
sscanf(buf, "%*s%n", &end);
printf("%d\n", end);
Ideally, sscanf would advance the fmt and str pointers the same as it
would without the *, but the code for that is rather complicated and is
not included in the patch.
Signed-off-by: Andy Spencer <andy753421@gmail.com>
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
If the lzma/gzip decompressors are called with insufficient input data
(len > 0 & fill = NULL), they will attempt to call the fill function to
obtain more data, leading to a kernel oops.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
Jens Rosenboom noticed that a possibly unaligned const char*
is cast to a const struct in6_addr *.
Avoid this at the cost of a struct in6_addr copy on the stack.
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck:
kmemcheck: add missing braces to do-while in kmemcheck_annotate_bitfield
kmemcheck: update documentation
kmemcheck: depend on HAVE_ARCH_KMEMCHECK
kmemcheck: remove useless check
kmemcheck: remove duplicated #include
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
Add kerneldoc annotations for function formals of type struct flex_array
and gfp_t which are currently lacking.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
FLEX_ARRAY_INIT(element_size, total_nr_elements) cannot determine if
either parameter is valid, so flex arrays which are statically allocated
with this interface can easily become corrupted or reference beyond its
allocated memory.
This removes FLEX_ARRAY_INIT() as a struct flex_array initializer since no
initializer may perform the required checking. Instead, the array is now
defined with a new interface:
DEFINE_FLEX_ARRAY(name, element_size, total_nr_elements)
This may be prefixed with `static' for file scope.
This interface includes compile-time checking of the parameters to ensure
they are valid. Since the validity of both element_size and
total_nr_elements depend on FLEX_ARRAY_BASE_SIZE and FLEX_ARRAY_PART_SIZE,
the kernel build will fail if either of these predefined values changes
such that the array parameters are no longer valid.
Since BUILD_BUG_ON() requires compile time constants, several of the
static inline functions that were once local to lib/flex_array.c had to be
moved to include/linux/flex_array.h.
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Add a new function to the flex_array API:
int flex_array_shrink(struct flex_array *fa)
This function will free all unused second-level pages. Since elements are
now poisoned if they are not allocated with __GFP_ZERO, it's possible to
identify parts that consist solely of unused elements.
flex_array_shrink() returns the number of pages freed.
Newly initialized flex_array's and/or flex_array_part's are now poisoned
with a new poison value, FLEX_ARRAY_FREE. It's value is similar to
POISON_FREE used in the various slab allocators, but is different to
distinguish between flex array's poisoned kmem and slab allocator poisoned
kmem.
This will allow us to identify flex_array_part's that only contain free
elements (and free them with an addition to the flex_array API). This
could also be extended in the future to identify `get' uses on elements
that have not been `put'.
If __GFP_ZERO is passed for a part's gfp mask, the poisoning is avoided.
These elements are considered to be in-use since they have been
initialized.
int flex_array_clear(struct flex_array *fa,
unsigned int element_nr)
This function will zero the element at element_nr in the flex_array.
Although this is equivalent to using flex_array_put() and passing a
pointer to zero'd memory, flex_array_clear() does not require such a
pointer to memory that would most likely need to be allocated on the
caller's stack which could be significantly large depending on
element_size.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Sam suggested moving STRIP_ASM_SYMS into the Kernel hacking menu
from the General Setup menu. It makes more sense there.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Remove the duplicate comment of bstr_printf that is the same as the
vsnprintf.
Add the 's' option to the comment for the pointer function. This is
more of an internal function so the little duplication of the comment
here is OK.
Reported-by: Zhaolei <zhaolei@cn.fujitsu.com>
On PowerPC64 function pointers do not point directly at the functions,
but instead point to pointers to the functions. The output of %pF expects
to point to a pointer to the function, whereas %pS will show the function
itself.
mcount returns the direct pointer to the function and not the pointer to
the pointer. Thus %pS must be used to show this. The function tracer
requires printing of the functions without offsets and uses the %pf
instead.
%pF produces run_local_timers+0x4/0x1f
%pf produces just run_local_timers
For PowerPC64, we need to use the direct pointer, and we only have
%pS which will produce .run_local_timers+0x4/0x1f
This patch creates a %ps that matches the %pf as %pS matches %pF.
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits)
powerpc/nvram: Enable use Generic NVRAM driver for different size chips
powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline
powerpc/ps3: Workaround for flash memory I/O error
powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead
powerpc/perf_counters: Reduce stack usage of power_check_constraints
powerpc: Fix bug where perf_counters breaks oprofile
powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops
powerpc/irq: Improve nanodoc
powerpc: Fix some late PowerMac G5 with PCIe ATI graphics
powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT
powerpc/book3e: Add missing page sizes
powerpc/pseries: Fix to handle slb resize across migration
powerpc/powermac: Thermal control turns system off too eagerly
powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan()
powerpc/405ex: support cuImage via included dtb
powerpc/405ex: provide necessary fixup function to support cuImage
powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC
powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support.
powerpc/44x: Update Arches defconfig
powerpc/44x: Update Arches dts
Fix up conflicts in drivers/char/agp/uninorth-agp.c
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
Due to problems at cam.org, my nico@cam.org email address is no longer
valid. FRom now on, nico@fluxnic.net should be used instead.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits)
netxen: update copyright
netxen: fix tx timeout recovery
netxen: fix file firmware leak
netxen: improve pci memory access
netxen: change firmware write size
tg3: Fix return ring size breakage
netxen: build fix for INET=n
cdc-phonet: autoconfigure Phonet address
Phonet: back-end for autoconfigured addresses
Phonet: fix netlink address dump error handling
ipv6: Add IFA_F_DADFAILED flag
net: Add DEVTYPE support for Ethernet based devices
mv643xx_eth.c: remove unused txq_set_wrr()
ucc_geth: Fix hangs after switching from full to half duplex
ucc_geth: Rearrange some code to avoid forward declarations
phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs
drivers/net/phy: introduce missing kfree
drivers/net/wan: introduce missing kfree
net: force bridge module(s) to be GPL
Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded
Fixed up trivial conflicts:
- arch/x86/include/asm/socket.h
converted to <asm-generic/socket.h> in the x86 tree. The generic
header has the same new #define's, so that works out fine.
- drivers/net/tun.c
fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that
switched over to using 'tun->socket.sk' instead of the redundantly
available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks
to the TUN driver") which added a new 'tun->sk' use.
Noted in 'next' by Stephen Rothwell.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
rcu: Move end of special early-boot RCU operation earlier
rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments
rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees
rcu: Remove lockdep annotations from RCU's _notrace() API members
rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds
rcu: Add CPU-offline processing for single-node configurations
rcu: Add "notrace" to RCU function headers used by ftrace
rcu: Remove CONFIG_PREEMPT_RCU
rcu: Merge preemptable-RCU functionality into hierarchical RCU
rcu: Simplify rcu_pending()/rcu_check_callbacks() API
rcu: Use debugfs_remove_recursive() simplify code.
rcu: Merge per-RCU-flavor initialization into pre-existing macro
rcu: Fix online/offline indication for rcudata.csv trace file
rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h
rcu: Renamings to increase RCU clarity
rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h
rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP
rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation.
rcu: Fix typo in rcu_irq_exit() comment header
rcu: Make rcupreempt_trace.c look at offline CPUs
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (59 commits)
x86/gart: Do not select AGP for GART_IOMMU
x86/amd-iommu: Initialize passthrough mode when requested
x86/amd-iommu: Don't detach device from pt domain on driver unbind
x86/amd-iommu: Make sure a device is assigned in passthrough mode
x86/amd-iommu: Align locking between attach_device and detach_device
x86/amd-iommu: Fix device table write order
x86/amd-iommu: Add passthrough mode initialization functions
x86/amd-iommu: Add core functions for pd allocation/freeing
x86/dma: Mark iommu_pass_through as __read_mostly
x86/amd-iommu: Change iommu_map_page to support multiple page sizes
x86/amd-iommu: Support higher level PTEs in iommu_page_unmap
x86/amd-iommu: Remove old page table handling macros
x86/amd-iommu: Use 2-level page tables for dma_ops domains
x86/amd-iommu: Remove bus_addr check in iommu_map_page
x86/amd-iommu: Remove last usages of IOMMU_PTE_L0_INDEX
x86/amd-iommu: Change alloc_pte to support 64 bit address space
x86/amd-iommu: Introduce increase_address_space function
x86/amd-iommu: Flush domains if address space size was increased
x86/amd-iommu: Introduce set_dte_entry function
x86/amd-iommu: Add a gneric version of amd_iommu_flush_all_devices
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/iommu
Merge reason: Avoid fuzz in init/main.c and update from rc6 to rc8.
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking
for credential management. The additional code keeps track of the number of
pointers from task_structs to any given cred struct, and checks to see that
this number never exceeds the usage count of the cred struct (which includes
all references, not just those from task_structs).
Furthermore, if SELinux is enabled, the code also checks that the security
pointer in the cred struct is never seen to be invalid.
This attempts to catch the bug whereby inode_has_perm() faults in an nfsd
kernel thread on seeing cred->security be a NULL pointer (it appears that the
credential struct has been previously released):
http://www.kerneloops.org/oops.php?number=252883
Signed-off-by: James Morris <jmorris@namei.org>
Tested-by: Jens Rosenboom <jens@mcbone.net>
We call lmb_end_of_DRAM() to test whether a DMA mask is ok on a machine
without IOMMU, but this function is marked as __init.
I don't think there's a clean way to get the top of RAM max_pfn doesn't
appear to include highmem or I missed (or we have a bug :-) so for now,
let's just avoid having a broken 2.6.31 by making this function
non-__init and we can revisit later.
It's problematic to allow signed element_nr's or total's to be passed as
part of the flex array API.
flex_array_alloc() allows total_nr_elements to be set to a negative
quantity, which is obviously erroneous.
flex_array_get() and flex_array_put() allows negative array indices in
dereferencing an array part, which could address memory mapped before
struct flex_array.
The fix is to convert all existing element_nr formals to be qualified as
unsigned. Existing checks to compare it to total_nr_elements or the max
array size based on element_size need not be changed.
flex_array_free_parts() does not take `src' or `element_nr' formals, so
remove their respective comments.
If all array elements fit into the base structure and data is copied using
flex_array_put() starting at a non-zero index, flex_array_get() will fail
to return the data.
This fixes the bug by only checking for NULL parts when all elements do
not fit in the base structure when flex_array_get() is used. Otherwise,
fa_element_to_part_nr() will always be 0 since there are no parts
structures needed and such element may never have been put. Thus, it will
remain NULL due to the kzalloc() of the base.
Additionally, flex_array_put() now only checks for a NULL part when all
elements do not fit in the base structure. This is otherwise unnecessary
since the base structure is guaranteed to exist (or we would have already
hit a NULL pointer).
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
dma-debug: Fix check_unmap null pointer dereference
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no
further need for CONFIG_PREEMPT_RCU. Remove it, along with
whatever subtle bugs it may (or may not) contain.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: akpm@linux-foundation.org
Cc: mathieu.desnoyers@polymtl.ca
Cc: josht@linux.vnet.ibm.com
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
LKML-Reference: <125097461396-git-send-email->
