commit 95389b08d93d5c06ec63ab49bd732b0069b7c35e upstream.
This fixes CVE-2014-3631.
It is possible for an associative array to end up with a shortcut node at the
root of the tree if there are more than fan-out leaves in the tree, but they
all crowd into the same slot in the lowest level (ie. they all have the same
first nibble of their index keys).
When assoc_array_gc() returns back up the tree after scanning some leaves, it
can fall off of the root and crash because it assumes that the back pointer
from a shortcut (after label ascend_old_tree) must point to a normal node -
which isn't true of a shortcut node at the root.
Should we find we're ascending rootwards over a shortcut, we should check to
see if the backpointer is zero - and if it is, we have completed the scan.
This particular bug cannot occur if the root node is not a shortcut - ie. if
you have fewer than 17 keys in a keyring or if you have at least two keys that
sit into separate slots (eg. a keyring and a non keyring).
This can be reproduced by:
ring=`keyctl newring bar @s`
for ((i=1; i<=18; i++)); do last_key=`keyctl newring foo$i $ring`; done
keyctl timeout $last_key 2
Doing this:
echo 3 >/proc/sys/kernel/keys/gc_delay
first will speed things up.
If we do fall off of the top of the tree, we get the following oops:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540
PGD dae15067 PUD cfc24067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: xt_nat xt_mark nf_conntrack_netbios_ns nf_conntrack_broadcast ip6t_rpfilter ip6t_REJECT xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_ni
CPU: 0 PID: 26011 Comm: kworker/0:1 Not tainted 3.14.9-200.fc20.x86_64 #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Workqueue: events key_garbage_collector
task: ffff8800918bd580 ti: ffff8800aac14000 task.ti: ffff8800aac14000
RIP: 0010:[<ffffffff8136cea7>] [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540
RSP: 0018:ffff8800aac15d40 EFLAGS: 00010206
RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff8800aaecacc0
RDX: ffff8800daecf440 RSI: 0000000000000001 RDI: ffff8800aadc2bc0
RBP: ffff8800aac15da8 R08: 0000000000000001 R09: 0000000000000003
R10: ffffffff8136ccc7 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000070 R15: 0000000000000001
FS: 0000000000000000(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000018 CR3: 00000000db10d000 CR4: 00000000000006f0
Stack:
ffff8800aac15d50 0000000000000011 ffff8800aac15db8 ffffffff812e2a70
ffff880091a00600 0000000000000000 ffff8800aadc2bc3 00000000cd42c987
ffff88003702df20 ffff88003702dfa0 0000000053b65c09 ffff8800aac15fd8
Call Trace:
[<ffffffff812e2a70>] ? keyring_detect_cycle_iterator+0x30/0x30
[<ffffffff812e3e75>] keyring_gc+0x75/0x80
[<ffffffff812e1424>] key_garbage_collector+0x154/0x3c0
[<ffffffff810a67b6>] process_one_work+0x176/0x430
[<ffffffff810a744b>] worker_thread+0x11b/0x3a0
[<ffffffff810a7330>] ? rescuer_thread+0x3b0/0x3b0
[<ffffffff810ae1a8>] kthread+0xd8/0xf0
[<ffffffff810ae0d0>] ? insert_kthread_work+0x40/0x40
[<ffffffff816ffb7c>] ret_from_fork+0x7c/0xb0
Code: 08 4c 8b 22 0f 84 bf 00 00 00 41 83 c7 01 49 83 e4 fc 41 83 ff 0f 4c 89 65 c0 0f 8f 5a fe ff ff 48 8b 45 c0 4d 63 cf 49 83 c1 02 <4e> 8b 34 c8 4d 85 f6 0f 84 be 00 00 00 41 f6 c6 01 0f 84 92
RIP [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540
RSP <ffff8800aac15d40>
---[ end trace 1129028a088c0cbd ]---
Acked-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 27419604f51a97d497853f14142c1059d46eb597 upstream.
An edit script should be considered inaccessible by a function once it has
called assoc_array_apply_edit() or assoc_array_cancel_edit().
However, assoc_array_gc() is accessing the edit script just after the
gc_complete: label.
Reported-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
Reviewed-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
cc: shemming@brocade.com
cc: paulmck@linux.vnet.ibm.com
[ Upstream commit 06ebb06d49486676272a3c030bfeef4bd969a8e6 ]
Check for cases when the caller requests 0 bytes instead of running off
and dereferencing potentially invalid iovecs.
Pull networking fixes from David Miller:
1) Bluetooth pairing fixes from Johan Hedberg.
2) ieee80211_send_auth() doesn't allocate enough tail room for the SKB,
from Max Stepanov.
3) New iwlwifi chip IDs, from Oren Givon.
4) bnx2x driver reads wrong PCI config space MSI register, from Yijing
Wang.
5) IPV6 MLD Query validation isn't strong enough, from Hangbin Liu.
6) Fix double SKB free in openvswitch, from Andy Zhou.
7) Fix sk_dst_set() being racey with UDP sockets, leading to strange
crashes, from Eric Dumazet.
8) Interpret the NAPI budget correctly in the new systemport driver,
from Florian Fainelli.
9) VLAN code frees percpu stats in the wrong place, leading to crashes
in the get stats handler. From Eric Dumazet.
10) TCP sockets doing a repair can crash with a divide by zero, because
we invoke tcp_push() with an MSS value of zero. Just skip that part
of the sendmsg paths in repair mode. From Christoph Paasch.
11) IRQ affinity bug fixes in mlx4 driver from Amir Vadai.
12) Don't ignore path MTU icmp messages with a zero mtu, machines out
there still spit them out, and all of our per-protocol handlers for
PMTU can cope with it just fine. From Edward Allcutt.
13) Some NETDEV_CHANGE notifier invocations were not passing in the
correct kind of cookie as the argument, from Loic Prylli.
14) Fix crashes in long multicast/broadcast reassembly, from Jon Paul
Maloy.
15) ip_tunnel_lookup() doesn't interpret wildcard keys correctly, fix
from Dmitry Popov.
16) Fix skb->sk assigned without taking a reference to 'sk' in
appletalk, from Andrey Utkin.
17) Fix some info leaks in ULP event signalling to userspace in SCTP,
from Daniel Borkmann.
18) Fix deadlocks in HSO driver, from Olivier Sobrie.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (93 commits)
hso: fix deadlock when receiving bursts of data
hso: remove unused workqueue
net: ppp: don't call sk_chk_filter twice
mlx4: mark napi id for gro_skb
bonding: fix ad_select module param check
net: pppoe: use correct channel MTU when using Multilink PPP
neigh: sysctl - simplify address calculation of gc_* variables
net: sctp: fix information leaks in ulpevent layer
MAINTAINERS: update r8169 maintainer
net: bcmgenet: fix RGMII_MODE_EN bit
tipc: clear 'next'-pointer of message fragments before reassembly
r8152: fix r8152_csum_workaround function
be2net: set EQ DB clear-intr bit in be_open()
GRE: enable offloads for GRE
farsync: fix invalid memory accesses in fst_add_one() and fst_init_card()
igb: do a reset on SR-IOV re-init if device is down
igb: Workaround for i210 Errata 25: Slow System Clock
usbnet: smsc95xx: add reset_resume function with reset operation
dp83640: Always decode received status frames
r8169: disable L23
Jan points out that I forgot to make the needed fixes to the
lz4_uncompress_unknownoutputsize() function to mirror the changes done
in lz4_decompress() with regards to potential pointer overflows.
The only in-kernel user of this function is the zram code, which only
takes data from a valid compressed buffer that it made itself, so it's
not a big issue. But due to external kernel modules using this
function, it's better to be safe here.
Reported-by: Jan Beulich <JBeulich@suse.com>
Cc: "Don A. Bailey" <donb@securitymouse.com>
Cc: stable <stable@vger.kernel.org>
not defined
When device is non numa aware (numa_node == -1), use all online cpu's.
Signed-off-by: Amir Vadai <amirv@mellanox.com>
Pull SCSI target fixes from Nicholas Bellinger:
"Mostly minor fixes this time around. The highlights include:
- iscsi-target CHAP authentication fixes to enforce explicit key
values (Tejas Vaykole + rahul.rane)
- fix a long-standing OOPs in target-core when a alua configfs
attribute is accessed after port symlink has been removed.
(Sebastian Herbszt)
- fix a v3.10.y iscsi-target regression causing the login reject
status class/detail to be ignored (Christoph Vu-Brugier)
- fix a v3.10.y iscsi-target regression to avoid rejecting an
existing ITT during Data-Out when data-direction is wrong (Santosh
Kulkarni + Arshad Hussain)
- fix a iscsi-target related shutdown deadlock on UP kernels (Mikulas
Patocka)
- fix a v3.16-rc1 build issue with vhost-scsi + !CONFIG_NET (MST)"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: fix iscsit_del_np deadlock on unload
iovec: move memcpy_from/toiovecend to lib/iovec.c
iscsi-target: Avoid rejecting incorrect ITT for Data-Out
tcm_loop: Fix memory leak in tcm_loop_submission_work error path
iscsi-target: Explicily clear login response PDU in exception path
target: Fix left-over se_lun->lun_sep pointer OOPs
iscsi-target; Enforce 1024 byte maximum for CHAP_C key value
iscsi-target: Convert chap_server_compute_md5 to use kstrtoul
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull compress bugfix from Greg KH:
"Here is another lz4 bugfix for 3.16-rc3 that resolves a reported issue
with that compression algorithm"
* tag 'compress-3.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
lz4: fix another possible overrun
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb
Pull swiotlb bugfix from Konrad Rzeszutek Wilk:
"One bug-fix that had been in tree for quite some time. We had assumed
that the physical address zero was invalid and would fail it. But
that is not true and on some architectures it is not reserved and
valid. This fixes it"
* tag 'stable/for-linus-3.16-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb:
swiotlb: don't assume PA 0 is invalid
ERROR: "memcpy_fromiovecend" [drivers/vhost/vhost_scsi.ko] undefined!
commit 9f977ef7b671f6169eca78bf40f230fe84b7c7e5
vhost-scsi: Include prot_bytes into expected data transfer length
in target-pending makes drivers/vhost/scsi.c call memcpy_fromiovecend().
This function is not available when CONFIG_NET is not enabled.
socket.h already includes uio.h, so no callers need updating.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
There is one other possible overrun in the lz4 code as implemented by
Linux at this point in time (which differs from the upstream lz4
codebase, but will get synced at in a future kernel release.) As
pointed out by Don, we also need to check the overflow in the data
itself.
While we are at it, replace the odd error return value with just a
"simple" -1 value as the return value is never used for anything other
than a basic "did this work or not" check.
Reported-by: "Don A. Bailey" <donb@securitymouse.com>
Reported-by: Willy Tarreau <w@1wt.eu>
Pull compress bugfixes from Greg KH:
"Here are two bugfixes for some compression functions that resolve some
errors when uncompressing some pathalogical data. Both were found by
Don A Bailey"
lz4: ensure length does not wrap
lzo: properly check for overruns
of other architectures
The related warning:
scripts/kconfig/conf --allmodconfig Kconfig
warning: (FAULT_INJECTION_STACKTRACE_FILTER && LATENCYTOP && KMEMCHECK && LOCKDEP) selects FRAME_POINTER which has unmet direct dependencies (DEBUG_KERNEL && (CRIS || M68K || FRV || UML || AVR32 || SUPERH || BLACKFIN || MN10300 || METAG) || ARCH_WANT_FRAME_POINTERS)
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Given some pathologically compressed data, lz4 could possibly decide to
wrap a few internal variables, causing unknown things to happen. Catch
this before the wrapping happens and abort the decompression.
The lzo decompressor can, if given some really crazy data, possibly
overrun some variable types. Modify the checking logic to properly
detect overruns before they happen.
Tested-by: "Don A. Bailey" <donb@securitymouse.com>
In 2.6.29 io_tlb_orig_addr[] got converted from storing virtual addresses
to storing physical ones. While checking virtual addresses against NULL
is a legitimate thing to catch invalid entries, checking physical ones
against zero isn't: There's no guarantee that PFN 0 is reserved on a
particular platform.
Since it is unclear whether the check in swiotlb_tbl_unmap_single() is
actually needed, retain it but check against a guaranteed invalid physical
address. This requires setting up the array in a suitable fashion. And
since the original code failed to invalidate array entries when regions
get unmapped, this is being fixed at once along with adding a similar
check to swiotlb_tbl_sync_single().
Obviously the less intrusive change would be to simply drop the check in
swiotlb_tbl_unmap_single().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Pull drm updates from Dave Airlie:
"This is the main drm merge window pull request, changes all over the
place, mostly normal levels of churn.
Highlights:
Core drm:
More cleanups, fix race on connector/encoder naming, docs updates,
object locking rework in prep for atomic modeset
i915:
mipi DSI support, valleyview power fixes, cursor size fixes,
execlist refactoring, vblank improvements, userptr support, OOM
radeon:
GPUVM tuning and large page size support, gart fixes, deep color
HDMI support, HDMI audio cleanups
nouveau:
- displayport rework should fix lots of issues
- initial gk20a support
- gk110b support
- gk208 fixes
exynos:
probe order fixes, HDMI changes, IPP consolidation
msm:
debugfs updates, misc fixes
ast:
ast2400 support, sync with UMS driver
tegra:
cleanups, hdmi + hw cursor for Tegra 124.
panel:
fixes existing panels add some new ones.
ipuv3:
moved from staging to drivers/gpu"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits)
drm/nouveau/disp/dp: fix tmds passthrough on dp connector
drm/nouveau/dp: probe dpcd to determine connectedness
drm/nv50-: trigger update after all connectors disabled
drm/nv50-: prepare for attaching a SOR to multiple heads
drm/gf119-/disp: fix debug output on update failure
drm/nouveau/disp/dp: make use of postcursor when its available
drm/g94-/disp/dp: take max pullup value across all lanes
drm/nouveau/bios/dp: parse lane postcursor data
drm/nouveau/dp: fix support for dpms
drm/nouveau: register a drm_dp_aux channel for each dp connector
drm/g94-/disp: add method to power-off dp lanes
drm/nouveau/disp/dp: maintain link in response to hpd signal
drm/g94-/disp: bash and wait for something after changing lane power regs
drm/nouveau/disp/dp: split link config/power into two steps
drm/nv50/disp: train PIOR-attached DP from second supervisor
drm/nouveau/disp/dp: make use of existing output data for link training
drm/gf119/disp: start removing direct vbios parsing from supervisor
drm/nv50/disp: start removing direct vbios parsing from supervisor
drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal
drm/nouveau/disp/dp: create subclass for dp outputs
This function sets the n'th cpu - local cpu's first.
For example: in a 16 cores server with even cpu's local, will get the
following values:
cpumask_set_cpu_local_first(0, numa, cpumask) => cpu 0 is set
cpumask_set_cpu_local_first(1, numa, cpumask) => cpu 2 is set
cpumask_set_cpu_local_first(7, numa, cpumask) => cpu 14 is set
cpumask_set_cpu_local_first(8, numa, cpumask) => cpu 1 is set
cpumask_set_cpu_local_first(9, numa, cpumask) => cpu 3 is set
cpumask_set_cpu_local_first(15, numa, cpumask) => cpu 15 is set
Curently this function will be used by multi queue networking devices to
calculate the irq affinity mask, such that as many local cpu's as
possible will be utilized to handle the mq device irq's.
- 'struct nlattr' must be 2 byte aligned
- provide big-endian input data for nlattr/nlattr_nest tests
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Now that 3.15 is released, this merges the 'next' branch into 'master',
bringing us to the normal situation where my 'master' branch is the
merge window.
* accumulated work in next: (6809 commits)
ufs: sb mutex merge + mutex_destroy
powerpc: update comments for generic idle conversion
cris: update comments for generic idle conversion
idle: remove cpu_idle() forward declarations
nbd: zero from and len fields in NBD_CMD_DISCONNECT.
mm: convert some level-less printks to pr_*
MAINTAINERS: adi-buildroot-devel is moderated
MAINTAINERS: add linux-api for review of API/ABI changes
mm/kmemleak-test.c: use pr_fmt for logging
fs/dlm/debug_fs.c: replace seq_printf by seq_puts
fs/dlm/lockspace.c: convert simple_str to kstr
fs/dlm/config.c: convert simple_str to kstr
mm: mark remap_file_pages() syscall as deprecated
mm: memcontrol: remove unnecessary memcg argument from soft limit functions
mm: memcontrol: clean up memcg zoneinfo lookup
mm/memblock.c: call kmemleak directly from memblock_(alloc|free)
mm/mempool.c: update the kmemleak stack trace for mempool allocations
lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations
mm: introduce kmemleak_update_trace()
mm/kmemleak.c: use %u to print ->checksum
Since radix_tree_preload() stack trace is not always useful for
debugging an actual radix tree memory leak, this patch updates the
kmemleak allocation stack trace in the radix_tree_node_alloc() function.
If "idr->hint == p" is true, it also implies "idr->hint" is true(not NULL).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
After idr subsystem is changed to RCU-awared, the free layer will not go
to the free list. The free list will not be filled up when
idr_remove(). So we don't need to shink it too.
When the smaller id is not found, idr_replace() returns -ENOENT. But
when the id is bigger enough, idr_replace() returns -EINVAL, actually
there is no difference between these two kinds of ids.
These are all unallocated id, the return values of the idr_replace() for
these ids should be the same: -ENOENT.
If the ida has at least one existing id, and when an unallocated ID
which meets a certain condition is passed to the ida_remove(), the
system will crash because it hits NULL pointer dereference.
The condition is that the unallocated ID shares the same lowest idr
layer with the existing ID, but the idr slot would be different if the
unallocated ID were to be allocated.
In this case the matching idr slot for the unallocated_id is NULL,
causing @bitmap to be NULL which the function dereferences without
checking crashing the kernel.
See the test code:
static void test3(void)
int id;
DEFINE_IDA(test_ida);
printk(KERN_INFO "Start test3\n");
if (ida_pre_get(&test_ida, GFP_KERNEL) < 0) return;
if (ida_get_new(&test_ida, &id) < 0) return;
ida_remove(&test_ida, 4000); /* bug: null deference here */
printk(KERN_INFO "End of test3\n");
It happens only when the caller tries to free an unallocated ID which is
the caller's fault. It is not a bug. But it is better to add the
proper check and complain rather than crashing the kernel.
[tj@kernel.org: updated patch description]
If unallocated_id = (ANY * idr_max(idp->layers) + existing_id) is passed
to idr_remove(). The existing_id will be removed unexpectedly.
The following test shows this unexpected id-removal:
static void test4(void)
int id;
DEFINE_IDR(test_idr);
printk(KERN_INFO "Start test4\n");
id = idr_alloc(&test_idr, (void *)1, 42, 43, GFP_KERNEL);
BUG_ON(id != 42);
idr_remove(&test_idr, 42 + IDR_SIZE);
TEST_BUG_ON(idr_find(&test_idr, 42) != (void *)1);
idr_destroy(&test_idr);
printk(KERN_INFO "End of test4\n");
ida_remove() shares the similar problem.
proper check and complain rather than removing an existing_id silently.
idr_replace() open-codes the logic to calculate the maximum valid ID
given the height of the idr tree; unfortunately, the open-coded logic
doesn't account for the fact that the top layer may have unused slots
and over-shifts the limit to zero when the tree is at its maximum
height.
The following test code shows it fails to replace the value for
id=((1<<27)+42):
static void test5(void)
int id;
#define TEST5_START ((1<<27)+42) /* use the highest layer */
printk(KERN_INFO "Start test5\n");
id = idr_alloc(&test_idr, (void *)1, TEST5_START, 0, GFP_KERNEL);
BUG_ON(id != TEST5_START);
TEST_BUG_ON(idr_replace(&test_idr, (void *)2, TEST5_START) != (void *)1);
printk(KERN_INFO "End of test5\n");
Fix the bug by using idr_max() which correctly takes into account the
maximum allowed shift.
sub_alloc() shares the same problem and may incorrectly fail with
-EAGAIN; however, this bug doesn't affect correct operation because
idr_get_empty_slot(), which already uses idr_max(), retries with the
increased @id in such cases.
[tj@kernel.org: Updated patch description.]
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull ARM64 EFI update from Peter Anvin:
"By agreement with the ARM64 EFI maintainers, we have agreed to make
-tip the upstream for all EFI patches. That is why this patchset
comes from me :)
This patchset enables EFI stub support for ARM64, like we already have
on x86"
* 'arm64-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arm64: efi: only attempt efi map setup if booting via EFI
efi/arm64: ignore dtb= when UEFI SecureBoot is enabled
doc: arm64: add description of EFI stub support
arm64: efi: add EFI stub
doc: arm: add UEFI support documentation
arm64: add EFI runtime services
efi: Add shared FDT related functions for ARM/ARM64
arm64: Add function to create identity mappings
efi: add helper function to get UEFI params from FDT
doc: efi-stub.txt updates for ARM
lib: add fdt_empty_tree.c
Merge drm-fixes into drm-next.
Both i915 and radeon need this done for later patches.
drivers/gpu/drm/drm_crtc_helper.c
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem.c
drivers/gpu/drm/i915/i915_gem_execbuffer.c
drivers/gpu/drm/i915/i915_gem_gtt.c
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Convert printk to current pr_foo() logging functions.
Also add pr_fmt based on KBUILD_MODNAME to avoid repeating prefix. Prefix
is now "atomic64_test: "
Cc: Luca Barbieri <luca@luca-barbieri.com>
- Coalesce formats
- "WARNING:" prefix unchanged to keep bug format.
- printk(KERN_DEFAULT not converted.
- define pr_fmt without prefix to avoid any default prefix update
(suggested by Joe Perches).
Cc: Joe Perches <joe@perches.com>
Fix checkpatch warning:
"WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable"
Fix some checkpatch warnings:
Cc: Pablo Neira <pablo@netfilter.org>
Small typo and @return: -> Returns ...
Cc: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Use cpu_to_le32 instead of __constant_cpu_to_le32.
index has been removed from __radix_tree_delete_node in 449dd6984d0e47
("mm: keep page cache radix tree nodes in check")
Change CONFIG_DEBUG_PI_LIST to be user-selectable, and add a title and
description. Remove the dependency on DEBUG_RT_MUTEXES since they were
changed to use rbtrees, and there are other users of plists now.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
I use btree from 3.14-rc2 in my own module. When the btree module is
removed, a warning arises:
kmem_cache_destroy btree_node: Slab cache still has objects
CPU: 13 PID: 9150 Comm: rmmod Tainted: GF O 3.14.0-rc2 #1
Hardware name: Inspur NF5270M3/NF5270M3, BIOS CHEETAH_2.1.3 09/10/2013
Call Trace:
dump_stack+0x49/0x5d
kmem_cache_destroy+0xcf/0xe0
btree_module_exit+0x10/0x12 [btree]
SyS_delete_module+0x198/0x1f0
system_call_fastpath+0x16/0x1b
The cause is that it doesn't release the last btree node, when height = 1
and fill = 1.
[akpm@linux-foundation.org: remove unneeded test of NULL]
Signed-off-by: Minfei Huang <huangminfei@ucloud.cn>
Cc: Joern Engel <joern@logfs.org>
Cc: Johannes Berg <johannes@sipsolutions.net>
Fixing 2 coccinelle warnings:
lib/vsprintf.c:2350:2-9: WARNING: Assignment of bool to 0/1
lib/vsprintf.c:2389:3-10: WARNING: Assignment of bool to 0/1
replace IS_ERR/PTR_ERR
This restores the old behavior that existed before 2013-02-22, when
changes were made by 64dbfb444c150 ("decompressors: drop dependency on
CONFIG_EXPERT") and 5dc49c75a2 ("decompressors: make the default
XZ_DEC_* config match the selected architecture").
Disabling the filters only makes sense on embedded systems.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Acked-by: Kyle McMartin <kyle@infradead.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
Replace pr_debug() in lib/plist.c test function plist_test() with
printk(KERN_DEBUG ...).
Without DEBUG defined, pr_debug() is complied out, but the entire
plist_test() function is already inside CONFIG_DEBUG_PI_LIST, so printk
should just be used directly.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
For strncpy() and friends the source string may or may not have an actual
NUL character at the end. The documentation is confusing in this because
it specifically mentions that you are passing a "NUL-terminated" string.
Wikipedia says that "C-string" is an alternative name we can use instead.
http://en.wikipedia.org/wiki/Null-terminated_string
Add plist_requeue(), which moves the specified plist_node after all other
same-priority plist_nodes in the list. This is essentially an optimized
plist_del() followed by plist_add().
This is needed by swap, which (with the next patch in this set) uses a
plist of available swap devices. When a swap device (either a swap
partition or swap file) are added to the system with swapon(), the device
is added to a plist, ordered by the swap device's priority. When swap
needs to allocate a page from one of the swap devices, it takes the page
from the first swap device on the plist, which is the highest priority
swap device. The swap device is left in the plist until all its pages are
used, and then removed from the plist when it becomes full.
However, as described in man 2 swapon, swap must allocate pages from swap
devices with the same priority in round-robin order; to do this, on each
swap page allocation, swap uses a page from the first swap device in the
plist, and then calls plist_requeue() to move that swap device entry to
after any other same-priority swap devices. The next swap page allocation
will again use a page from the first swap device in the plist and requeue
it, and so on, resulting in round-robin usage of equal-priority swap
devices.
Also add plist_test_requeue() test function, for use by plist_test() to
test plist_requeue() function.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Shaohua Li <shli@fusionio.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Cc: Weijie Yang <weijieut@gmail.com>
Cc: Bob Liu <bob.liu@oracle.com>
Replace places where __get_cpu_var() is used for an address calculation
with this_cpu_ptr().
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
The DMA Contiguous Memory Allocator support on x86 is disabled when
swiotlb config option is enabled. So DMA CMA is always disabled on
x86_64 because swiotlb is always enabled. This attempts to support for
DMA CMA with enabling swiotlb config option.
The contiguous memory allocator on x86 is integrated in the function
dma_generic_alloc_coherent() which is .alloc callback in nommu_dma_ops
for dma_alloc_coherent().
x86_swiotlb_alloc_coherent() which is .alloc callback in swiotlb_dma_ops
tries to allocate with dma_generic_alloc_coherent() firstly and then
swiotlb_alloc_coherent() is called as a fallback.
The main part of supporting DMA CMA with swiotlb is that changing
x86_swiotlb_free_coherent() which is .free callback in swiotlb_dma_ops
for dma_free_coherent() so that it can distinguish memory allocated by
dma_generic_alloc_coherent() from one allocated by
swiotlb_alloc_coherent() and release it with dma_generic_free_coherent()
which can handle contiguous memory. This change requires making
is_swiotlb_buffer() global function.
This also needs to change .free callback in the dma_map_ops for amd_gart
and sta2x11, because these dma_ops are also using
dma_generic_alloc_coherent().
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Don Dutile <ddutile@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Introduce a CONFIG_DEBUG_VM_VMACACHE option to enable counting the cache
hit rate -- exported in /proc/vmstat.
Any updates to the caching scheme needs this kind of data, thus it can
save some work re-implementing the counting all the time.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Aswin Chandramouleeswaran <aswin@hp.com>
