git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into sched/core
The sleeping inside spinlock detection is actually used
for more general sleeping inside atomic sections
debugging: preemption disabled, rcu read side critical
sections, interrupts, interrupt disabled, etc...
Change the name of the config and its help section to
reflect its more general role.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
AFS: Use i_generation not i_version for the vnode uniquifier
AFS: Set s_id in the superblock to the volume name
vfs: Fix data corruption after failed write in __block_write_begin()
afs: afs_fill_page reads too much, or wrong data
VFS: Fix vfsmount overput on simultaneous automount
fix wrong iput on d_inode introduced by e6bc45d65d
Delay struct net freeing while there's a sysfs instance refering to it
afs: fix sget() races, close leak on umount
ubifs: fix sget races
ubifs: split allocation of ubifs_info into a separate function
fix leak in proc_set_super()
Fix new kernel-doc warnings in lib/bitmap.c:
Warning(lib/bitmap.c:596): No description found for parameter 'buf'
Warning(lib/bitmap.c:596): Excess function parameter 'bp' description in '__bitmap_parselist'
* new refcount in struct net, controlling actual freeing of the memory
* new method in kobj_ns_type_operations (->drop_ns())
* ->current_ns() semantics change - it's supposed to be followed by
corresponding ->drop_ns(). For struct net in case of CONFIG_NET_NS it bumps
the new refcount; net_drop_ns() decrements it and calls net_free() if the
last reference has been dropped. Method renamed to ->grab_current_ns().
* old net_free() callers call net_drop_ns() instead.
* sysfs_exit_ns() is gone, along with a large part of callchain
leading to it; now that the references stored in ->ns[...] stay valid we
do not need to hunt them down and replace them with NULL. That fixes
problems in sysfs_lookup() and sysfs_readdir(), along with getting rid
of sb->s_instances abuse.
Note that struct net *shutdown* logics has not changed - net_cleanup()
is called exactly when it used to be called. The only thing postponed by
having a sysfs instance refering to that struct net is actual freeing of
memory occupied by struct net.
Select CONFIG_PREEMPT_COUNT when we enable the sleeping inside
spinlock detection, so that the preempt offset gets correctly
incremented/decremented from preempt_disable()/preempt_enable().
This makes the preempt count eventually working in !CONFIG_PREEMPT
when that debug option is set and thus fixes the detection of explicit
preemption disabled sections under such config. Code that sleeps
in explicitly preempt disabled section can be finally spotted
in non-preemptible kernels.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6
* 'stable/xen-swiotlb.bugfix' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6:
swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.
RFC 5952 (http://tools.ietf.org/html/rfc5952) mandates that 2 or more
consecutive 0's are required before using :: compression.
Update ip6_compressed_string to match the RFC and update the http
reference as well.
By default the io_tlb_nslabs is set to zero, and gets set to
whatever value is passed in via swiotlb_init_with_tbl function.
The default value passed in is 64MB. However, if the user provides
the 'swiotlb=<nslabs>' the default value is ignored and
the value provided by the user is used... Except when the SWIOTLB
is used under Xen - there the default value of 64MB is used and
the Xen-SWIOTLB has no mechanism to get the 'io_tlb_nslabs' filled
out by setup_io_tlb_npages functions. This patch provides a function
for the Xen-SWIOTLB to call to see if the io_tlb_nslabs is set
and if so use that value.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Trivial config change to enable backtraces on panic.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The style that we normally use in asm-generic is to test the macro itself
for existence, so in asm-generic, do:
#ifndef find_next_zero_bit_le
extern unsigned long find_next_zero_bit_le(const void *addr,
unsigned long size, unsigned long offset);
#endif
and in the architectures, write
static inline unsigned long find_next_zero_bit_le(const void *addr,
#define find_next_zero_bit_le find_next_zero_bit_le
This adds the #ifndef for each of the find bitops in the generic header
and source files.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Greg Ungerer <gerg@uclinux.org>
On most architectures division is an expensive operation and accessing an
element currently requires four of them. This performance penalty
effectively precludes flex arrays from being used on any kind of fast
path. However, two of these divisions can be handled at creation time and
the others can be replaced by a reciprocal divide, completely avoiding
real divisions on access.
[eparis@redhat.com: rebase on top of changes to support 0 len elements]
[eparis@redhat.com: initialize part_nr when array fits entirely in base]
Signed-off-by: Jesse Gross <jesse@nicira.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
HARDIRQ_ENTER() maps to irq_enter() which calls rcu_irq_enter().
But HARDIRQ_EXIT() maps to __irq_exit() which doesn't call
rcu_irq_exit().
So for every locking selftest that simulates hardirq disabled,
we create an imbalance in the rcu extended quiescent state
internal state.
As a result, after the first missing rcu_irq_exit(), subsequent
irqs won't exit dyntick-idle mode after leaving the interrupt
handler. This means that RCU won't see the affected CPU as being
in an extended quiescent state, resulting in long grace-period
delays (as in grace periods extending for hours).
To fix this, just use __irq_enter() to simulate the hardirq
context. This is sufficient for the locking selftests as we
don't need to exit any extended quiescent state or perform
any check that irqs normally do when they wake up from idle.
As a side effect, this patch makes it possible to restore
"rcu: Decrease memory-barrier usage based on semi-formal proof",
which eventually helped finding this bug.
Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Stable <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it
to lib/Kconfig.debug so each arch doesn't have to define it. This
obviously makes the option generic, but that's fine because the config is
already used in generic code.
It's not obvious to me that sysrq-P actually does anything caution by
keeping the most inclusive wording.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
So we can specify the virtual address as the base of the pool chunk and
then get physical addresses for hardware IP.
For example on at91 we will use this on spi, uart or macb
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice VILCHEZ <patrice.vilchez@atmel.com>
Cc: Jes Sorensen <jes@wildopensource.com>
DEBUG_PER_CPU_MAPS is used in lib/cpumask.c as well as in
inlcude/linux/cpumask.h and thus it has outgrown its use within x86 and
powerpc alone. Any arch with SMP support may want to get some more
debugging, so make this option generic.
Cc: <linux-arch@vger.kernel.org>
There is quite a lot of code which does copy_from_user() + strict_strto*()
or simple_strto*() combo in slightly different ways.
Before doing conversions all over tree, let's get final API correct.
Enter kstrtoull_from_user() and friends.
Typical code which uses them looks very simple:
TYPE val;
int rv;
rv = kstrtoTYPE_from_user(buf, count, 0, &val);
if (rv < 0)
return rv;
[use val]
return count;
There is a tiny semantic difference from the plain kstrto*() API -- the
latter allows any amount of leading zeroes, while the former copies data
into buffer on stack and thus allows leading zeroes as long as it fits
into buffer.
This shouldn't be a problem for typical usecase "echo 42 > /proc/x".
The point is to make reading one integer from userspace _very_ simple and
very bug free.
This has no actual effect, since sizeof(struct hlist_head) ==
sizeof(struct hlist_head *), but it's still the wrong type to use.
The semantic match that finds this problem:
// <smpl>
type T;
identifier x;
T *x;
* x = kzalloc(... * sizeof(T*) * ..., ...);
// </smpl>
[akpm@linux-foundation.org: use kcalloc()]
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Acked-by: Lars Ellenberg <lars@linbit.com>
Otherwise, the warning at the top of vsnprintf() gets triggered by
kvasprintf()'s first invocation (with NULL buffer and zero size) of
vsnprintf().
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Manually adjusting the smp_affinity for IRQ's becomes unwieldy when the
cpu count is large.
Setting smp affinity to cpus 256 to 263 would be:
echo 000000ff,00000000,00000000,00000000,00000000,00000000,00000000,00000000 > smp_affinity
instead of:
echo 256-263 > smp_affinity_list
Think about what it looks like for cpus around say, 4088 to 4095.
We already have many alternate "list" interfaces:
/sys/devices/system/cpu/cpuX/indexY/shared_cpu_list
/sys/devices/system/cpu/cpuX/topology/thread_siblings_list
/sys/devices/system/cpu/cpuX/topology/core_siblings_list
/sys/devices/system/node/nodeX/cpulist
/sys/devices/pci***/***/local_cpulist
Add a companion interface, smp_affinity_list to use cpu lists instead of
cpu maps. This conforms to other companion interfaces where both a map
and a list interface exists.
This required adding a bitmap_parselist_user() function in a manner
similar to the bitmap_parse_user() function.
[akpm@linux-foundation.org: make __bitmap_parselist() static]
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Architectures that implement their own show_mem() function did not pass
the filter argument to show_free_areas() to appropriately avoid emitting
the state of nodes that are disallowed in the current context. This patch
now passes the filter argument to show_free_areas() so those nodes are now
avoided.
This patch also removes the show_free_areas() wrapper around
__show_free_areas() and converts existing callers to pass an empty filter.
ia64 emits additional information for each node, so skip_free_areas_zone()
must be made global to filter disallowed nodes and it is converted to use
a nid argument rather than a zone for this use case.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
for-linus
lib/flex_array.c
security/selinux/avc.c
security/selinux/hooks.c
security/selinux/ss/policydb.c
security/smack/smack_lsm.c
Manually resolve conflicts.
Signed-off-by: James Morris <jmorris@namei.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
seqlock: Don't smp_rmb in seqlock reader spin loop
watchdog, hung_task_timeout: Add Kconfig configurable default
lockdep: Remove cmpxchg to update nr_chain_hlocks
lockdep: Print a nicer description for simple irq lock inversions
lockdep: Replace "Bad BFS generated tree" message with something less cryptic
lockdep: Print a nicer description for irq inversion bugs
lockdep: Print a nicer description for simple deadlocks
lockdep: Print a nicer description for normal deadlocks
lockdep: Print a nicer description for irq lock inversions
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, gart: Rename pci-gart_64.c to amd_gart_64.c
x86/amd-iommu: Use threaded interupt handler
arch/x86/kernel/pci-iommu_table.c: Convert sprintf_symbol to %pS
x86/amd-iommu: Add support for invalidate_all command
x86/amd-iommu: Add extended feature detection
x86/amd-iommu: Add ATS enable/disable code
x86/amd-iommu: Add flag to indicate IOTLB support
x86/amd-iommu: Flush device IOTLB if ATS is enabled
x86/amd-iommu: Select PCI_IOV with AMD IOMMU driver
PCI: Move ATS declarations in seperate header file
dma-debug: print information about leaked entry
x86/amd-iommu: Flush all internal TLBs when IOMMUs are enabled
x86/amd-iommu: Rename iommu_flush_device
x86/amd-iommu: Improve handling of full command buffer
x86/amd-iommu: Rename iommu_flush* to domain_flush*
x86/amd-iommu: Remove command buffer resetting logic
x86/amd-iommu: Cleanup completion-wait handling
x86/amd-iommu: Cleanup inv_pages command handling
x86/amd-iommu: Move inv-dte command building to own function
x86/amd-iommu: Move compl-wait command building to own function
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm:
kmemleak: Initialise kmemleak after debug_objects_mem_init()
kmemleak: Select DEBUG_FS unconditionally in DEBUG_KMEMLEAK
kmemleak: Do not return a pointer to an object that kmemleak did not get
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (48 commits)
MIPS: Move arch_get_unmapped_area and gang to new file.
MIPS: Cleanup arch_get_unmapped_area
MIPS: Octeon: Don't request interrupts for unused IPI mailbox bits.
Octeon: Fix interrupt irq settings for performance counters.
MIPS: Fix build warnings on defconfigs
MIPS: Lemote 2F, Malta: Fix build warning
MIPS: Set ELF AT_PLATFORM string for Loongson2 processors
MIPS: Set ELF AT_PLATFORM string for BMIPS processors
MIPS: Introduce set_elf_platform() helper function
MIPS: JZ4740: setup: Autodetect physical memory.
MIPS: BCM47xx: Fix MAC address parsing.
MIPS: BCM47xx: Extend the filling of SPROM from NVRAM
MIPS: BCM47xx: Register SSB fallback sprom callback
MIPS: BCM47xx: Extend bcm47xx_fill_sprom with prefix.
SSB: Change fallback sprom to callback mechanism.
MIPS: Alchemy: Clean up GPIO registers and accessors
MIPS: Alchemy: Cleanup DMA addresses
MIPS: Alchemy: Rewrite ethernet platform setup
MIPS: Alchemy: Rewrite UART setup and constants.
MIPS: Alchemy: Convert dbdma.c to syscore_ops
In the past DEBUG_FS used to depend on SYSFS and DEBUG_KMEMLEAK selected
it conditionally. This is no longer the case, so always select DEBUG_FS
via DEBUG_KMEMLEAK.
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
To: Catalin Marinas <catalin.marinas@arm.com>
Cc: Daniel Baluta <dbaluta@ixiacom.com>
Cc: naveen yadav <yad.naveen@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: linux-mm@kvack.org
Patchwork: https://patchwork.linux-mips.org/patch/2244/
This is a rename of the usr_strtobool proposal, which was a renamed,
relocated and fixed version of previous kstrtobool RFC
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
There a large number hand-coded binary searches in the kernel (run
"git grep search | grep binary" to find many of them). Since in my
experience, hand-coding binary searches can be error-prone, it seems
worth cleaning this up by providing a generic binary search function.
This generic binary search implementation comes from Ksplice. It has
the same basic API as the C library bsearch() function. Ksplice uses
it in half a dozen places with 4 different comparison functions, and I
think our code is substantially cleaner because of this.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Extra-bikeshedding-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Extra-bikeshedding-by: André Goddard Rosa <andre.goddard@gmail.com>
Extra-bikeshedding-by: Rusty Russell <rusty@rustcorp.com.au>
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
kptr_restrict has been triggering bugs in apps such as perf, and it also makes
the system less useful by default, so turn it off by default.
This is how we generally handle security features that remove functionality,
such as firewall code or SELinux - they have to be configured and activated
from user-space.
Distributions can turn kptr_restrict on again via this line in
/etc/sysctrl.conf:
kernel.kptr_restrict = 1
( Also mark the variable __read_mostly while at it, as it's typically modified
only once per bootup, or not at all. )
'amd-iommu/ats' and 'amd-iommu/extended-features' into iommu/2.6.40
arch/x86/include/asm/amd_iommu_types.h
arch/x86/kernel/amd_iommu.c
arch/x86/kernel/amd_iommu_init.c
The prohibition of DEBUG_OBJECTS_RCU_HEAD from !PREEMPT was due to the
fixup actions. So just produce a warning from !PREEMPT.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The RCU CPU stall warnings can now be controlled using the
rcu_cpu_stall_suppress boot-time parameter or via the same parameter
from sysfs. There is therefore no longer any reason to have
kernel config parameters for this feature. This commit therefore
removes the RCU_CPU_STALL_DETECTOR and RCU_CPU_STALL_DETECTOR_RUNNABLE
kernel config parameters. The RCU_CPU_STALL_TIMEOUT parameter remains
to allow the timeout to be tuned and the RCU_CPU_STALL_VERBOSE parameter
remains to allow task-stall information to be suppressed if desired.
Many of the syscalls mentioned in the audit code are not present
for architectures that implement only the "standard" set of
Linux syscalls (e.g. openat, but not open, etc.). This change
adds proper #ifdefs for all those syscalls.
into for-linus
The old code considered valid empty LZMA2 streams to be corrupt.
Note that a typical empty .xz file has no LZMA2 data at all,
and thus most .xz files having no uncompressed data are handled
correctly even without this fix.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Just like kmalloc will allow one to allocate a 0 length segment of memory
flex arrays should do the same thing. It should bomb if you try to use
something, but it should at least allow the allocation.
This is needed because when SELinux switched to using flex_arrays in 2.6.38
the inability to allocate a 0 length array resulted in SELinux policy load
returning -ENOSPC when previously it worked.
Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com>
Tested-by: Chris Richards <gizmo@giz-works.com>
Cc: stable@kernel.org [2.6.38+]
Change flex_array_prealloc to take the number of elements for which space
should be allocated instead of the last (inclusive) element. Users
and documentation are updated accordingly. flex_arrays got introduced before
they had users. When folks started using it, they ended up needing a
different API than was coded up originally. This swaps over to the API that
folks apparently need.
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
flex_arrays are supposed to be a replacement for:
kmalloc(num_elements * sizeof(element))
If kmalloc is given 0 num_elements or a 0 size element it will happily return
ZERO_SIZE_PTR. Which looks like a valid allocation, but which will explode if
something actually try to use it. The current flex_array code will return an
equivalent result if num_elements is 0, but will fail to work if
sizeof(element) is 0. This patch allows allocation to work even for 0 size
elements. It will cause flex_arrays to explode though if they are used.
Imitating the kmalloc behavior.
This patch allows the default value for sysctl_hung_task_timeout_secs
to be set at build time. The feature carries virtually no overhead,
so it makes sense to keep it enabled. On heavily loaded systems, though,
it can end up triggering stack traces when there is no bug other than
the system being underprovisioned. We use this patch to keep the hung task
facility available but disabled at boot-time.
The default of 120 seconds is preserved. As a note, commit e162b39a may
have accidentally reverted commit fb822db4, which raised the default from
120 seconds to 480 seconds.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Acked-by: Mandeep Singh Baines <msb@google.com>
Link: http://lkml.kernel.org/r/4DB8600C.8080000@suse.com
Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
