path: root/lib
2013-01-03misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the last of the __dev* markings from the kernel from a variety of different, tiny, places. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20lib: atomic64: Initialize locks statically to fix early usersStephen Boyd
The atomic64 library uses a handful of static spin locks to implement atomic 64-bit operations on architectures without support for atomic 64-bit instructions. Unfortunately, the spinlocks are initialized in a pure initcall and that is too late for the vfs namespace code which wants to use atomic64 operations before the initcall is run. This became a problem as of commit 8823c079ba71: "vfs: Add setns support for the mount namespace". This leads to BUG messages such as: BUG: spinlock bad magic on CPU#0, swapper/0/0 lock: atomic64_lock+0x240/0x400, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 do_raw_spin_lock+0x158/0x198 _raw_spin_lock_irqsave+0x4c/0x58 atomic64_add_return+0x30/0x5c alloc_mnt_ns.clone.14+0x44/0xac create_mnt_ns+0xc/0x54 mnt_init+0x120/0x1d4 vfs_caches_init+0xe0/0x10c start_kernel+0x29c/0x300 coming out early on during boot when spinlock debugging is enabled. Fix this by initializing the spinlocks statically at compile time. Reported-and-tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com> Tested-by: Tony Lindgren <tony@atomide.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20Merge tag 'iommu-updates-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "A few new features this merge-window. The most important one is probably, that dma-debug now warns if a dma-handle is not checked with dma_mapping_error by the device driver. This requires minor changes to some architectures which make use of dma-debug. Most of these changes have the respective Acks by the Arch-Maintainers. Besides that there are updates to the AMD IOMMU driver for refactor the IOMMU-Groups support and to make sure it does not trigger a hardware erratum. The OMAP changes (for which I pulled in a branch from Tony Lindgren's tree) have a conflict in linux-next with the arm-soc tree. The conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is deleted in the arm-soc tree. It is safe to delete the file too so solve the conflict. Similar changes are done in the arm-soc tree in the common clock framework migration. A missing hunk from the patch in the IOMMU tree will be submitted as a seperate patch when the merge-window is closed." * tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits) ARM: dma-mapping: support debug_dma_mapping_error ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks iommu/omap: Adapt to runtime pm iommu/omap: Migrate to hwmod framework iommu/omap: Keep mmu enabled when requested iommu/omap: Remove redundant clock handling on ISR iommu/amd: Remove obsolete comment iommu/amd: Don't use 512GB pages iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch iommu/tegra: gart: Move bus_set_iommu after probe for multi arch iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all tile: dma_debug: add debug_dma_mapping_error support sh: dma_debug: add debug_dma_mapping_error support powerpc: dma_debug: add debug_dma_mapping_error support mips: dma_debug: add debug_dma_mapping_error support microblaze: dma-mapping: support debug_dma_mapping_error ia64: dma_debug: add debug_dma_mapping_error support c6x: dma_debug: add debug_dma_mapping_error support ARM64: dma_debug: add debug_dma_mapping_error support intel-iommu: Prevent devices with RMRRs from being placed into SI Domain ...
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlight is probably some base POWER8 support. There's more to come such as transactional memory support but that will wait for the next one. Overall it's pretty quiet, or rather I've been pretty poor at picking things up from patchwork and reviewing them this time around and Kumar no better on the FSL side it seems..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits) powerpc+of: Rename and fix OF reconfig notifier error inject module powerpc: mpc5200: Add a3m071 board support powerpc/512x: don't compile any platform DIU code if the DIU is not enabled powerpc/mpc52xx: use module_platform_driver macro powerpc+of: Export of_reconfig_notifier_[register,unregister] powerpc/dma/raidengine: add raidengine device powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct powerpc/mpc85xx: Change spin table to cached memory powerpc/fsl-pci: Add PCI controller ATMU PM support powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS] powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers powerpc: Disable relocation on exceptions when kexecing powerpc: Enable relocation on during exceptions at boot powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function powerpc: Add wrappers to enable/disable relocation on exceptions powerpc: Add set_mode hcall powerpc: Setup relocation on exceptions for bare metal systems powerpc: Move initial mfspr LPCR out of __init_LPCR powerpc: Add relocation on exception vector handlers ...
2012-12-18Merge tag 'md-3.8' of git://neil.brown.name/mdLinus Torvalds
Pull md update from Neil Brown: "Mostly just little fixes. Probably biggest part is AVX accelerated RAID6 calculations." * tag 'md-3.8' of git://neil.brown.name/md: md/raid5: add blktrace calls md/raid5: use async_tx_quiesce() instead of open-coding it. md: Use ->curr_resync as last completed request when cleanly aborting resync. lib/raid6: build proper files on corresponding arch lib/raid6: Add AVX2 optimized gen_syndrome functions lib/raid6: Add AVX2 optimized recovery functions md: Update checkpoint of resync/recovery based on time. md:Add place to update ->recovery_cp. md.c: re-indent various 'switch' statements. md: close race between removing and adding a device. md: removed unused variable in calc_sb_1_csm.
2012-12-17Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc patches from Andrew Morton: "Incoming: - lots of misc stuff - backlight tree updates - lib/ updates - Oleg's percpu-rwsem changes - checkpatch - rtc - aoe - more checkpoint/restart support I still have a pile of MM stuff pending - Pekka should be merging later today after which that is good to go. A number of other things are twiddling thumbs awaiting maintainer merges." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits) scatterlist: don't BUG when we can trivially return a proper error. docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output fs, fanotify: add @mflags field to fanotify output docs: add documentation about /proc/<pid>/fdinfo/<fd> output fs, notify: add procfs fdinfo helper fs, exportfs: add exportfs_encode_inode_fh() helper fs, exportfs: escape nil dereference if no s_export_op present fs, epoll: add procfs fdinfo helper fs, eventfd: add procfs fdinfo helper procfs: add ability to plug in auxiliary fdinfo providers tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test breakpoint selftests: print failure status instead of cause make error kcmp selftests: print fail status instead of cause make error kcmp selftests: make run_tests fix mem-hotplug selftests: print failure status instead of cause make error cpu-hotplug selftests: print failure status instead of cause make error mqueue selftests: print failure status instead of cause make error vm selftests: print failure status instead of cause make error ubifs: use prandom_bytes mtd: nandsim: use prandom_bytes ...
2012-12-17scatterlist: don't BUG when we can trivially return a proper error.Nick Bowler
There is absolutely no reason to crash the kernel when we have a perfectly good return value already available to use for conveying failure status. Let's return an error code instead of crashing the kernel: that sounds like a much better plan. [akpm@linux-foundation.org: s/E2BIG/EINVAL/] Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17prandom: introduce prandom_bytes() and prandom_bytes_state()Akinobu Mita
Add functions to get the requested number of pseudo-random bytes. The difference from get_random_bytes() is that it generates pseudo-random numbers by prandom_u32(). It doesn't consume the entropy pool, and the sequence is reproducible if the same rnd_state is used. So it is suitable for generating random bytes for testing. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: David Laight <david.laight@aculab.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17random32: rename random32 to prandomAkinobu Mita
This renames all random32 functions to have 'prandom_' prefix as follows: void prandom_seed(u32 seed); /* rename from srandom32() */ u32 prandom_u32(void); /* rename from random32() */ void prandom_seed_state(struct rnd_state *state, u64 seed); /* rename from prandom32_seed() */ u32 prandom_u32_state(struct rnd_state *state); /* rename from prandom32() */ The purpose of this renaming is to prevent some kernel developers from assuming that prandom32() and random32() might imply that only prandom32() was the one using a pseudo-random number generator by prandom32's "p", and the result may be a very embarassing security exposure. This concern was expressed by Theodore Ts'o. And furthermore, I'm going to introduce new functions for getting the requested number of pseudo-random bytes. If I continue to use both prandom32 and random32 prefixes for these functions, the confusion is getting worse. As a result of this renaming, "prandom_" is the common prefix for pseudo-random number library. Currently, srandom32() and random32() are preserved because it is difficult to rename too many users at once. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Robert Love <robert.w.love@intel.com> Cc: Michel Lespinasse <walken@google.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: David Laight <david.laight@aculab.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17simple_strto*: annotate function as obsoleteEldad Zack
Update the documentation for simple_strto* to reflect that it has been obsoleted and advise the usage of kstrto*. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Joe Perches <joe@perches.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17kstrto*: add documentationEldad Zack
As Bruce Fields pointed out, kstrto* is currently lacking kerneldoc comments. This patch adds kerneldoc comments to common variants of kstrto*: kstrto(u)l, kstrto(u)ll and kstrto(u)int. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Joe Perches <joe@perches.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lib/rbtree_test.c: fix uninitialized variable warningCong Ding
Fix this warning: lib/rbtree_test.c: In function `check': lib/rbtree_test.c:121: warning: `blacks' may be used uninitialized in this function Signed-off-by: Cong Ding <dinggnu@gmail.com> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17percpu_rw_semaphore: introduce CONFIG_PERCPU_RWSEMOleg Nesterov
Currently only block_dev and uprobes use percpu_rw_semaphore, add the config option selected by BLOCK || UPROBES. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17percpu_rw_semaphore: add lockdep annotationsOleg Nesterov
Add lockdep annotations. Not only this can help to find the potential problems, we do not want the false warnings if, say, the task takes two different percpu_rw_semaphore's for reading. IOW, at least ->rw_sem should not use a single class. This patch exposes this internal lock to lockdep so that it represents the whole percpu_rw_semaphore. This way we do not need to add another "fake" ->lockdep_map and lock_class_key. More importantly, this also makes the output from lockdep much more understandable if it finds the problem. In short, with this patch from lockdep pov percpu_down_read() and percpu_up_read() acquire/release ->rw_sem for reading, this matches the actual semantics. This abuses __up_read() but I hope this is fine and in fact I'd like to have down_read_no_lockdep() as well, percpu_down_read_recursive_readers() will need it. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17percpu_rw_semaphore: kill ->writer_mutex, add ->write_ctrOleg Nesterov
percpu_rw_semaphore->writer_mutex was only added to simplify the initial rewrite, the only thing it protects is clear_fast_ctr() which otherwise could be called by multiple writers. ->rw_sem is enough to serialize the writers. Kill this mutex and add "atomic_t write_ctr" instead. The writers increment/decrement this counter, the readers check it is zero instead of mutex_is_locked(). Move atomic_add(clear_fast_ctr(), slow_read_ctr) under down_write() to avoid the race with other writers. This is a bit sub-optimal, only the first writer needs this and we do not need to exclude the readers at this stage. But this is simple, we do not want another internal lock until we add more features. And this speeds up the write-contended case. Before this patch the racing writers sleep in synchronize_sched_expedited() sequentially, with this patch multiple synchronize_sched_expedited's can "overlap" with each other. Note: we can do more optimizations, this is only the first step. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17percpu_rw_semaphore: reimplement to not block the readers unnecessarilyOleg Nesterov
Currently the writer does msleep() plus synchronize_sched() 3 times to acquire/release the semaphore, and during this time the readers are blocked completely. Even if the "write" section was not actually started or if it was already finished. With this patch down_write/up_write does synchronize_sched() twice and down_read/up_read are still possible during this time, just they use the slow path. percpu_down_write() first forces the readers to use rw_semaphore and increment the "slow" counter to take the lock for reading, then it takes that rw_semaphore for writing and blocks the readers. Also. With this patch the code relies on the documented behaviour of synchronize_sched(), it doesn't try to pair synchronize_sched() with barrier. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anton Arapov <anton@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17sscanf: don't ignore field widths for numeric conversionsJan Beulich
This is another step towards better standard conformance. Rather than adding a local buffer to store the specified portion of the string (with the need to enforce an arbitrary maximum supported width to limit the buffer size), do a maximum width conversion and then drop as much of it as is necessary to meet the caller's request. Also fail on negative field widths. Uses the deprecated simple_strto*() functions because kstrtoXX() fail on non-zero terminated strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lib: dynamic_debug: use kbasename()Andy Shevchenko
Remove the custom implementation of the functionality similar to kbasename(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lib/vsprintf.c: fix handling of %zd when using ssize_tJason Gunthorpe
Documentation/printk-formats.txt says to use %zd for a ssize_t argument and some drivers do. Unfortunately this prints a positive number for negative values eg: tpm_tis 70030000.tpm_tis: tpm_transmit: tpm_send: error 4294967234 Add a case to va_args a ssize_t type if the interpretation should be signed. Tested on PPC32. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18Merge remote-tracking branch 'agust/next' into nextBenjamin Herrenschmidt
Brings some 52xx updates. Also manually merged tools/perf/perf.h. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-12-17Merge branch 'for-3.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver update from Jens Axboe: "Now that the core bits are in, here are the driver bits for 3.8. The branch contains: - A huge pile of drbd bits that were dumped from the 3.7 merge window. Following that, it was both made perfectly clear that there is going to be no more over-the-wall pulls and how the situation on individual pulls can be improved. - A few cleanups from Akinobu Mita for drbd and cciss. - Queue improvement for loop from Lukas. This grew into adding a generic interface for waiting/checking an even with a specific lock, allowing this to be pulled out of md and now loop and drbd is also using it. - A few fixes for xen back/front block driver from Roger Pau Monne. - Partition improvements from Stephen Warren, allowing partiion UUID to be used as an identifier." * 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits) drbd: update Kconfig to match current dependencies drbd: Fix drbdsetup wait-connect, wait-sync etc... commands drbd: close race between drbd_set_role and drbd_connect drbd: respect no-md-barriers setting also when changed online via disk-options drbd: Remove obsolete check drbd: fixup after wait_even_lock_irq() addition to generic code loop: Limit the number of requests in the bio list wait: add wait_event_lock_irq() interface xen-blkfront: free allocated page xen-blkback: move free persistent grants code block: partition: msdos: provide UUIDs for partitions init: reduce PARTUUID min length to 1 from 36 block: store partition_meta_info.uuid as a string cciss: use check_signature() cciss: cleanup bitops usage drbd: use copy_highpage drbd: if the replication link breaks during handshake, keep retrying drbd: check return of kmalloc in receive_uuids drbd: Broadcast sync progress no more often than once per second drbd: don't try to clear bits once the disk has failed ...
2012-12-16Merge tag 'stable/for-linus-3.8-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb Pull swiotlb update from Konrad Rzeszutek Wilk: "Feature: - Use dma addresses instead of the virt_to_phys and vice versa functions. Remove the multitude of phys_to_virt/virt_to_phys calls and instead operate on the physical addresses instead of virtual in many of the internal functions. This does provide a speed up in interrupt handlers that do DMA operations and use SWIOTLB." * tag 'stable/for-linus-3.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb: swiotlb: Do not export swiotlb_bounce since there are no external consumers swiotlb: Use physical addresses instead of virtual in swiotlb_tbl_sync_single swiotlb: Use physical addresses for swiotlb_tbl_unmap_single swiotlb: Return physical addresses when calling swiotlb_tbl_map_single swiotlb: Make io_tlb_overflow_buffer a physical address swiotlb: Make io_tlb_start a physical address instead of a virtual one swiotlb: Make io_tlb_end a physical address instead of a virtual one
2012-12-16Merge branches 'iommu/fixes', 'dma-debug', 'x86/amd', 'x86/vt-d', ↵Joerg Roedel
'arm/tegra' and 'arm/omap' into next
2012-12-14Merge branch 'x86-acpi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 ACPI update from Peter Anvin: "This is a patchset which didn't make the last merge window. It adds a debugging capability to feed ACPI tables via the initramfs. On a grander scope, it formalizes using the initramfs protocol for feeding arbitrary blobs which need to be accessed early to the kernel: they are fed first in the initramfs blob (lots of bootloaders can concatenate this at boot time, others can use a single file) in an uncompressed cpio archive using filenames starting with "kernel/". The ACPI maintainers requested that this patchset be fed via the x86 tree rather than the ACPI tree as the footprint in the general x86 code is much bigger than in the ACPI code proper." * 'x86-acpi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: X86 ACPI: Use #ifdef not #if for CONFIG_X86 check ACPI: Fix build when disabled ACPI: Document ACPI table overriding via initrd ACPI: Create acpi_table_taint() function to avoid code duplication ACPI: Implement physical address table override ACPI: Store valid ACPI tables passed via early initrd in reserved memblock areas x86, acpi: Introduce x86 arch specific arch_reserve_mem_area() for e820 handling lib: Add early cpio decoder
2012-12-14ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constantsDavid Howells
Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants in the ASN.1 general decoder instead of the equivalent numbers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14powerpc+of: Rename and fix OF reconfig notifier error inject moduleBenjamin Herrenschmidt
This module used to inject errors in the pSeries specific dynamic reconfiguration notifiers. Those are gone however, replaced by generic notifiers for changes to the device-tree. So let's update the module to deal with these instead and rename it along the way. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13lib/raid6: build proper files on corresponding archYuanhan Liu
sse and avx2 stuff only exist on x86 arch, and we don't need to build altivec on x86. And we can do that at lib/raid6/Makefile. Proposed-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Jim Kukunas <james.t.kukunas@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-12-13lib/raid6: Add AVX2 optimized gen_syndrome functionsYuanhan Liu
Add AVX2 optimized gen_syndrom functions, which is simply based on sse2.c written by hpa. Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Jim Kukunas <james.t.kukunas@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-12-13lib/raid6: Add AVX2 optimized recovery functionsJim Kukunas
Optimize RAID6 recovery functions to take advantage of the 256-bit YMM integer instructions introduced in AVX2. The patch was tested and benchmarked before submission. However hardware is not yet released so benchmark numbers cannot be reported. Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Jim Kukunas <james.t.kukunas@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-12-11Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU update from Ingo Molnar: "The major features of this tree are: 1. A first version of no-callbacks CPUs. This version prohibits offlining CPU 0, but only when enabled via CONFIG_RCU_NOCB_CPU=y. Relaxing this constraint is in progress, but not yet ready for prime time. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/724. 2. Changes to SRCU that allows statically initialized srcu_struct structures. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/296. 3. Restructuring of RCU's debugfs output. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/341. 4. Additional CPU-hotplug/RCU improvements, posted to LKML at https://lkml.org/lkml/2012/10/30/327. Note that the commit eliminating __stop_machine() was judged to be too-high of risk, so is deferred to 3.9. 5. Changes to RCU's idle interface, most notably a new module parameter that redirects normal grace-period operations to their expedited equivalents. These were posted to LKML at https://lkml.org/lkml/2012/10/30/739. 6. Additional diagnostics for RCU's CPU stall warning facility, posted to LKML at https://lkml.org/lkml/2012/10/30/315. The most notable change reduces the default RCU CPU stall-warning time from 60 seconds to 21 seconds, so that it once again happens sooner than the softlockup timeout. 7. Documentation updates, which were posted to LKML at https://lkml.org/lkml/2012/10/30/280. A couple of late-breaking changes were posted at https://lkml.org/lkml/2012/11/16/634 and https://lkml.org/lkml/2012/11/16/547. 8. Miscellaneous fixes, which were posted to LKML at https://lkml.org/lkml/2012/10/30/309. 9. Finally, a fix for an lockdep-RCU splat was posted to LKML at https://lkml.org/lkml/2012/11/7/486." * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (49 commits) context_tracking: New context tracking susbsystem sched: Mark RCU reader in sched_show_task() rcu: Separate accounting of callbacks from callback-free CPUs rcu: Add callback-free CPUs rcu: Add documentation for the new rcuexp debugfs trace file rcu: Update documentation for TREE_RCU debugfs tracing rcu: Reduce default RCU CPU stall warning timeout rcu: Fix TINY_RCU rcu_is_cpu_rrupt_from_idle check rcu: Clarify memory-ordering properties of grace-period primitives rcu: Add new rcutorture module parameters to start/end test messages rcu: Remove list_for_each_continue_rcu() rcu: Fix batch-limit size problem rcu: Add tracing for synchronize_sched_expedited() rcu: Remove old debugfs interfaces and also RCU flavor name rcu: split 'rcuhier' to each flavor rcu: split 'rcugp' to each flavor rcu: split 'rcuboost' to each flavor rcu: split 'rcubarrier' to each flavor rcu: Fix tracing formatting rcu: Remove the interface "rcudata.csv" ...
2012-12-11Merge branch 'akpm' (Andrew's patchbomb)Linus Torvalds
Merge misc updates from Andrew Morton: "About half of most of MM. Going very early this time due to uncertainty over the coreautounifiednumasched things. I'll send the other half of most of MM tomorrow. The rest of MM awaits a slab merge from Pekka." * emailed patches from Andrew Morton: (71 commits) memory_hotplug: ensure every online node has NORMAL memory memory_hotplug: handle empty zone when online_movable/online_kernel mm, memory-hotplug: dynamic configure movable memory and portion memory drivers/base/node.c: cleanup node_state_attr[] bootmem: fix wrong call parameter for free_bootmem() avr32, kconfig: remove HAVE_ARCH_BOOTMEM mm: cma: remove watermark hacks mm: cma: skip watermarks check for already isolated blocks in split_free_page() mm, oom: fix race when specifying a thread as the oom origin mm, oom: change type of oom_score_adj to short mm: cleanup register_node() mm, mempolicy: remove duplicate code mm/vmscan.c: try_to_freeze() returns boolean mm: introduce putback_movable_pages() virtio_balloon: introduce migration primitives to balloon pages mm: introduce compaction and migration for ballooned pages mm: introduce a common interface for balloon pages mobility mm: redefine address_space.assoc_mapping mm: adjust address_space_operations.migratepage() return code arch/sparc/kernel/sys_sparc_64.c: s/COLOUR/COLOR/ ...
2012-12-11bootmem: fix wrong call parameter for free_bootmem()Joonsoo Kim
It is strange that alloc_bootmem() returns a virtual address and free_bootmem() requires a physical address. Anyway, free_bootmem()'s first parameter should be physical address. There are some call sites for free_bootmem() with virtual address. So fix them. [akpm@linux-foundation.org: improve free_bootmem() and free_bootmem_pate() documentation] Signed-off-by: Joonsoo Kim <js1304@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-06lib/Makefile: Fix oid_registry build dependencyTim Gardner
It is $(obj)/oid_registry.o that is dependent on $(obj)/oid_registry_data.c. The object file cannot be built until $(obj)/oid_registry_data.c has been generated. A periodic and hard to reproduce parallel build failure is due to this incorrect lib/Makefile dependency. The compile error is completely disingenuous. GEN lib/oid_registry_data.c Compiling 49 OIDs CC lib/oid_registry.o gcc: error: lib/oid_registry.c: No such file or directory gcc: fatal error: no input files compilation terminated. make[3]: *** [lib/oid_registry.o] Error 4 Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-05ASN.1: Fix an indefinite length skip errorDavid Howells
Fix an error in asn1_find_indefinite_length() whereby small definite length elements of size 0x7f are incorrecly classified as non-small. Without this fix, an error will be given as the length of the length will be perceived as being very much greater than the maximum supported size. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-03treewide: Fix typos in various KconfigMasanari Iida
Correct spelling typo within various Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-03Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Conflicts: arch/x86/kernel/ptrace.c Pull the latest RCU tree from Paul E. McKenney: " The major features of this series are: 1. A first version of no-callbacks CPUs. This version prohibits offlining CPU 0, but only when enabled via CONFIG_RCU_NOCB_CPU=y. Relaxing this constraint is in progress, but not yet ready for prime time. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/724, and are at branch rcu/nocb. 2. Changes to SRCU that allows statically initialized srcu_struct structures. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/296, and are at branch rcu/srcu. 3. Restructuring of RCU's debugfs output. These commits were posted to LKML at https://lkml.org/lkml/2012/10/30/341, and are at branch rcu/tracing. 4. Additional CPU-hotplug/RCU improvements, posted to LKML at https://lkml.org/lkml/2012/10/30/327, and are at branch rcu/hotplug. Note that the commit eliminating __stop_machine() was judged to be too-high of risk, so is deferred to 3.9. 5. Changes to RCU's idle interface, most notably a new module parameter that redirects normal grace-period operations to their expedited equivalents. These were posted to LKML at https://lkml.org/lkml/2012/10/30/739, and are at branch rcu/idle. 6. Additional diagnostics for RCU's CPU stall warning facility, posted to LKML at https://lkml.org/lkml/2012/10/30/315, and are at branch rcu/stall. The most notable change reduces the default RCU CPU stall-warning time from 60 seconds to 21 seconds, so that it once again happens sooner than the softlockup timeout. 7. Documentation updates, which were posted to LKML at https://lkml.org/lkml/2012/10/30/280, and are at branch rcu/doc. A couple of late-breaking changes were posted at https://lkml.org/lkml/2012/11/16/634 and https://lkml.org/lkml/2012/11/16/547. 8. Miscellaneous fixes, which were posted to LKML at https://lkml.org/lkml/2012/10/30/309, along with a late-breaking change posted at Fri, 16 Nov 2012 11:26:25 -0800 with message-ID <20121116192625.GA447@linux.vnet.ibm.com>, but which lkml.org seems to have missed. These are at branch rcu/fixes. 9. Finally, a fix for an lockdep-RCU splat was posted to LKML at https://lkml.org/lkml/2012/11/7/486. This is at rcu/next. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-11-28lib: kobject_uevent is no longer dependant on CONFIG_HOTPLUGBill Pemberton
CONFIG_HOTPLUG is being removed so kobject_uevent needs to always be part of the library. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-23MPI: Fix compilation on MIPS with GCC 4.4 and newerManuel Lauss
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint, leading to this build failure: CC lib/mpi/generic_mpih-mul1.o lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm' This patch updates MPI with the latest umul_ppm implementations for MIPS. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: James Morris <jmorris@namei.org> Patchwork: https://patchwork.linux-mips.org/patch/4612/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-17dma-debug: fix to not have dependency on get_dma_ops() interfaceShuah Khan
dma-debug depends on get_dma_ops() interface. Several architectures do not define dma_ops and get_dma_ops(). When dma debug interfaces are used on an architecture (e.g: c6x) that doesn't define get_dmap_ops(), compilation fails. Changing dma-debug to call dma_mapping_error() instead of defining its own that calls get_dma_ops(), such that the internal use of dma_mapping_error() doesn't interfere with the debug_dma_mapping_error() interface's mapping error checks. Moving dma_mapping_error() checks in check_unmap() under the dma debug entry not found is sufficient to fix the problem. Reference: https://lkml.org/lkml/2012/10/26/367 Signed-off-by: Shuah Khan <shuah.khan@hp.com> Reported-by: Mark Salter <msalter@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-11-13rcu: Reduce default RCU CPU stall warning timeoutPaul E. McKenney
The RCU CPU stall warning timeout has defaulted to 60 seconds for some years, with almost no false positives. This commit therefore reduces the default to 21 seconds, slightly shorter than the new soft-lockup timeout. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-11-09Merge branch 'drbd-8.4_ed6' into for-3.8-drivers-drbd-8.4_ed6Philipp Reisner
2012-10-30swiotlb: Do not export swiotlb_bounce since there are no external consumersAlexander Duyck
Currently swiotlb is the only consumer for swiotlb_bounce. Since that is the case it doesn't make much sense to be exporting it so make it a static function only. In addition we can save a few more lines of code by making it so that it accepts the DMA address as a physical address instead of a virtual one. This is the last piece in essentially pushing all of the DMA address values to use physical addresses in swiotlb. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_bounce I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Use physical addresses instead of virtual in swiotlb_tbl_sync_singleAlexander Duyck
This change makes it so that the sync functionality also uses physical addresses. This helps to further reduce the use of virt_to_phys and phys_to_virt functions. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_sync_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Use physical addresses for swiotlb_tbl_unmap_singleAlexander Duyck
This change makes it so that the unmap functionality also uses physical addresses. This helps to further reduce the use of virt_to_phys and phys_to_virt functions. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_unmap_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Return physical addresses when calling swiotlb_tbl_map_singleAlexander Duyck
This change makes it so that swiotlb_tbl_map_single will return a physical address instead of a virtual address when called. The advantage to this once again is that we are avoiding a number of virt_to_phys and phys_to_virt translations by working with everything as a physical address. One change I had to make in order to support using physical addresses is that I could no longer trust 0 to be a invalid physical address on all platforms. So instead I made it so that ~0 is returned on error. This should never be a valid return value as it implies that only one byte would be available for use. In order to clarify things since we now have 2 physical addresses in use inside of swiotlb_tbl_map_single I am renaming phys to orig_addr, and dma_addr to tlb_addr. This way is should be clear that orig_addr is contained within io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30swiotlb: Make io_tlb_overflow_buffer a physical addressAlexander Duyck
This change makes it so that we can avoid virt_to_phys overhead when using the io_tlb_overflow_buffer. My original plan was to completely remove the value and replace it with a constant but I had seen that there were recent patches that stated this couldn't be done until all device drivers that depended on that functionality be updated. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
