path: root/lib
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-12-06lib: Improve EWMA efficiency by using bitshiftsBruno Randolf
Using bitshifts instead of division and multiplication should improve performance. That requires weight and factor to be powers of two, but i think this is something we can live with. Thanks to Peter Zijlstra for the improved formula! Signed-off-by: Bruno Randolf <br1@einfach.org> -- v2: use log2.h functions Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-29Revert "debug_locks: set oops_in_progress if we will log messages."Dave Airlie
This reverts commit e0fdace10e75dac67d906213b780ff1b1a4cc360. On-list discussion seems to suggest that the robustness fixes for printk make this unnecessary and DaveM has also agreed in person at Kernel Summit and on list. The main problem with this code is once we hit a lockdep splat we always keep oops_in_progress set, the console layer uses oops_in_progress with KMS to decide when it should be showing the oops and not showing X, so it causes problems around suspend/resume time when a userspace resume can cause a console switch away from X, only if oops_in_progress is set (which is what we want if an oops actually is in progress, but not because we had a lockdep splat 2 days prior). Cc: David S Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-24Merge branch 'master' of ↵John W. Linville
2010-11-18lib: Add generic exponentially weighted moving average (EWMA) functionBruno Randolf
This adds generic functions for calculating Exponentially Weighted Moving Averages (EWMA). This implementation makes use of a structure which keeps the EWMA parameters and a scaled up internal representation to reduce rounding errors. The original idea for this implementation came from the rt2x00 driver (rt2x00link.c). I would like to use it in several places in the mac80211 and ath5k code and I hope it can be useful in many other places in the kernel code. Signed-off-by: Bruno Randolf <br1@einfach.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16netlink: let nlmsg and nla functions take pointer-to-const argsJan Engelhardt
The changed functions do not modify the NL messages and/or attributes at all. They should use const (similar to strchr), so that callers which have a const nlmsg/nlattr around can make use of them without casting. While at it, constify a data array. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12radix-tree: fix RCU bugNick Piggin
Salman Qazi describes the following radix-tree bug: In the following case, we get can get a deadlock: 0. The radix tree contains two items, one has the index 0. 1. The reader (in this case find_get_pages) takes the rcu_read_lock. 2. The reader acquires slot(s) for item(s) including the index 0 item. 3. The non-zero index item is deleted, and as a consequence the other item is moved to the root of the tree. The place where it used to be is queued for deletion after the readers finish. 3b. The zero item is deleted, removing it from the direct slot, it remains in the rcu-delayed indirect node. 4. The reader looks at the index 0 slot, and finds that the page has 0 ref count 5. The reader looks at it again, hoping that the item will either be freed or the ref count will increase. This never happens, as the slot it is looking at will never be updated. Also, this slot can never be reclaimed because the reader is holding rcu_read_lock and is in an infinite loop. The fix is to re-use the same "indirect" pointer case that requires a slot lookup retry into a general "retry the lookup" bit. Signed-off-by: Nick Piggin <npiggin@kernel.dk> Reported-by: Salman Qazi <sqazi@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-26docbook: add idr/ida to kernel-api docbookRandy Dunlap
Add idr/ida to kernel-api docbook. Fix typos and kernel-doc notation. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Naohiro Aota <naota@elisp.net> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: convert a BUG_ON to BUILD_BUG_ON arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode arch/tile: support new info op generated by compiler arch/tile: minor whitespace/naming changes for string support files arch/tile: enable single-step support for TILE-Gx arch/tile: parameterize system PLs to support KVM port arch/tile: add Tilera's <arch/sim.h> header as an open-source header arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h> arch/tile: prevent corrupt top frame from causing backtracer runaway arch/tile: various top-level Makefile cleanups arch/tile: change lower bound on syscall error return to -4095 arch/tile: properly export __mb_incoherent for modules arch/tile: provide a definition of MAP_STACK kmemleak: add TILE to the list of supported architectures. char: hvc: check for error case arch/tile: Add a warning if we try to allocate too much vmalloc memory. arch/tile: update some comments to clarify register usage. arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends arch/tile: Use <asm-generic/syscalls.h> tile: replace some BUG_ON checks with BUILD_BUG_ON checks
2010-10-26div64_u64(): improve precision on 32bit platformsBrian Behlendorf
The current implementation of div64_u64 for 32bit systems returns an approximately correct result when the divisor exceeds 32bits. Since doing 64bit division using 32bit hardware is a long since solved problem we just use one of the existing proven methods. Additionally, add a div64_s64 function to correctly handle doing signed 64bit division. Addresses https://bugzilla.redhat.com/show_bug.cgi?id=616105 Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Ben Woodard <bwoodard@llnl.gov> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Mark Grondona <mgrondona@llnl.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/parser: cleanup match_number()Namhyung Kim
Use new variable 'len' to make code more readable. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu_counter: use this_cpu_ptr() instead of per_cpu_ptr()Christoph Lameter
this_cpu_ptr() avoids an array lookup and can use the percpu offset of the local cpu directly. Signed-off-by: Christoph Lameter <cl@linux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: check element addressesArtem Bityutskiy
Improve 'lib_sort()' test and check that: o 'cmp()' is called only for elements which were present in the original list, i.e., the 'a' and 'b' parameters are valid o the resulted (sorted) list consists onlly of the original elements o intdoruce "poison" fields to make sure data around 'struc list_head' field are not corrupted. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: unify test messagesArtem Bityutskiy
This patch unifies 'list_sort_test()' messages a bit and makes sure all of them start with the "list_sort_test:" prefix to make it obvious for users where the messages come from. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: improve errors handlingArtem Bityutskiy
The 'lib_sort()' test does not free memory if it fails, and it makes the kernel panic if it cannot allocate memory. This patch fixes the problem. This patch also changes several small things: o use 'list_add()' helper instead of adding manually o introduce temporary 'el1' variable to avoid ugly and unreadalbe "if" statement o make 'head' to be stack variable instead of 'kmalloc()'ed, which simplifies code a bit Overall, this patch is of clean-up type. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: use generic random32Artem Bityutskiy
Instead of using own pseudo-random generator, use generic linux 'random32()' function. Presumably, this should improve test coverage. At the same time, do the following changes: o Use shorter macro name for test list length o Do not use strange 'l_h' name for 'struct list_head' element, use 'list', because it is traditional name and thus, makes the code more obvious and readable. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: use more reasonable printk levelsArtem Bityutskiy
I do not see any reason to use KERN_WARN for normal messages and KERN_EMERG for error messages in the lib_sort testing routine. Let's use more reasonable KERN_NORM and KERN_ERR levels. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/Kconfig.debug: add list_sort debugging switchArtem Bityutskiy
While hunting a non-existing bug in 'list_sort()', I've improved the 'list_sort_test()' function which tests the 'list_sort()' library call. Although at the end I found a bug in my code, but not in 'list_sort()', I think my clean-ups and improvements are worth merging because they make the test function better. This patch: Make the self-tests selectable via Kconfig rather than by manual enabling of DEBUG_LIST_SORT. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu_counter: add debugobj supportTejun Heo
All percpu counters are linked to a global list on initialization and removed from it on destruction. The list is walked during CPU up/down. If a percpu counter is freed without being properly destroyed, the system will oops only on the next CPU up/down making it pretty nasty to track down. This patch adds debugobj support for percpu counters so that such problems can be found easily. As percpu counters don't make sense on stack and can't be statically initialized, debugobj support is pretty simple. It's initialized and activated on counter initialization, and deactivatd and destroyed on counter destruction. With this patch applied, the bug fixed by commit 602586a83b719df0fbd94196a1359ed35aeb2df3 (shmem: put_super must percpu_counter_destroy) triggers the following warning on tmpfs unmount and the system won't oops on the next cpu up/down operation. ------------[ cut here ]------------ WARNING: at lib/debugobjects.c:259 debug_print_object+0x5c/0x70() Hardware name: Bochs ODEBUG: free active (active state 0) object type: percpu_counter Modules linked in: Pid: 3999, comm: umount Not tainted 2.6.36-rc2-work+ #5 Call Trace: [<ffffffff81083f7f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81084076>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813b45cc>] debug_print_object+0x5c/0x70 [<ffffffff813b50e5>] debug_check_no_obj_freed+0x125/0x210 [<ffffffff811577d3>] kfree+0xb3/0x2f0 [<ffffffff81132edd>] shmem_put_super+0x1d/0x30 [<ffffffff81162e96>] generic_shutdown_super+0x56/0xe0 [<ffffffff81162f86>] kill_anon_super+0x16/0x60 [<ffffffff81162ff7>] kill_litter_super+0x27/0x30 [<ffffffff81163295>] deactivate_locked_super+0x45/0x60 [<ffffffff81163cfa>] deactivate_super+0x4a/0x70 [<ffffffff8117d446>] mntput_no_expire+0x86/0xe0 [<ffffffff8117df7f>] sys_umount+0x6f/0x360 [<ffffffff8103f01b>] system_call_fastpath+0x16/0x1b ---[ end trace cce2a341ba3611a7 ]--- Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Thomas Gleixner <tglxlinutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26idr: fix idr_pre_get() locking descriptionNaohiro Aota
Despite the idr_pre_get() kernel-doc, there are some cases where you can call idr_pre_get() from within locked regions. Add a description for such cases. See also: http://lkml.org/lkml/2010/9/16/462 [akpm@linux-foundation.org: cleanups, grammatical fixes] Signed-off-by: Naohiro Aota <naota@elisp.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/bitmap.c: use hex_to_bin()Andy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib: fix scnprintf() if @size is == 0Changli Gao
scnprintf() should return 0 if @size is == 0. Update the comment for it, as @size is unsigned. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26vsprintf.c: use default pointer field size for "(null)" stringsJoe Perches
It might be nicer to align the output. For instance, ACPI messages sometimes have "(null)" pointers. $ dmesg | grep "(null)" -A 1 -B 1 [ 0.198733] ACPI: Dynamic OEM Table Load: [ 0.198745] ACPI: SSDT (null) 00239 (v02 PmRef Cpu0Ist 00003000 INTL 20051117) [ 0.199294] ACPI: SSDT 7f596e10 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117) [ 0.200708] ACPI: Dynamic OEM Table Load: [ 0.200721] ACPI: SSDT (null) 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117) [ 0.201950] ACPI: SSDT 7f597f10 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117) [ 0.203386] ACPI: Dynamic OEM Table Load: [ 0.203398] ACPI: SSDT (null) 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117) [ 0.203871] ACPI: SSDT 7f595f10 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117) [ 0.205301] ACPI: Dynamic OEM Table Load: [ 0.205315] ACPI: SSDT (null) 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117) [akpm@linux-foundation.org: add code comment] Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu: fix list_head init bug in __percpu_counter_init()Masanori ITOH
WARNING: at lib/list_debug.c:26 __list_add+0x3f/0x81() Hardware name: Express5800/B120a [N8400-085] list_add corruption. next->prev should be prev (ffffffff81a7ea00), but was dead000000200200. (next=ffff88080b872d58). Modules linked in: aoe ipt_MASQUERADE iptable_nat nf_nat autofs4 sunrpc bridge 8021q garp stp llc ipv6 cpufreq_ondemand acpi_cpufreq freq_table dm_round_robin dm_multipath kvm_intel kvm uinput lpfc scsi_transport_fc igb ioatdma scsi_tgt i2c_i801 i2c_core dca iTCO_wdt iTCO_vendor_support pcspkr shpchp megaraid_sas [last unloaded: aoe] Pid: 54, comm: events/3 Tainted: G W 2.6.34-vanilla1 #1 Call Trace: [<ffffffff8104bd77>] warn_slowpath_common+0x7c/0x94 [<ffffffff8104bde6>] warn_slowpath_fmt+0x41/0x43 [<ffffffff8120fd2e>] __list_add+0x3f/0x81 [<ffffffff81212a12>] __percpu_counter_init+0x59/0x6b [<ffffffff810d8499>] bdi_init+0x118/0x17e [<ffffffff811f2c50>] blk_alloc_queue_node+0x79/0x143 [<ffffffff811f2d2b>] blk_alloc_queue+0x11/0x13 [<ffffffffa02a931d>] aoeblk_gdalloc+0x8e/0x1c9 [aoe] [<ffffffffa02aa655>] aoecmd_sleepwork+0x25/0xa8 [aoe] [<ffffffff8106186c>] worker_thread+0x1a9/0x237 [<ffffffffa02aa630>] ? aoecmd_sleepwork+0x0/0xa8 [aoe] [<ffffffff81065827>] ? autoremove_wake_function+0x0/0x39 [<ffffffff810616c3>] ? worker_thread+0x0/0x237 [<ffffffff810653ad>] kthread+0x7f/0x87 [<ffffffff8100aa24>] kernel_thread_helper+0x4/0x10 [<ffffffff8106532e>] ? kthread+0x0/0x87 [<ffffffff8100aa20>] ? kernel_thread_helper+0x0/0x10 It's because there is no initialization code for a list_head contained in the struct backing_dev_info under CONFIG_HOTPLUG_CPU, and the bug comes up when block device drivers calling blk_alloc_queue() are used. In case of me, I got them by using aoe. Signed-off-by: Masanori Itoh <itoumsn@nttdata.co.jp> Cc: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24Merge branch 'master' into for-linusPekka Enberg
Conflicts: include/linux/percpu.h mm/percpu.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: introduce CONFIG_BKL. dabusb: remove the BKL sunrpc: remove the big kernel lock init/main.c: remove BKL notations blktrace: remove the big kernel lock rtmutex-tester: make it build without BKL dvb-core: kill the big kernel lock dvb/bt8xx: kill the big kernel lock tlclk: remove big kernel lock fix rawctl compat ioctls breakage on amd64 and itanic uml: kill big kernel lock parisc: remove big kernel lock cris: autoconvert trivial BKL users alpha: kill big kernel lock isapnp: BKL removal s390/block: kill the big kernel lock hpet: kill BKL, add compat_ioctl
2010-10-22kobject: Introduce kset_find_obj_hinted.Robin Holt
One call chain getting to kset_find_obj is: link_mem_sections() find_mem_section() kset_find_obj() This is done during boot. The memory sections were added in a linearly increasing order and link_mem_sections tends to utilize them in that same linear order. Introduce a kset_find_obj_hinted which is passed the result of the previous kset_find_obj which it uses for a quick "is the next object our desired object" check before falling back to the old behavior. Signed-off-by: Robin Holt <holt@sgi.com> To: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Initialize dynamic debug earlier via arch_initcallThomas Renninger
Having the ddebug_query= boot parameter it makes sense to set up dynamic debug as soon as possible. I expect sysfs files cannot be set up via an arch_initcall, because this one is even before fs_initcall. Therefore I splitted the dynamic_debug_init function into an early one and a later one providing /sys/../dynamic_debug/control file. Possibly dynamic_debug can be initialized even earlier, not sure whether this still makes sense then. I picked up arch_initcall as it covers quite a lot already. Dynamic debug needs to allocate memory, therefore it's not easily possible to set it up even before the command line gets parsed. Therefore the boot param query string is stored in a temp string which is applied when dynamic debug gets set up. This has been tested with ddebug_query="file ec.c +p" and I could retrieve pr_debug() messages early at boot during ACPI setup: ACPI: EC: Look up EC in DSDT ACPI: EC: ---> status = 0x08 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 ACPI: EC: ~~~> interrupt ACPI: EC: ---> status = 0x08 ACPI: EC: <--- data = 0xa4 ... ACPI: Interpreter enabled ACPI: (supports S0 S3 S4 S5) ACPI: Using IOAPIC for interrupt routing ACPI: EC: ---> status = 0x00 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> CC: linux-acpi@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Introduce ddebug_query= boot parameterThomas Renninger
Dynamic debug lacks the ability to enable debug messages at boot time. One could patch initramfs or service startup scripts to write to /sys/../dynamic_debug/control, but this sucks. This patch makes it possible to pass a query in the same format one can write to /sys/../dynamic_debug/control via boot param. When dynamic debug gets initialized, this query will automatically be applied. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Split out query string parsing/setup from proc_writeThomas Renninger
The parsing and applying of dynamic debug strings is not only useful for /sys/../dynamic_debug/control write access, but can also be used for boot parameter parsing. The boot parameter is introduced in a follow up patch. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-21Merge branch 'stable/swiotlb-0.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6 * 'stable/swiotlb-0.9' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6: swiotlb: Use page alignment for early buffer allocation swiotlb: make io_tlb_overflow static
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-18jump_label: Use more consistent namingPeter Zijlstra
Now that there's still only a few users around, rename things to make them more consistent. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101014203625.448565169@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-14kmemleak: add TILE to the list of supported architectures.Chris Metcalf
All the necessary functionality was already there; we just need to make it possible to select the config option. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-11swiotlb: Use page alignment for early buffer allocationYinghai Lu
We could call free_bootmem_late() if swiotlb is not used, and it will shrink to page alignment. So alloc them with page alignment at first, to avoid lose two pages before patch: [ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer [ 0.000000] memblock_x86_reserve_range: [00d7e7ef40, 00d7e9ef40] swiotlb list [ 0.000000] memblock_x86_reserve_range: [00d7e3ef40, 00d7e7ef40] swiotlb orig_ad [ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo after patch will get [ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer [ 0.000000] memblock_x86_reserve_range: [00d7e7e000, 00d7e9e000] swiotlb list [ 0.000000] memblock_x86_reserve_range: [00d7e3e000, 00d7e7e000] swiotlb orig_ad [ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-11swiotlb: make io_tlb_overflow staticFUJITA Tomonori
We don't need to export io_tlb_overflow_buffer. I'll remove io_tlb_overflow_buffer completely in the long term though. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-08Merge commit 'v2.6.36-rc7' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/module.c Merge reason: Resolve the conflict, pick up fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07move async raid6 test to lib/Kconfig.debugDan Williams
The prompt for "Self test for hardware accelerated raid6 recovery" does not belong in the top level configuration menu. All the options in crypto/async_tx/Kconfig are selected and do not depend on CRYPTO. Kconfig.debug seems like a reasonable fit. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-07Merge commit 'v2.6.36-rc7' into core/rcuIngo Molnar
Merge reason: Update from -rc3 to -rc7. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-10-06slub: Enable sysfs support for !CONFIG_SLUB_DEBUGChristoph Lameter
Currently disabling CONFIG_SLUB_DEBUG also disabled SYSFS support meaning that the slabs cannot be tuned without DEBUG. Make SYSFS support independent of CONFIG_SLUB_DEBUG Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-01lib/list_sort: do not pass bad pointers to cmp callbackDon Mullis
If the original list is a POT in length, the first callback from line 73 will pass a==b both pointing to the original list_head. This is dangerous because the 'list_sort()' user can use 'container_of()' and accesses the "containing" object, which does not necessary exist for the list head. So the user can access RAM which does not belong to him. If this is a write access, we can end up with memory corruption. Signed-off-by: Don Mullis <don.mullis@gmail.com> Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
