path: root/lib
2011-01-13flex_array: export symbols to modulesDavid Rientjes
Alex said: I want to use flex_array to store a sparse array of ATM cell re-assembly buffers for my ATM over Ethernet driver. Using the per-vcc user_back structure causes problems when stacked with things like br2684. Add EXPORT_SYMBOL() for all publically accessible flex array functions and move to obj-y so that modules may use this library. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Reported-by: Alex Bennee <kernel-hacker@bennee.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13lib/vsprintf.c: fix vscnprintf() if @size is == 0Anton Arapov
vscnprintf() should return 0 if @size is == 0. Update the comment for it, as @size is unsigned. This change based on the code of commit b903c0b8899b46829a9b80ba55b61079b35940ec ("lib: fix scnprintf() if @size is == 0") moves the real fix into vscnprinf() from scnprintf() and makes scnprintf() call vscnprintf(), thus avoid code duplication. Signed-off-by: Anton Arapov <aarapov@redhat.com> Acked-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h lib/hexdump.c: neatening and add CONFIG_PRINTK guardJoe Perches
- Move prototypes and align arguments. - Add CONFIG_PRINTK guard for print_hex functions Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kptr_restrict for hiding kernel pointers from unprivileged usersDan Rosenberg
Add the %pK printk format specifier and the /proc/sys/kernel/kptr_restrict sysctl. The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". [akpm@linux-foundation.org: check for IRQ context when !kptr_restrict, save an indent level, s/WARN/WARN_ONCE/] [akpm@linux-foundation.org: coding-style fixup] [randy.dunlap@oracle.com: fix kernel/sysctl.c warning] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-10Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (390 commits) drm/radeon/kms: disable underscan by default drm/radeon/kms: only enable hdmi features if the monitor supports audio drm: Restore the old_fb upon modeset failure drm/nouveau: fix hwmon device binding radeon: consolidate asic-specific function decls for pre-r600 vga_switcheroo: comparing too few characters in strncmp() drm/radeon/kms: add NI pci ids drm/radeon/kms: don't enable pcie gen2 on NI yet drm/radeon/kms: add radeon_asic struct for NI asics drm/radeon/kms/ni: load default sclk/mclk/vddc at pm init drm/radeon/kms: add ucode loader for NI drm/radeon/kms: add support for DCE5 display LUTs drm/radeon/kms: add ni_reg.h drm/radeon/kms: add bo blit support for NI drm/radeon/kms: always use writeback/events for fences on NI drm/radeon/kms: adjust default clock/vddc tracking for pm on DCE5 drm/radeon/kms: add backend map workaround for barts drm/radeon/kms: fill gpu init for NI asics drm/radeon/kms: add disabled vbios accessor for NI asics drm/radeon/kms: handle NI thermal controller ...
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07dynamic debug: Fix build issue with older gccJason Baron
On older gcc (3.3) dynamic debug fails to compile: include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer': include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label declaration `out' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label `do_printk' include/net/inet_connection_sock.h:236: error: duplicate label `out' Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now. Cc: <stable@kernel.org> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-06Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: MAINTAINERS: Update timer related entries timers: Use this_cpu_read timerqueue: Make timerqueue_getnext() static inline hrtimer: fix timerqueue conversion flub hrtimers: Convert hrtimers to use timerlist infrastructure timers: Fixup allmodconfig build issue timers: Rename timerlist infrastructure to timerqueue timers: Introduce timerlist infrastructure. hrtimer: Remove stale comment on curr_timer timer: Warn when del_timer_sync() is called in hardirq context timer: Del_timer_sync() can be used in softirq context timer: Make try_to_del_timer_sync() the same on SMP and UP posix-timers: Annotate lock_timer() timer: Permit statically-declared work with deferrable timers time: Use ARRAY_SIZE macro in timecompare.c timer: Initialize the field slack of timer_list timer_list: Remove alignment padding on 64 bit when CONFIG_TIMER_STATS time: Compensate for rounding on odd-frequency clocksources Fix up trivial conflict in MAINTAINERS
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-22x86, nmi_watchdog: Remove ARCH_HAS_NMI_WATCHDOG and rely on ↵Don Zickus
CONFIG_HARDLOCKUP_DETECTOR The x86 arch has shifted its use of the nmi_watchdog from a local implementation to the global one provide by kernel/watchdog.c. This shift has caused a whole bunch of compile problems under different config options. I attempt to simplify things with the patch below. In order to simplify things, I had to come to terms with the meaning of two terms ARCH_HAS_NMI_WATCHDOG and CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing, the former on a local level and the latter on a global level. With the old x86 nmi watchdog gone, there is no need to rely on defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't make sense any more. x86 will now use the global implementation. The changes below do a few things. First it changes the few places that relied on ARCH_HAS_NMI_WATCHDOG to use CONFIG_X86_LOCAL_APIC (the former was an alias for the latter anyway, so nothing unusual here). Those pieces of code were relying more on local apic functionality the nmi watchdog functionality, so the change should make sense. Second, I removed the x86 implementation of touch_nmi_watchdog(). It isn't need now, instead x86 will rely on kernel/watchdog.c's implementation. Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from x86. And tweaked the include/linux/nmi.h file to tell users to look for an externally defined touch_nmi_watchdog in the case of ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This changes removes some of the ugliness in that file. Finally, I added a Kconfig dependency for CONFIG_HARDLOCKUP_DETECTOR that said you can't have ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can only have one nmi_watchdog. Tested with ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig, (various broken configs) Hopefully, after this patch I won't get any more compile broken emails. :-) v3: changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-17percpucounter: Optimize __percpu_counter_add a bit through the use of ↵Christoph Lameter
this_cpu() options. The this_cpu_* options can be used to optimize __percpu_counter_add a bit. Avoids some address arithmetic and saves 12 bytes. Before: 00000000000001d3 <__percpu_counter_add>: 1d3: 55 push %rbp 1d4: 48 89 e5 mov %rsp,%rbp 1d7: 41 55 push %r13 1d9: 41 54 push %r12 1db: 53 push %rbx 1dc: 48 89 fb mov %rdi,%rbx 1df: 48 83 ec 08 sub $0x8,%rsp 1e3: 4c 8b 67 30 mov 0x30(%rdi),%r12 1e7: 65 4c 03 24 25 00 00 add %gs:0x0,%r12 1ee: 00 00 1f0: 4d 63 2c 24 movslq (%r12),%r13 1f4: 48 63 c2 movslq %edx,%rax 1f7: 49 01 f5 add %rsi,%r13 1fa: 49 39 c5 cmp %rax,%r13 1fd: 7d 0a jge 209 <__percpu_counter_add+0x36> 1ff: f7 da neg %edx 201: 48 63 d2 movslq %edx,%rdx 204: 49 39 d5 cmp %rdx,%r13 207: 7f 1e jg 227 <__percpu_counter_add+0x54> 209: 48 89 df mov %rbx,%rdi 20c: e8 00 00 00 00 callq 211 <__percpu_counter_add+0x3e> 211: 4c 01 6b 18 add %r13,0x18(%rbx) 215: 48 89 df mov %rbx,%rdi 218: 41 c7 04 24 00 00 00 movl $0x0,(%r12) 21f: 00 220: e8 00 00 00 00 callq 225 <__percpu_counter_add+0x52> 225: eb 04 jmp 22b <__percpu_counter_add+0x58> 227: 45 89 2c 24 mov %r13d,(%r12) 22b: 5b pop %rbx 22c: 5b pop %rbx 22d: 41 5c pop %r12 22f: 41 5d pop %r13 231: c9 leaveq 232: c3 retq After: 00000000000001d3 <__percpu_counter_add>: 1d3: 55 push %rbp 1d4: 48 63 ca movslq %edx,%rcx 1d7: 48 89 e5 mov %rsp,%rbp 1da: 41 54 push %r12 1dc: 53 push %rbx 1dd: 48 89 fb mov %rdi,%rbx 1e0: 48 8b 47 30 mov 0x30(%rdi),%rax 1e4: 65 44 8b 20 mov %gs:(%rax),%r12d 1e8: 4d 63 e4 movslq %r12d,%r12 1eb: 49 01 f4 add %rsi,%r12 1ee: 49 39 cc cmp %rcx,%r12 1f1: 7d 0a jge 1fd <__percpu_counter_add+0x2a> 1f3: f7 da neg %edx 1f5: 48 63 d2 movslq %edx,%rdx 1f8: 49 39 d4 cmp %rdx,%r12 1fb: 7f 21 jg 21e <__percpu_counter_add+0x4b> 1fd: 48 89 df mov %rbx,%rdi 200: e8 00 00 00 00 callq 205 <__percpu_counter_add+0x32> 205: 4c 01 63 18 add %r12,0x18(%rbx) 209: 48 8b 43 30 mov 0x30(%rbx),%rax 20d: 48 89 df mov %rbx,%rdi 210: 65 c7 00 00 00 00 00 movl $0x0,%gs:(%rax) 217: e8 00 00 00 00 callq 21c <__percpu_counter_add+0x49> 21c: eb 04 jmp 222 <__percpu_counter_add+0x4f> 21e: 65 44 89 20 mov %r12d,%gs:(%rax) 222: 5b pop %rbx 223: 41 5c pop %r12 225: c9 leaveq 226: c3 retq Reviewed-by: Pekka Enberg <penberg@kernel.org> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-16Merge remote branch 'airlied/drm-core-next' into drm-intel-nextChris Wilson
2010-12-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-12-11timerqueue: Make timerqueue_getnext() static inlineThomas Gleixner
No point in calling a function just to dereference a pointer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Fixup allmodconfig build issueJohn Stultz
Adds missed EXPORT_SYMBOL lines that cause the following build failures with allmodconfig: ERROR: "timerqueue_add" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_getnext" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_del" [drivers/rtc/rtc-core.ko] undefined! Reported-by: Ingo Molnar <mingo@elte.hu> Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Rename timerlist infrastructure to timerqueueJohn Stultz
Thomas pointed out a namespace collision between the new timerlist infrastructure I introduced and the existing timer_list.c So to avoid confusion, I've renamed the timerlist infrastructure to timerqueue. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-12-06lib: Improve EWMA efficiency by using bitshiftsBruno Randolf
Using bitshifts instead of division and multiplication should improve performance. That requires weight and factor to be powers of two, but i think this is something we can live with. Thanks to Peter Zijlstra for the improved formula! Signed-off-by: Bruno Randolf <br1@einfach.org> -- v2: use log2.h functions Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-02timers: Introduce timerlist infrastructure.John Stultz
The timerlist infrastructure is a thin layer over the rbtree code that implements a simple list of timers sorted by an expires value, and a getnext function that provides a pointer to the earliest timer. This infrastructure allows drivers and other kernel infrastructure to easily implement timers without duplicating code. Signed-off-by: John Stultz <john.stultz@linaro.org> LKML Reference: <1290136329-18291-2-git-send-email-john.stultz@linaro.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Richard Cochran <richardcochran@gmail.com>
2010-11-29Revert "debug_locks: set oops_in_progress if we will log messages."Dave Airlie
This reverts commit e0fdace10e75dac67d906213b780ff1b1a4cc360. On-list discussion seems to suggest that the robustness fixes for printk make this unnecessary and DaveM has also agreed in person at Kernel Summit and on list. The main problem with this code is once we hit a lockdep splat we always keep oops_in_progress set, the console layer uses oops_in_progress with KMS to decide when it should be showing the oops and not showing X, so it causes problems around suspend/resume time when a userspace resume can cause a console switch away from X, only if oops_in_progress is set (which is what we want if an oops actually is in progress, but not because we had a lockdep splat 2 days prior). Cc: David S Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-29lib: hex2bin converts ascii hexadecimal string to binaryMimi Zohar
Similar to the kgdb_hex2mem() code, hex2bin converts a string to binary using the hex_to_bin() library call. Changelog: - Replace parameter names with src/dst (based on David Howell's comment) - Add 'const' where needed (based on David Howell's comment) - Replace int with size_t (based on David Howell's comment) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-24Merge branch 'master' of ↵John W. Linville
2010-11-22kref: Add a kref_sub functionThomas Hellstrom
Makes it possible to optimize batched multiple unrefs. Initial user will be drivers/gpu/ttm which accumulates unrefs to be processed outside of atomic code. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-18lib: Add generic exponentially weighted moving average (EWMA) functionBruno Randolf
This adds generic functions for calculating Exponentially Weighted Moving Averages (EWMA). This implementation makes use of a structure which keeps the EWMA parameters and a scaled up internal representation to reduce rounding errors. The original idea for this implementation came from the rt2x00 driver (rt2x00link.c). I would like to use it in several places in the mac80211 and ath5k code and I hope it can be useful in many other places in the kernel code. Signed-off-by: Bruno Randolf <br1@einfach.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16netlink: let nlmsg and nla functions take pointer-to-const argsJan Engelhardt
The changed functions do not modify the NL messages and/or attributes at all. They should use const (similar to strchr), so that callers which have a const nlmsg/nlattr around can make use of them without casting. While at it, constify a data array. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12radix-tree: fix RCU bugNick Piggin
Salman Qazi describes the following radix-tree bug: In the following case, we get can get a deadlock: 0. The radix tree contains two items, one has the index 0. 1. The reader (in this case find_get_pages) takes the rcu_read_lock. 2. The reader acquires slot(s) for item(s) including the index 0 item. 3. The non-zero index item is deleted, and as a consequence the other item is moved to the root of the tree. The place where it used to be is queued for deletion after the readers finish. 3b. The zero item is deleted, removing it from the direct slot, it remains in the rcu-delayed indirect node. 4. The reader looks at the index 0 slot, and finds that the page has 0 ref count 5. The reader looks at it again, hoping that the item will either be freed or the ref count will increase. This never happens, as the slot it is looking at will never be updated. Also, this slot can never be reclaimed because the reader is holding rcu_read_lock and is in an infinite loop. The fix is to re-use the same "indirect" pointer case that requires a slot lookup retry into a general "retry the lookup" bit. Signed-off-by: Nick Piggin <npiggin@kernel.dk> Reported-by: Salman Qazi <sqazi@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-26docbook: add idr/ida to kernel-api docbookRandy Dunlap
Add idr/ida to kernel-api docbook. Fix typos and kernel-doc notation. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Naohiro Aota <naota@elisp.net> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: convert a BUG_ON to BUILD_BUG_ON arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode arch/tile: support new info op generated by compiler arch/tile: minor whitespace/naming changes for string support files arch/tile: enable single-step support for TILE-Gx arch/tile: parameterize system PLs to support KVM port arch/tile: add Tilera's <arch/sim.h> header as an open-source header arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h> arch/tile: prevent corrupt top frame from causing backtracer runaway arch/tile: various top-level Makefile cleanups arch/tile: change lower bound on syscall error return to -4095 arch/tile: properly export __mb_incoherent for modules arch/tile: provide a definition of MAP_STACK kmemleak: add TILE to the list of supported architectures. char: hvc: check for error case arch/tile: Add a warning if we try to allocate too much vmalloc memory. arch/tile: update some comments to clarify register usage. arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends arch/tile: Use <asm-generic/syscalls.h> tile: replace some BUG_ON checks with BUILD_BUG_ON checks
2010-10-26div64_u64(): improve precision on 32bit platformsBrian Behlendorf
The current implementation of div64_u64 for 32bit systems returns an approximately correct result when the divisor exceeds 32bits. Since doing 64bit division using 32bit hardware is a long since solved problem we just use one of the existing proven methods. Additionally, add a div64_s64 function to correctly handle doing signed 64bit division. Addresses https://bugzilla.redhat.com/show_bug.cgi?id=616105 Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Ben Woodard <bwoodard@llnl.gov> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Mark Grondona <mgrondona@llnl.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/parser: cleanup match_number()Namhyung Kim
Use new variable 'len' to make code more readable. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu_counter: use this_cpu_ptr() instead of per_cpu_ptr()Christoph Lameter
this_cpu_ptr() avoids an array lookup and can use the percpu offset of the local cpu directly. Signed-off-by: Christoph Lameter <cl@linux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: check element addressesArtem Bityutskiy
Improve 'lib_sort()' test and check that: o 'cmp()' is called only for elements which were present in the original list, i.e., the 'a' and 'b' parameters are valid o the resulted (sorted) list consists onlly of the original elements o intdoruce "poison" fields to make sure data around 'struc list_head' field are not corrupted. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: unify test messagesArtem Bityutskiy
This patch unifies 'list_sort_test()' messages a bit and makes sure all of them start with the "list_sort_test:" prefix to make it obvious for users where the messages come from. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: improve errors handlingArtem Bityutskiy
The 'lib_sort()' test does not free memory if it fails, and it makes the kernel panic if it cannot allocate memory. This patch fixes the problem. This patch also changes several small things: o use 'list_add()' helper instead of adding manually o introduce temporary 'el1' variable to avoid ugly and unreadalbe "if" statement o make 'head' to be stack variable instead of 'kmalloc()'ed, which simplifies code a bit Overall, this patch is of clean-up type. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: use generic random32Artem Bityutskiy
Instead of using own pseudo-random generator, use generic linux 'random32()' function. Presumably, this should improve test coverage. At the same time, do the following changes: o Use shorter macro name for test list length o Do not use strange 'l_h' name for 'struct list_head' element, use 'list', because it is traditional name and thus, makes the code more obvious and readable. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/list_sort: test: use more reasonable printk levelsArtem Bityutskiy
I do not see any reason to use KERN_WARN for normal messages and KERN_EMERG for error messages in the lib_sort testing routine. Let's use more reasonable KERN_NORM and KERN_ERR levels. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/Kconfig.debug: add list_sort debugging switchArtem Bityutskiy
While hunting a non-existing bug in 'list_sort()', I've improved the 'list_sort_test()' function which tests the 'list_sort()' library call. Although at the end I found a bug in my code, but not in 'list_sort()', I think my clean-ups and improvements are worth merging because they make the test function better. This patch: Make the self-tests selectable via Kconfig rather than by manual enabling of DEBUG_LIST_SORT. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu_counter: add debugobj supportTejun Heo
All percpu counters are linked to a global list on initialization and removed from it on destruction. The list is walked during CPU up/down. If a percpu counter is freed without being properly destroyed, the system will oops only on the next CPU up/down making it pretty nasty to track down. This patch adds debugobj support for percpu counters so that such problems can be found easily. As percpu counters don't make sense on stack and can't be statically initialized, debugobj support is pretty simple. It's initialized and activated on counter initialization, and deactivatd and destroyed on counter destruction. With this patch applied, the bug fixed by commit 602586a83b719df0fbd94196a1359ed35aeb2df3 (shmem: put_super must percpu_counter_destroy) triggers the following warning on tmpfs unmount and the system won't oops on the next cpu up/down operation. ------------[ cut here ]------------ WARNING: at lib/debugobjects.c:259 debug_print_object+0x5c/0x70() Hardware name: Bochs ODEBUG: free active (active state 0) object type: percpu_counter Modules linked in: Pid: 3999, comm: umount Not tainted 2.6.36-rc2-work+ #5 Call Trace: [<ffffffff81083f7f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81084076>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813b45cc>] debug_print_object+0x5c/0x70 [<ffffffff813b50e5>] debug_check_no_obj_freed+0x125/0x210 [<ffffffff811577d3>] kfree+0xb3/0x2f0 [<ffffffff81132edd>] shmem_put_super+0x1d/0x30 [<ffffffff81162e96>] generic_shutdown_super+0x56/0xe0 [<ffffffff81162f86>] kill_anon_super+0x16/0x60 [<ffffffff81162ff7>] kill_litter_super+0x27/0x30 [<ffffffff81163295>] deactivate_locked_super+0x45/0x60 [<ffffffff81163cfa>] deactivate_super+0x4a/0x70 [<ffffffff8117d446>] mntput_no_expire+0x86/0xe0 [<ffffffff8117df7f>] sys_umount+0x6f/0x360 [<ffffffff8103f01b>] system_call_fastpath+0x16/0x1b ---[ end trace cce2a341ba3611a7 ]--- Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Thomas Gleixner <tglxlinutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26idr: fix idr_pre_get() locking descriptionNaohiro Aota
Despite the idr_pre_get() kernel-doc, there are some cases where you can call idr_pre_get() from within locked regions. Add a description for such cases. See also: http://lkml.org/lkml/2010/9/16/462 [akpm@linux-foundation.org: cleanups, grammatical fixes] Signed-off-by: Naohiro Aota <naota@elisp.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib/bitmap.c: use hex_to_bin()Andy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lib: fix scnprintf() if @size is == 0Changli Gao
scnprintf() should return 0 if @size is == 0. Update the comment for it, as @size is unsigned. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26vsprintf.c: use default pointer field size for "(null)" stringsJoe Perches
It might be nicer to align the output. For instance, ACPI messages sometimes have "(null)" pointers. $ dmesg | grep "(null)" -A 1 -B 1 [ 0.198733] ACPI: Dynamic OEM Table Load: [ 0.198745] ACPI: SSDT (null) 00239 (v02 PmRef Cpu0Ist 00003000 INTL 20051117) [ 0.199294] ACPI: SSDT 7f596e10 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117) [ 0.200708] ACPI: Dynamic OEM Table Load: [ 0.200721] ACPI: SSDT (null) 001C7 (v02 PmRef Cpu0Cst 00003001 INTL 20051117) [ 0.201950] ACPI: SSDT 7f597f10 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117) [ 0.203386] ACPI: Dynamic OEM Table Load: [ 0.203398] ACPI: SSDT (null) 000D0 (v02 PmRef Cpu1Ist 00003000 INTL 20051117) [ 0.203871] ACPI: SSDT 7f595f10 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117) [ 0.205301] ACPI: Dynamic OEM Table Load: [ 0.205315] ACPI: SSDT (null) 00083 (v02 PmRef Cpu1Cst 00003000 INTL 20051117) [akpm@linux-foundation.org: add code comment] Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu: fix list_head init bug in __percpu_counter_init()Masanori ITOH
WARNING: at lib/list_debug.c:26 __list_add+0x3f/0x81() Hardware name: Express5800/B120a [N8400-085] list_add corruption. next->prev should be prev (ffffffff81a7ea00), but was dead000000200200. (next=ffff88080b872d58). Modules linked in: aoe ipt_MASQUERADE iptable_nat nf_nat autofs4 sunrpc bridge 8021q garp stp llc ipv6 cpufreq_ondemand acpi_cpufreq freq_table dm_round_robin dm_multipath kvm_intel kvm uinput lpfc scsi_transport_fc igb ioatdma scsi_tgt i2c_i801 i2c_core dca iTCO_wdt iTCO_vendor_support pcspkr shpchp megaraid_sas [last unloaded: aoe] Pid: 54, comm: events/3 Tainted: G W 2.6.34-vanilla1 #1 Call Trace: [<ffffffff8104bd77>] warn_slowpath_common+0x7c/0x94 [<ffffffff8104bde6>] warn_slowpath_fmt+0x41/0x43 [<ffffffff8120fd2e>] __list_add+0x3f/0x81 [<ffffffff81212a12>] __percpu_counter_init+0x59/0x6b [<ffffffff810d8499>] bdi_init+0x118/0x17e [<ffffffff811f2c50>] blk_alloc_queue_node+0x79/0x143 [<ffffffff811f2d2b>] blk_alloc_queue+0x11/0x13 [<ffffffffa02a931d>] aoeblk_gdalloc+0x8e/0x1c9 [aoe] [<ffffffffa02aa655>] aoecmd_sleepwork+0x25/0xa8 [aoe] [<ffffffff8106186c>] worker_thread+0x1a9/0x237 [<ffffffffa02aa630>] ? aoecmd_sleepwork+0x0/0xa8 [aoe] [<ffffffff81065827>] ? autoremove_wake_function+0x0/0x39 [<ffffffff810616c3>] ? worker_thread+0x0/0x237 [<ffffffff810653ad>] kthread+0x7f/0x87 [<ffffffff8100aa24>] kernel_thread_helper+0x4/0x10 [<ffffffff8106532e>] ? kthread+0x0/0x87 [<ffffffff8100aa20>] ? kernel_thread_helper+0x0/0x10 It's because there is no initialization code for a list_head contained in the struct backing_dev_info under CONFIG_HOTPLUG_CPU, and the bug comes up when block device drivers calling blk_alloc_queue() are used. In case of me, I got them by using aoe. Signed-off-by: Masanori Itoh <itoumsn@nttdata.co.jp> Cc: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24Merge branch 'master' into for-linusPekka Enberg
Conflicts: include/linux/percpu.h mm/percpu.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
