path: root/lib
2006-03-30[PARISC] Remove obsolete CONFIG_DEBUG_IOREMAPHelge Deller
Remove CONFIG_DEBUG_IOREMAP, it's now obsolete and won't work anyway. Remove it from lib/KConfig since it was only available on parisc. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-27[PATCH] Don't make debugfs depend on DEBUG_KERNELJens Axboe
We use it generally now, at least blktrace isn't a specific debug kernel feature. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-26[PATCH] bitops: hweight() speedupAkinobu Mita
<linux@horizon.com> wrote: This is an extremely well-known technique. You can see a similar version that uses a multiply for the last few steps at http://graphics.stanford.edu/~seander/bithacks.html#CountBitsSetParallel whch refers to "Software Optimization Guide for AMD Athlon 64 and Opteron Processors" http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/25112.PDF It's section 8.6, "Efficient Implementation of Population-Count Function in 32-bit Mode", pages 179-180. It uses the name that I am more familiar with, "popcount" (population count), although "Hamming weight" also makes sense. Anyway, the proof of correctness proceeds as follows: b = a - ((a >> 1) & 0x55555555); c = (b & 0x33333333) + ((b >> 2) & 0x33333333); d = (c + (c >> 4)) & 0x0f0f0f0f; #if SLOW_MULTIPLY e = d + (d >> 8) f = e + (e >> 16); return f & 63; #else /* Useful if multiply takes at most 4 cycles */ return (d * 0x01010101) >> 24; #endif The input value a can be thought of as 32 1-bit fields each holding their own hamming weight. Now look at it as 16 2-bit fields. Each 2-bit field a1..a0 has the value 2*a1 + a0. This can be converted into the hamming weight of the 2-bit field a1+a0 by subtracting a1. That's what the (a >> 1) & mask subtraction does. Since there can be no borrows, you can just do it all at once. Enumerating the 4 possible cases: 0b00 = 0 -> 0 - 0 = 0 0b01 = 1 -> 1 - 0 = 1 0b10 = 2 -> 2 - 1 = 1 0b11 = 3 -> 3 - 1 = 2 The next step consists of breaking up b (made of 16 2-bir fields) into even and odd halves and adding them into 4-bit fields. Since the largest possible sum is 2+2 = 4, which will not fit into a 4-bit field, the 2-bit ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ "which will not fit into a 2-bit field" fields have to be masked before they are added. After this point, the masking can be delayed. Each 4-bit field holds a population count from 0..4, taking at most 3 bits. These numbers can be added without overflowing a 4-bit field, so we can compute c + (c >> 4), and only then mask off the unwanted bits. This produces d, a number of 4 8-bit fields, each in the range 0..8. From this point, we can shift and add d multiple times without overflowing an 8-bit field, and only do a final mask at the end. The number to mask with has to be at least 63 (so that 32 on't be truncated), but can also be 128 or 255. The x86 has a special encoding for signed immediate byte values -128..127, so the value of 255 is slower. On other processors, a special "sign extend byte" instruction might be faster. On a processor with fast integer multiplies (Athlon but not P4), you can reduce the final few serially dependent instructions to a single integer multiply. Consider d to be 3 8-bit values d3, d2, d1 and d0, each in the range 0..8. The multiply forms the partial products: d3 d2 d1 d0 d3 d2 d1 d0 d3 d2 d1 d0 + d3 d2 d1 d0 ---------------------- e3 e2 e1 e0 Where e3 = d3 + d2 + d1 + d0. e2, e1 and e0 obviously cannot generate any carries. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: hweight() related cleanupAkinobu Mita
By defining generic hweight*() routines - hweight64() will be defined on all architectures - hweight_long() will use architecture optimized hweight32() or hweight64() I found two possible cleanups by these reasons. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ↵Akinobu Mita
ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() This patch introduces the C-language equivalents of the functions below: int ext2_set_bit(int nr, volatile unsigned long *addr); int ext2_clear_bit(int nr, volatile unsigned long *addr); int ext2_test_bit(int nr, const volatile unsigned long *addr); unsigned long ext2_find_first_zero_bit(const unsigned long *addr, unsigned long size); unsinged long ext2_find_next_zero_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/ext2-non-atomic.h This code largely copied from: include/asm-powerpc/bitops.h include/asm-parisc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic hweight{64,32,16,8}()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: unsigned int hweight32(unsigned int w); unsigned int hweight16(unsigned int w); unsigned int hweight8(unsigned int w); unsigned long hweight64(__u64 w); In include/asm-generic/bitops/hweight.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic find_{next,first}{,_zero}_bit()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: unsigned logn find_next_bit(const unsigned long *addr, unsigned long size, unsigned long offset); unsigned long find_next_zero_bit(const unsigned long *addr, unsigned long size, unsigned long offset); unsigned long find_first_zero_bit(const unsigned long *addr, unsigned long size); unsigned long find_first_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/find.h This code largely copied from: arch/powerpc/lib/bitops.c Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] x86_64: Don't enable CONFIG_UNWIND_INFO by default for DEBUG_KERNELAndi Kleen
DEBUG_KERNEL is often enabled just for sysrq, but this doesn't mean the user wants more heavyweight debugging information. Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (21 commits) BUG_ON() Conversion in drivers/video/ BUG_ON() Conversion in drivers/parisc/ BUG_ON() Conversion in drivers/block/ BUG_ON() Conversion in sound/sparc/cs4231.c BUG_ON() Conversion in drivers/s390/block/dasd.c BUG_ON() Conversion in lib/swiotlb.c BUG_ON() Conversion in kernel/cpu.c BUG_ON() Conversion in ipc/msg.c BUG_ON() Conversion in block/elevator.c BUG_ON() Conversion in fs/coda/ BUG_ON() Conversion in fs/binfmt_elf_fdpic.c BUG_ON() Conversion in input/serio/hil_mlc.c BUG_ON() Conversion in md/dm-hw-handler.c BUG_ON() Conversion in md/bitmap.c The comment describing how MS_ASYNC works in msync.c is confusing rcu: undeclared variable used in documentation fix typos "wich" -> "which" typo patch for fs/ufs/super.c Fix simple typos tabify drivers/char/Makefile ...
2006-03-25[PATCH] cpumask: uninline any_online_cpu()Andrew Morton
text data bss dec hex filename before: 3605597 1363528 363328 5332453 515de5 vmlinux after: 3605295 1363612 363200 5332107 515c8b vmlinux 218 bytes saved. Also, optimise any_online_cpu() out of existence on CONFIG_SMP=n. This function seems inefficient. Can't we simply AND the two masks, then use find_first_bit()? Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] cpumask: uninline highest_possible_processor_id()Andrew Morton
Shrinks the only caller (net/bridge/netfilter/ebtables.c) by 174 bytes. Also, optimise highest_possible_processor_id() out of existence on CONFIG_SMP=n. Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] cpumask: uninline next_cpu()Andrew Morton
text data bss dec hex filename before: 3488027 1322496 360128 5170651 4ee5db vmlinux after: 3485112 1322480 359968 5167560 4ed9c8 vmlinux 2931 bytes saved Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] cpumask: uninline first_cpu()Andrew Morton
text data bss dec hex filename before: 3490577 1322408 360000 5172985 4eeef9 vmlinux after: 3488027 1322496 360128 5170651 4ee5db vmlinux Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] radix-tree documentation cleanupsJonathan Corbet
Documentation changes to help radix tree users avoid overrunning the tags array. RADIX_TREE_TAGS moves to linux/radix-tree.h and is now known as RADIX_TREE_MAX_TAGS (Nick Piggin's idea). Tag parameters are changed to unsigned, and some comments are updated. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] kconfig: clarify memory debug optionsAndrew Morton
The Kconfig text for CONFIG_DEBUG_SLAB and CONFIG_DEBUG_PAGEALLOC have always seemed a bit confusing. Change them to: CONFIG_DEBUG_SLAB: "Debug slab memory allocations" CONFIG_DEBUG_PAGEALLOC: "Debug page memory allocations" Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] slab: implement /proc/slab_allocatorsAl Viro
Implement /proc/slab_allocators. It produces output like: idr_layer_cache: 80 idr_pre_get+0x33/0x4e buffer_head: 2555 alloc_buffer_head+0x20/0x75 mm_struct: 9 mm_alloc+0x1e/0x42 mm_struct: 20 dup_mm+0x36/0x370 vm_area_struct: 384 dup_mm+0x18f/0x370 vm_area_struct: 151 do_mmap_pgoff+0x2e0/0x7c3 vm_area_struct: 1 split_vma+0x5a/0x10e vm_area_struct: 11 do_brk+0x206/0x2e2 vm_area_struct: 2 copy_vma+0xda/0x142 vm_area_struct: 9 setup_arg_pages+0x99/0x214 fs_cache: 8 copy_fs_struct+0x21/0x133 fs_cache: 29 copy_process+0xf38/0x10e3 files_cache: 30 alloc_files+0x1b/0xcf signal_cache: 81 copy_process+0xbaa/0x10e3 sighand_cache: 77 copy_process+0xe65/0x10e3 sighand_cache: 1 de_thread+0x4d/0x5f8 anon_vma: 241 anon_vma_prepare+0xd9/0xf3 size-2048: 1 add_sect_attrs+0x5f/0x145 size-2048: 2 journal_init_revoke+0x99/0x302 size-2048: 2 journal_init_revoke+0x137/0x302 size-2048: 2 journal_init_inode+0xf9/0x1c4 Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> DESC slab-leaks3-locking-fix EDESC From: Andrew Morton <akpm@osdl.org> Update for slab-remove-cachep-spinlock.patch Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24BUG_ON() Conversion in lib/swiotlb.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] CONFIG_UNWIND_INFOJan Beulich
As a foundation for reliable stack unwinding, this adds a config option (available to all architectures except IA64 and those where the module loader might have problems with the resulting relocations) to enable the generation of frame unwind information. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region restructuringPaul Jackson
Restructure the bitmap_*_region() operations, to avoid code duplication. Also reduces binary text size by about 100 bytes (ia64 arch). The original Bottomley bitmap_*_region patch added about 1000 bytes of compiled kernel text (ia64). The Mundt multiword extension added another 600 bytes, and this restructuring patch gets back about 100 bytes. But the real motivation was the reduced amount of duplicated code. Tested by Paul Mundt using <= BITS_PER_LONG as well as power of 2 aligned multiword spanning allocations. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region multiword spanning supportPaul Mundt
Add support to the lib/bitmap.c bitmap_*_region() routines For bitmap regions larger than one word (nbits > BITS_PER_LONG). This removes a BUG_ON() in lib bitmap. I have an updated store queue API for SH that is currently using this with relative success, and at first glance, it seems like this could be useful for x86 (arch/i386/kernel/pci-dma.c) as well. Particularly for anything using dma_declare_coherent_memory() on large areas and that attempts to allocate large buffers from that space. Paul Jackson also did some cleanup to this patch. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] bitmap: region cleanupPaul Jackson
Paul Mundt <lethal@linux-sh.org> says: This patch set implements a number of patches to clean up and restructure the bitmap region code, in addition to extending the interface to support multiword spanning allocations. The current implementation (before this patch set) is limited by only being able to allocate pages <= BITS_PER_LONG, as noted by the strategically positioned BUG_ON() at lib/bitmap.c:752: /* We don't do regions of pages > BITS_PER_LONG. The * algorithm would be a simple look for multiple zeros in the * array, but there's no driver today that needs this. If you * trip this BUG(), you get to code it... */ BUG_ON(pages > BITS_PER_LONG); As I seem to have been the first person to trigger this, the result ends up being the following patch set with the help of Paul Jackson. The final patch in the series eliminates quite a bit of code duplication, so the bitmap code size ends up being smaller than the current implementation as an added bonus. After these are applied, it should already be possible to do multiword allocations with dma_alloc_coherent() out of ranges established by dma_declare_coherent_memory() on x86 without having to change any of the code, and the SH store queue API will follow up on this as the other user that needs support for this. This patch: Some code cleanup on the lib/bitmap.c bitmap_*_region() routines: * spacing * variable names * comments Has no change to code function. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: kernel/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (78 commits) [PATCH] powerpc: Add FSL SEC node to documentation [PATCH] macintosh: tidy-up driver_register() return values [PATCH] powerpc: tidy-up of_register_driver()/driver_register() return values [PATCH] powerpc: via-pmu warning fix [PATCH] macintosh: cleanup the use of i2c headers [PATCH] powerpc: dont allow old RTC to be selected [PATCH] powerpc: make powerbook_sleep_grackle static [PATCH] powerpc: Fix warning in add_memory [PATCH] powerpc: update mailing list addresses [PATCH] powerpc: Remove calculation of io hole [PATCH] powerpc: iseries: Add bootargs to /chosen [PATCH] powerpc: iseries: Add /system-id, /model and /compatible [PATCH] powerpc: Add strne2a() to convert a string from EBCDIC to ASCII [PATCH] powerpc: iseries: Make more stuff static in platforms/iseries/mf.c [PATCH] powerpc: iseries: Remove pointless iSeries_(restart|power_off|halt) [PATCH] powerpc: iseries: mf related cleanups [PATCH] powerpc: Replace platform_is_lpar() with a firmware feature [PATCH] powerpc: trivial: Cleanup whitespace in cputable.h [PATCH] powerpc: Remove unused iommu_off logic from pSeries_init_early() [PATCH] powerpc: Unconfuse htab_bolt_mapping() callers ...
2006-03-22[PATCH] multiple exports of strpbrkAndrew Morton
Sam's tree includes a new check, which found that we're exporting strpbrk() multiple times. It seems that the convention is that this is exported from the arch files, so reove the lib/string.c export. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] kobject_add_dirJun'ichi Nomura
Adding kobject_add_dir() function which creates a subdirectory for a given kobject. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] Kobject: provide better warning messages when people do stupid thingsGreg Kroah-Hartman
Now that kobject_add() is used more than kobject_register() the kernel wasn't always letting people know that they were doing something wrong. This change fixes this. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] kref: avoid an atomic operation in kref_put()Eric Dumazet
Avoid an atomic operation in kref_put() when the last reference is dropped. On most platforms, atomic_read() is a plan read of the counter and involves no atomic at all. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] kobject: fix build error if CONFIG_SYSFS=nJun'ichi Nomura
Moving uevent_seqnum and uevent_helper to kobject_uevent.c because they are used even if CONFIG_SYSFS=n while kernel/ksysfs.c is built only if CONFIG_SYSFS=y, Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-24Merge ../powerpc-mergePaul Mackerras
2006-02-22Revert mount/umount uevent removalGreg Kroah-Hartman
This change reverts the 033b96fd30db52a710d97b06f87d16fc59fee0f1 commit from Kay Sievers that removed the mount/umount uevents from the kernel. Some older versions of HAL still depend on these events to detect when a new device has been mounted. These events are not correctly emitted, and are broken by design, and so, should not be relied upon by any future program. Instead, the /proc/mounts file should be polled to properly detect this kind of event. A feature-removal-schedule.txt entry has been added, noting when this interface will be removed from the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-18[PATCH] iomap_copy fallout (m68k)Al Viro
added __raw_writel(), sanitized include order in iomap_copy.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-16[PATCH] Fix over-zealous tag clearing in radix_tree_deleteNeilBrown
If a tag is set for a node being deleted from a radix_tree, then that tag gets cleared from the parent of the node, even if it is set for some siblings of the node begin deleted. This patch changes the logic to include a test for any_tag_set similar to the logic a little futher down. Care is taken to ensure that 'nr_cleared_tags' remains equals to the number of entries in the 'tags' array which are set to '0' (which means that this tag is not set in the tree below pathp->node, and should be cleared at pathp->node and possibly above. [ Nick says: "Linus FYI, I was able to modify the radix tree test harness to catch the bug and can no longer trigger it after the fix. Resulting code passes all other harness tests as well of course." ] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
2006-02-07[PATCH] Fix spinlock debugging delays to not time out too earlyIngo Molnar
The spinlock-debug wait-loop was using loops_per_jiffy to detect too long spinlock waits - but on fast CPUs this led to a way too fast timeout and false messages. The fix is to include a __delay(1) call in the loop, to correctly approximate the intended delay timeout of 1 second. The code assumes that every architecture implements __delay(1) to last around 1/(loops_per_jiffy*HZ) seconds. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-06[PATCH] Fix uevent buffer overflow in input layerBenjamin Herrenschmidt
The buffer used for kobject uevent is too small for some of the events generated by the input layer. Bump it to 2k. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] kobject: don't oops on null kobject.nameChuck Ebbert
kobject_get_path() will oops if one of the component names is NULL. Fix that by returning NULL instead of oopsing. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] kobject_add() must have a valid name in order to succeed.Greg Kroah-Hartman
So we might as well check to verify this, and let the user know that something is wrong if they didn't do it correctly, instead of oopsing later on in kobject_get_name() or somewhere else. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-03Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-02-03[PATCH] lib: Fix bug in int_sqrt() for 64 bit longsPeter Williams
The implementation of int_sqrt() assumes that longs have 32 bits. On systems that have 64 bit longs this will result in gross errors when the argument to the function is greater than 2^32 - 1 on such systems. I doubt whether any such use is currently made of int_sqrt() but the attached patch fixes the problem anyway. Signed-off-by: Peter Williams <pwil3058@bigpond.com.au> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-02[TEXTSEARCH]: Fix broken good shift array calculation in Boyer-MoorePablo Neira Ayuso
The current logic does not calculate correctly the good shift array: Let x be the pattern that is being searched. Let y be the block of data. The good shift array aligns the segment: x[i+1 ... m-1] = y[i+j+1 ... j+m-1] with its rightmost occurrence in x that fulfils x[i] neq y[i+j]. In previous version, the good shift array for the pattern ANPANMAN is: [1, 8, 3, 8, 8, 8, 8, 8] and should be: [1, 8, 3, 6, 6, 6, 6, 6] Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-01[PATCH] Introduce __iowrite32_copyBryan O'Sullivan
This arch-independent routine copies data to a memory-mapped I/O region, using 32-bit accesses. The naming is double-underscored to make it clear that it does not guarantee write ordering, nor does it perform a memory barrier afterwards; the kernel doc also explicitly states this. This style of access is required by some devices. This change also introduces include/linux/io.h, at Andrew's suggestion. It only has one occupant at the moment, but is a logical destination for oft-replicated contents of include/asm-*/{io,iomap}.h to migrate to. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] When CONFIG_CC_OPTIMIZE_FOR_SIZE, allow gcc4 to control inliningIngo Molnar
If optimizing for size (CONFIG_CC_OPTIMIZE_FOR_SIZE), allow gcc4 compilers to decide what to inline and what not - instead of the kernel forcing gcc to inline all the time. This requires several places that require to be inlined to be marked as such, previous patches in this series do that. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: Use function pointers to call DMA mapping functionsMuli Ben-Yehuda
AK: I hacked Muli's original patch a lot and there were a lot of changes - all bugs are probably to blame on me now. There were also some changes in the fall back behaviour for swiotlb - in particular it doesn't try to use GFP_DMA now anymore. Also all DMA mapping operations use the same core dma_alloc_coherent code with proper fallbacks now. And various other changes and cleanups. Known problems: iommu=force swiotlb=force together breaks needs more testing. This patch cleans up x86_64's DMA mapping dispatching code. Right now we have three possible IOMMU types: AGP GART, swiotlb and nommu, and in the future we will also have Xen's x86_64 swiotlb and other HW IOMMUs for x86_64. In order to support all of them cleanly, this patch: - introduces a struct dma_mapping_ops with function pointers for each of the DMA mapping operations of gart (AMD HW IOMMU), swiotlb (software IOMMU) and nommu (no IOMMU). - gets rid of: if (swiotlb) return swiotlb_xxx(); - PCI_DMA_BUS_IS_PHYS is now checked against the dma_ops being set This makes swiotlb faster by avoiding double copying in some cases. Signed-Off-By: Muli Ben-Yehuda <mulix@mulix.org> Signed-Off-By: Jon D. Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] let MAGIC_SYSRQ no longer depend on DEBUG_KERNELAdrian Bunk
I know several people using MAGIC_SYSRQ not for kernel debugging but for trying to do a halfway normal shutdown in case of problems. Since there's no technical reason why MAGIC_SYSRQ would have to depend on DEBUG_KERNEL, I'm therefore suggesting to drop this dependency. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] lib/zlib*: cleanupsAdrian Bunk
This patch contains the following possible cleanups: - #if 0 the following unused functions: - zlib_deflate/deflate.c: zlib_deflateSetDictionary - zlib_deflate/deflate.c: zlib_deflateParams - zlib_deflate/deflate.c: zlib_deflateCopy - zlib_inflate/infblock.c: zlib_inflate_set_dictionary - zlib_inflate/infblock.c: zlib_inflate_blocks_sync_point - zlib_inflate/inflate_sync.c: zlib_inflateSync - zlib_inflate/inflate_sync.c: zlib_inflateSyncPoint - remove the following unneeded EXPORT_SYMBOL's: - zlib_deflate/deflate_syms.c: zlib_deflateCopy - zlib_deflate/deflate_syms.c: zlib_deflateParams - zlib_inflate/inflate_syms.c: zlib_inflateSync - zlib_inflate/inflate_syms.c: zlib_inflateSyncPoint Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] printk levels for spinlock debugDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, debugging codeIngo Molnar
mutex implementation - add debugging code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] atomic: dec_and_lock use atomic primitivesNick Piggin
Convert atomic_dec_and_lock to use new atomic primitives. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cpuset: better bitmap remap defaultsPaul Jackson
Fix the default behaviour for the remap operators in bitmap, cpumask and nodemask. As previously submitted, the pair of masks <A, B> defined a map of the positions of the set bits in A to the corresponding bits in B. This is still true. The issue is how to map the other positions, corresponding to the unset (0) bits in A. As previously submitted, they were all mapped to the first set bit position in B, a constant map. When I tried to code per-vma mempolicy rebinding using these remap operators, I realized this was wrong. This patch changes the default to map all the unset bit positions in A to the same positions in B, the identity map. For example, if A has bits 4-7 set, and B has bits 9-12 set, then the map defined by the pair <A, B> maps each bit position in the first 32 bits as follows: 0 ==> 0 ... 3 ==> 3 4 ==> 9 ... 7 ==> 12 8 ==> 8 9 ==> 9 ... 31 ==> 31 This now corresponds to the typical behaviour desired when migrating pages and policies from one cpuset to another. The pages on nodes within the original cpuset, and the references in memory policies to nodes within the original cpuset, are migrated to the corresponding cpuset-relative nodes in the destination cpuset. Other pages and node references are left untouched. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
