Add a generic (unoptimized) implementation of checksum.c in pure C
for use by all architectures that cannot be bother with implementing
their own version.
Based on microblaze code by Michal Simek <monstr@monstr.eu>
Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com>
Now that we set up the slab allocator earlier, we can get rid of some
alloc_bootmem_cpumask_var() calls in boot code.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
This patch adds a loadable module that deliberately leaks memory. It
is used for testing various memory leaking scenarios.
This patch adds the Kconfig.debug and Makefile entries needed for
building kmemleak into the kernel.
* serial-from-alan: (79 commits)
moxa: prevent opening unavailable ports
imx: serial: use tty_encode_baud_rate to set true rate
imx: serial: add IrDA support to serial driver
imx: serial: use rational library function
lib: isolate rational fractions helper function
imx: serial: handle initialisation failure correctly
imx: serial: be sure to stop xmit upon shutdown
imx: serial: notify higher layers in case xmit IRQ was not called
imx: serial: fix one bit field type
imx: serial: fix whitespaces (no changes in functionality)
tty: use prepare/finish_wait
tty: remove sleep_on
sierra: driver interface blacklisting
sierra: driver urb handling improvements
tty: resolve some sierra breakage
timbuart: Fix the termios logic
serial: Added Timberdale UART driver
tty: Add URL for ttydev queue
devpts: unregister the file system on error
tty: Untangle termios and mm mutex dependencies
Provide a helper function to determine optimum numerator
denominator value pairs taking into account restricted
register size. Useful especially with PLL and other clock
configurations.
Signed-off-by: Oskar Schirmer <os@emlix.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
* 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
vsprintf: introduce %pf format specifier
printk: add support of hh length modifier for printk
* 'iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits)
amd-iommu: remove unnecessary "AMD IOMMU: " prefix
amd-iommu: detach device explicitly before attaching it to a new domain
amd-iommu: remove BUS_NOTIFY_BOUND_DRIVER handling
dma-debug: simplify logic in driver_filter()
dma-debug: disable/enable irqs only once in device_dma_allocations
dma-debug: use pr_* instead of printk(KERN_* ...)
dma-debug: code style fixes
dma-debug: comment style fixes
dma-debug: change hash_bucket_find from first-fit to best-fit
x86: enable GART-IOMMU only after setting up protection methods
amd_iommu: fix lock imbalance
dma-debug: add documentation for the driver filter
dma-debug: add dma_debug_driver kernel command line
dma-debug: add debugfs file for driver filter
dma-debug: add variables and checks for driver filter
dma-debug: fix debug_dma_sync_sg_for_cpu and debug_dma_sync_sg_for_device
dma-debug: use sg_dma_len accessor
dma-debug: use sg_dma_address accessor instead of using dma_address directly
amd-iommu: don't free dma adresses below 512MB with CONFIG_IOMMU_STRESS
amd-iommu: don't preallocate page tables with CONFIG_IOMMU_STRESS
So can get cpumask_var with cpumask_clear
This patch makes the driver_filter function more readable by
reorganizing the code. The removal of a code code block to an upper
indentation level makes hard-to-read line-wraps unnecessary.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
There is no need to disable/enable irqs on each loop iteration. Just
disable irqs for the whole time the loop runs.
The pr_* macros are shorter than the old printk(KERN_ ...) variant.
Change the dma-debug code to use the new macros and save a few
unnecessary line breaks. If lines don't break the source code can also
be grepped more easily.
This patch changes the recent updates to dma-debug to conform with
coding style guidelines of Linux and the -tip tree.
Last patch series introduced some new comment which does not fit the
Kernel comment style guidelines. Fix it with this patch.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/iommu
Merge reason: This branch was on an -rc5 base so pull almost-2.6.30
to resync with the latest upstream fixes and make sure
the combination works fine.
Some device drivers map the same physical address multiple times to a
dma address. Without an IOMMU this results in the same dma address being
put into the dma-debug hash multiple times. With a first-fit match in
hash_bucket_find() this function may return the wrong dma_debug_entry.
This can result in false positive warnings. This patch fixes it by
changing the first-fit behavior of hash_bucket_find() into a best-fit
algorithm.
Reported-by: Torsten Kaiser <just.for.lkml@googlemail.com>
Reported-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: lethal@linux-sh.org
Cc: just.for.lkml@googlemail.com
Cc: hancockrwd@gmail.com
Cc: jens.axboe@oracle.com
Cc: bharrosh@panasas.com
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: <stable@kernel.org>
LKML-Reference: <20090605104132.GE24836@amd.com>
dma-debug/2.6.31
This patch add the dma_debug_driver= boot parameter to enable the driver
filter for early boot.
This patch adds the dma-api/driver_filter file to debugfs. The root user
can write a driver name into this file to see only dma-api errors for
that particular driver in the kernel log. Writing an empty string to
that file disables the driver filter.
This patch adds the state variables for the driver filter and a function
to check if the filter is enabled and matches to the current device. The
check is built into the err_printk function.
DMA-mapping.txt says that debug_dma_sync_sg family must be called with
the _same_ one you passed into the dma_map_sg call, it should _NOT_ be
the 'count' value _returned_ from the dma_map_sg call.
debug_dma_sync_sg_for_cpu and debug_dma_sync_sg_for_device can't
handle this properly; they need to use the sg_mapped_ents in struct
dma_debug_entry as debug_dma_unmap_sg() does.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
debug_dma_map_sg() and debug_dma_unmap_sg() use length in struct
scatterlist while debug_dma_sync_sg_for_cpu() and
debug_dma_sync_sg_for_device() use dma_length. This causes bugs
warnings on some IOMMU implementations since these values are not
same; the length doesn't represent the dma length.
We always need to use sg_dma_len() accessor to get the dma length of a
scatterlist entry.
Architectures might not have dma_address in struct scatterlist (PARISC
doesn't). Directly accessing to dma_address in struct scatterlist is
wrong; we need to use sg_dma_address() accesssor instead.
This is basically a revert of commit 314eeac9 but now in a
fixed version.
Merge reason: core/iommu was on an .30-rc1 base,
update it to .30-rc5 to refresh.
On Tue, Apr 21, 2009 at 01:55:53PM +0200, Stefan Richter wrote:
> Robert P. J. Day wrote:
> > lib/Kconfig.debug: select PRINTK_DEBUG
> > should that perhaps refer to "DYNAMIC_PRINTK_DEBUG"? since there is
> > no such thing as a PRINTK_DEBUG Kconfig variable.
> Looks like a rudiment from an earlier version of Jason's "driver core:
> basic infrastructure for per-module dynamic debug messages",
> http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=346e15beb5343c2eb8216d820f2ed8f150822b08
> Search an LKML archive for '+#ifdef CONFIG_PRINTK_DEBUG'.
> Jason, should it be deleted or replaced by something?
We re-named 'DYNAMIC_PRINTK_DEBUG' to 'DYNAMIC_DEBUG' in 2.6.30....
'PRINTK_DEBUG' as pointed out never existed. So, it appears to be
extraneous, and should be removed. thanks for pointing it out.
Signed-off-by: Jason Baron <jbaron@redhat.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kernel/posix-cpu-timers.c: fix sparse warning
dma-debug: remove broken dma memory leak detection for 2.6.30
locking: Documentation: lockdep-design.txt, fix note of state bits
A printf format specifier which would allow us to print a pure
function name has been suggested by Andrew Morton a couple of
months ago.
The current %pF is very convenient to print a function symbol,
but often we only want to print the name of the function, without
its asm offset.
That's what %pf does in this patch. The lowecase f has been chosen
for its intuitive meaning of a 'weak kind of %pF'.
The support for this new format would be welcome by the tracing code
where the need to print pure function names is often needed. This is
also true for other parts of the kernel:
$ git-grep -E "kallsyms_lookup\(.+?\)"
arch/blackfin/kernel/traps.c: symname = kallsyms_lookup(address, &symsize, &offset, &modname, namebuf);
arch/powerpc/xmon/xmon.c: name = kallsyms_lookup(pc, &size, &offset, NULL, tmpstr);
arch/sh/kernel/cpu/sh5/unwind.c: sym = kallsyms_lookup(pc, NULL, &offset, NULL, namebuf);
arch/x86/kernel/ftrace.c: kallsyms_lookup((unsigned long) syscall, NULL, NULL, NULL, str);
kernel/kprobes.c: sym = kallsyms_lookup((unsigned long)p->addr, NULL,
kernel/lockdep.c: return kallsyms_lookup((unsigned long)key, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup((unsigned long)rec->ops->func, NULL, NULL, NULL, str);
kernel/trace/ftrace.c: kallsyms_lookup(rec->ip, NULL, NULL, &modname, str);
kernel/trace/ftrace.c: kallsyms_lookup(*ptr, NULL, NULL, NULL, str);
kernel/trace/trace_functions.c: kallsyms_lookup(ip, NULL, NULL, NULL, str);
kernel/trace/trace_output.c: kallsyms_lookup(address, NULL, NULL, NULL, str);
Changes in v2:
- Add the explanation of the %pf role for vsnprintf() and bstr_printf()
- Change the comments by dropping the "asm offset" notion and only
define the %pf against the actual function offset notion.
Cc: Zhaolei <zhaolei@cn.fujitsu.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <20090415154817.GC5989@nowhere>
The feature needs some more work because the notfier which is used to
check for pending allocations is called before the device drivers
->remove() function. Therefore this feature reports false positives.
A real fix for this issue is to introduce a new notifier event which sent
_after_ the driver has deinitialized itself. That will done for the next
kernel version.
[ Impact: reduce the scope of CONFIG_DMA_API_DEBUG=y checks ]
Cc: iommu@lists.linux-foundation.org
LKML-Reference: <1240576557-22442-1-git-send-email-joerg.roedel@amd.com>
Currently, although find_last_bit is EXPORTed, it is statically linked
with the kernel and is referenced only under CONFIG_SMP.
When CONFIG_SMP is undefined and find_last_bit is referenced only by
modules, linking fails with:
ERROR: "find_last_bit" [fs/nfs/nfs.ko] undefined!
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] update default configuration.
[S390] omit frame pointers on s390 when possible
[S390] Use tape_generic_offline directly.
[S390] /proc/stat idle field for idle cpus
[S390] appldata: avoid deadlock with appldata_mem
[S390] ipl: fix compile breakage
Always omit frame pointers on s390. They aren't too useful for the
kernel since we have already the kernel stack backchain which allows
us to walk the kernel stack.
So eleminate the extra code for frame pointers. Only allow the extra
code for the function tracer since the gcc compile options -pg and
-fomit-frame-pointer are incompatible.
Impact: fix not-so-critical but annoying bug
sg_miter_next() returns 0 sized mapping if there is an zero sized sg
entry in the list or at the end of each iteration. As the users
always check the ->length field, this bug shouldn't be critical other
than causing unnecessary iteration.
Fix it.
notice one system /proc/iomem some entries missed the name for pci_devices
it turns that dev->dev.kobj name is changed after device_add.
for pci code: via acpi_pci_root_driver.ops.add (aka acpi_pci_root_add)
==> pci_acpi_scan_root is used to scan pci bus/device, and at the same
time we read the resource for pci_dev in the pci_read_bases, we have
res->name = pci_name(pci_dev); pci_name is calling dev_name.
later via acpi_pci_root_driver.ops.start (aka acpi_pci_root_start) ==>
pci_bus_add_device to add all pci_dev in kobj tree. pci_bus_add_device
will call device_add.
actually in device_add
/* first, register with generic layer. */
error = kobject_add(&dev->kobj, dev->kobj.parent, "%s", dev_name(dev));
if (error)
goto Error;
will get one new name for that kobj, old name is freed.
[Impact: fix corrupted names in /proc/iomem ]
Users can read sysfs files, there is no reason they should not be
allowed to listen to uevents. This lets xorg and other userspace
programs properly get these messages without having to be root.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This reverts commit f520360d93cdc37de5d972dac4bf3bdef6a7f6a7.
Tetsuo Handa, running a kernel with CONFIG_DEBUG_PAGEALLOC=y and
CONFIG_UEVENT_HELPER_PATH=/sbin/hotplug, has been hitting RCU detected
CPU stalls: it's been spinning in the loop where do_execve() counts up
the args (but why wasn't fixup_exception working? dunno).
The recent change, switching kobject_uevent_env() from UMH_WAIT_EXEC
to UMH_NO_WAIT, is broken: the exec uses args on the local stack here,
and an env which is kfreed as soon as call_usermodehelper() returns.
It very much needs to wait for the exec to be done.
An alternative would be to keep the UMH_NO_WAIT, and complicate the code
to allocate and free these resources correctly? but no, as GregKH
pointed out when making the commit, CONFIG_UEVENT_HELPER_PATH="" is a
much better optimization - though some distros are still saying
/sbin/hotplug in their .config, yet with no such binary in their initrd
or their root.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Will Newton <will.newton@gmail.com>
dma_debug_entries
We use a static value for the number of dma_debug_entries. It can be
overwritten by a kernel command line option.
Some IOMMUs (e.g. GART) can't set an appropriate value by a kernel
command line option because they can't know such value until they
finish initializing up their hardware.
This patch adds dma_debug_resize_entries() enables IOMMUs to adjust
the number of dma_debug_entries anytime.
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: fujita.tomonori@lab.ntt.co.jp
Cc: akpm@linux-foundation.org
LKML-Reference: <20090415182234R.fujita.tomonori@lab.ntt.co.jp>
Impact: provide useful missing info for developers
Kernel taint can occur in several situations such as warnings,
load of prorietary or staging modules, bad page, etc...
But when such taint happens, a developer might still be working on
the kernel, expecting that lockdep is still enabled. But a taint
disables lockdep without ever warning about it.
Such a kernel behaviour doesn't really help for kernel development.
This patch adds this missing warning.
Since the taint is done most of the time after the main message that
explain the real source issue, it seems safe to warn about it inside
add_taint() so that it appears at last, without hurting the main
information.
v2: Use a generic helper to disable lockdep instead of an
open coded xchg().
LKML-Reference: <1239412638-6739-1-git-send-email-fweisbec@gmail.com>
Impact: new feature, extend vsprintf format strings
hh is used as length modifier for signed char or unsigned char.
It is supported by glibc, we add kernel support now.
Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: torvalds@linux-foundation.org
LKML-Reference: <49CC9739.30107@cn.fujitsu.com>
printk("%Q");
Output before patch: %QQ
Output after patch: %Q
LKML-Reference: <49CC97B6.7040809@cn.fujitsu.com>
Add a hwdev argument that is needed on some architectures
in order to access a per-device offset that is taken into
account when producing a physical address (also needed to
get from bus address to virtual address because the physical
address is an intermediate step).
Also make swiotlb_bus_to_virt weak so architectures can
override it.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: jeremy@goop.org
Cc: ian.campbell@citrix.com
LKML-Reference: <1239199761-22886-8-git-send-email-galak@kernel.crashing.org>
Right now both swiotlb_sync_single_range and swiotlb_sync_sg
were duplicating the code in swiotlb_sync_single. Just call it
instead. Also rearrange the sync_single code for readability.
Note that the swiotlb_sync_sg code was previously doing
a complicated comparison to determine if an addresses needed
to be unmapped where a simple is_swiotlb_buffer() call
would have sufficed.
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-7-git-send-email-galak@kernel.crashing.org>
Previously, swiotlb_unmap_page and swiotlb_unmap_sg were
duplicating very similar code. Refactor that code into a
new unmap_single and unmap_single use do_unmap_single.
Note that the swiotlb_unmap_sg code was previously doing
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-6-git-send-email-galak@kernel.crashing.org>
Some architectures require additional checking to determine
if a device can dma to an address and need to provide their
own address_needs_mapping..
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-5-git-send-email-galak@kernel.crashing.org>
The current code calls virt_to_phys() on address that might
be in highmem, which is bad. This wasn't needed, anyway, because
we already have the physical address we need.
Get rid of the now-unused virtual address as well.
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-4-git-send-email-galak@kernel.crashing.org>
Squash a build warning seen on 32-bit powerpc caused by
calling min() with 2 different types. Use min_t() instead.
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-3-git-send-email-galak@kernel.crashing.org>
Impact: cleanup
swiotlb_map/unmap_single are now swiotlb_map/unmap_page;
trivially change all the comments to reference new names.
Also, there were some comments that should have been
referring to just plain old map_single, not swiotlb_map_single;
fix those as well.
Also change a use of the word "pointer", when what is
referred to is actually a dma/physical address.
Cc: jeremy@goop.org
LKML-Reference: <1239199761-22886-2-git-send-email-galak@kernel.crashing.org>
* 'core/softlockup' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUP
softlockup: move 'one' to the softlockup section in sysctl.c
softlockup: ensure the task has been switched out once
softlockup: remove timestamp checking from hung_task
softlockup: convert read_lock in hung_task to rcu_read_lock
softlockup: check all tasks in hung_task
softlockup: remove unused definition for spawn_softlockup_task
softlockup: fix potential race in hung_task when resetting timeout
softlockup: fix to allow compiling with !DETECT_HUNG_TASK
softlockup: decouple hung tasks check from softlockup detection
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
