path: root/lib
2009-03-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits) [ARM] 5435/1: fix compile warning in sanity_check_meminfo() [ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx [ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0 [ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins imxfb: Fix TFT mode i.MX21/27: remove ifdef CONFIG_FB_IMX imxfb: add clock support mxc: add arch_reset() function clkdev: add possibility to get a clock based on the device name i.MX1: remove fb support from mach-imx [ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined Gemini: Add support for Teltonika RUT100 Gemini: gpiolib based GPIO support v2 MAINTAINERS: add myself as Gemini architecture maintainer ARM: Add Gemini architecture v3 [ARM] OMAP: Fix compile for omap2_init_common_hw() MAINTAINERS: Add myself as Faraday ARM core variant maintainer ARM: Add support for FA526 v2 [ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h [ARM] collie: fix two minor formatting nits ...
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-28Merge branch 'linus' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/sparc/kernel/time_64.c drivers/gpu/drm/drm_proc.c Manual merge to resolve build warning due to phys_addr_t type change on x86: drivers/gpu/drm/drm_info.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-03-26Merge branch 'sched-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) sched: Add comments to find_busiest_group() function sched: Refactor the power savings balance code sched: Optimize the !power_savings_balance during fbg() sched: Create a helper function to calculate imbalance sched: Create helper to calculate small_imbalance in fbg() sched: Create a helper function to calculate sched_domain stats for fbg() sched: Define structure to store the sched_domain statistics for fbg() sched: Create a helper function to calculate sched_group stats for fbg() sched: Define structure to store the sched_group statistics for fbg() sched: Fix indentations in find_busiest_group() using gotos sched: Simple helper functions for find_busiest_group() sched: remove unused fields from struct rq sched: jiffies not printed per CPU sched: small optimisation of can_migrate_task() sched: fix typos in documentation sched: add avg_overlap decay x86, sched_clock(): mark variables read-mostly sched: optimize ttwu vs group scheduling sched: TIF_NEED_RESCHED -> need_reshed() cleanup sched: don't rebalance if attached on NULL domain ...
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits) Dynamic debug: fix pr_fmt() build error Dynamic debug: allow simple quoting of words dynamic debug: update docs dynamic debug: combine dprintk and dynamic printk sysfs: fix some bin_vm_ops errors kobject: don't block for each kobject_uevent sysfs: only allow one scheduled removal callback per kobj Driver core: Fix device_move() vs. dpm list ordering, v2 Driver core: some cleanup on drivers/base/sys.c Driver core: implement uevent suppress in kobject vcs: hook sysfs devices into object lifetime instead of "binding" driver core: fix passing platform_data driver core: move platform_data into platform_device sysfs: don't block indefinitely for unmapped files. driver core: move knode_bus into private structure driver core: move knode_driver into private structure driver core: move klist_children into private structure driver core: create a private portion of struct device driver core: remove polling for driver_probe_done(v5) sysfs: reference sysfs_dirent from sysfs inodes ... Fixed conflicts in drivers/sh/maple/maple.c manually
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits) crypto: sha512-s390 - Add missing block size hwrng: timeriomem - Breaks an allyesconfig build on s390: nlattr: Fix build error with NET off crypto: testmgr - add zlib test crypto: zlib - New zlib crypto module, using pcomp crypto: testmgr - Add support for the pcomp interface crypto: compress - Add pcomp interface netlink: Move netlink attribute parsing support to lib crypto: Fix dead links hwrng: timeriomem - New driver crypto: chainiv - Use kcrypto_wq instead of keventd_wq crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq crypto: api - Use dedicated workqueue for crypto subsystem crypto: testmgr - Test skciphers with no IVs crypto: aead - Avoid infinite loop when nivaead fails selftest crypto: skcipher - Avoid infinite loop when cipher fails selftest crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention crypto: api - crypto_alg_mod_lookup either tested or untested crypto: amcc - Add crypt4xx driver crypto: ansi_cprng - Add maintainer ...
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-24Dynamic debug: allow simple quoting of wordsGreg Banks
Allow simple quoting of words in the dynamic debug control language. This allows more natural specification when using the control language to match against printk formats, e.g #echo -n 'format "Setting node for non-present cpu" +p' > /mnt/debugfs/dynamic_debug/control instead of #echo -n 'format Setting\040node\040for\040non-present\040cpu +p' > /mnt/debugfs/dynamic_debug/control Adjust the dynamic debug documention to describe that and provide a new example. Adjust the existing examples in the documentation to reflect the current whitespace escaping behaviour when reading the control file. Fix some minor documentation trailing whitespace. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: update docsJason Baron
updates the documentation for 'dynamic debug' feature. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24kobject: don't block for each kobject_ueventArjan van de Ven
Right now, the kobject_uevent code blocks for each uevent that's being generated, due to using (for hystoric reasons) UHM_WAIT_EXEC as flag to call_usermode_helper(). Specifically, the effect is that each uevent that is being sent causes the code to wake up keventd, then block until keventd has processed the work. Needless to say, this happens many times during the system boot. This patches changes that to UHN_NO_WAIT (brilliant name for a constant btw) so that we only schedule the work to fire the uevent message, but do not wait for keventd to process the work. This removes one of the bottlenecks during boot; each one of them is only a small effect, but the sum of them does add up. [Note, distros that need this are broken, they should be setting CONFIG_UEVENT_HELPER_PATH to "", that way this code path will never be excuted at all -- gregkh] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Driver core: implement uevent suppress in kobjectMing Lei
This patch implements uevent suppress in kobject and removes it from struct device, based on the following ideas: 1,Uevent sending should be one attribute of kobject, so suppressing it in kobject layer is more natural than in device layer. By this way, we can do it for other objects embedded with kobject. 2,It may save several bytes for each instance of struct device.(On my omap3(32bit ARM) based box, can save 8bytes per device object) This patch also introduces dev_set|get_uevent_suppress() helpers to set and query uevent_suppress attribute in case to help kobject as private part of struct device in future. [This version is against the latest driver-core patch set of Greg,please ignore the last version.] Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24driver core: get rid of struct device's bus_id string arrayKay Sievers
Now that all users of bus_id is gone, we can remove it from struct device. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-18Merge branches 'sched/cleanups' and 'linus' into sched/coreIngo Molnar
2009-03-13Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into develRussell King
Conflicts: arch/arm/mach-at91/gpio.c
2009-03-13Merge branches 'sched/clock', 'sched/urgent' and 'linus' into sched/coreIngo Molnar
2009-03-12bitmap: fix end condition in bitmap_find_free_regionLinus Torvalds
Guennadi Liakhovetski noticed that the end condition for the loop in bitmap_find_free_region() is wrong, and the "return if error" was also using the wrong conditional that would only trigger if the bitmap was an exact multiple of the allocation size, which is not necessarily the case with dma_alloc_from_coherent(). Such a failure would end up in bitmap_find_free_region() accessing beyond the end of the bitmap. Reported-by: Guennadi Liakhovetski <lg@denx.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-11nlattr: Fix build error with NET offHerbert Xu
We moved the netlink attribute support from net to lib in order for it to be available for general consumption. However, parts of the code (the bits that we don't need :) really depends on NET because the target object is sk_buff. This patch fixes this by wrapping them in CONFIG_NET. Some EXPORTs have been moved to make this work. Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-10idr: make idr_remove_all() do removal -before- free_layer()Paul E. McKenney
Fix a problem in the IDR system, where an idr_remove_all() hands a data element to call_rcu() (via free_layer()) before making that data element inaccessible to new readers. This is very bad, and results in readers still having a reference to this data element at the end of the grace period. Tests on large machines that concurrently map and unmap user-space memory within the same multithreaded process result in crashes within about five minutes. Applying this patch increases the kernel's longevity to the three-to-eight-hour range. There appear to be other similar problems in idr_get_empty_slot() and sub_remove(), but I fixed the easy one in idr_remove_all() first. It is therefore no surprise that failures still occur. Located-by: Milton Miller II <miltonm@austin.ibm.com> Tested-by: Milton Miller II <miltonm@austin.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-06sched: TIF_NEED_RESCHED -> need_reshed() cleanupLai Jiangshan
Impact: cleanup Use test_tsk_need_resched(), set_tsk_need_resched(), need_resched() instead of using TIF_NEED_RESCHED. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <49B10BA4.9070209@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04netlink: Move netlink attribute parsing support to libGeert Uytterhoeven
Netlink attribute parsing may be used even if CONFIG_NET is not set. Move it from net/netlink to lib and control its inclusion based on the new config symbol CONFIG_NLATTR, which is selected by CONFIG_NET. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04Merge branches 'x86/apic', 'x86/cpu', 'x86/fixmap', 'x86/mm', 'x86/sched', ↵Ingo Molnar
'x86/setup-lzma', 'x86/signal' and 'x86/urgent' into x86/core
2009-02-26Merge branches 'sched/cleanups', 'sched/urgent' and 'linus' into sched/coreIngo Molnar
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-20docsrc: use config instead of menuconfigRandy Dunlap
BUILD_DOCSRC should be controlled by "config" instead of "menuconfig". I have no idea how I managed to use "menuconfig" here. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-19bzip2/lzma: don't stop search at first unconfigured compressionAlain Knaff
Impact: Bugfix, avoids kernels which build but panic on boot Fix a bug in decompress.c : only scanned until the first non-configured compressor (with disastrous result especially if that was gzip.) Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-02-19[ARM] 5386/2: unwind: Add Makefile and Kconfig entries for ARM stack unwindingCatalin Marinas
This patch also makes the frame pointer default to y only if !ARM_UNWIND. LOCKDEP no longer selects FRAME_POINTER if ARM_UNWIND is enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-08Merge branches 'sched/rt' and 'sched/urgent' into sched/coreIngo Molnar
2009-02-05netlink: change return-value logic of netlink_broadcast()Pablo Neira Ayuso
Currently, netlink_broadcast() reports errors to the caller if no messages at all were delivered: 1) If, at least, one message has been delivered correctly, returns 0. 2) Otherwise, if no messages at all were delivered due to skb_clone() failure, return -ENOBUFS. 3) Otherwise, if there are no listeners, return -ESRCH. With this patch, the caller knows if the delivery of any of the messages to the listeners have failed: 1) If it fails to deliver any message (for whatever reason), return -ENOBUFS. 2) Otherwise, if all messages were delivered OK, returns 0. 3) Otherwise, if no listeners, return -ESRCH. In the current ctnetlink code and in Netfilter in general, we can add reliable logging and connection tracking event delivery by dropping the packets whose events were not successfully delivered over Netlink. Of course, this option would be settable via /proc as this approach reduces performance (in terms of filtered connections per seconds by a stateful firewall) but providing reliable logging and event delivery (for conntrackd) in return. This patch also changes some clients of netlink_broadcast() that may report ENOBUFS errors via printk. This error handling is not of any help. Instead, the userspace daemons that are listening to those netlink messages should resync themselves with the kernel-side if they hit ENOBUFS. BTW, netlink_broadcast() clients include those that call cn_netlink_send(), nlmsg_multicast() and genlmsg_multicast() since they internally call netlink_broadcast() and return its error value. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30cpumask: convert lib/smp_processor_id to new cpumask opsRusty Russell
Impact: fix debug_smp_processor_id() for CONFIG_CPUMASK_OFFSTACK=y The scheduler now uses the new cpumask API, which deals up to nr_cpumask_bits, whereas the API used NR_CPUS bits. If CONFIG_CPUMASK_OFFSTACK=y these two are not equal, so the top bits are undefined. Leading to bug 12518 "BUG: using smp_processor_id() in preemptible [00000000] code: dellWirelessCtl/..." The fix is simple: use the modern API in the check. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-26Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: add and use INIT_WORK_ON_STACK rcu: remove duplicate CONFIG_RCU_CPU_STALL_DETECTOR relay: fix lock imbalance in relay_late_setup_files oprofile: fix uninitialized use of struct op_entry rcu: move Kconfig menu softlock: fix false panic which can occur if softlockup_thresh is reduced rcu: add __cpuinit to rcu_init_percpu_data()
2009-01-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits) xen: unitialised return value in xenbus_write_transaction x86: fix section mismatch warning x86: unmask CPUID levels on Intel CPUs, fix x86: work around PAGE_KERNEL_WC not getting WC in iomap_atomic_prot_pfn. x86: use standard PIT frequency xen: handle highmem pages correctly when shrinking a domain x86, mm: fix pte_free() xen: actually release memory when shrinking domain x86: unmask CPUID levels on Intel CPUs x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h> x86: fix PTE corruption issue while mapping RAM using /dev/mem x86: mtrr fix debug boot parameter x86: fix page attribute corruption with cpa() Revert "x86: signal: change type of paramter for sys_rt_sigreturn()" x86: use early clobbers in usercopy*.c x86: remove kernel_physical_mapping_init() from init section fix: crash: IP: __bitmap_intersects+0x48/0x73 cpufreq: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write work_on_cpu: Use our own workqueue. work_on_cpu: don't try to get_online_cpus() in work_on_cpu. ...
2009-01-22Merge branch 'core/debugobjects' into core/urgentThomas Gleixner
2009-01-22rcu: remove duplicate CONFIG_RCU_CPU_STALL_DETECTORLai Jiangshan
Impact: remove the old CONFIG_RCU_CPU_STALL_DETECTOR tree_rcu introduce CONFIG_RCU_CPU_STALL_DETECTOR again. These two are the same exactly except: the old one "depends on CLASSIC_RCU" the new one "depends on CLASSIC_RCU || TREE_RCU" This patch remove the old one. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-18x86: define ARCH_WANT_FRAME_POINTERSJeff Mahoney
Commit da4276b8299a6544dc41ac2485d3ffca5811b3fb changed a dependency for FRAME_POINTER from X86 to ARCH_WANT_FRAME_POINTERS, but didn't actually define it. This patch adds the definition for ARCH_WANT_FRAME_POINTERS. Without it, FRAME_POINTER can't be enabled on x86. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-16sched: make plist a library facilityPeter Zijlstra
Ingo Molnar wrote: > here's a new build failure with tip/sched/rt: > > LD .tmp_vmlinux1 > kernel/built-in.o: In function `set_curr_task_rt': > sched.c:(.text+0x3675): undefined reference to `plist_del' > kernel/built-in.o: In function `pick_next_task_rt': > sched.c:(.text+0x37ce): undefined reference to `plist_del' > kernel/built-in.o: In function `enqueue_pushable_task': > sched.c:(.text+0x381c): undefined reference to `plist_del' Eliminate the plist library kconfig and make it available unconditionally. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-15lib/idr.c: use kmem_cache_zalloc() for the idr_layer cacheAndrew Morton
David points out that the idr_remove_all() function returns unused slabs to the kmem cache, but needs to zero them first or else they will be uninitialized upon next use. This causes crashes which have been observed in the firewire subsystem. He fixed this by zeroing the object before freeing it in idr_remove_all(). But we agree that simply removing the constructor and zeroing the object at allocation time is simpler than relying upon slab constructor machinery and might even be faster. This problem was introduced by "idr: make idr_remove rcu-safe" (commit cf481c20c476ad2c0febdace9ce23f5a4db19582), which was first released in 2.6.27. There are no known codesites which trigger this bug in 2.6.27 or 2.6.28. The post-2.6.28 firewire changes are the only known triggerer. There might of course be not-yet-discovered triggerers in 2.6.27 and 2.6.28, and there might be out-of-tree triggerers which are added to those kernel versions. I'll let the -stable guys decide whether they want to backport this fix. Reported-by: David Moore <dcm@acm.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Paul E. McKenney <paulmck@us.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Kristian Hgsberg <krh@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15idr: fix wrong kernel-docLi Zefan
idr_get_new_above() and ida_get_new_above() return an id in the range of @staring_id ... 0x7fffffff, not 0 ... 0x7fffffff. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12bzip2/lzma: comprehensible error messages for missing decompressorH. Peter Anvin
Instead of failing to identify a compressed image with a decompressor that we don't have compiled in, identify it and fail with a comprehensible panic message. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-10Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86: fix section mismatch warnings in mcheck/mce_amd_64.c x86: offer frame pointers in all build modes x86: remove duplicated #include's x86: k8 numa register active regions later x86: update Alan Cox's email addresses x86: rename all fields of mpc_table mpc_X to X x86: rename all fields of mpc_oemtable oem_X to X x86: rename all fields of mpc_bus mpc_X to X x86: rename all fields of mpc_cpu mpc_X to X x86: rename all fields of mpc_intsrc mpc_X to X x86: rename all fields of mpc_lintsrc mpc_X to X x86: rename all fields of mpc_iopic mpc_X to X x86: irqinit_64.c init_ISA_irqs should be static Documentation/x86/boot.txt: payload length was changed to payload_length x86: setup_percpu.c fix style problems x86: irqinit_64.c fix style problems x86: irqinit_32.c fix style problems x86: i8259.c fix style problems x86: irq_32.c fix style problems x86: ioport.c fix style problems ...
2009-01-10rbtree: add const qualifier to some functionsArtem Bityutskiy
The 'rb_first()', 'rb_last()', 'rb_next()' and 'rb_prev()' calls take a pointer to an RB node or RB root. They do not change the pointed objects, so add a 'const' qualifier in order to make life of the users of these functions easier. Indeed, if I have my own constant pointer &const struct my_type *p, and I call 'rb_next(&p->rb)', I get a GCC warning: warning: passing argument 1 of ‘rb_next’ discards qualifiers from pointer target type Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10Merge branch 'linus' into x86/setup-lzmaIngo Molnar
Conflicts: init/do_mounts_rd.c
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08bzip2/lzma: centralize format detectionH. Peter Anvin
Centralize the compression format detection to a common routine in the lib directory, and use it for both initramfs and initrd. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-08bzip2/lzma: fix decompress_inflate.c vs multi-block-with-embedded-filenameAlain Knaff
Impact: Bug fix Fix gunzip uncompression, so that it also works with files with embedded filenames that are larger than one block. Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-08bzip2/lzma: fix constant in decompress_inflateH. Peter Anvin
Impact: Cleanup Fix constant 0x8100 /* 32K */; according to Alain the value 0x8100 was left over test code to test misalignment, the correct value is indeed 0x8000 == 32K. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-08generic swap(): lib/sort.c: rename swap to swap_funcWu Fengguang
This is to avoid name clashes for the introduction of a global swap() macro. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
