path: root/lib
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-devel * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-devel: (62 commits) sched: build fix sched: better rt-group documentation sched: features fix sched: /debug/sched_features sched: add SCHED_FEAT_DEADLINE sched: debug: show a weight tree sched: fair: weight calculations sched: fair-group: de-couple load-balancing from the rb-trees sched: fair-group scheduling vs latency sched: rt-group: optimize dequeue_rt_stack sched: debug: add some debug code to handle the full hierarchy sched: fair-group: SMP-nice for group scheduling sched, cpuset: customize sched domains, core sched, cpuset: customize sched domains, docs sched: prepatory code movement sched: rt: multi level group constraints sched: task_group hierarchy sched: fix the task_group hierarchy for UID grouping sched: allow the group scheduler to have multiple levels sched: mix tasks and groups ...
2008-04-19Kobject: Replace list_for_each() with list_for_each_entry().Robert P. J. Day
Use the more concise list_for_each_entry(), which allows for the deletion of the to_kobj() routine at the same time. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19kobject: catch kobjects that are not initializedGreg Kroah-Hartman
Add warnings to kobject_put() to catch kobjects that are cleaned up but were never initialized to begin with. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19cpumask: add cpumask_scnprintf_len functionMike Travis
Add a new function cpumask_scnprintf_len() to return the number of characters needed to display "len" cpumask bits. The current method of allocating NR_CPUS bytes is incorrect as what's really needed is 9 characters per 32-bit word of cpumask bits (8 hex digits plus the seperator [','] or the terminating NULL.) This function provides the caller the means to allocate the correct string length. Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19[PATCH] r/o bind mounts: debugging for missed callsDave Hansen
There have been a few oopses caused by 'struct file's with NULL f_vfsmnts. There was also a set of potentially missed mnt_want_write()s from dentry_open() calls. This patch provides a very simple debugging framework to catch these kinds of bugs. It will WARN_ON() them, but should stop us from having any oopses or mnt_writer count imbalances. I'm quite convinced that this is a good thing because it found bugs in the stuff I was working on as soon as I wrote it. [hch: made it conditional on a debug option. But it's still a little bit too ugly] [hch: merged forced remount r/o fix from Dave and akpm's fix for the fix] Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18lib: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
reed_solomon doesn't use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (137 commits) [SCSI] iscsi: bidi support for iscsi_tcp [SCSI] iscsi: bidi support at the generic libiscsi level [SCSI] iscsi: extended cdb support [SCSI] zfcp: Fix error handling for blocked unit for send FCP command [SCSI] zfcp: Remove zfcp_erp_wait from slave destory handler to fix deadlock [SCSI] zfcp: fix 31 bit compile warnings [SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commands [SCSI] bsg: remove minor in struct bsg_device [SCSI] bsg: use better helper list functions [SCSI] bsg: replace kobject_get with blk_get_queue [SCSI] bsg: takes a ref to struct device in fops->open [SCSI] qla1280: remove version check [SCSI] libsas: fix endianness bug in sas_ata [SCSI] zfcp: fix compiler warning caused by poking inside new semaphore (linux-next) [SCSI] aacraid: Do not describe check_reset parameter with its value [SCSI] aacraid: Fix down_interruptible() to check the return value [SCSI] sun3_scsi_vme: add MODULE_LICENSE [SCSI] st: rename flush_write_buffer() [SCSI] tgt: use KMEM_CACHE macro [SCSI] initio: fix big endian problems for auto request sense ...
2008-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (43 commits) firewire: cleanups firewire: fix synchronization of gap counts firewire: wait until PHY configuration packet was transmitted (fix bus reset loop) firewire: remove unused struct member firewire: use bitwise and to get reg in handle_registers firewire: replace more hex values with defined csr constants firewire: reread config ROM when device reset the bus firewire: replace static ROM cache by allocated cache firewire: fw-ohci: work around generation bug in TI controllers (fix AV/C and more) firewire: fw-ohci: extend logging of bus generations and node ID firewire: fw-ohci: conditionally log busReset interrupts firewire: fw-ohci: don't append to AT context when it's not active firewire: fw-ohci: log regAccessFail events firewire: fw-ohci: make sure HCControl register LPS bit is set firewire: fw-ohci: missing PPC PMac feature calls in failure path firewire: fw-ohci: untangle a mixed unsigned/signed expression firewire: debug interrupt events firewire: fw-ohci: catch self_id_count == 0 firewire: fw-ohci: add self ID error check firewire: fw-ohci: refactor probe, remove, suspend, resume ...
2008-04-18firewire: fw-ohci: add option for remote debuggingStefan Richter
This way firewire-ohci can be used for remote debugging like ohci1394. Version with amendment from Fri, 11 Apr 2008 00:08:08 +0200. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Bernhard Kaindl <bk@suse.de>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdb: kgdb: always use icache flush for sw breakpoints kgdb: fix SMP NMI kgdb_handle_exception exit race kgdb: documentation fixes kgdb: allow static kgdbts boot configuration kgdb: add documentation kgdb: Kconfig fix kgdb: add kgdb internal test suite kgdb: fix several kgdb regressions kgdb: kgdboc pl011 I/O module kgdb: fix optional arch functions and probe_kernel_* kgdb: add x86 HW breakpoints kgdb: print breakpoint removed on exception kgdb: clocksource watchdog kgdb: fix NMI hangs kgdb: fix kgdboc dynamic module configuration kgdb: document parameters x86: kgdb support consoles: polling support, kgdboc kgdb: core uaccess: add probe_kernel_write()
2008-04-18Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Remove DEBUG_SEMAPHORE from Kconfig Improve semaphore documentation Simplify semaphore implementation Add down_timeout and change ACPI to use it Introduce down_killable() Generic semaphore implementation Add semaphore.h to kernel_lock.c Fix quota.h includes
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-17kgdb: allow static kgdbts boot configurationJason Wessel
This patch adds in the ability to compile the kgdb internal test string into the kernel so as to run the tests at boot without changing the kernel boot arguments. This patch also changes all the error paths to invoke WARN_ON(1) which will emit the line number of the file and dump the kernel stack when an error occurs. You can disable the tests in a kernel that is built this way using "kgdbts=" Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: add kgdb internal test suiteJason Wessel
This patch adds regression tests for testing the kgdb core and arch specific implementation. The kgdb test suite is designed to be built into the kernel and not as a module because it uses a number of low level kernel and kgdb primitives which should not be exported externally. The kgdb test suite is designed as a KGDB I/O module which simulates the communications that a debugger would have with kgdb. The tests are broken up in to a line by line and referenced here as a "get" which is kgdb requesting input and "put" which is kgdb sending a response. The kgdb suite can be invoked from the kernel command line arguments system or executed dynamically at run time. The test suite uses the variable "kgdbts" to obtain the information about which tests to run and to configure the verbosity level. The following are the various characters you can use with the kgdbts= line: When using the "kgdbts=" you only choose one of the following core test types: A = Run all the core tests silently V1 = Run all the core tests with minimal output V2 = Run all the core tests in debug mode You can also specify optional tests: N## = Go to sleep with interrupts of for ## seconds to test the HW NMI watchdog F## = Break at do_fork for ## iterations S## = Break at sys_open for ## iterations NOTE: that the do_fork and sys_open tests are mutually exclusive. To invoke the kgdb test suite from boot you use a kernel start argument as follows: kgdbts=V1 kgdbwait Or if you wanted to perform the NMI test for 6 seconds and do_fork test for 100 forks, you could use: kgdbts=V1N6F100 kgdbwait The test suite can also be invoked at run time with: echo kgdbts=V1N6F100 > /sys/module/kgdbts/parameters/kgdbts Or as another example: echo kgdbts=V2 > /sys/module/kgdbts/parameters/kgdbts When developing a new kgdb arch specific implementation or using these tests for the purpose of regression testing, several invocations are required. 1) Boot with the test suite enabled by using the kernel arguments "kgdbts=V1F100 kgdbwait" ## If kgdb arch specific implementation has NMI use "kgdbts=V1N6F100 2) After the system boot run the basic test. echo kgdbts=V1 > /sys/module/kgdbts/parameters/kgdbts 3) Run the concurrency tests. It is best to use n+1 while loops where n is the number of cpus you have in your system. The example below uses only two loops. ## This tests break points on sys_open while [ 1 ] ; do find / > /dev/null 2>&1 ; done & while [ 1 ] ; do find / > /dev/null 2>&1 ; done & echo kgdbts=V1S10000 > /sys/module/kgdbts/parameters/kgdbts fg # and hit control-c fg # and hit control-c ## This tests break points on do_fork while [ 1 ] ; do date > /dev/null ; done & while [ 1 ] ; do date > /dev/null ; done & echo kgdbts=V1F1000 > /sys/module/kgdbts/parameters/kgdbts fg # and hit control-c Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17kgdb: coreJason Wessel
kgdb core code. Handles the protocol and the arch details. [ mingo@elte.hu: heavily modified, simplified and cleaned up. ] [ xemul@openvz.org: use find_task_by_pid_ns ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17Remove DEBUG_SEMAPHORE from KconfigMatthew Wilcox
Alpha and FRV mutexes had an option to print lots of debugging messages in their semaphore implementation. This feature has not been carried over to the generic semaphores, so remove the stale Kconfig option. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Add semaphore.h to kernel_lock.cMatthew Wilcox
kernel_lock.c uses DECLARE_MUTEX, up() and down() without explicitly including asm/semaphore.h. This is fragile and leaves it vulnerable to breakage during header reorganisations. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-15[LMB] Restructure allocation loops to avoid unsigned underflowPaul Mackerras
There is a potential bug in __lmb_alloc_base where we subtract `size' from the base address of a reserved region without checking whether the subtraction could wrap around and produce a very large unsigned value. In fact it probably isn't possible to hit the bug in practice since it would only occur in the situation where we can't satisfy the allocation request and there is a reserved region starting at 0. This fixes the potential bug by breaking out of the loop when we get to the point where the base of the reserved region is less than the size requested. This also restructures the loop to be a bit easier to follow. The same logic got copied into lmb_alloc_nid_unreserved, so this makes a similar change there. Here the bug is more likely to be hit because the outer loop (in lmb_alloc_nid) goes through the memory regions in increasing order rather than decreasing order as __lmb_alloc_base does, and we are therefore more likely to hit the case where we are testing against a reserved region with a base address of 0. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-15[LMB] Fix some whitespace and other formatting issues, use pr_debugPaul Mackerras
This makes no semantic changes. It fixes the whitespace and formatting a bit, gets rid of a local DBG macro and uses the equivalent pr_debug instead, and restructures one while loop that had a function call and assignment in the condition to be a bit more readable. Some comments about functions being called with relocation disabled were also removed as they would just be confusing to most readers now that the code is in lib/. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-15[LMB] Add lmb_alloc_nid()David S. Miller
A variant of lmb_alloc() that tries to allocate memory on a specified NUMA node 'nid' but falls back to normal lmb_alloc() if that fails. The caller provides a 'nid_range' function pointer which assists the allocator. It is given args 'start', 'end', and pointer to integer 'this_nid'. It places at 'this_nid' the NUMA node id that corresponds to 'start', and returns the end address within 'start' to 'end' at which memory assosciated with 'nid' ends. This callback allows a platform to use lmb_alloc_nid() in just about any context, even ones in which early_pfn_to_nid() might not be working yet. This function will be used by the NUMA setup code on sparc64, and also it can be used by powerpc, replacing it's hand crafted "careful_allocation()" function in arch/powerpc/mm/numa.c If x86 ever converts it's NUMA support over to using the LMB helpers, it can use this too as it has something entirely similar. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-14slub: Deal with config variable dependenciesChristoph Lameter
count_partial() is used by both slabinfo and the sysfs proc support. Move the function directly before the beginning of the sysfs code so that it can be easily found. Rework the preprocessor conditional to take into account that slub sysfs support depends on CONFIG_SYSFS *and* CONFIG_SLUB_DEBUG. Make CONFIG_SLUB_STATS depend on CONFIG_SLUB_DEBUG and CONFIG_SYSFS. There is no point of keeping statistics if no one can restrive them. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-04-14Merge branch 'linux-2.6'Paul Mackerras
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-10lzo: fix typo in decompressorHarvey Harrison
Shift of a LE value seems strange, probably meant to shift the cpu-order variable as in the prvious section of the switch statement. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-07[SCSI] block: add sg buffer copy helper functionsFUJITA Tomonori
This patch adds new three helper functions to copy data between an SG list and a linear buffer. - sg_copy_from_buffer copies data from linear buffer to an SG list - sg_copy_to_buffer copies data from an SG list to a linear buffer When the APIs copy data from a linear buffer to an SG list, flush_kernel_dcache_page is called. It's not necessary for everyone but it's a no-op on most architectures and in general the API is not used in performance critical path. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-03Merge branch 'master' of ↵David S. Miller
2008-04-03[NET]: srandom32 fixes for networking v2Andi Kleen
- Let it update the state of all CPUs. The network stack goes into pains to feed the current IP addresses in, but it is not very effective if that is only done for some random CPU instead of all. So change it to feed bits into all CPUs. I decided to do that lockless because well somewhat random results are ok. v2: Drop rename so that this patch doesn't depend on x86 maintainers Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[NETNS]: Declare init_net even without CONFIG_NET defined.Denis V. Lunev
This does not look good, but there is no other choice. The compilation without CONFIG_NET is broken and can not be fixed with ease. After that there is no need for the following commits: 1567ca7eec7664b8be3b07755ac59dc1b1ec76cb 3edf8fa5ccf10688a9280b5cbca8ed3947c42866 2d38f9a4f8d2ebdc799f03eecf82345825495711 Revert them. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-30fix uevent action-string regressionMark Lord
Mark Lord wrote: > > On boot, syslog is flooded with "uevent: unsupported action-string;" messages. .. > Mar 28 14:43:29 shrimp kernel: tty ptyqd: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyqe: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyqf: uevent: unsupported > action-string; this will be ignored in a future kernel version > Mar 28 14:43:29 shrimp kernel: tty ptyr0: uevent: unsupported > action-string; this will be ignored in a future kernel version .. These messages are a regression compared with 2.6.24, which did not flood the syslog with them. The actual underlying problem was introduced in 2.6.23, when somebody made the string parsing no longer accept nul-terminated strings as a valid input to store_uevent(). Eg. "add\0" was valid prior to 2.6.23, where the code regressed to require "add" without the '\0'. This patch fixes the 2.6.23 / 2.6.24 regressions, by having the code once again tolerate the trailing '\0', if present. According to GregKH, this mainly affects older Ubuntu systems, such as the one I have here that requires this fix. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28[LIB]: Drop the pcounter itself.Pavel Emelyanov
The knock-out. The pcounter abstraction is not used any longer in the kernel. Not sure whether this should go via netdev tree, but as far as I remember it was added via this one, and besides Eric thinks that Andrew shouldn't mind this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27[NETNS]: Do no include NET related headers if CONFIG_NET is not set.Denis V. Lunev
This fix broken compilation for 'allnoconfig'. This was introduced by Introduced by commit 1218854afa6f659be90b748cf1bc7badee954a35 ("[NET] NETNS: Omit seq_net_private->net without CONFIG_NET_NS.") Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26Merge branch 'linux-2.6'Paul Mackerras
2008-03-24x86-32: Pass the full resource data to ioremap()Linus Torvalds
It appears that 64-bit PCI resources cannot possibly ever have worked on x86-32 even when the RESOURCES_64BIT config option was set, because any driver that tried to [pci_]ioremap() the resource would have been unable to do so because the high 32 bits would have been silently dropped on the floor by the ioremap() routines that only used "unsigned long". Change them to use "resource_size_t" instead, which properly encodes the whole 64-bit resource data if RESOURCES_64BIT is enabled. Acked-by: H. Peter Anvin <hpa@kernel.org> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-17devres: implement pcim_iomap_regions_request_all()Tejun Heo
Some drivers need to reserve all PCI BARs to prevent other drivers misusing unoccupied BARs. pcim_iomap_regions_request_all() requests all BARs and iomap specified BARs. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-13avoid endless loops in lib/swiotlb.cJan Beulich
Commit 681cc5cd3efbeafca6386114070e0bfb5012e249 ("iommu sg merging: swiotlb: respect the segment boundary limits") introduced two possibilities for entering an endless loop in lib/swiotlb.c: - if max_slots is zero (possible if mask is ~0UL) - if the number of slots requested fits into a swiotlb segment, but is too large for the part of a segment which remains after considering offset_slots This fixes them Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-13Merge branch 'linux-2.6'Paul Mackerras
2008-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: debugfs: fix sparse warnings Driver core: Fix cleanup when failing device_add(). driver core: Remove dpm_sysfs_remove() from error path of device_add() PM: fix new mutex-locking bug in the PM core PM: Do not acquire device semaphores upfront during suspend kobject: properly initialize ksets sysfs: CONFIG_SYSFS_DEPRECATED fix driver core: fix up Kconfig text for CONFIG_SYSFS_DEPRECATED
2008-03-04iommu: export iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary is used internally in the IOMMU helper (lib/iommu-helper.c), a primitive function that judges whether a memory area spans LLD's segment boundary or not. It's difficult to convert some IOMMUs to use the IOMMU helper but iommu_is_span_boundary is still useful for them. So this patch exports it. This is needed for the parisc iommu fixes. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04kobject: properly initialize ksetsGreg Kroah-Hartman
kset_initialize was calling kobject_init_internal() which didn't initialize the kobject as well as kobject_init() was. So have kobject_init() call kobject_init_internal() and move the logic to initalize the kobject there. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/lmb-2.6Paul Mackerras
2008-02-23lib/vsprintf.c: fix bug omitting minus sign of numbers (module_param)Hoang-Nam Nguyen
lib/vsprintf.c: Fix bug omitting minus sign of numbers (module_param) Signed-off-by: Hoang-Nam Nguyen <hnguyen@de.ibm.com> Cc: Yi Yang <yi.y.yang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23make LKDTM depend on BLOCKChris Snook
Make LKDTM depend on BLOCK to prevent build failures with certain configs. Signed-off-by: Chris Snook <csnook@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-19[LMB]: Fix lmb_add_region if region should be added at the headKumar Gala
We introduced a bug in fixing lmb_add_region to handle an initial region being non-zero. Before that fix it was impossible to insert a region at the head of the list since the first region always started at zero. Now that its possible for the first region to be non-zero we need to check to see if the new region should be added at the head and if so actually add it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-15kbuild: explain why DEBUG_SECTION_MISMATCH is UNDEFINEDSam Ravnborg
We started to see patches enabling this - so explain why it is disabled and the condition to enable it again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-13[LMB]: Make lmb support large physical addressingBecky Bruce
Convert the lmb code to use u64 instead of unsigned long for physical addresses and sizes. This is needed to support large amounts of RAM on 32-bit systems that support 36-bit physical addressing. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-13[LMB]: Fix initial lmb add region with a non-zero baseKumar Gala
If we add to an empty lmb region with a non-zero base we will not coalesce the number of regions down to one. This causes problems on ppc32 for the memory region as its assumed to only have one region. We can fix this be easily specially casing the initial add to just replace the dummy region. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
