upstream commit: 4f032ac4122a77dbabf7a24b2739b2790448180f
Fix slab corruption caused by alloc_cpumask_var_node() overwriting the
tail end of an off-stack cpumask.
The function zeros out cpumask bits beyond the last possible cpu. The
starting point for zeroing should be the beginning of the mask offset by a
byte count derived from the number of possible cpus. The offset was
calculated in bits instead of bytes. This resulted in overwriting the end
of the cpumask.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Acked-by: Mike Travis <travis.sgi.com>
Cc: <stable@kernel.org> [2.6.29.x]
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Guennadi Liakhovetski noticed that the end condition for the loop in
bitmap_find_free_region() is wrong, and the "return if error" was also
using the wrong conditional that would only trigger if the bitmap was an
exact multiple of the allocation size, which is not necessarily the case
with dma_alloc_from_coherent().
Such a failure would end up in bitmap_find_free_region() accessing
beyond the end of the bitmap.
Reported-by: Guennadi Liakhovetski <lg@denx.de>
Fix a problem in the IDR system, where an idr_remove_all() hands a data
element to call_rcu() (via free_layer()) before making that data element
inaccessible to new readers. This is very bad, and results in readers
still having a reference to this data element at the end of the grace
period.
Tests on large machines that concurrently map and unmap user-space memory
within the same multithreaded process result in crashes within about five
minutes. Applying this patch increases the kernel's longevity to the
three-to-eight-hour range.
There appear to be other similar problems in idr_get_empty_slot() and
sub_remove(), but I fixed the easy one in idr_remove_all() first. It is
therefore no surprise that failures still occur.
Located-by: Milton Miller II <miltonm@austin.ibm.com>
Tested-by: Milton Miller II <miltonm@austin.ibm.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
BUILD_DOCSRC should be controlled by "config" instead of "menuconfig".
I have no idea how I managed to use "menuconfig" here.
Impact: fix debug_smp_processor_id() for CONFIG_CPUMASK_OFFSTACK=y
The scheduler now uses the new cpumask API, which deals up to
nr_cpumask_bits, whereas the API used NR_CPUS bits.
If CONFIG_CPUMASK_OFFSTACK=y these two are not equal, so the top bits
are undefined. Leading to bug 12518 "BUG: using smp_processor_id() in
preemptible [00000000] code: dellWirelessCtl/..."
The fix is simple: use the modern API in the check.
Signed-off-by: Mike Travis <travis@sgi.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
debugobjects: add and use INIT_WORK_ON_STACK
rcu: remove duplicate CONFIG_RCU_CPU_STALL_DETECTOR
relay: fix lock imbalance in relay_late_setup_files
oprofile: fix uninitialized use of struct op_entry
rcu: move Kconfig menu
softlock: fix false panic which can occur if softlockup_thresh is reduced
rcu: add __cpuinit to rcu_init_percpu_data()
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits)
xen: unitialised return value in xenbus_write_transaction
x86: fix section mismatch warning
x86: unmask CPUID levels on Intel CPUs, fix
x86: work around PAGE_KERNEL_WC not getting WC in iomap_atomic_prot_pfn.
x86: use standard PIT frequency
xen: handle highmem pages correctly when shrinking a domain
x86, mm: fix pte_free()
xen: actually release memory when shrinking domain
x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h>
x86: fix PTE corruption issue while mapping RAM using /dev/mem
x86: mtrr fix debug boot parameter
x86: fix page attribute corruption with cpa()
Revert "x86: signal: change type of paramter for sys_rt_sigreturn()"
x86: use early clobbers in usercopy*.c
x86: remove kernel_physical_mapping_init() from init section
fix: crash: IP: __bitmap_intersects+0x48/0x73
cpufreq: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write
work_on_cpu: Use our own workqueue.
work_on_cpu: don't try to get_online_cpus() in work_on_cpu.
Impact: remove the old CONFIG_RCU_CPU_STALL_DETECTOR
tree_rcu introduce CONFIG_RCU_CPU_STALL_DETECTOR again.
These two are the same exactly except:
the old one "depends on CLASSIC_RCU"
the new one "depends on CLASSIC_RCU || TREE_RCU"
This patch remove the old one.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Commit da4276b8299a6544dc41ac2485d3ffca5811b3fb changed a dependency
for FRAME_POINTER from X86 to ARCH_WANT_FRAME_POINTERS, but didn't
actually define it.
This patch adds the definition for ARCH_WANT_FRAME_POINTERS. Without it,
FRAME_POINTER can't be enabled on x86.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
David points out that the idr_remove_all() function returns unused slabs
to the kmem cache, but needs to zero them first or else they will be
uninitialized upon next use. This causes crashes which have been observed
in the firewire subsystem.
He fixed this by zeroing the object before freeing it in idr_remove_all().
But we agree that simply removing the constructor and zeroing the object
at allocation time is simpler than relying upon slab constructor machinery
and might even be faster.
This problem was introduced by "idr: make idr_remove rcu-safe" (commit
cf481c20c476ad2c0febdace9ce23f5a4db19582), which was first released in
2.6.27.
There are no known codesites which trigger this bug in 2.6.27 or 2.6.28.
The post-2.6.28 firewire changes are the only known triggerer.
There might of course be not-yet-discovered triggerers in 2.6.27 and
2.6.28, and there might be out-of-tree triggerers which are added to those
kernel versions. I'll let the -stable guys decide whether they want to
backport this fix.
Reported-by: David Moore <dcm@acm.org>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Cc: Kristian Hgsberg <krh@redhat.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
idr_get_new_above() and ida_get_new_above() return an id in the range of
@staring_id ... 0x7fffffff, not 0 ... 0x7fffffff.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
x86: fix section mismatch warnings in mcheck/mce_amd_64.c
x86: offer frame pointers in all build modes
x86: remove duplicated #include's
x86: k8 numa register active regions later
x86: update Alan Cox's email addresses
x86: rename all fields of mpc_table mpc_X to X
x86: rename all fields of mpc_oemtable oem_X to X
x86: rename all fields of mpc_bus mpc_X to X
x86: rename all fields of mpc_cpu mpc_X to X
x86: rename all fields of mpc_intsrc mpc_X to X
x86: rename all fields of mpc_lintsrc mpc_X to X
x86: rename all fields of mpc_iopic mpc_X to X
x86: irqinit_64.c init_ISA_irqs should be static
Documentation/x86/boot.txt: payload length was changed to payload_length
x86: setup_percpu.c fix style problems
x86: irqinit_64.c fix style problems
x86: irqinit_32.c fix style problems
x86: i8259.c fix style problems
x86: irq_32.c fix style problems
x86: ioport.c fix style problems
The 'rb_first()', 'rb_last()', 'rb_next()' and 'rb_prev()' calls
take a pointer to an RB node or RB root. They do not change the
pointed objects, so add a 'const' qualifier in order to make life
of the users of these functions easier.
Indeed, if I have my own constant pointer &const struct my_type *p,
and I call 'rb_next(&p->rb)', I get a GCC warning:
warning: passing argument 1 of ‘rb_next’ discards qualifiers from pointer target type
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu:
NOMMU: Support XIP on initramfs
NOMMU: Teach kobjsize() about VMA regions.
FLAT: Don't attempt to expand the userspace stack to fill the space allocated
FDPIC: Don't attempt to expand the userspace stack to fill the space allocated
NOMMU: Improve procfs output using per-MM VMAs
NOMMU: Make mmap allocation page trimming behaviour configurable.
NOMMU: Make VMAs per MM as for MMU-mode linux
NOMMU: Delete askedalloc and realalloc variables
NOMMU: Rename ARM's struct vm_region
NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
This is to avoid name clashes for the introduction of a global swap()
macro.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems:
(1) In SYSV SHM where nattch for a segment does not reflect the number of
shmat's (and forks) done.
(2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an
exec'ing process when VM_EXECUTABLE is specified, regardless of the fact
that a VMA might be shared and already have its vm_mm assigned to another
process or a dead process.
A new struct (vm_region) is introduced to track a mapped region and to remember
the circumstances under which it may be shared and the vm_list_struct structure
is discarded as it's no longer required.
This patch makes the following additional changes:
(1) Regions are now allocated with alloc_pages() rather than kmalloc() and
with no recourse to __GFP_COMP, so the pages are not composite. Instead,
each page has a reference on it held by the region. Anything else that is
interested in such a page will have to get a reference on it to retain it.
When the pages are released due to unmapping, each page is passed to
put_page() and will be freed when the page usage count reaches zero.
(2) Excess pages are trimmed after an allocation as the allocation must be
made as a power-of-2 quantity of pages.
(3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may
end up with overlapping VMAs within the tree, the VMA struct address is
appended to the sort key.
(4) Non-anonymous VMAs are now added to the backing inode's prio list.
(5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of
the backing region. The VMA and region structs will be split if
necessary.
(6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory
segment instead of all the attachments at that addresss. Multiple
shmat()'s return the same address under NOMMU-mode instead of different
virtual addresses as under MMU-mode.
(7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode.
(8) /proc/maps is now the global list of mapped regions, and may list bits
that aren't actually mapped anywhere.
(9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount
of RAM currently allocated by mmap to hold mappable regions that can't be
mapped directly. These are copies of the backing device or file if not
anonymous.
These changes make NOMMU mode more similar to MMU mode. The downside is that
NOMMU mode requires some extra memory to track things over NOMMU without this
patch (VMAs are no longer shared, and there are now region structs).
Tested-by: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
trivial: chack -> check typo fix in main Makefile
trivial: Add a space (and a comma) to a printk in 8250 driver
trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx
trivial: Fix misspelling of "firmware" in powerpc Makefile
trivial: Fix misspelling of "firmware" in usb.c
trivial: Fix misspelling of "firmware" in qla1280.c
trivial: Fix misspelling of "firmware" in a100u2w.c
trivial: Fix misspelling of "firmware" in megaraid.c
trivial: Fix misspelling of "firmware" in ql4_mbx.c
trivial: Fix misspelling of "firmware" in acpi_memhotplug.c
trivial: Fix misspelling of "firmware" in ipw2100.c
trivial: Fix misspelling of "firmware" in atmel.c
trivial: Fix misspelled firmware in Kconfig
trivial: fix an -> a typos in documentation and comments
trivial: fix then -> than typos in comments and documentation
trivial: update Jesper Juhl CREDITS entry with new email
trivial: fix singal -> signal typo
trivial: Fix incorrect use of "loose" in event.c
trivial: printk: fix indentation of new_text_line declaration
trivial: rtc-stk17ta8: fix sparse warning
CONFIG_FRAME_POINTERS=y results in much better debug info for the
kernel (clear and precise backtraces), with the only drawback being
a ~1% increase in kernel size.
So offer it unconditionally and enable it by default.
rcu: fix rcutorture bug
rcu: eliminate synchronize_rcu_xxx macro
rcu: make treercu safe for suspend and resume
rcu: fix rcutree grace-period-latency bug on small systems
futex: catch certain assymetric (get|put)_futex_key calls
futex: make futex_(get|put)_key() calls symmetric
locking, percpu counters: introduce separate lock classes
swiotlb: clean up EXPORT_SYMBOL usage
swiotlb: remove unnecessary declaration
swiotlb: replace architecture-specific swiotlb.h with linux/swiotlb.h
swiotlb: add support for systems with highmem
swiotlb: store phys address in io_tlb_orig_addr array
swiotlb: add hwdev to swiotlb_phys_to_bus() / swiotlb_sg_to_bus()
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (60 commits)
uio: make uio_info's name and version const
UIO: Documentation for UIO ioport info handling
UIO: Pass information about ioports to userspace (V2)
UIO: uio_pdrv_genirq: allow custom irq_flags
UIO: use pci_ioremap_bar() in drivers/uio
arm: struct device - replace bus_id with dev_name(), dev_set_name()
libata: struct device - replace bus_id with dev_name(), dev_set_name()
avr: struct device - replace bus_id with dev_name(), dev_set_name()
block: struct device - replace bus_id with dev_name(), dev_set_name()
chris: struct device - replace bus_id with dev_name(), dev_set_name()
dmi: struct device - replace bus_id with dev_name(), dev_set_name()
gadget: struct device - replace bus_id with dev_name(), dev_set_name()
gpio: struct device - replace bus_id with dev_name(), dev_set_name()
gpu: struct device - replace bus_id with dev_name(), dev_set_name()
hwmon: struct device - replace bus_id with dev_name(), dev_set_name()
i2o: struct device - replace bus_id with dev_name(), dev_set_name()
IA64: struct device - replace bus_id with dev_name(), dev_set_name()
i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name()
infiniband: struct device - replace bus_id with dev_name(), dev_set_name()
ISDN: struct device - replace bus_id with dev_name(), dev_set_name()
For NR_CPUS >= 16 values, FBC_BATCH is 2*NR_CPUS
Considering more and more distros are using high NR_CPUS values, it makes
sense to use a more sensible value for FBC_BATCH, and get rid of NR_CPUS.
A sensible value is 2*num_online_cpus(), with a minimum value of 32 (This
minimum value helps branch prediction in __percpu_counter_add())
We already have a hotcpu notifier, so we can adjust FBC_BATCH dynamically.
We rename FBC_BATCH to percpu_counter_batch since its not a constant
anymore.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
It decodes "\n" as 0, which is bad, because stray echo into backlight
will turn your backlight off, etc...
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: Yi Yang <yi.y.yang@intel.com>
Suppresses sparse warning:
lib/proportions.c:159:16: warning: context imbalance in 'prop_get_global': wrong count at exit
lib/proportions.c:159:16: context 'RCU': wanted 0, got 1
lib/proportions.c:164:2: warning: context imbalance in 'prop_put_global': unexpected unlock
lib/proportions.c:164:2: context 'RCU': wanted 0, got -1
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
radix_tree_preloads is unused outside of this file, make it static.
Noticed by sparse:
lib/radix-tree.c:84:1: warning: symbol 'per_cpu__radix_tree_preloads' was not declared. Should it be static?
pos is always set before being used, no need to declare a
second one inside the if() block.
lib/prio_heap.c:34:7: warning: symbol 'pos' shadows an earlier one
lib/prio_heap.c:30:6: originally declared here
Cc: Gabor Gombas <gombasg@sztaki.hu>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: Ingo Molnar <mingo@elte.hu>,
This used to work unpatched with older kernels, during the development
phase of mtdoops. Before commit e3e8a75d2acfc61ebf25524666a0a2c6abb0620c
a space was printed with console_loglevel set to 15, which probably
flushed the oops message as a side effect.
This is another patch from the Nokia N810 kernel.
Signed-off-by: Viktor Rosendahl <viktor.rosendahl@nokia.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cleanup pr_debug_write() to reduce one level of indentation.
Cc: Marcel Holtmann <marcel@holtmann.org>
Acked-by: Jason Baron <jbaron@redhat.com>
We need to return the result of uevent sending by netlink
to caller, when uevent_helper is disabled and CONFIG_NET
is defined.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
kobject_uevent_env() uses envp_ext[] as verbatim format string which
can cause problems ranging from unexpectedly mangled string to oops if
a string in envp_ext[] contains substring which can be interpreted as
format. Fix it.
Removing the completion from klist_node reduces its size from 64 bytes
to 28 on x86-64. To maintain the semantics of klist_remove(), we add
a single list of klist nodes which are pending deletion and scan them.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
And some 80-line cleanups.
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
core/urgent
lib/swiotlb.c
There's no point in including the linux/swiotlb.h header twice in
lib/swiotlb.c - this patch gets rid of the unneeded include.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
Before, when we only ever printed out the pointer value itself, a NULL
pointer would never cause issues and might as well be printed out as
just its numeric value.
However, with the extended %p formats, especially %pR, we might validly
want to print out resources for debugging. And sometimes they don't
even exist, and the resource pointer is just NULL. Print it out as
such, rather than oopsing.
This is a more generic version of a patch done by Trent Piepho (catching
all %p cases rather than just %pR, and using "(null)" instead of
"[NULL]" to match glibc).
Requested-by: Trent Piepho <xyzzy@speakeasy.org>
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
Impact: cleanup, reduce kernel size a bit
The current kernel build warns:
WARNING: vmlinux.o(.text+0x11458): Section mismatch in reference from the function swiotlb_alloc_boot() to the function .init.text:__alloc_bootmem_low()
The function swiotlb_alloc_boot() references
the function __init __alloc_bootmem_low().
This is often because swiotlb_alloc_boot lacks a __init
annotation or the annotation of __alloc_bootmem_low is wrong.
WARNING: vmlinux.o(.text+0x1011f2): Section mismatch in reference from the function swiotlb_late_init_with_default_size() to the function .init.text:__alloc_bootmem_low()
The function swiotlb_late_init_with_default_size() references
This is often because swiotlb_late_init_with_default_size lacks a __init
and indeed the functions calling __alloc_bootmem_low() can be marked
__init as well.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
* 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits)
x86: export vector_used_by_percpu_irq
x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and()
sched: nominate preferred wakeup cpu, fix
x86: fix lguest used_vectors breakage, -v2
x86: fix warning in arch/x86/kernel/io_apic.c
sched: fix warning in kernel/sched.c
sched: move test_sd_parent() to an SMP section of sched.h
sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0
sched: activate active load balancing in new idle cpus
sched: bias task wakeups to preferred semi-idle packages
sched: favour lower logical cpu number for sched_mc balance
sched: framework for sched_mc/smt_power_savings=N
sched: convert BALANCE_FOR_xx_POWER to inline functions
x86: use possible_cpus=NUM to extend the possible cpus allowed
x86: fix cpu_mask_to_apicid_and to include cpu_online_mask
x86: update io_apic.c to the new cpumask code
x86: Introduce topology_core_cpumask()/topology_thread_cpumask()
x86: xen: use smp_call_function_many()
x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c
Fixed up trivial conflict in kernel/time/tick-sched.c manually
Impact: new debug CONFIG options
This helps find unconverted code. It currently breaks compile horribly,
but we never wanted a flag day so that's expected.
Impact: extra safety checks during transition
When CONFIG_CPUMASKS_OFFSTACK is set, the new cpumask_ operators only
use bits up to nr_cpu_ids, not NR_CPUS. Using the old cpus_ operators
on these masks can mean accessing undefined bits.
After some discussion, Mike and I decided to err on the side of caution;
we zero the "undefined" bits in alloc_cpumask_var_node() until all the
old cpumask functions are removed.
Impact: New API
As the name suggests. For the moment everyone uses the generic one.
Impact: fix kernel-doc
alloc_bootmem_cpumask_var() returns avoid.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: avoid leaking caches or refcounts on sysfs error
slab: Fix comment on #endif
slab: remove GFP_THISNODE clearing from alloc_slabmgmt()
slub: Add might_sleep_if() to slab_alloc()
SLUB: failslab support
slub: Fix incorrect use of loose
slab: Update the kmem_cache_create documentation regarding the name parameter
slub: make early_kmem_cache_node_alloc void
slab: unsigned slabp->inuse cannot be less than 0
slub - fix get_object_page comment
SLUB: Replace __builtin_return_address(0) with _RET_IP_.
SLUB: cleanup - define macros instead of hardcoded numbers
* 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits)
stacktrace: provide save_stack_trace_tsk() weak alias
rcu: provide RCU options on non-preempt architectures too
printk: fix discarding message when recursion_bug
futex: clean up futex_(un)lock_pi fault handling
"Tree RCU": scalable classic RCU implementation
futex: rename field in futex_q to clarify single waiter semantics
x86/swiotlb: add default swiotlb_arch_range_needs_mapping
x86/swiotlb: add default phys<->bus conversion
x86: unify pci iommu setup and allow swiotlb to compile for 32 bit
x86: add swiotlb allocation functions
swiotlb: consolidate swiotlb info message printing
swiotlb: support bouncing of HighMem pages
swiotlb: factor out copy to/from device
swiotlb: add arch hook to force mapping
swiotlb: allow architectures to override phys<->bus<->phys conversions
swiotlb: add comment where we handle the overflow of a dma mask on 32 bit
rcu: fix rcutorture behavior during reboot
resources: skip sanity check of busy resources
swiotlb: move some definitions to header
swiotlb: allow architectures to override swiotlb pool allocation
Fix up trivial conflicts in
arch/x86/kernel/Makefile
arch/x86/mm/init_32.c
include/linux/hardirq.h
as per Ingo's suggestions.
