path: root/lib
2015-06-06lib: Fix strnlen_user() to not touch memory after specified maximumJan Kara
commit f18c34e483ff6b1d9866472221e4015b3a4698e4 upstream. If the specified maximum length of the string is a multiple of unsigned long, we would load one long behind the specified maximum. If that happens to be in a next page, we can hit a page fault although we were not expected to. Fix the off-by-one bug in the test whether we are at the end of the specified range. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06lib: memzero_explicit: use barrier instead of OPTIMIZER_HIDE_VARmancha security
commit 0b053c9518292705736329a8fe20ef4686ffc8e9 upstream. OPTIMIZER_HIDE_VAR(), as defined when using gcc, is insufficient to ensure protection from dead store optimization. For the random driver and crypto drivers, calls are emitted ... $ gdb vmlinux (gdb) disassemble memzero_explicit Dump of assembler code for function memzero_explicit: 0xffffffff813a18b0 <+0>: push %rbp 0xffffffff813a18b1 <+1>: mov %rsi,%rdx 0xffffffff813a18b4 <+4>: xor %esi,%esi 0xffffffff813a18b6 <+6>: mov %rsp,%rbp 0xffffffff813a18b9 <+9>: callq 0xffffffff813a7120 <memset> 0xffffffff813a18be <+14>: pop %rbp 0xffffffff813a18bf <+15>: retq End of assembler dump. (gdb) disassemble extract_entropy [...] 0xffffffff814a5009 <+313>: mov %r12,%rdi 0xffffffff814a500c <+316>: mov $0xa,%esi 0xffffffff814a5011 <+321>: callq 0xffffffff813a18b0 <memzero_explicit> 0xffffffff814a5016 <+326>: mov -0x48(%rbp),%rax [...] ... but in case in future we might use facilities such as LTO, then OPTIMIZER_HIDE_VAR() is not sufficient to protect gcc from a possible eviction of the memset(). We have to use a compiler barrier instead. Minimal test example when we assume memzero_explicit() would *not* be a call, but would have been *inlined* instead: static inline void memzero_explicit(void *s, size_t count) { memset(s, 0, count); <foo> } int main(void) { char buff[20]; snprintf(buff, sizeof(buff) - 1, "test"); printf("%s", buff); memzero_explicit(buff, sizeof(buff)); return 0; } With <foo> := OPTIMIZER_HIDE_VAR(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: xor %eax,%eax 0x000000000040046b <+43>: add $0x28,%rsp 0x000000000040046f <+47>: retq End of assembler dump. With <foo> := barrier(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: movq $0x0,(%rsp) 0x0000000000400471 <+49>: movq $0x0,0x8(%rsp) 0x000000000040047a <+58>: movl $0x0,0x10(%rsp) 0x0000000000400482 <+66>: xor %eax,%eax 0x0000000000400484 <+68>: add $0x28,%rsp 0x0000000000400488 <+72>: retq End of assembler dump. As can be seen, movq, movq, movl are being emitted inlined via memset(). Reference: http://thread.gmane.org/gmane.linux.kernel.cryptoapi/13764/ Fixes: d4c5efdb9777 ("random: add and use memzero_explicit() for clearing data") Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: mancha security <mancha1@zoho.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fix from Jens Axboe: "Just one patch in this pull request, fixing a regression caused by a 'mathematically correct' change to lcm()" * 'for-linus' of git://git.kernel.dk/linux-block: block: fix blk_stack_limits() regression due to lcm() change
2015-03-31netlink: pad nla_memcpy dest buffer with zeroesJiri Benc
This is especially important in cases where the kernel allocs a new structure and expects a field to be set from a netlink attribute. If such attribute is shorter than expected, the rest of the field is left containing previous data. When such field is read back by the user space, kernel memory content is leaked. Signed-off-by: Jiri Benc <jbenc@redhat.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31block: fix blk_stack_limits() regression due to lcm() changeMike Snitzer
Linux 3.19 commit 69c953c ("lib/lcm.c: lcm(n,0)=lcm(0,n) is 0, not n") caused blk_stack_limits() to not properly stack queue_limits for stacked devices (e.g. DM). Fix this regression by establishing lcm_not_zero() and switching blk_stack_limits() over to using it. DM uses blk_set_stacking_limits() to establish the initial top-level queue_limits that are then built up based on underlying devices' limits using blk_stack_limits(). In the case of optimal_io_size (io_opt) blk_set_stacking_limits() establishes a default value of 0. With commit 69c953c, lcm(0, n) is no longer n, which compromises proper stacking of the underlying devices' io_opt. Test: $ modprobe scsi_debug dev_size_mb=10 num_tgts=1 opt_blks=1536 $ cat /sys/block/sde/queue/optimal_io_size 786432 $ dmsetup create node --table "0 100 linear /dev/sde 0" Before this fix: $ cat /sys/block/dm-5/queue/optimal_io_size 0 After this fix: $ cat /sys/block/dm-5/queue/optimal_io_size 786432 Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # 3.19+ Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-03-16LZ4 : fix the data abort issueJeHyeon Yeon
If the part of the compression data are corrupted, or the compression data is totally fake, the memory access over the limit is possible. This is the log from my system usning lz4 decompression. [6502]data abort, halting [6503]r0 0x00000000 r1 0x00000000 r2 0xdcea0ffc r3 0xdcea0ffc [6509]r4 0xb9ab0bfd r5 0xdcea0ffc r6 0xdcea0ff8 r7 0xdce80000 [6515]r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0xb9a98000 [6522]r12 0xdcea1000 usp 0x00000000 ulr 0x00000000 pc 0x820149bc [6528]spsr 0x400001f3 and the memory addresses of some variables at the moment are ref:0xdcea0ffc, op:0xdcea0ffc, oend:0xdcea1000 As you can see, COPYLENGH is 8bytes, so @ref and @op can access the momory over @oend. Signed-off-by: JeHyeon Yeon <tom.yeon@windriver.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-13Merge branch 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfsLinus Torvalds
Pull gadgetfs fixes from Al Viro: "Assorted fixes around AIO on gadgetfs: leaks, use-after-free, troubles caused by ->f_op flipping" * 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: gadgetfs: really get rid of switching ->f_op gadgetfs: get rid of flipping ->f_op in ep_config() gadget: switch ep_io_operations to ->read_iter/->write_iter gadgetfs: use-after-free in ->aio_read() gadget/function/f_fs.c: switch to ->{read,write}_iter() gadget/function/f_fs.c: use put iov_iter into io_data gadget/function/f_fs.c: close leaks move iov_iter.c from mm/ to lib/ new helper: dup_iter()
2015-03-09Merge tag 'trace-fixes-v4.0-rc2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull seq-buf/ftrace fixes from Steven Rostedt: "This includes fixes for seq_buf_bprintf() truncation issue. It also contains fixes to ftrace when /proc/sys/kernel/ftrace_enabled and function tracing are started. Doing the following causes some issues: # echo 0 > /proc/sys/kernel/ftrace_enabled # echo function_graph > /sys/kernel/debug/tracing/current_tracer # echo 1 > /proc/sys/kernel/ftrace_enabled # echo nop > /sys/kernel/debug/tracing/current_tracer # echo function_graph > /sys/kernel/debug/tracing/current_tracer As well as with function tracing too. Pratyush Anand first reported this issue to me and supplied a patch. When I tested this on my x86 test box, it caused thousands of backtraces and warnings to appear in dmesg, which also caused a denial of service (a warning for every function that was listed). I applied Pratyush's patch but it did not fix the issue for me. I looked into it and found a slight problem with trampoline accounting. I fixed it and sent Pratyush a patch, but he said that it did not fix the issue for him. I later learned tha Pratyush was using an ARM64 server, and when I tested on my ARM board, I was able to reproduce the same issue as Pratyush. After applying his patch, it fixed the problem. The above test uncovered two different bugs, one in x86 and one in ARM and ARM64. As this looked like it would affect PowerPC, I tested it on my PPC64 box. It too broke, but neither the patch that fixed ARM or x86 fixed this box (the changes were all in generic code!). The above test, uncovered two more bugs that affected PowerPC. Again, the changes were only done to generic code. It's the way the arch code expected things to be done that was different between the archs. Some where more sensitive than others. The rest of this series fixes the PPC bugs as well" * tag 'trace-fixes-v4.0-rc2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Fix ftrace enable ordering of sysctl ftrace_enabled ftrace: Fix en(dis)able graph caller when en(dis)abling record via sysctl ftrace: Clear REGS_EN and TRAMP_EN flags on disabling record via sysctl seq_buf: Fix seq_buf_bprintf() truncation seq_buf: Fix seq_buf_vprintf() truncation
2015-03-04seq_buf: Fix seq_buf_bprintf() truncationSteven Rostedt (Red Hat)
In seq_buf_bprintf(), bstr_printf() is used to copy the format into the buffer remaining in the seq_buf structure. The return of bstr_printf() is the amount of characters written to the buffer excluding the '\0', unless the line was truncated! If the line copied does not fit, it is truncated, and a '\0' is added to the end of the buffer. But in this case, '\0' is included in the length of the line written. To know if the buffer had overflowed, the return length will be the same or greater than the length of the buffer passed in. The check in seq_buf_bprintf() only checked if the length returned from bstr_printf() would fit in the buffer, as the seq_buf_bprintf() is only to be an all or nothing command. It either writes all the string into the seq_buf, or none of it. If the string is truncated, the pointers inside the seq_buf must be reset to what they were when the function was called. This is not the case. On overflow, it copies only part of the string. The fix is to change the overflow check to see if the length returned from bstr_printf() is less than the length remaining in the seq_buf buffer, and not if it is less than or equal to as it currently does. Then seq_buf_bprintf() will know if the write from bstr_printf() was truncated or not. Link: http://lkml.kernel.org/r/1425500481.2712.27.camel@perches.com Cc: stable@vger.kernel.org Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-04seq_buf: Fix seq_buf_vprintf() truncationSteven Rostedt (Red Hat)
In seq_buf_vprintf(), vsnprintf() is used to copy the format into the buffer remaining in the seq_buf structure. The return of vsnprintf() is the amount of characters written to the buffer excluding the '\0', unless the line was truncated! If the line copied does not fit, it is truncated, and a '\0' is added to the end of the buffer. But in this case, '\0' is included in the length of the line written. To know if the buffer had overflowed, the return length will be the same as the length of the buffer passed in. The check in seq_buf_vprintf() only checked if the length returned from vsnprintf() would fit in the buffer, as the seq_buf_vprintf() is only to be an all or nothing command. It either writes all the string into the seq_buf, or none of it. If the string is truncated, the pointers inside the seq_buf must be reset to what they were when the function was called. This is not the case. On overflow, it copies only part of the string. The fix is to change the overflow check to see if the length returned from vsnprintf() is less than the length remaining in the seq_buf buffer, and not if it is less than or equal to as it currently does. Then seq_buf_vprintf() will know if the write from vsnpritnf() was truncated or not. Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If an IPVS tunnel is created with a mixed-family destination address, it cannot be removed. Fix from Alexey Andriyanov. 2) Fix module refcount underflow in netfilter's nft_compat, from Pablo Neira Ayuso. 3) Generic statistics infrastructure can reference variables sitting on a released function stack, therefore use dynamic allocation always. Fix from Ignacy Gawędzki. 4) skb_copy_bits() return value test is inverted in ip_check_defrag(). 5) Fix network namespace exit in openvswitch, we have to release all of the per-net vports. From Pravin B Shelar. 6) Fix signedness bug in CAIF's cfpkt_iterate(), from Dan Carpenter. 7) Fix rhashtable grow/shrink behavior, only expand during inserts and shrink during deletes. From Daniel Borkmann. 8) Netdevice names with semicolons should never be allowed, because they serve as a separator. From Matthew Thode. 9) Use {,__}set_current_state() where appropriate, from Fabian Frederick. 10) Revert byte queue limits support in r8169 driver, it's causing regressions we can't figure out. 11) tcp_should_expand_sndbuf() erroneously uses tp->packets_out to measure packets in flight, properly use tcp_packets_in_flight() instead. From Neal Cardwell. 12) Fix accidental removal of support for bluetooth in CSR based Intel wireless cards. From Marcel Holtmann. 13) We accidently added a behavioral change between native and compat tasks, wrt testing the MSG_CMSG_COMPAT bit. Just ignore it if the user happened to set it in a native binary as that was always the behavior we had. From Catalin Marinas. 14) Check genlmsg_unicast() return valud in hwsim netlink tx frame handling, from Bob Copeland. 15) Fix stale ->radar_required setting in mac80211 that can prevent starting new scans, from Eliad Peller. 16) Fix memory leak in nl80211 monitor, from Johannes Berg. 17) Fix race in TX index handling in xen-netback, from David Vrabel. 18) Don't enable interrupts in amx-xgbe driver until all software et al. state is ready for the interrupt handler to run. From Thomas Lendacky. 19) Add missing netlink_ns_capable() checks to rtnl_newlink(), from Eric W Biederman. 20) The amount of header space needed in macvtap was not calculated properly, fix it otherwise we splat past the beginning of the packet. From Eric Dumazet. 21) Fix bcmgenet TCP TX perf regression, from Jaedon Shin. 22) Don't raw initialize or mod timers, use setup_timer() and mod_timer() instead. From Vaishali Thakkar. 23) Fix software maintained statistics in bcmgenet and systemport drivers, from Florian Fainelli. 24) DMA descriptor updates in sh_eth need proper memory barriers, from Ben Hutchings. 25) Don't do UDP Fragmentation Offload on RAW sockets, from Michal Kubecek. 26) Openvswitch's non-masked set actions aren't constructed properly into netlink messages, fix from Joe Stringer. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) openvswitch: Fix serialization of non-masked set actions. gianfar: Reduce logging noise seen due to phy polling if link is down ibmveth: Add function to enable live MAC address changes net: bridge: add compile-time assert for cb struct size udp: only allow UFO for packets from SOCK_DGRAM sockets sh_eth: Really fix padding of short frames on TX Revert "sh_eth: Enable Rx descriptor word 0 shift for r8a7790" sh_eth: Fix RX recovery on R-Car in case of RX ring underrun sh_eth: Ensure proper ordering of descriptor active bit write/read net/mlx4_en: Disbale GRO for incoming loopback/selftest packets net/mlx4_core: Fix wrong mask and error flow for the update-qp command net: systemport: fix software maintained statistics net: bcmgenet: fix software maintained statistics rxrpc: don't multiply with HZ twice rxrpc: terminate retrans loop when sending of skb fails net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR interface. net: pasemi: Use setup_timer and mod_timer net: stmmac: Use setup_timer and mod_timer net: 8390: axnet_cs: Use setup_timer and mod_timer net: 8390: pcnet_cs: Use setup_timer and mod_timer ...
2015-02-27rhashtable: use cond_resched()Eric Dumazet
If a hash table has 128 slots and 16384 elems, expand to 256 slots takes more than one second. For larger sets, a soft lockup is detected. Holding cpu for that long, even in a work queue is a show stopper for non preemptable kernels. cond_resched() at strategic points to allow process scheduler to reschedule us. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-27rhashtable: remove indirection for grow/shrink decision functionsDaniel Borkmann
Currently, all real users of rhashtable default their grow and shrink decision functions to rht_grow_above_75() and rht_shrink_below_30(), so that there's currently no need to have this explicitly selectable. It can/should be generic and private inside rhashtable until a real use case pops up. Since we can make this private, we'll save us this additional indirection layer and can improve insertion/deletion time as well. Reference: http://patchwork.ozlabs.org/patch/443040/ Suggested-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-27rhashtable: unconditionally grow when max_shift is not specifiedDaniel Borkmann
While commit c0c09bfdc415 ("rhashtable: avoid unnecessary wakeup for worker queue") rightfully moved part of the decision making of whether we should expand or shrink from the expand/shrink functions themselves into insert/delete functions in order to avoid unnecessary worker wake-ups, it however introduced a regression by doing so. Before that change, if no max_shift was specified (= 0) on rhashtable initialization, rhashtable_expand() would just grow unconditionally and lets the available memory be the limiting factor. After that change, if no max_shift was specified, there would be _no_ expansion step at all. Given that netlink and tipc have a max_shift specified, it was not visible there, but Josh Hunt reported that if nft that starts out with a default element hint of 3 if not otherwise provided, would slow i.e. inserts down trememdously as it cannot grow larger to relax table occupancy. Given that the test case verifies shrinks/expands manually, we also must remove pointer to the helper functions to explicitly avoid parallel resizing on insertions/deletions. test_bucket_stats() and test_rht_lookup() could also be wrapped around rhashtable mutex to explicitly synchronize a walk from resizing, but I think that defeats the actual test case which intended to have explicit test steps, i.e. 1) inserts, 2) expands, 3) shrinks, 4) deletions, with object verification after each stage. Reported-by: Josh Hunt <johunt@akamai.com> Fixes: c0c09bfdc415 ("rhashtable: avoid unnecessary wakeup for worker queue") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Ying Xue <ying.xue@windriver.com> Cc: Josh Hunt <johunt@akamai.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-23rhashtable: initialize all rhashtable walker membersSasha Levin
Commit f2dba9c6ff ("rhashtable: Introduce rhashtable_walk_*") forgot to initialize the members of struct rhashtable_walker after allocating it, which caused an undefined value for 'resize' which is used later on. Fixes: f2dba9c6ff ("rhashtable: Introduce rhashtable_walk_*") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-20rhashtable: allow to unload test moduleDaniel Borkmann
There's no good reason why to disallow unloading of the rhashtable test case module. Commit 9d6dbe1bbaf8 moved the code from a boot test into a stand-alone module, but only converted the subsys_initcall() handler into a module_init() function without a related exit handler, and thus preventing the test module from unloading. Fixes: 9d6dbe1bbaf8 ("rhashtable: Make selftest modular") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-20rhashtable: better high order allocation attemptsDaniel Borkmann
When trying to allocate future tables via bucket_table_alloc(), it seems overkill on large table shifts that we probe for kzalloc() unconditionally first, as it's likely to fail. Only probe with kzalloc() for more reasonable table sizes and use vzalloc() either as a fallback on failure or directly in case of large table sizes. Fixes: 7e1e77636e36 ("lib: Resizable, Scalable, Concurrent Hash Table") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-20rhashtable: don't test for shrink on insert, expansion on deleteDaniel Borkmann
Restore pre 54c5b7d311c8 behaviour and only probe for expansions on inserts and shrinks on deletes. Currently, it will happen that on initial inserts into a sparse hash table, we may i.e. shrink it first simply because it's not fully populated yet, only to later realize that we need to grow again. This however is counter intuitive, e.g. an initial default size of 64 elements is already small enough, and in case an elements size hint is given to the hash table by a user, we should avoid unnecessary expansion steps, so a shrink is clearly unintended here. Fixes: 54c5b7d311c8 ("rhashtable: introduce rhashtable_wakeup_worker helper function") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Ying Xue <ying.xue@windriver.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-20rhashtable: don't allocate ht structure on stack in test_rht_initDaniel Borkmann
With object runtime debugging enabled, the rhashtable test suite will rightfully throw a warning "ODEBUG: object is on stack, but not annotated" from rhashtable_init(). This is because run_work is (correctly) being initialized via INIT_WORK(), and not annotated by INIT_WORK_ONSTACK(). Meaning, rhashtable_init() is okay as is, we just need to move ht e.g., into global scope. It never triggered anything, since test_rhashtable is rather a controlled environment and effectively runs to completion, so that stack memory is not vanishing underneath us, we shouldn't confuse any testers with it though. Fixes: 7e1e77636e36 ("lib: Resizable, Scalable, Concurrent Hash Table") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-19Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "Yann E Morin was supposed to take over kconfig maintainership, but this hasn't happened. So I'm sending a few kconfig patches that I collected: - Fix for missing va_end in kconfig - merge_config.sh displays used if given too few arguments - s/boolean/bool/ in Kconfig files for consistency, with the plan to only support bool in the future" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: use va_end to match corresponding va_start merge_config.sh: Display usage if given too few arguments kconfig: use bool instead of boolean for type definition attributes
2015-02-18Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "OK, this has the big virtio 1.0 implementation, as specified by OASIS. On top of tht is the major rework of lguest, to use PCI and virtio 1.0, to double-check the implementation. Then comes the inevitable fixes and cleanups from that work" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits) virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice. virtio_net: unconditionally define struct virtio_net_hdr_v1. tools/lguest: don't use legacy definitions for net device in example launcher. virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined. tools/lguest: use common error macros in the example launcher. tools/lguest: give virtqueues names for better error messages tools/lguest: more documentation and checking of virtio 1.0 compliance. lguest: don't look in console features to find emerg_wr. tools/lguest: don't start devices until DRIVER_OK status set. tools/lguest: handle indirect partway through chain. tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI) tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI) tools/lguest: rename virtio_pci_cfg_cap field to match spec. tools/lguest: fix features_accepted logic in example launcher. tools/lguest: handle device reset correctly in example launcher. virtual: Documentation: simplify and generalize paravirt_ops.txt lguest: remove NOTIFY call and eventfd facility. lguest: remove NOTIFY facility from demonstration launcher. lguest: use the PCI console device's emerg_wr for early boot messages. lguest: always put console in PCI slot #1. ...
2015-02-17move iov_iter.c from mm/ to lib/Al Viro
2015-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc VFS updates from Al Viro: "This cycle a lot of stuff sits on topical branches, so I'll be sending more or less one pull request per branch. This is the first pile; more to follow in a few. In this one are several misc commits from early in the cycle (before I went for separate branches), plus the rework of mntput/dput ordering on umount, switching to use of fs_pin instead of convoluted games in namespace_unlock()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch the IO-triggering parts of umount to fs_pin new fs_pin killing logics allow attaching fs_pin to a group not associated with some superblock get rid of the second argument of acct_kill() take count and rcu_head out of fs_pin dcache: let the dentry count go down to zero without taking d_lock pull bumping refcount into ->kill() kill pin_put() mode_t whack-a-mole: chelsio file->f_path.dentry is pinned down for as long as the file is open... get rid of lustre_dump_dentry() gut proc_register() a bit kill d_validate() ncpfs: get rid of d_validate() nonsense selinuxfs: don't open-code d_genocide()
2015-02-17scripts/gdb: add infrastructureJan Kiszka
This provides the basic infrastructure to load kernel-specific python helper scripts when debugging the kernel in gdb. The loading mechanism is based on gdb loading for <objfile>-gdb.py when opening <objfile>. Therefore, this places a corresponding link to the main helper script into the output directory that contains vmlinux. The main scripts will pull in submodules containing Linux specific gdb commands and functions. To avoid polluting the source directory with compiled python modules, we link to them from the object directory. Due to gdb.parse_and_eval and string redirection for gdb.execute, we depend on gdb >= 7.2. This feature is enabled via CONFIG_GDB_SCRIPTS. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Michal Marek <mmarek@suse.cz> [kbuild stuff] Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16lib/Kconfig: use bool instead of booleanChristoph Jaeger
Keyword 'boolean' for type definition attributes is considered deprecated and, therefore, should not be used anymore. See http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com See http://lkml.kernel.org/r/1419108071-11607-1-git-send-email-cj@linux.com Signed-off-by: Christoph Jaeger <cj@linux.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.20: - Added 192/256-bit key support to aesni GCM. - Added MIPS OCTEON MD5 support. - Fixed hwrng starvation and race conditions. - Added note that memzero_explicit is not a subsitute for memset. - Added user-space interface for crypto_rng. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits) crypto: tcrypt - do not allocate iv on stack for aead speed tests crypto: testmgr - limit IV copy length in aead tests crypto: tcrypt - fix buflen reminder calculation crypto: testmgr - mark rfc4106(gcm(aes)) as fips_allowed crypto: caam - fix resource clean-up on error path for caam_jr_init crypto: caam - pair irq map and dispose in the same function crypto: ccp - terminate ccp_support array with empty element crypto: caam - remove unused local variable crypto: caam - remove dead code crypto: caam - don't emit ICV check failures to dmesg hwrng: virtio - drop extra empty line crypto: replace scatterwalk_sg_next with sg_next crypto: atmel - Free memory in error path crypto: doc - remove colons in comments crypto: seqiv - Ensure that IV size is at least 8 bytes crypto: cts - Weed out non-CBC algorithms MAINTAINERS: add linux-crypto to hw random crypto: cts - Remove bogus use of seqiv crypto: qat - don't need qat_auth_state struct crypto: algif_rng - fix sparse non static symbol warning ...
2015-02-13kasan: enable instrumentation of global variablesAndrey Ryabinin
This feature let us to detect accesses out of bounds of global variables. This will work as for globals in kernel image, so for globals in modules. Currently this won't work for symbols in user-specified sections (e.g. __init, __read_mostly, ...) The idea of this is simple. Compiler increases each global variable by redzone size and add constructors invoking __asan_register_globals() function. Information about global variable (address, size, size with redzone ...) passed to __asan_register_globals() so we could poison variable's redzone. This patch also forces module_alloc() to return 8*PAGE_SIZE aligned address making shadow memory handling ( kasan_module_alloc()/kasan_module_free() ) more simple. Such alignment guarantees that each shadow page backing modules address space correspond to only one module_alloc() allocation. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: add kasan test moduleAndrey Ryabinin
This is a test module doing various nasty things like out of bounds accesses, use after free. It is useful for testing kernel debugging features like kernel address sanitizer. It mostly concentrates on testing of slab allocator, but we might want to add more different stuff here in future (like stack/global variables out of bounds accesses and so on). Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: slub: add kernel address sanitizer support for slub allocatorAndrey Ryabinin
With this patch kasan will be able to catch bugs in memory allocated by slub. Initially all objects in newly allocated slab page, marked as redzone. Later, when allocation of slub object happens, requested by caller number of bytes marked as accessible, and the rest of the object (including slub's metadata) marked as redzone (inaccessible). We also mark object as accessible if ksize was called for this object. There is some places in kernel where ksize function is called to inquire size of really allocated area. Such callers could validly access whole allocated memory, so it should be marked as accessible. Code in slub.c and slab_common.c files could validly access to object's metadata, so instrumentation for this files are disabled. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Signed-off-by: Dmitry Chernenkov <dmitryc@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13x86_64: add KASan supportAndrey Ryabinin
This patch adds arch specific code for kernel address sanitizer. 16TB of virtual addressed used for shadow memory. It's located in range [ffffec0000000000 - fffffc0000000000] between vmemmap and %esp fixup stacks. At early stage we map whole shadow region with zero page. Latter, after pages mapped to direct mapping address range we unmap zero pages from corresponding shadow (see kasan_map_shadow()) and allocate and map a real shadow memory reusing vmemmap_populate() function. Also replace __pa with __pa_nodebug before shadow initialized. __pa with CONFIG_DEBUG_VIRTUAL=y make external function call (__phys_addr) __phys_addr is instrumented, so __asan_load could be called before shadow area initialized. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Jim Davis <jim.epost@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kasan: add kernel address sanitizer infrastructureAndrey Ryabinin
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It provides fast and comprehensive solution for finding use-after-free and out-of-bounds bugs. KASAN uses compile-time instrumentation for checking every memory access, therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with putting symbol aliases into the wrong section, which breaks kasan instrumentation of globals. This patch only adds infrastructure for kernel address sanitizer. It's not available for use yet. The idea and some code was borrowed from [1]. Basic idea: The main idea of KASAN is to use shadow memory to record whether each byte of memory is safe to access or not, and use compiler's instrumentation to check the shadow memory on each memory access. Address sanitizer uses 1/8 of the memory addressable in kernel for shadow memory and uses direct mapping with a scale and offset to translate a memory address to its corresponding shadow address. Here is function to translate address to corresponding shadow address: unsigned long kasan_mem_to_shadow(unsigned long addr) { return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET; } where KASAN_SHADOW_SCALE_SHIFT = 3. So for every 8 bytes there is one corresponding byte of shadow memory. The following encoding used for each shadow byte: 0 means that all 8 bytes of the corresponding memory region are valid for access; k (1 <= k <= 7) means that the first k bytes are valid for access, and other (8 - k) bytes are not; Any negative value indicates that the entire 8-bytes are inaccessible. Different negative values used to distinguish between different kinds of inaccessible memory (redzones, freed memory) (see mm/kasan/kasan.h). To be able to detect accesses to bad memory we need a special compiler. Such compiler inserts a specific function calls (__asan_load*(addr), __asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16. These functions check whether memory region is valid to access or not by checking corresponding shadow memory. If access is not valid an error printed. Historical background of the address sanitizer from Dmitry Vyukov: "We've developed the set of tools, AddressSanitizer (Asan), ThreadSanitizer and MemorySanitizer, for user space. We actively use them for testing inside of Google (continuous testing, fuzzing, running prod services). To date the tools have found more than 10'000 scary bugs in Chromium, Google internal codebase and various open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and lots of others): [2] [3] [4]. The tools are part of both gcc and clang compilers. We have not yet done massive testing under the Kernel AddressSanitizer (it's kind of chicken and egg problem, you need it to be upstream to start applying it extensively). To date it has found about 50 bugs. Bugs that we've found in upstream kernel are listed in [5]. We've also found ~20 bugs in out internal version of the kernel. Also people from Samsung and Oracle have found some. [...] As others noted, the main feature of AddressSanitizer is its performance due to inline compiler instrumentation and simple linear shadow memory. User-space Asan has ~2x slowdown on computational programs and ~2x memory consumption increase. Taking into account that kernel usually consumes only small fraction of CPU and memory when running real user-space programs, I would expect that kernel Asan will have ~10-30% slowdown and similar memory consumption increase (when we finish all tuning). I agree that Asan can well replace kmemcheck. We have plans to start working on Kernel MemorySanitizer that finds uses of unitialized memory. Asan+Msan will provide feature-parity with kmemcheck. As others noted, Asan will unlikely replace debug slab and pagealloc that can be enabled at runtime. Asan uses compiler instrumentation, so even if it is disabled, it still incurs visible overheads. Asan technology is easily portable to other architectures. Compiler instrumentation is fully portable. Runtime has some arch-dependent parts like shadow mapping and atomic operation interception. They are relatively easy to port." Comparison with other debugging features: ======================================== KMEMCHECK: - KASan can do almost everything that kmemcheck can. KASan uses compile-time instrumentation, which makes it significantly faster than kmemcheck. The only advantage of kmemcheck over KASan is detection of uninitialized memory reads. Some brief performance testing showed that kasan could be x500-x600 times faster than kmemcheck: $ netperf -l 30 MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec no debug: 87380 16384 16384 30.00 41624.72 kasan inline: 87380 16384 16384 30.00 12870.54 kasan outline: 87380 16384 16384 30.00 10586.39 kmemcheck: 87380 16384 16384 30.03 20.23 - Also kmemcheck couldn't work on several CPUs. It always sets number of CPUs to 1. KASan doesn't have such limitation. DEBUG_PAGEALLOC: - KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page granularity level, so it able to find more bugs. SLUB_DEBUG (poisoning, redzones): - SLUB_DEBUG has lower overhead than KASan. - SLUB_DEBUG in most cases are not able to detect bad reads, KASan able to detect both reads and writes. - In some cases (e.g. redzone overwritten) SLUB_DEBUG detect bugs only on allocation/freeing of object. KASan catch bugs right before it will happen, so we always know exact place of first bad read/write. [1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel [2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs [3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs [4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs [5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies Based on work by Andrey Konovalov. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13bitmap, cpumask, nodemask: remove dedicated formatting functionsTejun Heo
Now that all bitmap formatting usages have been converted to '%*pb[l]', the separate formatting functions are unnecessary. The following functions are removed. * bitmap_scn[list]printf() * cpumask_scnprintf(), cpulist_scnprintf() * [__]nodemask_scnprintf(), [__]nodelist_scnprintf() * seq_bitmap[_list](), seq_cpumask[_list](), seq_nodemask[_list]() * seq_buf_bitmask() Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13bitmap: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/vsprintf: implement bitmap printing through '%*pb[l]'Tejun Heo
bitmap and its derivatives such as cpumask and nodemask currently only provide formatting functions which put the output string into the provided buffer; however, how long this buffer should be isn't defined anywhere and given that some of these bitmaps can be too large to be formatted into an on-stack buffer it users sometimes are unnecessarily forced to come up with creative solutions and compromises for the buffer just to printk these bitmaps. There have been a couple different attempts at making this easier. 1. Way back, PeterZ tried printk '%pb' extension with the precision for bit width - '%.*pb'. This was intuitive and made sense but unfortunately triggered a compile warning about using precision for a pointer. http://lkml.kernel.org/g/1336577562.2527.58.camel@twins 2. I implemented bitmap_pr_cont[_list]() and its wrappers for cpumask and nodemask. This works but PeterZ pointed out that pr_cont's tendency to produce broken lines when multiple CPUs are printing is bothering considering the usages. http://lkml.kernel.org/g/1418226774-30215-3-git-send-email-tj@kernel.org So, this patch is another attempt at teaching printk and friends how to print bitmaps. It's almost identical to what PeterZ tried with precision but it uses the field width for the number of bits instead of precision. The format used is '%*pb[l]', with the optional trailing 'l' specifying list format instead of hex masks. This is a valid format string and doesn't trigger compiler warnings; however, it does make it impossible to specify output field width when printing bitmaps. I think this is an acceptable trade-off given how much easier it makes printing bitmaps and that we don't have any in-kernel user which is using the field width specification. If any future user wants to use field width with a bitmap, it'd have to format the bitmap into a string buffer and then print that buffer with width spec, which isn't different from how it should be done now. This patch implements bitmap[_list]_string() which are called from the vsprintf pointer() formatting function. The implementation is mostly identical to bitmap_scn[list]printf() except that the output is performed in the vsprintf way. These functions handle formatting into too small buffers and sprintf() family of functions report the correct overrun output length. bitmap_scn[list]printf() are now thin wrappers around scnprintf(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Cc: Christoph Lameter <cl@linux.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Mike Travis <travis@sgi.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/genalloc.c: check result of devres_alloc()Jan Kara
devm_gen_pool_create() calls devres_alloc() and dereferences its result without checking whether devres_alloc() succeeded. Check for error and bail out if it happened. Coverity-id 1016493. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/string.c: improve strrchr()Rasmus Villemoes
Instead of potentially passing over the string twice in case c is not found, just keep track of the last occurrence. According to bloat-o-meter, this also cuts the generated code by a third (54 vs 36 bytes). Oh, and we get rid of those 7-space indented lines. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: crc32: constify crc32 lookup tableDaniel Borkmann
Commit 8f243af42ade ("sections: fix const sections for crc32 table") removed the compile-time generated crc32 tables from the RO sections, because it conflicts with the definition of __cacheline_aligned which puts all such aligned data into .data..cacheline_aligned section optimized for wasting less space, and can cause alignment issues when used in combination with const with some gcc versions like 4.7.0 due to a gcc bug [1]. Given that most gcc versions should have the fix by now, we can just use ____cacheline_aligned, which only aligns the data but doesn't move it into specific sections as opposed to __cacheline_aligned. In case of gcc versions having the mentioned bug, the alignment attribute will have no effect, but the data will still be made RO. After patch tables are in RO: $ nm -v lib/crc32.o | grep -1 -E "crc32c?table" 0000000000000000 t arch_local_irq_enable 0000000000000000 r crc32ctable_le 0000000000000000 t crc32_exit -- 0000000000000960 t test_buf 0000000000002000 r crc32table_be 0000000000004000 r crc32table_le 000000001d1056e5 A __crc_crc32_be [1] https://gcc.gnu.org/bugzilla/show_bug.cgi?id=52181 Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Joe Mario <jmario@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: remove redundant code from __bitmap_shift_leftRasmus Villemoes
The first of these conditionals is completely redundant: If k == lim-1, we must have off==0, so the second conditional will also trigger and then it wouldn't matter if upper had some high bits set. But the second conditional is in fact also redundant, since it only serves to clear out some high-order "don't care" bits of dst, about which no guarantee is made. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: eliminate branch in __bitmap_shift_leftRasmus Villemoes
We can shift the bits from lower and upper into place before assembling dst[k + off]; moving the shift of lower into the branch where we already know that rem is non-zero allows us to remove a conditional. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: change bitmap_shift_left to take unsigned parametersRasmus Villemoes
gcc can generate slightly better code for stuff like "nbits % BITS_PER_LONG" when it knows nbits is not negative. Since negative size bitmaps or shift amounts don't make sense, change these parameters of bitmap_shift_right to unsigned. If off >= lim (which requires shift >= nbits), k is initialized with a large positive value, but since I've let k continue to be signed, the loop will never run and dst will be zeroed as expected. Inside the loop, k is guaranteed to be non-negative, so the fact that it is promoted to unsigned in the various expressions it appears in is harmless. Also use "shift" and "nbits" consistently for the parameter names. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: yet another simplification in __bitmap_shift_rightRasmus Villemoes
If left is 0, we can just let mask be ~0UL, so that anding with it is a no-op. Conveniently, BITMAP_LAST_WORD_MASK provides precisely what we need, and we can eliminate left. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: remove redundant code from __bitmap_shift_rightRasmus Villemoes
If the condition k==lim-1 is true, we must have off == 0 (otherwise, k could never become that big). But in that case we have upper == 0 and hence dst[k] == (src[k] & mask) >> rem. Since mask consists of a consecutive range of bits starting from the LSB, anding dst[k] with mask is a no-op. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: eliminate branch in __bitmap_shift_rightRasmus Villemoes
We can shift the bits from lower and upper into place before assembling dst[k]; moving the shift of upper into the branch where we already know that rem is non-zero allows us to remove a conditional. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib: bitmap: change bitmap_shift_right to take unsigned parametersRasmus Villemoes
I've previously changed the nbits parameter of most bitmap_* functions to unsigned; now it is bitmap_shift_{left,right}'s turn. This alone saves some .text, but while at it I found that there were a few other things one could do. The end result of these seven patches is $ scripts/bloat-o-meter /tmp/bitmap.o.{old,new} add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-328 (-328) function old new delta __bitmap_shift_right 384 226 -158 __bitmap_shift_left 306 136 -170 and less importantly also a smaller stack footprint $ stack-o-meter.pl master bitmap file function old new delta lib/bitmap.o __bitmap_shift_right 24 8 -16 lib/bitmap.o __bitmap_shift_left 24 0 -24 For each pair of 0 <= shift <= nbits <= 256 I've tested the end result with a few randomly filled src buffers (including garbage beyond nbits), in each case verifying that the shift {left,right}-most bits of dst are zero and the remaining nbits-shift bits correspond to src, so I'm fairly confident I didn't screw up. That hasn't stopped me from being wrong before, though. This patch (of 7): gcc can generate slightly better code for stuff like "nbits % BITS_PER_LONG" when it knows nbits is not negative. Since negative size bitmaps or shift amounts don't make sense, change these parameters of bitmap_shift_right to unsigned. The expressions involving "lim - 1" are still ok, since if lim is 0 the loop is never executed. Also use "shift" and "nbits" consistently for the parameter names. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/bitmap.c: elide bitmap_copy_le on little-endianRasmus Villemoes
On little-endian, there's no reason to have an extra, presumably less efficient, way of copying a bitmap. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13lib/bitmap.c: change prototype of bitmap_copy_leRasmus Villemoes
Make the prototype of bitmap_copy_le the same as bitmap_copy's. All other bitmap_* functions take unsigned long* parameters; there's no reason this should be special. The only current user is the static inline uwb_mas_bm_copy_le, which already does the void* laundering, so the end users can pass their u8 or __le32 buffers without a cast. Furthermore, this allows us to simply let bitmap_copy_le be an alias for bitmap_copy on little-endian; see next patch. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third set of updates from Andrew Morton: - the rest of MM [ This includes getting rid of the numa hinting bits, in favor of just generic protnone logic. Yay. - Linus ] - core kernel - procfs - some of lib/ (lots of lib/ material this time) * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (104 commits) lib/lcm.c: replace include lib/percpu_ida.c: remove redundant includes lib/strncpy_from_user.c: replace module.h include lib/stmp_device.c: replace module.h include lib/sort.c: move include inside #if 0 lib/show_mem.c: remove redundant include lib/radix-tree.c: change to simpler include lib/plist.c: remove redundant include lib/nlattr.c: remove redundant include lib/kobject_uevent.c: remove redundant include lib/llist.c: remove redundant include lib/md5.c: simplify include lib/list_sort.c: rearrange includes lib/genalloc.c: remove redundant include lib/idr.c: remove redundant include lib/halfmd4.c: simplify includes lib/dynamic_queue_limits.c: simplify includes lib/sort.c: use simpler includes lib/interval_tree.c: simplify includes hexdump: make it return number of bytes placed in buffer ...
2015-02-12lib/lcm.c: replace includeRasmus Villemoes
We don't need all the stuff kernel.h pulls in; just compiler.h since export.h doesn't do necessary #includes. This removes more than 100 dependencies. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12lib/percpu_ida.c: remove redundant includesRasmus Villemoes
These three #includes seem to be completely redundant: Removing them yields identical objdump -d output for each of {allyes,allno,def}config, and neither included file end up in the generated dependency file through some recursive include. In total, about 50 lines are eliminated from .percpu.o.cmd. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12lib/strncpy_from_user.c: replace module.h includeRasmus Villemoes
strncpy_from_user.c only needs EXPORT_SYMBOL, so just include compiler.h and export.h instead of the whole module.h machinery. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
