when n < pool->hint
commit d046b770c9fc36ccb19c27afdb8322220108cbc7 upstream.
The check for invoking iommu->lazy_flush() from iommu_tbl_range_alloc()
has to be refactored so that we only call ->lazy_flush() if it is
non-null.
I had a sparc kernel that was crashing when I was trying to process some
very large perf.data files- the crash happens when the scsi driver calls
into dma_4v_map_sg and thus the iommu_tbl_range_alloc().
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
commit 2d3862d26e67a59340ba1cf1748196c76c5787de upstream.
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel
gunzip error.
| early console in decompress_kernel
| decompress_kernel:
| input: [0x807f2143b4-0x807ff61aee]
| output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len
| boot via startup_64
| KASLR using RDTSC...
| new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size
| decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee]
| Decompressing Linux... gz...
| uncompression error
| -- System halted
the new buffer is at 0x46fe000000ULL, decompressor_gzip is using
0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap
that len to 0x01ffffff and decompress fails later.
We could hit this problem with crashkernel booting that uses kexec loading
kernel above 4GiB.
We have decompress_* support:
1. inbuf[]/outbuf[] for kernel preboot.
2. inbuf[]/flush() for initramfs
3. fill()/flush() for initrd.
This bug only affect kernel preboot path that use outbuf[].
Add __decompress and take real out_buf_len for gunzip instead of guessing
wrong buf size.
Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length)
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Using a 64 bit constant generates "warning: integer constant is too
large for 'long' type" on 32 bit platforms. Instead use ~0ul and
BITS_PER_LONG.
Detected by Andrew Morton on ARMD.
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Without this we end up using the previous name of the compressor in the
loop in unpack_rootfs. For example we get errors like "compression
method gzip not configured" even when we have CONFIG_DECOMPRESS_GZIP
enabled.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
If dma-debug is disabled due to a memory error, DMA unmaps do not affect
the dma_active_cacheline radix tree anymore, and debug_dma_assert_idle()
can print false warnings.
Disable debug_dma_assert_idle() when dma_debug_disabled() is true.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
Fixes: 0abdd7a81b7e ("dma-debug: introduce debug_dma_assert_idle()")
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: James Bottomley <JBottomley@Parallels.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Horia Geanta <horia.geanta@freescale.com>
Cc: <stable@vger.kernel.org>
A hexdump with a buf not aligned to the groupsize causes
non-naturally-aligned memory accesses. This was causing a kernel panic
on the processor BlackFin BF527, when such an unaligned buffer was fed
by the function ubifs_scanned_corruption in fs/ubifs/scan.c .
To fix this, change accesses to the contents of the buffer so they go
through get_unaligned(). This change should be harmless to unaligned-
access-capable architectures, and any performance hit should be anyway
dwarfed by the snprintf() processing time.
Signed-off-by: Horacio Mijail Antón Quiles <hmijail@gmail.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Joe Perches <joe@perches.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Using __printf attributes helps to detect several format string issues
at compile time (even though -Wformat-security is currently disabled in
Makefile). For example it can detect when formatting a pointer as a
number, like the issue fixed in commit a3fa71c40f18 ("wl18xx: show
rx_frames_per_rates as an array as it really is"), or when the arguments
do not match the format string, c.f. for example commit 5ce1aca81435
("reiserfs: fix __RASSERT format string").
To prevent similar bugs in the future, add a __printf attribute to every
function prototype which needs one in include/linux/ and lib/. These
functions were mostly found by using gcc's -Wsuggest-attribute=format
flag.
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Cc: Felipe Balbi <balbi@ti.com>
Pull networking fixes from David Miller:
1) Missing list head init in bluetooth hidp session creation, from Tedd
Ho-Jeong An.
2) Don't leak SKB in bridge netfilter error paths, from Florian
Westphal.
3) ipv6 netdevice private leak in netfilter bridging, fixed by Julien
Grall.
4) Fix regression in IP over hamradio bpq encapsulation, from Ralf
Baechle.
5) Fix race between rhashtable resize events and table walks, from Phil
Sutter.
6) Missing validation of IFLA_VF_INFO netlink attributes, fix from
Daniel Borkmann.
7) Missing security layer socket state initialization in tipc code,
from Stephen Smalley.
8) Fix shared IRQ handling in boomerang 3c59x interrupt handler, from
Denys Vlasenko.
9) Missing minor_idr destroy on module unload on macvtap driver, from
Johannes Thumshirn.
10) Various pktgen kernel thread races, from Oleg Nesterov.
11) Fix races that can cause packets to be processed in the backlog even
after a device attached to that SKB has been fully unregistered.
From Julian Anastasov.
12) bcmgenet driver doesn't account packet drops vs. errors properly,
fix from Petri Gynther.
13) Array index validation and off by one fix in DSA layer from Florian
Fainelli
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (66 commits)
can: replace timestamp as unique skb attribute
ARM: dts: dra7x-evm: Prevent glitch on DCAN1 pinmux
can: c_can: Fix default pinmux glitch at init
can: rcar_can: unify error messages
can: rcar_can: print request_irq() error code
can: rcar_can: fix typo in error message
can: rcar_can: print signed IRQ #
can: rcar_can: fix IRQ check
net: dsa: Fix off-by-one in switch address parsing
net: dsa: Test array index before use
net: switchdev: don't abort unsupported operations
net: bcmgenet: fix accounting of packet drops vs errors
cdc_ncm: update specs URL
Doc: z8530book: Fix typo in API-z8530-sync-txdma-open.html
net: inet_diag: always export IPV6_V6ONLY sockopt for listening sockets
bridge: mdb: allow the user to delete mdb entry if there's a querier
net: call rcu_read_lock early in process_backlog
net: do not process device backlog during unregistration
bridge: fix potential crash in __netdev_pick_tx()
net: axienet: Fix devm_ioremap_resource return value check
If rhashtable_walk_next detects a resize operation in progress, it jumps
to the new table and continues walking that one. But it misses to drop
the reference to it's current item, leading it to continue traversing
the new table's bucket in which the current item is sorted into, and
after reaching that bucket's end continues traversing the new table's
second bucket instead of the first one, thereby potentially missing
items.
This fixes the rhashtable runtime test for me. Bug probably introduced
by Herbert Xu's patch eddee5ba ("rhashtable: Fix walker behaviour during
rehash") although not explicitly tested.
Fixes: eddee5ba ("rhashtable: Fix walker behaviour during rehash")
Signed-off-by: Phil Sutter <phil@nwl.cc>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
KASAN_SHADOW_OFFSET is purely arch specific setting,
so it should be in arch's Kconfig file.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Alexander Popov <alpopov@ptsecurity.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Link: http://lkml.kernel.org/r/1435828178-10975-7-git-send-email-a.ryabinin@samsung.com
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"It's been a busy development cycle for target-core in a number of
different areas.
The fabric API usage for se_node_acl allocation is now within
target-core code, dropping the external API callers for all fabric
drivers tree-wide.
There is a new conversion to RCU hlists for se_node_acl and
se_portal_group LUN mappings, that turns fast-past LUN lookup into a
completely lockless code-path. It also removes the original
hard-coded limitation of 256 LUNs per fabric endpoint.
The configfs attributes for backends can now be shared between core
and driver code, allowing existing drivers to use common code while
still allowing flexibility for new backend provided attributes.
The highlights include:
- Merge sbc_verify_dif_* into common code (sagi)
- Remove iscsi-target support for obsolete IFMarker/OFMarker
(Christophe Vu-Brugier)
- Add bidi support in target/user backend (ilias + vangelis + agover)
- Move se_node_acl allocation into target-core code (hch)
- Add crc_t10dif_update common helper (akinobu + mkp)
- Handle target-core odd SGL mapping for data transfer memory
(akinobu)
- Move transport ID handling into target-core (hch)
- Move task tag into struct se_cmd + support 64-bit tags (bart)
- Convert se_node_acl->device_list[] to RCU hlist (nab + hch +
paulmck)
- Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch +
paulmck)
- Simplify target backend driver registration (hch)
- Consolidate + simplify target backend attribute implementations
(hch + nab)
- Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch)
- Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab)
- Drop unnecessary core_tpg_register TFO parameter (nab)
- Use 64-bit LUNs tree-wide (hannes)
- Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits)
target: Bump core version to v5.0
target: remove target_core_configfs.h
target: remove unused TARGET_CORE_CONFIG_ROOT define
target: consolidate version defines
target: implement WRITE_SAME with UNMAP bit using ->execute_unmap
target: simplify UNMAP handling
target: replace se_cmd->execute_rw with a protocol_data field
target/user: Fix inconsistent kmap_atomic/kunmap_atomic
target: Send UA when changing LUN inventory
target: Send UA upon LUN RESET tmr completion
target: Send UA on ALUA target port group change
target: Convert se_lun->lun_deve_lock to normal spinlock
target: use 'se_dev_entry' when allocating UAs
target: Remove 'ua_nacl' pointer from se_ua structure
target_core_alua: Correct UA handling when switching states
xen-scsiback: Fix compile warning for 64-bit LUN
target: Remove TARGET_MAX_LUNS_PER_TRANSPORT
target: use 64-bit LUNs
target: Drop duplicate + unused se_dev_check_wce
target: Drop unnecessary core_tpg_register TFO parameter
Pull scheduler fixes from Ingo Molnar:
"Debug info and other statistics fixes and related enhancements"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/numa: Fix numa balancing stats in /proc/pid/sched
sched/numa: Show numa_group ID in /proc/sched_debug task listings
sched/debug: Move print_cfs_rq() declaration to kernel/sched/sched.h
sched/stat: Expose /proc/pid/schedstat if CONFIG_SCHED_INFO=y
sched/stat: Simplify the sched_info accounting dependency
Both CONFIG_SCHEDSTATS=y and CONFIG_TASK_DELAY_ACCT=y track task
sched_info, which results in ugly #if clauses.
Simplify the code by introducing a synthethic CONFIG_SCHED_INFO
switch, selected by both.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: a.p.zijlstra@chello.nl
Cc: ricklind@us.ibm.com
Link: http://lkml.kernel.org/r/8d19eef800811a94b0f91bcbeb27430a884d7433.1435255405.git.naveen.n.rao@linux.vnet.ibm.com
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Just a few kbuild core commits this time:
- kallsyms fix for CONFIG_XIP_KERNEL
- bashisms in scripts/link-vmlinux.sh fixed
- workaround to make DEBUG_INFO_REDUCED more useful yet still space
efficient
- clang is not wrongly detected when cross-compiling"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: include core debug info when DEBUG_INFO_REDUCED
scripts: link-vmlinux: Don't pass page offset to kallsyms if XIP Kernel
scripts: fix link-vmlinux.sh bash-ism
Makefile: Fix detection of clang when cross-compiling
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull module_init replacement part two from Paul Gortmaker:
"Replace module_init with appropriate alternate initcall in non
modules.
This series converts non-modular code that is using the module_init()
call to hook itself into the system to instead use one of our
alternate priority initcalls.
Unlike the previous series that used device_initcall and hence was a
runtime no-op, these commits change to one of the alternate initcalls,
because (a) we have them and (b) it seems like the right thing to do.
For example, it would seem logical to use arch_initcall for arch
specific setup code and fs_initcall for filesystem setup code.
This does mean however, that changes in the init ordering will be
taking place, and so there is a small risk that some kind of implicit
init ordering issue may lie uncovered. But I think it is still better
to give these ones sensible priorities than to just assign them all to
device_initcall in order to exactly preserve the old ordering.
Thad said, we have already made similar changes in core kernel code in
commit c96d6660dc65 ("kernel: audit/fix non-modular users of
module_init in core code") without any regressions reported, so this
type of change isn't without precedent. It has also got the same
local testing and linux-next coverage as all the other pull requests
that I'm sending for this merge window have got.
Once again, there is an unused module_exit function removal that shows
up as an outlier upon casual inspection of the diffstat"
* tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling
x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling
mm/page_owner.c: use late_initcall to hook in enabling
lib/list_sort: use late_initcall to hook in self tests
arm: use subsys_initcall in non-modular pl320 IPC code
powerpc: don't use module_init for non-modular core hugetlb code
powerpc: use subsys_initcall for Freescale Local Bus
x86: don't use module_init for non-modular core bootflag code
netfilter: don't use module_init/exit in core IPV4 code
fs/notify: don't use module_init for non-modular inotify_user code
mm: replace module_init usages with subsys_initcall in nommu.c
Merge third patchbomb from Andrew Morton:
- the rest of MM
- scripts/gdb updates
- ipc/ updates
- lib/ updates
- MAINTAINERS updates
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits)
genalloc: rename of_get_named_gen_pool() to of_gen_pool_get()
genalloc: rename dev_get_gen_pool() to gen_pool_get()
x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit
MAINTAINERS: add zpool
MAINTAINERS: BCACHE: Kent Overstreet has changed email address
MAINTAINERS: move Jens Osterkamp to CREDITS
MAINTAINERS: remove unused nbd.h pattern
MAINTAINERS: update brcm gpio filename pattern
MAINTAINERS: update brcm dts pattern
MAINTAINERS: update sound soc intel patterns
MAINTAINERS: remove website for paride
MAINTAINERS: update Emulex ocrdma email addresses
bcache: use kvfree() in various places
libcxgbi: use kvfree() in cxgbi_free_big_mem()
target: use kvfree() in session alloc and free
IB/ehca: use kvfree() in ipz_queue_{cd}tor()
drm/nouveau/gem: use kvfree() in u_free()
drm: use kvfree() in drm_free_large()
cxgb4: use kvfree() in t4_free_mem()
cxgb3: use kvfree() in cxgb_free_mem()
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Main excitement here is Peter Zijlstra's lockless rbtree optimization
to speed module address lookup. He found some abusers of the module
lock doing that too.
A little bit of parameter work here too; including Dan Streetman's
breaking up the big param mutex so writing a parameter can load
another module (yeah, really). Unfortunately that broke the usual
suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were
appended too"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits)
modules: only use mod->param_lock if CONFIG_MODULES
param: fix module param locks when !CONFIG_SYSFS.
rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE()
module: add per-module param_lock
module: make perm const
params: suppress unused variable error, warn once just in case code changes.
modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'.
kernel/module.c: avoid ifdefs for sig_enforce declaration
kernel/workqueue.c: remove ifdefs over wq_power_efficient
kernel/params.c: export param_ops_bool_enable_only
kernel/params.c: generalize bool_enable_only
kernel/module.c: use generic module param operaters for sig_enforce
kernel/params: constify struct kernel_param_ops uses
sysfs: tightened sysfs permission checks
module: Rework module_addr_{min,max}
module: Use __module_address() for module_address_lookup()
module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING
module: Optimize __module_address() using a latched RB-tree
rbtree: Implement generic latch_tree
seqlock: Introduce raw_read_seqcount_latch()
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"Outside of our usual batch of fixes, this integrates the subvolume
quota updates that Qu Wenruo from Fujitsu has been working on for a
few releases now. He gets an extra gold star for making btrfs smaller
this time, and fixing a number of quota corners in the process.
Dave Sterba tested and integrated Anand Jain's sysfs improvements.
Outside of exporting a symbol (ack'd by Greg) these are all internal
to btrfs and it's mostly cleanups and fixes. Anand also attached some
of our sysfs objects to our internal device management structs instead
of an object off the super block. It will make device management
easier overall and it's a better fit for how the sysfs files are used.
None of the existing sysfs files are moved around.
Thanks for all the fixes everyone"
* 'for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (87 commits)
btrfs: delayed-ref: double free in btrfs_add_delayed_tree_ref()
Btrfs: Check if kobject is initialized before put
lib: export symbol kobject_move()
Btrfs: sysfs: add support to show replacing target in the sysfs
Btrfs: free the stale device
Btrfs: use received_uuid of parent during send
Btrfs: fix use-after-free in btrfs_replay_log
btrfs: wait for delayed iputs on no space
btrfs: qgroup: Make snapshot accounting work with new extent-oriented qgroup.
btrfs: qgroup: Add the ability to skip given qgroup for old/new_roots.
btrfs: ulist: Add ulist_del() function.
btrfs: qgroup: Cleanup the old ref_node-oriented mechanism.
btrfs: qgroup: Switch self test to extent-oriented qgroup mechanism.
btrfs: qgroup: Switch to new extent-oriented qgroup mechanism.
btrfs: qgroup: Switch rescan to new mechanism.
btrfs: qgroup: Add new qgroup calculation function btrfs_qgroup_account_extents().
btrfs: backref: Add special time_seq == (u64)-1 case for btrfs_find_all_roots().
btrfs: qgroup: Add new function to record old_roots.
btrfs: qgroup: Record possible quota-related extent for qgroup.
btrfs: qgroup: Add function qgroup_update_counters().
To be consistent with other kernel interface namings, rename
of_get_named_gen_pool() to of_gen_pool_get(). In the original function
name "_named" suffix references to a device tree property, which contains
a phandle to a device and the corresponding device driver is assumed to
register a gen_pool object.
Due to a weak relation and to avoid any confusion (e.g. in future
possible scenario if gen_pool objects are named) the suffix is removed.
[sfr@canb.auug.org.au: crypto/marvell/cesa - fix up for of_get_named_gen_pool() rename]
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Boris BREZILLON <boris.brezillon@free-electrons.com>
To be consistent with other genalloc interface namings, rename
dev_get_gen_pool() to gen_pool_get(). The original omitted "dev_" prefix
is removed, since it points to argument type of the function, and so it
does not bring any useful information.
[akpm@linux-foundation.org: update arch/arm/mach-socfpga/pm.c]
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Alan Tull <atull@opensource.altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Kevin Hilman <khilman@linaro.org>
do_device_access() takes a separate parameter to indicate the direction of
data transfer, which it used to use to select the appropriate function out
of sg_pcopy_{to,from}_buffer(). However these two functions now have
So this patch makes it bypass these wrappers and call the underlying
function sg_copy_buffer() directly; this has the same calling style as
do_device_access() i.e. a separate direction-of-transfer parameter and no
pointers-to-const, so skipping the wrappers not only eliminates the
warning, it also make the code simpler :)
[akpm@linux-foundation.org: fix very broken build]
Signed-off-by: Dave Gordon <david.s.gordon@intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
The 'buf' parameter of sg(p)copy_from_buffer() can and should be
const-qualified, although because of the shared implementation of
_to_buffer() and _from_buffer(), we have to cast this away internally.
This means that callers who have a 'const' buffer containing the data to
be copied to the sg-list no longer have to cast away the const-ness
themselves. It also enables improved coverage by code analysis tools.
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
The kerneldoc for the functions doesn't match the code; the last two
parameters (buflen, skip) have been transposed, which is confusing,
especially as they're both integral types and the compiler won't warn
about swapping them.
These functions and the kerneldoc were introduced in commit:
df642cea lib/scatterlist: introduce sg_pcopy_from_buffer() ...
Author: Akinobu Mita <akinobu.mita@gmail.com>
Date: Mon Jul 8 16:01:54 2013 -0700
The only difference between sg_pcopy_{from,to}_buffer() and
sg_copy_{from,to}_buffer() is an additional argument that
specifies the number of bytes to skip the SG list before
copying.
The functions have the extra argument at the end, but the kerneldoc
lists it in penultimate position.
Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm
Pull libnvdimm subsystem from Dan Williams:
"The libnvdimm sub-system introduces, in addition to the
libnvdimm-core, 4 drivers / enabling modules:
NFIT:
Instantiates an "nvdimm bus" with the core and registers memory
devices (NVDIMMs) enumerated by the ACPI 6.0 NFIT (NVDIMM Firmware
Interface table).
After registering NVDIMMs the NFIT driver then registers "region"
devices. A libnvdimm-region defines an access mode and the
boundaries of persistent memory media. A region may span multiple
NVDIMMs that are interleaved by the hardware memory controller. In
turn, a libnvdimm-region can be carved into a "namespace" device and
bound to the PMEM or BLK driver which will attach a Linux block
device (disk) interface to the memory.
PMEM:
Initially merged in v4.1 this driver for contiguous spans of
persistent memory address ranges is re-worked to drive
PMEM-namespaces emitted by the libnvdimm-core.
In this update the PMEM driver, on x86, gains the ability to assert
that writes to persistent memory have been flushed all the way
through the caches and buffers in the platform to persistent media.
See memcpy_to_pmem() and wmb_pmem().
BLK:
This new driver enables access to persistent memory media through
"Block Data Windows" as defined by the NFIT. The primary difference
of this driver to PMEM is that only a small window of persistent
memory is mapped into system address space at any given point in
time.
Per-NVDIMM windows are reprogrammed at run time, per-I/O, to access
different portions of the media. BLK-mode, by definition, does not
support DAX.
BTT:
This is a library, optionally consumed by either PMEM or BLK, that
converts a byte-accessible namespace into a disk with atomic sector
update semantics (prevents sector tearing on crash or power loss).
The sinister aspect of sector tearing is that most applications do
not know they have a atomic sector dependency. At least today's
disk's rarely ever tear sectors and if they do one almost certainly
gets a CRC error on access. NVDIMMs will always tear and always
silently. Until an application is audited to be robust in the
presence of sector-tearing the usage of BTT is recommended.
Thanks to: Ross Zwisler, Jeff Moyer, Vishal Verma, Christoph Hellwig,
Ingo Molnar, Neil Brown, Boaz Harrosh, Robert Elliott, Matthew Wilcox,
Andy Rudoff, Linda Knippers, Toshi Kani, Nicholas Moulin, Rafael
Wysocki, and Bob Moore"
* tag 'libnvdimm-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: (33 commits)
arch, x86: pmem api for ensuring durability of persistent memory updates
libnvdimm: Add sysfs numa_node to NVDIMM devices
libnvdimm: Set numa_node to NVDIMM devices
acpi: Add acpi_map_pxm_to_online_node()
libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only
pmem: flag pmem block devices as non-rotational
libnvdimm: enable iostat
pmem: make_request cleanups
libnvdimm, pmem: fix up max_hw_sectors
libnvdimm, blk: add support for blk integrity
libnvdimm, btt: add support for blk integrity
fs/block_dev.c: skip rw_page if bdev has integrity
libnvdimm: Non-Volatile Devices
tools/testing/nvdimm: libnvdimm unit test infrastructure
libnvdimm, nfit, nd_blk: driver for BLK-mode access persistent memory
nd_btt: atomic sector updates
libnvdimm: infrastructure for btt devices
libnvdimm: write blk label set
libnvdimm: write pmem label set
libnvdimm: blk labels and namespace instantiation
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
Based on an original patch by Ross Zwisler [1].
Writes to persistent memory have the potential to be posted to cpu
cache, cpu write buffers, and platform write buffers (memory controller)
before being committed to persistent media. Provide apis,
memcpy_to_pmem(), wmb_pmem(), and memremap_pmem(), to write data to
pmem and assert that it is durable in PMEM (a persistent linear address
range). A '__pmem' attribute is added so sparse can track proper usage
of pointers to pmem.
This continues the status quo of pmem being x86 only for 4.2, but
reworks to ioremap, and wider implementation of memremap() will enable
other archs in 4.3.
[1]: https://lists.01.org/pipermail/linux-nvdimm/2015-May/000932.html
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
[djbw: various reworks]
There's probably not many slashes in the name, but starting over when
we see one feels wrong.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Strings are sometimes sanitized by replacing a certain character (often
'/') by another (often '!'). In a few places, this is done the same way
Schlemiel the Painter would do it. Others are slightly smarter but still
do multiple strchr() calls. Introduce strreplace() to do this using a
single function call and a single pass over the string.
One would expect the return value to be one of three things: void, s, or
the number of replacements made. I chose the fourth, returning a pointer
to the end of the string. This is more likely to be useful (for example
allowing the caller to avoid a strlen call).
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Neil Brown <neilb@suse.de>
Currently we use per-cpu array to hold pointers to preallocated nodes.
Let's replace it with linked list. On x86_64 it saves 256 bytes in
per-cpu ELF section which may translate into freeing up 2MB of memory for
NR_CPUS==8192.
[akpm@linux-foundation.org: fix comment, coding style]
bitmap_print_to_pagebuf uses scnprintf to copy the cpumask/list to page
buffer. It handles the newline and trailing null character explicitly.
It's unnecessary and also partially duplicated as scnprintf already adds
trailing null character. The newline can be passed through format
string to scnprintf. This patch does that simplification.
However theoretically there's one behavior difference: when the buffer
is too small, the original code would still output '\n' at the end while
the new code(with this patch) would just continue to print the formatted
string. Since this function is dealing with only page buffers, it's
highly unlikely to hit that corner case.
This patch will help in auditing the users of bitmap_print_to_pagebuf to
verify that the buffer passed is large enough and get rid of it
completely by replacing them with direct scnprintf()
[akpm@linux-foundation.org: tweak comment]
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Suggested-by: Pawel Moll <Pawel.Moll@arm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
In case the call side is not providing a swap function, we either use a
32 bit or a generic swap function. When swapping around pointers on 64
bit architectures falling back to use the generic swap function seems
like an unnecessary waste.
There at least 9 users ('sort' is of difficult to grep for) of sort()
and all of them use the sort function without a customized swap
function. Furthermore, they are all using pointers to swap around:
arch/x86/kernel/e820.c:sanitize_e820_map()
arch/x86/mm/extable.c:sort_extable()
drivers/acpi/fan.c:acpi_fan_get_fps()
fs/btrfs/super.c:btrfs_descending_sort_devices()
fs/xfs/libxfs/xfs_dir2_block.c:xfs_dir2_sf_to_block()
kernel/range.c:clean_sort_range()
mm/memcontrol.c:__mem_cgroup_usage_register_event()
sound/pci/hda/hda_auto_parser.c:snd_hda_parse_pin_defcfg()
sound/pci/hda/hda_auto_parser.c:sort_pins_by_sequence()
Obviously, we could improve the swap for other sizes as well
but this is overkill at this point.
A simple test shows sorting a 400 element array (try to stay in one
page) with either with u32_swap() or u64_swap() show that the theory
actually works. This test was done on a x86_64 (Intel Xeon E5-4610)
machine.
- swap_32:
NumSamples = 100; Min = 48.00; Max = 49.00
Mean = 48.320000; Variance = 0.217600; SD = 0.466476; Median 48.000000
each * represents a count of 1
48.0000 - 48.1000 [ 68]: ********************************************************************
48.1000 - 48.2000 [ 0]:
48.2000 - 48.3000 [ 0]:
48.3000 - 48.4000 [ 0]:
48.4000 - 48.5000 [ 0]:
48.5000 - 48.6000 [ 0]:
48.6000 - 48.7000 [ 0]:
48.7000 - 48.8000 [ 0]:
48.8000 - 48.9000 [ 0]:
48.9000 - 49.0000 [ 32]: ********************************
- swap_64:
NumSamples = 100; Min = 44.00; Max = 63.00
Mean = 48.250000; Variance = 18.687500; SD = 4.322904; Median 47.000000
44.0000 - 45.9000 [ 15]: ***************
45.9000 - 47.8000 [ 37]: *************************************
47.8000 - 49.7000 [ 39]: ***************************************
49.7000 - 51.6000 [ 0]:
51.6000 - 53.5000 [ 0]:
53.5000 - 55.4000 [ 0]:
55.4000 - 57.3000 [ 0]:
57.3000 - 59.2000 [ 1]: *
59.2000 - 61.1000 [ 3]: ***
61.1000 - 63.0000 [ 5]: *****
- swap_72:
NumSamples = 100; Min = 53.00; Max = 71.00
Mean = 55.070000; Variance = 21.565100; SD = 4.643824; Median 53.000000
53.0000 - 54.8000 [ 73]: *************************************************************************
54.8000 - 56.6000 [ 9]: *********
56.6000 - 58.4000 [ 9]: *********
58.4000 - 60.2000 [ 0]:
60.2000 - 62.0000 [ 0]:
62.0000 - 63.8000 [ 0]:
63.8000 - 65.6000 [ 0]:
65.6000 - 67.4000 [ 1]: *
67.4000 - 69.2000 [ 4]: ****
69.2000 - 71.0000 [ 4]: ****
- test program:
static int cmp_32(const void *a, const void *b)
u32 l = *(u32 *)a;
u32 r = *(u32 *)b;
if (l < r)
return -1;
if (l > r)
return 1;
return 0;
static int cmp_64(const void *a, const void *b)
u64 l = *(u64 *)a;
u64 r = *(u64 *)b;
if (l < r)
return -1;
if (l > r)
return 1;
return 0;
static int cmp_72(const void *a, const void *b)
u32 l = get_unaligned((u32 *) a);
u32 r = get_unaligned((u32 *) b);
if (l < r)
return -1;
if (l > r)
return 1;
return 0;
static void init_array32(void *array)
u32 *a = array;
int i;
a[0] = 3821;
for (i = 1; i < ARRAY_ELEMENTS; i++)
a[i] = next_pseudo_random32(a[i-1]);
static void init_array64(void *array)
u64 *a = array;
int i;
a[0] = 3821;
static void init_array72(void *array)
char *p;
u32 v;
int i;
v = 3821;
for (i = 0; i < ARRAY_ELEMENTS; i++) {
p = (char *)array + (i * 9);
put_unaligned(v, (u32*) p);
v = next_pseudo_random32(v);
static void sort_test(void (*init)(void *array),
int (*cmp) (const void *, const void *),
void *array, size_t size)
ktime_t start, stop;
int i;
for (i = 0; i < 10000; i++) {
init(array);
local_irq_disable();
start = ktime_get();
sort(array, ARRAY_ELEMENTS, size, cmp, NULL);
stop = ktime_get();
local_irq_enable();
if (i > 10000 - 101)
pr_info("%lld\n", ktime_to_us(ktime_sub(stop, start)));
static void *create_array(size_t size)
void *array;
array = kmalloc(ARRAY_ELEMENTS * size, GFP_KERNEL);
if (!array)
return NULL;
return array;
static int perform_test(size_t size)
void *array;
array = create_array(size);
if (!array)
return -ENOMEM;
pr_info("test element size %d bytes\n", (int)size);
switch (size) {
case 4:
sort_test(init_array32, cmp_32, array, size);
break;
case 8:
sort_test(init_array64, cmp_64, array, size);
break;
case 9:
sort_test(init_array72, cmp_72, array, size);
break;
kfree(array);
return 0;
static int __init sort_tests_init(void)
int err;
err = perform_test(sizeof(u32));
if (err)
return err;
err = perform_test(sizeof(u64));
if (err)
return err;
err = perform_test(sizeof(u64)+1);
if (err)
return err;
return 0;
static void __exit sort_tests_exit(void)
module_init(sort_tests_init);
module_exit(sort_tests_exit);
MODULE_LICENSE("GPL v2");
MODULE_AUTHOR("Daniel Wagner");
MODULE_DESCRIPTION("sort perfomance tests");
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
The test data arrays, containing pointers to test strings, are never
modified, so they can be const, too. Hence mark them "const" and
"__initconst".
This moves 28 pointers from ".init.data" to ".init.rodata".
bitmap_parselist("", &mask, nmaskbits) will erroneously set bit zero in
the mask. The same bug is visible in cpumask_parselist() since it is
layered on top of the bitmask code, e.g. if you boot with "isolcpus=",
you will actually end up with cpu zero isolated.
The bug was introduced in commit 4b060420a596 ("bitmap, irq: add
smp_affinity_list interface to /proc/irq") when bitmap_parselist() was
generalized to support userspace as well as kernelspace.
Fixes: 4b060420a596 ("bitmap, irq: add smp_affinity_list interface to /proc/irq")
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc updates from Michael Ellerman:
- disable the 32-bit vdso when building LE, so we can build with a
64-bit only toolchain.
- EEH fixes from Gavin & Richard.
- enable the sys_kcmp syscall from Laurent.
- sysfs control for fastsleep workaround from Shreyas.
- expose OPAL events as an irq chip by Alistair.
- MSI ops moved to pci_controller_ops by Daniel.
- fix for kernel to userspace backtraces for perf from Anton.
- merge pseries and pseries_le defconfigs from Cyril.
- CXL in-kernel API from Mikey.
- OPAL prd driver from Jeremy.
- fix for DSCR handling & tests from Anshuman.
- Powernv flash mtd driver from Cyril.
- dynamic DMA Window support on powernv from Alexey.
- LLVM clang fixes & workarounds from Anton.
- reworked version of the patch to abort syscalls when transactional.
- fix the swap encoding to support 4TB, from Aneesh.
- various fixes as usual.
- Freescale updates from Scott: Highlights include more 8xx
optimizations, an e6500 hugetlb optimization, QMan device tree nodes,
t1024/t1023 support, and various fixes and cleanup.
* tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits)
cxl: Fix typo in debug print
cxl: Add CXL_KERNEL_API config option
powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma()
powerpc/mm: Change the swap encoding in pte.
powerpc/mm: PTE_RPN_MAX is not used, remove the same
powerpc/tm: Abort syscalls in active transactions
powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off
powerpc/include: Add opal-prd to installed uapi headers
powerpc/powernv: fix construction of opal PRD messages
powerpc/powernv: Increase opal-irqchip initcall priority
powerpc: Make doorbell check preemption safe
powerpc/powernv: pnv_init_idle_states() should only run on powernv
macintosh/nvram: Remove as unused
powerpc: Don't use gcc specific options on clang
powerpc: Don't use -mno-strict-align on clang
powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it
powerpc: Only use -mabi=altivec if toolchain supports it
powerpc: Fix duplicate const clang warning in user access code
vfio: powerpc/spapr: Support Dynamic DMA windows
vfio: powerpc/spapr: Register memory and define IOMMU v2
Pull trivial tree updates from Jiri Kosina:
"As usual, mostly comment, kerneldoc and printk() fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
lpfc: Grammar s/an negative/a negative/
ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/
cx25821: cx25821-medusa-reg.h: fix 0x0x prefix
lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants
rapidio: Fix kerneldoc and comment
qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config()
treewide: Kconfig: fix wording / spelling
usb/serial: fix grammar in Kconfig help text for FTDI_SIO
megaraid_sas: fix kerneldoc
netfilter: ebtables: fix comment grammar
drm/radeon: fix comment
isdn: fix grammar in comment
ARM: KVM: fix comment
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into anand
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.2:
API:
- Convert RNG interface to new style.
- New AEAD interface with one SG list for AD and plain/cipher text.
All external AEAD users have been converted.
- New asymmetric key interface (akcipher).
Algorithms:
- Chacha20, Poly1305 and RFC7539 support.
- New RSA implementation.
- Jitter RNG.
- DRBG is now seeded with both /dev/random and Jitter RNG. If kernel
pool isn't ready then DRBG will be reseeded when it is.
- DRBG is now the default crypto API RNG, replacing krng.
- 842 compression (previously part of powerpc nx driver).
Drivers:
- Accelerated SHA-512 for arm64.
- New Marvell CESA driver that supports DMA and more algorithms.
- Updated powerpc nx 842 support.
- Added support for SEC1 hardware to talitos"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (292 commits)
crypto: marvell/cesa - remove COMPILE_TEST dependency
crypto: algif_aead - Temporarily disable all AEAD algorithms
crypto: af_alg - Forbid the use internal algorithms
crypto: echainiv - Only hold RNG during initialisation
crypto: seqiv - Add compatibility support without RNG
crypto: eseqiv - Offer normal cipher functionality without RNG
crypto: chainiv - Offer normal cipher functionality without RNG
crypto: user - Add CRYPTO_MSG_DELRNG
crypto: user - Move cryptouser.h to uapi
crypto: rng - Do not free default RNG when it becomes unused
crypto: skcipher - Allow givencrypt to be NULL
crypto: sahara - propagate the error on clk_disable_unprepare() failure
crypto: rsa - fix invalid select for AKCIPHER
crypto: picoxcell - Update to the current clk API
crypto: nx - Check for bogus firmware properties
crypto: marvell/cesa - add DT bindings documentation
crypto: marvell/cesa - add support for Kirkwood and Dove SoCs
crypto: marvell/cesa - add support for Orion SoCs
crypto: marvell/cesa - add allhwsupport module parameter
crypto: marvell/cesa - add support for all armada SoCs
Pull timer updates from Thomas Gleixner:
"A rather largish update for everything time and timer related:
- Cache footprint optimizations for both hrtimers and timer wheel
- Lower the NOHZ impact on systems which have NOHZ or timer migration
disabled at runtime.
- Optimize run time overhead of hrtimer interrupt by making the clock
offset updates smarter
- hrtimer cleanups and removal of restrictions to tackle some
problems in sched/perf
- Some more leap second tweaks
- Another round of changes addressing the 2038 problem
- First step to change the internals of clock event devices by
introducing the necessary infrastructure
- Allow constant folding for usecs/msecs_to_jiffies()
- The usual pile of clockevent/clocksource driver updates
The hrtimer changes contain updates to sched, perf and x86 as they
depend on them plus changes all over the tree to cleanup API changes
and redundant code, which got copied all over the place. The y2038
changes touch s390 to remove the last non 2038 safe code related to
boot/persistant clock"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits)
clocksource: Increase dependencies of timer-stm32 to limit build wreckage
timer: Minimize nohz off overhead
timer: Reduce timer migration overhead if disabled
timer: Stats: Simplify the flags handling
timer: Replace timer base by a cpu index
timer: Use hlist for the timer wheel hash buckets
timer: Remove FIFO "guarantee"
timers: Sanitize catchup_timer_jiffies() usage
hrtimer: Allow hrtimer::function() to free the timer
seqcount: Introduce raw_write_seqcount_barrier()
seqcount: Rename write_seqcount_barrier()
hrtimer: Fix hrtimer_is_queued() hole
hrtimer: Remove HRTIMER_STATE_MIGRATE
selftest: Timers: Avoid signal deadlock in leap-a-day
timekeeping: Copy the shadow-timekeeper over the real timekeeper last
clockevents: Check state instead of mode in suspend/resume path
selftests: timers: Add leap-second timer edge testing to leap-a-day.c
ntp: Do leapsecond adjustment in adjtimex read path
time: Prevent early expiry of hrtimers[CLOCK_REALTIME] at the leap second edge
ntp: Introduce and use SECS_PER_DAY macro instead of 86400
Pull x86 kdump updates from Ingo Molnar:
"Three kdump robustness related improvements (Joerg Roedel)"
* 'x86-kdump-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/crash: Allocate enough low memory when crashkernel=high
x86/swiotlb: Try coherent allocations with __GFP_NOWARN
swiotlb: Warn on allocation failure in swiotlb_alloc_coherent()
Pull x86 FPU updates from Ingo Molnar:
"This tree contains two main changes:
- The big FPU code rewrite: wide reaching cleanups and reorganization
that pulls all the FPU code together into a clean base in
arch/x86/fpu/.
The resulting code is leaner and faster, and much easier to
understand. This enables future work to further simplify the FPU
code (such as removing lazy FPU restores).
By its nature these changes have a substantial regression risk: FPU
code related bugs are long lived, because races are often subtle
and bugs mask as user-space failures that are difficult to track
back to kernel side backs. I'm aware of no unfixed (or even
suspected) FPU related regression so far.
- MPX support rework/fixes. As this is still not a released CPU
feature, there were some buglets in the code - should be much more
robust now (Dave Hansen)"
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (250 commits)
x86/fpu: Fix double-increment in setup_xstate_features()
x86/mpx: Allow 32-bit binaries on 64-bit kernels again
x86/mpx: Do not count MPX VMAs as neighbors when unmapping
x86/mpx: Rewrite the unmap code
x86/mpx: Support 32-bit binaries on 64-bit kernels
x86/mpx: Use 32-bit-only cmpxchg() for 32-bit apps
x86/mpx: Introduce new 'directory entry' to 'addr' helper function
x86/mpx: Add temporary variable to reduce masking
x86: Make is_64bit_mm() widely available
x86/mpx: Trace allocation of new bounds tables
x86/mpx: Trace the attempts to find bounds tables
x86/mpx: Trace entry to bounds exception paths
x86/mpx: Trace #BR exceptions
x86/mpx: Introduce a boot-time disable flag
x86/mpx: Restrict the mmap() size check to bounds tables
x86/mpx: Remove redundant MPX_BNDCFG_ADDR_MASK
x86/mpx: Clean up the code by not passing a task pointer around when unnecessary
x86/mpx: Use the new get_xsave_field_ptr()API
x86/fpu/xstate: Wrap get_xsave_addr() to make it safer
x86/fpu/xstate: Fix up bad get_xsave_addr() assumptions
Pull scheduler updates from Ingo Molnar:
"The main changes are:
- lockless wakeup support for futexes and IPC message queues
(Davidlohr Bueso, Peter Zijlstra)
- Replace spinlocks with atomics in thread_group_cputimer(), to
improve scalability (Jason Low)
- NUMA balancing improvements (Rik van Riel)
- SCHED_DEADLINE improvements (Wanpeng Li)
- clean up and reorganize preemption helpers (Frederic Weisbecker)
- decouple page fault disabling machinery from the preemption
counter, to improve debuggability and robustness (David
Hildenbrand)
- SCHED_DEADLINE documentation updates (Luca Abeni)
- topology CPU masks cleanups (Bartosz Golaszewski)
- /proc/sched_debug improvements (Srikar Dronamraju)"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits)
sched/deadline: Remove needless parameter in dl_runtime_exceeded()
sched: Remove superfluous resetting of the p->dl_throttled flag
sched/deadline: Drop duplicate init_sched_dl_class() declaration
sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target
sched/deadline: Make init_sched_dl_class() __init
sched/deadline: Optimize pull_dl_task()
sched/preempt: Add static_key() to preempt_notifiers
sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration
sched/stop_machine: Fix deadlock between multiple stop_two_cpus()
sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched
sched/debug: Replace vruntime with wait_sum in /proc/sched_debug
sched/debug: Properly format runnable tasks in /proc/sched_debug
sched/numa: Only consider less busy nodes as numa balancing destinations
Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced")
sched/fair: Prevent throttling in early pick_next_task_fair()
preempt: Reorganize the notrace definitions a bit
preempt: Use preempt_schedule_context() as the official tracing preemption point
sched: Make preempt_schedule_context() function-tracing safe
x86: Remove cpu_sibling_mask() and cpu_core_mask()
x86: Replace cpu_**_mask() with topology_**_cpumask()
Pull RCU updates from Ingo Molnar:
- Continued initialization/Kconfig updates: hide most Kconfig options
from unsuspecting users.
There's now a single high level configuration option:
* RCU Subsystem
Make expert-level adjustments to RCU configuration (RCU_EXPERT) [N/y/?] (NEW)
Which if answered in the negative, leaves us with a single
interactive configuration option:
Offload RCU callback processing from boot-selected CPUs (RCU_NOCB_CPU) [N/y/?] (NEW)
All the rest of the RCU options are configured automatically. Later
on we'll remove this single leftover configuration option as well.
- Remove all uses of RCU-protected array indexes: replace the
rcu_[access|dereference]_index_check() APIs with READ_ONCE() and
rcu_lockdep_assert()
- RCU CPU-hotplug cleanups
- Updates to Tiny RCU: a race fix and further code shrinkage.
- RCU torture-testing updates: fixes, speedups, cleanups and
documentation updates.
- Miscellaneous fixes
- Documentation updates
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (60 commits)
rcutorture: Allow repetition factors in Kconfig-fragment lists
rcutorture: Display "make oldconfig" errors
rcutorture: Update TREE_RCU-kconfig.txt
rcutorture: Make rcutorture scripts force RCU_EXPERT
rcutorture: Update configuration fragments for rcutree.rcu_fanout_exact
rcutorture: TASKS_RCU set directly, so don't explicitly set it
rcutorture: Test SRCU cleanup code path
rcutorture: Replace barriers with smp_store_release() and smp_load_acquire()
locktorture: Change longdelay_us to longdelay_ms
rcutorture: Allow negative values of nreaders to oversubscribe
rcutorture: Exchange TREE03 and TREE08 NR_CPUS, speed up CPU hotplug
rcutorture: Exchange TREE03 and TREE04 geometries
locktorture: fix deadlock in 'rw_lock_irq' type
rcu: Correctly handle non-empty Tiny RCU callback list with none ready
rcutorture: Test both RCU-sched and RCU-bh for Tiny RCU
rcu: Further shrink Tiny RCU by making empty functions static inlines
rcu: Conditionally compile RCU's eqs warnings
rcu: Remove prompt for RCU implementation
rcu: Make RCU able to tolerate undefined CONFIG_RCU_KTHREAD_PRIO
rcu: Make RCU able to tolerate undefined CONFIG_RCU_FANOUT_LEAF
Merge the mvebu/drivers branch of the arm-soc tree which contains
just a single patch bfa1ce5f38938cc9e6c7f2d1011f88eba2b9e2b2 ("bus:
mvebu-mbus: add mv_mbus_dram_info_nooverlap()") that happens to be
a prerequisite of the new marvell/cesa crypto driver.
drivers/cpufreq/cpufreq.c is already using this function. And now btrfs
needs it as well. Export symbol kobject_move().
Signed-off-by: Anand Jain <anand.jain@oracle.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: David Sterba <dsterba@suse.cz>
Revert commit 534b483a86e6 ("cpumask: don't perform while loop in
cpumask_next_and()").
This was a minor optimization, but it puts a `struct cpumask' on the
stack, which consumes too much stack space.
Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Amir Vadai <amirv@mellanox.com>
This was using module_init, but there is no way this code can
be modular. In the non-modular case, a module_init becomes a
device_initcall, but this really isn't a device. So we should
choose a more appropriate initcall bucket to put it in.
Assuming boot time self tests need to be observed over a console
to be useful, and that the console device could possibly not be
fully functional until after device_initcall, we move this to the
late_initcall bucket, which is immediately after device_initcall.
