path: root/lib
2006-11-03[PATCH] fix missing ifdefs in syscall classes hookup for generic targetsAl Viro
several targets have no ....at() family and m32r calls its only chown variant chown32(), with __NR_chown being undefined. creat(2) is also absent in some targets. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-09-12[PATCH] syscall class hookup for all normal targetsAl Viro
Take default arch/*/kernel/audit.c to lib/, have those with special needs (== biarch) define AUDIT_ARCH in their Kconfig. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-22[TEXTSEARCH]: Fix Boyer Moore initialization bugMichael Rash
The pattern is set after trying to compute the prefix table, which tries to use it. Initialize it before calling compute_prefix_tbl, make compute_prefix_tbl consistently use only the data from struct ts_bm and remove the now unnecessary arguments. Signed-off-by: Michael Rash <mbr@cipherdyne.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-06[PATCH] disable debugging version of write_lock()Andrew Morton
We've confirmed that the debug version of write_lock() can get stuck for long enough to cause NMI watchdog timeouts and hence a crash. We don't know why, yet. Disable it for now. Also disable the similar read_lock() code. Just in case. Thanks to Dave Olson <olson@unixfolk.com> for reporting and testing. Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03PCI: docking station: remove dock ueventsKristen Carlson Accardi
Remove uevent dock notifications. There are no consumers of these events at present, and uevents are likely not the correct way to send this type of event anyway. Until I get some kind of idea if anyone in userspace cares about dock events, I will just not send any. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] Fix ppc32 zImage inflatePeter Korsgaard
The recent zlib update (commit 4f3865fb57a04db7cca068fed1c15badc064a302) broke ppc32 zImage decompression as it tries to decompress to address zero and the updated zlib_inflate checks that strm->next_out isn't a null pointer. This little patch fixes it. [rpurdie@rpsys.net: add comment] Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Tom Rini <trini@kernel.crashing.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] let the the lockdep options depend on DEBUG_KERNELAdrian Bunk
The lockdep options should depend on DEBUG_KERNEL since: - they are kernel debugging options and - they do otherwise break the DEBUG_KERNEL menu structure Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] Convert idr's internal locking to _irqsave variantRoland Dreier
Currently, the code in lib/idr.c uses a bare spin_lock(&idp->lock) to do internal locking. This is a nasty trap for code that might call idr functions from different contexts; for example, it seems perfectly reasonable to call idr_get_new() from process context and idr_remove() from interrupt context -- but with the current locking this would lead to a potential deadlock. The simplest fix for this is to just convert the idr locking to use spin_lock_irqsave(). In particular, this fixes a very complicated locking issue detected by lockdep, involving the ib_ipoib driver's priv->lock and dev->_xmit_lock, which get involved with the ib_sa module's query_idr.lock. Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Zach Brown <zach.brown@oracle.com>, Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: kconfigIngo Molnar
Offer the following lock validation options: CONFIG_PROVE_LOCKING Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove spinlock rwlock locking correctnessIngo Molnar
Use the lock validator framework to prove spinlock and rwlock locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove rwsem locking correctnessIngo Molnar
Use the lock validator framework to prove rwsem locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: allow read_lock() recursion of same classIngo Molnar
From: Ingo Molnar <mingo@elte.hu> lockdep so far only allowed read-recursion for the same lock instance. This is enough in the overwhelming majority of cases, but a hostap case triggered and reported by Miles Lane relies on same-class different-instance recursion. So we relax the restriction on read-lock recursion. (This change does not allow rwsem read-recursion, which is still forbidden.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: coreIngo Molnar
Do 'make oldconfig' and accept all the defaults for new config options - reboot into the kernel and if everything goes well it should boot up fine and you should have /proc/lockdep and /proc/lockdep_stats files. Typically if the lock validator finds some problem it will print out voluminous debug output that begins with "BUG: ..." and which syslog output can be used by kernel developers to figure out the precise locking scenario. What does the lock validator do? It "observes" and maps all locking rules as they occur dynamically (as triggered by the kernel's natural use of spinlocks, rwlocks, mutexes and rwsems). Whenever the lock validator subsystem detects a new locking scenario, it validates this new rule against the existing set of rules. If this new rule is consistent with the existing set of rules then the new rule is added transparently and the kernel continues as normal. If the new rule could create a deadlock scenario then this condition is printed out. When determining validity of locking, all possible "deadlock scenarios" are considered: assuming arbitrary number of CPUs, arbitrary irq context and task context constellations, running arbitrary combinations of all the existing locking scenarios. In a typical system this means millions of separate scenarios. This is why we call it a "locking correctness" validator - for all rules that are observed the lock validator proves it with mathematical certainty that a deadlock could not occur (assuming that the lock validator implementation itself is correct and its internal data structures are not corrupted by some other kernel subsystem). [see more details and conditionals of this statement in include/linux/lockdep.h and Documentation/lockdep-design.txt] Furthermore, this "all possible scenarios" property of the validator also enables the finding of complex, highly unlikely multi-CPU multi-context races via single single-context rules, increasing the likelyhood of finding bugs drastically. In practical terms: the lock validator already found a bug in the upstream kernel that could only occur on systems with 3 or more CPUs, and which needed 3 very unlikely code sequences to occur at once on the 3 CPUs. That bug was found and reported on a single-CPU system (!). So in essence a race will be found "piecemail-wise", triggering all the necessary components for the race, without having to reproduce the race scenario itself! In its short existence the lock validator found and reported many bugs before they actually caused a real deadlock. To further increase the efficiency of the validator, the mapping is not per "lock instance", but per "lock-class". For example, all struct inode objects in the kernel have inode->inotify_mutex. If there are 10,000 inodes cached, then there are 10,000 lock objects. But ->inotify_mutex is a single "lock type", and all locking activities that occur against ->inotify_mutex are "unified" into this single lock-class. The advantage of the lock-class approach is that all historical ->inotify_mutex uses are mapped into a single (and as narrow as possible) set of locking rules - regardless of how many different tasks or inode structures it took to build this set of rules. The set of rules persist during the lifetime of the kernel. To see the rough magnitude of checking that the lock validator does, here's a portion of /proc/lockdep_stats, fresh after bootup: lock-classes: 694 [max: 2048] direct dependencies: 1598 [max: 8192] indirect dependencies: 17896 all direct dependencies: 16206 dependency chains: 1910 [max: 8192] in-hardirq chains: 17 in-softirq chains: 105 in-process chains: 1065 stack-trace entries: 38761 [max: 131072] combined max dependencies: 2033928 hardirq-safe locks: 24 hardirq-unsafe locks: 176 softirq-safe locks: 53 softirq-unsafe locks: 137 irq-safe locks: 59 irq-unsafe locks: 176 The lock validator has observed 1598 actual single-thread locking patterns, and has validated all possible 2033928 distinct locking scenarios. More details about the design of the lock validator can be found in Documentation/lockdep-design.txt, which can also found at: http://redhat.com/~mingo/lockdep-patches/lockdep-design.txt [bunk@stusta.de: cleanups] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking API self testsIngo Molnar
Introduce DEBUG_LOCKING_API_SELFTESTS, which uses the generic lock debugging code's silent-failure feature to run a matrix of testcases. There are 210 testcases currently: +----------------------- | Locking API testsuite: +------------------------------+------+------+------+------+------+------+ | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------+------+------+------+------+------+------+ A-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-A-B-C deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-C-D-A deadlock: ok | ok | ok | ok | ok | ok | double unlock: ok | ok | ok | ok | ok | ok | bad unlock order: ok | ok | ok | ok | ok | ok | --------------------------------------+------+------+------+------+------+ recursive read-lock: | ok | | ok | --------------------------------------+------+------+------+------+------+ non-nested unlock: ok | ok | ok | ok | --------------------------------------+------+------+------+ hard-irqs-on + irq-safe-A/12: ok | ok | ok | soft-irqs-on + irq-safe-A/12: ok | ok | ok | hard-irqs-on + irq-safe-A/21: ok | ok | ok | soft-irqs-on + irq-safe-A/21: ok | ok | ok | sirq-safe-A => hirqs-on/12: ok | ok | ok | sirq-safe-A => hirqs-on/21: ok | ok | ok | hard-safe-A + irqs-on/12: ok | ok | ok | soft-safe-A + irqs-on/12: ok | ok | ok | hard-safe-A + irqs-on/21: ok | ok | ok | soft-safe-A + irqs-on/21: ok | ok | ok | hard-safe-A + unsafe-B #1/123: ok | ok | ok | soft-safe-A + unsafe-B #1/123: ok | ok | ok | hard-safe-A + unsafe-B #1/132: ok | ok | ok | soft-safe-A + unsafe-B #1/132: ok | ok | ok | hard-safe-A + unsafe-B #1/213: ok | ok | ok | soft-safe-A + unsafe-B #1/213: ok | ok | ok | hard-safe-A + unsafe-B #1/231: ok | ok | ok | soft-safe-A + unsafe-B #1/231: ok | ok | ok | hard-safe-A + unsafe-B #1/312: ok | ok | ok | soft-safe-A + unsafe-B #1/312: ok | ok | ok | hard-safe-A + unsafe-B #1/321: ok | ok | ok | soft-safe-A + unsafe-B #1/321: ok | ok | ok | hard-safe-A + unsafe-B #2/123: ok | ok | ok | soft-safe-A + unsafe-B #2/123: ok | ok | ok | hard-safe-A + unsafe-B #2/132: ok | ok | ok | soft-safe-A + unsafe-B #2/132: ok | ok | ok | hard-safe-A + unsafe-B #2/213: ok | ok | ok | soft-safe-A + unsafe-B #2/213: ok | ok | ok | hard-safe-A + unsafe-B #2/231: ok | ok | ok | soft-safe-A + unsafe-B #2/231: ok | ok | ok | hard-safe-A + unsafe-B #2/312: ok | ok | ok | soft-safe-A + unsafe-B #2/312: ok | ok | ok | hard-safe-A + unsafe-B #2/321: ok | ok | ok | soft-safe-A + unsafe-B #2/321: ok | ok | ok | hard-irq lock-inversion/123: ok | ok | ok | soft-irq lock-inversion/123: ok | ok | ok | hard-irq lock-inversion/132: ok | ok | ok | soft-irq lock-inversion/132: ok | ok | ok | hard-irq lock-inversion/213: ok | ok | ok | soft-irq lock-inversion/213: ok | ok | ok | hard-irq lock-inversion/231: ok | ok | ok | soft-irq lock-inversion/231: ok | ok | ok | hard-irq lock-inversion/312: ok | ok | ok | soft-irq lock-inversion/312: ok | ok | ok | hard-irq lock-inversion/321: ok | ok | ok | soft-irq lock-inversion/321: ok | ok | ok | hard-irq read-recursion/123: ok | soft-irq read-recursion/123: ok | hard-irq read-recursion/132: ok | soft-irq read-recursion/132: ok | hard-irq read-recursion/213: ok | soft-irq read-recursion/213: ok | hard-irq read-recursion/231: ok | soft-irq read-recursion/231: ok | hard-irq read-recursion/312: ok | soft-irq read-recursion/312: ok | hard-irq read-recursion/321: ok | soft-irq read-recursion/321: ok | --------------------------------+-----+---------------- Good, all 210 testcases passed! | --------------------------------+ Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: s390 CONFIG_FRAME_POINTER supportHeiko Carstens
CONFIG_FRAME_POINTER support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: stacktrace subsystem, coreIngo Molnar
Framework to generate and save stacktraces quickly, without printing anything to the console. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: remove mutex deadlock checking codeIngo Molnar
With the lock validator we detect mutex deadlocks (and more), the mutex deadlock checking code is both redundant and slower. So remove it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: clean up rwsemsIngo Molnar
Clean up rwsems. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-29merge linus into release branchLen Brown
Conflicts: drivers/acpi/acpi_memhotplug.c
2006-06-28Fix vsnprintf off-by-one bugLinus Torvalds
The recent vsnprintf() fix introduced an off-by-one, and it's now possible to overrun the target buffer by one byte. The "end" pointer points to past the end of the buffer, so if we have to truncate the result, it needs to be done though "end[-1]". [ This is just an alternate and simpler patch to one proposed by Andrew and Jeremy, who actually noticed the problem ] Acked-by: Andrew Morton <akpm@osdl.org> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] Add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPLArjan van de Ven
Temporarily add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPL. These will be used as a transition measure for symbols that aren't used in the kernel and are on the way out. When a module uses such a symbol, a warning is printk'd at modprobe time. The main reason for removing unused exports is size: eacho export takes roughly between 100 and 150 bytes of kernel space in the binary. This patch gives users the option to immediately get this size gain via a config option. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] fix rt-mutex defaults and dependenciesRoman Zippel
Fix defaults and dependencies. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: rt mutex testerThomas Gleixner
RT-mutex tester: scriptable tester for rt mutexes, which allows userspace scripting of mutex unit-tests (and dynamic tests as well), using the actual rt-mutex implementation of the kernel. [akpm@osdl.org: fixlet] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: rt mutex debugIngo Molnar
Runtime debugging functionality for rt-mutexes. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: add plist implementationIngo Molnar
Add the priority-sorted list (plist) implementation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] zlib inflate: fix function definitionsRandy Dunlap
Fix function definitions to be ANSI-compliant: lib/zlib_inflate/inffast.c:68:1: warning: non-ANSI definition of function 'inflate_fast' lib/zlib_inflate/inftrees.c:33:1: warning: non-ANSI definition of function 'zlib_inflate_table' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27KEVENT: add new uevent for dockKristen Accardi
so that userspace can be notified of dock and undock events. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: typo fixes Clean up 'inline is not at beginning' warnings for usb storage Storage class should be first i386: Trivial typo fixes ixj: make ixj_set_tone_off() static spelling fixes fix paniced->panicked typos Spelling fixes for Documentation/atomic_ops.txt move acknowledgment for Mark Adler to CREDITS remove the bouncing email address of David Campbell
2006-06-26Merge branch 'x86-64'Linus Torvalds
* x86-64: (83 commits) [PATCH] x86_64: x86_64 stack usage debugging [PATCH] x86_64: (resend) x86_64 stack overflow debugging [PATCH] x86_64: msi_apic.c build fix [PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUs [PATCH] x86_64: Avoid broadcasting NMI IPIs [PATCH] x86_64: fix apic error on bootup [PATCH] x86_64: enlarge window for stack growth [PATCH] x86_64: Minor string functions optimizations [PATCH] x86_64: Move export symbols to their C functions [PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTOR [PATCH] x86_64: Fix modular pc speaker [PATCH] x86_64: remove sys32_ni_syscall() [PATCH] x86_64: Do not use -ffunction-sections for modules [PATCH] x86_64: Add cpu_relax to apic_wait_icr_idle [PATCH] x86_64: adjust kstack_depth_to_print default [PATCH] i386/x86-64: adjust /proc/interrupts column headings [PATCH] x86_64: Fix race in cpu_local_* on preemptible kernels [PATCH] x86_64: Fix fast check in safe_smp_processor_id [PATCH] x86_64: x86_64 setup.c - printing cmp related boottime information [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status ... Manual resolve of trivial conflict in arch/i386/kernel/Makefile
2006-06-26[PATCH] i386: reliable stack trace support (i386)Jan Beulich
These are the i386-specific pieces to enable reliable stack traces. This is going to be even more useful once CFI annotations get added to he assembly code, namely to entry.S. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: reliable stack trace support (x86-64)Jan Beulich
These are the x86_64-specific pieces to enable reliable stack traces. The only restriction with this is that it currently cannot unwind across the interrupt->normal stack boundary, as that transition is lacking proper annotation. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: reliable stack trace supportJan Beulich
These are the generic bits needed to enable reliable stack traces based on Dwarf2-like (.eh_frame) unwind information. Subsequent patches will enable x86-64 and i386 to make use of this. Thanks to Andi Kleen and Ingo Molnar, who pointed out several possibilities for improvement. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] lib: add idr_replaceJeff Mahoney
This patch adds idr_replace() to replace an existing pointer in a single operation. Device-mapper will use this to update the pointer it stored against a given id. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-26move acknowledgment for Mark Adler to CREDITSAdrian Bunk
The place in the documentation of the Linux kernel to acknowledge contributions is the CREDITS file. Give Mark Adler an entry there instead of including a string in the kernel image. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] fix race in idr codeSonny Rao
I ran into a bug where the kernel died in the idr code: cpu 0x1d: Vector: 300 (Data Access) at [c000000b7096f710] pc: c0000000001f8984: .idr_get_new_above_int+0x140/0x330 lr: c0000000001f89b4: .idr_get_new_above_int+0x170/0x330 sp: c000000b7096f990 msr: 800000000000b032 dar: 0 dsisr: 40010000 current = 0xc000000b70d43830 paca = 0xc000000000556900 pid = 2022, comm = hwup 1d:mon> t [c000000b7096f990] c0000000000d2ad8 .expand_files+0x2e8/0x364 (unreliable) [c000000b7096faa0] c0000000001f8bf8 .idr_get_new_above+0x18/0x68 [c000000b7096fb20] c00000000002a054 .init_new_context+0x5c/0xf0 [c000000b7096fbc0] c000000000049dc8 .copy_process+0x91c/0x1404 [c000000b7096fcd0] c00000000004a988 .do_fork+0xd8/0x224 [c000000b7096fdc0] c00000000000ebdc .sys_clone+0x5c/0x74 [c000000b7096fe30] c000000000008950 .ppc_clone+0x8/0xc
2006-06-25[PATCH] Implement kasprintfJeremy Fitzhardinge
Implement kasprintf, a kernel version of asprintf. This allocates the memory required for the formatted string, including the trailing '\0'. Returns NULL on allocation failure. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Fix bounds check in vsnprintf, to allow for a 0 size and NULL bufferJeremy Fitzhardinge
This change allows callers to use a 0-byte buffer and a NULL buffer pointer with vsnprintf, so it can be used to determine how large the resulting formatted string will be. Previously the code effectively treated a size of 0 as a size of 4G (on 32-bit systems), with other checks preventing it from actually trying to emit the string - but the terminal \0 would still be written, which would crash if the buffer is NULL. This change changes the boundary check so that 'end' points to the putative location of the terminal '\0', which is only written if size > 0. vsnprintf still allows the buffer size to be set very large, to allow unbounded buffer sizes (to implement sprintf, etc). [akpm@osdl.org: fix long-vs-longlong confusion] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] reed-solomon: fix kernel-doc commentsRandy Dunlap
Fix kernel-doc formatting in Reed-Solomon code. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] kernel-doc for lib/crc*.cRandy Dunlap
Make kernel-doc corrections & additions to lib/crc*.c. Add crc functions to kernel-api.tmpl in DocBook. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] kernel-doc for lib/bitmap.cRandy Dunlap
Make corrections/fixes to kernel-doc in lib/bitmap.c and include it in DocBook template. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] radixtree: normalize radix_tree_tag_get() return valueWu Fengguang
In radix_tree_tag_get(), return normalized value of 0/1, as indicated by its comment. Signed-off-by: Wu Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] constify libcrc32c tableAndreas Mohr
constify a medium-large CRC code table. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] strstrip() APIPekka Enberg
Add a new strstrip() function to lib/string.c for removing leading and trailing whitespace from a string. Cc: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Ingo Oeser <ioe-lkml@rameria.de> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] percpu counter data type changes to suppport more than 2**31 ext3 ↵Mingming Cao
free blocks counter The percpu counter data type are changed in this set of patches to support more users like ext3 who need more than 32 bit to store the free blocks total in the filesystem. - Generic perpcu counters data type changes. The size of the global counter and local counter were explictly specified using s64 and s32. The global counter is changed from long to s64, while the local counter is changed from long to s32, so we could avoid doing 64 bit update in most cases. - Users of the percpu counters are updated to make use of the new percpu_counter_init() routine now taking an additional parameter to allow users to pass the initial value of the global counter. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] percpu_counters: create lib/percpu_counter.cRavikiran G Thirumalai
- Move percpu_counter routines from mm/swap.c to lib/percpu_counter.c Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] buglet in radix_tree_tag_setPeter Zijlstra
The comment states: 'Setting a tag on a not-present item is a BUG.' Hence if 'index' is larger than the maxindex; the item _cannot_ be presen; it should also be a BUG. Also, this allows the following statement (assume a fresh tree): radix_tree_tag_set(root, 16, 1); to fail silently, but when preceded by: radix_tree_insert(root, 32, item); it would BUG, because the height has been extended by the insert. In neither case was 16 present. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
