path: root/lib
2005-08-07[PATCH] crc32.c typo fixDominik Hackl
This patch fixes a typo in lib/crc32.c which results in incorrect debug output. Signed-off-by: Dominik Hackl <dominik@hackl.dhs.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-05[PATCH] Update in-kernel zlib routinesTim Yamin
These bugs have been fixed in the standard zlib for a while. See for example a) http://sources.redhat.com/ml/bug-gnu-utils/1999-06/msg00183.html b) http://bugs.gentoo.org/show_bug.cgi?id=94584 Signed-off-by: Tim Yamin <plasmaroo@gentoo.org> Signed-off-by: Tavis Ormandy <taviso@gentoo.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] DEBUG_FS must depend on SYSFSAdrian Bunk
CONFIG_DEBUG_FS=y and CONFIG_SYSFS=n results in the following compile error: <-- snip --> ... LD vmlinux fs/built-in.o: In function `debugfs_init': inode.c:(.init.text+0x31be): undefined reference to `kernel_subsys' make: *** [vmlinux] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] statically link halfmd4Andrew Morton
For some reason halfmd4 isn't being linked into the kernel any more and modular ext3 wants it. So statically link the halfmd4 code into the kernel. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] mostly_read data sectionChristoph Lameter
Add a new section called ".data.read_mostly" for data items that are read frequently and rarely written to like cpumaps etc. If these maps are placed in the .data section then these frequenly read items may end up in cachelines with data is is frequently updated. In that case all processors in an SMP system must needlessly reload the cachelines again and again containing elements of those frequently used variables. The ability to share these cachelines will allow each cpu in an SMP system to keep local copies of those shared cachelines thereby optimizing performance. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Christoph Lameter <christoph@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Use ALIGN to remove duplicate codeNick Wilson
This patch makes use of ALIGN() to remove duplicate round-up code. Signed-off-by: Nick Wilson <njw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] lib/sha1.c: fix sparse warningDomen Puncer
lib/sha1.c:44:10: warning: cast to restricted type Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PKT_SCHED]: Make TEXTSEARCH* options only selected.David S. Miller
Do not present these confusing new options to the user unless he picked some facility that makes use of it, such as NET_EMATCH_TEXT. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[LIB]: textsearch.o needs to be obj-y not lib-y.David S. Miller
It exports symbols. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[LIB]: Naive finite state machine based textsearchThomas Graf
A finite state machine consists of n states (struct ts_fsm_token) representing the pattern as a finite automation. The data is read sequentially on a octet basis. Every state token specifies the number of recurrences and the type of value accepted which can be either a specific character or ctype based set of characters. The available type of recurrences include 1, (0|1), [0 n], and [1 n]. The algorithm differs between strict/non-strict mode specyfing whether the pattern has to start at the first octect. Strict mode is enabled by default and can be disabled by inserting TS_FSM_HEAD_IGNORE as the first token in the chain. The runtime performance of the algorithm should be around O(n), however while in strict mode the average runtime can be better. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[LIB]: Knuth-Morris-Pratt textsearch algorithmThomas Graf
Implements a linear-time string-matching algorithm due to Knuth, Morris, and Pratt [1]. Their algorithm avoids the explicit computation of the transition function DELTA altogether. Its matching time is O(n), for n being length(text), using just an auxiliary function PI[1..m], for m being length(pattern), precomputed from the pattern in time O(m). The array PI allows the transition function DELTA to be computed efficiently "on the fly" as needed. Roughly speaking, for any state "q" = 0,1,...,m and any character "a" in SIGMA, the value PI["q"] contains the information that is independent of "a" and is needed to compute DELTA("q", "a") [2]. Since the array PI has only m entries, whereas DELTA has O(m|SIGMA|) entries, we save a factor of |SIGMA| in the preprocessing time by computing PI rather than DELTA. [1] Cormen, Leiserson, Rivest, Stein Introdcution to Algorithms, 2nd Edition, MIT Press [2] See finite automation theory Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[LIB]: Textsearch infrastructure.Thomas Graf
The textsearch infrastructure provides text searching facitilies for both linear and non-linear data. Individual search algorithms are implemented in modules and chosen by the user. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] ia64 uncached allocJes Sorensen
This patch contains the ia64 uncached page allocator and the generic allocator (genalloc). The uncached allocator was formerly part of the SN2 mspec driver but there are several other users of it so it has been split off from the driver. The generic allocator can be used by device driver to manage special memory etc. The generic allocator is based on the allocator from the sym53c8xx_2 driver. Various users on ia64 needs uncached memory. The SGI SN architecture requires it for inter-partition communication between partitions within a large NUMA cluster. The specific user for this is the XPC code. Another application is large MPI style applications which use it for synchronization, on SN this can be done using special 'fetchop' operations but it also benefits non SN hardware which may use regular uncached memory for this purpose. Performance of doing this through uncached vs cached memory is pretty substantial. This is handled by the mspec driver which I will push out in a seperate patch. Rather than creating a specific allocator for just uncached memory I came up with genalloc which is a generic purpose allocator that can be used by device drivers and other subsystems as they please. For instance to handle onboard device memory. It was derived from the sym53c7xx_2 driver's allocator which is also an example of a potential user (I am refraining from modifying sym2 right now as it seems to have been under fairly heavy development recently). On ia64 memory has various properties within a granule, ie. it isn't safe to access memory as uncached within the same granule as currently has memory accessed in cached mode. The regular system therefore doesn't utilize memory in the lower granules which is mixed in with device PAL code etc. The uncached driver walks the EFI memmap and pulls out the spill uncached pages and sticks them into the uncached pool. Only after these chunks have been utilized, will it start converting regular cached memory into uncached memory. Hence the reason for the EFI related code additions. Signed-off-by: Jes Sorensen <jes@wildopensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] smp_processor_id() cleanupIngo Molnar
This patch implements a number of smp_processor_id() cleanup ideas that Arjan van de Ven and I came up with. The previous __smp_processor_id/_smp_processor_id/smp_processor_id API spaghetti was hard to follow both on the implementational and on the usage side. Some of the complexity arose from picking wrong names, some of the complexity comes from the fact that not all architectures defined __smp_processor_id. In the new code, there are two externally visible symbols: - smp_processor_id(): debug variant. - raw_smp_processor_id(): nondebug variant. Replaces all existing uses of _smp_processor_id() and __smp_processor_id(). Defined by every SMP architecture in include/asm-*/smp.h. There is one new internal symbol, dependent on DEBUG_PREEMPT: - debug_smp_processor_id(): internal debug variant, mapped to smp_processor_id(). Also, i moved debug_smp_processor_id() from lib/kernel_lock.c into a new lib/smp_processor_id.c file. All related comments got updated and/or clarified. I have build/boot tested the following 8 .config combinations on x86: {SMP,UP} x {PREEMPT,!PREEMPT} x {DEBUG_PREEMPT,!DEBUG_PREEMPT} I have also build/boot tested x64 on UP/PREEMPT/DEBUG_PREEMPT. (Other architectures are untested, but should work just fine.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] coverity: idr_get_new_above_int() overrun fixZaur Kambarov
This patch fixes overrun of array pa: 92 struct idr_layer *pa[MAX_LEVEL]; in 98 l = idp->layers; 99 pa[l--] = NULL; by passing idp->layers, set in 202 idp->layers = layers; to function sub_alloc in 203 v = sub_alloc(idp, ptr, &id); Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Don't reference NULL klist pointer in klist_remove().mochel@digitalimplant.org
Signed-off-by: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -Nru a/lib/klist.c b/lib/klist.c
2005-06-20[PATCH] add klist_node_attached() to determine if a node is on a list or not.mochel@digitalimplant.org
Signed-off-by: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -Nru a/include/linux/klist.h b/include/linux/klist.h
2005-06-20[PATCH] Add initial implementation of klist helpers.mochel@digitalimplant.org
This klist interface provides a couple of structures that wrap around struct list_head to provide explicit list "head" (struct klist) and list "node" (struct klist_node) objects. For struct klist, a spinlock is included that protects access to the actual list itself. struct klist_node provides a pointer to the klist that owns it and a kref reference count that indicates the number of current users of that node in the list. The entire point is to provide an interface for iterating over a list that is safe and allows for modification of the list during the iteration (e.g. insertion and removal), including modification of the current node on the list. It works using a 3rd object type - struct klist_iter - that is declared and initialized before an iteration. klist_next() is used to acquire the next element in the list. It returns NULL if there are no more items. This klist interface provides a couple of structures that wrap around struct list_head to provide explicit list "head" (struct klist) and list "node" (struct klist_node) objects. For struct klist, a spinlock is included that protects access to the actual list itself. struct klist_node provides a pointer to the klist that owns it and a kref reference count that indicates the number of current users of that node in the list. The entire point is to provide an interface for iterating over a list that is safe and allows for modification of the list during the iteration (e.g. insertion and removal), including modification of the current node on the list. It works using a 3rd object type - struct klist_iter - that is declared and initialized before an iteration. klist_next() is used to acquire the next element in the list. It returns NULL if there are no more items. Internally, that routine takes the klist's lock, decrements the reference count of the previous klist_node and increments the count of the next klist_node. It then drops the lock and returns. There are primitives for adding and removing nodes to/from a klist. When deleting, klist_del() will simply decrement the reference count. Only when the count goes to 0 is the node removed from the list. klist_remove() will try to delete the node from the list and block until it is actually removed. This is useful for objects (like devices) that have been removed from the system and must be freed (but must wait until all accessors have finished). Internally, that routine takes the klist's lock, decrements the reference count of the previous klist_node and increments the count of the next klist_node. It then drops the lock and returns. There are primitives for adding and removing nodes to/from a klist. When deleting, klist_del() will simply decrement the reference count. Only when the count goes to 0 is the node removed from the list. klist_remove() will try to delete the node from the list and block until it is actually removed. This is useful for objects (like devices) that have been removed from the system and must be freed (but must wait until all accessors have finished). Signed-off-by: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -Nru a/include/linux/klist.h b/include/linux/klist.h
2005-06-20[PATCH] Make kobject's name be const char *Dmitry Torokhov
kobject: make kobject's name const char * since users should not attempt to change it (except by calling kobject_rename). Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] kobject_hotplug() should use kobject_name()Dmitry Torokhov
kobject: kobject_hotplug should use kobject_name() instead of accessing kobj->name directly since for objects with long names it can contain garbage. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-28[PATCH] uml: split CONFIG_FRAME_POINTER from DEBUG_INFOPaolo 'Blaisorblade' Giarrusso
Until now, FRAME_POINTER was set = DEBUG_INFO for UML. Change it to be the default way, so that it can be enabled alone (for instance to get better backtraces on crashes). The call-trace dumper which uses the frame pointer is not yet in, I'm going to introduce it in a separate patch. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] documentation for strncpy()walter harms
this clarifies the documentation on the behavier of strncpy(). Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] fix lib/sort regression testDomen Puncer
The regression test in lib/sort.c is currently worthless because the array that is generated for sorting will be all zeros. This patch fixes things so that the array that is generated will contain unsorted integers (that are not all identical) as was probably intended. Signed-off-by Daniel Dickman <didickman@yahoo.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] x86_64: make string func definition work as intendedPaolo 'Blaisorblade' Giarrusso
In include/asm-x86_64/string.h there are such comments: /* Use C out of line version for memcmp */ #define memcmp __builtin_memcmp int memcmp(const void * cs,const void * ct,size_t count); This would mean that if the compiler does not decide to use __builtin_memcmp, it emits a call to memcmp to be satisfied by the C out-of-line version in lib/string.c. What happens is that after preprocessing, in lib/string.i you may find the definition of "__builtin_strcmp". Actually, by accident, in the object you will find the definition of strcmp and such (maybe a trick intended to redirect calls to __builtin_memcmp to the default memcmp when the definition is not expanded); however, this particular case is not a documented feature as far as I can see. Also, the EXPORT_SYMBOL does not work, so it's duplicated in the arch. I simply added some #undef to lib/string.c and removed the (now duplicated) exports in x86-64 and UML/x86_64 subarchs (the second ones are introduced by another patch I just posted for -mm). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] remove all kernel BUGsMatt Mackall
This patch eliminates all kernel BUGs, trims about 35k off the typical kernel, and makes the system slightly faster. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] kobject/hotplug split - kobject add/removekay.sievers@vrfy.org
kobject_add() and kobject_del() don't emit hotplug events anymore. The user should do it itself if it has finished populating the device directory. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-16[PATCH] add Big Endian variants of ioread/iowriteJames Bottomley
In the new io infrastructure, all of our operators are expecting the underlying device to be little endian (because the PCI bus, their main consumer, is LE). However, there are a fair few devices and busses in the world that are actually Big Endian. There's even evidence that some of these BE bus and chip types are attached to LE systems. Thus, there's a need for a BE equivalent of our io{read,write}{16,32} operations. The attached patch adds this as io{read,write}{16,32}be. When it's in, I'll add the first consume (the 53c700 SCSI chip driver). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
