path: root/lib
2012-03-01cpumask: Disable CONFIG_CPUMASK_OFFSTACK for RTThomas Gleixner
We can't deal with the cpumask allocations which happen in atomic context (see arch/x86/kernel/apic/io_apic.c) on RT right now. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-01sysrq: Allow immediate Magic SysRq output for PREEMPT_RT_FULLFrank Rowand
Add a CONFIG option to allow the output from Magic SysRq to be output immediately, even if this causes large latencies. If PREEMPT_RT_FULL, printk() will not try to acquire the console lock when interrupts or preemption are disabled. If the console lock is not acquired the printk() output will be buffered, but will not be output immediately. Some drivers call into the Magic SysRq code with interrupts or preemption disabled, so the output of Magic SysRq will be buffered instead of printing immediately if this option is not selected. Even with this option selected, Magic SysRq output will be delayed if the attempt to acquire the console lock fails. Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Link: http://lkml.kernel.org/r/4E7CEF60.5020508@am.sony.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-01debugobjects-rt.patchThomas Gleixner
2012-03-01rt: Add the preempt-rt lock replacement APIsThomas Gleixner
Map spinlocks, rwlocks, rw_semaphores and semaphores to the rt_mutex based locking functions for preempt-rt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-01rwsem-add-rt-variant.patchThomas Gleixner
2012-03-01sched: Generic migrate_disablePeter Zijlstra
Make migrate_disable() be a preempt_disable() for !rt kernels. This allows generic code to use it but still enforces that these code sections stay relatively small. A preemptible migrate_disable() accessible for general use would allow people growing arbitrary per-cpu crap instead of clean these things up. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-275i87sl8e1jcamtchmehonm@git.kernel.org
2012-03-01sched-migrate-disable.patchThomas Gleixner
2012-03-01radix-tree-rt-aware.patchThomas Gleixner
2012-03-01genirq: Disable DEBUG_SHIRQ for rtThomas Gleixner
2012-03-01mm: scatterlist dont disable irqs on RTThomas Gleixner
2011-11-21Fix comparison using wrong pointer variable in dma debug codeThomas Jarosch
cppcheck reported: [lib/dma-debug.c:248] -> [lib/dma-debug.c:248]: (style) Same expression on both sides of '=='. Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) forcedeth: fix a few sparse warnings (variable shadowing) forcedeth: Improve stats counters forcedeth: remove unneeded stats updates forcedeth: Acknowledge only interrupts that are being processed forcedeth: fix race when unloading module MAINTAINERS/rds: update maintainer wanrouter: Remove kernel_lock annotations usbnet: fix oops in usbnet_start_xmit ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined etherh: Add MAINTAINERS entry for etherh bonding: comparing a u8 with -1 is always false sky2: fix regression on Yukon Optima netlink: clarify attribute length check documentation netlink: validate NLA_MSECS length i825xx:xscale:8390:freescale: Fix Kconfig dependancies macvlan: receive multicast with local address tg3: Update version to 3.121 tg3: Eliminate timer race with reset_task tg3: Schedule at most one tg3_reset_task run tg3: Obtain PCI function number from device ...
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-04netlink: validate NLA_MSECS lengthJohannes Berg
L2TP for example uses NLA_MSECS like this: policy: [L2TP_ATTR_RECV_TIMEOUT] = { .type = NLA_MSECS, }, code: if (info->attrs[L2TP_ATTR_RECV_TIMEOUT]) cfg.reorder_timeout = nla_get_msecs(info->attrs[L2TP_ATTR_RECV_TIMEOUT]); As nla_get_msecs() is essentially nla_get_u64() plus the conversion to a HZ-based value, this will not properly reject attributes from userspace that aren't long enough and might overrun the message. Add NLA_MSECS to the attribute minlen array to check the size properly. Cc: Thomas Graf <tgraf@suug.ch> Cc: stable@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-02ida: make ida_simple_get/put() IRQ safeTejun Heo
It's often convenient to be able to release resource from IRQ context. Make ida_simple_*() use irqsave/restore spin ops so that they are IRQ safe. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib: rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
As suggested by Andrew Morton in [1] there is better to have most significant part first in the function name. [1] https://lkml.org/lkml/2011/9/20/22 There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/string.c: fix strim() semantics for strings that have only blanksMichael Holzheu
Commit 84c95c9acf0 ("string: on strstrip(), first remove leading spaces before running over str") improved the performance of the strim() function. Unfortunately this changed the semantics of strim() and broke my code. Before the patch it was possible to use strim() without using the return value for removing trailing spaces from strings that had either only blanks or only trailing blanks. Now this does not work any longer for strings that *only* have blanks. Before patch: " " -> "" (empty string) After patch: " " -> " " (no change) I think we should remove your patch to restore the old behavior. The description (lib/string.c): * Note that the first trailing whitespace is replaced with a %NUL-terminator => The first trailing whitespace of a string that only has whitespace characters is the first whitespace The patch restores the old strim() semantics. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Andre Goddard Rosa <andre.goddard@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/idr.c: fix comment for ida_get_new_above()Wang Sheng-Hui
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/percpu_counter.c: enclose hotplug only variables in hotplug ifdefGlauber Costa
These variables are only used when CONFIG_HOTPLUG_CPU is enabled, they are ifdef'ed everywhere else. So don't define them when CONFIG_HOTPLUG_CPU is not enabled. Signed-off-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/bitmap.c: quiet sparse noise about address spaceH Hartley Sweeten
__bitmap_parse() and __bitmap_parselist() both take a pointer to a kernel buffer as a parameter and then cast it to a pointer to user buffer for use in cases when the parameter is_user indicates that the buffer is actually located in user space. This casting, and the casts in the callers, results in sparse noise like the following: warning: incorrect type in initializer (different address spaces) expected char const [noderef] <asn:1>*ubuf got char const *buf warning: cast removes address space of expression Since these casts are intentional, use __force to quiet the noise. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Len Brown <len.brown@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/spinlock_debug.c: print owner on spinlock lockupAkinobu Mita
When SPIN_BUG_ON is triggered, the lock owner information is reported. But it is omitted when spinlock lockup is detected. This information is useful especially on the architectures which don't implement trigger_all_cpu_backtrace() that is called just after detecting lockup. So report it and also avoid message format duplication. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/kstrtox: common code between kstrto*() and simple_strto*() functionsAlexey Dobriyan
Currently termination logic (\0 or \n\0) is hardcoded in _kstrtoull(), avoid that for code reuse between kstrto*() and simple_strtoull(). Essentially, make them different only in termination logic. simple_strtoull() (and scanf(), BTW) ignores integer overflow, that's a bug we currently don't have guts to fix, making KSTRTOX_OVERFLOW hack necessary. Almost forgot: patch shrinks code size by about ~80 bytes on x86_64. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/Kconfig.debug: fix help message for DEFAULT_HUNG_TASK_TIMEOUTJiaju Zhang
Added missing _secs in the help message of config DEFAULT_HUNG_TASK_TIMEOUT. Signed-off-by: Jiaju Zhang <jjzhang@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/string.c: introduce memchr_inv()Akinobu Mita
memchr_inv() is mainly used to check whether the whole buffer is filled with just a specified byte. The function name and prototype are stolen from logfs and the implementation is from SLUB. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Joern Engel <joern@logfs.org> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31radix_tree: clean away saw_unset_tag leftoversHugh Dickins
radix_tree_tag_get()'s BUG (when it sees a tag after saw_unset_tag) was unsafe and removed in 2.6.34, but the pointless saw_unset_tag left behind. Remove it now, and return 0 as soon as we see unset tag - we already rely upon the root tag to be correct, returning 0 immediately if it's not set. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib: dma-debug needs export.h for EXPORT_SYMBOLPaul Gortmaker
There are no modular calls here, so just the minimal header for the EXPORT_SYMBOL macro will suffice. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31md: Add in export.h for files using EXPORT_SYMBOLPaul Gortmaker
These files were getting the defines for EXPORT_SYMBOL because device.h was including module.h. But we are going to put an end to that. So add the proper export.h include now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31md: Add module.h to all files using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in md dir are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-30Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/core: Remove global iommu_ops and register_iommu iommu/msm: Use bus_set_iommu instead of register_iommu iommu/omap: Use bus_set_iommu instead of register_iommu iommu/vt-d: Use bus_set_iommu instead of register_iommu iommu/amd: Use bus_set_iommu instead of register_iommu iommu/core: Use bus->iommu_ops in the iommu-api iommu/core: Convert iommu_found to iommu_present iommu/core: Add bus_type parameter to iommu_domain_alloc Driver core: Add iommu_ops to bus_type iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API iommu/amd: Fix wrong shift direction iommu/omap: always provide iommu debug code iommu/core: let drivers know if an iommu fault handler isn't installed iommu/core: export iommu_set_fault_handler() iommu/omap: Fix build error with !IOMMU_SUPPORT iommu/omap: Migrate to the generic fault report mechanism iommu/core: Add fault reporting mechanism iommu/core: Use PAGE_SIZE instead of hard-coded value iommu/core: use the existing IS_ALIGNED macro iommu/msm: ->unmap() should return order of unmapped page ... Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config options" just happened to touch lines next to each other.
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (83 commits) mmc: fix compile error when CONFIG_BLOCK is not enabled mmc: core: Cleanup eMMC4.5 conditionals mmc: omap_hsmmc: if multiblock reads are broken, disable them mmc: core: add workaround for controllers with broken multiblock reads mmc: core: Prevent too long response times for suspend mmc: recognise SDIO cards with SDIO_CCCR_REV 3.00 mmc: sd: Handle SD3.0 cards not supporting UHS-I bus speed mode mmc: core: support HPI send command mmc: core: Add cache control for eMMC4.5 device mmc: core: Modify the timeout value for writing power class mmc: core: new discard feature support at eMMC v4.5 mmc: core: mmc sanitize feature support for v4.5 mmc: dw_mmc: modify DATA register offset mmc: sdhci-pci: add flag for devices that can support runtime PM mmc: omap_hsmmc: ensure pbias configuration is always done mmc: core: Add Power Off Notify Feature eMMC 4.5 mmc: sdhci-s3c: fix potential NULL dereference mmc: replace printk with appropriate display macro mmc: core: Add default timeout value for CMD6 mmc: sdhci-pci: add runtime pm support ...
2011-10-26fault-inject: export setup_fault_attr()Per Forlin
mmc_core module needs to use setup_fault_attr() in order to set fault injection attributes during module load time. Signed-off-by: Per Forlin <per.forlin@linaro.org> Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26mmc: core: add random fault injectionPer Forlin
This adds support to inject data errors after a completed host transfer. The mmc core will return error even though the host transfer is successful. This simple fault injection proved to be very useful to test the non-blocking error handling in the mmc_blk_issue_rw_rq(). Random faults can also test how the host driver handles pre_req() and post_req() in case of errors. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26fault-inject: export fault injection functionsPer Forlin
Export symbols should_fail() and fault_create_debugfs_attr() in order to let modules utilize the fault injection framework. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (34 commits) md: Fix some bugs in recovery_disabled handling. md/raid5: fix bug that could result in reads from a failed device. lib/raid6: Fix filename emitted in generated code md.c: trivial comment fix MD: Allow restarting an interrupted incremental recovery. md: clear In_sync bit on devices added to an active array. md: add proper write-congestion reporting to RAID1 and RAID10. md: rename "mdk_personality" to "md_personality" md/bitmap remove fault injection options. md/raid5: typedef removal: raid5_conf_t -> struct r5conf md/raid1: typedef removal: conf_t -> struct r1conf md/raid10: typedef removal: conf_t -> struct r10conf md/raid0: typedef removal: raid0_conf_t -> struct r0conf md/multipath: typedef removal: multipath_conf_t -> struct mpconf md/linear: typedef removal: linear_conf_t -> struct linear_conf md/faulty: remove typedef: conf_t -> struct faulty_conf md/linear: remove typedefs: dev_info_t -> struct dev_info md: remove typedefs: mirror_info_t -> struct mirror_info md: remove typedefs: r10bio_t -> struct r10bio and r1bio_t -> struct r1bio md: remove typedefs: mdk_thread_t -> struct md_thread ...
2011-10-26Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) llist: Add back llist_add_batch() and llist_del_first() prototypes sched: Don't use tasklist_lock for debug prints sched: Warn on rt throttling sched: Unify the ->cpus_allowed mask copy sched: Wrap scheduler p->cpus_allowed access sched: Request for idle balance during nohz idle load balance sched: Use resched IPI to kick off the nohz idle balance sched: Fix idle_cpu() llist: Remove cpu_relax() usage in cmpxchg loops sched: Convert to struct llist llist: Add llist_next() irq_work: Use llist in the struct irq_work logic llist: Return whether list is empty before adding in llist_add() llist: Move cpu_relax() to after the cmpxchg() llist: Remove the platform-dependent NMI checks llist: Make some llist functions inline sched, tracing: Show PREEMPT_ACTIVE state in trace_sched_switch sched: Remove redundant test in check_preempt_tick() sched: Add documentation for bandwidth control sched: Return unused runtime on group dequeue ...
2011-10-26Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock() lockdep: Comment all warnings lib: atomic64: Change the type of local lock to raw_spinlock_t locking, lib/atomic64: Annotate atomic64_lock::lock as raw locking, x86, iommu: Annotate qi->q_lock as raw locking, x86, iommu: Annotate irq_2_ir_lock as raw locking, x86, iommu: Annotate iommu->register_lock as raw locking, dma, ipu: Annotate bank_lock as raw locking, ARM: Annotate low level hw locks as raw locking, drivers/dca: Annotate dca_lock as raw locking, powerpc: Annotate uic->lock as raw locking, x86: mce: Annotate cmci_discover_lock as raw locking, ACPI: Annotate c3_lock as raw locking, oprofile: Annotate oprofilefs lock as raw locking, video: Annotate vga console lock as raw locking, latencytop: Annotate latency_lock as raw locking, timer_stats: Annotate table_lock as raw locking, rwsem: Annotate inner lock as raw locking, semaphores: Annotate inner lock as raw locking, sched: Annotate thread_group_cputimer as raw ... Fix up conflicts in kernel/posix-cpu-timers.c manually: making cputimer->cputime a raw lock conflicted with the ABBA fix in commit bcd5cff7216f ("cputimer: Cure lock inversion").
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'for-linus' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (81 commits) ARM: 7133/1: SMP: fix per cpu timer setup before the cpu is marked online ARM: 7129/1: Add __arm_ioremap_exec for mapping external memory as MT_MEMORY ARM: 7136/1: pl330: Fix a race condition ARM: smp: fix clipping of number of CPUs ARM: 7137/1: Fix error upon adding LL debug ARM: Add a few machine types to mach-types ARM: 7130/1: dev_archdata: add private iommu extension ARM: 7125/1: Add unwinding annotations for 64bit division functions ARM: 7120/1: remove bashism in check for multiple zreladdrs ARM: 7118/1: rename temp variable in read*_relaxed() ARM: 6217/4: mach-realview: expose PB1176 ROM using physmap and map_rom ARM: 7098/1: kdump: copy kernel relocation code at the kexec prepare stage ARM: 7062/1: cache: detect PIPT I-cache using CTR ARM: platform fixups: remove mdesc argument to fixup function ARM: 7017/1: Use generic BUG() handler ARM: 7102/1: mach-integrator: update defconfig ARM: 7087/2: mach-integrator: get timer frequency from clock ARM: 7086/2: mach-integrator: modernize clock event registration ARM: 7085/2: mach-integrator: clockevent supports oneshot mode ARM: 7084/1: mach-integrator: retire some timer macros ...
2011-10-25Merge branch 'next' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'next' of git://selinuxproject.org/~jmorris/linux-security: (95 commits) TOMOYO: Fix incomplete read after seek. Smack: allow to access /smack/access as normal user TOMOYO: Fix unused kernel config option. Smack: fix: invalid length set for the result of /smack/access Smack: compilation fix Smack: fix for /smack/access output, use string instead of byte Smack: domain transition protections (v3) Smack: Provide information for UDS getsockopt(SO_PEERCRED) Smack: Clean up comments Smack: Repair processing of fcntl Smack: Rule list lookup performance Smack: check permissions from user space (v2) TOMOYO: Fix quota and garbage collector. TOMOYO: Remove redundant tasklist_lock. TOMOYO: Fix domain transition failure warning. TOMOYO: Remove tomoyo_policy_memory_lock spinlock. TOMOYO: Simplify garbage collector. TOMOYO: Fix make namespacecheck warnings. target: check hex2bin result encrypted-keys: check hex2bin result ...
2011-10-25Merge branches 'arnd-randcfg-fixes', 'debug', 'io' (early part), 'l2x0', ↵Russell King
'p2v', 'pgt' (early part) and 'smp' into for-linus
2011-10-21Merge branches 'amd/fixes', 'debug/dma-api', 'arm/omap', 'arm/msm', 'core', ↵Joerg Roedel
'iommu/fault-reporting' and 'api/iommu-ops-per-bus' into next Conflicts: drivers/iommu/amd_iommu.c drivers/iommu/iommu.c
2011-10-20lib/raid6: Fix filename emitted in generated codeDan McGee
The files were renamed in commit cc4589ebf; fix the name in the file itself. Signed-off-by: Dan McGee <dpmcgee@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-10-18dynamic_debug: fix undefined reference to `__netdev_printk'Jason Baron
Dynamic debug recently added support for netdev_printk. It uses __netdev_printk() to support this functionality. However, when CONFIG_NET is not set, we get the following error: lib/built-in.o: In function `__dynamic_netdev_dbg': (.text+0x9fda): undefined reference to `__netdev_printk' Fix this by making the call to netdev_printk() contingent upon CONFIG_NET. We could have fixed this by defining netdev_printk() to a 'no-op' in the !CONFIG_NET case. However, this is not consistent with how the networking layer uses netdev_printk. For example, CONFIG_NET is not set, netdev_printk() does not have a 'no-op' definition defined. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18dynamic_debug: use a single printk() to emit messagesJason Baron
We were using KERN_CONT to combine messages with their prefix. However, KERN_CONT is not smp safe, in the sense that it can interleave messages. This interleaving can result in printks coming out at the wrong loglevel. With the high frequency of printks that dynamic debug can produce this is not desirable. So make dynamic_emit_prefix() fill a char buf[64] instead of doing a printk directly. If we enable printing out of function, module, line, or pid info, they are placed in this 64 byte buffer. In my testing 64 bytes was enough size to fulfill all requests. Even if it's not, we can match up the printk itself to see where it's from, so to me this is no big deal. [akpm@linux-foundation.org: convert dangerous macro to C] Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18dynamic_debug: remove num_enabled accountingJason Baron
The num_enabled accounting isn't actually used anywhere - remove them. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-06sched: Wrap scheduler p->cpus_allowed accessPeter Zijlstra
This task is preparatory for the migrate_disable() implementation, but stands on its own and provides a cleanup. It currently only converts those sites required for task-placement. Kosaki-san once mentioned replacing cpus_allowed with a proper cpumask_t instead of the NR_CPUS sized array it currently is, that would also require something like this. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Link: http://lkml.kernel.org/n/tip-e42skvaddos99psip0vce41o@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04llist: Remove cpu_relax() usage in cmpxchg loopsPeter Zijlstra
Initial benchmarks show they're a net loss: $ for i in /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor ; do echo performance > $i; done $ echo 4096 32000 64 128 > /proc/sys/kernel/sem $ ./sembench -t 2048 -w 1900 -o 0 Pre: run time 30 seconds 778936 worker burns per second run time 30 seconds 912190 worker burns per second run time 30 seconds 817506 worker burns per second run time 30 seconds 830870 worker burns per second run time 30 seconds 845056 worker burns per second Post: run time 30 seconds 905920 worker burns per second run time 30 seconds 849046 worker burns per second run time 30 seconds 886286 worker burns per second run time 30 seconds 822320 worker burns per second run time 30 seconds 900283 worker burns per second So about 4% faster. (!) cpu_relax() stalls the pipeline, therefore, when used in a tight loop it has the following benefits: - allows SMT siblings to have a go; - reduces pressure on the CPU interconnect. However, cmpxchg loops are unfair and thus have unbounded completion time, therefore we should avoid getting in such heavily contended situations where the above benefits make any difference. A typical cmpxchg loop should not go round more than a handfull of times at worst, therefore adding extra delays just slows things down. Since the llist primitives are new, there aren't any bad users yet, and we should avoid growing them. Heavily contended sites should generally be better off using the ticket locks for serialization since they provide bounded completion times (fifo-fair over the cpus). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Huang Ying <ying.huang@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1315836358.26517.43.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04llist: Return whether list is empty before adding in llist_add()Huang Ying
Extend the llist_add*() functions to return a success indicator, this allows us in the scheduler code to send an IPI if the queue was empty. ( There's no effect on existing users, because the list_add_xxx() functions are inline, thus this will be optimized out by the compiler if not used by callers. ) Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1315461646-1379-5-git-send-email-ying.huang@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-04llist: Move cpu_relax() to after the cmpxchg()Huang Ying
If in llist_add()/etc. functions the first cmpxchg() call succeeds, it is not necessary to use cpu_relax() before the cmpxchg(). So cpu_relax() in a busy loop involving cmpxchg() should go after cmpxchg() instead of before that. This patch fixes this for all involved llist functions. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1315461646-1379-4-git-send-email-ying.huang@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
