commit 711a49a07f84f914aac26a52143f6e7526571143 upstream.
The last patch to lib/idr.c caused a bug if idr_get_new_above() was
called on an empty idr.
Usually, nodes stay on the same layer. New layers are added to the top
of the tree.
The exception is idr_get_new_above() on an empty tree: In this case, the
new root node is first added on layer 0, then moved upwards. p->layer
was not updated.
As usual: You shall never rely on the source code comments, they will
only mislead you.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
commit 6ff2d39b91aec3dcae951afa982059e3dd9b49dc upstream.
2nd part of the fixes needed for
http://bugzilla.kernel.org/show_bug.cgi?id=11796.
When the idr tree is either grown or shrunk, then the update to the number
of layers and the top pointer were not atomic. This race caused crashes.
The attached patch fixes that by replicating the layers counter in each
layer, thus idr_find doesn't need idp->layers anymore.
Cc: Clement Calmels <cboulte@gmail.com>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Pierre Peiffer <peifferp@gmail.com>
commit f652c521e0bec2e70cf123f47e80117a7e6ed139 upstream.
kunmap() takes as argument the struct page that orginally got kmap()'d,
however the sg_miter_stop() function passed it the kernel virtual address
instead, resulting in weird stuff.
Somehow I ended up fixing this bug by accident while looking for a bug in
the same area.
Reported-by: kerneloops.org
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Hugh Dickins <hugh@veritas.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
sg: disable interrupts inside sg_copy_buffer
The callers of sg_copy_buffer must disable interrupts before calling
it (since it uses kmap_atomic). Some callers use it on
interrupt-disabled code but some need to take the trouble to disable
interrupts just for this. No wonder they forget about it and we hit a
bug like:
http://bugzilla.kernel.org/show_bug.cgi?id=11529
James said that it might be better to disable interrupts inside the
function rather than risk the callers getting it wrong.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
This fixes a SWIOTLB oops
With SWIOTLB being enabled and straight-forward page allocation
failure [1], the swiotlb_alloc_coherent fall-back path hits an
issue [2], resulting in my webcam failing to work.
At the time of oops, RDI is clearly a pointer to a structure which
has arrived as NULL, leading to the typo in swiotlb_map_single's
callsite arguments.
Correctly passing the device structure [3] addresses the issue and
gets my webcam working again (the allocation failure still occuring).
--- [1]
skype: page allocation failure. order:3, mode:0x1
Pid: 5895, comm: skype Not tainted 2.6.27-rc6-235c-debug #1
Call Trace:
[<ffffffff802b7cf0>] __alloc_pages_internal+0x4a0/0x5d0
[<ffffffff802d5ddd>] alloc_pages_current+0xad/0x110
[<ffffffff802b4ccd>] __get_free_pages+0x1d/0x60
[<ffffffff8046cd39>] swiotlb_alloc_coherent+0x49/0x180
[<ffffffff80212731>] dma_alloc_coherent+0x281/0x310
[<ffffffff805621c0>] hcd_buffer_alloc+0x50/0x90
[<ffffffff805547fd>] usb_buffer_alloc+0x2d/0x40
[<ffffffffa0056763>] uvc_alloc_urb_buffers+0x53/0xf0 [uvcvideo]
[<ffffffffa0056958>] uvc_init_video+0x158/0x3e0 [uvcvideo]
[<ffffffffa0056c17>] uvc_video_enable+0x37/0x80 [uvcvideo]
[<ffffffffa0055853>] uvc_v4l2_do_ioctl+0x723/0x1260 [uvcvideo]
[<ffffffff8026dd61>] ? trace_hardirqs_off_caller+0x21/0xc0
[<ffffffffa0032c9f>] video_usercopy+0x19f/0x390 [videodev]
[<ffffffffa0055130>] ? uvc_v4l2_do_ioctl+0x0/0x1260 [uvcvideo]
[<ffffffff8026d0ce>] ? put_lock_stats+0xe/0x30
[<ffffffffa0054dad>] uvc_v4l2_ioctl+0x4d/0x80 [uvcvideo]
[<ffffffffa0045083>] native_ioctl+0x83/0x90 [compat_ioctl32]
[<ffffffffa004534e>] v4l_compat_ioctl32+0x2be/0x1da4 [compat_ioctl32]
[<ffffffff806aad21>] ? do_page_fault+0x3d1/0xae0
[<ffffffff80270ccd>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff80270c59>] ? trace_hardirqs_on_caller+0x149/0x1b0
[<ffffffff80329afa>] compat_sys_ioctl+0x8a/0x3c0
[<ffffffff806a700d>] ? trace_hardirqs_off_thunk+0x3a/0x3c
[<ffffffff8022f816>] sysenter_dispatch+0x7/0x2c
[<ffffffff806a6fce>] ? trace_hardirqs_on_thunk+0x3a/0x3f
Mem-Info:
Node 0 DMA per-cpu:
CPU 0: hi: 0, btch: 1 usd: 0
CPU 1: hi: 0, btch: 1 usd: 0
Node 0 DMA32 per-cpu:
CPU 0: hi: 186, btch: 31 usd: 3
CPU 1: hi: 186, btch: 31 usd: 0
Node 0 Normal per-cpu:
CPU 0: hi: 186, btch: 31 usd: 23
CPU 1: hi: 186, btch: 31 usd: 179
Active:78545 inactive:48683 dirty:31 writeback:0 unstable:2
free:830202 slab:17516 mapped:17473 pagetables:3496 bounce:0
Node 0 DMA free:36kB min:28kB low:32kB high:40kB active:0kB
inactive:0kB present:15156kB pages_scanned:0 all_unreclaimable? no
lowmem_reserve[]: 0 3207 3956 3956
Node 0 DMA32 free:3197192kB min:6512kB low:8140kB high:9768kB
active:0kB inactive:0kB present:3284896kB pages_scanned:0
lowmem_reserve[]: 0 0 748 748
Node 0 Normal free:123580kB min:1516kB low:1892kB high:2272kB
active:314180kB inactive:194732kB present:766464kB pages_scanned:0
lowmem_reserve[]: 0 0 0 0
Node 0 DMA: 1*4kB 0*8kB 0*16kB 1*32kB 0*64kB 0*128kB 0*256kB 0*512kB
0*1024kB 0*2048kB 0*4096kB = 36kB
Node 0 DMA32: 4*4kB 3*8kB 2*16kB 3*32kB 4*64kB 5*128kB 3*256kB 5*512kB
4*1024kB 5*2048kB 776*4096kB = 3197224kB
Node 0 Normal: 14*4kB 14*8kB 8*16kB 6*32kB 1*64kB 3*128kB 3*256kB
2*512kB 4*1024kB 1*2048kB 28*4096kB = 123560kB
64847 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 502752kB
Total swap = 502752kB
1048576 pages RAM
52120 pages reserved
71967 pages shared
143004 pages non-shared
--- [2]
BUG: unable to handle kernel NULL pointer dereference at 00000000000002c8
IP: [<ffffffff8046c84c>] map_single+0x1c/0x280
PGD 10e54e067 PUD 10e595067 PMD 0
Oops: 0000 [1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Modules linked in: kvm_intel kvm microcode uvcvideo compat_ioctl32
videodev v4l1_compat shpchp pci_hotplug
RIP: 0010:[<ffffffff8046c84c>] [<ffffffff8046c84c>] map_single+0x1c/0x280
RSP: 0018:ffff88010e78d988 EFLAGS: 00210296
RAX: 0000780000000000 RBX: 0000000000000000 RCX: 0000000000000002
RDX: 0000000000005000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88010e78d9e8 R08: 0000000000000000 R09: 0000000000000001
R10: ffff88010e78d698 R11: 0000000000000001 R12: 0000000000000002
R13: 0000000000000000 R14: 0000000000005000 R15: ffff88012f1c9968
FS: 0000000000000000(0000) GS:ffffffff80a6cdc0(0063) knlGS:00000000f6355b90
CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
CR2: 00000000000002c8 CR3: 000000010e57d000 CR4: 00000000000026e0
Process skype (pid: 5895, threadinfo ffff88010e78c000, task ffff88012b9cc460)
Stack: 0000000200000000 0000000000005000 0000000000000000 0000000000000000
00000000000017b8 0000000000000000 ffff88010e78d9c8 0000000000000000
0000000000000002 0000000000000000 0000000000005000 ffff88012f1c9968
Call Trace:
[<ffffffff8046cbb0>] swiotlb_map_single_attrs+0x60/0xf0
[<ffffffff8046cc4c>] swiotlb_map_single+0xc/0x10
[<ffffffff8046cdee>] swiotlb_alloc_coherent+0xfe/0x180
Code: 45 31 c0 48 89 e5 e8 a4 ff ff ff c9 c3 66 90 55 48 89 e5 41 57
41 56 41 55 41 54 53 48 83 ec 38 48 89 75 b0 48 89 55 a8 89 4d a4 <48>
8b 87 c8 02 00 00 48 85 c0 0f 84 1c 02 00 00 48 8b 58 08 48
RIP [<ffffffff8046c84c>] map_single+0x1c/0x280
RSP <ffff88010e78d988>
---[ end trace 5d15baeeb7025a0e ]---
--- [3]
ffffffff8046c830 <map_single>:
map_single():
/store/kernel/linux/lib/swiotlb.c:291
ffffffff8046c830: 55 push %rbp
ffffffff8046c831: 48 89 e5 mov %rsp,%rbp
ffffffff8046c834: 41 57 push %r15
ffffffff8046c836: 41 56 push %r14
ffffffff8046c838: 41 55 push %r13
ffffffff8046c83a: 41 54 push %r12
ffffffff8046c83c: 53 push %rbx
ffffffff8046c83d: 48 83 ec 38 sub $0x38,%rsp
ffffffff8046c841: 48 89 75 b0 mov %rsi,-0x50(%rbp)
ffffffff8046c845: 48 89 55 a8 mov %rdx,-0x58(%rbp)
ffffffff8046c849: 89 4d a4 mov %ecx,-0x5c(%rbp)
dma_get_seg_boundary():
/store/kernel/linux/include/linux/dma-mapping.h:80
ffffffff8046c84c: 48 8b 87 c8 02 00 00 mov 0x2c8(%rdi),%rax <----
--- [4]
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
It was introduced by "vsprintf: add support for '%pS' and '%pF' pointer
formats" in commit 0fe1ef24f7bd0020f29ffe287dfdb9ead33ca0b2. However,
the current way its coded doesn't work on parisc64. For two reasons: 1)
parisc isn't in the #ifdef and 2) parisc has a different format for
function descriptors
Make dereference_function_descriptor() more accommodating by allowing
architecture overrides. I put the three overrides (for parisc64, ppc64
and ia64) in arch/kernel/module.c because that's where the kernel
internal linker which knows how to deal with function descriptors sits.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Tony Luck <tony.luck@intel.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
* 'core/debugobjects' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
debugobjects: fix lockdep warning
This bug is causing random crashes
(http://bugzilla.kernel.org/show_bug.cgi?id=11414).
-fno-omit-frame-pointer is only needed on powerpc when -pg is also
supplied, and there is a gcc bug that causes incorrect code generation
on 32-bit powerpc when -fno-omit-frame-pointer is used---it uses stack
locations below the stack pointer, which is not allowed by the ABI
because those locations can and sometimes do get corrupted by an
interrupt.
This ensures that CONFIG_FRAME_POINTER is only selected by ftrace.
When CONFIG_FTRACE is enabled we also pass -mno-sched-epilog to work
around the gcc codegen bug.
Patch based on work by:
Andreas Schwab <schwab@suse.de>
Segher Boessenkool <segher@kernel.crashing.org>
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Daniel J. Blueman reported:
> [ INFO: possible circular locking dependency detected ]
> 2.6.27-rc4-224c #1
> hald/4680 is trying to acquire lock:
> (&n->list_lock){++..}, at: [<ffffffff802bfa26>] add_partial+0x26/0x80
> but task is already holding lock:
> (&obj_hash[i].lock){++..}, at: [<ffffffff8041cfdc>]
> debug_object_free+0x5c/0x120
We fix it by moving the actual freeing to outside the lock (the lock
now only protects the list).
The pool lock is also promoted to irq-safe (suggested by Dan). It's
necessary because free_pool is now called outside the irq disabled
region. So we need to protect against an interrupt handler which calls
debug_object_init().
[tglx@linutronix.de: added hlist_move_list helper to avoid looping
through the list twice]
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
A recent patch from Kay Sievers <kay.sievers@vrfy.org>
replaced the first occurrence of '/' with '!' as needed for block devices.
Now do some cheap defensive coding and replace all of them to avoid future
issues in this area.
Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de>
Cc: Kay Sievers <kay.sievers@vrfy.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
lmb: Fix reserved region handling in lmb_enforce_memory_limit().
sparc64: Fix cmdline_memory_size handling bugs.
sparc64: Fix overshoot in nid_range().
I noticed that sysctl_check.o was the largest object file in
a allnoconfig build in kernel/*.
36243 0 0 36243 8d93 kernel/sysctl_check.o
This is because it was default y and && EMBEDDED. But I don't
really see a need for a non kernel developer to have their
sysctls checked all the time.
So move the Kconfig into the kernel debugging section and
also drop the default y and the EMBEDDED check.
The idea of the implementation of this fix is from Michael Ellerman.
This function has two loops, but they each interpret the memory_limit
value differently. The first loop interprets it as a "size limit"
whereas the second loop interprets it as an "address limit".
Before the second loop runs, reset memory_limit to lmb_end_of_DRAM()
so that it all works out.
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Currently source files in the Documentation/ sub-dir can easily bit-rot
since they are not generally buildable, either because they are hidden in
text files or because there are no Makefile rules for them. This needs to
be fixed so that the source files remain usable and good examples of code
instead of bad examples.
Add the ability to build source files that are in the Documentation/ dir.
Add to Kconfig as "BUILD_DOCSRC" config symbol.
Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the
Documentation/ sources. Or enable BUILD_DOCSRC in the *config system.
However, this symbol depends on HEADERS_CHECK since the header files need
to be installed (for userspace builds).
Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32,
sparc64, powerpc, sh, m68k, & mips.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no
good reason.
This became noticed with NR_CPUS=4096 patches, when length of printed
representation of cpumask becase 1152, but cat(1) continued to read with
1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns
1023, check returns -EINVAL.
Fix it by switching to seq_file, so handler will just fill buffer and
doesn't care about offsets, length, filling EOF and all this crap.
For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and
seq_nodemask().
Reviewed-by: Paul Jackson <pj@sgi.com>
Cc: Mike Travis <travis@sgi.com>
Fix wrong conversion function used by strict_strtou*
Signed-off-by: Yi Yang <yi.y.yang@intel.com>
Reported-by: Swen Schillig <swen@vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
kgdb: fix gdb serial thread queries
kgdb: fix kgdb_validate_break_address to perform a mem write
kgdb: remove the requirement for CONFIG_FRAME_POINTER
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (46 commits)
tcp: MD5: Fix IPv6 signatures
skbuff: add missing kernel-doc for do_not_encrypt
net/ipv4/route.c: fix build error
tcp: MD5: Fix MD5 signatures on certain ACK packets
ipv6: Fix ip6_xmit to send fragments if ipfragok is true
ipvs: Move userspace definitions to include/linux/ip_vs.h
netdev: Fix lockdep warnings in multiqueue configurations.
netfilter: xt_hashlimit: fix race between htable_destroy and htable_gc
netfilter: ipt_recent: fix race between recent_mt_destroy and proc manipulations
netfilter: nf_conntrack_tcp: decrease timeouts while data in unacknowledged
irda: replace __FUNCTION__ with __func__
nsc-ircc: default to dongle type 9 on IBM hardware
bluetooth: add quirks for a few hci_usb devices
hysdn: remove the packed attribute from PofTimStamp_tag
isdn: use the common ascii hex helpers
tg3: adapt tg3 to use reworked PCI PM code
atm: fix direct casts of pointers to u32 in the InterPhase driver
atm: fix const assignment/discard warnings in the ATM networking driver
net: use the common ascii hex helpers
random32: seeding improvement
There is no technical reason that the kgdb core requires frame
pointers. It is up to the end user of KGDB to decide if they need
them or not.
[ anemo@mba.ocn.ne.jp: removed frame pointers on mips ]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Otherwise lock debugging messages on runqueue locks can deadlock the
system due to the wakeups performed by printk().
The rationale is:
* use u32 consistently
* no need to do LCG on values from (better) get_random_bytes
* use more data from get_random_bytes for secondary seeding
* don't reduce state space on srandom32()
* enforce state variable initialization restrictions
Note: the second paper has a version of random32() with even longer period
and a version of random64() if needed.
This IOMMU helper function doesn't work for some architectures:
http://marc.info/?l=linux-kernel&m=121699304403202&w=2
It also breaks POWER and SPARC builds:
http://marc.info/?l=linux-kernel&m=121730388001890&w=2
Currently, only x86 IOMMUs use this so let's move it to x86 for
now.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits)
x86/PCI: use dev_printk when possible
PCI: add D3 power state avoidance quirk
PCI: fix bogus "'device' may be used uninitialized" warning in pci_slot
PCI: add an option to allow ASPM enabled forcibly
PCI: disable ASPM on pre-1.1 PCIe devices
PCI: disable ASPM per ACPI FADT setting
PCI MSI: Don't disable MSIs if the mask bit isn't supported
PCI: handle 64-bit resources better on 32-bit machines
PCI: rewrite PCI BAR reading code
PCI: document pci_target_state
PCI hotplug: fix typo in pcie hotplug output
x86 gart: replace to_pages macro with iommu_num_pages
x86, AMD IOMMU: replace to_pages macro with iommu_num_pages
iommu: add iommu_num_pages helper function
dma-coherent: add documentation to new interfaces
Cris: convert to using generic dma-coherent mem allocator
Sh: use generic per-device coherent dma allocator
ARM: support generic per-device coherent dma mem
Generic dma-coherent: fix DMA_MEMORY_EXCLUSIVE
x86: use generic per-device dma coherent allocator
Cc: Dave Young <hidave.darkstar@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into for-linus
This implements a platform-independent version of show_mem().
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Chris Zankel <chris@zankel.net>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Mikael Starvik <starvik@axis.com>
This adds the new function task_current_syscall() on machines where the
asm/syscall.h interface is supported (CONFIG_HAVE_ARCH_TRACEHOOK). It's
exported for modules to use in the future. This function safely samples
the state of a blocked thread to collect what system call it is blocked
in, and the six system call argument registers.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes
part of the warning section for better reporting/collection. In addition, one
of the if() clauses collapes into the WARN() entirely now.
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Introduce gang_lookup_slot() and gang_lookup_slot_tag() functions, which
are used by lockless pagecache.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER
architecture does:
This enables us to cleanly fix the Calgary IOMMU issue that some devices
are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423).
I think that per-device dma_mapping_ops support would be also helpful for
KVM people to support PCI passthrough but Andi thinks that this makes it
difficult to support the PCI passthrough (see the above thread). So I
CC'ed this to KVM camp. Comments are appreciated.
A pointer to dma_mapping_ops to struct dev_archdata is added. If the
pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's
NULL, the system-wide dma_ops pointer is used as before.
If it's useful for KVM people, I plan to implement a mechanism to register
a hook called when a new pci (or dma capable) device is created (it works
with hot plugging). It enables IOMMUs to set up an appropriate
dma_mapping_ops per device.
The major obstacle is that dma_mapping_error doesn't take a pointer to the
device unlike other DMA operations. So x86 can't have dma_mapping_ops per
device. Note all the POWER IOMMUs use the same dma_mapping_error function
so this is not a problem for POWER but x86 IOMMUs use different
dma_mapping_error functions.
The first patch adds the device argument to dma_mapping_error. The patch
is trivial but large since it touches lots of drivers and dma-mapping.h in
all the architecture.
This patch:
dma_mapping_error() doesn't take a pointer to the device unlike other DMA
operations. So we can't have dma_mapping_ops per device.
Note that POWER already has dma_mapping_ops per device but all the POWER
IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device
argument.
[akpm@linux-foundation.org: fix sge]
[akpm@linux-foundation.org: fix svc_rdma]
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix bnx2x]
[akpm@linux-foundation.org: fix s2io]
[akpm@linux-foundation.org: fix pasemi_mac]
[akpm@linux-foundation.org: fix sdhci]
[akpm@linux-foundation.org: fix sparc]
[akpm@linux-foundation.org: fix ibmvscsi]
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Avi Kivity <avi@qumranet.com>
* Replace previous instances of the cpumask_of_cpu_ptr* macros
with a the new (lvalue capable) generic cpumask_of_cpu().
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
Calculating the number of pages from given address and length numbers is a task
required in multiple IOMMU implementations. So implement this as a generic
function into the IOMMU helper code.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: iommu@lists.linux-foundation.org
Cc: bhavna.sarathy@amd.com
Cc: robert.richter@amd.com
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Introduce the free_layer() routine: it is the one that actually frees memory
after a grace period has elapsed.
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
Reviewed-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Jim Houston <jim.houston@comcast.net>
Make idr_find rcu-safe: it can now be called inside an rcu_read critical
section.
Make the idr_get_new* routines rcu-safe.
Do some code factorization in the return code analysis.
Fix the incomplete printk call.
This is a trivial patch that renames:
. alloc_layer to get_from_free_list since it idr_pre_get that actually
allocates memory.
. free_layer to move_to_free_list since memory is not actually freed there.
This makes things more clear for the next patches.
All ratelimit user use same jiffies and burst params, so some messages
(callbacks) will be lost.
For example:
a call printk_ratelimit(5 * HZ, 1)
b call printk_ratelimit(5 * HZ, 1) before the 5*HZ timeout of a, then b will
will be supressed.
- rewrite __ratelimit, and use a ratelimit_state as parameter. Thanks for
hints from andrew.
- Add WARN_ON_RATELIMIT, update rcupreempt.h
- remove __printk_ratelimit
- use __ratelimit in net_ratelimit
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Arjan noted that the list_head debugging is BUG'ing when it detects
corruption. By causing the box to panic immediately, we're possibly
losing some bug reports. Changing this to a WARN() should mean we at the
least start seeing reports collected at kerneloops.org
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Arjan van de Ven <arjan@infradead.org>
Now that WARN() exists, we can fold some of the printk's into it.
Cc: Greg KH <greg@kroah.com>
Inflate requires some dynamic memory allocation very early in the boot
process and this is provided with a set of four functions:
malloc/free/gzip_mark/gzip_release.
The old inflate code used a mark/release strategy rather than implement
free. This new version instead keeps a count on the number of outstanding
allocations and when it hits zero, it resets the malloc arena.
This allows removing all the mark and release implementations and unifying
all the malloc/free implementations.
The architecture-dependent code must define two addresses:
- free_mem_ptr, the address of the beginning of the area in which
allocations should be made
- free_mem_end_ptr, the address of the end of the area in which
allocations should be made. If set to 0, then no check is made on
the number of allocations, it just grows as much as needed
The architecture-dependent code can also provide an arch_decomp_wdog()
function call. This function will be called several times during the
decompression process, and allow to notify the watchdog that the system is
still running. If an architecture provides such a call, then it must
define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls
arch_decomp_wdog().
Work initially done by Matt Mackall, updated to a recent version of the
kernel and improved by me.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Mikael Starvik <mikael.starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp>
Remove the conditional surrounding the definition of list_add() from list.h
since, if you define CONFIG_DEBUG_LIST, the definition you will subsequently
pick up from lib/list_debug.c will be absolutely identical, at which point you
can remove that redundant definition from list_debug.c as well.
Cc: Dave Jones <davej@codemonkey.org.uk>
Extend memparse() to allow the caller to use a NULL second parameter, which
would represent no interest in returning the address of the end of the parsed
string.
In numerous cases, callers invoke memparse() to parse a possibly-suffixed
string (such as "64K" or "2G" or whatever) and define a character pointer to
accept the end pointer being returned by memparse() even though they have no
interest in it and promptly throw it away.
This (backward-compatible) enhancement allows callers to use NULL in the cases
where they just don't care about getting back that end pointer.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Richard Purdie <rpurdie@rpsys.net>
This updates <linux/bcd.h> to define the key routines as constant
functions, which the macros will then call. Newer code can now call
bcd2bin() instead of SCREAMING BCD2BIN() TO THE FOUR WINDS.
This lets each driver shrink their codespace by using N function calls to
a single (global) copy of those routines, instead of N inlined copies of
these functions per driver.
These routines aren't used in speed-critical code. Almost all callers are
in the RTC framework. Typical per-driver savings is near 300 bytes.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Adrian Bunk <bunk@kernel.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
