path: root/lib
2014-03-04lib/radix-tree.c: swapoff tmpfs radix_tree: remember to rcu_read_unlockHugh Dickins
Running fsx on tmpfs with concurrent memhog-swapoff-swapon, lots of BUG: sleeping function called from invalid context at kernel/fork.c:606 in_atomic(): 0, irqs_disabled(): 0, pid: 1394, name: swapoff 1 lock held by swapoff/1394: #0: (rcu_read_lock){.+.+.+}, at: [<ffffffff812520a1>] radix_tree_locate_item+0x1f/0x2b6 followed by ================================================ [ BUG: lock held when returning to user space! ] 3.14.0-rc1 #3 Not tainted ------------------------------------------------ swapoff/1394 is leaving the kernel with locks still held! 1 lock held by swapoff/1394: #0: (rcu_read_lock){.+.+.+}, at: [<ffffffff812520a1>] radix_tree_locate_item+0x1f/0x2b6 after which the system recovered nicely. Whoops, I long ago forgot the rcu_read_unlock() on one unlikely branch. Fixes e504f3fdd63d ("tmpfs radix_tree: locate_item to speed up swapoff") Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04dma debug: account for cachelines and read-only mappings in overlap trackingDan Williams
While debug_dma_assert_idle() checks if a given *page* is actively undergoing dma the valid granularity of a dma mapping is a *cacheline*. Sander's testing shows that the warning message "DMA-API: exceeded 7 overlapping mappings of pfn..." is falsely triggering. The test is simply mapping multiple cachelines in a given page. Ultimately we want overlap tracking to be valid as it is a real api violation, so we need to track active mappings by cachelines. Update the active dma tracking to use the page-frame-relative cacheline of the mapping as the key, and update debug_dma_assert_idle() to check for all possible mapped cachelines for a given page. However, the need to track active mappings is only relevant when the dma-mapping is writable by the device. In fact it is fairly standard for read-only mappings to have hundreds or thousands of overlapping mappings at once. Limiting the overlap tracking to writable (!DMA_TO_DEVICE) eliminates this class of false-positive overlap reports. Note, the radix gang lookup is sub-optimal. It would be best if it stopped fetching entries once the search passed a page boundary. Nevertheless, this implementation does not perturb the original net_dma failing case. That is to say the extra overhead does not show up in terms of making the failing case pass due to a timing change. References: http://marc.info/?l=linux-netdev&m=139232263419315&w=2 http://marc.info/?l=linux-netdev&m=139217088107122&w=2 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Reported-by: Dave Jones <davej@redhat.com> Tested-by: Dave Jones <davej@redhat.com> Tested-by: Sander Eikelenboom <linux@eikelenboom.it> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Wei Liu <wei.liu2@citrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-14Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO fixes from Jens Axboe: "Second round of updates and fixes for 3.14-rc2. Most of this stuff has been queued up for a while. The notable exception is the blk-mq changes, which are naturally a bit more in flux still. The pull request contains: - Two bug fixes for the new immutable vecs, causing crashes with raid or swap. From Kent. - Various blk-mq tweaks and fixes from Christoph. A fix for integrity bio's from Nic. - A few bcache fixes from Kent and Darrick Wong. - xen-blk{front,back} fixes from David Vrabel, Matt Rushton, Nicolas Swenson, and Roger Pau Monne. - Fix for a vec miscount with integrity vectors from Martin. - Minor annotations or fixes from Masanari Iida and Rashika Kheria. - Tweak to null_blk to do more normal FIFO processing of requests from Shlomo Pongratz. - Elevator switching bypass fix from Tejun. - Softlockup in blkdev_issue_discard() fix when !CONFIG_PREEMPT from me" * 'for-linus' of git://git.kernel.dk/linux-block: (31 commits) block: add cond_resched() to potentially long running ioctl discard loop xen-blkback: init persistent_purge_work work_struct blk-mq: pair blk_mq_start_request / blk_mq_requeue_request blk-mq: dont assume rq->errors is set when returning an error from ->queue_rq block: Fix cloning of discard/write same bios block: Fix type mismatch in ssize_t_blk_mq_tag_sysfs_show blk-mq: rework flush sequencing logic null_blk: use blk_complete_request and blk_mq_complete_request virtio_blk: use blk_mq_complete_request blk-mq: rework I/O completions fs: Add prototype declaration to appropriate header file include/linux/bio.h fs: Mark function as static in fs/bio-integrity.c block/null_blk: Fix completion processing from LIFO to FIFO block: Explicitly handle discard/write same segments block: Fix nr_vecs for inline integrity vectors blk-mq: Add bio_integrity setup to blk_mq_make_request blk-mq: initialize sg_reserved_size blk-mq: handle dma_drain_size blk-mq: divert __blk_put_request for MQ ops blk-mq: support at_head inserations for blk_execute_rq ...
2014-02-08Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Quite a varied little collection of fixes. Most of them are relatively small or isolated; the biggest one is Mel Gorman's fixes for TLB range flushing. A couple of AMD-related fixes (including not crashing when given an invalid microcode image) and fix a crash when compiled with gcov" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Unify valid container checks x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y x86/efi: Allow mapping BGRT on x86-32 x86: Fix the initialization of physnode_map x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable() x86/intel/mid: Fix X86_INTEL_MID dependencies arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge x86: mm: change tlb_flushall_shift for IvyBridge x86/mm: Eliminate redundant page table walk during TLB range flushing x86/mm: Clean up inconsistencies when flushing TLB ranges mm, x86: Account for TLB flushes only when debugging x86/AMD/NB: Fix amd_set_subcaches() parameter type x86/quirks: Add workaround for AMD F16h Erratum792 x86, doc, kconfig: Fix dud URL for Microcode data
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-06x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=yPeter Oberparleiter
Commit d61931d89b, "x86: Add optimized popcnt variants" introduced compile flag -fcall-saved-rdi for lib/hweight.c. When combined with options -fprofile-arcs and -O2, this flag causes gcc to generate broken constructor code. As a result, a 64 bit x86 kernel compiled with CONFIG_GCOV_PROFILE_ALL=y prints message "gcov: could not create file" and runs into sproadic BUGs during boot. The gcc people indicate that these kinds of problems are endemic when using ad hoc calling conventions. It is therefore best to treat any file compiled with ad hoc calling conventions as an isolated environment and avoid things like profiling or coverage analysis, since those subsystems assume a "normal" calling conventions. This patch avoids the bug by excluding lib/hweight.o from coverage profiling. Reported-by: Meelis Roos <mroos@linux.ee> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/52F3A30C.7050205@linux.vnet.ibm.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@vger.kernel.org>
2014-02-04kbuild: don't enable DEBUG_INFO when building for COMPILE_TESTLinus Torvalds
It really isn't very interesting to have DEBUG_INFO when doing compile coverage stuff (you wouldn't want to run the result anyway, that's kind of the whole point of COMPILE_TEST), and it currently makes the build take longer and use much more disk space for "all{yes,mod}config". There's somewhat active discussion about this still, and we might end up with some new config option for things like this (Andi points out that the silly X86_DECODER_SELFTEST option also slows down the normal coverage tests hugely), but I'm starting the ball rolling with this simple one-liner. DEBUG_INFO isn't that noticeable if you have tons of memory and a good IO subsystem, but it hurts you a lot if you don't - for very little upside for the common use. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-02parisc/sti_console: prefer Linux fonts over built-in ROM fontsHelge Deller
The built-in ROM fonts lack many necessary ASCII characters, which is why it makes sens to prefer the Linux fonts instead if they are available. This makes consoles on STI graphics cards which are not supported by the stifb driver (e.g. Visualize FXe) looks much nicer. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
2014-01-30percpu_ida: fix a live lockShaohua Li
steal_tags only happens when free tags is more than half of the total tags. This is too strict and can cause live lock. I found that if one cpu has free tags, but other cpu can't steal (thread is bound to specific cpus), threads which want to allocate tags are always sleeping. I found this when I run next patch, but this could happen without it I think. I did performance test too with null_blk. Two cases (each cpu has enough percpu tags, or total tags are limited), no performance changes were observed. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-29dma-debug: fix overlap detectionDan Williams
Commit 0abdd7a81b7e ("dma-debug: introduce debug_dma_assert_idle()") was reworked to expand the overlap counter to the full range expressable by 3 tag bits, but it has a thinko in treating the overlap counter as a pure reference count for the entry. Instead of deleting when the reference-count drops to zero, we need to delete when the overlap-count drops below zero. Also, when detecting overflow we can just test the overlap-count > MAX rather than applying special meaning to 0. Regression report available here: http://marc.info/?l=linux-netdev&m=139073373932386&w=2 This patch, now tested on the original net_dma case, sees the expected handful of reports before the eventual data corruption occurs. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Cc: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29lib/genalloc.c: add check gen_pool_dma_alloc() if dma pointer is not NULLLad, Prabhakar
In the gen_pool_dma_alloc() the dma pointer can be NULL and while assigning gen_pool_virt_to_phys(pool, vaddr) to dma caused the following crash on da850 evm: Unable to handle kernel NULL pointer dereference at virtual address 00000000 Internal error: Oops: 805 [#1] PREEMPT ARM Modules linked in: CPU: 0 PID: 1 Comm: swapper Tainted: G W 3.13.0-rc1-00001-g0609e45-dirty #5 task: c4830000 ti: c4832000 task.ti: c4832000 PC is at gen_pool_dma_alloc+0x30/0x3c LR is at gen_pool_virt_to_phys+0x74/0x80 Process swapper, call trace: gen_pool_dma_alloc+0x30/0x3c davinci_pm_probe+0x40/0xa8 platform_drv_probe+0x1c/0x4c driver_probe_device+0x98/0x22c __driver_attach+0x8c/0x90 bus_for_each_dev+0x6c/0x8c bus_add_driver+0x124/0x1d4 driver_register+0x78/0xf8 platform_driver_probe+0x20/0xa4 davinci_init_late+0xc/0x14 init_machine_late+0x1c/0x28 do_one_initcall+0x34/0x15c kernel_init_freeable+0xe4/0x1ac kernel_init+0x8/0xec This patch fixes the above. [akpm@linux-foundation.org: update kerneldoc] Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Nicolin Chen <b42378@freescale.com> Cc: Joe Perches <joe@perches.com> Cc: Sachin Kamat <sachin.kamat@linaro.org> Cc: <stable@vger.kernel.org> [3.13.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-28kobject: export kobj_sysfs_opsJeff Mahoney
struct kobj_attribute implements the baseline attribute functionality that can be used all over the place. We should export the ops associated with it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-27dynamic_debug: replace obselete simple_strtoul() with kstrtouint()Andrey Ryabinin
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: fix ddebug_parse_query()Andrey Ryabinin
This fixes following scenario: $ echo 'file dynamic_debug.c line 1-123 +p' > /sys/kernel/debug/dynamic_debug/control -bash: echo: write error: Invalid argument $ dmesg | grep dynamic_debug dynamic_debug:ddebug_parse_query: last-line:123 < 1st-line:1 dynamic_debug:ddebug_parse_query: query parse failed Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: remove wrong error messageAndrey Ryabinin
parse_lineno() returns either negative error code or zero. We don't need to print something here because if parse_lineno fails it will print error message. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27memblock, nobootmem: add memblock_virt_alloc_low()Yinghai Lu
The new memblock_virt APIs are used to replaced old bootmem API. We need to allocate page below 4G for swiotlb. That should fix regression on Andrew's system that is using swiotlb. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27Merge tag 'stable/for-linus-3.14-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb Pull swiotlb bug-fixes from Konrad Rzeszutek Wilk: - Don't DoS with 'swiotlb is full' message. - Documentation update. * tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb: swiotlb: Don't DoS us with 'swiotlb buffer is full' (v2) swiotlb: update format
2014-01-27Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "IEEE 1394 (FireWire) subsystem changes: - make remote debugging over 1394 a runtime option instead of a buildtime option - extend remote debug access past the 4 GB barrier on respectively capable hardware - documentation update" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: Enable remote DMA above 4 GB firewire: ohci: Turn remote DMA support into a module parameter Documentation/: update FireWire debugging documentation
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-25iscsi-target: Fix connection reset hang with percpu_ida_allocNicholas Bellinger
This patch addresses a bug where connection reset would hang indefinately once percpu_ida_alloc() was starved for tags, due to the fact that it always assumed uninterruptible sleep mode. So now make percpu_ida_alloc() check for signal_pending_state() for making interruptible sleep optional, and convert iscsit_allocate_cmd() to set TASK_INTERRUPTIBLE for GFP_KERNEL, or TASK_RUNNING for GFP_ATOMIC. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-01-23lib/decompress_unlz4.c: always set an error return code on failuresJan Beulich
"ret", being set to -1 early on, gets cleared by the first invocation of lz4_decompress()/lz4_decompress_unknownoutputsize(), and hence subsequent failures wouldn't be noticed by the caller without setting it back to -1 right after those calls. Reported-by: Matthew Daley <mattjd@gmail.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23rbtree/test: test rbtree_postorder_for_each_entry_safe()Cody P Schafer
Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Michel Lespinasse <walken@google.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23rbtree/test: move rb_node to the middle of the test structCody P Schafer
Avoid making the rb_node the first entry to catch some bugs around NULL checking the rb_node. Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Michel Lespinasse <walken@google.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23test: check copy_to/from_user boundary validationKees Cook
To help avoid an architecture failing to correctly check kernel/user boundaries when handling copy_to_user, copy_from_user, put_user, or get_user, perform some simple tests and fail to load if any of them behave unexpectedly. Specifically, this is to make sure there is a way to notice if things like what was fixed in commit 8404663f81d2 ("ARM: 7527/1: uaccess: explicitly check __user pointer when !CPU_USE_DOMAINS") ever regresses again, for any architecture. Additionally, adds new "user" selftest target, which loads this module. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23test: add minimal module for verification testingKees Cook
This is a pair of test modules I'd like to see in the tree. Instead of putting these in lkdtm, where I've been adding various tests that trigger crashes, these don't make sense there since they need to be either distinctly separate, or their pass/fail state don't need to crash the machine. These live in lib/ for now, along with a few other in-kernel test modules, and use the slightly more common "test_" naming convention, instead of "test-". We should likely standardize on the former: $ find . -name 'test_*.c' | grep -v /tools/ | wc -l 4 $ find . -name 'test-*.c' | grep -v /tools/ | wc -l 2 The first is entirely a no-op module, designed to allow simple testing of the module loading and verification interface. It's useful to have a module that has no other uses or dependencies so it can be reliably used for just testing module loading and verification. The second is a module that exercises the user memory access functions, in an effort to make sure that we can quickly catch any regressions in boundary checking (e.g. like what was recently fixed on ARM). This patch (of 2): When doing module loading verification tests (for example, with module signing, or LSM hooks), it is very handy to have a module that can be built on all systems under test, isn't auto-loaded at boot, and has no device or similar dependencies. This creates the "test_module.ko" module for that purpose, which only reports its load and unload to printk. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/cmdline.c: declare exported symbols immediatelyFelipe Contreras
WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(memparse); WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(get_option); WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(get_options); Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Levente Kurusa <levex@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/cmdline.c: fix style issuesFelipe Contreras
WARNING: space prohibited between function name and open parenthesis '(' +int get_option (char **str, int *pint) WARNING: space prohibited between function name and open parenthesis '(' + *pint = simple_strtol (cur, str, 0); ERROR: trailing whitespace + $ WARNING: please, no spaces at the start of a line + $ WARNING: space prohibited between function name and open parenthesis '(' + res = get_option ((char **)&str, ints + i); Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/kstrtox.c: remove redundant cleanupFelipe Contreras
We can't reach the cleanup code unless the flag KSTRTOX_OVERFLOW is not set, so there's not no point in clearing a bit that we know is not set. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Levente Kurusa <levex@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23vsprintf: add %pad extension for dma_addr_t useJoe Perches
dma_addr_t's can be either u32 or u64 depending on a CONFIG option. There are a few hundred dma_addr_t's printed via either cast to unsigned long long, unsigned long or no cast at all. Add %pad to be able to emit them without the cast. Update Documentation/printk-formats.txt too. Signed-off-by: Joe Perches <joe@perches.com> Cc: "Shevchenko, Andriy" <andriy.shevchenko@intel.com> Cc: Rob Landley <rob@landley.net> Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23dynamic_debug: add wildcard support to filter files/functions/modulesDu, Changbin
Add wildcard '*'(matches zero or more characters) and '?' (matches one character) support when qurying debug flags. Now we can open debug messages using keywords. eg: 1. open debug logs in all usb drivers echo "file drivers/usb/* +p" > <debugfs>/dynamic_debug/control 2. open debug logs for usb xhci code echo "file *xhci* +p" > <debugfs>/dynamic_debug/control Signed-off-by: Du, Changbin <changbin.du@gmail.com> Cc: Jason Baron <jbaron@akamai.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/parser.c: put EXPORT_SYMBOLs in the conventional placeAndrew Morton
Cc: Du, Changbin <changbin.du@gmail.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/parser.c: add match_wildcard() functionDu, Changbin
match_wildcard function is a simple implementation of wildcard matching algorithm. It only supports two usual wildcardes: '*' - matches zero or more characters '?' - matches one character This algorithm is safe since it is non-recursive. Signed-off-by: Du, Changbin <changbin.du@gmail.com> Cc: Jason Baron <jbaron@akamai.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23percpu_ida: Make percpu_ida_alloc + callers accept task state bitmaskKent Overstreet
This patch changes percpu_ida_alloc() + callers to accept task state bitmask for prepare_to_wait() for code like target/iscsi that needs it for interruptible sleep, that is provided in a subsequent patch. It now expects TASK_UNINTERRUPTIBLE when the caller is able to sleep waiting for a new tag, or TASK_RUNNING when the caller cannot sleep, and is forced to return a negative value when no tags are available. v2 changes: - Include blk-mq + tcm_fc + vhost/scsi + target/iscsi changes - Drop signal_pending_state() call v3 changes: - Only call prepare_to_wait() + finish_wait() when != TASK_RUNNING (PeterZ) Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-01-23assoc_array: remove global variableStephen Hemminger
The associative array code creates unnecessary and potentially problematic global variable 'status'. Remove it since never used. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21reciprocal_divide: update/correction of the algorithmHannes Frederic Sowa
Jakub Zawadzki noticed that some divisions by reciprocal_divide() were not correct [1][2], which he could also show with BPF code after divisions are transformed into reciprocal_value() for runtime invariance which can be passed to reciprocal_divide() later on; reverse in BPF dump ended up with a different, off-by-one K in some situations. This has been fixed by Eric Dumazet in commit aee636c4809fa5 ("bpf: do not use reciprocal divide"). This follow-up patch improves reciprocal_value() and reciprocal_divide() to work in all cases by using Granlund and Montgomery method, so that also future use is safe and without any non-obvious side-effects. Known problems with the old implementation were that division by 1 always returned 0 and some off-by-ones when the dividend and divisor where very large. This seemed to not be problematic with its current users, as far as we can tell. Eric Dumazet checked for the slab usage, we cannot surely say so in the case of flex_array. Still, in order to fix that, we propose an extension from the original implementation from commit 6a2d7a955d8d resp. [3][4], by using the algorithm proposed in "Division by Invariant Integers Using Multiplication" [5], Torbjörn Granlund and Peter L. Montgomery, that is, pseudocode for q = n/d where q, n, d is in u32 universe: 1) Initialization: int l = ceil(log_2 d) uword m' = floor((1<<32)*((1<<l)-d)/d)+1 int sh_1 = min(l,1) int sh_2 = max(l-1,0) 2) For q = n/d, all uword: uword t = (n*m')>>32 q = (t+((n-t)>>sh_1))>>sh_2 The assembler implementation from Agner Fog [6] also helped a lot while implementing. We have tested the implementation on x86_64, ppc64, i686, s390x; on x86_64/haswell we're still half the latency compared to normal divide. Joint work with Daniel Borkmann. [1] http://www.wireshark.org/~darkjames/reciprocal-buggy.c [2] http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c [3] https://gmplib.org/~tege/division-paper.pdf [4] http://homepage.cs.uiowa.edu/~jones/bcd/divide.html [5] http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.2556 [6] http://www.agner.org/optimize/asmlib.zip Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Austin S Hemmelgarn <ahferroin7@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: Jesse Gross <jesse@nicira.com> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Veaceslav Falico <vfalico@redhat.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Jakub Zawadzki <darkjames-ws@darkjames.pl> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - a couple of misc things - inotify/fsnotify work from Jan - ocfs2 updates (partial) - about half of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (117 commits) mm/migrate: remove unused function, fail_migrate_page() mm/migrate: remove putback_lru_pages, fix comment on putback_movable_pages mm/migrate: correct failure handling if !hugepage_migration_support() mm/migrate: add comment about permanent failure path mm, page_alloc: warn for non-blockable __GFP_NOFAIL allocation failure mm: compaction: reset scanner positions immediately when they meet mm: compaction: do not mark unmovable pageblocks as skipped in async compaction mm: compaction: detect when scanners meet in isolate_freepages mm: compaction: reset cached scanner pfn's before reading them mm: compaction: encapsulate defer reset logic mm: compaction: trace compaction begin and end memcg, oom: lock mem_cgroup_print_oom_info sched: add tracepoints related to NUMA task migration mm: numa: do not automatically migrate KSM pages mm: numa: trace tasks that fail migration due to rate limiting mm: numa: limit scope of lock for NUMA migrate rate limiting mm: numa: make NUMA-migrate related functions static lib/show_mem.c: show num_poisoned_pages when oom mm/hwpoison: add '#' to hwpoison_inject mm/memblock: use WARN_ONCE when MAX_NUMNODES passed as input parameter ...
2014-01-21Merge branch 'for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu changes from Tejun Heo: "Two trivial changes - addition of WARN_ONCE() in lib/percpu-refcount.c and use of VMALLOC_TOTAL instead of END - START in percpu.c" * 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: use VMALLOC_TOTAL instead of VMALLOC_END - VMALLOC_START percpu-refcount: Add a WARN() for ref going negative
2014-01-21lib/show_mem.c: show num_poisoned_pages when oomXishi Qiu
Show num_poisoned_pages when oom, it is a little helpful to find the reason. Also it will be emitted anytime show_mem() is called. Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Suggested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21lib/cpumask.c: use memblock apis for early memory allocationsSantosh Shilimkar
Switch to memblock interfaces for early memory allocator instead of bootmem allocator. No functional change in beahvior than what it is in current code from bootmem users points of view. Archs already converted to NO_BOOTMEM now directly use memblock interfaces instead of bootmem wrappers build on top of memblock. And the archs which still uses bootmem, these new apis just fallback to exiting bootmem APIs. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Walmsley <paul@pwsan.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21lib/swiotlb.c: use memblock apis for early memory allocationsSantosh Shilimkar
2014-01-21mm, show_mem: remove SHOW_MEM_FILTER_PAGE_COUNTMel Gorman
Commit 4b59e6c47309 ("mm, show_mem: suppress page counts in non-blockable contexts") introduced SHOW_MEM_FILTER_PAGE_COUNT to suppress PFN walks on large memory machines. Commit c78e93630d15 ("mm: do not walk all of system memory during show_mem") avoided a PFN walk in the generic show_mem helper which removes the requirement for SHOW_MEM_FILTER_PAGE_COUNT in that case. This patch removes PFN walkers from the arch-specific implementations that report on a per-node or per-zone granularity. ARM and unicore32 still do a PFN walk as they report memory usage on each bank which is a much finer granularity where the debugging information may still be of use. As the remaining arches doing PFN walks have relatively small amounts of memory, this patch simply removes SHOW_MEM_FILTER_PAGE_COUNT. [akpm@linux-foundation.org: fix parisc] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21dma-debug: introduce debug_dma_assert_idle()Dan Williams
Record actively mapped pages and provide an api for asserting a given page is dma inactive before execution proceeds. Placing debug_dma_assert_idle() in cow_user_page() flagged the violation of the dma-api in the NET_DMA implementation (see commit 77873803363c "net_dma: mark broken"). The implementation includes the capability to count, in a limited way, repeat mappings of the same page that occur without an intervening unmap. This 'overlap' counter is limited to the few bits of tag space in a radix tree. This mechanism is added to mitigate false negative cases where, for example, a page is dma mapped twice and debug_dma_assert_idle() is called after the page is un-mapped once. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21percpu-refcount: Add a WARN() for ref going negativeKent Overstreet
AIO had a missing get, which led to an ioctx leak - after percpu_ref_kill() the ref was 0 so percpu_ref_put() never saw it hit 0. This wasn't noticed at the time because it all happened completely silently, this adds a WARN() which would've caught the aio bug. tj: Used WARN_ONCE() instead of WARN(). Signed-off-by: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-01-20Merge tag 'usb-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB pull request for 3.14-rc1 Lots of little things all over the place, and the usual USB gadget updates, and XHCI fixes (some for an issue reported by a lot of people). USB PHY updates as well as chipidea updates and fixes. All of these have been in the linux-next tree with no reported issues" * tag 'usb-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (318 commits) usb: chipidea: udc: using MultO at TD as real mult value for ISO-TX usb: chipidea: need to mask INT_STATUS when write otgsc usb: chipidea: put hw_phymode_configure before ci_usb_phy_init usb: chipidea: Fix Internal error: : 808 [#1] ARM related to STS flag usb: chipidea: imx: set CI_HDRC_IMX28_WRITE_FIX for imx28 usb: chipidea: add freescale imx28 special write register method usb: ehci: add freescale imx28 special write register method usb: core: check for valid id_table when using the RefId feature usb: cdc-wdm: resp_count can be 0 even if WDM_READ is set usb: core: bail out if user gives an unknown RefId when using new_id usb: core: allow a reference device for new_id usb: core: add sanity checks when using bInterfaceClass with new_id USB: image: correct spelling mistake in comment USB: c67x00: correct spelling mistakes in comments usb: delete non-required instances of include <linux/init.h> usb:hub set hub->change_bits when over-current happens Revert "usb: chipidea: imx: set CI_HDRC_IMX28_WRITE_FIX for imx28" xhci: Set scatter-gather limit to avoid failed block writes. xhci: Avoid infinite loop when sg urb requires too many trbs usb: gadget: remove unused variable in gr_queue_int() ...
2014-01-20Merge tag 'driver-core-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core / sysfs patches from Greg KH: "Here's the big driver core and sysfs patch set for 3.14-rc1. There's a lot of work here moving sysfs logic out into a "kernfs" to allow other subsystems to also have a virtual filesystem with the same attributes of sysfs (handle device disconnect, dynamic creation / removal as needed / unneeded, etc) This is primarily being done for the cgroups filesystem, but the goal is to also move debugfs to it when it is ready, solving all of the known issues in that filesystem as well. The code isn't completed yet, but all should be stable now (there is a big section that was reverted due to problems found when testing) There's also some other smaller fixes, and a driver core addition that allows for a "collection" of objects, that the DRM people will be using soon (it's in this tree to make merges after -rc1 easier) All of this has been in linux-next with no reported issues" * tag 'driver-core-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (113 commits) kernfs: associate a new kernfs_node with its parent on creation kernfs: add struct dentry declaration in kernfs.h kernfs: fix get_active failure handling in kernfs_seq_*() Revert "kernfs: fix get_active failure handling in kernfs_seq_*()" Revert "kernfs: replace kernfs_node->u.completion with kernfs_root->deactivate_waitq" Revert "kernfs: remove KERNFS_ACTIVE_REF and add kernfs_lockdep()" Revert "kernfs: remove KERNFS_REMOVED" Revert "kernfs: restructure removal path to fix possible premature return" Revert "kernfs: invoke kernfs_unmap_bin_file() directly from __kernfs_remove()" Revert "kernfs: remove kernfs_addrm_cxt" Revert "kernfs: make kernfs_get_active() block if the node is deactivated but not removed" Revert "kernfs: implement kernfs_{de|re}activate[_self]()" Revert "kernfs, sysfs, driver-core: implement kernfs_remove_self() and its wrappers" Revert "pci: use device_remove_file_self() instead of device_schedule_callback()" Revert "scsi: use device_remove_file_self() instead of device_schedule_callback()" Revert "s390: use device_remove_file_self() instead of device_schedule_callback()" Revert "sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()" Revert "kernfs: remove unnecessary NULL check in __kernfs_remove()" kernfs: remove unnecessary NULL check in __kernfs_remove() drivers/base: provide an infrastructure for componentised subsystems ...
2014-01-20Merge branch 'core-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core debug changes from Ingo Molnar: "Currently there are two methods to set the panic_timeout: via 'panic=X' boot commandline option, or via /proc/sys/kernel/panic. This tree adds a third panic_timeout configuration method: configuration via Kconfig, via CONFIG_PANIC_TIMEOUT=X - useful to distros that generally want their kernel defaults to come with the .config. CONFIG_PANIC_TIMEOUT defaults to 0, which was the previous default value of panic_timeout. Doing that unearthed a few arch trickeries regarding arch-special panic_timeout values and related complications - hopefully all resolved to the satisfaction of everyone" * 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: powerpc: Clean up panic_timeout usage MIPS: Remove panic_timeout settings panic: Make panic_timeout configurable
2014-01-19net: fix "queues" uevent between network namespacesWeilong Chen
When I create a new namespace with 'ip netns add net0', or add/remove new links in a namespace with 'ip link add/delete type veth', rx/tx queues events can be got in all namespaces. That is because rx/tx queue ktypes do not have namespace support, and their kobj parents are setted to NULL. This patch is to fix it. Reported-by: Libo Chen <chenlibo@huawei.com> Signed-off-by: Libo Chen <chenlibo@huawei.com> Signed-off-by: Weilong Chen <chenweilong@huawei.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c net/ipv4/tcp_metrics.c Overlapping changes between the "don't create two tcp metrics objects with the same key" race fix in net and the addition of the destination address in the lookup key in net-next. Minor overlapping changes in bnx2x driver. Signed-off-by: David S. Miller <davem@davemloft.net>
