path: root/lib
2011-05-09XZ decompressor: Fix decoding of empty LZMA2 streamsLasse Collin
commit 646032e3b05b32d3f20cb108a030593d9d792eb5 upstream. The old code considered valid empty LZMA2 streams to be corrupt. Note that a typical empty .xz file has no LZMA2 data at all, and thus most .xz files having no uncompressed data are handled correctly even without this fix. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09flex_arrays: allow zero length flex arraysEric Paris
commit bf69d41d198138e3c601e9a6645f4f1369aff7e0 upstream. Just like kmalloc will allow one to allocate a 0 length segment of memory flex arrays should do the same thing. It should bomb if you try to use something, but it should at least allow the allocation. This is needed because when SELinux switched to using flex_arrays in 2.6.38 the inability to allocate a 0 length array resulted in SELinux policy load returning -ENOSPC when previously it worked. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09flex_array: flex_array_prealloc takes a number of elements, not an endEric Paris
commit 5d30b10bd68df007e7ae21e77d1e0ce184b53040 upstream. Change flex_array_prealloc to take the number of elements for which space should be allocated instead of the last (inclusive) element. Users and documentation are updated accordingly. flex_arrays got introduced before they had users. When folks started using it, they ended up needing a different API than was coded up originally. This swaps over to the API that folks apparently need. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-21kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
commit 33ee3b2e2eb9b4b6c64dcf9ed66e2ac3124e748c upstream. 1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) MAINTAINERS: Add Andy Gospodarek as co-maintainer. r8169: disable ASPM RxRPC: Fix v1 keys AF_RXRPC: Handle receiving ACKALL packets cnic: Fix lost interrupt on bnx2x cnic: Prevent status block race conditions with hardware net: dcbnl: check correct ops in dcbnl_ieee_set() e1000e: disable broken PHY wakeup for ICH10 LOMs, use MAC wakeup instead igb: fix sparse warning e1000: fix sparse warning netfilter: nf_log: avoid oops in (un)bind with invalid nfproto values dccp: fix oops on Reset after close ipvs: fix dst_lock locking on dest update davinci_emac: Add Carrier Link OK check in Davinci RX Handler bnx2x: update driver version to 1.62.00-6 bnx2x: properly calculate lro_mss bnx2x: perform statistics "action" before state transition. bnx2x: properly configure coefficients for MinBW algorithm (NPAR mode). bnx2x: Fix ethtool -t link test for MF (non-pmf) devices. bnx2x: Fix nvram test for single port devices. ...
2011-02-28net: fix nla_policy_len to actually _iterate_ over the policyLars Ellenberg
Currently nla_policy_len always returns n * NLA_HDRLEN: It loops, but does not advance it's iterator. NLA_UNSPEC == 0 does not contain a .len in any policy. Trivially fixed by adding p++. Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25swiotlb: fix wrong panicFUJITA Tomonori
swiotlb's map_page wrongly calls panic() when it can't find a buffer fit for device's dma mask. It should return an error instead. Devices with an odd dma mask (i.e. under 4G) like b44 network card hit this bug (the system crashes): http://marc.info/?l=linux-kernel&m=129648943830106&w=2 If swiotlb returns an error, b44 driver can use the own bouncing mechanism. Reported-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-18Expand CONFIG_DEBUG_LIST to several other list operationsLinus Torvalds
When list debugging is enabled, we aim to readably show list corruption errors, and the basic list_add/list_del operations end up having extra debugging code in them to do some basic validation of the list entries. However, "list_del_init()" and "list_move[_tail]()" ended up avoiding the debug code due to how they were written. This fixes that. So the _next_ time we have list_move() problems with stale list entries, we'll hopefully have an easier time finding them.. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-08m68knommu: Remove dependencies on nonexistent M68KNOMMUGeert Uytterhoeven
M68KNOMMU is set nowhere. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-01-28Export the augmented rbtree helper functionsAndreas Gruenbacher
The augmented rbtree helper functions are not exported to modules right now. (We have started using augmented rbtrees in the upcoming version of drbd.) Signed-off-by: Andreas Gruenbacher <agruen@linbit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) bnx2: Eliminate AER error messages on systems not supporting it cnic: Fix big endian bug xfrm6: Don't forget to propagate peer into ipsec route. tg3: Use new VLAN code bonding: update documentation - alternate configuration. TCP: fix a bug that triggers large number of TCP RST by mistake MAINTAINERS: remove Reinette Chatre as iwlwifi maintainer rt2x00: add device id for windy31 usb device mac80211: fix a crash in ieee80211_beacon_get_tim on change_interface ipv6: Revert 'administrative down' address handling changes. textsearch: doc - fix spelling in lib/textsearch.c. USB NET KL5KUSB101: Fix mem leak in error path of kaweth_download_firmware() pch_gbe: don't use flush_scheduled_work() bnx2: Always set ETH_FLAG_TXVLAN net: clear heap allocation for ethtool_get_regs() ipv6: Always clone offlink routes. dcbnl: make get_app handling symmetric for IEEE and CEE DCBx tcp: fix bug in listening_get_next() inetpeer: Use correct AVL tree base pointer in inet_getpeer(). GRO: fix merging a paged skb after non-paged skbs ...
2011-01-26radix_tree: radix_tree_gang_lookup_tag_slot() may never returnToshiyuki Okajima
Executed command: fsstress -d /mnt -n 600 -p 850 crash> bt PID: 7947 TASK: ffff880160546a70 CPU: 0 COMMAND: "fsstress" #0 [ffff8800dfc07d00] machine_kexec at ffffffff81030db9 #1 [ffff8800dfc07d70] crash_kexec at ffffffff810a7952 #2 [ffff8800dfc07e40] oops_end at ffffffff814aa7c8 #3 [ffff8800dfc07e70] die_nmi at ffffffff814aa969 #4 [ffff8800dfc07ea0] do_nmi_callback at ffffffff8102b07b #5 [ffff8800dfc07f10] do_nmi at ffffffff814aa514 #6 [ffff8800dfc07f50] nmi at ffffffff814a9d60 [exception RIP: __lookup_tag+100] RIP: ffffffff812274b4 RSP: ffff88016056b998 RFLAGS: 00000287 RAX: 0000000000000000 RBX: 0000000000000002 RCX: 0000000000000006 RDX: 000000000000001d RSI: ffff88016056bb18 RDI: ffff8800c85366e0 RBP: ffff88016056b9c8 R8: ffff88016056b9e8 R9: 0000000000000000 R10: 000000000000000e R11: ffff8800c8536908 R12: 0000000000000010 R13: 0000000000000040 R14: ffffffffffffffc0 R15: ffff8800c85366e0 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 <NMI exception stack> #7 [ffff88016056b998] __lookup_tag at ffffffff812274b4 #8 [ffff88016056b9d0] radix_tree_gang_lookup_tag_slot at ffffffff81227605 #9 [ffff88016056ba20] find_get_pages_tag at ffffffff810fc110 #10 [ffff88016056ba80] pagevec_lookup_tag at ffffffff81105e85 #11 [ffff88016056baa0] write_cache_pages at ffffffff81104c47 #12 [ffff88016056bbd0] generic_writepages at ffffffff81105014 #13 [ffff88016056bbe0] do_writepages at ffffffff81105055 #14 [ffff88016056bbf0] __filemap_fdatawrite_range at ffffffff810fb2cb #15 [ffff88016056bc40] filemap_write_and_wait_range at ffffffff810fb32a #16 [ffff88016056bc70] generic_file_direct_write at ffffffff810fb3dc #17 [ffff88016056bce0] __generic_file_aio_write at ffffffff810fcee5 #18 [ffff88016056bda0] generic_file_aio_write at ffffffff810fd085 #19 [ffff88016056bdf0] do_sync_write at ffffffff8114f9ea #20 [ffff88016056bf00] vfs_write at ffffffff8114fcf8 #21 [ffff88016056bf30] sys_write at ffffffff81150691 #22 [ffff88016056bf80] system_call_fastpath at ffffffff8100c0b2 I think this root cause is the following: radix_tree_range_tag_if_tagged() always tags the root tag with settag if the root tag is set with iftag even if there are no iftag tags in the specified range (Of course, there are some iftag tags outside the specified range). =============================================================================== [[[Detailed description]]] (1) Why cannot radix_tree_gang_lookup_tag_slot() return forever? __lookup_tag(): - Return with 0. - Return with the index which is not bigger than the old one as the input parameter. Therefore the following "while" repeats forever because the above conditions cause "ret" not to be updated and the cur_index cannot be changed into the bigger one. (So, radix_tree_gang_lookup_tag_slot() cannot return forever.) radix_tree_gang_lookup_tag_slot(): 1178 while (ret < max_items) { 1179 unsigned int slots_found; 1180 unsigned long next_index; /* Index of next search */ 1181 1182 if (cur_index > max_index) 1183 break; 1184 slots_found = __lookup_tag(node, results + ret, 1185 cur_index, max_items - ret, &next_index, tag); 1186 ret += slots_found; // cannot update ret because slots_found == 0. // so, this while loops forever. 1187 if (next_index == 0) 1188 break; 1189 cur_index = next_index; 1190 } (2) Why does __lookup_tag() return with 0 and doesn't update the index? Assuming the following: - the one of the slot in radix_tree_node is NULL. - the one of the tag which corresponds to the slot sets with PAGECACHE_TAG_TOWRITE or other. - In a certain height(!=0), the corresponding index is 0. a) __lookup_tag() notices that the tag is set. 1005 static unsigned int 1006 __lookup_tag(struct radix_tree_node *slot, void ***results, unsigned long index, 1007 unsigned int max_items, unsigned long *next_index, unsigned int tag) 1008 { 1009 unsigned int nr_found = 0; 1010 unsigned int shift, height; 1011 1012 height = slot->height; 1013 if (height == 0) 1014 goto out; 1015 shift = (height-1) * RADIX_TREE_MAP_SHIFT; 1016 1017 while (height > 0) { 1018 unsigned long i = (index >> shift) & RADIX_TREE_MAP_MASK ; 1019 1020 for (;;) { 1021 if (tag_get(slot, tag, i)) 1022 break; ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ * the index is not updated yet. b) __lookup_tag() notices that the slot is NULL. 1023 index &= ~((1UL << shift) - 1); 1024 index += 1UL << shift; 1025 if (index == 0) 1026 goto out; /* 32-bit wraparound */ 1027 i++; 1028 if (i == RADIX_TREE_MAP_SIZE) 1029 goto out; 1030 } 1031 height--; 1032 if (height == 0) { /* Bottom level: grab some items */ ... 1055 } 1056 shift -= RADIX_TREE_MAP_SHIFT; 1057 slot = rcu_dereference_raw(slot->slots[i]); 1058 if (slot == NULL) 1059 break; ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ c) __lookup_tag() doesn't update the index and return with 0. 1060 } 1061 out: 1062 *next_index = index; ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 1063 return nr_found; 1064 } (3) Why is the slot NULL even if the tag is set? Because radix_tree_range_tag_if_tagged() always sets the root tag with PAGECACHE_TAG_TOWRITE if the root tag is set with PAGECACHE_TAG_DIRTY, even if there is no tag which can be set with PAGECACHE_TAG_TOWRITE in the specified range (from *first_indexp to last_index). Of course, some PAGECACHE_TAG_DIRTY nodes must exist outside the specified range. (radix_tree_range_tag_if_tagged() is called only from tag_pages_for_writeback()) 640 unsigned long radix_tree_range_tag_if_tagged(struct radix_tree_root *root, 641 unsigned long *first_indexp, unsigned long last_index, 642 unsigned long nr_to_tag, 643 unsigned int iftag, unsigned int settag) 644 { 645 unsigned int height = root->height; 646 struct radix_tree_path path[height]; 647 struct radix_tree_path *pathp = path; 648 struct radix_tree_node *slot; 649 unsigned int shift; 650 unsigned long tagged = 0; 651 unsigned long index = *first_indexp; 652 653 last_index = min(last_index, radix_tree_maxindex(height)); 654 if (index > last_index) 655 return 0; 656 if (!nr_to_tag) 657 return 0; 658 if (!root_tag_get(root, iftag)) { 659 *first_indexp = last_index + 1; 660 return 0; 661 } 662 if (height == 0) { 663 *first_indexp = last_index + 1; 664 root_tag_set(root, settag); 665 return 1; 666 } ... 733 root_tag_set(root, settag); ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 734 *first_indexp = index; 735 736 return tagged; 737 } As the result, there is no radix_tree_node which is set with PAGECACHE_TAG_TOWRITE but the root tag(radix_tree_root) is set with PAGECACHE_TAG_TOWRITE. [figure: inside radix_tree] (Please see the figure with typewriter font) =========================================== [roottag = DIRTY] | tag=0:NOTHING tag[0 0 0 1] 1:DIRTY [x x x +] 2:WRITEBACK | 3:DIRTY,WRITEBACK p 4:TOWRITE <---> 5:DIRTY,TOWRITE ... specified range (index: 0 to 2) * There is no DIRTY tag within the specified range. (But there is a DIRTY tag outside that range.) | | | | | | | | | after calling tag_pages_for_writeback() | | | | | | | | | v v v v v v v v v [roottag = DIRTY,TOWRITE] | p is "page". tag[0 0 0 1] x is NULL. [x x x +] +- is a pointer to "page". | p * But TOWRITE tag is set on the root tag. ============================================ After that, radix_tree_extend() via radix_tree_insert() is called when the page is added. This function sets the new radix_tree_node with PAGECACHE_TAG_TOWRITE to succeed the status of the root tag. 246 static int radix_tree_extend(struct radix_tree_root *root, unsigned long index) 247 { 248 struct radix_tree_node *node; 249 unsigned int height; 250 int tag; 251 252 /* Figure out what the height should be. */ 253 height = root->height + 1; 254 while (index > radix_tree_maxindex(height)) 255 height++; 256 257 if (root->rnode == NULL) { 258 root->height = height; 259 goto out; 260 } 261 262 do { 263 unsigned int newheight; 264 if (!(node = radix_tree_node_alloc(root))) 265 return -ENOMEM; 266 267 /* Increase the height. */ 268 node->slots[0] = radix_tree_indirect_to_ptr(root->rnode); 269 270 /* Propagate the aggregated tag info into the new root */ 271 for (tag = 0; tag < RADIX_TREE_MAX_TAGS; tag++) { 272 if (root_tag_get(root, tag)) 273 tag_set(node, tag, 0); ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 274 } =========================================== [roottag = DIRTY,TOWRITE] | : tag[0 0 0 1] [0 0 0 0] [x x x +] [+ x x x] | | p p (new page) | | | | | | | | | after calling radix_tree_insert | | | | | | | | | v v v v v v v v v [roottag = DIRTY,TOWRITE] | tag [5 0 0 0] * DIRTY and TOWRITE tags are [+ + x x] succeeded to the new node. | | tag [0 0 0 1] [0 0 0 0] [x x x +] [+ x x x] | | p p ============================================ After that, the index 3 page is released by remove_from_page_cache(). Then we can make the situation that the tag is set with PAGECACHE_TAG_TOWRITE and that the slot which corresponds to the tag is NULL. =========================================== [roottag = DIRTY,TOWRITE] | tag [5 0 0 0] [+ + x x] | | tag [0 0 0 1] [0 0 0 0] [x x x +] [+ x x x] | | p p (remove) | | | | | | | | | after calling remove_page_cache | | | | | | | | | v v v v v v v v v [roottag = DIRTY,TOWRITE] | tag [4 0 0 0] * Only DIRTY tag is cleared [x + x x] because no TOWRITE tag is existed | in the bottom node. [0 0 0 0] [+ x x x] | p ============================================ To solve this problem Change to that radix_tree_tag_if_tagged() doesn't tag the root tag if it doesn't set any tags within the specified range. Like this. ============================================ 640 unsigned long radix_tree_range_tag_if_tagged(struct radix_tree_root *root, 641 unsigned long *first_indexp, unsigned long last_index, 642 unsigned long nr_to_tag, 643 unsigned int iftag, unsigned int settag) 644 { 650 unsigned long tagged = 0; ... 733 if (tagged) ^^^^^^^^^^^^^^^^^^^^^^^^ 734 root_tag_set(root, settag); 735 *first_indexp = index; 736 737 return tagged; 738 } ============================================ Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-24textsearch: doc - fix spelling in lib/textsearch.c.Jesper Dangaard Brouer
Found the following spelling errors while reading the textsearch code: "facitilies" -> "facilities" "continously" -> "continuously" "arbitary" -> "arbitrary" "patern" -> "pattern" "occurences" -> "occurrences" I'll try to push this patch through DaveM, given the only users of textsearch is in the net/ tree (nf_conntrack_amanda.c, xt_string.c and em_text.c) Signed-off-by: Jesper Sander <sander.contrib@gmail.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13decompressors: check input size in decompress_inflate.cLasse Collin
Check for end of the input buffer when skipping over the filename field in the .gz file header. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13decompressors: add boot-time XZ supportLasse Collin
This implements the API defined in <linux/decompress/generic.h> which is used for kernel, initramfs, and initrd decompression. This patch together with the first patch is enough for XZ-compressed initramfs and initrd; XZ-compressed kernel will need arch-specific changes. The buffering requirements described in decompress_unxz.c are stricter than with gzip, so the relevant changes should be done to the arch-specific code when adding support for XZ-compressed kernel. Similarly, the heap size in arch-specific pre-boot code may need to be increased (30 KiB is enough). The XZ decompressor needs memmove(), memeq() (memcmp() == 0), and memzero() (memset(ptr, 0, size)), which aren't available in all arch-specific pre-boot environments. I'm including simple versions in decompress_unxz.c, but a cleaner solution would naturally be nicer. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13decompressors: add XZ decompressor moduleLasse Collin
In userspace, the .lzma format has become mostly a legacy file format that got superseded by the .xz format. Similarly, LZMA Utils was superseded by XZ Utils. These patches add support for XZ decompression into the kernel. Most of the code is as is from XZ Embedded <http://tukaani.org/xz/embedded.html>. It was written for the Linux kernel but is usable in other projects too. Advantages of XZ over the current LZMA code in the kernel: - Nice API that can be used by other kernel modules; it's not limited to kernel, initramfs, and initrd decompression. - Integrity check support (CRC32) - BCJ filters improve compression of executable code on certain architectures. These together with LZMA2 can produce a few percent smaller kernel or Squashfs images than plain LZMA without making the decompression slower. This patch: Add the main decompression code (xz_dec), testing module (xz_dec_test), wrapper script (xz_wrap.sh) for the xz command line tool, and documentation. The xz_dec module is enough to have a usable XZ decompressor e.g. for Squashfs. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: fix callback-to-callback mode in decompress_unlzo.cLasse Collin
Callback-to-callback decompression mode is used for initrd (not initramfs). The LZO wrapper is broken for this use case for two reasons: - The argument validation is needlessly too strict by requiring that "posp" is non-NULL when "fill" is non-NULL. - The buffer handling code didn't work at all for this use case. I tested with LZO-compressed kernel, initramfs, initrd, and corrupt (truncated) initramfs and initrd images. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check input size in decompress_unlzo.cLasse Collin
The code assumes that the input is valid and not truncated. Add checks to avoid reading past the end of the input buffer. Change the type of "skip" from u8 to int to fix a possible integer overflow. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for write errors in decompress_unlzo.cLasse Collin
The return value of flush() is not checked in unlzo(). This means that the decompressor won't stop even if the caller doesn't want more data. This can happen e.g. with a corrupt LZO-compressed initramfs image. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: validate match distance in decompress_unlzma.cLasse Collin
Validate the newly decoded distance (rep0) in process_bit1(). This is to detect corrupt LZMA data quickly. The old code can run for long time producing garbage until it hits the end of the input. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for write errors in decompress_unlzma.cLasse Collin
The return value of wr->flush() is not checked in write_byte(). This means that the decompressor won't stop even if the caller doesn't want more data. This can happen e.g. with corrupt LZMA-compressed initramfs. Returning the error quickly allows the user to see the error message quicker. There is a similar missing check for wr.flush() near the end of unlzma(). Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for read errors in decompress_unlzma.cLasse Collin
Return value of rc->fill() is checked in rc_read() and error() is called when needed, but then the code continues as if nothing had happened. rc_read() is a void function and it's on the top of performance critical call stacks, so propagating the error code via return values doesn't sound like the best fix. It seems better to check rc->buffer_size (which holds the return value of rc->fill()) in the main loop. It does nothing bad that the code runs a little with unknown data after a failed rc->fill(). This fixes an infinite loop in initramfs decompression if the LZMA-compressed initramfs image is corrupt. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: fix header validation in decompress_unlzma.cLasse Collin
Validation of header.pos calls error() but doesn't make the function return to indicate an error to the caller. Instead the decoding is attempted with invalid header.pos. This fixes it. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: remove unused function from lib/decompress_unlzma.cLasse Collin
2011-01-13Decompressors: include <linux/slab.h> in <linux/decompress/mm.h>Lasse Collin
Currently users of mm.h need to include <linux/slab.h> to use the macros malloc() and free() provided by mm.h. This fixes it. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: get rid of set_error_fn() macroLasse Collin
set_error_fn() has become a useless complication after c1e7c3ae59 ("bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure") fixed the use of error() in malloc(). Only decompress_unlzma.c had some use for it and that was easy to change too. This also gets rid of the static function pointer "error", which should have been marked as __initdata. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: add missing INIT (i.e. __init)Lasse Collin
2011-01-13flex_array: export symbols to modulesDavid Rientjes
Alex said: I want to use flex_array to store a sparse array of ATM cell re-assembly buffers for my ATM over Ethernet driver. Using the per-vcc user_back structure causes problems when stacked with things like br2684. Add EXPORT_SYMBOL() for all publically accessible flex array functions and move to obj-y so that modules may use this library. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Reported-by: Alex Bennee <kernel-hacker@bennee.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13lib/vsprintf.c: fix vscnprintf() if @size is == 0Anton Arapov
vscnprintf() should return 0 if @size is == 0. Update the comment for it, as @size is unsigned. This change based on the code of commit b903c0b8899b46829a9b80ba55b61079b35940ec ("lib: fix scnprintf() if @size is == 0") moves the real fix into vscnprinf() from scnprintf() and makes scnprintf() call vscnprintf(), thus avoid code duplication. Signed-off-by: Anton Arapov <aarapov@redhat.com> Acked-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13include/linux/printk.h lib/hexdump.c: neatening and add CONFIG_PRINTK guardJoe Perches
- Move prototypes and align arguments. - Add CONFIG_PRINTK guard for print_hex functions Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kptr_restrict for hiding kernel pointers from unprivileged usersDan Rosenberg
Add the %pK printk format specifier and the /proc/sys/kernel/kptr_restrict sysctl. The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". [akpm@linux-foundation.org: check for IRQ context when !kptr_restrict, save an indent level, s/WARN/WARN_ONCE/] [akpm@linux-foundation.org: coding-style fixup] [randy.dunlap@oracle.com: fix kernel/sysctl.c warning] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12ACPI, APEI, Generic Hardware Error Source POLL/IRQ/NMI notification type supportHuang Ying
Generic Hardware Error Source provides a way to report platform hardware errors (such as that from chipset). It works in so called "Firmware First" mode, that is, hardware errors are reported to firmware firstly, then reported to Linux by firmware. This way, some non-standard hardware error registers or non-standard hardware link can be checked by firmware to produce more valuable hardware error information for Linux. This patch adds POLL/IRQ/NMI notification types support. Because the memory area used to transfer hardware error information from BIOS to Linux can be determined only in NMI, IRQ or timer handler, but general ioremap can not be used in atomic context, so a special version of atomic ioremap is implemented for that. Known issue: - Error information can not be printed for recoverable errors notified via NMI, because printk is not NMI-safe. Will fix this via delay printing to IRQ context via irq_work or make printk NMI-safe. v2: - adjust printk format per comments. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-11Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) perf session: Fix infinite loop in __perf_session__process_events perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1) perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail perf tools: Emit clearer message for sys_perf_event_open ENOENT return perf stat: better error message for unsupported events perf sched: Fix allocation result check perf, x86: P4 PMU - Fix unflagged overflows handling dynamic debug: Fix build issue with older gcc tracing: Fix TRACE_EVENT power tracepoint creation tracing: Fix preempt count leak tracepoint: Add __rcu annotation tracing: remove duplicate null-pointer check in skb tracepoint tracing/trivial: Add missing comma in TRACE_EVENT comment tracing: Include module.h in define_trace.h x86: Save rbp in pt_regs on irq entry x86, dumpstack: Fix unused variable warning x86, NMI: Clean-up default_do_nmi() x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU x86, NMI: Remove DIE_NMI_IPI x86, NMI: Add priorities to handlers ...
2011-01-10Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (390 commits) drm/radeon/kms: disable underscan by default drm/radeon/kms: only enable hdmi features if the monitor supports audio drm: Restore the old_fb upon modeset failure drm/nouveau: fix hwmon device binding radeon: consolidate asic-specific function decls for pre-r600 vga_switcheroo: comparing too few characters in strncmp() drm/radeon/kms: add NI pci ids drm/radeon/kms: don't enable pcie gen2 on NI yet drm/radeon/kms: add radeon_asic struct for NI asics drm/radeon/kms/ni: load default sclk/mclk/vddc at pm init drm/radeon/kms: add ucode loader for NI drm/radeon/kms: add support for DCE5 display LUTs drm/radeon/kms: add ni_reg.h drm/radeon/kms: add bo blit support for NI drm/radeon/kms: always use writeback/events for fences on NI drm/radeon/kms: adjust default clock/vddc tracking for pm on DCE5 drm/radeon/kms: add backend map workaround for barts drm/radeon/kms: fill gpu init for NI asics drm/radeon/kms: add disabled vbios accessor for NI asics drm/radeon/kms: handle NI thermal controller ...
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07dynamic debug: Fix build issue with older gccJason Baron
On older gcc (3.3) dynamic debug fails to compile: include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer': include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label declaration `out' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label `do_printk' include/net/inet_connection_sock.h:236: error: duplicate label `out' Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now. Cc: <stable@kernel.org> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-06Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: MAINTAINERS: Update timer related entries timers: Use this_cpu_read timerqueue: Make timerqueue_getnext() static inline hrtimer: fix timerqueue conversion flub hrtimers: Convert hrtimers to use timerlist infrastructure timers: Fixup allmodconfig build issue timers: Rename timerlist infrastructure to timerqueue timers: Introduce timerlist infrastructure. hrtimer: Remove stale comment on curr_timer timer: Warn when del_timer_sync() is called in hardirq context timer: Del_timer_sync() can be used in softirq context timer: Make try_to_del_timer_sync() the same on SMP and UP posix-timers: Annotate lock_timer() timer: Permit statically-declared work with deferrable timers time: Use ARRAY_SIZE macro in timecompare.c timer: Initialize the field slack of timer_list timer_list: Remove alignment padding on 64 bit when CONFIG_TIMER_STATS time: Compensate for rounding on odd-frequency clocksources Fix up trivial conflict in MAINTAINERS
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-22x86, nmi_watchdog: Remove ARCH_HAS_NMI_WATCHDOG and rely on ↵Don Zickus
CONFIG_HARDLOCKUP_DETECTOR The x86 arch has shifted its use of the nmi_watchdog from a local implementation to the global one provide by kernel/watchdog.c. This shift has caused a whole bunch of compile problems under different config options. I attempt to simplify things with the patch below. In order to simplify things, I had to come to terms with the meaning of two terms ARCH_HAS_NMI_WATCHDOG and CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing, the former on a local level and the latter on a global level. With the old x86 nmi watchdog gone, there is no need to rely on defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't make sense any more. x86 will now use the global implementation. The changes below do a few things. First it changes the few places that relied on ARCH_HAS_NMI_WATCHDOG to use CONFIG_X86_LOCAL_APIC (the former was an alias for the latter anyway, so nothing unusual here). Those pieces of code were relying more on local apic functionality the nmi watchdog functionality, so the change should make sense. Second, I removed the x86 implementation of touch_nmi_watchdog(). It isn't need now, instead x86 will rely on kernel/watchdog.c's implementation. Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from x86. And tweaked the include/linux/nmi.h file to tell users to look for an externally defined touch_nmi_watchdog in the case of ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This changes removes some of the ugliness in that file. Finally, I added a Kconfig dependency for CONFIG_HARDLOCKUP_DETECTOR that said you can't have ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can only have one nmi_watchdog. Tested with ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig, (various broken configs) Hopefully, after this patch I won't get any more compile broken emails. :-) v3: changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-17percpucounter: Optimize __percpu_counter_add a bit through the use of ↵Christoph Lameter
this_cpu() options. The this_cpu_* options can be used to optimize __percpu_counter_add a bit. Avoids some address arithmetic and saves 12 bytes. Before: 00000000000001d3 <__percpu_counter_add>: 1d3: 55 push %rbp 1d4: 48 89 e5 mov %rsp,%rbp 1d7: 41 55 push %r13 1d9: 41 54 push %r12 1db: 53 push %rbx 1dc: 48 89 fb mov %rdi,%rbx 1df: 48 83 ec 08 sub $0x8,%rsp 1e3: 4c 8b 67 30 mov 0x30(%rdi),%r12 1e7: 65 4c 03 24 25 00 00 add %gs:0x0,%r12 1ee: 00 00 1f0: 4d 63 2c 24 movslq (%r12),%r13 1f4: 48 63 c2 movslq %edx,%rax 1f7: 49 01 f5 add %rsi,%r13 1fa: 49 39 c5 cmp %rax,%r13 1fd: 7d 0a jge 209 <__percpu_counter_add+0x36> 1ff: f7 da neg %edx 201: 48 63 d2 movslq %edx,%rdx 204: 49 39 d5 cmp %rdx,%r13 207: 7f 1e jg 227 <__percpu_counter_add+0x54> 209: 48 89 df mov %rbx,%rdi 20c: e8 00 00 00 00 callq 211 <__percpu_counter_add+0x3e> 211: 4c 01 6b 18 add %r13,0x18(%rbx) 215: 48 89 df mov %rbx,%rdi 218: 41 c7 04 24 00 00 00 movl $0x0,(%r12) 21f: 00 220: e8 00 00 00 00 callq 225 <__percpu_counter_add+0x52> 225: eb 04 jmp 22b <__percpu_counter_add+0x58> 227: 45 89 2c 24 mov %r13d,(%r12) 22b: 5b pop %rbx 22c: 5b pop %rbx 22d: 41 5c pop %r12 22f: 41 5d pop %r13 231: c9 leaveq 232: c3 retq After: 00000000000001d3 <__percpu_counter_add>: 1d3: 55 push %rbp 1d4: 48 63 ca movslq %edx,%rcx 1d7: 48 89 e5 mov %rsp,%rbp 1da: 41 54 push %r12 1dc: 53 push %rbx 1dd: 48 89 fb mov %rdi,%rbx 1e0: 48 8b 47 30 mov 0x30(%rdi),%rax 1e4: 65 44 8b 20 mov %gs:(%rax),%r12d 1e8: 4d 63 e4 movslq %r12d,%r12 1eb: 49 01 f4 add %rsi,%r12 1ee: 49 39 cc cmp %rcx,%r12 1f1: 7d 0a jge 1fd <__percpu_counter_add+0x2a> 1f3: f7 da neg %edx 1f5: 48 63 d2 movslq %edx,%rdx 1f8: 49 39 d4 cmp %rdx,%r12 1fb: 7f 21 jg 21e <__percpu_counter_add+0x4b> 1fd: 48 89 df mov %rbx,%rdi 200: e8 00 00 00 00 callq 205 <__percpu_counter_add+0x32> 205: 4c 01 63 18 add %r12,0x18(%rbx) 209: 48 8b 43 30 mov 0x30(%rbx),%rax 20d: 48 89 df mov %rbx,%rdi 210: 65 c7 00 00 00 00 00 movl $0x0,%gs:(%rax) 217: e8 00 00 00 00 callq 21c <__percpu_counter_add+0x49> 21c: eb 04 jmp 222 <__percpu_counter_add+0x4f> 21e: 65 44 89 20 mov %r12d,%gs:(%rax) 222: 5b pop %rbx 223: 41 5c pop %r12 225: c9 leaveq 226: c3 retq Reviewed-by: Pekka Enberg <penberg@kernel.org> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-16Merge remote branch 'airlied/drm-core-next' into drm-intel-nextChris Wilson
2010-12-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-12-11timerqueue: Make timerqueue_getnext() static inlineThomas Gleixner
No point in calling a function just to dereference a pointer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Fixup allmodconfig build issueJohn Stultz
Adds missed EXPORT_SYMBOL lines that cause the following build failures with allmodconfig: ERROR: "timerqueue_add" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_getnext" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_del" [drivers/rtc/rtc-core.ko] undefined! Reported-by: Ingo Molnar <mingo@elte.hu> Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
