commit b5c8afe5be51078a979d86ae5ae78c4ac948063d upstream.
"origPtr" is used as an offset into the bd->dbuf[] array. That array is
allocated in start_bunzip() and has "bd->dbufSize" number of elements so
the test here should be >= instead of >.
Later we check "origPtr" again before using it as an offset so I don't
know if this bug can be triggered in real life.
Fixes: bc22c17e12c1 ('bzip2/lzma: library support for gzip, bzip2 and lzma decompression')
Cc: Alain Knaff <alain@knaff.lu>
Cc: Yinghai Lu <yinghai@kernel.org>
commit ea5d05b34aca25c066e0699512d0ffbd8ee6ac3e upstream.
If __bitmap_shift_left() or __bitmap_shift_right() are asked to shift by
a multiple of BITS_PER_LONG, they will try to shift a long value by
BITS_PER_LONG bits which is undefined. Change the functions to avoid
the undefined shift.
Coverity id: 1192175
Coverity id: 1192174
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[bwh: Backported to 3.2:
- extract_buf() needs to use this for the 'extract' array as well
- Adjust context]
commit 72cf90124e87d975d0b2114d930808c58b4c05e4 upstream.
This fix ensures that we never meet an integer overflow while adding
255 while parsing a variable length encoding. It works differently from
commit 206a81c ("lzo: properly check for overruns") because instead of
ensuring that we don't overrun the input, which is tricky to guarantee
due to many assumptions in the code, it simply checks that the cumulated
number of 255 read cannot overflow by bounding this number.
The MAX_255_COUNT is the maximum number of times we can add 255 to a base
count without overflowing an integer. The multiply will overflow when
multiplying 255 by more than MAXINT/255. The sum will overflow earlier
depending on the base count. Since the base count is taken from a u8
and a few bits, it is safe to assume that it will always be lower than
or equal to 2*255, thus we can always prevent any overflow by accepting
two less 255 steps.
This patch also reduces the CPU overhead and actually increases performance
by 1.1% compared to the initial code, while the previous fix costs 3.1%
(measured on x86_64).
The fix needs to be backported to all currently supported stable kernels.
Reported-by: Willem Pinckaers <willem@lekkertech.net>
Cc: "Don A. Bailey" <donb@securitymouse.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit af958a38a60c7ca3d8a39c918c1baa2ff7b6b233 upstream.
This reverts commit 206a81c ("lzo: properly check for overruns").
As analysed by Willem Pinckaers, this fix is still incomplete on
certain rare corner cases, and it is easier to restart from the
original code.
[ Upstream commit bfc5184b69cf9eeb286137640351c650c27f118a ]
Any process is able to send netlink messages with leftover bytes.
Make the warning rate-limited to prevent too much log spam.
The warning is supposed to help find userspace bugs, so print the
triggering command name to implicate the buggy program.
[v2: Use pr_warn_ratelimited instead of printk_ratelimited.]
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
[bwh: Add #include of <linux/sched.h> for definition of struct task_struct,
as in 3.2 it doesn't get included indirectly on all architectures. Thanks
to Guenter Roeck for debugging this.]
commit 206a81c18401c0cde6e579164f752c4b147324ce upstream.
The lzo decompressor can, if given some really crazy data, possibly
overrun some variable types. Modify the checking logic to properly
detect overruns before they happen.
Reported-by: "Don A. Bailey" <donb@securitymouse.com>
Tested-by: "Don A. Bailey" <donb@securitymouse.com>
commit 8b975bd3f9089f8ee5d7bbfd798537b992bbc7e7 upstream.
This commit updates the kernel LZO code to the current upsteam version
which features a significant speed improvement - benchmarking the Calgary
and Silesia test corpora typically shows a doubled performance in
both compression and decompression on modern i386/x86_64/powerpc machines.
Signed-off-by: Markus F.X.J. Oberhumer <markus@oberhumer.com>
commit b6bec26cea948148a9420e7a0ac337f925de49e7 upstream.
Rename the source file to match the function name and thereby
also make room for a possible future even slightly faster
"non-safe" decompressor version.
commit 3afb69cb5572b3c8c898c00880803cf1a49852c4 upstream.
idr_replace() open-codes the logic to calculate the maximum valid ID
given the height of the idr tree; unfortunately, the open-coded logic
doesn't account for the fact that the top layer may have unused slots
and over-shifts the limit to zero when the tree is at its maximum
height.
The following test code shows it fails to replace the value for
id=((1<<27)+42):
static void test5(void)
int id;
DEFINE_IDR(test_idr);
#define TEST5_START ((1<<27)+42) /* use the highest layer */
printk(KERN_INFO "Start test5\n");
id = idr_alloc(&test_idr, (void *)1, TEST5_START, 0, GFP_KERNEL);
BUG_ON(id != TEST5_START);
TEST_BUG_ON(idr_replace(&test_idr, (void *)2, TEST5_START) != (void *)1);
idr_destroy(&test_idr);
printk(KERN_INFO "End of test5\n");
Fix the bug by using idr_max() which correctly takes into account the
maximum allowed shift.
sub_alloc() shares the same problem and may incorrectly fail with
-EAGAIN; however, this bug doesn't affect correct operation because
idr_get_empty_slot(), which already uses idr_max(), retries with the
increased @id in such cases.
[tj@kernel.org: Updated patch description.]
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
[bwh: Backported to 3.2: adjust context]
commit e39435ce68bb4685288f78b1a7e24311f7ef939f upstream.
I got a bug report yesterday from Laszlo Ersek in which he states that
his kvm instance fails to suspend. Laszlo bisected it down to this
commit 1cf7e9c68fe8 ("virtio_blk: blk-mq support") where virtio-blk is
converted to use the blk-mq infrastructure.
After digging a bit, it became clear that the issue was with the queue
drain. blk-mq tracks queue usage in a percpu counter, which is
incremented on request alloc and decremented when the request is freed.
The initial hunt was for an inconsistency in blk-mq, but everything
seemed fine. In fact, the counter only returned crazy values when
suspend was in progress.
When a CPU is unplugged, the percpu counters merges that CPU state with
the general state. blk-mq takes care to register a hotcpu notifier with
the appropriate priority, so we know it runs after the percpu counter
notifier. However, the percpu counter notifier only merges the state
when the CPU is fully gone. This leaves a state transition where the
CPU going away is no longer in the online mask, yet it still holds
private values. This means that in this state, percpu_counter_sum()
returns invalid results, and the suspend then hangs waiting for
abs(dead-cpu-value) requests to complete which of course will never
happen.
Fix this by clearing the state earlier, so we never have a case where
the CPU isn't in online mask but still holds private state. This bug
has been there since forever, I guess we don't have a lot of users where
percpu counters needs to be reliable during the suspend cycle.
Signed-off-by: Jens Axboe <axboe@fb.com>
Reported-by: Laszlo Ersek <lersek@redhat.com>
Tested-by: Laszlo Ersek <lersek@redhat.com>
[ Upstream commit 8b7b932434f5eee495b91a2804f5b64ebb2bc835 ]
nla_strcmp compares the string length plus one, so it's implicitly
including the nul-termination in the comparison.
int nla_strcmp(const struct nlattr *nla, const char *str)
int len = strlen(str) + 1;
d = memcmp(nla_data(nla), str, len);
However, if NLA_STRING is used, userspace can send us a string without
the nul-termination. This is a problem since the string
comparison will not match as the last byte may be not the
nul-termination.
Fix this by skipping the comparison of the nul-termination if the
attribute data is nul-terminated. Suggested by Thomas Graf.
Cc: Florian Westphal <fw@strlen.de>
Cc: Thomas Graf <tgraf@suug.ch>
commit 6583327c4dd55acbbf2a6f25e775b28b3abf9a42 upstream.
Commit d61931d89b, "x86: Add optimized popcnt variants" introduced
compile flag -fcall-saved-rdi for lib/hweight.c. When combined with
options -fprofile-arcs and -O2, this flag causes gcc to generate
broken constructor code. As a result, a 64 bit x86 kernel compiled
with CONFIG_GCOV_PROFILE_ALL=y prints message "gcov: could not create
file" and runs into sproadic BUGs during boot.
The gcc people indicate that these kinds of problems are endemic when
using ad hoc calling conventions. It is therefore best to treat any
file compiled with ad hoc calling conventions as an isolated
environment and avoid things like profiling or coverage analysis,
since those subsystems assume a "normal" calling conventions.
This patch avoids the bug by excluding lib/hweight.o from coverage
profiling.
Reported-by: Meelis Roos <mroos@linux.ee>
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/52F3A30C.7050205@linux.vnet.ibm.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ]
For properly initialising the Tausworthe generator [1], we have
a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15.
Commit 697f8d0348 ("random32: seeding improvement") introduced
a __seed() function that imposes boundary checks proposed by the
errata paper [2] to properly ensure above conditions.
However, we're off by one, as the function is implemented as:
"return (x < m) ? x + m : x;", and called with __seed(X, 1),
__seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15
would be possible, whereas the lower boundary should actually
be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise
an initialization with an unwanted seed could have the effect
that Tausworthe's PRNG properties cannot not be ensured.
Note that this PRNG is *not* used for cryptography in the kernel.
[1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps
[2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps
Joint work with Hannes Frederic Sowa.
Fixes: 697f8d0348a6 ("random32: seeding improvement")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
commit 312b4e226951f707e120b95b118cbc14f3d162b2 upstream.
Some setuid binaries will allow reading of files which have read
permission by the real user id. This is problematic with files which
use %pK because the file access permission is checked at open() time,
but the kptr_restrict setting is checked at read() time. If a setuid
binary opens a %pK file as an unprivileged user, and then elevates
permissions before reading the file, then kernel pointer values may be
leaked.
This happens for example with the setuid pppd application on Ubuntu 12.04:
$ head -1 /proc/kallsyms
00000000 T startup_32
$ pppd file /proc/kallsyms
pppd: In file /proc/kallsyms: unrecognized option 'c1000000'
This will only leak the pointer value from the first line, but other
setuid binaries may leak more information.
Fix this by adding a check that in addition to the current process having
CAP_SYSLOG, that effective user and group ids are equal to the real ids.
If a setuid binary reads the contents of a file which uses %pK then the
pointer values will be printed as NULL if the real user is unprivileged.
Update the sysctl documentation to reflect the changes, and also correct
the documentation to state the kptr_restrict=0 is the default.
This is a only temporary solution to the issue. The correct solution is
to do the permission check at open() time on files, and to replace %pK
with a function which checks the open() time permission. %pK uses in
printk should be removed since no sane permission check can be done, and
instead protected by using dmesg_restrict.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
- Adjust context
- Compare ids directly instead of using {uid,gid}_eq()]
commit 3d77b50c5874b7e923be946ba793644f82336b75 upstream.
Commit b1adaf65ba03 ("[SCSI] block: add sg buffer copy helper
functions") introduces two sg buffer copy helpers, and calls
flush_kernel_dcache_page() on pages in SG list after these pages are
written to.
Unfortunately, the commit may introduce a potential bug:
- Before sending some SCSI commands, kmalloc() buffer may be passed to
block layper, so flush_kernel_dcache_page() can see a slab page
finally
- According to cachetlb.txt, flush_kernel_dcache_page() is only called
on "a user page", which surely can't be a slab page.
- ARCH's implementation of flush_kernel_dcache_page() may use page
mapping information to do optimization so page_mapping() will see the
slab page, then VM_BUG_ON() is triggered.
Aaro Koskinen reported the bug on ARM/kirkwood when DEBUG_VM is enabled,
and this patch fixes the bug by adding test of '!PageSlab(miter->page)'
before calling flush_kernel_dcache_page().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Simon Baatz <gmbnomis@gmail.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Tejun Heo <tj@kernel.org>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
commit 4b59e6c4730978679b414a8da61514a2518da512 upstream.
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
commit a49b7e82cab0f9b41f483359be83f44fbb6b4979 upstream.
Anatol Pomozov identified a race condition that hits module unloading
and re-loading. To quote Anatol:
"This is a race codition that exists between kset_find_obj() and
kobject_put(). kset_find_obj() might return kobject that has refcount
equal to 0 if this kobject is freeing by kobject_put() in other
thread.
Here is timeline for the crash in case if kset_find_obj() searches for
an object tht nobody holds and other thread is doing kobject_put() on
the same kobject:
THREAD A (calls kset_find_obj()) THREAD B (calls kobject_put())
splin_lock()
atomic_dec_return(kobj->kref), counter gets zero here
... starts kobject cleanup ....
spin_lock() // WAIT thread A in kobj_kset_leave()
iterate over kset->list
atomic_inc(kobj->kref) (counter becomes 1)
spin_unlock()
spin_lock() // taken
// it does not know that thread A increased counter so it
remove obj from list
spin_unlock()
vfree(module) // frees module object with containing kobj
// kobj points to freed memory area!!
kobject_put(kobj) // OOPS!!!!
The race above happens because module.c tries to use kset_find_obj()
when somebody unloads module. The module.c code was introduced in
commit 6494a93d55fa"
Anatol supplied a patch specific for module.c that worked around the
problem by simply not using kset_find_obj() at all, but rather than make
a local band-aid, this just fixes kset_find_obj() to be thread-safe
using the proper model of refusing the get a new reference if the
refcount has already dropped to zero.
See examples of this proper refcount handling not only in the kref
documentation, but in various other equivalent uses of this pattern by
grepping for atomic_inc_not_zero().
[ Side note: the module race does indicate that module loading and
unloading is not properly serialized wrt sysfs information using the
module mutex. That may require further thought, but this is the
correct fix at the kobject layer regardless. ]
Reported-analyzed-and-tested-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit 326cf0f0f308933c10236280a322031f0097205d upstream.
Most functions in idr fail to deal with the high bits when the idr
tree grows to the maximum height.
* idr_get_empty_slot() stops growing idr tree once the depth reaches
MAX_IDR_LEVEL - 1, which is one depth shallower than necessary to
cover the whole range. The function doesn't even notice that it
didn't grow the tree enough and ends up allocating the wrong ID
given sufficiently high @starting_id.
For example, on 64 bit, if the starting id is 0x7fffff01,
idr_get_empty_slot() will grow the tree 5 layer deep, which only
covers the 30 bits and then proceed to allocate as if the bit 30
wasn't specified. It ends up allocating 0x3fffff01 without the bit
30 but still returns 0x7fffff01.
* __idr_remove_all() will not remove anything if the tree is fully
grown.
* idr_find() can't find anything if the tree is fully grown.
* idr_for_each() and idr_get_next() can't iterate anything if the tree
is fully grown.
Fix it by introducing idr_max() which returns the maximum possible ID
given the depth of tree and replacing the id limit checks in all
affected places.
As the idr_layer pointer array pa[] needs to be 1 larger than the
maximum depth, enlarge pa[] arrays by one.
While this plugs the discovered issues, the whole code base is
horrible and in desparate need of rewrite. It's fragile like hell,
- Adjust context
- s/MAX_IDR_LEVEL/MAX_LEVEL/; s/MAX_IDR_SHIFT/MAX_ID_SHIFT/
- Drop change to idr_alloc()]
commit 9f7de8275b46d9d11b1505adbfe6c2bb48df4741 upstream.
Make one small adjustment to idr_get_next(): take the height from the top
layer (stable under RCU) instead of from the root (unprotected by RCU), as
idr_find() does: so that it can be used with RCU locking. Copied comment
on RCU locking from idr_find().
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
commit 6cdae7416a1c45c2ce105a78187d9b7e8feb9e24 upstream.
The iteration logic of idr_get_next() is borrowed mostly verbatim from
idr_for_each(). It walks down the tree looking for the slot matching
the current ID. If the matching slot is not found, the ID is
incremented by the distance of single slot at the given level and
repeats.
The implementation assumes that during the whole iteration id is aligned
to the layer boundaries of the level closest to the leaf, which is true
for all iterations starting from zero or an existing element and thus is
fine for idr_for_each().
However, idr_get_next() may be given any point and if the starting id
hits in the middle of a non-existent layer, increment to the next layer
will end up skipping the same offset into it. For example, an IDR with
IDs filled between [64, 127] would look like the following.
[ 0 64 ... ]
NULL [ 64 ... 127 ]
If idr_get_next() is called with 63 as the starting point, it will try
to follow down the pointer from 0. As it is NULL, it will then try to
proceed to the next slot in the same level by adding the slot distance
at that level which is 64 - making the next try 127. It goes around the
loop and finds and returns 127 skipping [64, 126].
Note that this bug also triggers in idr_for_each_entry() loop which
deletes during iteration as deletions can make layers go away leaving
the iteration with unaligned ID into missing layers.
Fix it by ensuring proceeding to the next slot doesn't carry over the
unaligned offset - ie. use round_up(id + 1, slot_distance) instead of
id += slot_distance.
Reported-by: David Teigland <teigland@redhat.com>
commit eedce141cd2dad8d0cefc5468ef41898949a7031 upstream.
The genalloc code uses the bitmap API from include/linux/bitmap.h and
lib/bitmap.c, which is based on long values. Both bitmap_set from
lib/bitmap.c and bitmap_set_ll, which is the lockless version from
genalloc.c, use BITMAP_LAST_WORD_MASK to set the first bits in a long in
the bitmap.
That one uses (1 << bits) - 1, 0b111, if you are setting the first three
bits. This means that the API counts from the least significant bits
(LSB from now on) to the MSB. The LSB in the first long is bit 0, then.
The same works for the lookup functions.
The genalloc code uses longs for the bitmap, as it should. In
include/linux/genalloc.h, struct gen_pool_chunk has unsigned long
bits[0] as its last member. When allocating the struct, genalloc should
reserve enough space for the bitmap. This should be a proper number of
longs that can fit the amount of bits in the bitmap.
However, genalloc allocates an integer number of bytes that fit the
amount of bits, but may not be an integer amount of longs. 9 bytes, for
example, could be allocated for 70 bits.
This is a problem in itself if the Least Significat Bit in a long is in
the byte with the largest address, which happens in Big Endian machines.
This means genalloc is not allocating the byte in which it will try to
set or check for a bit.
This may end up in memory corruption, where genalloc will try to set the
bits it has not allocated. In fact, genalloc may not set these bits
because it may find them already set, because they were not zeroed since
they were not allocated. And that's what causes a BUG when
gen_pool_destroy is called and check for any set bits.
What really happens is that genalloc uses kmalloc_node with __GFP_ZERO
on gen_pool_add_virt. With SLAB and SLUB, this means the whole slab
will be cleared, not only the requested bytes. Since struct
gen_pool_chunk has a size that is a multiple of 8, and slab sizes are
multiples of 8, we get lucky and allocate and clear the right amount of
bytes.
Hower, this is not the case with SLOB or with older code that did memset
after allocating instead of using __GFP_ZERO.
So, a simple module as this (running 3.6.0), will cause a crash when
rmmod'ed.
[root@phantom-lp2 foo]# cat foo.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/genalloc.h>
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
static struct gen_pool *foo_pool;
static __init int foo_init(void)
int ret;
foo_pool = gen_pool_create(10, -1);
if (!foo_pool)
return -ENOMEM;
ret = gen_pool_add(foo_pool, 0xa0000000, 32 << 10, -1);
if (ret) {
gen_pool_destroy(foo_pool);
return ret;
return 0;
static __exit void foo_exit(void)
module_init(foo_init);
module_exit(foo_exit);
[root@phantom-lp2 foo]# zcat /proc/config.gz | grep SLOB
CONFIG_SLOB=y
[root@phantom-lp2 foo]# insmod ./foo.ko
[root@phantom-lp2 foo]# rmmod foo
kernel BUG at lib/genalloc.c:243!
cpu 0x4: Vector: 700 (Program Check) at [c0000000bb0e7960]
pc: c0000000003cb50c: .gen_pool_destroy+0xac/0x110
lr: c0000000003cb4fc: .gen_pool_destroy+0x9c/0x110
sp: c0000000bb0e7be0
msr: 8000000000029032
current = 0xc0000000bb0e0000
paca = 0xc000000006d30e00 softe: 0 irq_happened: 0x01
pid = 13044, comm = rmmod
[c0000000bb0e7ca0] d000000004b00020 .foo_exit+0x20/0x38 [foo]
[c0000000bb0e7d20] c0000000000dff98 .SyS_delete_module+0x1a8/0x290
[c0000000bb0e7e30] c0000000000097d4 syscall_exit+0x0/0x94
--- Exception: c00 (System Call) at 000000800753d1a0
SP (fffd0b0e640) is in userspace
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Benjamin Gaignard <benjamin.gaignard@stericsson.com>
commit e96875677fb2b7cb739c5d7769824dff7260d31d upstream.
Account for all properties when a and/or b are 0:
gcd(0, 0) = 0
gcd(a, 0) = a
gcd(0, b) = b
Fixes no known problems in current kernels.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
commit 3715c5309f6d175c3053672b73fd4f73be16fd07 upstream.
When using ALT+SysRq+Q all the pointers are replaced with "pK-error" like
this:
[23153.208033] .base: pK-error
with echo h > /proc/sysrq-trigger it works:
[23107.776363] .base: ffff88023e60d540
The intent behind this behavior was to return "pK-error" in cases where
the %pK format specifier was used in interrupt context, because the
CAP_SYSLOG check wouldn't be meaningful. Clearly this should only apply
when kptr_restrict is actually enabled though.
Reported-by: Stevie Trujillo <stevie.trujillo@gmail.com>
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
commit cbf8ae32f66a9ceb8907ad9e16663c2a29e48990 upstream.
The memory the parameter __key points to is used as an iterator in
btree_get_prev(), so if we save off a bkey() pointer in retry_key and
then assign that to __key, we'll end up corrupting the btree internals
when we do eg
longcpy(__key, bkey(geo, node, i), geo->keylen);
to return the key value. What we should do instead is use longcpy() to
copy the key value that retry_key points to __key.
This can cause a btree to get corrupted by seemingly read-only
operations such as btree_for_each_safe.
[akpm@linux-foundation.org: avoid the double longcpy()]
Signed-off-by: Roland Dreier <roland@purestorage.com>
Acked-by: Joern Engel <joern@logfs.org>
commit 7b60a18da393ed70db043a777fd9e6d5363077c4 upstream.
The queue handling in the udev daemon assumes that the events are
ordered.
Before this patch uevent_seqnum is incremented under sequence_lock,
than an event is send uner uevent_sock_mutex. I want to say that code
contained a window between incrementing seqnum and sending an event.
This patch locks uevent_sock_mutex before incrementing uevent_seqnum.
v2: delete sequence_lock, uevent_seqnum is protected by uevent_sock_mutex
v3: unlock the mutex before the goto exit
Thanks for Kay for the comments.
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Tested-By: Kay Sievers <kay.sievers@vrfy.org>
cppcheck reported:
[lib/dma-debug.c:248] -> [lib/dma-debug.c:248]: (style) Same expression on both sides of '=='.
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
forcedeth: fix a few sparse warnings (variable shadowing)
forcedeth: Improve stats counters
forcedeth: remove unneeded stats updates
forcedeth: Acknowledge only interrupts that are being processed
forcedeth: fix race when unloading module
MAINTAINERS/rds: update maintainer
wanrouter: Remove kernel_lock annotations
usbnet: fix oops in usbnet_start_xmit
ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined
etherh: Add MAINTAINERS entry for etherh
bonding: comparing a u8 with -1 is always false
sky2: fix regression on Yukon Optima
netlink: clarify attribute length check documentation
netlink: validate NLA_MSECS length
i825xx:xscale:8390:freescale: Fix Kconfig dependancies
macvlan: receive multicast with local address
tg3: Update version to 3.121
tg3: Eliminate timer race with reset_task
tg3: Schedule at most one tg3_reset_task run
tg3: Obtain PCI function number from device
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
L2TP for example uses NLA_MSECS like this:
policy:
[L2TP_ATTR_RECV_TIMEOUT] = { .type = NLA_MSECS, },
code:
if (info->attrs[L2TP_ATTR_RECV_TIMEOUT])
cfg.reorder_timeout = nla_get_msecs(info->attrs[L2TP_ATTR_RECV_TIMEOUT]);
As nla_get_msecs() is essentially nla_get_u64() plus the
conversion to a HZ-based value, this will not properly
reject attributes from userspace that aren't long enough
and might overrun the message.
Add NLA_MSECS to the attribute minlen array to check the
size properly.
Cc: stable@vger.kernel.org
It's often convenient to be able to release resource from IRQ context.
Make ida_simple_*() use irqsave/restore spin ops so that they are IRQ
safe.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
As suggested by Andrew Morton in [1] there is better to have most
significant part first in the function name.
[1] https://lkml.org/lkml/2011/9/20/22
There is no functional change.
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Mimi Zohar <zohar@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: "John W. Linville" <linville@tuxdriver.com>
Commit 84c95c9acf0 ("string: on strstrip(), first remove leading spaces
before running over str") improved the performance of the strim()
function.
Unfortunately this changed the semantics of strim() and broke my code.
Before the patch it was possible to use strim() without using the return
value for removing trailing spaces from strings that had either only
blanks or only trailing blanks.
Now this does not work any longer for strings that *only* have blanks.
Before patch: " " -> "" (empty string)
After patch: " " -> " " (no change)
I think we should remove your patch to restore the old behavior.
The description (lib/string.c):
* Note that the first trailing whitespace is replaced with a %NUL-terminator
=> The first trailing whitespace of a string that only has whitespace
characters is the first whitespace
The patch restores the old strim() semantics.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Andre Goddard Rosa <andre.goddard@gmail.com>
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com>
These variables are only used when CONFIG_HOTPLUG_CPU is enabled, they are
ifdef'ed everywhere else. So don't define them when CONFIG_HOTPLUG_CPU is
not enabled.
Signed-off-by: Glauber Costa <glommer@parallels.com>
__bitmap_parse() and __bitmap_parselist() both take a pointer to a kernel
buffer as a parameter and then cast it to a pointer to user buffer for use
in cases when the parameter is_user indicates that the buffer is actually
located in user space. This casting, and the casts in the callers,
results in sparse noise like the following:
warning: incorrect type in initializer (different address spaces)
expected char const [noderef] <asn:1>*ubuf
got char const *buf
warning: cast removes address space of expression
Since these casts are intentional, use __force to quiet the noise.
Cc: Len Brown <len.brown@intel.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
When SPIN_BUG_ON is triggered, the lock owner information is reported.
But it is omitted when spinlock lockup is detected.
This information is useful especially on the architectures which don't
implement trigger_all_cpu_backtrace() that is called just after detecting
lockup. So report it and also avoid message format duplication.
Currently termination logic (\0 or \n\0) is hardcoded in _kstrtoull(),
avoid that for code reuse between kstrto*() and simple_strtoull().
Essentially, make them different only in termination logic.
simple_strtoull() (and scanf(), BTW) ignores integer overflow, that's a
bug we currently don't have guts to fix, making KSTRTOX_OVERFLOW hack
necessary.
Almost forgot: patch shrinks code size by about ~80 bytes on x86_64.
Added missing _secs in the help message of config DEFAULT_HUNG_TASK_TIMEOUT.
Signed-off-by: Jiaju Zhang <jjzhang@suse.de>
memchr_inv() is mainly used to check whether the whole buffer is filled
with just a specified byte.
The function name and prototype are stolen from logfs and the
implementation is from SLUB.
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Marcin Slusarz <marcin.slusarz@gmail.com>
radix_tree_tag_get()'s BUG (when it sees a tag after saw_unset_tag) was
unsafe and removed in 2.6.34, but the pointless saw_unset_tag left behind.
Remove it now, and return 0 as soon as we see unset tag - we already rely
upon the root tag to be correct, returning 0 immediately if it's not set.
There are no modular calls here, so just the minimal header for
the EXPORT_SYMBOL macro will suffice.
These files were getting the defines for EXPORT_SYMBOL because
device.h was including module.h. But we are going to put an
end to that. So add the proper export.h include now.
A pending cleanup will mean that module.h won't be implicitly
everywhere anymore. Make sure the modular drivers in md dir
are actually calling out for <module.h> explicitly in advance.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits)
iommu/core: Remove global iommu_ops and register_iommu
iommu/msm: Use bus_set_iommu instead of register_iommu
iommu/omap: Use bus_set_iommu instead of register_iommu
iommu/vt-d: Use bus_set_iommu instead of register_iommu
iommu/amd: Use bus_set_iommu instead of register_iommu
iommu/core: Use bus->iommu_ops in the iommu-api
iommu/core: Convert iommu_found to iommu_present
iommu/core: Add bus_type parameter to iommu_domain_alloc
Driver core: Add iommu_ops to bus_type
iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API
iommu/amd: Fix wrong shift direction
iommu/omap: always provide iommu debug code
iommu/core: let drivers know if an iommu fault handler isn't installed
iommu/core: export iommu_set_fault_handler()
iommu/omap: Fix build error with !IOMMU_SUPPORT
iommu/omap: Migrate to the generic fault report mechanism
iommu/core: Add fault reporting mechanism
iommu/core: Use PAGE_SIZE instead of hard-coded value
iommu/core: use the existing IS_ALIGNED macro
iommu/msm: ->unmap() should return order of unmapped page
Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to
dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config
options" just happened to touch lines next to each other.
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (83 commits)
mmc: fix compile error when CONFIG_BLOCK is not enabled
mmc: core: Cleanup eMMC4.5 conditionals
mmc: omap_hsmmc: if multiblock reads are broken, disable them
mmc: core: add workaround for controllers with broken multiblock reads
mmc: core: Prevent too long response times for suspend
mmc: recognise SDIO cards with SDIO_CCCR_REV 3.00
mmc: sd: Handle SD3.0 cards not supporting UHS-I bus speed mode
mmc: core: support HPI send command
mmc: core: Add cache control for eMMC4.5 device
mmc: core: Modify the timeout value for writing power class
mmc: core: new discard feature support at eMMC v4.5
mmc: core: mmc sanitize feature support for v4.5
mmc: dw_mmc: modify DATA register offset
mmc: sdhci-pci: add flag for devices that can support runtime PM
mmc: omap_hsmmc: ensure pbias configuration is always done
mmc: core: Add Power Off Notify Feature eMMC 4.5
mmc: sdhci-s3c: fix potential NULL dereference
mmc: replace printk with appropriate display macro
mmc: core: Add default timeout value for CMD6
mmc: sdhci-pci: add runtime pm support
mmc_core module needs to use setup_fault_attr() in order
to set fault injection attributes during module load time.
Signed-off-by: Per Forlin <per.forlin@linaro.org>
Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
This adds support to inject data errors after a completed host transfer.
The mmc core will return error even though the host transfer is successful.
This simple fault injection proved to be very useful to test the
non-blocking error handling in the mmc_blk_issue_rw_rq().
Random faults can also test how the host driver handles pre_req()
and post_req() in case of errors.
Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
Export symbols should_fail() and fault_create_debugfs_attr() in order
to let modules utilize the fault injection framework.
* 'for-linus' of git://neil.brown.name/md: (34 commits)
md: Fix some bugs in recovery_disabled handling.
md/raid5: fix bug that could result in reads from a failed device.
lib/raid6: Fix filename emitted in generated code
md.c: trivial comment fix
MD: Allow restarting an interrupted incremental recovery.
md: clear In_sync bit on devices added to an active array.
md: add proper write-congestion reporting to RAID1 and RAID10.
md: rename "mdk_personality" to "md_personality"
md/bitmap remove fault injection options.
md/raid5: typedef removal: raid5_conf_t -> struct r5conf
md/raid1: typedef removal: conf_t -> struct r1conf
md/raid10: typedef removal: conf_t -> struct r10conf
md/raid0: typedef removal: raid0_conf_t -> struct r0conf
md/multipath: typedef removal: multipath_conf_t -> struct mpconf
md/linear: typedef removal: linear_conf_t -> struct linear_conf
md/faulty: remove typedef: conf_t -> struct faulty_conf
md/linear: remove typedefs: dev_info_t -> struct dev_info
md: remove typedefs: mirror_info_t -> struct mirror_info
md: remove typedefs: r10bio_t -> struct r10bio and r1bio_t -> struct r1bio
md: remove typedefs: mdk_thread_t -> struct md_thread
