commit fcc16882ac4532aaa644bff444f0c5d6228ba71e upstream.
The atomic64 library uses a handful of static spin locks to implement
atomic 64-bit operations on architectures without support for atomic
64-bit instructions.
Unfortunately, the spinlocks are initialized in a pure initcall and that
is too late for the vfs namespace code which wants to use atomic64
operations before the initcall is run.
This became a problem as of commit 8823c079ba71: "vfs: Add setns support
for the mount namespace".
This leads to BUG messages such as:
BUG: spinlock bad magic on CPU#0, swapper/0/0
lock: atomic64_lock+0x240/0x400, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
do_raw_spin_lock+0x158/0x198
_raw_spin_lock_irqsave+0x4c/0x58
atomic64_add_return+0x30/0x5c
alloc_mnt_ns.clone.14+0x44/0xac
create_mnt_ns+0xc/0x54
mnt_init+0x120/0x1d4
vfs_caches_init+0xe0/0x10c
start_kernel+0x29c/0x300
coming out early on during boot when spinlock debugging is enabled.
Fix this by initializing the spinlocks statically at compile time.
Reported-and-tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
It is $(obj)/oid_registry.o that is dependent on $(obj)/oid_registry_data.c.
The object file cannot be built until $(obj)/oid_registry_data.c has been
generated.
A periodic and hard to reproduce parallel build failure is due to
this incorrect lib/Makefile dependency. The compile error is completely
disingenuous.
GEN lib/oid_registry_data.c
Compiling 49 OIDs
CC lib/oid_registry.o
gcc: error: lib/oid_registry.c: No such file or directory
gcc: fatal error: no input files
compilation terminated.
make[3]: *** [lib/oid_registry.o] Error 4
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Fix an error in asn1_find_indefinite_length() whereby small definite length
elements of size 0x7f are incorrecly classified as non-small. Without this
fix, an error will be given as the length of the length will be perceived as
being very much greater than the maximum supported size.
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint,
leading to this build failure:
CC lib/mpi/generic_mpih-mul1.o
lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1':
lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm'
This patch updates MPI with the latest umul_ppm implementations for MIPS.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/4612/
The genalloc code uses the bitmap API from include/linux/bitmap.h and
lib/bitmap.c, which is based on long values. Both bitmap_set from
lib/bitmap.c and bitmap_set_ll, which is the lockless version from
genalloc.c, use BITMAP_LAST_WORD_MASK to set the first bits in a long in
the bitmap.
That one uses (1 << bits) - 1, 0b111, if you are setting the first three
bits. This means that the API counts from the least significant bits
(LSB from now on) to the MSB. The LSB in the first long is bit 0, then.
The same works for the lookup functions.
The genalloc code uses longs for the bitmap, as it should. In
include/linux/genalloc.h, struct gen_pool_chunk has unsigned long
bits[0] as its last member. When allocating the struct, genalloc should
reserve enough space for the bitmap. This should be a proper number of
longs that can fit the amount of bits in the bitmap.
However, genalloc allocates an integer number of bytes that fit the
amount of bits, but may not be an integer amount of longs. 9 bytes, for
example, could be allocated for 70 bits.
This is a problem in itself if the Least Significat Bit in a long is in
the byte with the largest address, which happens in Big Endian machines.
This means genalloc is not allocating the byte in which it will try to
set or check for a bit.
This may end up in memory corruption, where genalloc will try to set the
bits it has not allocated. In fact, genalloc may not set these bits
because it may find them already set, because they were not zeroed since
they were not allocated. And that's what causes a BUG when
gen_pool_destroy is called and check for any set bits.
What really happens is that genalloc uses kmalloc_node with __GFP_ZERO
on gen_pool_add_virt. With SLAB and SLUB, this means the whole slab
will be cleared, not only the requested bytes. Since struct
gen_pool_chunk has a size that is a multiple of 8, and slab sizes are
multiples of 8, we get lucky and allocate and clear the right amount of
bytes.
Hower, this is not the case with SLOB or with older code that did memset
after allocating instead of using __GFP_ZERO.
So, a simple module as this (running 3.6.0), will cause a crash when
rmmod'ed.
[root@phantom-lp2 foo]# cat foo.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/genalloc.h>
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
static struct gen_pool *foo_pool;
static __init int foo_init(void)
int ret;
foo_pool = gen_pool_create(10, -1);
if (!foo_pool)
return -ENOMEM;
ret = gen_pool_add(foo_pool, 0xa0000000, 32 << 10, -1);
if (ret) {
gen_pool_destroy(foo_pool);
return ret;
return 0;
static __exit void foo_exit(void)
module_init(foo_init);
module_exit(foo_exit);
[root@phantom-lp2 foo]# zcat /proc/config.gz | grep SLOB
CONFIG_SLOB=y
[root@phantom-lp2 foo]# insmod ./foo.ko
[root@phantom-lp2 foo]# rmmod foo
kernel BUG at lib/genalloc.c:243!
cpu 0x4: Vector: 700 (Program Check) at [c0000000bb0e7960]
pc: c0000000003cb50c: .gen_pool_destroy+0xac/0x110
lr: c0000000003cb4fc: .gen_pool_destroy+0x9c/0x110
sp: c0000000bb0e7be0
msr: 8000000000029032
current = 0xc0000000bb0e0000
paca = 0xc000000006d30e00 softe: 0 irq_happened: 0x01
pid = 13044, comm = rmmod
[c0000000bb0e7ca0] d000000004b00020 .foo_exit+0x20/0x38 [foo]
[c0000000bb0e7d20] c0000000000dff98 .SyS_delete_module+0x1a8/0x290
[c0000000bb0e7e30] c0000000000097d4 syscall_exit+0x0/0x94
--- Exception: c00 (System Call) at 000000800753d1a0
SP (fffd0b0e640) is in userspace
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Benjamin Gaignard <benjamin.gaignard@stericsson.com>
Cc: <stable@vger.kernel.org>
If there is only one match, the unique matched entry should be returned.
Without the fix, the upcoming dma debug interfaces ("dma-debug: new
interfaces to debug dma mapping errors") can't work reliably because
only device and dma_addr are passed to dma_mapping_error().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Tested-by: Shuah Khan <shuah.khan@hp.com>
Cc: Jakub Kicinski <kubakici@wp.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Merge misc fixes from Andrew Morton:
"Followups, fixes and some random stuff I found on the internet."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (11 patches)
perf: fix duplicate header inclusion
memcg, kmem: fix build error when CONFIG_INET is disabled
rtc: kconfig: fix RTC_INTF defaults connected to RTC_CLASS
rapidio: fix comment
lib/kasprintf.c: use kmalloc_track_caller() to get accurate traces for kvasprintf
rapidio: update for destination ID allocation
rapidio: update asynchronous discovery initialization
rapidio: use msleep in discovery wait
mm: compaction: fix bit ranges in {get,clear,set}_pageblock_skip()
arch/powerpc/platforms/pseries/hotplug-memory.c: section removal cleanups
arch/powerpc/platforms/pseries/hotplug-memory.c: fix section handling code
Pull block IO update from Jens Axboe:
"Core block IO bits for 3.7. Not a huge round this time, it contains:
- First series from Kent cleaning up and generalizing bio allocation
and freeing.
- WRITE_SAME support from Martin.
- Mikulas patches to prevent O_DIRECT crashes when someone changes
the block size of a device.
- Make bio_split() work on data-less bio's (like trim/discards).
- A few other minor fixups."
Fixed up silent semantic mis-merge as per Mikulas Patocka and Andrew
Morton. It is due to the VM no longer using a prio-tree (see commit
6b2dbba8b6ac: "mm: replace vma prio_tree with an interval tree").
So make set_blocksize() use mapping_mapped() instead of open-coding the
internal VM knowledge that has changed.
* 'for-3.7/core' of git://git.kernel.dk/linux-block: (26 commits)
block: makes bio_split support bio without data
scatterlist: refactor the sg_nents
scatterlist: add sg_nents
fs: fix include/percpu-rwsem.h export error
percpu-rw-semaphore: fix documentation typos
fs/block_dev.c:1644:5: sparse: symbol 'blkdev_mmap' was not declared
blockdev: turn a rw semaphore into a percpu rw semaphore
Fix a crash when block device is read and block size is changed at the same time
block: fix request_queue->flags initialization
block: lift the initial queue bypass mode on blk_register_queue() instead of blk_init_allocated_queue()
block: ioctl to zero block ranges
block: Make blkdev_issue_zeroout use WRITE SAME
block: Implement support for WRITE SAME
block: Consolidate command flag and queue limit checks for merges
block: Clean up special command handling logic
block/blk-tag.c: Remove useless kfree
block: remove the duplicated setting for congestion_threshold
block: reject invalid queue attribute values
block: Add bio_clone_bioset(), bio_clone_kmalloc()
block: Consolidate bio_alloc_bioset(), bio_kmalloc()
kvasprintf
Previously kvasprintf() allocation was being done through kmalloc(),
thus producing an inaccurate trace report.
This is a common problem: in order to get accurate callsite tracing, a
lib/utils function shouldn't allocate kmalloc but instead use
kmalloc_track_caller.
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
asn1_find_indefinite_length() returns an error indicator of -1, which the
caller asn1_ber_decoder() places in a size_t (which is usually unsigned) and
then checks to see whether it is less than 0 (which it can't be). This can
lead to the following warning:
lib/asn1_decoder.c:320 asn1_ber_decoder()
warn: unsigned 'len' is never less than zero.
Instead, asn1_find_indefinite_length() update the caller's idea of the data
cursor and length separately from returning the error code.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Add a CONFIG_DEBUG_VM_RB build option for the previously existing
DEBUG_MM_RB code. Now that Andi Kleen modified it to avoid using
recursive algorithms, we can expose it a bit more.
Also extend this code to validate_mm() after stack expansion, and to check
that the vma's start and last pgoffs have not changed since the nodes were
inserted on the anon vma interval tree (as it is important that the nodes
be reindexed after each such update).
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Daniel Santos <daniel.santos@pobox.com>
Update the generic interval tree code that was introduced in "mm: replace
vma prio_tree with an interval tree".
Changes:
- fixed 'endpoing' typo noticed by Andrew Morton
- replaced include/linux/interval_tree_tmpl.h, which was used as a
template (including it automatically defined the interval tree
functions) with include/linux/interval_tree_generic.h, which only
defines a preprocessor macro INTERVAL_TREE_DEFINE(), which itself
defines the interval tree functions when invoked. Now that is a very
long macro which is unfortunate, but it does make the usage sites
(lib/interval_tree.c and mm/interval_tree.c) a bit nicer than previously.
- make use of RB_DECLARE_CALLBACKS() in the INTERVAL_TREE_DEFINE() macro,
instead of duplicating that code in the interval tree template.
- replaced vma_interval_tree_add(), which was actually handling the
nonlinear and interval tree cases, with vma_interval_tree_insert_after()
which handles only the interval tree case and has an API that is more
consistent with the other interval tree handling functions.
The nonlinear case is now handled explicitly in kernel/fork.c dup_mmap().
Provide rb_insert_augmented() and rb_erase_augmented() through a new
rbtree_augmented.h include file. rb_erase_augmented() is defined there as
an __always_inline function, in order to allow inlining of augmented
rbtree callbacks into it. Since this generates a relatively large
function, each augmented rbtree user should make sure to have a single
call site.
Cc: Hillf Danton <dhillf@gmail.com>
After both prio_tree users have been converted to use red-black trees,
there is no need to keep around the prio tree library anymore.
Implement an interval tree as a replacement for the VMA prio_tree. The
algorithms are similar to lib/interval_tree.c; however that code can't be
directly reused as the interval endpoints are not explicitly stored in the
VMA. So instead, the common algorithm is moved into a template and the
details (node type, how to get interval endpoints from the node, etc) are
filled in using the C preprocessor.
Once the interval tree functions are available, using them as a
replacement to the VMA prio tree is a relatively simple, mechanical job.
Patch 1 implements support for interval trees, on top of the augmented
rbtree API. It also adds synthetic tests to compare the performance of
interval trees vs prio trees. Short answers is that interval trees are
slightly faster (~25%) on insert/erase, and much faster (~2.4 - 3x)
on search. It is debatable how realistic the synthetic test is, and I have
not made such measurements yet, but my impression is that interval trees
would still come out faster.
Patch 2 uses a preprocessor template to make the interval tree generic,
and uses it as a replacement for the vma prio_tree.
Patch 3 takes the other prio_tree user, kmemleak, and converts it to use
a basic rbtree. We don't actually need the augmented rbtree support here
because the intervals are always non-overlapping.
Patch 4 removes the now-unused prio tree library.
Patch 5 proposes an additional optimization to rb_erase_augmented, now
providing it as an inline function so that the augmented callbacks can be
inlined in. This provides an additional 5-10% performance improvement
for the interval tree insert/erase benchmark. There is a maintainance cost
as it exposes augmented rbtree users to some of the rbtree library internals;
however I think this cost shouldn't be too high as I expect the augmented
rbtree will always have much less users than the base rbtree.
I should probably add a quick summary of why I think it makes sense to
replace prio trees with augmented rbtree based interval trees now. One of
the drivers is that we need augmented rbtrees for Rik's vma gap finding
code, and once you have them, it just makes sense to use them for interval
trees as well, as this is the simpler and more well known algorithm. prio
trees, in comparison, seem *too* clever: they impose an additional 'heap'
constraint on the tree, which they use to guarantee a faster worst-case
complexity of O(k+log N) for stabbing queries in a well-balanced prio
tree, vs O(k*log N) for interval trees (where k=number of matches,
N=number of intervals). Now this sounds great, but in practice prio trees
don't realize this theorical benefit. First, the additional constraint
makes them harder to update, so that the kernel implementation has to
simplify things by balancing them like a radix tree, which is not always
ideal. Second, the fact that there are both index and heap properties
makes both tree manipulation and search more complex, which results in a
higher multiplicative time constant. As it turns out, the simple interval
tree algorithm ends up running faster than the more clever prio tree.
This patch:
Add two test modules:
- prio_tree_test measures the performance of lib/prio_tree.c, both for
insertion/removal and for stabbing searches
- interval_tree_test measures the performance of a library of equivalent
functionality, built using the augmented rbtree support.
In order to support the second test module, lib/interval_tree.c is
introduced. It is kept separate from the interval_tree_test main file
for two reasons: first we don't want to provide an unfair advantage
over prio_tree_test by having everything in a single compilation unit,
and second there is the possibility that the interval tree functionality
could get some non-test users in kernel over time.
As proposed by Peter Zijlstra, this makes it easier to define the augmented
rbtree callbacks.
convert arch/x86/mm/pat_rbtree.c to the proposed augmented rbtree api
and remove the old augmented rbtree implementation.
Introduce new augmented rbtree APIs that allow minimal recalculation of
augmented node information.
A new callback is added to the rbtree insertion and erase rebalancing
functions, to be called on each tree rotations. Such rotations preserve
the subtree's root augmented value, but require recalculation of the one
child that was previously located at the subtree root.
In the insertion case, the handcoded search phase must be updated to
maintain the augmented information on insertion, and then the rbtree
coloring/rebalancing algorithms keep it up to date.
In the erase case, things are more complicated since it is library
code that manipulates the rbtree in order to remove internal nodes.
This requires a couple additional callbacks to copy a subtree's
augmented value when a new root is stitched in, and to recompute
augmented values down the ancestry path when a node is removed from
the tree.
In order to preserve maximum speed for the non-augmented case,
we provide two versions of each tree manipulation function.
rb_insert_augmented() is the augmented equivalent of rb_insert_color(),
and rb_erase_augmented() is the augmented equivalent of rb_erase().
Small test to measure the performance of augmented rbtrees.
Various minor optimizations in rb_erase():
- Avoid multiple loading of node->__rb_parent_color when computing parent
and color information (possibly not in close sequence, as there might
be further branches in the algorithm)
- In the 1-child subcase of case 1, copy the __rb_parent_color field from
the erased node to the child instead of recomputing it from the desired
parent and color
- When searching for the erased node's successor, differentiate between
cases 2 and 3 based on whether any left links were followed. This avoids
a condition later down.
- In case 3, keep a pointer to the erased node's right child so we don't
have to refetch it later to adjust its parent.
- In the no-childs subcase of cases 2 and 3, place the rebalance assigment
last so that the compiler can remove the following if(rebalance) test.
Also, added some comments to illustrate cases 2 and 3.
An interesting observation for rb_erase() is that when a node has
exactly one child, the node must be black and the child must be red.
An interesting consequence is that removing such a node can be done by
simply replacing it with its child and making the child black,
which we can do efficiently in rb_erase(). __rb_erase_color() then
only needs to handle the no-childs case and can be modified accordingly.
In rb_erase, move the easy case (node to erase has no more than
1 child) first. I feel the code reads easier that way.
Add __rb_change_child() as an inline helper function to replace code that
would otherwise be duplicated 4 times in the source.
No changes to binary size or speed.
Just a small fix to make sparse happy.
Reported-by: Fengguang Wu <wfg@linux.intel.com>
When looking to fetch a node's sibling, we went through a sequence of:
- check if node is the parent's left child
- if it is, then fetch the parent's right child
This can be replaced with:
- fetch the parent's right child as an assumed sibling
- check that node is NOT the fetched child
This avoids fetching the parent's left child when node is actually
that child. Saves a bit on code size, though it doesn't seem to make
a large difference in speed.
Cc: David Woodhouse <David.Woodhouse@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Set comment and indentation style to be consistent with linux coding style
and the rest of the file, as suggested by Peter Zijlstra
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
In __rb_erase_color(), we often already have pointers to the nodes being
rotated and/or know what their colors must be, so we can generate more
efficient code than the generic __rb_rotate_left() and __rb_rotate_right()
functions.
Also when the current node is red or when flipping the sibling's color,
the parent is already known so we can use the more efficient
rb_set_parent_color() function to set the desired color.
In __rb_erase_color(), we have to select one of 3 cases depending on the
color on the 'other' node children. If both children are black, we flip a
few node colors and iterate. Otherwise, we do either one or two tree
rotations, depending on the color of the 'other' child opposite to 'node',
and then we are done.
The corresponding logic had duplicate checks for the color of the 'other'
child opposite to 'node'. It was checking it first to determine if both
children are black, and then to determine how many tree rotations are
required. Rearrange the logic to avoid that extra check.
In __rb_erase_color(), we were always setting a node to black after
exiting the main loop. And in one case, after fixing up the tree to
satisfy all rbtree invariants, we were setting the current node to root
just to guarantee a loop exit, at which point the root would be set to
black. However this is not necessary, as the root of an rbtree is already
known to be black. The only case where the color flip is required is when
we exit the loop due to the current node being red, and it's easiest to
just do the flip at that point instead of doing it after the loop.
[adrian.hunter@intel.com: perf tools: fix build for another rbtree.c change]
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@intel.com>
- Use the newly introduced rb_set_parent_color() function to flip the color
of nodes whose parent is already known.
- Optimize rb_parent() when the node is known to be red - there is no need
to mask out the color in that case.
- Flipping gparent's color to red requires us to fetch its rb_parent_color
field, so we can reuse it as the parent value for the next loop iteration.
- Do not use __rb_rotate_left() and __rb_rotate_right() to handle tree
rotations: we already have pointers to all relevant nodes, and know their
colors (either because we want to adjust it, or because we've tested it,
or we can deduce it as black due to the node proximity to a known red node).
So we can generate more efficient code by making use of the node pointers
we already have, and setting both the parent and color attributes for
nodes all at once. Also in Case 2, some node attributes don't have to
be set because we know another tree rotation (Case 3) will always follow
and override them.
The root node of an rbtree must always be black. However,
rb_insert_color() only needs to maintain this invariant when it has been
broken - that is, when it exits the loop due to the current (red) node
being the root. In all other cases (exiting after tree rotations, or
exiting due to an existing black parent) the invariant is already
satisfied, so there is no need to adjust the root node color.
It is a well known property of rbtrees that insertion never requires more
than two tree rotations. In our implementation, after one loop iteration
identified one or two necessary tree rotations, we would iterate and look
for more. However at that point the node's parent would always be black,
which would cause us to exit the loop.
We can make the code flow more obvious by just adding a break statement
after the tree rotations, where we know we are done. Additionally, in the
cases where two tree rotations are necessary, we don't have to update the
'node' pointer as it wouldn't be used until the next loop iteration, which
we now avoid due to this break statement.
This small module helps measure the performance of rbtree insert and
erase.
Additionally, we run a few correctness tests to check that the rbtrees
have all desired properties:
- contains the right number of nodes in the order desired,
- never two consecutive red nodes on any path,
- all paths to leaf nodes have the same number of black nodes,
- root node is black
[akpm@linux-foundation.org: fix printk warning: sparc64 cycles_t is unsigned long]
rbtree users must use the documented APIs to manipulate the tree
structure. Low-level helpers to manipulate node colors and parenthood are
not part of that API, so move them to lib/rbtree.c
[dwmw2@infradead.org: fix jffs2 build issue due to renamed __rb_parent_color field]
Empty nodes have no color. We can make use of this property to simplify
the code emitted by the RB_EMPTY_NODE and RB_CLEAR_NODE macros. Also,
we can get rid of the rb_init_node function which had been introduced by
commit 88d19cf37952 ("timers: Add rb_init_node() to allow for stack
allocated rb nodes") to avoid some issue with the empty node's color not
being initialized.
I'm not sure what the RB_EMPTY_NODE checks in rb_prev() / rb_next() are
doing there, though. axboe introduced them in commit 10fd48f2376d
("rbtree: fixed reversed RB_EMPTY_NODE and rb_next/prev"). The way I
see it, the 'empty node' abstraction is only used by rbtree users to
flag nodes that they haven't inserted in any rbtree, so asking the
predecessor or successor of such nodes doesn't make any sense.
One final rb_init_node() caller was recently added in sysctl code to
implement faster sysctl name lookups. This code doesn't make use of
RB_EMPTY_NODE at all, and from what I could see it only called
rb_init_node() under the mistaken assumption that such initialization was
required before node insertion.
[sfr@canb.auug.org.au: fix net/ceph/osd_client.c build]
Cc: John Stultz <john.stultz@linaro.org>
Introduce HAVE_DEBUG_BUGVERBOSE config option and select it in
corresponding architecture Kconfig files. Architectures that already
select GENERIC_BUG don't need to select HAVE_DEBUG_BUGVERBOSE.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Introduce HAVE_DEBUG_KMEMLEAK config option and select it in corresponding
architecture Kconfig files. DEBUG_KMEMLEAK now only depends on
HAVE_DEBUG_KMEMLEAK.
Provide a function to read raw data of a predetermined size into an MPI rather
than expecting the size to be encoded within the data. The data is assumed to
represent an unsigned integer, and the resulting MPI will be positive.
The function looks like this:
MPI mpi_read_raw_data(const void *, size_t);
This is useful for reading ASN.1 integer primitives where the length is encoded
in the ASN.1 metadata.
Add an ASN.1 BER/DER/CER decoder. This uses the bytecode from the ASN.1
compiler in the previous patch to inform it as to what to expect to find in the
encoded byte stream. The output from the compiler also tells it what functions
to call on what tags, thus allowing the caller to retrieve information.
The decoder is called as follows:
int asn1_decoder(const struct asn1_decoder *decoder,
void *context,
const unsigned char *data,
size_t datalen);
The decoder argument points to the bytecode from the ASN.1 compiler. context
is the caller's context and is passed to the action functions. data and
datalen define the byte stream to be decoded.
Note that the decoder is currently limited to datalen being less than 64K.
This reduces the amount of stack space used by the decoder because ASN.1 is a
nested construct. Similarly, the decoder is limited to a maximum of 10 levels
of constructed data outside of a leaf node also in an effort to keep stack
usage down.
These restrictions can be raised if necessary.
Add a pair of utility functions to render OIDs as strings. The first takes an
encoded OID and turns it into a "a.b.c.d" form string:
int sprint_oid(const void *data, size_t datasize,
char *buffer, size_t bufsize);
The second takes an OID enum index and calls the first on the data held
therein:
int sprint_OID(enum OID oid, char *buffer, size_t bufsize);
Implement a simple static OID registry that allows the mapping of an encoded
OID to an enum value for ease of use.
The OID registry index enum appears in the:
linux/oid_registry.h
header file. A script generates the registry from lines in the header file
that look like:
<sp*>OID_foo,<sp*>/*<sp*>1.2.3.4<sp*>*/
The actual OID is taken to be represented by the numbers with interpolated
dots in the comment.
All other lines in the header are ignored.
The registry is queries by calling:
OID look_up_oid(const void *data, size_t datasize);
This returns a number from the registry enum representing the OID if found or
OID__NR if not.
Reinstate and export mpi_cmp() and mpi_cmp_ui() from the MPI library for use by
RSA signature verification as per RFC3447 section 5.2.2 step 1.
Provide count_leading/trailing_zeros() macros based on extant arch bit scanning
functions rather than reimplementing from scratch in MPILIB.
Whilst we're at it, turn count_foo_zeros(n, x) into n = count_foo_zeros(x).
Also move the definition to asm-generic as other people may be interested in
using it.
Cc: Arnd Bergmann <arnd@arndb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This time the IOMMU updates contain a bunch of fixes and cleanups to
various IOMMU drivers and the DMA debug code. New features are the
code for IRQ remapping support with the AMD IOMMU (preperation for
that was already merged in the last release) and a debugfs interface
to export some statistics in the NVidia Tegra IOMMU driver."
* tag 'iommu-updates-v3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (27 commits)
iommu/amd: Remove obsolete comment line
dma-debug: Remove local BUS_NOTIFY_UNBOUND_DRIVER define
iommu/amd: Fix possible use after free in get_irq_table()
iommu/amd: Report irq remapping through IOMMU-API
iommu/amd: Print message to system log when irq remapping is enabled
iommu/irq: Use amd_iommu_irq_ops if supported
iommu/amd: Make sure irq remapping still works on dma init failure
iommu/amd: Add initialization routines for AMD interrupt remapping
iommu/amd: Add call-back routine for HPET MSI
iommu/amd: Implement MSI routines for interrupt remapping
iommu/amd: Add IOAPIC remapping routines
iommu/amd: Add routines to manage irq remapping tables
iommu/amd: Add IRTE invalidation routine
iommu/amd: Make sure IOMMU is not considered to translate itself
iommu/amd: Split device table initialization into irq and dma part
iommu/amd: Check if IOAPIC information is correct
iommu/amd: Allocate data structures to keep track of irq remapping tables
iommu/amd: Add slab-cache for irq remapping tables
iommu/amd: Keep track of HPET and IOAPIC device ids
iommu/amd: Fix features reporting
Fix the warning:
WARNING: vmlinux.o(.text+0x14cfd8): Section mismatch in reference from the variable compressed_formats to the function .init.text:gunzip()
The function compressed_formats() references
the function __init gunzip().
etc..
Within decompress.c, compressed_formats[] needs 'a __initdata annotation',
because some of it's data members refer to functions which will be
unloaded after init.
Consequently, its user decompress_method() will get the __init prefix.
Signed-off-by: Hein Tibosch <hein_tibosch@yahoo.es>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
SG mapping iterator w/ SG_MITER_ATOMIC set required IRQ disabled because
it originally used KM_BIO_SRC_IRQ to allow use from IRQ handlers.
kmap_atomic() has long been updated to handle stacking atomic mapping
requests on per-cpu basis and only requires not sleeping while mapped.
Update sg_mapping_iter such that atomic iterators only require disabling
preemption instead of disabling IRQ.
While at it, convert wte weird @ARG@ notations to @ARG in the comment of
sg_miter_start().
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Alex Dubov <oakad@yahoo.com>
They show up in dmesg
[ 4.041094] start plist test
[ 4.045804] end plist test
without a lot of meaning so hide them behind debug loglevel.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Xen's pciback points out a couple of deficiencies with vsscanf()'s
standard conformance:
- Trailing character matching cannot be checked by the caller: With a
format string of "(%x:%x.%x) %n" absence of the closing parenthesis
cannot be checked, as input of "(00:00.0)" doesn't cause the %n to be
evaluated (because of the code not skipping white space before the
trailing %n).
- The parameter corresponding to a trailing %n could get filled even if
there was a matching error: With a format string of "(%x:%x.%x)%n",
input of "(00:00.0]" would still fill the respective variable pointed to
(and hence again make the mismatch non-detectable by the caller).
This patch aims at fixing those, but leaves other non-conforming aspects
of it untouched, among them these possibly relevant ones:
- improper handling of the assignment suppression character '*' (blindly
discarding all succeeding non-white space from the format and input
strings),
- not honoring conversion specifiers for %n, - not recognizing the C99
conversion specifier 't' (recognized by vsprintf()).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
