path: root/lib
2017-11-30lib/mpi: call cond_resched() from mpi_powm() loopEric Biggers
commit 1d9ddde12e3c9bab7f3d3484eb9446315e3571ca upstream. On a non-preemptible kernel, if KEYCTL_DH_COMPUTE is called with the largest permitted inputs (16384 bits), the kernel spends 10+ seconds doing modular exponentiation in mpi_powm() without rescheduling. If all threads do it, it locks up the system. Moreover, it can cause rcu_sched-stall warnings. Notwithstanding the insanity of doing this calculation in kernel mode rather than in userspace, fix it by calling cond_resched() as each bit from the exponent is processed. It's still noninterruptible, but at least it's preemptible now. Do the cond_resched() once per bit rather than once per MPI limb because each limb might still easily take 100+ milliseconds on slow CPUs. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: fix NULL pointer dereference during ASN.1 parsing [ver #2]Eric Biggers
commit 624f5ab8720b3371367327a822c267699c1823b8 upstream. syzkaller reported a NULL pointer dereference in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_PKCS7_TEST_KEY=y: keyctl add pkcs7_test desc '' @s The bug is that if the data buffer is empty, an integer underflow occurs in the following check: if (unlikely(dp >= datalen - 1)) goto data_overrun_error; This results in the NULL data pointer being dereferenced. Fix it by checking for 'datalen - dp < 2' instead. Also fix the similar check for 'dp >= datalen - n' later in the same function. That one possibly could result in a buffer overread. The NULL pointer dereference was reproducible using the "pkcs7_test" key type but not the "asymmetric" key type because the "asymmetric" key type checks for a 0-length payload before calling into the ASN.1 decoder but the "pkcs7_test" key type does not. The bug report was: BUG: unable to handle kernel NULL pointer dereference at (null) IP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 PGD 7b708067 P4D 7b708067 PUD 7b6ee067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: CPU: 0 PID: 522 Comm: syz-executor1 Not tainted 4.14.0-rc8 #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014 task: ffff9b6b3798c040 task.stack: ffff9b6b37970000 RIP: 0010:asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: 0018:ffff9b6b37973c78 EFLAGS: 00010216 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000021c RDX: ffffffff814a04ed RSI: ffffb1524066e000 RDI: ffffffff910759e0 RBP: ffff9b6b37973d60 R08: 0000000000000001 R09: ffff9b6b3caa4180 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f10ed1f2700(0000) GS:ffff9b6b3ea00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 000000007b6f3000 CR4: 00000000000006f0 Call Trace: pkcs7_parse_message+0xee/0x240 crypto/asymmetric_keys/pkcs7_parser.c:139 verify_pkcs7_signature+0x33/0x180 certs/system_keyring.c:216 pkcs7_preparse+0x41/0x70 crypto/asymmetric_keys/pkcs7_key_type.c:63 key_create_or_update+0x180/0x530 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xbf/0x250 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x4585c9 RSP: 002b:00007f10ed1f1bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007f10ed1f2700 RCX: 00000000004585c9 RDX: 0000000020000000 RSI: 0000000020008ffb RDI: 0000000020008000 RBP: 0000000000000000 R08: ffffffffffffffff R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff1b2260ae R13: 00007fff1b2260af R14: 00007f10ed1f2700 R15: 0000000000000000 Code: dd ca ff 48 8b 45 88 48 83 e8 01 4c 39 f0 0f 86 a8 07 00 00 e8 53 dd ca ff 49 8d 46 01 48 89 85 58 ff ff ff 48 8b 85 60 ff ff ff <42> 0f b6 0c 30 89 c8 88 8d 75 ff ff ff 83 e0 1f 89 8d 28 ff ff RIP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: ffff9b6b37973c78 CR2: 0000000000000000 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08KEYS: fix out-of-bounds read during ASN.1 parsingEric Biggers
commit 2eb9eabf1e868fda15808954fb29b0f105ed65f1 upstream. syzkaller with KASAN reported an out-of-bounds read in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_X509_CERTIFICATE_PARSER=y and CONFIG_KASAN=y: keyctl add asymmetric desc $'\x30\x30' @s The bug is that the length of an ASN.1 data value isn't validated in the case where it is encoded using the short form, causing the decoder to read past the end of the input buffer. Fix it by validating the length. The bug report was: BUG: KASAN: slab-out-of-bounds in asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 Read of size 1 at addr ffff88003cccfa02 by task syz-executor0/6818 CPU: 1 PID: 6818 Comm: syz-executor0 Not tainted 4.14.0-rc7-00008-g5f479447d983 #2 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0xb3/0x10b lib/dump_stack.c:52 print_address_description+0x79/0x2a0 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x236/0x340 mm/kasan/report.c:409 __asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427 asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 x509_cert_parse+0x1db/0x650 crypto/asymmetric_keys/x509_cert_parser.c:89 x509_key_preparse+0x64/0x7a0 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xcb/0x1a0 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x347/0xb20 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0x1cd/0x340 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x447c89 RSP: 002b:00007fca7a5d3bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007fca7a5d46cc RCX: 0000000000447c89 RDX: 0000000020006f4a RSI: 0000000020006000 RDI: 0000000020001ff5 RBP: 0000000000000046 R08: fffffffffffffffd R09: 0000000000000000 R10: 0000000000000002 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000000000 R14: 00007fca7a5d49c0 R15: 00007fca7a5d4700 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02assoc_array: Fix a buggy node-splitting caseDavid Howells
commit ea6789980fdaa610d7eb63602c746bf6ec70cd2b upstream. This fixes CVE-2017-12193. Fix a case in the assoc_array implementation in which a new leaf is added that needs to go into a node that happens to be full, where the existing leaves in that node cluster together at that level to the exclusion of new leaf. What needs to happen is that the existing leaves get moved out to a new node, N1, at level + 1 and the existing node needs replacing with one, N0, that has pointers to the new leaf and to N1. The code that tries to do this gets this wrong in two ways: (1) The pointer that should've pointed from N0 to N1 is set to point recursively to N0 instead. (2) The backpointer from N0 needs to be set correctly in the case N0 is either the root node or reached through a shortcut. Fix this by removing this path and using the split_node path instead, which achieves the same end, but in a more general way (thanks to Eric Biggers for spotting the redundancy). The problem manifests itself as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: assoc_array_apply_edit+0x59/0xe5 Fixes: 3cb989501c26 ("Add a generic associative array implementation.") Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27lib/digsig: fix dereference of NULL user_key_payloadEric Biggers
commit 192cabd6a296cbc57b3d8c05c4c89d87fc102506 upstream. digsig_verify() requests a user key, then accesses its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 051dbb918c7f ("crypto: digital signature verification support") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12lib/ratelimit.c: use deferred printk() versionSergey Senozhatsky
commit 656d61ce9666209c4c4a13c71902d3ee70d1ff6f upstream. printk_ratelimit() invokes ___ratelimit() which may invoke a normal printk() (pr_warn() in this particular case) to warn about suppressed output. Given that printk_ratelimit() may be called from anywhere, that pr_warn() is dangerous - it may end up deadlocking the system. Fix ___ratelimit() by using deferred printk(). Sasha reported the following lockdep error: : Unregister pv shared memory for cpu 8 : select_fallback_rq: 3 callbacks suppressed : process 8583 (trinity-c78) no longer affine to cpu8 : : ====================================================== : WARNING: possible circular locking dependency detected : 4.14.0-rc2-next-20170927+ #252 Not tainted : ------------------------------------------------------ : migration/8/62 is trying to acquire lock: : (&port_lock_key){-.-.}, at: serial8250_console_write() : : but task is already holding lock: : (&rq->lock){-.-.}, at: sched_cpu_dying() : : which lock already depends on the new lock. : : : the existing dependency chain (in reverse order) is: : : -> #3 (&rq->lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock() : task_fork_fair() : sched_fork() : copy_process.part.31() : _do_fork() : kernel_thread() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #2 (&p->pi_lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : try_to_wake_up() : default_wake_function() : woken_wake_function() : __wake_up_common() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #1 (&tty->write_wait){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #0 (&port_lock_key){-.-.}: : check_prev_add() : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : serial8250_console_write() : univ8250_console_write() : console_unlock() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : cpuhp_invoke_callback() : take_cpu_down() : multi_cpu_stop() : cpu_stopper_thread() : smpboot_thread_fn() : kthread() : ret_from_fork() : : other info that might help us debug this: : : Chain exists of: : &port_lock_key --> &p->pi_lock --> &rq->lock : : Possible unsafe locking scenario: : : CPU0 CPU1 : ---- ---- : lock(&rq->lock); : lock(&p->pi_lock); : lock(&rq->lock); : lock(&port_lock_key); : : *** DEADLOCK *** : : 4 locks held by migration/8/62: : #0: (&p->pi_lock){-.-.}, at: sched_cpu_dying() : #1: (&rq->lock){-.-.}, at: sched_cpu_dying() : #2: (printk_ratelimit_state.lock){....}, at: ___ratelimit() : #3: (console_lock){+.+.}, at: vprintk_emit() : : stack backtrace: : CPU: 8 PID: 62 Comm: migration/8 Not tainted 4.14.0-rc2-next-20170927+ #252 : Call Trace: : dump_stack() : print_circular_bug() : check_prev_add() : ? add_lock_to_list.isra.26() : ? check_usage() : ? kvm_clock_read() : ? kvm_sched_clock_read() : ? sched_clock() : ? check_preemption_disabled() : __lock_acquire() : ? __lock_acquire() : ? add_lock_to_list.isra.26() : ? debug_check_no_locks_freed() : ? memcpy() : lock_acquire() : ? serial8250_console_write() : _raw_spin_lock_irqsave() : ? serial8250_console_write() : serial8250_console_write() : ? serial8250_start_tx() : ? lock_acquire() : ? memcpy() : univ8250_console_write() : console_unlock() : ? __down_trylock_console_sem() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ? show_regs_print_info() : ? lock_acquire() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : ? sched_cpu_starting() : ? rcutree_dying_cpu() : ? sched_cpu_starting() : cpuhp_invoke_callback() : ? cpu_disable_common() : take_cpu_down() : ? trace_hardirqs_off_caller() : ? cpuhp_invoke_callback() : multi_cpu_stop() : ? __this_cpu_preempt_check() : ? cpu_stop_queue_work() : cpu_stopper_thread() : ? cpu_stop_create() : smpboot_thread_fn() : ? sort_range() : ? schedule() : ? __kthread_parkme() : kthread() : ? sort_range() : ? kthread_create_on_node() : ret_from_fork() : process 9121 (trinity-c78) no longer affine to cpu8 : smpboot: CPU 8 is now offline Link: http://lkml.kernel.org/r/20170928120405.18273-1-sergey.senozhatsky@gmail.com Fixes: 6b1d174b0c27b ("ratelimit: extend to print suppressed messages on release") Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Petr Mladek <pmladek@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Borislav Petkov <bp@suse.de> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07lib/mpi: kunmap after finishing accessing bufferStephan Mueller
commit dea3eb8b452e36cf2dd572b0a797915ccf452ae6 upstream. Using sg_miter_start and sg_miter_next, the buffer of an SG is kmap'ed to *buff. The current code calls sg_miter_stop (and thus kunmap) on the SG entry before the last access of *buff. The patch moves the sg_miter_stop call after the last access to *buff to ensure that the memory pointed to by *buff is still mapped. Fixes: 4816c9406430 ("lib/mpi: Fix SG miter leak") Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02lz4: fix bogus gcc warningGreg Kroah-Hartman
When building lz4 under gcc-7 we get the following bogus warning: CC [M] lib/lz4/lz4hc_compress.o lib/lz4/lz4hc_compress.c: In function ‘lz4hc_compress’: lib/lz4/lz4hc_compress.c:179:42: warning: ‘delta’ may be used uninitialized in this function [-Wmaybe-uninitialized] chaintable[(size_t)(ptr) & MAXD_MASK] = delta; ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~ lib/lz4/lz4hc_compress.c:134:6: note: ‘delta’ was declared here u16 delta; ^~~~~ This doesn't show up in the 4.4-stable tree due to us turning off warnings like this. It also doesn't show up in newer kernel versions as this code was totally rewritten. So for now, to get the 4.9-stable tree to build with 0 warnings on x86 allmodconfig, let's just shut the compiler up by initializing the variable to 0, despite it not really doing anything. To be far, this code is crazy complex, so the fact that gcc can't determine if the variable is really used or not isn't that bad, I'd blame the code here instead of the compiler. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11lib/Kconfig.debug: fix frv build failureSudip Mukherjee
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ] The build of frv allmodconfig was failing with the errors like: /tmp/cc0JSPc3.s: Assembler messages: /tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined /tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined /tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined /tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced splitting the debug info and keeping that in a separate file. Somehow, the frv-linux gcc did not like that and I am guessing that instead of splitting it started copying. The first report about this is at: https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html. I will try and see if this can work with frv and if still fails I will open a bug report with gcc. But meanwhile this is the easiest option to solve build failure of frv. Fixes: 866ced950bcd ("kbuild: Support split debug info v4") Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/fair, cpumask: Export for_each_cpu_wrap()Peter Zijlstra
commit c6508a39640b9a27fc2bc10cb708152672c82045 upstream. commit c743f0a5c50f2fcbc628526279cfa24f3dabe182 upstream. More users for for_each_cpu_wrap() have appeared. Promote the construct to generic cpumask interface. The implementation is slightly modified to reduce arguments. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Lauro Ramos Venancio <lvenanci@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: lwang@redhat.com Link: http://lkml.kernel.org/r/20170414122005.o35me2h5nowqkxbv@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05swiotlb: ensure that page-sized mappings are page-alignedNikita Yushchenko
[ Upstream commit 602d9858f07c72eab64f5f00e2fae55f9902cfbe ] Some drivers do depend on page mappings to be page aligned. Swiotlb already enforces such alignment for mappings greater than page, extend that to page-sized mappings as well. Without this fix, nvme hits BUG() in nvme_setup_prps(), because that routine assumes page-aligned mappings. Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29lib/cmdline.c: fix get_options() overflow while parsing rangesIlya Matveychikov
commit a91e0f680bcd9e10c253ae8b62462a38bd48f09f upstream. When using get_options() it's possible to specify a range of numbers, like 1-100500. The problem is that it doesn't track array size while calling internally to get_range() which iterates over the range and fills the memory with numbers. Link: http://lkml.kernel.org/r/2613C75C-B04D-4BFF-82A6-12F97BA0F620@gmail.com Signed-off-by: Ilya V. Matveychikov <matvejchikov@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24crypto: Work around deallocated stack frame reference gcc bug on sparc.David Miller
commit d41519a69b35b10af7fda867fb9100df24fdf403 upstream. On sparc, if we have an alloca() like situation, as is the case with SHASH_DESC_ON_STACK(), we can end up referencing deallocated stack memory. The result can be that the value is clobbered if a trap or interrupt arrives at just the right instruction. It only occurs if the function ends returning a value from that alloca() area and that value can be placed into the return value register using a single instruction. For example, in lib/libcrc32c.c:crc32c() we end up with a return sequence like: return %i7+8 lduw [%o5+16], %o0 ! MEM[(u32 *)__shash_desc.1_10 + 16B], %o5 holds the base of the on-stack area allocated for the shash descriptor. But the return released the stack frame and the register window. So if an intererupt arrives between 'return' and 'lduw', then the value read at %o5+16 can be corrupted. Add a data compiler barrier to work around this problem. This is exactly what the gcc fix will end up doing as well, and it absolutely should not change the code generated for other cpus (unless gcc on them has the same bug :-) With crucial insight from Eric Sandeen. Reported-by: Anatoly Pugachev <matorola@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14usercopy: Adjust tests to deal with SMAP/PANKees Cook
commit f5f893c57e37ca730808cb2eee3820abd05e7507 upstream. Under SMAP/PAN/etc, we cannot write directly to userspace memory, so this rearranges the test bytes to get written through copy_to_user(). Additionally drops the bad copy_from_user() test that would trigger a memcpy() against userspace on failure. [arnd: the test module was added in 3.14, and this backported patch should apply cleanly on all version from 3.14 to 4.10. The original patch was in 4.11 on top of a context change I saw the bug triggered with kselftest on a 4.4.y stable kernel] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14bpf, arm64: fix jit branch offset related to ldimm64Daniel Borkmann
[ Upstream commit ddc665a4bb4b728b4e6ecec8db1b64efa9184b9c ] When the instruction right before the branch destination is a 64 bit load immediate, we currently calculate the wrong jump offset in the ctx->offset[] array as we only account one instruction slot for the 64 bit load immediate although it uses two BPF instructions. Fix it up by setting the offset into the right slot after we incremented the index. Before (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 54ffff82 b.cs 0x00000020 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] After (ldimm64 test 1): [...] 00000020: 52800007 mov w7, #0x0 // #0 00000024: d2800060 mov x0, #0x3 // #3 00000028: d2800041 mov x1, #0x2 // #2 0000002c: eb01001f cmp x0, x1 00000030: 540000a2 b.cs 0x00000044 00000034: d29fffe7 mov x7, #0xffff // #65535 00000038: f2bfffe7 movk x7, #0xffff, lsl #16 0000003c: f2dfffe7 movk x7, #0xffff, lsl #32 00000040: f2ffffe7 movk x7, #0xffff, lsl #48 00000044: d29dddc7 mov x7, #0xeeee // #61166 00000048: f2bdddc7 movk x7, #0xeeee, lsl #16 0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32 00000050: f2fdddc7 movk x7, #0xeeee, lsl #48 [...] Also, add a couple of test cases to make sure JITs pass this test. Tested on Cavium ThunderX ARMv8. The added test cases all pass after the fix. Fixes: 8eee539ddea0 ("arm64: bpf: fix out-of-bounds read in bpf2a64_offset()") Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21new privimitive: iov_iter_revert()Al Viro
commit 27c0e3748e41ca79171ffa3e97415a20af6facd0 upstream. opposite to iov_iter_advance(); the caller is responsible for never using it to move back past the initial position. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08lib/syscall: Clear return values when no stackKees Cook
commit 854fbd6e5f60fe99e8e3a569865409fca378f143 upstream. Commit: aa1f1a639621 ("lib/syscall: Pin the task stack in collect_syscall()") ... added logic to handle a process stack not existing, but left sp and pc uninitialized, which can be later reported via /proc/$pid/syscall for zombie processes, potentially exposing kernel memory to userspace. Zombie /proc/$pid/syscall before: -1 0xffffffff9a060100 0xffff92f42d6ad900 Zombie /proc/$pid/syscall after: -1 0x0 0x0 Reported-by: Robert Święcki <robert@swiecki.net> Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: aa1f1a639621 ("lib/syscall: Pin the task stack in collect_syscall()") Link: http://lkml.kernel.org/r/20170323224616.GA92694@beast Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26swiotlb: Add swiotlb=noforce debug optionGeert Uytterhoeven
commit fff5d99225107f5f13fe4a9805adc2a1c4b5fb00 upstream. On architectures like arm64, swiotlb is tied intimately to the core architecture DMA support. In addition, ZONE_DMA cannot be disabled. To aid debugging and catch devices not supporting DMA to memory outside the 32-bit address space, add a kernel command line option "swiotlb=noforce", which disables the use of bounce buffers. If specified, trying to map memory that cannot be used with DMA will fail, and a rate-limited warning will be printed. Note that io_tlb_nslabs is set to 1, which is the minimal supported value. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26swiotlb: Convert swiotlb_force from int to enumGeert Uytterhoeven
commit ae7871be189cb41184f1e05742b4a99e2c59774d upstream. Convert the flag swiotlb_force from an int to an enum, to prepare for the advent of more possible values. Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19fix a fencepost error in pipe_advance()Al Viro
commit b9dc6f65bc5e232d1c05fe34b5daadc7e8bbf1fb upstream. The logics in pipe_advance() used to release all buffers past the new position failed in cases when the number of buffers to release was equal to pipe->buffers. If that happened, none of them had been released, leaving pipe full. Worse, it was trivial to trigger and we end up with pipe full of uninitialized pages. IOW, it's an infoleak. Reported-by: "Alan J. Wylie" <alan@wylie.me.uk> Tested-by: "Alan J. Wylie" <alan@wylie.me.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-09Revert "radix tree test suite: fix compilation"Linus Torvalds
This reverts commit 53855d10f4567a0577360b6448d52a863929775b. It shouldn't have come in yet - it depends on the changes in linux-next that will come in during the next merge window. As Matthew Wilcox says, the test suite is broken with the current state without the revert. Requested-by: Matthew Wilcox <mawilcox@microsoft.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-07radix tree test suite: fix compilationMatthew Wilcox
Patch "lib/radix-tree: Convert to hotplug state machine" breaks the test suite as it adds a call to cpuhp_setup_state_nocalls() which is not currently emulated in the test suite. Add it, and delete the emulation of the old CPU hotplug mechanism. Link: http://lkml.kernel.org/r/1480369871-5271-36-git-send-email-mawilcox@linuxonhyperv.com Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-07Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two rtmutex race fixes (which miraculously never triggered, that we know of), plus two lockdep printk formatting regression fixes" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: lockdep: Fix report formatting locking/rtmutex: Use READ_ONCE() in rt_mutex_owner() locking/rtmutex: Prevent dequeue vs. unlock race locking/selftest: Fix output since KERN_CONT changes
2016-11-30kasan: support use-after-scope detectionDmitry Vyukov
Gcc revision 241896 implements use-after-scope detection. Will be available in gcc 7. Support it in KASAN. Gcc emits 2 new callbacks to poison/unpoison large stack objects when they go in/out of scope. Implement the callbacks and add a test. [dvyukov@google.com: v3] Link: http://lkml.kernel.org/r/1479998292-144502-1-git-send-email-dvyukov@google.com Link: http://lkml.kernel.org/r/1479226045-145148-1-git-send-email-dvyukov@google.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-30lib/debugobjects: export for use in modulesChris Wilson
Drivers, or other modules, that use a mixture of objects (especially objects embedded within other objects) would like to take advantage of the debugobjects facilities to help catch misuse. Currently, the debugobjects interface is only available to builtin drivers and requires a set of EXPORT_SYMBOL_GPL for use by modules. I am using the debugobjects in i915.ko to try and catch some invalid operations on embedded objects. The problem currently only presents itself across module unload so forcing i915 to be builtin is not an option. Link: http://lkml.kernel.org/r/20161122143039.6433-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: "Du, Changbin" <changbin.du@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-11-25locking/selftest: Fix output since KERN_CONT changesMichael Ellerman
Since the KERN_CONT changes the locking-selftest output is messed up, eg: ---------------------------------------------------------------------------- | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------------------------------------------------- A-A deadlock: ok | ok | ok | ok | ok | ok | Use pr_cont() to get it looking normal again: ---------------------------------------------------------------------------- | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------------------------------------------------- A-A deadlock: ok | ok | ok | ok | ok | ok | Reported-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linuxppc-dev@ozlabs.org Link: http://lkml.kernel.org/r/1480027528-934-1-git-send-email-mpe@ellerman.id.au Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-11-25mpi: Fix NULL ptr dereference in mpi_powm() [ver #3]Andrey Ryabinin
This fixes CVE-2016-8650. If mpi_powm() is given a zero exponent, it wants to immediately return either 1 or 0, depending on the modulus. However, if the result was initalised with zero limb space, no limbs space is allocated and a NULL-pointer exception ensues. Fix this by allocating a minimal amount of limb space for the result when the 0-exponent case when the result is 1 and not touching the limb space when the result is 0. This affects the use of RSA keys and X.509 certificates that carry them. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 PGD 0 Oops: 0002 [#1] SMP Modules linked in: CPU: 3 PID: 3014 Comm: keyctl Not tainted 4.9.0-rc6-fscache+ #278 Hardware name: ASUS All Series/H97-PLUS, BIOS 2306 10/09/2014 task: ffff8804011944c0 task.stack: ffff880401294000 RIP: 0010:[<ffffffff8138ce5d>] [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 RSP: 0018:ffff880401297ad8 EFLAGS: 00010212 RAX: 0000000000000000 RBX: ffff88040868bec0 RCX: ffff88040868bba0 RDX: ffff88040868b260 RSI: ffff88040868bec0 RDI: ffff88040868bee0 RBP: ffff880401297ba8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000047 R11: ffffffff8183b210 R12: 0000000000000000 R13: ffff8804087c7600 R14: 000000000000001f R15: ffff880401297c50 FS: 00007f7a7918c700(0000) GS:ffff88041fb80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000401250000 CR4: 00000000001406e0 Stack: ffff88040868bec0 0000000000000020 ffff880401297b00 ffffffff81376cd4 0000000000000100 ffff880401297b10 ffffffff81376d12 ffff880401297b30 ffffffff81376f37 0000000000000100 0000000000000000 ffff880401297ba8 Call Trace: [<ffffffff81376cd4>] ? __sg_page_iter_next+0x43/0x66 [<ffffffff81376d12>] ? sg_miter_get_next_page+0x1b/0x5d [<ffffffff81376f37>] ? sg_miter_next+0x17/0xbd [<ffffffff8138ba3a>] ? mpi_read_raw_from_sgl+0xf2/0x146 [<ffffffff8132a95c>] rsa_verify+0x9d/0xee [<ffffffff8132acca>] ? pkcs1pad_sg_set_buf+0x2e/0xbb [<ffffffff8132af40>] pkcs1pad_verify+0xc0/0xe1 [<ffffffff8133cb5e>] public_key_verify_signature+0x1b0/0x228 [<ffffffff8133d974>] x509_check_for_self_signed+0xa1/0xc4 [<ffffffff8133cdde>] x509_cert_parse+0x167/0x1a1 [<ffffffff8133d609>] x509_key_preparse+0x21/0x1a1 [<ffffffff8133c3d7>] asymmetric_key_preparse+0x34/0x61 [<ffffffff812fc9f3>] key_create_or_update+0x145/0x399 [<ffffffff812fe227>] SyS_add_key+0x154/0x19e [<ffffffff81001c2b>] do_syscall_64+0x80/0x191 [<ffffffff816825e4>] entry_SYSCALL64_slow_path+0x25/0x25 Code: 56 41 55 41 54 53 48 81 ec a8 00 00 00 44 8b 71 04 8b 42 04 4c 8b 67 18 45 85 f6 89 45 80 0f 84 b4 06 00 00 85 c0 75 2f 41 ff ce <49> c7 04 24 01 00 00 00 b0 01 75 0b 48 8b 41 18 48 83 38 01 0f RIP [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6 RSP <ffff880401297ad8> CR2: 0000000000000000 ---[ end trace d82015255d4a5d8d ]--- Basically, this is a backport of a libgcrypt patch: http://git.gnupg.org/cgi-bin/gitweb.cgi?p=libgcrypt.git;a=patch;h=6e1adb05d290aeeb1c230c763970695f4a538526 Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files (part 1)") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> cc: linux-ima-devel@lists.sourceforge.net cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) With modern networking cards we can run out of 32-bit DMA space, so support 64-bit DMA addressing when possible on sparc64. From Dave Tushar. 2) Some signal frame validation checks are inverted on sparc32, fix from Andreas Larsson. 3) Lockdep tables can get too large in some circumstances on sparc64, add a way to adjust the size a bit. From Babu Moger. 4) Fix NUMA node probing on some sun4v systems, from Thomas Tai. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: drop duplicate header scatterlist.h lockdep: Limit static allocations if PROVE_LOCKING_SMALL is defined config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparc sunbmac: Fix compiler warning sunqe: Fix compiler warnings sparc64: Enable 64-bit DMA sparc64: Enable sun4v dma ops to use IOMMU v2 APIs sparc64: Bind PCIe devices to use IOMMU v2 service sparc64: Initialize iommu_map_table and iommu_pool sparc64: Add ATU (new IOMMU) support sparc64: Add FORCE_MAX_ZONEORDER and default to 13 sparc64: fix compile warning section mismatch in find_node() sparc32: Fix inverted invalid_frame_pointer checks on sigreturns sparc64: Fix find_node warning if numa node cannot be found
2016-11-18config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparcBabu Moger
This new config parameter limits the space used for "Lock debugging: prove locking correctness" by about 4MB. The current sparc systems have the limitation of 32MB size for kernel size including .text, .data and .bss sections. With PROVE_LOCKING feature, the kernel size could grow beyond this limit and causing system boot-up issues. With this option, kernel limits the size of the entries of lock_chains, stack_trace etc., so that kernel fits in required size limit. This is not visible to user and only used for sparc. Signed-off-by: Babu Moger <babu.moger@oracle.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-17fix iov_iter_advance() for ITER_PIPEAbhi Das
iov_iter_advance() needs to decrement iter->count by the number of bytes we'd moved beyond. Normal flavours do that, but ITER_PIPE doesn't and ITER_PIPE generic_file_read_iter() for O_DIRECT files ends up with a bogus fallback to page cache read, resulting in incorrect values for file offset and bytes read. Signed-off-by: Abhi Das <adas@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-11-11lib/stackdepot: export save/fetch stack for driversChris Wilson
Some drivers would like to record stacktraces in order to aide leak tracing. As stackdepot already provides a facility for only storing the unique traces, thereby reducing the memory required, export that functionality for use by drivers. The code was originally created for KASAN and moved under lib in commit cd11016e5f521 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB") so that it could be shared with mm/. In turn, we want to share it now with drivers. Link: http://lkml.kernel.org/r/20161108133209.22704-1-chris@chris-wilson.co.uk Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Lots of fixes, mostly drivers as is usually the case. 1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey Khoroshilov. 2) Fix element timeouts in netfilter's nft_dynset, from Anders K. Pedersen. 3) Don't put aead_req crypto struct on the stack in mac80211, from Ard Biesheuvel. 4) Several uninitialized variable warning fixes from Arnd Bergmann. 5) Fix memory leak in cxgb4, from Colin Ian King. 6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann. 7) Several VRF semantic fixes from David Ahern. 8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper. 9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet. 10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev. 11) Fix stale link state during failover in NCSCI driver, from Gavin Shan. 12) Fix netdev lower adjacency list traversal, from Ido Schimmel. 13) Propvide proper handle when emitting notifications of filter deletes, from Jamal Hadi Salim. 14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen. 15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac. 16) Several routing offload fixes in mlxsw driver, from Jiri Pirko. 17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy. 18) Validate chunk len before using it in SCTP, from Marcelo Ricardo Leitner. 19) Revert a netns locking change that causes regressions, from Paul Moore. 20) Add recursion limit to GRO handling, from Sabrina Dubroca. 21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon. 22) Avoid accessing stale vxlan/geneve socket in data path, from Pravin Shelar" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits) geneve: avoid using stale geneve socket. vxlan: avoid using stale vxlan socket. qede: Fix out-of-bound fastpath memory access net: phy: dp83848: add dp83822 PHY support enic: fix rq disable tipc: fix broadcast link synchronization problem ibmvnic: Fix missing brackets in init_sub_crq_irqs ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context" arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold net/mlx4_en: Save slave ethtool stats command net/mlx4_en: Fix potential deadlock in port statistics flow net/mlx4: Fix firmware command timeout during interrupt test net/mlx4_core: Do not access comm channel if it has not yet been initialized net/mlx4_en: Fix panic during reboot net/mlx4_en: Process all completions in RX rings after port goes up net/mlx4_en: Resolve dividing by zero in 32-bit system net/mlx4_core: Change the default value of enable_qos net/mlx4_core: Avoid setting ports to auto when only one port type is supported net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec ...
2016-10-27lib/genalloc.c: start search from start of chunkDaniel Mentz
gen_pool_alloc_algo() iterates over the chunks of a pool trying to find a contiguous block of memory that satisfies the allocation request. The shortcut if (size > atomic_read(&chunk->avail)) continue; makes the loop skip over chunks that do not have enough bytes left to fulfill the request. There are two situations, though, where an allocation might still fail: (1) The available memory is not contiguous, i.e. the request cannot be fulfilled due to external fragmentation. (2) A race condition. Another thread runs the same code concurrently and is quicker to grab the available memory. In those situations, the loop calls pool->algo() to search the entire chunk, and pool->algo() returns some value that is >= end_bit to indicate that the search failed. This return value is then assigned to start_bit. The variables start_bit and end_bit describe the range that should be searched, and this range should be reset for every chunk that is searched. Today, the code fails to reset start_bit to 0. As a result, prefixes of subsequent chunks are ignored. Memory allocations might fail even though there is plenty of room left in these prefixes of those other chunks. Fixes: 7f184275aa30 ("lib, Make gen_pool memory allocator lockless") Link: http://lkml.kernel.org/r/1477420604-28918-1-git-send-email-danielmentz@google.com Signed-off-by: Daniel Mentz <danielmentz@google.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-27lib/stackdepot.c: bump stackdepot capacity from 16MB to 128MBDmitry Vyukov
KASAN uses stackdepot to memorize stacks for all kmalloc/kfree calls. Current stackdepot capacity is 16MB (1024 top level entries x 4 pages on second level). Size of each stack is (num_frames + 3) * sizeof(long). Which gives us ~84K stacks. This capacity was chosen empirically and it is enough to run kernel normally. However, when lots of configs are enabled and a fuzzer tries to maximize code coverage, it easily hits the limit within tens of minutes. I've tested for long a time with number of top level entries bumped 4x (4096). And I think I've seen overflow only once. But I don't have all configs enabled and code coverage has not reached maximum yet. So bump it 8x to 8192. Since we have two-level table, memory cost of this is very moderate -- currently the top-level table is 8KB, with this patch it is 64KB, which is negligible under KASAN. Here is some approx math. 128MB allows us to memorize ~670K stacks (assuming stack is ~200b). I've grepped kernel for kmalloc|kfree|kmem_cache_alloc|kmem_cache_free| kzalloc|kstrdup|kstrndup|kmemdup and it gives ~60K matches. Most of alloc/free call sites are reachable with only one stack. But some utility functions can have large fanout. Assuming average fanout is 5x, total number of alloc/free stacks is ~300K. Link: http://lkml.kernel.org/r/1476458416-122131-1-git-send-email-dvyukov@google.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Baozeng Ding <sploving1@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-27latent_entropy: raise CONFIG_FRAME_WARN by defaultKees Cook
When building with the latent_entropy plugin, set the default CONFIG_FRAME_WARN to 2048, since some __init functions have many basic blocks that, when instrumented by the latent_entropy plugin, grow beyond 1024 byte stack size on 32-bit builds. Link: http://lkml.kernel.org/r/20161018211216.GA39687@beast Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Emese Revfy <re.emese@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michal Marek <mmarek@suse.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Shuah Khan <shuah@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-20bpf, test: fix ld_abs + vlan push/pop stress testDaniel Borkmann
After commit 636c2628086e ("net: skbuff: Remove errornous length validation in skb_vlan_pop()") mentioned test case stopped working, throwing a -12 (ENOMEM) return code. The issue however is not due to 636c2628086e, but rather due to a buggy test case that got uncovered from the change in behaviour in 636c2628086e. The data_size of that test case for the skb was set to 1. In the bpf_fill_ld_abs_vlan_push_pop() handler bpf insns are generated that loop with: reading skb data, pushing 68 tags, reading skb data, popping 68 tags, reading skb data, etc, in order to force a skb expansion and thus trigger that JITs recache skb->data. Problem is that initial data_size is too small. While before 636c2628086e, the test silently bailed out due to the skb->len < VLAN_ETH_HLEN check with returning 0, and now throwing an error from failing skb_ensure_writable(). Set at least minimum of ETH_HLEN as an initial length so that on first push of data, equivalent pop will succeed. Fixes: 4d9c5c53ac99 ("test_bpf: add bpf_skb_vlan_push/pop() tests") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-15Merge tag 'gcc-plugins-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull gcc plugins update from Kees Cook: "This adds a new gcc plugin named "latent_entropy". It is designed to extract as much possible uncertainty from a running system at boot time as possible, hoping to capitalize on any possible variation in CPU operation (due to runtime data differences, hardware differences, SMP ordering, thermal timing variation, cache behavior, etc). At the very least, this plugin is a much more comprehensive example for how to manipulate kernel code using the gcc plugin internals" * tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: latent_entropy: Mark functions with __latent_entropy gcc-plugins: Add latent_entropy plugin
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more misc uaccess and vfs updates from Al Viro: "The rest of the stuff from -next (more uaccess work) + assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: score: traps: Add missing include file to fix build error fs/super.c: don't fool lockdep in freeze_super() and thaw_super() paths fs/super.c: fix race between freeze_super() and thaw_super() overlayfs: Fix setting IOP_XATTR flag iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector() blackfin: no access_ok() for __copy_{to,from}_user() arm64: don't zero in __copy_from_user{,_inatomic} arm: don't zero in __copy_from_user_inatomic()/__copy_from_user() arc: don't leak bits of kernel stack into coredump alpha: get rid of tail-zeroing in __copy_user()
2016-10-14iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector()Vegard Nossum
Both import_iovec() and rw_copy_check_uvector() take an array (typically small and on-stack) which is used to hold an iovec array copy from userspace. This is to avoid an expensive memory allocation in the fast path (i.e. few iovec elements). The caller may have to check whether these functions actually used the provided buffer or allocated a new one -- but this differs between the too. Let's just add a kernel doc to clarify what the semantics are for each function. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-14Merge branch 'for-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: - Nick improved generic implementations of percpu operations which modify the variable and return so that they calculate the physical address only once. - percpu_ref percpu <-> atomic mode switching improvements. The patchset was originally posted about a year ago but fell through the crack. - misc non-critical fixes. * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: mm/percpu.c: fix potential memory leakage for pcpu_embed_first_chunk() mm/percpu.c: correct max_distance calculation for pcpu_embed_first_chunk() percpu: eliminate two sparse warnings percpu: improve generic percpu modify-return implementation percpu-refcount: init ->confirm_switch member properly percpu_ref: allow operation mode switching operations to be called concurrently percpu_ref: restructure operation mode switching percpu_ref: unify staggered atomic switching wait behavior percpu_ref: reorganize __percpu_ref_switch_to_atomic() and relocate percpu_ref_switch_to_atomic() percpu_ref: remove unnecessary RCU grace period for staggered atomic switching confirmation
2016-10-11kcov: do not instrument lib/stackdepot.cAlexander Potapenko
There's no point in collecting coverage from lib/stackdepot.c, as it is not a function of syscall inputs. Disabling kcov instrumentation for that file will reduce the coverage noise level. Link: http://lkml.kernel.org/r/1474640972-104131-1-git-send-email-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Dmitry Vyukov <dvyukov@google.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: syzkaller <syzkaller@googlegroups.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11lib/bitmap.c: enhance bitmap syntaxNoam Camus
Today there are platforms with many CPUs (up to 4K). Trying to boot only part of the CPUs may result in too long string. For example lets take NPS platform that is part of arch/arc. This platform have SMP system with 256 cores each with 16 HW threads (SMT machine) where HW thread appears as CPU to the kernel. In this example there is total of 4K CPUs. When one tries to boot only part of the HW threads from each core the string representing the map may be long... For example if for sake of performance we decided to boot only first half of HW threads of each core the map will look like: 0-7,16-23,32-39,...,4080-4087 This patch introduce new syntax to accommodate with such use case. I added an optional postfix to a range of CPUs which will choose according to given modulo the desired range of reminders i.e.: <cpus range>:sed_size/group_size For example, above map can be described in new syntax like this: 0-4095:8/16 Note that this patch is backward compatible with current syntax. [akpm@linux-foundation.org: rework documentation] Link: http://lkml.kernel.org/r/1473579629-4283-1-git-send-email-noamca@mellanox.com Signed-off-by: Noam Camus <noamca@mellanox.com> Cc: David Decotigny <decot@googlers.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: David S. Miller <davem@davemloft.net> Cc: Pan Xinhui <xinhui@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11lib/kstrtox.c: smaller _parse_integer()Alexey Dobriyan
Set "overflow" bit upon encountering it instead of postponing to the end of the conversion. Somehow gcc unwedges itself and generates better code: $ ./scripts/bloat-o-meter ../vmlinux-000 ../obj/vmlinux _parse_integer 177 139 -38 Inspired by patch from Zhaoxiu Zeng. Link: http://lkml.kernel.org/r/20160826221920.GA1909@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11lib: harden strncpy_from_userMark Rutland
The strncpy_from_user() accessor is effectively a copy_from_user() specialised to copy strings, terminating early at a NUL byte if possible. In other respects it is identical, and can be used to copy an arbitrarily large buffer from userspace into the kernel. Conceptually, it exposes a similar attack surface. As with copy_from_user(), we check the destination range when the kernel is built with KASAN, but unlike copy_from_user() we do not check the destination buffer when using HARDENED_USERCOPY. As strncpy_from_user() calls get_user() in a loop, we must call check_object_size() explicitly. This patch adds this instrumentation to strncpy_from_user(), per the same rationale as with the regular copy_from_user(). In the absence of hardened usercopy this will have no impact as the instrumentation expands to an empty static inline function. Link: http://lkml.kernel.org/r/1472221903-31181-1-git-send-email-mark.rutland@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11Fix off-by-one in __pipe_get_pages()Al Viro
it actually worked only when requested area ended on the page boundary... Reported-by: Marco Grassi <marco.gra@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10latent_entropy: Mark functions with __latent_entropyEmese Revfy
The __latent_entropy gcc attribute can be used only on functions and variables. If it is on a function then the plugin will instrument it for gathering control-flow entropy. If the attribute is on a variable then the plugin will initialize it with random contents. The variable must be an integer, an integer array type or a structure with integer fields. These specific functions have been selected because they are init functions (to help gather boot-time entropy), are called at unpredictable times, or they have variable loops, each of which provide some level of latent entropy. Signed-off-by: Emese Revfy <re.emese@gmail.com> [kees: expanded commit message] Signed-off-by: Kees Cook <keescook@chromium.org>
2016-10-10Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted misc bits and pieces. There are several single-topic branches left after this (rename2 series from Miklos, current_time series from Deepa Dinamani, xattr series from Andreas, uaccess stuff from from me) and I'd prefer to send those separately" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits) proc: switch auxv to use of __mem_open() hpfs: support FIEMAP cifs: get rid of unused arguments of CIFSSMBWrite() posix_acl: uapi header split posix_acl: xattr representation cleanups fs/aio.c: eliminate redundant loads in put_aio_ring_file fs/internal.h: add const to ns_dentry_operations declaration compat: remove compat_printk() fs/buffer.c: make __getblk_slow() static proc: unsigned file descriptors fs/file: more unsigned file descriptors fs: compat: remove redundant check of nr_segs cachefiles: Fix attempt to read i_blocks after deleting file [ver #2] cifs: don't use memcpy() to copy struct iov_iter get rid of separate multipage fault-in primitives fs: Avoid premature clearing of capabilities fs: Give dentry to inode_change_ok() instead of inode fuse: Propagate dentry down to inode_change_ok() ceph: Propagate dentry down to inode_change_ok() xfs: Propagate dentry down to inode_change_ok() ...
2016-10-10samples: move blackfin gptimers-example from DocumentationShuah Khan
Move blackfin gptimers-example to samples and remove it from Documentation Makefile. Update samples Kconfig and Makefile to build gptimers-example. blackfin is the last CONFIG_BUILD_DOCSRC target in Documentation/Makefile. Hence this patch also includes changes to remove CONFIG_BUILD_DOCSRC from Makefile and lib/Kconfig.debug and updates VIDEO_PCI_SKELETON dependency on BUILD_DOCSRC. Documentation/Makefile is not deleted to avoid braking make htmldocs and make distclean. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Reported-by: Valentin Rothberg <valentinrothberg@gmail.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: - fsnotify updates - ocfs2 updates - all of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (127 commits) console: don't prefer first registered if DT specifies stdout-path cred: simpler, 1D supplementary groups CREDITS: update Pavel's information, add GPG key, remove snail mail address mailmap: add Johan Hovold .gitattributes: set git diff driver for C source code files uprobes: remove function declarations from arch/{mips,s390} spelling.txt: "modeled" is spelt correctly nmi_backtrace: generate one-line reports for idle cpus arch/tile: adopt the new nmi_backtrace framework nmi_backtrace: do a local dump_stack() instead of a self-NMI nmi_backtrace: add more trigger_*_cpu_backtrace() methods min/max: remove sparse warnings when they're nested Documentation/filesystems/proc.txt: add more description for maps/smaps mm, proc: fix region lost in /proc/self/smaps proc: fix timerslack_ns CAP_SYS_NICE check when adjusting self proc: add LSM hook checks to /proc/<tid>/timerslack_ns proc: relax /proc/<tid>/timerslack_ns capability requirements meminfo: break apart a very long seq_printf with #ifdefs seq/proc: modify seq_put_decimal_[u]ll to take a const char *, not char proc: faster /proc/*/status ...
