commit e0a94c2a63f2644826069044649669b5e7ca75d3 upstream.
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY.
It also sets a default mmap_min_addr of 4096.
mmapping of addresses below 4096 will only be possible for processes
with CAP_SYS_RAWIO.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Eric Paris <eparis@redhat.com>
Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: James Morris <jmorris@namei.org>
Out of line get_user_pages_fast fallback implementation, make it a weak
symbol, get rid of CONFIG_HAVE_GET_USER_PAGES_FAST.
Export the symbol to modules so lguest can use it.
Signed-off-by: Nick Piggin <npiggin@suse.de>
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages.
There are secondary MMUs (with secondary sptes and secondary tlbs) too.
sptes in the kvm case are shadow pagetables, but when I say spte in
mmu-notifier context, I mean "secondary pte". In GRU case there's no
actual secondary pte and there's only a secondary tlb because the GRU
secondary MMU has no knowledge about sptes and every secondary tlb miss
event in the MMU always generates a page fault that has to be resolved by
the CPU (this is not the case of KVM where the a secondary tlb miss will
walk sptes in hardware and it will refill the secondary tlb transparently
to software if the corresponding spte is present). The same way
zap_page_range has to invalidate the pte before freeing the page, the spte
(and secondary tlb) must also be invalidated before any page is freed and
reused.
Currently we take a page_count pin on every page mapped by sptes, but that
means the pages can't be swapped whenever they're mapped by any spte
because they're part of the guest working set. Furthermore a spte unmap
event can immediately lead to a page to be freed when the pin is released
(so requiring the same complex and relatively slow tlb_gather smp safe
logic we have in zap_page_range and that can be avoided completely if the
spte unmap event doesn't require an unpin of the page previously mapped in
the secondary MMU).
The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know
when the VM is swapping or freeing or doing anything on the primary MMU so
that the secondary MMU code can drop sptes before the pages are freed,
avoiding all page pinning and allowing 100% reliable swapping of guest
physical address space. Furthermore it avoids the code that teardown the
mappings of the secondary MMU, to implement a logic like tlb_gather in
zap_page_range that would require many IPI to flush other cpu tlbs, for
each fixed number of spte unmapped.
To make an example: if what happens on the primary MMU is a protection
downgrade (from writeable to wrprotect) the secondary MMU mappings will be
invalidated, and the next secondary-mmu-page-fault will call
get_user_pages and trigger a do_wp_page through get_user_pages if it
called get_user_pages with write=1, and it'll re-establishing an updated
spte or secondary-tlb-mapping on the copied page. Or it will setup a
readonly spte or readonly tlb mapping if it's a guest-read, if it calls
get_user_pages with write=0. This is just an example.
This allows to map any page pointed by any pte (and in turn visible in the
primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an
full MMU with both sptes and secondary-tlb like the shadow-pagetable layer
with kvm), or a remote DMA in software like XPMEM (hence needing of
schedule in XPMEM code to send the invalidate to the remote node, while no
need to schedule in kvm/gru as it's an immediate event like invalidating
primary-mmu pte).
At least for KVM without this patch it's impossible to swap guests
reliably. And having this feature and removing the page pin allows
several other optimizations that simplify life considerably.
Dependencies:
1) mm_take_all_locks() to register the mmu notifier when the whole VM
isn't doing anything with "mm". This allows mmu notifier users to keep
track if the VM is in the middle of the invalidate_range_begin/end
critical section with an atomic counter incraese in range_begin and
decreased in range_end. No secondary MMU page fault is allowed to map
any spte or secondary tlb reference, while the VM is in the middle of
range_begin/end as any page returned by get_user_pages in that critical
section could later immediately be freed without any further
->invalidate_page notification (invalidate_range_begin/end works on
ranges and ->invalidate_page isn't called immediately before freeing
the page). To stop all page freeing and pagetable overwrites the
mmap_sem must be taken in write mode and all other anon_vma/i_mmap
locks must be taken too.
2) It'd be a waste to add branches in the VM if nobody could possibly
run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if
CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of
mmu notifiers, but this already allows to compile a KVM external module
against a kernel with mmu notifiers enabled and from the next pull from
kvm.git we'll start using them. And GRU/XPMEM will also be able to
continue the development by enabling KVM=m in their config, until they
submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can
also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n).
This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM
are all =n.
The mmu_notifier_register call can fail because mm_take_all_locks may be
interrupted by a signal and return -EINTR. Because mmu_notifier_reigster
is used when a driver startup, a failure can be gracefully handled. Here
an example of the change applied to kvm to register the mmu notifiers.
Usually when a driver startups other allocations are required anyway and
-ENOMEM failure paths exists already.
struct kvm *kvm_arch_create_vm(void)
struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL);
+ int err;
if (!kvm)
return ERR_PTR(-ENOMEM);
INIT_LIST_HEAD(&kvm->arch.active_mmu_pages);
+ kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops;
+ err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm);
+ if (err) {
+ kfree(kvm);
+ return ERR_PTR(err);
return kvm;
mmu_notifier_unregister returns void and it's reliable.
The patch also adds a few needed but missing includes that would prevent
kernel to compile after these changes on non-x86 archs (x86 didn't need
them by luck).
[akpm@linux-foundation.org: fix mm/filemap_xip.c build]
[akpm@linux-foundation.org: fix mm/mmu_notifier.c build]
Signed-off-by: Andrea Arcangeli <andrea@qumranet.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Kanoj Sarcar <kanojsarcar@yahoo.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Steve Wise <swise@opengridcomputing.com>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Anthony Liguori <aliguori@us.ibm.com>
Cc: Chris Wright <chrisw@redhat.com>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Cc: Eric Dumazet <dada1@cosmosbay.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Izik Eidus <izike@qumranet.com>
Implement get_user_pages_fast without locking in the fastpath on x86.
Do an optimistic lockless pagetable walk, without taking mmap_sem or any
page table locks or even mmap_sem. Page table existence is guaranteed by
turning interrupts off (combined with the fact that we're always looking
up the current mm, means we can do the lockless page table walk within the
constraints of the TLB shootdown design). Basically we can do this
lockless pagetable walk in a similar manner to the way the CPU's pagetable
walker does not have to take any locks to find present ptes.
This patch (combined with the subsequent ones to convert direct IO to use
it) was found to give about 10% performance improvement on a 2 socket 8
core Intel Xeon system running an OLTP workload on DB2 v9.5
"To test the effects of the patch, an OLTP workload was run on an IBM
x3850 M2 server with 2 processors (quad-core Intel Xeon processors at
2.93 GHz) using IBM DB2 v9.5 running Linux 2.6.24rc7 kernel. Comparing
runs with and without the patch resulted in an overall performance
benefit of ~9.8%. Correspondingly, oprofiles showed that samples from
__up_read and __down_read routines that is seen during thread contention
for system resources was reduced from 2.8% down to .05%. Monitoring the
/proc/vmstat output from the patched run showed that the counter for
fast_gup contained a very high number while the fast_gup_slow value was
zero."
(fast_gup is the old name for get_user_pages_fast, fast_gup_slow is a
counter we had for the number of times the slowpath was invoked).
The main reason for the improvement is that DB2 has multiple threads each
issuing direct-IO. Direct-IO uses get_user_pages, and thus the threads
contend the mmap_sem cacheline, and can also contend on page table locks.
I would anticipate larger performance gains on larger systems, however I
think DB2 uses an adaptive mix of threads and processes, so it could be
that thread contention remains pretty constant as machine size increases.
In which case, we stuck with "only" a 10% gain.
The downside of using get_user_pages_fast is that if there is not a pte
with the correct permissions for the access, we end up falling back to
get_user_pages and so the get_user_pages_fast is a bit of extra work.
However this should not be the common case in most performance critical
code.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: Kconfig fix]
[akpm@linux-foundation.org: Makefile fix/cleanup]
[akpm@linux-foundation.org: warning fix]
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
We'd like to support CONFIG_MEMORY_HOTREMOVE on s390, which depends on
CONFIG_MIGRATION. So far, CONFIG_MIGRATION is only available with NUMA
support.
This patch makes CONFIG_MIGRATION selectable for architectures that define
ARCH_ENABLE_MEMORY_HOTREMOVE. When MIGRATION is enabled w/o NUMA, the
kernel won't compile because migrate_vmas() does not know about
vm_ops->migrate() and vma_migratable() does not know about policy_zone.
To fix this, those two functions can be restricted to '#ifdef CONFIG_NUMA'
because they are not being used w/o NUMA. vma_migratable() is moved over
from migrate.h to mempolicy.h.
[kosaki.motohiro@jp.fujitsu.com: build fix]
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Signed-off-by: KOSAKI Motorhiro <kosaki.motohiro@jp.fujitsu.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: (31 commits)
avr32: Fix typo of IFSR in a comment in the PIO header file
avr32: Power Management support ("standby" and "mem" modes)
avr32: Add system device for the internal interrupt controller (intc)
avr32: Add simple SRAM allocator
avr32: Enable SDRAMC clock at startup
rtc-at32ap700x: Enable wakeup
macb: Basic suspend/resume support
atmel_serial: Drain console TX shifter before suspending
atmel_serial: Fix build on avr32 with CONFIG_PM enabled
avr32: Use a quicklist for PTE allocation as well
avr32: Use a quicklist for PGD allocation
avr32: Cover the kernel page tables in the user PGDs
avr32: Store virtual addresses in the PGD
avr32: Remove useless zeroing of swapper_pg_dir at startup
avr32: Clean up and optimize the TLB operations
avr32: Rename at32ap.c -> pdc.c
avr32: Move setup_platform() into chip-specific file
avr32: Kill special exception handler sections
avr32: Kill unneeded #include <asm/pgalloc.h> from asm/mmu_context.h
avr32: Clean up time.c #includes
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Using a quicklist to allocate PTEs might be slightly faster than using
the page allocator directly since we might avoid zeroing the page
after each allocation.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Having separate page flags for the head and the tail of a compound page allows
the compiler to use bitops instead of operations on a word to check for a tail
page. That is f.e. important for virt_to_head_page() which is used in
various critical code paths (kfree for example):
Code for PageTail(page)
Before:
mov (%rdi),%rdx page->flags
mov %rdx,%rax 3 bytes
and $0x12000,%eax 5 bytes
cmp $0x12000,%rax 6 bytes
je 897 <kfree+0xa7>
After:
mov (%rdi),%rax
test $0x40,%ah (3 bytes)
jne 887 <kfree+0x97>
So we go from 14 bytes to 3 bytes and from 3 instructions to one. From the
use of 2 registers we go to none.
We can only use page flags for this if we have page flags available. This
patch introduces CONFIG_PAGEFLAGS_EXTENDED that is set if pageflags are not
scarce due to SPARSEMEM using page flags for its sectionid on 32 bit NUMA
platforms.
Additional page flag definitions can be added to the CONFIG_PAGEFLAGS_EXTENDED
section in page-flags.h if the functionality depends on PAGEFLAGS_EXTENDED or
if more page flag overlapping tricks are used for the !PAGEFLAGS_EXTENDED
fallback (the upcoming virtual compound patch may hook in here and Rik's/Lee's
additional page flags to solve the reclaim issues could also be added there
[hint... hint... where are these patchsets?]).
Avoiding the overlaying of Pg_reclaim also clears the way for possible use of
compound pages for the pagecache or on the LRU.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Sync up with the SH definitions.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
SPARSEMEM_VMEMMAP needs to be a selectable config option to support
building the kernel both with and without sparsemem vmemmap support. This
selection is desirable for platforms which could be configured one way for
platform specific builds and the other for multi-platform builds.
Signed-off-by: Miguel Botón <mboton@gmail.com>
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'xen-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xfs: eagerly remove vmap mappings to avoid upsetting Xen
xen: add some debug output for failed multicalls
xen: fix incorrect vcpu_register_vcpu_info hypercall argument
xen: ask the hypervisor how much space it needs reserved
xen: lock pte pages while pinning/unpinning
xen: deal with stale cr3 values when unpinning pagetables
xen: add batch completion callbacks
xen: yield to IPI target if necessary
Clean up duplicate includes in arch/i386/xen/
remove dead code in pgtable_cache_init
paravirt: clean up lazy mode handling
paravirt: refactor struct paravirt_ops into smaller pv_*_ops
When a pagetable is created, it is made globally visible in the rmap
prio tree before it is pinned via arch_dup_mmap(), and remains in the
rmap tree while it is unpinned with arch_exit_mmap().
This means that other CPUs may race with the pinning/unpinning
process, and see a pte between when it gets marked RO and actually
pinned, causing any pte updates to fail with write-protect faults.
As a result, all pte pages must be properly locked, and only unlocked
once the pinning/unpinning process has finished.
In order to avoid taking spinlocks for the whole pagetable - which may
overflow the PREEMPT_BITS portion of preempt counter - it locks and pins
each pte page individually, and then finally pins the whole pagetable.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Hugh Dickens <hugh@veritas.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Keir Fraser <keir@xensource.com>
Cc: Jan Beulich <jbeulich@novell.com>
Logic.
- set all pages in [start,end) as isolated migration-type.
by this, all free pages in the range will be not-for-use.
- Migrate all LRU pages in the range.
- Test all pages in the range's refcnt is zero or not.
Todo:
- allocate migration destination page from better area.
- confirm page_count(page)== 0 && PageReserved(page) page is safe to be freed..
(I don't like this kind of page but..
- Find out pages which cannot be migrated.
- more running tests.
- Use reclaim for unplugging other memory type area.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Convert the common vmemmap population into initialisation helpers for use by
architecture vmemmap populators. All architecture implementing the
SPARSEMEM_VMEMMAP variant supply an architecture specific vmemmap_populate()
initialiser, which may make use of the helpers.
This allows us to clean up and remove the initialisation Kconfig entries.
With this patch there is a single SPARSEMEM_VMEMMAP_ENABLE Kconfig option to
indicate use of that variant.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Acked-by: Christoph Lameter <clameter@sgi.com>
When pinning and unpinning pagetables, we must protect them against
being used by other CPUs, lest they see the pagetable in an
intermediate read-only-but-not-pinned state.
When using split pte locks, doing this properly would require taking
all the pte locks for the pagetable while pinning, but this may overflow
the PREEMPT_BITS part of the preempt counter if the process has mapped
more than about 512M of memory.
However, failing to take the pte locks causes write-protect faults when
the pageout code is trying to clear the Access bit on a pte which is part
of a freshy created and still being pinned process after fork.
This is a short-term fix until the problem is solved properly.
Acked-by: Hugh Dickins <hugh@veritas.com>
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid
confusion (among other things, with CONFIG_SUSPEND introduced in the
next patch).
The bounce buffer logic is included on systems that do not need it. If a
system does not have zones like ZONE_DMA and ZONE_HIGHMEM that can lead to
the use of bounce buffers then there is no need to reserve memory pools etc
etc. This is true f.e. for SGI Altix.
Also nicifies the Makefile and gets rid of the tricky "and" there.
Acked-by: Jens Axboe <jens.axboe@oracle.com>
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: (68 commits)
sh: sh-rtc support for SH7709.
sh: Revert __xdiv64_32 size change.
sh: Update r7785rp defconfig.
sh: Export div symbols for GCC 4.2 and ST GCC.
sh: fix race in parallel out-of-tree build
sh: Kill off dead mach.c for hp6xx.
sh: hd64461.h cleanup and added comments.
sh: Update the alignment when 4K stacks are used.
sh: Add a .bss.page_aligned section for 4K stacks.
sh: Don't let SH-4A clobber SH-4 CFLAGS.
sh: Add parport stub for SuperIO ports.
sh: Drop -Wa,-dsp for DSP tuning.
sh: Update dreamcast defconfig.
fb: pvr2fb: A few more __devinit annotations for PCI.
fb: pvr2fb: Fix up section mismatch warnings.
sh: Select IPR-IRQ for SH7091.
sh: Correct __xdiv64_32/div64_32 return value size.
sh: Fix timer-tmu build for SH-3.
sh: Add cpu and mach links to CLEAN_FILES.
sh: Preliminary support for the SH-X3 CPU.
Make some offending drivers depend on it and set CONFIG_ARCH_NO_VIRT_TO_BUS
for ppc64 so that we don't build those drivers.
This gets PowerPC allmodconfig and allyesconfig much closer to building.
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: David Miller <davem@davemloft.net>
This enables simple hotplug support for sparsemem users. Presently
this only permits memory being added in to node 0 on ZONE_NORMAL.
This moves SH over to the generic quicklists. As per x86_64,
we have special mappings for the PGDs, so these go on their
own list..
On x86_64 this cuts allocation overhead for page table pages down to a
fraction (kernel compile / editing load. TSC based measurement of times spend
in each function):
no quicklist
pte_alloc 1569048 4.3s(401ns/2.7us/179.7us)
pmd_alloc 780988 2.1s(337ns/2.7us/86.1us)
pud_alloc 780072 2.2s(424ns/2.8us/300.6us)
pgd_alloc 260022 1s(920ns/4us/263.1us)
quicklist:
pte_alloc 452436 573.4ms(8ns/1.3us/121.1us)
pmd_alloc 196204 174.5ms(7ns/889ns/46.1us)
pud_alloc 195688 172.4ms(7ns/881ns/151.3us)
pgd_alloc 65228 9.8ms(8ns/150ns/6.1us)
pgd allocations are the most complex and there we see the most dramatic
improvement (may be we can cut down the amount of pgds cached somewhat?). But
even the pte allocations still see a doubling of performance.
1. Proven code from the IA64 arch.
The method used here has been fine tuned for years and
is NUMA aware. It is based on the knowledge that accesses
to page table pages are sparse in nature. Taking a page
off the freelists instead of allocating a zeroed pages
allows a reduction of number of cachelines touched
in addition to getting rid of the slab overhead. So
performance improves. This is particularly useful if pgds
contain standard mappings. We can save on the teardown
and setup of such a page if we have some on the quicklists.
This includes avoiding lists operations that are otherwise
necessary on alloc and free to track pgds.
2. Light weight alternative to use slab to manage page size pages
Slab overhead is significant and even page allocator use
is pretty heavy weight. The use of a per cpu quicklist
means that we touch only two cachelines for an allocation.
There is no need to access the page_struct (unless arch code
needs to fiddle around with it). So the fast past just
means bringing in one cacheline at the beginning of the
page. That same cacheline may then be used to store the
page table entry. Or a second cacheline may be used
if the page table entry is not in the first cacheline of
the page. The current code will zero the page which means
touching 32 cachelines (assuming 128 byte). We get down
from 32 to 2 cachelines in the fast path.
3. x86_64 gets lightweight page table page management.
This will allow x86_64 arch code to faster repopulate pgds
and other page table entries. The list operations for pgds
are reduced in the same way as for i386 to the point where
a pgd is allocated from the page allocator and when it is
freed back to the page allocator. A pgd can pass through
the quicklists without having to be reinitialized.
64 Consolidation of code from multiple arches
So far arches have their own implementation of quicklist
management. This patch moves that feature into the core allowing
an easier maintenance and consistent management of quicklists.
Page table pages have the characteristics that they are typically zero or in a
known state when they are freed. This is usually the exactly same state as
needed after allocation. So it makes sense to build a list of freed page
table pages and then consume the pages already in use first. Those pages have
already been initialized correctly (thus no need to zero them) and are likely
already cached in such a way that the MMU can use them most effectively. Page
table pages are used in a sparse way so zeroing them on allocation is not too
useful.
Such an implementation already exits for ia64. Howver, that implementation
did not support constructors and destructors as needed by i386 / x86_64. It
also only supported a single quicklist. The implementation here has
constructor and destructor support as well as the ability for an arch to
specify how many quicklists are needed.
Quicklists are defined by an arch defining CONFIG_QUICKLIST. If more than one
quicklist is necessary then we can define NR_QUICK for additional lists. F.e.
i386 needs two and thus has
config NR_QUICK
int
default 2
If an arch has requested quicklist support then pages can be allocated
from the quicklist (or from the page allocator if the quicklist is
empty) via:
quicklist_alloc(<quicklist-nr>, <gfpflags>, <constructor>)
Page table pages can be freed using:
quicklist_free(<quicklist-nr>, <destructor>, <page>)
Pages must have a definite state after allocation and before
they are freed. If no constructor is specified then pages
will be zeroed on allocation and must be zeroed before they are
freed.
If a constructor is used then the constructor will establish
a definite page state. F.e. the i386 and x86_64 pgd constructors
establish certain mappings.
Constructors and destructors can also be used to track the pages.
i386 and x86_64 use a list of pgds in order to be able to dynamically
update standard mappings.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: William Lee Irwin III <wli@holomorphy.com>
As Andi pointed out: CONFIG_GENERIC_ISA_DMA only disables the ISA DMA
channel management. Other functionality may still expect GFP_DMA to
provide memory below 16M. So we need to make sure that CONFIG_ZONE_DMA is
set independent of CONFIG_GENERIC_ISA_DMA. Undo the modifications to
mm/Kconfig where we made ZONE_DMA dependent on GENERIC_ISA_DMA and set
theses explicitly in each arches Kconfig.
Reviews must occur for each arch in order to determine if ZONE_DMA can be
switched off. It can only be switched off if we know that all devices
supported by a platform are capable of performing DMA transfers to all of
memory (Some arches already support this: uml, avr32, sh sh64, parisc and
IA64/Altix).
In order to switch ZONE_DMA off conditionally, one would have to establish
a scheme by which one can assure that no drivers are enabled that are only
capable of doing I/O to a part of memory, or one needs to provide an
alternate means of performing an allocation from a specific range of memory
(like provided by alloc_pages_range()) and insure that all drivers use that
call. In that case the arches alloc_dma_coherent() may need to be modified
to call alloc_pages_range() instead of relying on GFP_DMA.
Make ZONE_DMA optional in core code.
- ifdef all code for ZONE_DMA and related definitions following the example
for ZONE_DMA32 and ZONE_HIGHMEM.
- Without ZONE_DMA, ZONE_HIGHMEM and ZONE_DMA32 we get to a ZONES_SHIFT of
0.
- Modify the VM statistics to work correctly without a DMA zone.
- Modify slab to not create DMA slabs if there is no ZONE_DMA.
[akpm@osdl.org: cleanup]
[jdike@addtoit.com: build fix]
[apw@shadowen.org: Simplify calculation of the number of bits we need for ZONES_SHIFT]
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
This patch simply defines CONFIG_ZONE_DMA for all arches. We later do special
things with CONFIG_ZONE_DMA after the VM and an arch are prepared to work
without ZONE_DMA.
CONFIG_ZONE_DMA can be defined in two ways depending on how an architecture
handles ISA DMA.
First if CONFIG_GENERIC_ISA_DMA is set by the arch then we know that the arch
needs ZONE_DMA because ISA DMA devices are supported. We can catch this in
mm/Kconfig and do not need to modify arch code.
Second, arches may use ZONE_DMA in an unknown way. We set CONFIG_ZONE_DMA for
all arches that do not set CONFIG_GENERIC_ISA_DMA in order to insure backwards
compatibility. The arches may later undefine ZONE_DMA if their arch code has
been verified to not depend on ZONE_DMA.
Randy brought it to my attention that in proper english "can not" should always
be written "cannot". I donot see any reason to argue, even if I mightnot
understand why this rule exists. This patch fixes "can not" in several
Documentation files as well as three Kconfigs.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Create Kconfig namespace for MEMORY_HOTPLUG_RESERVE and MEMORY_HOTPLUG_SPARSE.
This is needed to create a disticiton between the 2 paths. Selecting the
high level opiton of MEMORY_HOTPLUG will get you MEMORY_HOTPLUG_SPARSE if you
have sparsemem enabled or MEMORY_HOTPLUG_RESERVE if you are x86_64 with
discontig and ACPI numa support.
Signed-off-by: Keith Mannthey <kmannth@us.ibm.com>
Cc: Andi Kleen <ak@muc.de>
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6:
[PATCH] i386: export memory more than 4G through /proc/iomem
[PATCH] 64bit Resource: finally enable 64bit resource sizes
[PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed
[PATCH] 64bit resource: change pnp core to use resource_size_t
[PATCH] 64bit resource: change pci core and arch code to use resource_size_t
[PATCH] 64bit resource: change resource core to use resource_size_t
[PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource
[PATCH] 64bit resource: fix up printks for resources in misc drivers
[PATCH] 64bit resource: fix up printks for resources in arch and core code
[PATCH] 64bit resource: fix up printks for resources in pcmcia drivers
[PATCH] 64bit resource: fix up printks for resources in video drivers
[PATCH] 64bit resource: fix up printks for resources in ide drivers
[PATCH] 64bit resource: fix up printks for resources in mtd drivers
[PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers
[PATCH] 64bit resource: fix up printks for resources in networks drivers
[PATCH] 64bit resource: fix up printks for resources in sound drivers
[PATCH] 64bit resource: C99 changes for struct resource declarations
Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that
was changed by the 64-bit resources had been deleted in the meantime ;)
Memory hotplug code of i386 adds memory to only highmem. So, if
CONFIG_HIGHMEM is not set, CONFIG_MEMORY_HOTPLUG shouldn't be set.
Otherwise, it causes compile error.
In addition, many architecture can't use memory hotplug feature yet. So, I
introduce CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG.
Cc: <stable@kernel.org>
Fix "undefined reference to `arch_add_memory'" on sparc64 allmodconfig.
sparc64 doesn't support memory hotplug. But we want it to support
sparsemem.
Introduce the Kconfig entry and actually switch to a 64bit value, if
wanted, for resource_size_t.
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Use the migration entries for page migration
This modifies the migration code to use the new migration entries. It now
becomes possible to migrate anonymous pages without having to add a swap
entry.
We add a couple of new functions to replace migration entries with the proper
ptes.
We cannot take the tree_lock for migrating anonymous pages anymore. However,
we know that we hold the only remaining reference to the page when the page
count reaches 1.
The page migration code could function without NUMA but we currently have
no users for the non-NUMA case.
Cc: Adrian Bunk <bunk@stusta.de>
Centralize the page migration functions in anticipation of additional
tinkering. Creates a new file mm/migrate.c
1. Extract buffer_migrate_page() from fs/buffer.c
2. Extract central migration code from vmscan.c
3. Extract some components from mempolicy.c
4. Export pageout() and remove_from_swap() from vmscan.c
5. Make it possible to configure NUMA systems without page migration
and non-NUMA systems with page migration.
I had to so some #ifdeffing in mempolicy.c that may need a cleanup.
Include page migration if the system is NUMA or having a memory model that
allows distinct areas of memory (SPARSEMEM, DISCONTIGMEM).
And:
- Only include lru_add_drain_per_cpu if building for an SMP system.
On architectures that implement sparsemem but not discontigmem we want to
be able to hide the flatmem option in some cases. On ppc64 for example,
when we select NUMA we must not select flatmem.
Closer attention to the arithmetic shows that neither ppc64 nor sparc really
uses one page for multiple page tables: how on earth could they, while
pte_alloc_one returns just a struct page pointer, with no offset?
Well, arm26 manages it by returning a pte_t pointer cast to a struct page
pointer, harumph, then compensating in its pmd_populate. But arm26 is never
SMP, so it's not a problem for split ptlock either.
And the PA-RISC situation has been recently improved: CONFIG_PA20 works
without the 16-byte alignment which inflated its spinlock_t. But the current
union of spinlock_t with private does make the 7xxx struct page significantly
larger, even without debug, so disable its split ptlock.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
page tables
Suppress split ptlock on arches which may use one page for multiple page
tables. Reconsider what better to do (particularly on ppc64) later on.
This adds generic memory add/remove and supporting functions for memory
hotplug into a new file as well as a memory hotplug kernel config option.
Individual architecture patches will follow.
For now, disable memory hotplug when swsusp is enabled. There's a lot of
churn there right now. We'll fix it up properly once it calms down.
Signed-off-by: Matt Tolentino <matthew.e.tolentino@intel.com>
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with
a many-threaded application which concurrently initializes different parts of
a large anonymous area.
This patch corrects that, by using a separate spinlock per page table page, to
guard the page table entries in that page, instead of using the mm's single
page_table_lock. (But even then, page_table_lock is still used to guard page
table allocation, and anon_vma allocation.)
In this implementation, the spinlock is tucked inside the struct page of the
page table page: with a BUILD_BUG_ON in case it overflows - which it would in
the case of 32-bit PA-RISC with spinlock debugging enabled.
Splitting the lock is not quite for free: another cacheline access. Ideally,
I suppose we would use split ptlock only for multi-threaded processes on
multi-cpu machines; but deciding that dynamically would have its own costs.
So for now enable it by config, at some number of cpus - since the Kconfig
language doesn't support inequalities, let preprocessor compare that with
NR_CPUS. But I don't think it's worth being user-configurable: for good
testing of both split and unsplit configs, split now at 4 cpus, and perhaps
change that to 8 later.
There is a benefit even for singly threaded processes: kswapd can be attacking
one part of the mm while another part is busy faulting.
With cleanups from Dave Hansen <haveblue@us.ibm.com>
SPARSEMEM_EXTREME makes mem_section a one dimensional array of pointers to
mem_sections. This two level layout scheme is able to achieve smaller
memory requirements for SPARSEMEM with the tradeoff of an additional shift
and load when fetching the memory section. The current SPARSEMEM
implementation is a one dimensional array of mem_sections which is the
default SPARSEMEM configuration. The patch attempts isolates the
implementation details of the physical layout of the sparsemem section
array.
SPARSEMEM_EXTREME requires bootmem to be functioning at the time of
memory_present() calls. This is not always feasible, so architectures
which do not need it may allocate everything statically by using
SPARSEMEM_STATIC.
Signed-off-by: Bob Picco <bob.picco@hp.com>
A new option for SPARSEMEM is ARCH_SPARSEMEM_EXTREME. Architecture
platforms with a very sparse physical address space would likely want to
select this option. For those architecture platforms that don't select the
option, the code generated is equivalent to SPARSEMEM currently in -mm.
I'll be posting a patch on ia64 ml which uses this new SPARSEMEM feature.
ARCH_SPARSEMEM_EXTREME makes mem_section a one dimensional array of
pointers to mem_sections. This two level layout scheme is able to achieve
smaller memory requirements for SPARSEMEM with the tradeoff of an
additional shift and load when fetching the memory section. The current
SPARSEMEM -mm implementation is a one dimensional array of mem_sections
which is the default SPARSEMEM configuration. The patch attempts isolates
the implementation details of the physical layout of the sparsemem section
array.
ARCH_SPARSEMEM_EXTREME depends on 64BIT and is by default boolean false.
I've boot tested under aim load ia64 configured for ARCH_SPARSEMEM_EXTREME.
I've also boot tested a 4 way Opteron machine with !ARCH_SPARSEMEM_EXTREME
and tested with aim.
Sparsemem abstracts the use of discontiguous mem_maps[]. This kind of
mem_map[] is needed by discontiguous memory machines (like in the old
CONFIG_DISCONTIGMEM case) as well as memory hotplug systems. Sparsemem
replaces DISCONTIGMEM when enabled, and it is hoped that it can eventually
become a complete replacement.
A significant advantage over DISCONTIGMEM is that it's completely separated
from CONFIG_NUMA. When producing this patch, it became apparent in that NUMA
and DISCONTIG are often confused.
Another advantage is that sparse doesn't require each NUMA node's ranges to be
contiguous. It can handle overlapping ranges between nodes with no problems,
where DISCONTIGMEM currently throws away that memory.
Sparsemem uses an array to provide different pfn_to_page() translations for
each SECTION_SIZE area of physical memory. This is what allows the mem_map[]
to be chopped up.
In order to do quick pfn_to_page() operations, the section number of the page
is encoded in page->flags. Part of the sparsemem infrastructure enables
sharing of these bits more dynamically (at compile-time) between the
page_zone() and sparsemem operations. However, on 32-bit architectures, the
number of bits is quite limited, and may require growing the size of the
page->flags type in certain conditions. Several things might force this to
occur: a decrease in the SECTION_SIZE (if you want to hotplug smaller areas of
memory), an increase in the physical address space, or an increase in the
number of used page->flags.
One thing to note is that, once sparsemem is present, the NUMA node
information no longer needs to be stored in the page->flags. It might provide
speed increases on certain platforms and will be stored there if there is
room. But, if out of room, an alternate (theoretically slower) mechanism is
used.
This patch introduces CONFIG_FLATMEM. It is used in almost all cases where
there used to be an #ifndef DISCONTIG, because SPARSEMEM and DISCONTIGMEM
often have to compile out the same areas of code.
Signed-off-by: Martin Bligh <mbligh@aracnet.com>
Allow architectures to indicate that they will be providing hooks to indice
installed memory areas, memory_present(). Provide prototypes for the i386
implementation.
This gives DISCONTIGMEM a bit more help text to explain what it does, not just
when to choose it.
