path: root/mm/filemap.c
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12Merge commit '9f12600fe425bc28f0ccba034a77783c09c15af4' into for-linusAl Viro
Backmerge of dcache.c changes from mainline. It's that, or complete rebase... Conflicts: fs/splice.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-04mm: avoid unnecessary atomic operations during end_page_writeback()Mel Gorman
If a page is marked for immediate reclaim then it is moved to the tail of the LRU list. This occurs when the system is under enough memory pressure for pages under writeback to reach the end of the LRU but we test for this using atomic operations on every writeback. This patch uses an optimistic non-atomic test first. It'll miss some pages in rare cases but the consequences are not severe enough to warrant such a penalty. While the function does not dominate profiles during a simple dd test the cost of it is reduced. 73048 0.7428 vmlinux-3.15.0-rc5-mmotm-20140513 end_page_writeback 23740 0.2409 vmlinux-3.15.0-rc5-lessatomic end_page_writeback Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: non-atomically mark page accessed during page cache allocation where ↵Mel Gorman
possible aops->write_begin may allocate a new page and make it visible only to have mark_page_accessed called almost immediately after. Once the page is visible the atomic operations are necessary which is noticable overhead when writing to an in-memory filesystem like tmpfs but should also be noticable with fast storage. The objective of the patch is to initialse the accessed information with non-atomic operations before the page is visible. The bulk of filesystems directly or indirectly use grab_cache_page_write_begin or find_or_create_page for the initial allocation of a page cache page. This patch adds an init_page_accessed() helper which behaves like the first call to mark_page_accessed() but may called before the page is visible and can be done non-atomically. The primary APIs of concern in this care are the following and are used by most filesystems. find_get_page find_lock_page find_or_create_page grab_cache_page_nowait grab_cache_page_write_begin All of them are very similar in detail to the patch creates a core helper pagecache_get_page() which takes a flags parameter that affects its behavior such as whether the page should be marked accessed or not. Then old API is preserved but is basically a thin wrapper around this core function. Each of the filesystems are then updated to avoid calling mark_page_accessed when it is known that the VM interfaces have already done the job. There is a slight snag in that the timing of the mark_page_accessed() has now changed so in rare cases it's possible a page gets to the end of the LRU as PageReferenced where as previously it might have been repromoted. This is expected to be rare but it's worth the filesystem people thinking about it in case they see a problem with the timing change. It is also the case that some filesystems may be marking pages accessed that previously did not but it makes sense that filesystems have consistent behaviour in this regard. The test case used to evaulate this is a simple dd of a large file done multiple times with the file deleted on each iterations. The size of the file is 1/10th physical memory to avoid dirty page balancing. In the async case it will be possible that the workload completes without even hitting the disk and will have variable results but highlight the impact of mark_page_accessed for async IO. The sync results are expected to be more stable. The exception is tmpfs where the normal case is for the "IO" to not hit the disk. The test machine was single socket and UMA to avoid any scheduling or NUMA artifacts. Throughput and wall times are presented for sync IO, only wall times are shown for async as the granularity reported by dd and the variability is unsuitable for comparison. As async results were variable do to writback timings, I'm only reporting the maximum figures. The sync results were stable enough to make the mean and stddev uninteresting. The performance results are reported based on a run with no profiling. Profile data is based on a separate run with oprofile running. async dd 3.15.0-rc3 3.15.0-rc3 vanilla accessed-v2 ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%) tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%) btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%) ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%) xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%) The XFS figure is a bit strange as it managed to avoid a worst case by sheer luck but the average figures looked reasonable. samples percentage ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed [akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/mpage.c: factor page_endio() out of mpage_end_io()Matthew Wilcox
page_endio() takes care of updating all the appropriate page flags once I/O has finished to a page. Switch to using mapping_set_error() instead of setting AS_EIO directly; this will handle thin-provisioned devices correctly. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Dheeraj Reddy <dheeraj.reddy@intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-05-23mm/filemap.c: avoid always dirtying mapping->flags on O_DIRECTJens Axboe
In some testing I ran today (some fio jobs that spread over two nodes), we end up spending 40% of the time in filemap_check_errors(). That smells fishy. Looking further, this is basically what happens: blkdev_aio_read() generic_file_aio_read() filemap_write_and_wait_range() if (!mapping->nr_pages) filemap_check_errors() and filemap_check_errors() always attempts two test_and_clear_bit() on the mapping flags, thus dirtying it for every single invocation. The patch below tests each of these bits before clearing them, avoiding this issue. In my test case (4-socket box), performance went from 1.7M IOPS to 4.0M IOPS. Signed-off-by: Jens Axboe <axboe@fb.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06bury generic_file_aio_{read,write}Al Viro
no callers left Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06bury __generic_file_aio_write()Al Viro
all users converted to __generic_file_write_iter() now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06iov_iter_truncate()Al Viro
Now It Can Be Done(tm) - we don't need to do iov_shorten() in generic_file_direct_write() anymore, now that all ->direct_IO() instances are converted to proper iov_iter methods and honour iter->count and iter->iov_offset properly. Get rid of count/ocount arguments of generic_file_direct_write(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06start adding the tag to iov_iterAl Viro
For now, just use the same thing we pass to ->direct_IO() - it's all iovec-based at the moment. Pass it explicitly to iov_iter_init() and account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO() uses. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06new helper: generic_file_read_iter()Al Viro
iov_iter-using variant of generic_file_aio_read(). Some callers converted. Note that it's still not quite there for use as ->read_iter() - we depend on having zero iter->iov_offset in O_DIRECT case. Fortunately, that's true for all converted callers (and for generic_file_aio_read() itself). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06give ->direct_IO() a copy of iov_iterAl Viro
the thing is, we want to advance what's given to ->direct_IO() as we are forming the request; however, the callers care about the amount of data actually transferred, not the amount we tried to transfer. It's more convenient to allow ->direct_IO() instances do use iov_iter_advance() on the copy of iov_iter, leaving the actual advancing of the original to caller. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06get rid of pointless iov_length() in ->direct_IO()Al Viro
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06kill generic_segment_checks()Al Viro
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already checked - generic_segment_checks() done after that is just an odd way to spell iov_length(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06generic_file_direct_write(): switch to iov_iterAl Viro
2014-05-06mm: filemap: update find_get_pages_tag() to deal with shadow entriesJohannes Weiner
Dave Jones reports the following crash when find_get_pages_tag() runs into an exceptional entry: kernel BUG at mm/filemap.c:1347! RIP: find_get_pages_tag+0x1cb/0x220 Call Trace: find_get_pages_tag+0x36/0x220 pagevec_lookup_tag+0x21/0x30 filemap_fdatawait_range+0xbe/0x1e0 filemap_fdatawait+0x27/0x30 sync_inodes_sb+0x204/0x2a0 sync_inodes_one_sb+0x19/0x20 iterate_supers+0xb2/0x110 sys_sync+0x44/0xb0 ia32_do_call+0x13/0x13 1343 /* 1344 * This function is never used on a shmem/tmpfs 1345 * mapping, so a swap entry won't be found here. 1346 */ 1347 BUG(); After commit 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees") this comment and BUG() are out of date because exceptional entries can now appear in all mappings - as shadows of recently evicted pages. However, as Hugh Dickins notes, "it is truly surprising for a PAGECACHE_TAG_WRITEBACK (and probably any other PAGECACHE_TAG_*) to appear on an exceptional entry. I expect it comes down to an occasional race in RCU lookup of the radix_tree: lacking absolute synchronization, we might sometimes catch an exceptional entry, with the tag which really belongs with the unexceptional entry which was there an instant before." And indeed, not only is the tree walk lockless, the tags are also read in chunks, one radix tree node at a time. There is plenty of time for page reclaim to swoop in and replace a page that was already looked up as tagged with a shadow entry. Remove the BUG() and update the comment. While reviewing all other lookup sites for whether they properly deal with shadow entries of evicted pages, update all the comments and fix memcg file charge moving to not miss shmem/tmpfs swapcache pages. Fixes: 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees") Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Dave Jones <davej@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18mm: fix new kernel-doc warning in filemap.cRandy Dunlap
Fix new kernel-doc warning in mm/filemap.c: Warning(mm/filemap.c:2600): Excess function parameter 'ppos' description in '__generic_file_aio_write' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-07memcg: rename high level charging functionsMichal Hocko
mem_cgroup_newpage_charge is used only for charging anonymous memory so it is better to rename it to mem_cgroup_charge_anon. mem_cgroup_cache_charge is used for file backed memory so rename it to mem_cgroup_charge_file. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: cleanup size checks in filemap_fault() and filemap_map_pages()Kirill A. Shutemov
Minor cleanups: - 'size' variable is now in bytes, not pages; - use round_up(): it should be easier to read. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: implement ->map_pages for page cacheKirill A. Shutemov
filemap_map_pages() is generic implementation of ->map_pages() for filesystems who uses page cache. It should be safe to use filemap_map_pages() for ->map_pages() if filesystem use filemap_fault() for ->fault(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: remove read_cache_page_async()Sasha Levin
This patch removes read_cache_page_async() which wasn't really needed anywhere and simplifies the code around it a bit. read_cache_page_async() is useful when we want to read a page into the cache without waiting for it to complete. This happens when the appropriate callback 'filler' doesn't complete its read operation and releases the page lock immediately, and instead queues a different completion routine to do that. This never actually happened anywhere in the code. read_cache_page_async() had 3 different callers: - read_cache_page() which is the sync version, it would just wait for the requested read to complete using wait_on_page_read(). - JFFS2 would call it from jffs2_gc_fetch_page(), but the filler function it supplied doesn't do any async reads, and would complete before the filler function returns - making it actually a sync read. - CRAMFS would call it using the read_mapping_page_async() wrapper, with a similar story to JFFS2 - the filler function doesn't do anything that reminds async reads and would always complete before the filler function returns. To sum it up, the code in mm/filemap.c never took advantage of having read_cache_page_async(). While there are filler callbacks that do async reads (such as the block one), we always called it with the read_cache_page(). This patch adds a mandatory wait for read to complete when adding a new page to the cache, and removes read_cache_page_async() and its wrappers. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: keep page cache radix tree nodes in checkJohannes Weiner
Previously, page cache radix tree nodes were freed after reclaim emptied out their page pointers. But now reclaim stores shadow entries in their place, which are only reclaimed when the inodes themselves are reclaimed. This is problematic for bigger files that are still in use after they have a significant amount of their cache reclaimed, without any of those pages actually refaulting. The shadow entries will just sit there and waste memory. In the worst case, the shadow entries will accumulate until the machine runs out of memory. To get this under control, the VM will track radix tree nodes exclusively containing shadow entries on a per-NUMA node list. Per-NUMA rather than global because we expect the radix tree nodes themselves to be allocated node-locally and we want to reduce cross-node references of otherwise independent cache workloads. A simple shrinker will then reclaim these nodes on memory pressure. A few things need to be stored in the radix tree node to implement the shadow node LRU and allow tree deletions coming from the list: 1. There is no index available that would describe the reverse path from the node up to the tree root, which is needed to perform a deletion. To solve this, encode in each node its offset inside the parent. This can be stored in the unused upper bits of the same member that stores the node's height at no extra space cost. 2. The number of shadow entries needs to be counted in addition to the regular entries, to quickly detect when the node is ready to go to the shadow node LRU list. The current entry count is an unsigned int but the maximum number of entries is 64, so a shadow counter can easily be stored in the unused upper bits. 3. Tree modification needs tree lock and tree root, which are located in the address space, so store an address_space backpointer in the node. The parent pointer of the node is in a union with the 2-word rcu_head, so the backpointer comes at no extra cost as well. 4. The node needs to be linked to an LRU list, which requires a list head inside the node. This does increase the size of the node, but it does not change the number of objects that fit into a slab page. [akpm@linux-foundation.org: export the right function] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: thrash detection-based file cache sizingJohannes Weiner
The VM maintains cached filesystem pages on two types of lists. One list holds the pages recently faulted into the cache, the other list holds pages that have been referenced repeatedly on that first list. The idea is to prefer reclaiming young pages over those that have shown to benefit from caching in the past. We call the recently usedbut ultimately was not significantly better than a FIFO policy and still thrashed cache based on eviction speed, rather than actual demand for cache. This patch solves one half of the problem by decoupling the ability to detect working set changes from the inactive list size. By maintaining a history of recently evicted file pages it can detect frequently used pages with an arbitrarily small inactive list size, and subsequently apply pressure on the active list based on actual demand for cache, not just overall eviction speed. Every zone maintains a counter that tracks inactive list aging speed. When a page is evicted, a snapshot of this counter is stored in the now-empty page cache radix tree slot. On refault, the minimum access distance of the page can be assessed, to evaluate whether the page should be part of the active list or not. This fixes the VM's blindness towards working set changes in excess of the inactive list. And it's the foundation to further improve the protection ability and reduce the minimum inactive list size of 50%. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Bob Liu <bob.liu@oracle.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: prepare for non-page entries in page cache radix treesJohannes Weiner
shmem mappings already contain exceptional entries where swap slot information is remembered. To be able to store eviction information for regular page cache, prepare every site dealing with the radix trees directly to handle entries other than pages. The common lookup functions will filter out non-page entries and return NULL for page cache holes, just as before. But provide a raw version of the API which returns non-page entries as well, and switch shmem over to use it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: filemap: move radix tree hole searching hereJohannes Weiner
The radix tree hole searching code is only used for page cache, for example the readahead code trying to get a a picture of the area surrounding a fault. It sufficed to rely on the radix tree definition of holes, which is "empty tree slot". But this is about to change, though, as shadow page descriptors will be stored in the page cache after the actual pages get evicted from memory. Move the functions over to mm/filemap.c and make them native page cache operations, where they can later be adapted to handle the new definition of "page cache hole". Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: optimize put_mems_allowed() usageMel Gorman
Since put_mems_allowed() is strictly optional, its a seqcount retry, we don't need to evaluate the function if the allocation was in fact successful, saving a smp_rmb some loads and comparisons on some relative fast-paths. Since the naming, get/put_mems_allowed() does suggest a mandatory pairing, rename the interface, as suggested by Mel, to resemble the seqcount interface. This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(), where it is important to note that the return value of the latter call is inverted from its previous incarnation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-01kill generic_file_buffered_write()Al Viro
2014-04-01export generic_perform_write(), start getting rid of generic_file_buffer_write()Al Viro
2014-04-01generic_file_direct_write(): get rid of ppos argumentAl Viro
always equal to &iocb->ki_pos. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01kill the 5th argument of generic_file_buffered_write()Al Viro
same story - it's &iocb->ki_pos in all cases Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01kill the 4th argument of __generic_file_aio_write()Al Viro
It's always equal to &iocb->ki_pos, where iocb is the value of the 1st argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01take iov_iter stuff to mm/iov_iter.cAl Viro
2014-04-01introduce copy_page_to_iter, kill loop over iovec in generic_file_aio_read()Al Viro
generic_file_aio_read() was looping over the target iovec, with loop over (source) pages nested inside that. Just set an iov_iter up and pass *that* to do_generic_file_aio_read(). With copy_page_to_iter() doing all work of mapping and copying a page to iovec and advancing iov_iter. Switch shmem_file_aio_read() to the same and kill file_read_actor(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01callers of iov_copy_from_user_atomic() don't need pagecache_disable()Al Viro
... it does that itself (via kmap_atomic()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01switch ->is_partially_uptodate() to saner argumentsAl Viro
2014-02-09fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Assorted stuff; the biggest pile here is Christoph's ACL series. Plus assorted cleanups and fixes all over the place... There will be another pile later this week" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits) __dentry_path() fixes vfs: Remove second variable named error in __dentry_path vfs: Is mounted should be testing mnt_ns for NULL or error. Fix race when checking i_size on direct i/o read hfsplus: remove can_set_xattr nfsd: use get_acl and ->set_acl fs: remove generic_acl nfs: use generic posix ACL infrastructure for v3 Posix ACLs gfs2: use generic posix ACL infrastructure jfs: use generic posix ACL infrastructure xfs: use generic posix ACL infrastructure reiserfs: use generic posix ACL infrastructure ocfs2: use generic posix ACL infrastructure jffs2: use generic posix ACL infrastructure hfsplus: use generic posix ACL infrastructure f2fs: use generic posix ACL infrastructure ext2/3/4: use generic posix ACL infrastructure btrfs: use generic posix ACL infrastructure fs: make posix_acl_create more useful fs: make posix_acl_chmod more useful ...
2014-01-26Fix race when checking i_size on direct i/o readSteven Whitehouse
So far I've had one ACK for this, and no other comments. So I think it is probably time to send this via some suitable tree. I'm guessing that the vfs tree would be the most appropriate route, but not sure that there is one at the moment (don't see anything recent at kernel.org) so in that case I think -mm is the "back up plan". Al, please let me know if you will take this? Steve. --------------------- Following on from the "Re: [PATCH v3] vfs: fix a bug when we do some dio reads with append dio writes" thread on linux-fsdevel, this patch is my current version of the fix proposed as option (b) in that thread. Removing the i_size test from the direct i/o read path at vfs level means that filesystems now have to deal with requests which are beyond i_size themselves. These I've divided into three sets: a) Those with "no op" ->direct_IO (9p, cifs, ceph) These are obviously not going to be an issue b) Those with "home brew" ->direct_IO (nfs, fuse) I've been told that NFS should not have any problem with the larger i_size, however I've added an extra test to FUSE to duplicate the original behaviour just to be on the safe side. c) Those using __blockdev_direct_IO() These call through to ->get_block() which should deal with the EOF condition correctly. I've verified that with GFS2 and I believe that Zheng has verified it for ext4. I've also run the test on XFS and it passes both before and after this change. The part of the patch in filemap.c looks a lot larger than it really is - there are only two lines of real change. The rest is just indentation of the contained code. There remains a test of i_size though, which was added for btrfs. It doesn't cause the other filesystems a problem as the test is performed after ->direct_IO has been called. It is possible that there is a race that does matter to btrfs, however this patch doesn't change that, so its still an overall improvement. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reported-by: Zheng Liu <gnehzuil.liu@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Acked-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Chris Mason <clm@fb.com> Cc: Josef Bacik <jbacik@fb.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: drop actor argument of do_generic_file_read()Kirill A. Shutemov
There's only one caller of do_generic_file_read() and the only actor is file_read_actor(). No reason to have a callback parameter. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12mm: cleanup add_to_page_cache_locked()Kirill A. Shutemov
Make add_to_page_cache_locked() cleaner: - unindent most code of the function by inverting one condition; - streamline code no-error path; - move insert error path outside normal code path; - call radix_tree_preload_end() earlier; No functional changes. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hughd@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12mm: memcg: enable memcg OOM killer only for user faultsJohannes Weiner
System calls and kernel faults (uaccess, gup) can handle an out of memory situation gracefully and just return -ENOMEM. Enable the memcg OOM killer only for user faults, where it's really the only option available. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11lib/radix-tree.c: make radix_tree_node_alloc() work correctly within interruptJan Kara
With users of radix_tree_preload() run from interrupt (block/blk-ioc.c is one such possible user), the following race can happen: radix_tree_preload() ... radix_tree_insert() radix_tree_node_alloc() if (rtp->nr) { ret = rtp->nodes[rtp->nr - 1]; <interrupt> ... radix_tree_preload() ... radix_tree_insert() radix_tree_node_alloc() if (rtp->nr) { ret = rtp->nodes[rtp->nr - 1]; And we give out one radix tree node twice. That clearly results in radix tree corruption with different results (usually OOPS) depending on which two users of radix tree race. We fix the problem by making radix_tree_node_alloc() always allocate fresh radix tree nodes when in interrupt. Using preloading when in interrupt doesn't make sense since all the allocations have to be atomic anyway and we cannot steal nodes from process-context users because some users rely on radix_tree_insert() succeeding after radix_tree_preload(). in_interrupt() check is somewhat ugly but we cannot simply key off passed gfp_mask as that is acquired from root_gfp_mask() and thus the same for all preload users. Another part of the fix is to avoid node preallocation in radix_tree_preload() when passed gfp_mask doesn't allow waiting. Again, preallocation in such case doesn't make sense and when preallocation would happen in interrupt we could possibly leak some allocated nodes. However, some users of radix_tree_preload() require following radix_tree_insert() to succeed. To avoid unexpected effects for these users, radix_tree_preload() only warns if passed gfp mask doesn't allow waiting and we provide a new function radix_tree_maybe_preload() for those users which get different gfp mask from different call sites and which are prepared to handle radix_tree_insert() failure. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
