split_huge_pmd() doesn't guarantee that the pmd is normal pmd pointing
to pte entries, which can be checked with pmd_trans_unstable(). Some
callers make this assertion and some do it differently and some not, so
let's do it in a unified manner.
Link: http://lkml.kernel.org/r/1464741400-12143-1-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Mel Gorman <mgorman@techsingularity.net>
The vGPU folks would like to trap the first access to a BAR by setting
vm_ops on the VMAs produced by mmap-ing a VFIO device. The fault handler
then can use remap_pfn_range to place some non-reserved pages in the VMA.
This kind of VM_PFNMAP mapping is not handled by KVM, but follow_pfn
and fixup_user_fault together help supporting it. The patch also supports
VM_MIXEDMAP vmas where the pfns are not reserved and thus subject to
reference counting.
Cc: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Tested-by: Neo Jia <cjia@nvidia.com>
Reported-by: Kirti Wankhede <kwankhede@nvidia.com>
Pull mm gup cleanup from Ingo Molnar:
"This removes the ugly get-user-pages API hack, now that all upstream
code has been migrated to it"
("ugly" is putting it mildly. But it worked.. - Linus)
* 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm/gup: Remove the macro overload API migration helpers from the get_user*() APIs
APIs
The pkeys changes brought about a truly hideous set of macros in:
cde70140fed8 ("mm/gup: Overload get_user_pages() functions")
... which macros are (ab-)using the fact that __VA_ARGS__ can be used
to shift parameter positions in macro arguments without breaking the
build and so can be used to call separate C functions depending on
the number of arguments of the macro.
This allowed easy migration of these 3 GUP APIs, as both these variants
worked at the C level:
old:
ret = get_user_pages(current, current->mm, address, 1, 1, 0, &page, NULL);
new:
ret = get_user_pages(address, 1, 1, 0, &page, NULL);
... while we also generated a (functionally harmless but noticeable) build
time warning if the old API was used. As there are over 300 uses of these
APIs, this trick eased the migration of the API and avoided excessive
migration pain in linux-next.
Now, with its work done, get rid of all of that complication and ugliness:
3 files changed, 16 insertions(+), 140 deletions(-)
... where the linecount of the migration hack was further inflated by the
fact that there are NOMMU variants of these GUP APIs as well.
Much of the conversion was done in linux-next over the past couple of months,
and Linus recently removed all remaining old API uses from the upstream tree
in the following upstrea commit:
cb107161df3c ("Convert straggling drivers to new six-argument get_user_pages()")
There was one more old-API usage in mm/gup.c, in the CONFIG_HAVE_GENERIC_RCU_GUP
code path that ARM, ARM64 and PowerPC uses.
After this commit any old API usage will break the build.
[ Also fixed a PowerPC/HAVE_GENERIC_RCU_GUP warning reported by Stephen Rothwell. ]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: linux-mm@kvack.org
Mostly direct substitution with occasional adjustment or removing
outdated comments.
As discussed earlier, we attempt to enforce protection keys in
software.
However, the code checks all faults to ensure that they are not
violating protection key permissions. It was assumed that all
faults are either write faults where we check PKRU[key].WD (write
disable) or read faults where we check the AD (access disable)
bit.
But, there is a third category of faults for protection keys:
instruction faults. Instruction faults never run afoul of
protection keys because they do not affect instruction fetches.
So, plumb the PF_INSTR bit down in to the
arch_vma_access_permitted() function where we do the protection
key checks.
We also add a new FAULT_FLAG_INSTRUCTION. This is because
handle_mm_fault() is not passed the architecture-specific
error_code where we keep PF_INSTR, so we need to encode the
instruction fetch information in to the arch-generic fault
flags.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20160212210224.96928009@viggo.jf.intel.com
We try to enforce protection keys in software the same way that we
do in hardware. (See long example below).
But, we only want to do this when accessing our *own* process's
memory. If GDB set PKRU[6].AD=1 (disable access to PKEY 6), then
tried to PTRACE_POKE a target process which just happened to have
some mprotect_pkey(pkey=6) memory, we do *not* want to deny the
debugger access to that memory. PKRU is fundamentally a
thread-local structure and we do not want to enforce it on access
to _another_ thread's data.
This gets especially tricky when we have workqueues or other
delayed-work mechanisms that might run in a random process's context.
We can check that we only enforce pkeys when operating on our *own* mm,
but delayed work gets performed when a random user context is active.
We might end up with a situation where a delayed-work gup fails when
running randomly under its "own" task but succeeds when running under
another process. We want to avoid that.
To avoid that, we use the new GUP flag: FOLL_REMOTE and add a
fault flag: FAULT_FLAG_REMOTE. They indicate that we are
walking an mm which is not guranteed to be the same as
current->mm and should not be subject to protection key
enforcement.
Thanks to Jerome Glisse for pointing out this scenario.
Cc: Alexey Kardashevskiy <aik@ozlabs.ru>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: Dominik Vogt <vogt@linux.vnet.ibm.com>
Cc: Eric B Munson <emunson@akamai.com>
Cc: Geliang Tang <geliangtang@163.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Jan Kara <jack@suse.cz>
Cc: Jason Low <jason.low2@hp.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Shachar Raindel <raindel@mellanox.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
Cc: iommu@lists.linux-foundation.org
Cc: linux-s390@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Today, for normal faults and page table walks, we check the VMA
and/or PTE to ensure that it is compatible with the action. For
instance, if we get a write fault on a non-writeable VMA, we
SIGSEGV.
We try to do the same thing for protection keys. Basically, we
try to make sure that if a user does this:
mprotect(ptr, size, PROT_NONE);
*ptr = foo;
they see the same effects with protection keys when they do this:
mprotect(ptr, size, PROT_READ|PROT_WRITE);
set_pkey(ptr, size, 4);
wrpkru(0xffffff3f); // access disable pkey 4
*ptr = foo;
The state to do that checking is in the VMA, but we also
sometimes have to do it on the page tables only, like when doing
a get_user_pages_fast() where we have no VMA.
We add two functions and expose them to generic code:
arch_pte_access_permitted(pte_flags, write)
arch_vma_access_permitted(vma, write)
These are, of course, backed up in x86 arch code with checks
against the PTE or VMA's protection key.
But, there are also cases where we do not want to respect
protection keys. When we ptrace(), for instance, we do not want
to apply the tracer's PKRU permissions to the PTEs from the
process being traced.
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Toshi Kani <toshi.kani@hpe.com>
Link: http://lkml.kernel.org/r/20160212210219.14D5D715@viggo.jf.intel.com
This code matches a fault condition up with the VMA and ensures
that the VMA allows the fault to be handled instead of just
erroring out.
We will be extending this in a moment to comprehend protection
keys.
Link: http://lkml.kernel.org/r/20160212210216.C3824032@viggo.jf.intel.com
We will soon modify the vanilla get_user_pages() so it can no
longer be used on mm/tasks other than 'current/current->mm',
which is by far the most common way it is called. For now,
we allow the old-style calls, but warn when they are used.
(implemented in previous patch)
This patch switches all callers of:
get_user_pages()
get_user_pages_unlocked()
get_user_pages_locked()
to stop passing tsk/mm so they will no longer see the warnings.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: jack@suse.cz
Link: http://lkml.kernel.org/r/20160212210156.113E9407@viggo.jf.intel.com
The concept here was a suggestion from Ingo. The implementation
horrors are all mine.
This allows get_user_pages(), get_user_pages_unlocked(), and
get_user_pages_locked() to be called with or without the
leading tsk/mm arguments. We will give a compile-time warning
about the old style being __deprecated and we will also
WARN_ON() if the non-remote version is used for a remote-style
access.
Doing this, folks will get nice warnings and will not break the
build. This should be nice for -next and will hopefully let
developers fix up their own code instead of maintainers needing
to do it at merge time.
The way we do this is hideous. It uses the __VA_ARGS__ macro
functionality to call different functions based on the number
of arguments passed to the macro.
There's an additional hack to ensure that our EXPORT_SYMBOL()
of the deprecated symbols doesn't trigger a warning.
We should be able to remove this mess as soon as -rc1 hits in
the release after this is merged.
Cc: Alexander Kuleshov <kuleshovmail@gmail.com>
Cc: Leon Romanovsky <leon@leon.nu>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Link: http://lkml.kernel.org/r/20160212210155.73222EE1@viggo.jf.intel.com
For protection keys, we need to understand whether protections
should be enforced in software or not. In general, we enforce
protections when working on our own task, but not when on others.
We call these "current" and "remote" operations.
This patch introduces a new get_user_pages() variant:
get_user_pages_remote()
Which is a replacement for when get_user_pages() is called on
non-current tsk/mm.
We also introduce a new gup flag: FOLL_REMOTE which can be used
for the "__" gup variants to get this new behavior.
The uprobes is_trap_at_addr() location holds mmap_sem and
calls get_user_pages(current->mm) on an instruction address. This
makes it a pretty unique gup caller. Being an instruction access
and also really originating from the kernel (vs. the app), I opted
to consider this a 'remote' access where protection keys will not
be enforced.
Without protection keys, this patch should not change any behavior.
Cc: jack@suse.cz
Link: http://lkml.kernel.org/r/20160212210154.3F0E51EA@viggo.jf.intel.com
Trinity is now hitting the WARN_ON_ONCE we added in v3.15 commit
cda540ace6a1 ("mm: get_user_pages(write,force) refuse to COW in shared
areas"). The warning has served its purpose, nobody was harmed by that
change, so just remove the warning to generate less noise from Trinity.
Which reminds me of the comment I wrongly left behind with that commit
(but was spotted at the time by Kirill), which has since moved into a
separate function, and become even more obscure: delete it.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Suggested-by: Kirill A. Shutemov <kirill@shutemov.name>
During Jason's work with postcopy migration support for s390 a problem
regarding gmap faults was discovered.
The gmap code will call fixup_user_fault which will end up always in
handle_mm_fault. Till now we never cared about retries, but as the
userfaultfd code kind of relies on it. this needs some fix.
This patchset does not take care of the futex code. I will now look
closer at this.
This patch (of 2):
With the introduction of userfaultfd, kvm on s390 needs fixup_user_fault
to pass in FAULT_FLAG_ALLOW_RETRY and give feedback if during the
faulting we ever unlocked mmap_sem.
This patch brings in the logic to handle retries as well as it cleans up
the current documentation. fixup_user_fault was not having the same
semantics as filemap_fault. It never indicated if a retry happened and
so a caller wasn't able to handle that case. So we now changed the
behaviour to always retry a locked mmap_sem.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Jason J. Herne" <jjherne@linux.vnet.ibm.com>
A dax mapping establishes a pte with _PAGE_DEVMAP set when the driver
has established a devm_memremap_pages() mapping, i.e. when the pfn_t
return from ->direct_access() has PFN_DEV and PFN_MAP set. Later, when
encountering _PAGE_DEVMAP during a page table walk we lookup and pin a
struct dev_pagemap instance to keep the result of pfn_to_page() valid
until put_page().
Tested-by: Logan Gunthorpe <logang@deltatee.com>
Before THP refcounting rework, THP was not allowed to cross VMA
boundary. So, if we have THP and we split it, PG_mlocked can be safely
transferred to small pages.
With new THP refcounting and naive approach to mlocking we can end up
with this scenario:
1. we have a mlocked THP, which belong to one VM_LOCKED VMA.
2. the process does munlock() on the *part* of the THP:
- the VMA is split into two, one of them VM_LOCKED;
- huge PMD split into PTE table;
- THP is still mlocked;
3. split_huge_page():
- it transfers PG_mlocked to *all* small pages regrardless if it
blong to any VM_LOCKED VMA.
We probably could munlock() all small pages on split_huge_page(), but I
think we have accounting issue already on step two.
Instead of forbidding mlocked pages altogether, we just avoid mlocking
PTE-mapped THPs and munlock THPs on split_huge_pmd().
This means PTE-mapped THPs will be on normal lru lists and will be split
under memory pressure by vmscan. After the split vmscan will detect
unevictable small pages and mlock them.
With this approach we shouldn't hit situation like described above.
Cc: Steve Capper <steve.capper@linaro.org>
Cc: Christoph Lameter <cl@linux.com>
With new refcounting we don't need to mark PMDs splitting. Let's drop
code to handle this.
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Tail page refcounting is utterly complicated and painful to support.
It uses ->_mapcount on tail pages to store how many times this page is
pinned. get_page() bumps ->_mapcount on tail page in addition to
->_count on head. This information is required by split_huge_page() to
be able to distribute pins from head of compound page to tails during
the split.
We will need ->_mapcount to account PTE mappings of subpages of the
compound page. We eliminate need in current meaning of ->_mapcount in
tail pages by forbidding split entirely if the page is pinned.
The only user of tail page refcounting is THP which is marked BROKEN for
now.
Let's drop all this mess. It makes get_page() and put_page() much
simpler.
We are going to decouple splitting THP PMD from splitting underlying
compound page.
This patch renames split_huge_page_pmd*() functions to split_huge_pmd*()
to reflect the fact that it doesn't imply page splitting, only PMD.
With new refcounting THP can belong to several VMAs. This makes tricky
to track THP pages, when they partially mlocked. It can lead to leaking
mlocked pages to non-VM_LOCKED vmas and other problems.
With this patch we will split all pages on mlock and avoid
fault-in/collapse new THP in VM_LOCKED vmas.
I've tried alternative approach: do not mark THP pages mlocked and keep
them on normal LRUs. This way vmscan could try to split huge pages on
memory pressure and free up subpages which doesn't belong to VM_LOCKED
vmas. But this is user-visible change: we screw up Mlocked accouting
reported in meminfo, so I had to leave this approach aside.
We can bring something better later, but this should be good enough for
now.
With new refcounting we are going to see THP tail pages mapped with PTE.
Generic fast GUP rely on page_cache_get_speculative() to obtain
reference on page. page_cache_get_speculative() always fails on tail
pages, because ->_count on tail pages is always zero.
Let's handle tail pages in gup_pte_range().
New split_huge_page() will rely on migration entries to freeze page's
counts. Recheck PTE value after page_cache_get_speculative() on head
page should be enough to serialize against split.
We need to prepare kernel to allow transhuge pages to be mapped with
ptes too. We need to handle FOLL_SPLIT in follow_page_pte().
Also we use split_huge_page() directly instead of split_huge_page_pmd().
split_huge_page_pmd() will gone.
The cost of faulting in all memory to be locked can be very high when
working with large mappings. If only portions of the mapping will be used
this can incur a high penalty for locking.
For the example of a large file, this is the usage pattern for a large
statical language model (probably applies to other statical or graphical
models as well). For the security example, any application transacting in
data that cannot be swapped out (credit card data, medical records, etc).
This patch introduces the ability to request that pages are not
pre-faulted, but are placed on the unevictable LRU when they are finally
faulted in. The VM_LOCKONFAULT flag will be used together with VM_LOCKED
and has no effect when set without VM_LOCKED. Setting the VM_LOCKONFAULT
flag for a VMA will cause pages faulted into that VMA to be added to the
unevictable LRU when they are faulted or if they are already present, but
will not cause any missing pages to be faulted in.
Exposing this new lock state means that we cannot overload the meaning of
the FOLL_POPULATE flag any longer. Prior to this patch it was used to
mean that the VMA for a fault was locked. This means we need the new
FOLL_MLOCK flag to communicate the locked state of a VMA. FOLL_POPULATE
will now only control if the VMA should be populated and in the case of
VM_LOCKONFAULT, it will not be set.
Signed-off-by: Eric B Munson <emunson@akamai.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
With DAX, pfn mapping becoming more common. The patch adjusts GUP code to
cover pfn mapping for cases when we don't need struct page to proceed.
To make it possible, let's change follow_page() code to return -EEXIST
error code if proper page table entry exists, but no corresponding struct
page. __get_user_page() would ignore the error code and move to the next
page frame.
The immediate effect of the change is working MAP_POPULATE and mlock() on
DAX mappings.
[akpm@linux-foundation.org: fix arm64 build]
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Commit 38c5ce936a08 ("mm/gup: Replace ACCESS_ONCE with READ_ONCE")
converted ACCESS_ONCE usage in gup_pmd_range() to READ_ONCE, since
ACCESS_ONCE doesn't work reliably on non-scalar types.
This patch also fixes the other ACCESS_ONCE usages in gup_pte_range()
and __get_user_pages_fast() in mm/gup.c
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
It's odd that we have populate_vma_page_range() and __mm_populate() in
mm/mlock.c. It's implementation of generic memory population and mlocking
is one of possible side effect, if VM_LOCKED is set.
__get_user_pages() is core of the implementation. Let's move the code
into mm/gup.c.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Michel Lespinasse <walken@google.com>
After commit a1fde08c74e9 ("VM: skip the stack guard page lookup in
get_user_pages only for mlock") FOLL_MLOCK has lost its original
meaning: we don't necessarily mlock the page if the flags is set -- we
also take VM_LOCKED into consideration.
Since we use the same codepath for __mm_populate(), let's rename
FOLL_MLOCK to FOLL_POPULATE.
git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux
Pull ACCESS_ONCE() rule tightening from Christian Borntraeger:
"Tighten rules for ACCESS_ONCE
This series tightens the rules for ACCESS_ONCE to only work on scalar
types. It also contains the necessary fixups as indicated by build
bots of linux-next. Now everything is in place to prevent new
non-scalar users of ACCESS_ONCE and we can continue to convert code to
READ_ONCE/WRITE_ONCE"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux:
kernel: Fix sparse warning for ACCESS_ONCE
next: sh: Fix compile error
kernel: tighten rules for ACCESS ONCE
x86/spinlock: Leftover conversion ACCESS_ONCE->READ_ONCE
x86/xen/p2m: Replace ACCESS_ONCE with READ_ONCE
ppc/hugetlbfs: Replace ACCESS_ONCE with READ_ONCE
ppc/kvm: Replace ACCESS_ONCE with READ_ONCE
Convert existing users of pte_numa and friends to the new helper. Note
that the kernel is broken after this patch is applied until the other page
table modifiers are also altered. This patch layout is to make review
easier.
Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Dave Jones <davej@redhat.com>
Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com>
This allows the get_user_pages_fast slow path to release the mmap_sem
before blocking.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
Some callers (like KVM) may want to set the gup_flags like FOLL_HWPOSION
to get a proper -EHWPOSION retval instead of -EFAULT to take a more
appropriate action if get_user_pages runs into a memory failure.
FAULT_FOLL_ALLOW_RETRY allows the page fault to drop the mmap_sem for
reading to reduce the mmap_sem contention (for writing), like while
waiting for I/O completion. The problem is that right now practically no
get_user_pages call uses FAULT_FOLL_ALLOW_RETRY, so we're not leveraging
that nifty feature.
Andres fixed it for the KVM page fault. However get_user_pages_fast
remains uncovered, and 99% of other get_user_pages aren't using it either
(the only exception being FOLL_NOWAIT in KVM which is really nonblocking
and in fact it doesn't even release the mmap_sem).
So this patchsets extends the optimization Andres did in the KVM page
fault to the whole kernel. It makes most important places (including
gup_fast) to use FAULT_FOLL_ALLOW_RETRY to reduce the mmap_sem hold times
during I/O.
The only few places that remains uncovered are drivers like v4l and other
exceptions that tends to work on their own memory and they're not working
on random user memory (for example like O_DIRECT that uses gup_fast and is
fully covered by this patch).
A follow up patch should probably also add a printk_once warning to
get_user_pages that should go obsolete and be phased out eventually. The
"vmas" parameter of get_user_pages makes it fundamentally incompatible
with FAULT_FOLL_ALLOW_RETRY (vmas array becomes meaningless the moment the
mmap_sem is released).
While this is just an optimization, this becomes an absolute requirement
for the userfaultfd feature http://lwn.net/Articles/615086/ .
The userfaultfd allows to block the page fault, and in order to do so I
need to drop the mmap_sem first. So this patch also ensures that all
memory where userfaultfd could be registered by KVM, the very first fault
(no matter if it is a regular page fault, or a get_user_pages) always has
FAULT_FOLL_ALLOW_RETRY set. Then the userfaultfd blocks and it is waken
only when the pagetable is already mapped. The second fault attempt after
the wakeup doesn't need FAULT_FOLL_ALLOW_RETRY, so it's ok to retry
without it.
This patch (of 5):
We can leverage the VM_FAULT_RETRY functionality in the page fault paths
better by using either get_user_pages_locked or get_user_pages_unlocked.
The former allows conversion of get_user_pages invocations that will have
to pass a "&locked" parameter to know if the mmap_sem was dropped during
the call. Example from:
down_read(&mm->mmap_sem);
do_something()
get_user_pages(tsk, mm, ..., pages, NULL);
up_read(&mm->mmap_sem);
to:
int locked = 1;
do_something()
get_user_pages_locked(tsk, mm, ..., pages, &locked);
if (locked)
The latter is suitable only as a drop in replacement of the form:
into:
get_user_pages_unlocked(tsk, mm, ..., pages);
Where tsk, mm, the intermediate "..." paramters and "pages" can be any
value as before. Just the last parameter of get_user_pages (vmas) must be
NULL for get_user_pages_locked|unlocked to be usable (the latter original
form wouldn't have been safe anyway if vmas wasn't null, for the former we
just make it explicit by dropping the parameter).
If vmas is not NULL these two methods cannot be used.
Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com>
Reviewed-by: Peter Feiner <pfeiner@google.com>
We have a race condition between move_pages() and freeing hugepages, where
move_pages() calls follow_page(FOLL_GET) for hugepages internally and
tries to get its refcount without preventing concurrent freeing. This
race crashes the kernel, so this patch fixes it by moving FOLL_GET code
for hugepages into follow_huge_pmd() with taking the page table lock.
This patch intentionally removes page==NULL check after pte_page.
This is justified because pte_page() never returns NULL for any
architectures or configurations.
This patch changes the behavior of follow_huge_pmd() for tail pages and
then tail pages can be pinned/returned. So the caller must be changed to
properly handle the returned tail pages.
We could have a choice to add the similar locking to
follow_huge_(addr|pud) for consistency, but it's not necessary because
currently these functions don't support FOLL_GET flag, so let's leave it
for future development.
Here is the reproducer:
$ cat movepages.c
#include <stdio.h>
#include <stdlib.h>
#include <numaif.h>
#define ADDR_INPUT 0x700000000000UL
#define HPS 0x200000
#define PS 0x1000
int main(int argc, char *argv[]) {
int i;
int nr_hp = strtol(argv[1], NULL, 0);
int nr_p = nr_hp * HPS / PS;
int ret;
void **addrs;
int *status;
int *nodes;
pid_t pid;
pid = strtol(argv[2], NULL, 0);
addrs = malloc(sizeof(char *) * nr_p + 1);
status = malloc(sizeof(char *) * nr_p + 1);
nodes = malloc(sizeof(char *) * nr_p + 1);
while (1) {
for (i = 0; i < nr_p; i++) {
addrs[i] = (void *)ADDR_INPUT + i * PS;
nodes[i] = 1;
status[i] = 0;
ret = numa_move_pages(pid, nr_p, addrs, nodes, status,
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
nodes[i] = 0;
status[i] = 0;
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
return 0;
$ cat hugepage.c
#include <stdio.h>
#include <sys/mman.h>
#include <string.h>
char *p;
while (1) {
p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0);
if (p != (void *)ADDR_INPUT) {
perror("mmap");
break;
memset(p, 0, nr_hp * HPS);
munmap(p, nr_hp * HPS);
$ sysctl vm.nr_hugepages=40
$ ./hugepage 10 &
$ ./movepages 10 $(pgrep -f hugepage)
Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()")
Reported-by: Hugh Dickins <hughd@google.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: <stable@vger.kernel.org> [3.12+]
One bit in ->vm_flags is unused now!
Cc: Dan Carpenter <dan.carpenter@oracle.com>
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
ACCESS_ONCE does not work reliably on non-scalar types. For
example gcc 4.6 and 4.7 might remove the volatile tag for such
accesses during the SRA (scalar replacement of aggregates) step
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=58145)
Fixup gup_pmd_range.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Pull ACCESS_ONCE cleanup preparation from Christian Borntraeger:
"kernel: Provide READ_ONCE and ASSIGN_ONCE
As discussed on LKML http://marc.info/?i=54611D86.4040306%40de.ibm.com
ACCESS_ONCE might fail with specific compilers for non-scalar
accesses.
Here is a set of patches to tackle that problem.
The first patch introduce READ_ONCE and ASSIGN_ONCE. If the data
structure is larger than the machine word size memcpy is used and a
warning is emitted. The next patches fix up several in-tree users of
ACCESS_ONCE on non-scalar types.
This does not yet contain a patch that forces ACCESS_ONCE to work only
on scalar types. This is targetted for the next merge window as Linux
next already contains new offenders regarding ACCESS_ONCE vs.
non-scalar types"
s390/kvm: REPLACE barrier fixup with READ_ONCE
arm/spinlock: Replace ACCESS_ONCE with READ_ONCE
arm64/spinlock: Replace ACCESS_ONCE READ_ONCE
mips/gup: Replace ACCESS_ONCE with READ_ONCE
x86/gup: Replace ACCESS_ONCE with READ_ONCE
x86/spinlock: Replace ACCESS_ONCE with READ_ONCE
mm: replace ACCESS_ONCE with READ_ONCE or barriers
Let's change the code to access the page table elements with
READ_ONCE that does implicit scalar accesses for the gup code.
mm_find_pmd is tricky, because m68k and sparc(32bit) define pmd_t
as array of longs. This code requires just that the pmd_present
and pmd_trans_huge check are done on the same value, so a barrier
is sufficent.
A similar case is in handle_pte_fault. On ppc44x the word size is
32 bit, but a pte is 64 bit. A barrier is ok as well.
Update generic gup implementation with powerpc specific details.
On powerpc at pmd level we can have hugepte, normal pmd pointer
or a pointer to the hugepage directory.
Tested-by: Steve Capper <steve.capper@linaro.org>
Acked-by: Steve Capper <steve.capper@linaro.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This series implements general forms of get_user_pages_fast and
__get_user_pages_fast in core code and activates them for arm and arm64.
These are required for Transparent HugePages to function correctly, as a
futex on a THP tail will otherwise result in an infinite loop (due to the
core implementation of __get_user_pages_fast always returning 0).
Unfortunately, a futex on THP tail can be quite common for certain
workloads; thus THP is unreliable without a __get_user_pages_fast
implementation.
This series may also be beneficial for direct-IO heavy workloads and
certain KVM workloads.
This patch (of 6):
get_user_pages_fast() attempts to pin user pages by walking the page
tables directly and avoids taking locks. Thus the walker needs to be
protected from page table pages being freed from under it, and needs to
block any THP splits.
One way to achieve this is to have the walker disable interrupts, and rely
on IPIs from the TLB flushing code blocking before the page table pages
are freed.
On some platforms we have hardware broadcast of TLB invalidations, thus
the TLB flushing code doesn't necessarily need to broadcast IPIs; and
spuriously broadcasting IPIs can hurt system performance if done too
often.
This problem has been solved on PowerPC and Sparc by batching up page
table pages belonging to more than one mm_user, then scheduling an
rcu_sched callback to free the pages. This RCU page table free logic has
been promoted to core code and is activated when one enables
HAVE_RCU_TABLE_FREE. Unfortunately, these architectures implement their
own get_user_pages_fast routines.
The RCU page table free logic coupled with an IPI broadcast on THP split
(which is a rare event), allows one to protect a page table walker by
merely disabling the interrupts during the walk.
This patch provides a general RCU implementation of get_user_pages_fast
that can be used by architectures that perform hardware broadcast of TLB
invalidations.
It is based heavily on the PowerPC implementation by Nick Piggin.
[akpm@linux-foundation.org: various comment fixes]
Signed-off-by: Steve Capper <steve.capper@linaro.org>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
When KVM handles a tdp fault it uses FOLL_NOWAIT. If the guest memory
has been swapped out or is behind a filemap, this will trigger async
readahead and return immediately. The rationale is that KVM will kick
back the guest with an "async page fault" and allow for some other
guest process to take over.
If async PFs are enabled the fault is retried asap from an async
workqueue. If not, it's retried immediately in the same code path. In
either case the retry will not relinquish the mmap semaphore and will
block on the IO. This is a bad thing, as other mmap semaphore users
now stall as a function of swap or filemap latency.
This patch ensures both the regular and async PF path re-enter the
fault allowing for the mmap semaphore to be relinquished in the case
of IO wait.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Add a comment describing the circumstances in which
__lock_page_or_retry() will or will not release the mmap_sem when
returning 0.
Add comments to lock_page_or_retry()'s callers (filemap_fault(),
do_swap_page()) noting the impact on VM_FAULT_RETRY returns.
Add comments on up the call tree, particularly replacing the false "We
return with mmap_sem still held" comments.
Signed-off-by: Paul Cassella <cassella@cray.com>
Get rid of two nested loops over nr_pages, extract vma flags checking to
separate function and other random cleanups.
Nesting level in __get_user_pages() is just insane. Let's try to fix it
a bit.
Cleanups:
- move pte-related code to separate function. It's about half of the
function;
- get rid of some goto-logic;
- use 'return NULL' instead of 'return page' where page can only be
NULL;
The case is special and disturb from reading main __get_user_pages()
code path. Let's move it to separate function.
mm/memory.c is overloaded: over 4k lines. get_user_pages() code is
pretty much self-contained let's move it to separate file.
No other changes made.
