path: root/mm/init-mm.c
2017-01-06mm: Add a user_ns owner to mm_struct and fix ptrace permission checksEric W. Biederman
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream. During exec dumpable is cleared if the file that is being executed is not readable by the user executing the file. A bug in ptrace_may_access allows reading the file if the executable happens to enter into a subordinate user namespace (aka clone(CLONE_NEWUSER), unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER). This problem is fixed with only necessary userspace breakage by adding a user namespace owner to mm_struct, captured at the time of exec, so it is clear in which user namespace CAP_SYS_PTRACE must be present in to be able to safely give read permission to the executable. The function ptrace_may_access is modified to verify that the ptracer has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns. This ensures that if the task changes it's cred into a subordinate user namespace it does not become ptraceable. The function ptrace_attach is modified to only set PT_PTRACE_CAP when CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of PT_PTRACE_CAP is to be a flag to note that whatever permission changes the task might go through the tracer has sufficient permissions for it not to be an issue. task->cred->user_ns is always the same as or descendent of mm->user_ns. Which guarantees that having CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks credentials. To prevent regressions mm->dumpable and mm->user_ns are not considered when a task has no mm. As simply failing ptrace_may_attach causes regressions in privileged applications attempting to read things such as /proc/<pid>/stat Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Cyrill Gorcunov <gorcunov@openvz.org> Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: convert mm->cpu_vm_cpumask into cpumask_var_tKOSAKI Motohiro
cpumask_t is very big struct and cpu_vm_mask is placed wrong position. It might lead to reduce cache hit ratio. This patch has two change. 1) Move the place of cpumask into last of mm_struct. Because usually cpumask is accessed only front bits when the system has cpu-hotplug capability 2) Convert cpu_vm_mask into cpumask_var_t. It may help to reduce memory footprint if cpumask_size() will use nr_cpumask_bits properly in future. In addition, this patch change the name of cpu_vm_mask with cpu_vm_mask_var. It may help to detect out of tree cpu_vm_mask users. This patch has no functional change. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Hugh Dickins <hughd@google.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: provide init_mm mm_context initializerHeiko Carstens
Provide an INIT_MM_CONTEXT intializer macro which can be used to statically initialize mm_struct:mm_context of init_mm. This way we can get rid of code which will do the initialization at run time (on s390). In addition the current code can be found at a place where it is not expected. So let's have a common initializer which architectures can use if needed. This is based on a patch from Suzuki Poulose. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Suzuki Poulose <suzuki@in.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
