path: root/mm/internal.h
2020-01-09mm: drop mmap_sem before calling balance_dirty_pages() in write faultJohannes Weiner
[ Upstream commit 89b15332af7c0312a41e50846819ca6613b58b4c ] One of our services is observing hanging ps/top/etc under heavy write IO, and the task states show this is an mmap_sem priority inversion: A write fault is holding the mmap_sem in read-mode and waiting for (heavily cgroup-limited) IO in balance_dirty_pages(): balance_dirty_pages+0x724/0x905 balance_dirty_pages_ratelimited+0x254/0x390 fault_dirty_shared_page.isra.96+0x4a/0x90 do_wp_page+0x33e/0x400 __handle_mm_fault+0x6f0/0xfa0 handle_mm_fault+0xe4/0x200 __do_page_fault+0x22b/0x4a0 page_fault+0x45/0x50 Somebody tries to change the address space, contending for the mmap_sem in write-mode: call_rwsem_down_write_failed_killable+0x13/0x20 do_mprotect_pkey+0xa8/0x330 SyS_mprotect+0xf/0x20 do_syscall_64+0x5b/0x100 entry_SYSCALL_64_after_hwframe+0x3d/0xa2 The waiting writer locks out all subsequent readers to avoid lock starvation, and several threads can be seen hanging like this: call_rwsem_down_read_failed+0x14/0x30 proc_pid_cmdline_read+0xa0/0x480 __vfs_read+0x23/0x140 vfs_read+0x87/0x130 SyS_read+0x42/0x90 do_syscall_64+0x5b/0x100 entry_SYSCALL_64_after_hwframe+0x3d/0xa2 To fix this, do what we do for cache read faults already: drop the mmap_sem before calling into anything IO bound, in this case the balance_dirty_pages() function, and return VM_FAULT_RETRY. Link: http://lkml.kernel.org/r/20190924194238.GA29030@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Josef Bacik <josef@toxicpanda.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-09-25mm: introduce MADV_COLDMinchan Kim
Patch series "Introduce MADV_COLD and MADV_PAGEOUT", v7. - Background The Android terminology used for forking a new process and starting an app from scratch is a cold start, while resuming an existing app is a hot start. While we continually try to improve the performance of cold starts, hot starts will always be significantly less power hungry as well as faster so we are trying to make hot start more likely than cold start. To increase hot start, Android userspace manages the order that apps should be killed in a process called ActivityManagerService. ActivityManagerService tracks every Android app or service that the user could be interacting with at any time and translates that into a ranked list for lmkd(low memory killer daemon). They are likely to be killed by lmkd if the system has to reclaim memory. In that sense they are similar to entries in any other cache. Those apps are kept alive for opportunistic performance improvements but those performance improvements will vary based on the memory requirements of individual workloads. - Problem Naturally, cached apps were dominant consumers of memory on the system. However, they were not significant consumers of swap even though they are good candidate for swap. Under investigation, swapping out only begins once the low zone watermark is hit and kswapd wakes up, but the overall allocation rate in the system might trip lmkd thresholds and cause a cached process to be killed(we measured performance swapping out vs. zapping the memory by killing a process. Unsurprisingly, zapping is 10x times faster even though we use zram which is much faster than real storage) so kill from lmkd will often satisfy the high zone watermark, resulting in very few pages actually being moved to swap. - Approach The approach we chose was to use a new interface to allow userspace to proactively reclaim entire processes by leveraging platform information. This allowed us to bypass the inaccuracy of the kernel’s LRUs for pages that are known to be cold from userspace and to avoid races with lmkd by reclaiming apps as soon as they entered the cached state. Additionally, it could provide many chances for platform to use much information to optimize memory efficiency. To achieve the goal, the patchset introduce two new options for madvise. One is MADV_COLD which will deactivate activated pages and the other is MADV_PAGEOUT which will reclaim private pages instantly. These new options complement MADV_DONTNEED and MADV_FREE by adding non-destructive ways to gain some free memory space. MADV_PAGEOUT is similar to MADV_DONTNEED in a way that it hints the kernel that memory region is not currently needed and should be reclaimed immediately; MADV_COLD is similar to MADV_FREE in a way that it hints the kernel that memory region is not currently needed and should be reclaimed when memory pressure rises. This patch (of 5): When a process expects no accesses to a certain memory range, it could give a hint to kernel that the pages can be reclaimed when memory pressure happens but data should be preserved for future use. This could reduce workingset eviction so it ends up increasing performance. This patch introduces the new MADV_COLD hint to madvise(2) syscall. MADV_COLD can be used by a process to mark a memory range as not expected to be used in the near future. The hint can help kernel in deciding which pages to evict early during memory pressure. It works for every LRU pages like MADV_[DONTNEED|FREE]. IOW, It moves active file page -> inactive file LRU active anon page -> inacdtive anon LRU Unlike MADV_FREE, it doesn't move active anonymous pages to inactive file LRU's head because MADV_COLD is a little bit different symantic. MADV_FREE means it's okay to discard when the memory pressure because the content of the page is *garbage* so freeing such pages is almost zero overhead since we don't need to swap out and access afterward causes just minor fault. Thus, it would make sense to put those freeable pages in inactive file LRU to compete other used-once pages. It makes sense for implmentaion point of view, too because it's not swapbacked memory any longer until it would be re-dirtied. Even, it could give a bonus to make them be reclaimed on swapless system. However, MADV_COLD doesn't mean garbage so reclaiming them requires swap-out/in in the end so it's bigger cost. Since we have designed VM LRU aging based on cost-model, anonymous cold pages would be better to position inactive anon's LRU list, not file LRU. Furthermore, it would help to avoid unnecessary scanning if system doesn't have a swap device. Let's start simpler way without adding complexity at this moment. However, keep in mind, too that it's a caveat that workloads with a lot of pages cache are likely to ignore MADV_COLD on anonymous memory because we rarely age anonymous LRU lists. * man-page material MADV_COLD (since Linux x.x) Pages in the specified regions will be treated as less-recently-accessed compared to pages in the system with similar access frequencies. In contrast to MADV_FREE, the contents of the region are preserved regardless of subsequent writes to pages. MADV_COLD cannot be applied to locked pages, Huge TLB pages, or VM_PFNMAP pages. [akpm@linux-foundation.org: resolve conflicts with hmm.git] Link: http://lkml.kernel.org/r/20190726023435.214162-2-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: kbuild test robot <lkp@intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Chris Zankel <chris@zankel.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Daniel Colascione <dancol@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Hillf Danton <hdanton@sina.com> Cc: Joel Fernandes (Google) <joel@joelfernandes.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Oleksandr Natalenko <oleksandr@redhat.com> Cc: Shakeel Butt <shakeelb@google.com> Cc: Sonny Rao <sonnyrao@google.com> Cc: Suren Baghdasaryan <surenb@google.com> Cc: Tim Murray <timmurray@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-05mm, compaction: capture a page under direct compactionMel Gorman
Compaction is inherently race-prone as a suitable page freed during compaction can be allocated by any parallel task. This patch uses a capture_control structure to isolate a page immediately when it is freed by a direct compactor in the slow path of the page allocator. The intent is to avoid redundant scanning. 5.0.0-rc1 5.0.0-rc1 selective-v3r17 capture-v3r19 Amean fault-both-1 0.00 ( 0.00%) 0.00 * 0.00%* Amean fault-both-3 2582.11 ( 0.00%) 2563.68 ( 0.71%) Amean fault-both-5 4500.26 ( 0.00%) 4233.52 ( 5.93%) Amean fault-both-7 5819.53 ( 0.00%) 6333.65 ( -8.83%) Amean fault-both-12 9321.18 ( 0.00%) 9759.38 ( -4.70%) Amean fault-both-18 9782.76 ( 0.00%) 10338.76 ( -5.68%) Amean fault-both-24 15272.81 ( 0.00%) 13379.55 * 12.40%* Amean fault-both-30 15121.34 ( 0.00%) 16158.25 ( -6.86%) Amean fault-both-32 18466.67 ( 0.00%) 18971.21 ( -2.73%) Latency is only moderately affected but the devil is in the details. A closer examination indicates that base page fault latency is reduced but latency of huge pages is increased as it takes creater care to succeed. Part of the "problem" is that allocation success rates are close to 100% even when under pressure and compaction gets harder 5.0.0-rc1 5.0.0-rc1 selective-v3r17 capture-v3r19 Percentage huge-3 96.70 ( 0.00%) 98.23 ( 1.58%) Percentage huge-5 96.99 ( 0.00%) 95.30 ( -1.75%) Percentage huge-7 94.19 ( 0.00%) 97.24 ( 3.24%) Percentage huge-12 94.95 ( 0.00%) 97.35 ( 2.53%) Percentage huge-18 96.74 ( 0.00%) 97.30 ( 0.58%) Percentage huge-24 97.07 ( 0.00%) 97.55 ( 0.50%) Percentage huge-30 95.69 ( 0.00%) 98.50 ( 2.95%) Percentage huge-32 96.70 ( 0.00%) 99.27 ( 2.65%) And scan rates are reduced as expected by 6% for the migration scanner and 29% for the free scanner indicating that there is less redundant work. Compaction migrate scanned 20815362 19573286 Compaction free scanned 16352612 11510663 [mgorman@techsingularity.net: remove redundant check] Link: http://lkml.kernel.org/r/20190201143853.GH9565@techsingularity.net Link: http://lkml.kernel.org/r/20190118175136.31341-23-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: round-robin the order while searching the free lists for a ↵Mel Gorman
target As compaction proceeds and creates high-order blocks, the free list search gets less efficient as the larger blocks are used as compaction targets. Eventually, the larger blocks will be behind the migration scanner for partially migrated pageblocks and the search fails. This patch round-robins what orders are searched so that larger blocks can be ignored and find smaller blocks that can be used as migration targets. The overall impact was small on 1-socket but it avoids corner cases where the migration/free scanners meet prematurely or situations where many of the pageblocks encountered by the free scanner are almost full instead of being properly packed. Previous testing had indicated that without this patch there were occasional large spikes in the free scanner without this patch. [dan.carpenter@oracle.com: fix static checker warning] Link: http://lkml.kernel.org/r/20190118175136.31341-20-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: avoid rescanning the same pageblock multiple timesMel Gorman
Pageblocks are marked for skip when no pages are isolated after a scan. However, it's possible to hit corner cases where the migration scanner gets stuck near the boundary between the source and target scanner. Due to pages being migrated in blocks of COMPACT_CLUSTER_MAX, pages that are migrated can be reallocated before the pageblock is complete. The pageblock is not necessarily skipped so it can be rescanned multiple times. Similarly, a pageblock with some dirty/writeback pages may fail to migrate and be rescanned until writeback completes which is wasteful. This patch tracks if a pageblock is being rescanned. If so, then the entire pageblock will be migrated as one operation. This narrows the race window during which pages can be reallocated during migration. Secondly, if there are pages that cannot be isolated then the pageblock will still be fully scanned and marked for skipping. On the second rescan, the pageblock skip is set and the migration scanner makes progress. 5.0.0-rc1 5.0.0-rc1 findfree-v3r16 norescan-v3r16 Amean fault-both-1 0.00 ( 0.00%) 0.00 * 0.00%* Amean fault-both-3 3200.68 ( 0.00%) 3002.07 ( 6.21%) Amean fault-both-5 4847.75 ( 0.00%) 4684.47 ( 3.37%) Amean fault-both-7 6658.92 ( 0.00%) 6815.54 ( -2.35%) Amean fault-both-12 11077.62 ( 0.00%) 10864.02 ( 1.93%) Amean fault-both-18 12403.97 ( 0.00%) 12247.52 ( 1.26%) Amean fault-both-24 15607.10 ( 0.00%) 15683.99 ( -0.49%) Amean fault-both-30 18752.27 ( 0.00%) 18620.02 ( 0.71%) Amean fault-both-32 21207.54 ( 0.00%) 19250.28 * 9.23%* 5.0.0-rc1 5.0.0-rc1 findfree-v3r16 norescan-v3r16 Percentage huge-3 96.86 ( 0.00%) 95.00 ( -1.91%) Percentage huge-5 93.72 ( 0.00%) 94.22 ( 0.53%) Percentage huge-7 94.31 ( 0.00%) 92.35 ( -2.08%) Percentage huge-12 92.66 ( 0.00%) 91.90 ( -0.82%) Percentage huge-18 91.51 ( 0.00%) 89.58 ( -2.11%) Percentage huge-24 90.50 ( 0.00%) 90.03 ( -0.52%) Percentage huge-30 91.57 ( 0.00%) 89.14 ( -2.65%) Percentage huge-32 91.00 ( 0.00%) 90.58 ( -0.46%) Negligible difference but this was likely a case when the specific corner case was not hit. A previous run of the same patch based on an earlier iteration of the series showed large differences where migration rates could be halved when the corner case was hit. The specific corner case where migration scan rates go through the roof was due to a dirty/writeback pageblock located at the boundary of the migration/free scanner did not happen in this case. When it does happen, the scan rates multipled by massive margins. Link: http://lkml.kernel.org/r/20190118175136.31341-13-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: use free lists to quickly locate a migration sourceMel Gorman
The migration scanner is a linear scan of a zone with a potentiall large search space. Furthermore, many pageblocks are unusable such as those filled with reserved pages or partially filled with pages that cannot migrate. These still get scanned in the common case of allocating a THP and the cost accumulates. The patch uses a partial search of the free lists to locate a migration source candidate that is marked as MOVABLE when allocating a THP. It prefers picking a block with a larger number of free pages already on the basis that there are fewer pages to migrate to free the entire block. The lowest PFN found during searches is tracked as the basis of the start for the linear search after the first search of the free list fails. After the search, the free list is shuffled so that the next search will not encounter the same page. If the search fails then the subsequent searches will be shorter and the linear scanner is used. If this search fails, or if the request is for a small or unmovable/reclaimable allocation then the linear scanner is still used. It is somewhat pointless to use the list search in those cases. Small free pages must be used for the search and there is no guarantee that movable pages are located within that block that are contiguous. 5.0.0-rc1 5.0.0-rc1 noboost-v3r10 findmig-v3r15 Amean fault-both-3 3771.41 ( 0.00%) 3390.40 ( 10.10%) Amean fault-both-5 5409.05 ( 0.00%) 5082.28 ( 6.04%) Amean fault-both-7 7040.74 ( 0.00%) 7012.51 ( 0.40%) Amean fault-both-12 11887.35 ( 0.00%) 11346.63 ( 4.55%) Amean fault-both-18 16718.19 ( 0.00%) 15324.19 ( 8.34%) Amean fault-both-24 21157.19 ( 0.00%) 16088.50 * 23.96%* Amean fault-both-30 21175.92 ( 0.00%) 18723.42 * 11.58%* Amean fault-both-32 21339.03 ( 0.00%) 18612.01 * 12.78%* 5.0.0-rc1 5.0.0-rc1 noboost-v3r10 findmig-v3r15 Percentage huge-3 86.50 ( 0.00%) 89.83 ( 3.85%) Percentage huge-5 92.52 ( 0.00%) 91.96 ( -0.61%) Percentage huge-7 92.44 ( 0.00%) 92.85 ( 0.44%) Percentage huge-12 92.98 ( 0.00%) 92.74 ( -0.25%) Percentage huge-18 91.70 ( 0.00%) 91.71 ( 0.02%) Percentage huge-24 91.59 ( 0.00%) 92.13 ( 0.60%) Percentage huge-30 90.14 ( 0.00%) 93.79 ( 4.04%) Percentage huge-32 90.03 ( 0.00%) 91.27 ( 1.37%) This shows an improvement in allocation latencies with similar allocation success rates. While not presented, there was a 31% reduction in migration scanning and a 8% reduction on system CPU usage. A 2-socket machine showed similar benefits. [mgorman@techsingularity.net: several fixes] Link: http://lkml.kernel.org/r/20190204120111.GL9565@techsingularity.net [vbabka@suse.cz: migrate block that was found-fast, some optimisations] Link: http://lkml.kernel.org/r/20190118175136.31341-10-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <Vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: always finish scanning of a full pageblockMel Gorman
When compaction is finishing, it uses a flag to ensure the pageblock is complete but it makes sense to always complete migration of a pageblock. Minimally, skip information is based on a pageblock and partially scanned pageblocks may incur more scanning in the future. The pageblock skip handling also becomes more strict later in the series and the hint is more useful if a complete pageblock was always scanned. The potentially impacts latency as more scanning is done but it's not a consistent win or loss as the scanning is not always a high percentage of the pageblock and sometimes it is offset by future reductions in scanning. Hence, the results are not presented this time due to a misleading mix of gains/losses without any clear pattern. However, full scanning of the pageblock is important for later patches. Link: http://lkml.kernel.org/r/20190118175136.31341-8-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: remove last_migrated_pfn from compact_controlMel Gorman
The last_migrated_pfn field is a bit dubious as to whether it really helps but either way, the information from it can be inferred without increasing the size of compact_control so remove the field. Link: http://lkml.kernel.org/r/20190118175136.31341-4-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: rearrange compact_controlMel Gorman
compact_control spans two cache lines with write-intensive lines on both. Rearrange so the most write-intensive fields are in the same cache line. This has a negligible impact on the overall performance of compaction and is more a tidying exercise than anything. Link: http://lkml.kernel.org/r/20190118175136.31341-3-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm, compaction: shrink compact_controlMel Gorman
Patch series "Increase success rates and reduce latency of compaction", v3. This series reduces scan rates and success rates of compaction, primarily by using the free lists to shorten scans, better controlling of skip information and whether multiple scanners can target the same block and capturing pageblocks before being stolen by parallel requests. The series is based on mmotm from January 9th, 2019 with the previous compaction series reverted. I'm mostly using thpscale to measure the impact of the series. The benchmark creates a large file, maps it, faults it, punches holes in the mapping so that the virtual address space is fragmented and then tries to allocate THP. It re-executes for different numbers of threads. From a fragmentation perspective, the workload is relatively benign but it does stress compaction. The overall impact on latencies for a 1-socket machine is baseline patches Amean fault-both-3 3832.09 ( 0.00%) 2748.56 * 28.28%* Amean fault-both-5 4933.06 ( 0.00%) 4255.52 ( 13.73%) Amean fault-both-7 7017.75 ( 0.00%) 6586.93 ( 6.14%) Amean fault-both-12 11610.51 ( 0.00%) 9162.34 * 21.09%* Amean fault-both-18 17055.85 ( 0.00%) 11530.06 * 32.40%* Amean fault-both-24 19306.27 ( 0.00%) 17956.13 ( 6.99%) Amean fault-both-30 22516.49 ( 0.00%) 15686.47 * 30.33%* Amean fault-both-32 23442.93 ( 0.00%) 16564.83 * 29.34%* The allocation success rates are much improved baseline patches Percentage huge-3 85.99 ( 0.00%) 97.96 ( 13.92%) Percentage huge-5 88.27 ( 0.00%) 96.87 ( 9.74%) Percentage huge-7 85.87 ( 0.00%) 94.53 ( 10.09%) Percentage huge-12 82.38 ( 0.00%) 98.44 ( 19.49%) Percentage huge-18 83.29 ( 0.00%) 99.14 ( 19.04%) Percentage huge-24 81.41 ( 0.00%) 97.35 ( 19.57%) Percentage huge-30 80.98 ( 0.00%) 98.05 ( 21.08%) Percentage huge-32 80.53 ( 0.00%) 97.06 ( 20.53%) That's a nearly perfect allocation success rate. The biggest impact is on the scan rates Compaction migrate scanned 55893379 19341254 Compaction free scanned 474739990 11903963 The number of pages scanned for migration was reduced by 65% and the free scanner was reduced by 97.5%. So much less work in exchange for lower latency and better success rates. The series was also evaluated using a workload that heavily fragments memory but the benefits there are also significant, albeit not presented. It was commented that we should be rethinking scanning entirely and to a large extent I agree. However, to achieve that you need a lot of this series in place first so it's best to make the linear scanners as best as possible before ripping them out. This patch (of 22): The isolate and migrate scanners should never isolate more than a pageblock of pages so unsigned int is sufficient saving 8 bytes on a 64-bit build. Link: http://lkml.kernel.org/r/20190118175136.31341-2-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-05mm/page_alloc.c: memory hotplug: free pages as higher orderArun KS
When freeing pages are done with higher order, time spent on coalescing pages by buddy allocator can be reduced. With section size of 256MB, hot add latency of a single section shows improvement from 50-60 ms to less than 1 ms, hence improving the hot add latency by 60 times. Modify external providers of online callback to align with the change. [arunks@codeaurora.org: v11] Link: http://lkml.kernel.org/r/1547792588-18032-1-git-send-email-arunks@codeaurora.org [akpm@linux-foundation.org: remove unused local, per Arun] [akpm@linux-foundation.org: avoid return of void-returning __free_pages_core(), per Oscar] [akpm@linux-foundation.org: fix it for mm-convert-totalram_pages-and-totalhigh_pages-variables-to-atomic.patch] [arunks@codeaurora.org: v8] Link: http://lkml.kernel.org/r/1547032395-24582-1-git-send-email-arunks@codeaurora.org [arunks@codeaurora.org: v9] Link: http://lkml.kernel.org/r/1547098543-26452-1-git-send-email-arunks@codeaurora.org Link: http://lkml.kernel.org/r/1538727006-5727-1-git-send-email-arunks@codeaurora.org Signed-off-by: Arun KS <arunks@codeaurora.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Reviewed-by: Alexander Duyck <alexander.h.duyck@linux.intel.com> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: Stephen Hemminger <sthemmin@microsoft.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Juergen Gross <jgross@suse.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mathieu Malaterre <malat@debian.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Souptick Joarder <jrdr.linux@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Aaron Lu <aaron.lu@intel.com> Cc: Srivatsa Vaddagiri <vatsa@codeaurora.org> Cc: Vinayak Menon <vinmenon@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-28mm: use alloc_flags to record if kswapd can wakeMel Gorman
This is a preparation patch that copies the GFP flag __GFP_KSWAPD_RECLAIM into alloc_flags. This is a preparation patch only that avoids having to pass gfp_mask through a long callchain in a future patch. Note that the setting in the fast path happens in alloc_flags_nofragment() and it may be claimed that this has nothing to do with ALLOC_NO_FRAGMENT. That's true in this patch but is not true later so it's done now for easier review to show where the flag needs to be recorded. No functional change. [mgorman@techsingularity.net: ALLOC_KSWAPD flag needs to be applied in the !CONFIG_ZONE_DMA32 case] Link: http://lkml.kernel.org/r/20181126143503.GO23260@techsingularity.net Link: http://lkml.kernel.org/r/20181123114528.28802-4-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zi Yan <zi.yan@cs.rutgers.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-28mm, page_alloc: spread allocations across zones before introducing fragmentationMel Gorman
Patch series "Fragmentation avoidance improvements", v5. It has been noted before that fragmentation avoidance (aka anti-fragmentation) is not perfect. Given sufficient time or an adverse workload, memory gets fragmented and the long-term success of high-order allocations degrades. This series defines an adverse workload, a definition of external fragmentation events (including serious) ones and a series that reduces the level of those fragmentation events. The details of the workload and the consequences are described in more detail in the changelogs. However, from patch 1, this is a high-level summary of the adverse workload. The exact details are found in the mmtests implementation. The broad details of the workload are as follows; 1. Create an XFS filesystem (not specified in the configuration but done as part of the testing for this patch) 2. Start 4 fio threads that write a number of 64K files inefficiently. Inefficiently means that files are created on first access and not created in advance (fio parameterr create_on_open=1) and fallocate is not used (fallocate=none). With multiple IO issuers this creates a mix of slab and page cache allocations over time. The total size of the files is 150% physical memory so that the slabs and page cache pages get mixed 3. Warm up a number of fio read-only threads accessing the same files created in step 2. This part runs for the same length of time it took to create the files. It'll fault back in old data and further interleave slab and page cache allocations. As it's now low on memory due to step 2, fragmentation occurs as pageblocks get stolen. 4. While step 3 is still running, start a process that tries to allocate 75% of memory as huge pages with a number of threads. The number of threads is based on a (NR_CPUS_SOCKET - NR_FIO_THREADS)/4 to avoid THP threads contending with fio, any other threads or forcing cross-NUMA scheduling. Note that the test has not been used on a machine with less than 8 cores. The benchmark records whether huge pages were allocated and what the fault latency was in microseconds 5. Measure the number of events potentially causing external fragmentation, the fault latency and the huge page allocation success rate. 6. Cleanup Overall the series reduces external fragmentation causing events by over 94% on 1 and 2 socket machines, which in turn impacts high-order allocation success rates over the long term. There are differences in latencies and high-order allocation success rates. Latencies are a mixed bag as they are vulnerable to exact system state and whether allocations succeeded so they are treated as a secondary metric. Patch 1 uses lower zones if they are populated and have free memory instead of fragmenting a higher zone. It's special cased to handle a Normal->DMA32 fallback with the reasons explained in the changelog. Patch 2-4 boosts watermarks temporarily when an external fragmentation event occurs. kswapd wakes to reclaim a small amount of old memory and then wakes kcompactd on completion to recover the system slightly. This introduces some overhead in the slowpath. The level of boosting can be tuned or disabled depending on the tolerance for fragmentation vs allocation latency. Patch 5 stalls some movable allocation requests to let kswapd from patch 4 make some progress. The duration of the stalls is very low but it is possible to tune the system to avoid fragmentation events if larger stalls can be tolerated. The bulk of the improvement in fragmentation avoidance is from patches 1-4 but patch 5 can deal with a rare corner case and provides the option of tuning a system for THP allocation success rates in exchange for some stalls to control fragmentation. This patch (of 5): The page allocator zone lists are iterated based on the watermarks of each zone which does not take anti-fragmentation into account. On x86, node 0 may have multiple zones while other nodes have one zone. A consequence is that tasks running on node 0 may fragment ZONE_NORMAL even though ZONE_DMA32 has plenty of free memory. This patch special cases the allocator fast path such that it'll try an allocation from a lower local zone before fragmenting a higher zone. In this case, stealing of pageblocks or orders larger than a pageblock are still allowed in the fast path as they are uninteresting from a fragmentation point of view. This was evaluated using a benchmark designed to fragment memory before attempting THP allocations. It's implemented in mmtests as the following configurations configs/config-global-dhp__workload_thpfioscale configs/config-global-dhp__workload_thpfioscale-defrag configs/config-global-dhp__workload_thpfioscale-madvhugepage e.g. from mmtests ./run-mmtests.sh --run-monitor --config configs/config-global-dhp__workload_thpfioscale test-run-1 The broad details of the workload are as follows; 1. Create an XFS filesystem (not specified in the configuration but done as part of the testing for this patch). 2. Start 4 fio threads that write a number of 64K files inefficiently. Inefficiently means that files are created on first access and not created in advance (fio parameter create_on_open=1) and fallocate is not used (fallocate=none). With multiple IO issuers this creates a mix of slab and page cache allocations over time. The total size of the files is 150% physical memory so that the slabs and page cache pages get mixed. 3. Warm up a number of fio read-only processes accessing the same files created in step 2. This part runs for the same length of time it took to create the files. It'll refault old data and further interleave slab and page cache allocations. As it's now low on memory due to step 2, fragmentation occurs as pageblocks get stolen. 4. While step 3 is still running, start a process that tries to allocate 75% of memory as huge pages with a number of threads. The number of threads is based on a (NR_CPUS_SOCKET - NR_FIO_THREADS)/4 to avoid THP threads contending with fio, any other threads or forcing cross-NUMA scheduling. Note that the test has not been used on a machine with less than 8 cores. The benchmark records whether huge pages were allocated and what the fault latency was in microseconds. 5. Measure the number of events potentially causing external fragmentation, the fault latency and the huge page allocation success rate. 6. Cleanup the test files. Note that due to the use of IO and page cache that this benchmark is not suitable for running on large machines where the time to fragment memory may be excessive. Also note that while this is one mix that generates fragmentation that it's not the only mix that generates fragmentation. Differences in workload that are more slab-intensive or whether SLUB is used with high-order pages may yield different results. When the page allocator fragments memory, it records the event using the mm_page_alloc_extfrag ftrace event. If the fallback_order is smaller than a pageblock order (order-9 on 64-bit x86) then it's considered to be an "external fragmentation event" that may cause issues in the future. Hence, the primary metric here is the number of external fragmentation events that occur with order < 9. The secondary metric is allocation latency and huge page allocation success rates but note that differences in latencies and what the success rate also can affect the number of external fragmentation event which is why it's a secondary metric. 1-socket Skylake machine config-global-dhp__workload_thpfioscale XFS (no special madvise) 4 fio threads, 1 THP allocating thread -------------------------------------- 4.20-rc3 extfrag events < order 9: 804694 4.20-rc3+patch: 408912 (49% reduction) thpfioscale Fault Latencies 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Amean fault-base-1 662.92 ( 0.00%) 653.58 * 1.41%* Amean fault-huge-1 0.00 ( 0.00%) 0.00 ( 0.00%) 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Percentage huge-1 0.00 ( 0.00%) 0.00 ( 0.00%) Fault latencies are slightly reduced while allocation success rates remain at zero as this configuration does not make any special effort to allocate THP and fio is heavily active at the time and either filling memory or keeping pages resident. However, a 49% reduction of serious fragmentation events reduces the changes of external fragmentation being a problem in the future. Vlastimil asked during review for a breakdown of the allocation types that are falling back. vanilla 3816 MIGRATE_UNMOVABLE 800845 MIGRATE_MOVABLE 33 MIGRATE_UNRECLAIMABLE patch 735 MIGRATE_UNMOVABLE 408135 MIGRATE_MOVABLE 42 MIGRATE_UNRECLAIMABLE The majority of the fallbacks are due to movable allocations and this is consistent for the workload throughout the series so will not be presented again as the primary source of fallbacks are movable allocations. Movable fallbacks are sometimes considered "ok" to fallback because they can be migrated. The problem is that they can fill an unmovable/reclaimable pageblock causing those allocations to fallback later and polluting pageblocks with pages that cannot move. If there is a movable fallback, it is pretty much guaranteed to affect an unmovable/reclaimable pageblock and while it might not be enough to actually cause a unmovable/reclaimable fallback in the future, we cannot know that in advance so the patch takes the only option available to it. Hence, it's important to control them. This point is also consistent throughout the series and will not be repeated. 1-socket Skylake machine global-dhp__workload_thpfioscale-madvhugepage-xfs (MADV_HUGEPAGE) ----------------------------------------------------------------- 4.20-rc3 extfrag events < order 9: 291392 4.20-rc3+patch: 191187 (34% reduction) thpfioscale Fault Latencies 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Amean fault-base-1 1495.14 ( 0.00%) 1467.55 ( 1.85%) Amean fault-huge-1 1098.48 ( 0.00%) 1127.11 ( -2.61%) thpfioscale Percentage Faults Huge 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Percentage huge-1 78.57 ( 0.00%) 77.64 ( -1.18%) Fragmentation events were reduced quite a bit although this is known to be a little variable. The latencies and allocation success rates are similar but they were already quite high. 2-socket Haswell machine config-global-dhp__workload_thpfioscale XFS (no special madvise) 4 fio threads, 5 THP allocating threads ---------------------------------------------------------------- 4.20-rc3 extfrag events < order 9: 215698 4.20-rc3+patch: 200210 (7% reduction) thpfioscale Fault Latencies 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Amean fault-base-5 1350.05 ( 0.00%) 1346.45 ( 0.27%) Amean fault-huge-5 4181.01 ( 0.00%) 3418.60 ( 18.24%) 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Percentage huge-5 1.15 ( 0.00%) 0.78 ( -31.88%) The reduction of external fragmentation events is slight and this is partially due to the removal of __GFP_THISNODE in commit ac5b2c18911f ("mm: thp: relax __GFP_THISNODE for MADV_HUGEPAGE mappings") as THP allocations can now spill over to remote nodes instead of fragmenting local memory. 2-socket Haswell machine global-dhp__workload_thpfioscale-madvhugepage-xfs (MADV_HUGEPAGE) ----------------------------------------------------------------- 4.20-rc3 extfrag events < order 9: 166352 4.20-rc3+patch: 147463 (11% reduction) thpfioscale Fault Latencies 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Amean fault-base-5 6138.97 ( 0.00%) 6217.43 ( -1.28%) Amean fault-huge-5 2294.28 ( 0.00%) 3163.33 * -37.88%* thpfioscale Percentage Faults Huge 4.20.0-rc3 4.20.0-rc3 vanilla lowzone-v5r8 Percentage huge-5 96.82 ( 0.00%) 95.14 ( -1.74%) There was a slight reduction in external fragmentation events although the latencies were higher. The allocation success rate is high enough that the system is struggling and there is quite a lot of parallel reclaim and compaction activity. There is also a certain degree of luck on whether processes start on node 0 or not for this patch but the relevance is reduced later in the series. Overall, the patch reduces the number of external fragmentation causing events so the success of THP over long periods of time would be improved for this adverse workload. Link: http://lkml.kernel.org/r/20181123114528.28802-2-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Zi Yan <zi.yan@cs.rutgers.edu> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-28vmscan: return NODE_RECLAIM_NOSCAN in node_reclaim() when CONFIG_NUMA is nWei Yang
Commit fa5e084e43eb ("vmscan: do not unconditionally treat zones that fail zone_reclaim() as full") changed the return value of node_reclaim(). The original return value 0 means NODE_RECLAIM_SOME after this commit. While the return value of node_reclaim() when CONFIG_NUMA is n is not changed. This will leads to call zone_watermark_ok() again. This patch fixes the return value by adjusting to NODE_RECLAIM_NOSCAN. Since node_reclaim() is only called in page_alloc.c, move it to mm/internal.h. Link: http://lkml.kernel.org/r/20181113080436.22078-1-richard.weiyang@gmail.com Signed-off-by: Wei Yang <richard.weiyang@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Matthew Wilcox <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: rename __free_pages_bootmem to memblock_free_pagesMike Rapoport
The conversion is done using sed -i 's@__free_pages_bootmem@memblock_free_pages@' \ $(git grep -l __free_pages_bootmem) Link: http://lkml.kernel.org/r/1536927045-23536-27-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-23mm: Change return type int to vm_fault_t for fault handlersSouptick Joarder
Use new return type vm_fault_t for fault handler. For now, this is just documenting that the function returns a VM_FAULT value rather than an errno. Once all instances are converted, vm_fault_t will become a distinct type. Ref-> commit 1c8f422059ae ("mm: change return type to vm_fault_t") The aim is to change the return type of finish_fault() and handle_mm_fault() to vm_fault_t type. As part of that clean up return type of all other recursively called functions have been changed to vm_fault_t type. The places from where handle_mm_fault() is getting invoked will be change to vm_fault_t type but in a separate patch. vmf_error() is the newly introduce inline function in 4.17-rc6. [akpm@linux-foundation.org: don't shadow outer local `ret' in __do_huge_pmd_anonymous_page()] Link: http://lkml.kernel.org/r/20180604171727.GA20279@jordon-HP-15-Notebook-PC Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Matthew Wilcox <willy@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-22mm: remove __paginginitPavel Tatashin
__paginginit is the same thing as __meminit except for platforms without sparsemem, there it is defined as __init. Remove __paginginit and use __meminit. Use __ref in one single function that merges __meminit and __init sections: setup_usemap(). Link: http://lkml.kernel.org/r/20180801122348.21588-4-osalvador@techadventures.net Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Signed-off-by: Oscar Salvador <osalvador@suse.de> Reviewed-by: Oscar Salvador <osalvador@suse.de> Cc: Pasha Tatashin <Pavel.Tatashin@microsoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-05Merge tag 'xfs-4.18-merge-3' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linuxLinus Torvalds
Pull xfs updates from Darrick Wong: "New features this cycle include the ability to relabel mounted filesystems, support for fallocated swapfiles, and using FUA for pure data O_DSYNC directio writes. With this cycle we begin to integrate online filesystem repair and refactor the growfs code in preparation for eventual subvolume support, though the road ahead for both features is quite long. There are also numerous refactorings of the iomap code to remove unnecessary log overhead, to disentangle some of the quota code, and to prepare for buffer head removal in a future upstream kernel. Metadata validation continues to improve, both in the hot path veifiers and the online filesystem check code. I anticipate sending a second pull request in a few days with more metadata validation improvements. This series has been run through a full xfstests run over the weekend and through a quick xfstests run against this morning's master, with no major failures reported. Summary: - Strengthen inode number and structure validation when allocating inodes. - Reduce pointless buffer allocations during cache miss - Use FUA for pure data O_DSYNC directio writes - Various iomap refactorings - Strengthen quota metadata verification to avoid unfixable broken quota - Make AGFL block freeing a deferred operation to avoid blowing out transaction reservations when running complex operations - Get rid of the log item descriptors to reduce log overhead - Fix various reflink bugs where inodes were double-joined to transactions - Don't issue discards when trimming unwritten extents - Refactor incore dquot initialization and retrieval interfaces - Fix some locking problmes in the quota scrub code - Strengthen btree structure checks in scrub code - Rewrite swapfile activation to use iomap and support unwritten extents - Make scrub exit to userspace sooner when corruptions or cross-referencing problems are found - Make scrub invoke the data fork scrubber directly on metadata inodes - Don't do background reclamation of post-eof and cow blocks when the fs is suspended - Fix secondary superblock buffer lifespan hinting - Refactor growfs to use table-dispatched functions instead of long stringy functions - Move growfs code to libxfs - Implement online fs label getting and setting - Introduce online filesystem repair (in a very limited capacity) - Fix unit conversion problems in the realtime freemap iteration functions - Various refactorings and cleanups in preparation to remove buffer heads in a future release - Reimplement the old bmap call with iomap - Remove direct buffer head accesses from seek hole/data - Various bug fixes" * tag 'xfs-4.18-merge-3' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linux: (121 commits) fs: use ->is_partially_uptodate in page_cache_seek_hole_data fs: remove the buffer_unwritten check in page_seek_hole_data fs: move page_cache_seek_hole_data to iomap.c xfs: use iomap_bmap iomap: add an iomap-based bmap implementation iomap: add a iomap_sector helper iomap: use __bio_add_page in iomap_dio_zero iomap: move IOMAP_F_BOUNDARY to gfs2 iomap: fix the comment describing IOMAP_NOWAIT iomap: inline data should be an iomap type, not a flag mm: split ->readpages calls to avoid non-contiguous pages lists mm: return an unsigned int from __do_page_cache_readahead mm: give the 'ret' variable a better name __do_page_cache_readahead block: add a lower-level bio_add_page interface xfs: fix error handling in xfs_refcount_insert() xfs: fix xfs_rtalloc_rec units xfs: strengthen rtalloc query range checks xfs: xfs_rtbuf_get should check the bmapi_read results xfs: xfs_rtword_t should be unsigned, not signed dax: change bdev_dax_supported() to support boolean returns ...
2018-06-01mm: return an unsigned int from __do_page_cache_readaheadChristoph Hellwig
We never return an error, so switch to returning an unsigned int. Most callers already did implicit casts to an unsigned type, and the one that didn't can be simplified now. Suggested-by: Matthew Wilcox <willy@infradead.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2018-05-24Revert "mm/cma: manage the memory of the CMA area by using the ZONE_MOVABLE"Joonsoo Kim
This reverts the following commits that change CMA design in MM. 3d2054ad8c2d ("ARM: CMA: avoid double mapping to the CMA area if CONFIG_HIGHMEM=y") 1d47a3ec09b5 ("mm/cma: remove ALLOC_CMA") bad8c6c0b114 ("mm/cma: manage the memory of the CMA area by using the ZONE_MOVABLE") Ville reported a following error on i386. Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) microcode: microcode updated early to revision 0x4, date = 2013-06-28 Initializing CPU#0 Initializing HighMem for node 0 (000377fe:00118000) Initializing Movable for node 0 (00000001:00118000) BUG: Bad page state in process swapper pfn:377fe page:f53effc0 count:0 mapcount:-127 mapping:00000000 index:0x0 flags: 0x80000000() raw: 80000000 00000000 00000000 ffffff80 00000000 00000100 00000200 00000001 page dumped because: nonzero mapcount Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 4.17.0-rc5-elk+ #145 Hardware name: Dell Inc. Latitude E5410/03VXMC, BIOS A15 07/11/2013 Call Trace: dump_stack+0x60/0x96 bad_page+0x9a/0x100 free_pages_check_bad+0x3f/0x60 free_pcppages_bulk+0x29d/0x5b0 free_unref_page_commit+0x84/0xb0 free_unref_page+0x3e/0x70 __free_pages+0x1d/0x20 free_highmem_page+0x19/0x40 add_highpages_with_active_regions+0xab/0xeb set_highmem_pages_init+0x66/0x73 mem_init+0x1b/0x1d7 start_kernel+0x17a/0x363 i386_start_kernel+0x95/0x99 startup_32_smp+0x164/0x168 The reason for this error is that the span of MOVABLE_ZONE is extended to whole node span for future CMA initialization, and, normal memory is wrongly freed here. I submitted the fix and it seems to work, but, another problem happened. It's so late time to fix the later problem so I decide to reverting the series. Reported-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Laura Abbott <labbott@redhat.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-11mm/cma: remove ALLOC_CMAJoonsoo Kim
Now, all reserved pages for CMA region are belong to the ZONE_MOVABLE and it only serves for a request with GFP_HIGHMEM && GFP_MOVABLE. Therefore, we don't need to maintain ALLOC_CMA at all. Link: http://lkml.kernel.org/r/1512114786-5085-3-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@suse.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-11mm/cma: manage the memory of the CMA area by using the ZONE_MOVABLEJoonsoo Kim
Patch series "mm/cma: manage the memory of the CMA area by using the ZONE_MOVABLE", v2. 0. History This patchset is the follow-up of the discussion about the "Introduce ZONE_CMA (v7)" [1]. Please reference it if more information is needed. 1. What does this patch do? This patch changes the management way for the memory of the CMA area in the MM subsystem. Currently the memory of the CMA area is managed by the zone where their pfn is belong to. However, this approach has some problems since MM subsystem doesn't have enough logic to handle the situation that different characteristic memories are in a single zone. To solve this issue, this patch try to manage all the memory of the CMA area by using the MOVABLE zone. In MM subsystem's point of view, characteristic of the memory on the MOVABLE zone and the memory of the CMA area are the same. So, managing the memory of the CMA area by using the MOVABLE zone will not have any problem. 2. Motivation There are some problems with current approach. See following. Although these problem would not be inherent and it could be fixed without this conception change, it requires many hooks addition in various code path and it would be intrusive to core MM and would be really error-prone. Therefore, I try to solve them with this new approach. Anyway, following is the problems of the current implementation. o CMA memory utilization First, following is the freepage calculation logic in MM. - For movable allocation: freepage = total freepage - For unmovable allocation: freepage = total freepage - CMA freepage Freepages on the CMA area is used after the normal freepages in the zone where the memory of the CMA area is belong to are exhausted. At that moment that the number of the normal freepages is zero, so - For movable allocation: freepage = total freepage = CMA freepage - For unmovable allocation: freepage = 0 If unmovable allocation comes at this moment, allocation request would fail to pass the watermark check and reclaim is started. After reclaim, there would exist the normal freepages so freepages on the CMA areas would not be used. FYI, there is another attempt [2] trying to solve this problem in lkml. And, as far as I know, Qualcomm also has out-of-tree solution for this problem. Useless reclaim: There is no logic to distinguish CMA pages in the reclaim path. Hence, CMA page is reclaimed even if the system just needs the page that can be usable for the kernel allocation. Atomic allocation failure: This is also related to the fallback allocation policy for the memory of the CMA area. Consider the situation that the number of the normal freepages is *zero* since the bunch of the movable allocation requests come. Kswapd would not be woken up due to following freepage calculation logic. - For movable allocation: freepage = total freepage = CMA freepage If atomic unmovable allocation request comes at this moment, it would fails due to following logic. - For unmovable allocation: freepage = total freepage - CMA freepage = 0 It was reported by Aneesh [3]. Useless compaction: Usual high-order allocation request is unmovable allocation request and it cannot be served from the memory of the CMA area. In compaction, migration scanner try to migrate the page in the CMA area and make high-order page there. As mentioned above, it cannot be usable for the unmovable allocation request so it's just waste. 3. Current approach and new approach Current approach is that the memory of the CMA area is managed by the zone where their pfn is belong to. However, these memory should be distinguishable since they have a strong limitation. So, they are marked as MIGRATE_CMA in pageblock flag and handled specially. However, as mentioned in section 2, the MM subsystem doesn't have enough logic to deal with this special pageblock so many problems raised. New approach is that the memory of the CMA area is managed by the MOVABLE zone. MM already have enough logic to deal with special zone like as HIGHMEM and MOVABLE zone. So, managing the memory of the CMA area by the MOVABLE zone just naturally work well because constraints for the memory of the CMA area that the memory should always be migratable is the same with the constraint for the MOVABLE zone. There is one side-effect for the usability of the memory of the CMA area. The use of MOVABLE zone is only allowed for a request with GFP_HIGHMEM && GFP_MOVABLE so now the memory of the CMA area is also only allowed for this gfp flag. Before this patchset, a request with GFP_MOVABLE can use them. IMO, It would not be a big issue since most of GFP_MOVABLE request also has GFP_HIGHMEM flag. For example, file cache page and anonymous page. However, file cache page for blockdev file is an exception. Request for it has no GFP_HIGHMEM flag. There is pros and cons on this exception. In my experience, blockdev file cache pages are one of the top reason that causes cma_alloc() to fail temporarily. So, we can get more guarantee of cma_alloc() success by discarding this case. Note that there is no change in admin POV since this patchset is just for internal implementation change in MM subsystem. Just one minor difference for admin is that the memory stat for CMA area will be printed in the MOVABLE zone. That's all. 4. Result Following is the experimental result related to utilization problem. 8 CPUs, 1024 MB, VIRTUAL MACHINE make -j16 <Before> CMA area: 0 MB 512 MB Elapsed-time: 92.4 186.5 pswpin: 82 18647 pswpout: 160 69839 <After> CMA : 0 MB 512 MB Elapsed-time: 93.1 93.4 pswpin: 84 46 pswpout: 183 92 akpm: "kernel test robot" reported a 26% improvement in vm-scalability.throughput: http://lkml.kernel.org/r/20180330012721.GA3845@yexl-desktop [1]: lkml.kernel.org/r/1491880640-9944-1-git-send-email-iamjoonsoo.kim@lge.com [2]: https://lkml.org/lkml/2014/10/15/623 [3]: http://www.spinics.net/lists/linux-mm/msg100562.html Link: http://lkml.kernel.org/r/1512114786-5085-2-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@suse.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-11mm, migrate: remove reason argument from new_page_tMichal Hocko
No allocation callback is using this argument anymore. new_page_node used to use this parameter to convey node_id resp. migration error up to move_pages code (do_move_page_to_node_array). The error status never made it into the final status field and we have a better way to communicate node id to the status field now. All other allocation callbacks simply ignored the argument so we can drop it finally. [mhocko@suse.com: fix migration callback] Link: http://lkml.kernel.org/r/20180105085259.GH2801@dhcp22.suse.cz [akpm@linux-foundation.org: fix alloc_misplaced_dst_page()] [mhocko@kernel.org: fix build] Link: http://lkml.kernel.org/r/20180103091134.GB11319@dhcp22.suse.cz Link: http://lkml.kernel.org/r/20180103082555.14592-3-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Zi Yan <zi.yan@cs.rutgers.edu> Cc: Andrea Reale <ar@linux.vnet.ibm.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-11mm, numa: rework do_pages_moveMichal Hocko
Patch series "unclutter thp migration" Motivation: THP migration is hacked into the generic migration with rather surprising semantic. The migration allocation callback is supposed to check whether the THP can be migrated at once and if that is not the case then it allocates a simple page to migrate. unmap_and_move then fixes that up by splitting the THP into small pages while moving the head page to the newly allocated order-0 page. Remaining pages are moved to the LRU list by split_huge_page. The same happens if the THP allocation fails. This is really ugly and error prone [2]. I also believe that split_huge_page to the LRU lists is inherently wrong because all tail pages are not migrated. Some callers will just work around that by retrying (e.g. memory hotplug). There are other pfn walkers which are simply broken though. e.g. madvise_inject_error will migrate head and then advances next pfn by the huge page size. do_move_page_to_node_array, queue_pages_range (migrate_pages, mbind), will simply split the THP before migration if the THP migration is not supported then falls back to single page migration but it doesn't handle tail pages if the THP migration path is not able to allocate a fresh THP so we end up with ENOMEM and fail the whole migration which is a questionable behavior. Page compaction doesn't try to migrate large pages so it should be immune. The first patch reworks do_pages_move which relies on a very ugly calling semantic when the return status is pushed to the migration path via private pointer. It uses pre allocated fixed size batching to achieve that. We simply cannot do the same if a THP is to be split during the migration path which is done in the patch 3. Patch 2 is follow up cleanup which removes the mentioned return status calling convention ugliness. On a side note: There are some semantic issues I have encountered on the way when working on patch 1 but I am not addressing them here. E.g. trying to move THP tail pages will result in either success or EBUSY (the later one more likely once we isolate head from the LRU list). Hugetlb reports EACCESS on tail pages. Some errors are reported via status parameter but migration failures are not even though the original `reason' argument suggests there was an intention to do so. From a quick look into git history this never worked. I have tried to keep the semantic unchanged. Then there is a relatively minor thing that the page isolation might fail because of pages not being on the LRU - e.g. because they are sitting on the per-cpu LRU caches. Easily fixable. This patch (of 3): do_pages_move is supposed to move user defined memory (an array of addresses) to the user defined numa nodes (an array of nodes one for each address). The user provided status array then contains resulting numa node for each address or an error. The semantic of this function is little bit confusing because only some errors are reported back. Notably migrate_pages error is only reported via the return value. This patch doesn't try to address these semantic nuances but rather change the underlying implementation. Currently we are processing user input (which can be really large) in batches which are stored to a temporarily allocated page. Each address is resolved to its struct page and stored to page_to_node structure along with the requested target numa node. The array of these structures is then conveyed down the page migration path via private argument. new_page_node then finds the corresponding structure and allocates the proper target page. What is the problem with the current implementation and why to change it? Apart from being quite ugly it also doesn't cope with unexpected pages showing up on the migration list inside migrate_pages path. That doesn't happen currently but the follow up patch would like to make the thp migration code more clear and that would need to split a THP into the list for some cases. How does the new implementation work? Well, instead of batching into a fixed size array we simply batch all pages that should be migrated to the same node and isolate all of them into a linked list which doesn't require any additional storage. This should work reasonably well because page migration usually migrates larger ranges of memory to a specific node. So the common case should work equally well as the current implementation. Even if somebody constructs an input where the target numa nodes would be interleaved we shouldn't see a large performance impact because page migration alone doesn't really benefit from batching. mmap_sem batching for the lookup is quite questionable and isolate_lru_page which would benefit from batching is not using it even in the current implementation. Link: http://lkml.kernel.org/r/20180103082555.14592-2-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Zi Yan <zi.yan@cs.rutgers.edu> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Reale <ar@linux.vnet.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-29Revert "mm, thp: Do not make pmd/pud dirty without a reason"Linus Torvalds
This reverts commit 152e93af3cfe2d29d8136cc0a02a8612507136ee. It was a nice cleanup in theory, but as Nicolai Stange points out, we do need to make the page dirty for the copy-on-write case even when we didn't end up making it writable, since the dirty bit is what we use to check that we've gone through a COW cycle. Reported-by: Michal Hocko <mhocko@kernel.org> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-27mm, thp: Do not make pmd/pud dirty without a reasonKirill A. Shutemov
Currently we make page table entries dirty all the time regardless of access type and don't even consider if the mapping is write-protected. The reasoning is that we don't really need dirty tracking on THP and making the entry dirty upfront may save some time on first write to the page. Unfortunately, such approach may result in false-positive can_follow_write_pmd() for huge zero page or read-only shmem file. Let's only make page dirty only if we about to write to the page anyway (as we do for small pages). I've restructured the code to make entry dirty inside maybe_p[mu]d_mkwrite(). It also takes into account if the vma is write-protected. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-17mm, compaction: split off flag for not updating skip hintsVlastimil Babka
Pageblock skip hints were added as a heuristic for compaction, which shares core code with CMA. Since CMA reliability would suffer from the heuristics, compact_control flag ignore_skip_hint was added for the CMA use case. Since 6815bf3f233e ("mm/compaction: respect ignore_skip_hint in update_pageblock_skip") the flag also means that CMA won't *update* the skip hints in addition to ignoring them. Today, direct compaction can also ignore the skip hints in the last resort attempt, but there's no reason not to set them when isolation fails in such case. Thus, this patch splits off a new no_set_skip_hint flag to avoid the updating, which only CMA sets. This should improve the heuristics a bit, and allow us to simplify the persistent skip bit handling as the next step. Link: http://lkml.kernel.org/r/20171102121706.21504-2-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06mm, oom: do not rely on TIF_MEMDIE for memory reserves accessMichal Hocko
For ages we have been relying on TIF_MEMDIE thread flag to mark OOM victims and then, among other things, to give these threads full access to memory reserves. There are few shortcomings of this implementation, though. First of all and the most serious one is that the full access to memory reserves is quite dangerous because we leave no safety room for the system to operate and potentially do last emergency steps to move on. Secondly this flag is per task_struct while the OOM killer operates on mm_struct granularity so all processes sharing the given mm are killed. Giving the full access to all these task_structs could lead to a quick memory reserves depletion. We have tried to reduce this risk by giving TIF_MEMDIE only to the main thread and the currently allocating task but that doesn't really solve this problem while it surely opens up a room for corner cases - e.g. GFP_NO{FS,IO} requests might loop inside the allocator without access to memory reserves because a particular thread was not the group leader. Now that we have the oom reaper and that all oom victims are reapable after 1b51e65eab64 ("oom, oom_reaper: allow to reap mm shared by the kthreads") we can be more conservative and grant only partial access to memory reserves because there are reasonable chances of the parallel memory freeing. We still want some access to reserves because we do not want other consumers to eat up the victim's freed memory. oom victims will still contend with __GFP_HIGH users but those shouldn't be so aggressive to starve oom victims completely. Introduce ALLOC_OOM flag and give all tsk_is_oom_victim tasks access to the half of the reserves. This makes the access to reserves independent on which task has passed through mark_oom_victim. Also drop any usage of TIF_MEMDIE from the page allocator proper and replace it by tsk_is_oom_victim as well which will make page_alloc.c completely TIF_MEMDIE free finally. CONFIG_MMU=n doesn't have oom reaper so let's stick to the original ALLOC_NO_WATERMARKS approach. There is a demand to make the oom killer memcg aware which will imply many tasks killed at once. This change will allow such a usecase without worrying about complete memory reserves depletion. Link: http://lkml.kernel.org/r/20170810075019.28998-2-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Roman Gushchin <guro@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06mm, memory_hotplug: drop zone from build_all_zonelistsMichal Hocko
build_all_zonelists gets a zone parameter to initialize zone's pagesets. There is only a single user which gives a non-NULL zone parameter and that one doesn't really need the rest of the build_all_zonelists (see commit 6dcd73d7011b ("memory-hotplug: allocate zone's pcp before onlining pages")). Therefore remove setup_zone_pageset from build_all_zonelists and call it from its only user directly. This will also remove a pointless zonlists rebuilding which is always good. Link: http://lkml.kernel.org/r/20170721143915.14161-5-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-02mm, mprotect: flush TLB if potentially racing with a parallel reclaim ↵Mel Gorman
leaving stale TLB entries Nadav Amit identified a theoritical race between page reclaim and mprotect due to TLB flushes being batched outside of the PTL being held. He described the race as follows: CPU0 CPU1 ---- ---- user accesses memory using RW PTE [PTE now cached in TLB] try_to_unmap_one() ==> ptep_get_and_clear() ==> set_tlb_ubc_flush_pending() mprotect(addr, PROT_READ) ==> change_pte_range() ==> [ PTE non-present - no flush ] user writes using cached RW PTE ... try_to_unmap_flush() The same type of race exists for reads when protecting for PROT_NONE and also exists for operations that can leave an old TLB entry behind such as munmap, mremap and madvise. For some operations like mprotect, it's not necessarily a data integrity issue but it is a correctness issue as there is a window where an mprotect that limits access still allows access. For munmap, it's potentially a data integrity issue although the race is massive as an munmap, mmap and return to userspace must all complete between the window when reclaim drops the PTL and flushes the TLB. However, it's theoritically possible so handle this issue by flushing the mm if reclaim is potentially currently batching TLB flushes. Other instances where a flush is required for a present pte should be ok as either the page lock is held preventing parallel reclaim or a page reference count is elevated preventing a parallel free leading to corruption. In the case of page_mkclean there isn't an obvious path that userspace could take advantage of without using the operations that are guarded by this patch. Other users such as gup as a race with reclaim looks just at PTEs. huge page variants should be ok as they don't race with reclaim. mincore only looks at PTEs. userfault also should be ok as if a parallel reclaim takes place, it will either fault the page back in or read some of the data before the flush occurs triggering a fault. Note that a variant of this patch was acked by Andy Lutomirski but this was for the x86 parts on top of his PCID work which didn't make the 4.13 merge window as expected. His ack is dropped from this version and there will be a follow-on patch on top of PCID that will include his ack. [akpm@linux-foundation.org: tweak comments] [akpm@linux-foundation.org: fix spello] Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de Reported-by: Nadav Amit <nadav.amit@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: <stable@vger.kernel.org> [v4.4+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-12mm, tree wide: replace __GFP_REPEAT by __GFP_RETRY_MAYFAIL with more useful ↵Michal Hocko
semantic __GFP_REPEAT was designed to allow retry-but-eventually-fail semantic to the page allocator. This has been true but only for allocations requests larger than PAGE_ALLOC_COSTLY_ORDER. It has been always ignored for smaller sizes. This is a bit unfortunate because there is no way to express the same semantic for those requests and they are considered too important to fail so they might end up looping in the page allocator for ever, similarly to GFP_NOFAIL requests. Now that the whole tree has been cleaned up and accidental or misled usage of __GFP_REPEAT flag has been removed for !costly requests we can give the original flag a better name and more importantly a more useful semantic. Let's rename it to __GFP_RETRY_MAYFAIL which tells the user that the allocator would try really hard but there is no promise of a success. This will work independent of the order and overrides the default allocator behavior. Page allocator users have several levels of guarantee vs. cost options (take GFP_KERNEL as an example) - GFP_KERNEL & ~__GFP_RECLAIM - optimistic allocation without _any_ attempt to free memory at all. The most light weight mode which even doesn't kick the background reclaim. Should be used carefully because it might deplete the memory and the next user might hit the more aggressive reclaim - GFP_KERNEL & ~__GFP_DIRECT_RECLAIM (or GFP_NOWAIT)- optimistic allocation without any attempt to free memory from the current context but can wake kswapd to reclaim memory if the zone is below the low watermark. Can be used from either atomic contexts or when the request is a performance optimization and there is another fallback for a slow path. - (GFP_KERNEL|__GFP_HIGH) & ~__GFP_DIRECT_RECLAIM (aka GFP_ATOMIC) - non sleeping allocation with an expensive fallback so it can access some portion of memory reserves. Usually used from interrupt/bh context with an expensive slow path fallback. - GFP_KERNEL - both background and direct reclaim are allowed and the _default_ page allocator behavior is used. That means that !costly allocation requests are basically nofail but there is no guarantee of that behavior so failures have to be checked properly by callers (e.g. OOM killer victim is allowed to fail currently). - GFP_KERNEL | __GFP_NORETRY - overrides the default allocator behavior and all allocation requests fail early rather than cause disruptive reclaim (one round of reclaim in this implementation). The OOM killer is not invoked. - GFP_KERNEL | __GFP_RETRY_MAYFAIL - overrides the default allocator behavior and all allocation requests try really hard. The request will fail if the reclaim cannot make any progress. The OOM killer won't be triggered. - GFP_KERNEL | __GFP_NOFAIL - overrides the default allocator behavior and all allocation requests will loop endlessly until they succeed. This might be really dangerous especially for larger orders. Existing users of __GFP_REPEAT are changed to __GFP_RETRY_MAYFAIL because they already had their semantic. No new users are added. __alloc_pages_slowpath is changed to bail out for __GFP_RETRY_MAYFAIL if there is no progress and we have already passed the OOM point. This means that all the reclaim opportunities have been exhausted except the most disruptive one (the OOM killer) and a user defined fallback behavior is more sensible than keep retrying in the page allocator. [akpm@linux-foundation.org: fix arch/sparc/kernel/mdesc.c] [mhocko@suse.com: semantic fix] Link: http://lkml.kernel.org/r/20170626123847.GM11534@dhcp22.suse.cz [mhocko@kernel.org: address other thing spotted by Vlastimil] Link: http://lkml.kernel.org/r/20170626124233.GN11534@dhcp22.suse.cz Link: http://lkml.kernel.org/r/20170623085345.11304-3-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Alex Belits <alex.belits@cavium.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: David Daney <david.daney@cavium.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: NeilBrown <neilb@suse.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08mm, compaction: finish whole pageblock to reduce fragmentationVlastimil Babka
The main goal of direct compaction is to form a high-order page for allocation, but it should also help against long-term fragmentation when possible. Most lower-than-pageblock-order compactions are for non-movable allocations, which means that if we compact in a movable pageblock and terminate as soon as we create the high-order page, it's unlikely that the fallback heuristics will claim the whole block. Instead there might be a single unmovable page in a pageblock full of movable pages, and the next unmovable allocation might pick another pageblock and increase long-term fragmentation. To help against such scenarios, this patch changes the termination criteria for compaction so that the current pageblock is finished even though the high-order page already exists. Note that it might be possible that the high-order page formed elsewhere in the zone due to parallel activity, but this patch doesn't try to detect that. This is only done with sync compaction, because async compaction is limited to pageblock of the same migratetype, where it cannot result in a migratetype fallback. (Async compaction also eagerly skips order-aligned blocks where isolation fails, which is against the goal of migrating away as much of the pageblock as possible.) As a result of this patch, long-term memory fragmentation should be reduced. In testing based on 4.9 kernel with stress-highalloc from mmtests configured for order-4 GFP_KERNEL allocations, this patch has reduced the number of unmovable allocations falling back to movable pageblocks by 20%. The number Link: http://lkml.kernel.org/r/20170307131545.28577-9-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08mm, compaction: add migratetype to compact_controlVlastimil Babka
Preparation patch. We are going to need migratetype at lower layers than compact_zone() and compact_finished(). Link: http://lkml.kernel.org/r/20170307131545.28577-7-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08mm, compaction: reorder fields in struct compact_controlVlastimil Babka
Patch series "try to reduce fragmenting fallbacks", v3. Last year, Johannes Weiner has reported a regression in page mobility grouping [1] and while the exact cause was not found, I've come up with some ways to improve it by reducing the number of allocations falling back to different migratetype and causing permanent fragmentation. The series was tested with mmtests stress-highalloc modified to do GFP_KERNEL order-4 allocations, on 4.9 with "mm, vmscan: fix zone balance check in prepare_kswapd_sleep" (without that, kcompactd indeed wasn't woken up) on UMA machine with 4GB memory. There were 5 repeats of each run, as the extfrag stats are quite volatile (note the stats below are sums, not averages, as it was less perl hacking for me). Success rate are the same, already high due to the low allocation order used, so I'm not including them. Compaction stats: (the patches are stacked, and I haven't measured the non-functional-changes patches separately) patch 1 patch 2 patch 3 patch 4 patch 7 patch 8 Compaction stalls 22449 24680 24846 19765 22059 17480 Compaction success 12971 14836 14608 10475 11632 8757 Compaction failures 9477 9843 10238 9290 10426 8722 Page migrate success 3109022 3370438 3312164 1695105 1608435 2111379 Page migrate failure 911588 1149065 1028264 1112675 1077251 1026367 Compaction pages isolated 7242983 8015530 7782467 4629063 4402787 5377665 Compaction migrate scanned 980838938 987367943 957690188 917647238 947155598 1018922197 Compaction free scanned 557926893 598946443 602236894 594024490 541169699 763651731 Compaction cost 10243 10578 10304 8286 8398 9440 Compaction stats are mostly within noise until patch 4, which decreases the number of compactions, and migrations. Part of that could be due to more pageblocks marked as unmovable, and async compaction skipping those. This changes a bit with patch 7, but not so much. Patch 8 increases free scanner stats and migrations, which comes from the changed termination criteria. Interestingly number of compactions decreases - probably the fully compacted pageblock satisfies multiple subsequent allocations, so it amortizes. Next comes the extfrag tracepoint, where "fragmenting" means that an allocation had to fallback to a pageblock of another migratetype which wasn't fully free (which is almost all of the fallbacks). I have locally added another tracepoint for "Page steal" into steal_suitable_fallback() which triggers in situations where we are allowed to do move_freepages_block(). If we decide to also do set_pageblock_migratetype(), it's "Pages steal with pageblock" with break down for which allocation migratetype we are stealing and from which fallback migratetype. The last part "due to counting" comes from patch 4 and counts the events where the counting of movable pages allowed us to change pageblock's migratetype, while the number of free pages alone wouldn't be enough to cross the threshold. patch 1 patch 2 patch 3 patch 4 patch 7 patch 8 Page alloc extfrag event 10155066 8522968 10164959 15622080 13727068 13140319 Extfrag fragmenting 10149231 8517025 10159040 15616925 13721391 13134792 Extfrag fragmenting for unmovable 159504 168500 184177 97835 70625 56948 Extfrag fragmenting unmovable placed with movable 153613 163549 172693 91740 64099 50917 Extfrag fragmenting unmovable placed with reclaim. 5891 4951 11484 6095 6526 6031 Extfrag fragmenting for reclaimable 4738 4829 6345 4822 5640 5378 Extfrag fragmenting reclaimable placed with movable 1836 1902 1851 1579 1739 1760 Extfrag fragmenting reclaimable placed with unmov. 2902 2927 4494 3243 3901 3618 Extfrag fragmenting for movable 9984989 8343696 9968518 15514268 13645126 13072466 Pages steal 179954 192291 210880 123254 94545 81486 Pages steal with pageblock 22153 18943 20154 33562 29969 33444 Pages steal with pageblock for unmovable 14350 12858 13256 20660 19003 20852 Pages steal with pageblock for unmovable from mov. 12812 11402 11683 19072 17467 19298 Pages steal with pageblock for unmovable from recl. 1538 1456 1573 1588 1536 1554 Pages steal with pageblock for movable 7114 5489 5965 11787 10012 11493 Pages steal with pageblock for movable from unmov. 6885 5291 5541 11179 9525 10885 Pages steal with pageblock for movable from recl. 229 198 424 608 487 608 Pages steal with pageblock for reclaimable 689 596 933 1115 954 1099 Pages steal with pageblock for reclaimable from unmov. 273 219 537 658 547 667 Pages steal with pageblock for reclaimable from mov. 416 377 396 457 407 432 Pages steal with pageblock due to counting 11834 10075 7530 ... for unmovable 8993 7381 4616 ... for movable 2792 2653 2851 ... for reclaimable 49 41 63 What we can see is that "Extfrag fragmenting for unmovable" and "... placed with movable" drops with almost each patch, which is good as we are polluting less movable pageblocks with unmovable pages. The most significant change is patch 4 with movable page counting. On the other hand it increases "Extfrag fragmenting for movable" by 50%. "Pages steal" drops though, so these movable allocation fallbacks find only small free pages and are not allowed to steal whole pageblocks back. "Pages steal with pageblock" raises, because the patch increases the chances of pageblock migratetype changes to happen. This affects all migratetypes. The summary is that patch 4 is not a clear win wrt these stats, but I believe that the tradeoff it makes is a good one. There's less pollution of movable pageblocks by unmovable allocations. There's less stealing between pageblock, and those that remain have higher chance of changing migratetype also the pageblock itself, so it should more faithfully reflect the migratetype of the pages within the pageblock. The increase of movable allocations falling back to unmovable pageblock might look dramatic, but those allocations can be migrated by compaction when needed, and other patches in the series (7-9) improve that aspect. Patches 7 and 8 continue the trend of reduced unmovable fallbacks and also reduce the impact on movable fallbacks from patch 4. [1] https://www.spinics.net/lists/linux-mm/msg114237.html This patch (of 8): While currently there are (mostly by accident) no holes in struct compact_control (on x86_64), but we are going to add more bool flags, so place them all together to the end of the structure. While at it, just order all fields from largest to smallest. Link: http://lkml.kernel.org/r/20170307131545.28577-2-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: use is_migrate_highatomic() to simplify the codeXishi Qiu
Introduce two helpers, is_migrate_highatomic() and is_migrate_highatomic_page(). Simplify the code, no functional changes. [akpm@linux-foundation.org: use static inlines rather than macros, per mhocko] Link: http://lkml.kernel.org/r/58B94F15.6060606@huawei.com Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: delete NR_PAGES_SCANNED and pgdat_reclaimable()Johannes Weiner
NR_PAGES_SCANNED counts number of pages scanned since the last page free event in the allocator. This was used primarily to measure the reclaimability of zones and nodes, and determine when reclaim should give up on them. In that role, it has been replaced in the preceding patches by a different mechanism. Being implemented as an efficient vmstat counter, it was automatically exported to userspace as well. It's however unlikely that anyone outside the kernel is using this counter in any meaningful way. Remove the counter and the unused pgdat_reclaimable(). Link: http://lkml.kernel.org/r/20170228214007.5621-8-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Jia He <hejianet@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm: fix 100% CPU kswapd busyloop on unreclaimable nodesJohannes Weiner
Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and cleanups". Jia reported a scenario in which the kswapd of a node indefinitely spins at 100% CPU usage. We have seen similar cases at Facebook. The kernel's current method of judging its ability to reclaim a node (or whether to back off and sleep) is based on the amount of scanned pages in proportion to the amount of reclaimable pages. In Jia's and our scenarios, there are no reclaimable pages in the node, however, and the condition for backing off is never met. Kswapd busyloops in an attempt to restore the watermarks while having nothing to work with. This series reworks the definition of an unreclaimable node based not on scanning but on whether kswapd is able to actually reclaim pages in MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria the page allocator uses for giving up on direct reclaim and invoking the OOM killer. If it cannot free any pages, kswapd will go to sleep and leave further attempts to direct reclaim invocations, which will either make progress and re-enable kswapd, or invoke the OOM killer. Patch #1 fixes the immediate problem Jia reported, the remainder are smaller fixlets, cleanups, and overall phasing out of the old method. Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(), and directly related to #5, but in itself not relevant to the series. If the whole series is too ambitious for 4.11, I would consider the first three patches fixes, the rest cleanups. This patch (of 9): Jia He reports a problem with kswapd spinning at 100% CPU when requesting more hugepages than memory available in the system: $ echo 4000 >/proc/sys/vm/nr_hugepages top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01 Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3 At that time, there are no reclaimable pages left in the node, but as kswapd fails to restore the high watermarks it refuses to go to sleep. Kswapd needs to back away from nodes that fail to balance. Up until commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of nodes") kswapd had such a mechanism. It considered zones whose theoretically reclaimable pages it had reclaimed six times over as unreclaimable and backed away from them. This guard was erroneously removed as the patch changed the definition of a balanced node. However, simply restoring this code wouldn't help in the case reported here: there *are* no reclaimable pages that could be scanned until the threshold is met. Kswapd would stay awake anyway. Introduce a new and much simpler way of backing off. If kswapd runs through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single page, make it back off from the node. This is the same number of shots direct reclaim takes before declaring OOM. Kswapd will go to sleep on that node until a direct reclaimer manages to reclaim some pages, thus proving the node reclaimable again. [hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count] Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org [shakeelb@google.com: fix condition for throttle_direct_reclaim] Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Shakeel Butt <shakeelb@google.com> Reported-by: Jia He <hejianet@gmail.com> Tested-by: Jia He <hejianet@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-04-08mm: move pcp and lru-pcp draining into single wqMichal Hocko
We currently have 2 specific WQ_RECLAIM workqueues in the mm code. vmstat_wq for updating pcp stats and lru_add_drain_wq dedicated to drain per cpu lru caches. This seems more than necessary because both can run on a single WQ. Both do not block on locks requiring a memory allocation nor perform any allocations themselves. We will save one rescuer thread this way. On the other hand drain_all_pages() queues work on the system wq which doesn't have rescuer and so this depend on memory allocation (when all workers are stuck allocating and new ones cannot be created). Initially we thought this would be more of a theoretical problem but Hugh Dickins has reported: : 4.11-rc has been giving me hangs after hours of swapping load. At : first they looked like memory leaks ("fork: Cannot allocate memory"); : but for no good reason I happened to do "cat /proc/sys/vm/stat_refresh" : before looking at /proc/meminfo one time, and the stat_refresh stuck : in D state, waiting for completion of flush_work like many kworkers. : kthreadd waiting for completion of flush_work in drain_all_pages(). This worker should be using WQ_RECLAIM as well in order to guarantee a forward progress. We can reuse the same one as for lru draining and vmstat. Link: http://lkml.kernel.org/r/20170307131751.24936-1-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Suggested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Tested-by: Yang Li <pku.leo@gmail.com> Tested-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24mm, rmap: check all VMAs that PTE-mapped THP can be part ofKirill A. Shutemov
Current rmap code can miss a VMA that maps PTE-mapped THP if the first suppage of the THP was unmapped from the VMA. We need to walk rmap for the whole range of offsets that THP covers, not only the first one. vma_address() also need to be corrected to check the range instead of the first subpage. Link: http://lkml.kernel.org/r/20170129173858.45174-6-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22oom-reaper: use madvise_dontneed() logic to decide if unmap the VMAKirill A. Shutemov
Logic on whether we can reap pages from the VMA should match what we have in madvise_dontneed(). In particular, we should skip, VM_PFNMAP VMAs, but we don't now. Let's just extract condition on which we can shoot down pagesi from a VMA with MADV_DONTNEED into separate function and use it in both places. Link: http://lkml.kernel.org/r/20170118122429.43661-4-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm, compaction: add vmstats for kcompactd workDavid Rientjes
A "compact_daemon_wake" vmstat exists that represents the number of times kcompactd has woken up. This doesn't represent how much work it actually did, though. It's useful to understand how much compaction work is being done by kcompactd versus other methods such as direct compaction and explicitly triggered per-node (or system) compaction. This adds two new vmstats: "compact_daemon_migrate_scanned" and "compact_daemon_free_scanned" to represent the number of pages kcompactd has scanned as part of its migration scanner and freeing scanner, respectively. These values are still accounted for in the general "compact_migrate_scanned" and "compact_free_scanned" for compatibility. It could be argued that explicitly triggered compaction could also be tracked separately, and that could be added if others find it useful. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1612071749390.69852@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm, page_alloc: don't convert pfn to idx when mergingVlastimil Babka
In __free_one_page() we do the buddy merging arithmetics on "page/buddy index", which is just the lower MAX_ORDER bits of pfn. The operations we do that affect the higher bits are bitwise AND and subtraction (in that order), where the final result will be the same with the higher bits left unmasked, as long as these bits are equal for both buddies - which must be true by the definition of a buddy. We can therefore use pfn's directly instead of "index" and skip the zeroing of >MAX_ORDER bits. This can help a bit by itself, although compiler might be smart enough already. It also helps the next patch to avoid page_to_pfn() for memory hole checks. Link: http://lkml.kernel.org/r/20161216120009.20064-1-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-25mm: add PageWaiters indicating tasks are waiting for a page bitNicholas Piggin
Add a new page flag, PageWaiters, to indicate the page waitqueue has tasks waiting. This can be tested rather than testing waitqueue_active which requires another cacheline load. This bit is always set when the page has tasks on page_waitqueue(page), and is set and cleared under the waitqueue lock. It may be set when there are no tasks on the waitqueue, which will cause a harmless extra wakeup check that will clears the bit. The generic bit-waitqueue infrastructure is no longer used for pages. Instead, waitqueues are used directly with a custom key type. The generic code was not flexible enough to have PageWaiters manipulation under the waitqueue lock (which simplifies concurrency). This improves the performance of page lock intensive microbenchmarks by 2-3%. Putting two bits in the same word opens the opportunity to remove the memory barrier between clearing the lock bit and testing the waiters bit, after some work on the arch primitives (e.g., ensuring memory operand widths match and cover both bits). Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Bob Peterson <rpeterso@redhat.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Andrew Lutomirski <luto@kernel.org> Cc: Andreas Gruenbacher <agruenba@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14mm: add orig_pte field into vm_faultJan Kara
Add orig_pte field to vm_fault structure to allow ->page_mkwrite handlers to fully handle the fault. This also allows us to save some passing of extra arguments around. Link: http://lkml.kernel.org/r/1479460644-25076-8-git-send-email-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-14mm: join struct fault_env and vm_faultJan Kara
Currently we have two different structures for passing fault information around - struct vm_fault and struct fault_env. DAX will need more information in struct vm_fault to handle its faults so the content of that structure would become event closer to fault_env. Furthermore it would need to generate struct fault_env to be able to call some of the generic functions. So at this point I don't think there's much use in keeping these two structures separate. Just embed into struct vm_fault all that is needed to use it for both purposes. Link: http://lkml.kernel.org/r/1479460644-25076-2-git-send-email-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: make full priority ignore pageblock suitabilityVlastimil Babka
Several people have reported premature OOMs for order-2 allocations (stack) due to OOM rework in 4.7. In the scenario (parallel kernel build and dd writing to two drives) many pageblocks get marked as Unmovable and compaction free scanner struggles to isolate free pages. Joonsoo Kim pointed out that the free scanner skips pageblocks that are not movable to prevent filling them and forcing non-movable allocations to fallback to other pageblocks. Such heuristic makes sense to help prevent long-term fragmentation, but premature OOMs are relatively more urgent problem. As a compromise, this patch disables the heuristic only for the ultimate compaction priority. Link: http://lkml.kernel.org/r/20160906135258.18335-5-vbabka@suse.cz Reported-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com> Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Reported-by: Olaf Hering <olaf@aepfle.de> Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: make whole_zone flag ignore cached scanner positionsVlastimil Babka
Patch series "make direct compaction more deterministic") This is mostly a followup to Michal's oom detection rework, which highlighted the need for direct compaction to provide better feedback in reclaim/compaction loop, so that it can reliably recognize when compaction cannot make further progress, and allocation should invoke OOM killer or fail. We've discussed this at LSF/MM [1] where I proposed expanding the async/sync migration mode used in compaction to more general "priorities". This patchset adds one new priority that just overrides all the heuristics and makes compaction fully scan all zones. I don't currently think that we need more fine-grained priorities, but we'll see. Other than that there's some smaller fixes and cleanups, mainly related to the THP-specific hacks. I've tested this with stress-highalloc in GFP_KERNEL order-4 and THP-like order-9 scenarios. There's some improvement for compaction stats for the order-4, which is likely due to the better watermarks handling. In the previous version I reported mostly noise wrt compaction stats, and decreased direct reclaim - now the reclaim is without difference. I believe this is due to the less aggressive compaction priority increase in patch 6. "before" is a mmotm tree prior to 4.7 release plus the first part of the series that was sent and merged separately before after order-4: Compaction stalls 27216 30759 Compaction success 19598 25475 Compaction failures 7617 5283 Page migrate success 370510 464919 Page migrate failure 25712 27987 Compaction pages isolated 849601 1041581 Compaction migrate scanned 143146541 101084990 Compaction free scanned 208355124 144863510 Compaction cost 1403 1210 order-9: Compaction stalls 7311 7401 Compaction success 1634 1683 Compaction failures 5677 5718 Page migrate success 194657 183988 Page migrate failure 4753 4170 Compaction pages isolated 498790 456130 Compaction migrate scanned 565371 524174 Compaction free scanned 4230296 4250744 Compaction cost 215 203 [1] https://lwn.net/Articles/684611/ This patch (of 11): A recent patch has added whole_zone flag that compaction sets when scanning starts from the zone boundary, in order to report that zone has been fully scanned in one attempt. For allocations that want to try really hard or cannot fail, we will want to introduce a mode where scanning whole zone is guaranteed regardless of the cached positions. This patch reuses the whole_zone flag in a way that if it's already passed true to compaction, the cached scanner positions are ignored. Employing this flag during reclaim/compaction loop will be done in the next patch. This patch however converts compaction invoked from userspace via procfs to use this flag. Before this patch, the cached positions were first reset to zone boundaries and then read back from struct zone, so there was a window where a parallel compaction could replace the reset values, making the manual compaction less effective. Using the flag instead of performing reset is more robust. [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/20160810091226.6709-2-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, compaction: simplify contended compaction handlingVlastimil Babka
Async compaction detects contention either due to failing trylock on zone->lock or lru_lock, or by need_resched(). Since 1f9efdef4f3f ("mm, compaction: khugepaged should not give up due to need_resched()") the code got quite complicated to distinguish these two up to the __alloc_pages_slowpath() level, so different decisions could be taken for khugepaged allocations. After the recent changes, khugepaged allocations don't check for contended compaction anymore, so we again don't need to distinguish lock and sched contention, and simplify the current convoluted code a lot. However, I believe it's also possible to simplify even more and completely remove the check for contended compaction after the initial async compaction for costly orders, which was originally aimed at THP page fault allocations. There are several reasons why this can be done now: - with the new defaults, THP page faults no longer do reclaim/compaction at all, unless the system admin has overridden the default, or application has indicated via madvise that it can benefit from THP's. In both cases, it means that the potential extra latency is expected and worth the benefits. - even if reclaim/compaction proceeds after this patch where it previously wouldn't, the second compaction attempt is still async and will detect the contention and back off, if the contention persists - there are still heuristics like deferred compaction and pageblock skip bits in place that prevent excessive THP page fault latencies Link: http://lkml.kernel.org/r/20160721073614.24395-9-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, page_alloc: remove fair zone allocation policyMel Gorman
The fair zone allocation policy interleaves allocation requests between zones to avoid an age inversion problem whereby new pages are reclaimed to balance a zone. Reclaim is now node-based so this should no longer be an issue and the fair zone allocation policy is not free. This patch removes it. Link: http://lkml.kernel.org/r/1467970510-21195-30-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
